  4. Raspberry Absturz alle 3 Tage
    5.5k
118 Beiträge 9 Kommentatoren 13.4k Aufrufe 7 Beobachtet
  • S shellyrulestheworld
    grafana auch gefixt. Echt toll :-)
    pi@raspberrypi:~ $ sudo apt update
    Hit:1 http://deb.debian.org/debian bullseye InRelease
    Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:5 https://phoscon.de/apt/deconz bullseye InRelease
    Hit:6 https://repos.influxdata.com/debian bullseye InRelease
    Hit:7 https://deb.nodesource.com/node_16.x bullseye InRelease
    Get:8 https://apt.grafana.com stable InRelease [5,984 B]
    Hit:9 https://packagecloud.io/ookla/speedtest-cli/debian bullseye InRelease
    Get:10 https://apt.grafana.com stable/main armhf Packages [62.8 kB]
    Get:11 https://apt.grafana.com stable/main arm64 Packages [64.8 kB]
    Fetched 134 kB in 3s (44.7 kB/s)
    Reading package lists... Done
    All packages are up to date.
    shellyrulestheworld
    schrieb am zuletzt editiert von shellyrulestheworld
    Heute leider das gleiche Spiel:
    2023-01-23 18:30:14.828 - warn: trashschedule.0 (1627) no events matches type "Altpapier" with match "Altpapier"
    2023-01-23 18:30:19.839 - info: ical.0 (64838) Terminated (NO_ERROR): Without reason
    2023-01-23 18:30:20.382 - info: host.raspberrypi instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
    2023-01-23 18:30:32.846 - info: admin.1 (739) <== Disconnect system.user.admin from ::ffff:192.168.178.37 admin
    2023-01-23 18:30:40.606 - info: daswetter.0 (64819) still wrong data structure from server received! repaired...
    2023-01-23 18:30:47.585 - info: admin.1 (739) <== Disconnect system.user.admin from ::ffff:192.168.178.37 admin
    2023-01-23 18:30:49.031 - info: daswetter.0 (64819) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
    2023-01-23 18:30:49.555 - info: daswetter.0 (64819) cleaned everything up...
    2023-01-23 18:30:49.584 - info: host.raspberrypi instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-01-23 18:32:30.483 - info: javascript.0 (806) Stop script script.js.Test.Test
    2023-01-23 18:33:38.234 - info: web.0 (1654) <== Disconnect system.user.admin from ::ffff:192.168.178.37 vis.0
    2023-01-23 18:33:59.666 - info: javascript.0 (806) Start javascript script.js.Test.Test
    2023-01-23 18:33:59.686 - info: javascript.0 (806) script.js.Test.Test: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
    2023-01-23 18:34:46.007 - info: javascript.0 (806) script.js.Test.Test: timeout hat zugeschlagen
    2023-01-23 18:35:00.238 - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 64966
    2023-01-23 18:35:04.018 - info: dwd.0 (64966) starting. Version 2.8.3 in /opt/iobroker/node_modules/iobroker.dwd, node: v16.19.0, js-controller: 4.0.24
    2023-01-23 18:35:09.773 - info: dwd.0 (64966) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-01-23 18:35:10.322 - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-01-23 18:35:50.683 - info: javascript.0 (806) script.js.Test.Test: timeout hat zugeschlagen
    2023-01-23 18:40:00.242 - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 65118
    2023-01-23 18:40:04.203 - info: dwd.0 (65118) starting. Version 2.8.3 in /opt/iobroker/node_modules/iobroker.dwd, node: v16.19.0, js-controller: 4.0.24
    2023-01-23 18:40:10.272 - info: dwd.0 (65118) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-01-23 18:40:10.807 - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-01-23 18:45:00.041 - info: javascript.0 (806) script.js.PV.VerbrauchsberechnungShellys: Shelly Verbrauch: Verbrauchswerte aktualisiert: 5 | Reboots korrigiert: 0 | Unveränderte Werte: 28
    2023-01-23 18:45:00.292 - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 65289
    2023-01-23 18:45:04.381 - info: host.raspberrypi instance system.adapter.daswetter.0 started with pid 65300
    2023-01-23 18:45:06.108 - info: dwd.0 (65289) starting. Version 2.8.3 in /opt/iobroker/node_modules/iobroker.dwd, node: v16.19.0, js-controller: 4.0.24
    2023-01-23 18:45:08.637 - info: daswetter.0 (65300) starting. Version 3.1.4 in /opt/iobroker/node_modules/iobroker.daswetter, node: v16.19.0, js-controller: 4.0.24
    2023-01-23 18:45:09.580 - error: pvforecast.0 (1536) [updateActualWeatherData] failed to update weather data: TypeError: data.filter is not a function
    2023-01-23 18:45:11.322 - info: dwd.0 (65289) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-01-23 18:45:11.946 - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-01-23 18:45:38.150 - info: daswetter.0 (65300) still wrong data structure from server received! repaired...
    2023-01-23 18:45:47.366 - info: daswetter.0 (65300) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
    2023-01-23 18:45:47.883 - info: daswetter.0 (65300) cleaned everything up...
    2023-01-23 18:45:47.907 - info: host.raspberrypi instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-01-23 18:47:24.927 - info: admin.1 (739) Request actual repository...
    2023-01-23 18:47:25.659 - info: host.raspberrypi Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
    2023-01-23 18:47:35.629 - info: hs100.0 (1413) cleaned everything up...
    2023-01-23 18:47:35.642 - error: pvforecast.0 (1536) States database error: read ECONNRESET
    2023-01-23 18:47:35.823 - error: trashschedule.0 (1627) States database error: read ECONNRESET
    2023-01-23 18:47:35.679 - info: zigbee.0 (1204) cleaned everything up...
    2023-01-23 18:47:35.676 - info: pollenflug.0 (37919) Closing Adapter
    2023-01-23 18:47:35.896 - info: trashschedule.0 (1627) cleaned everything up...
    2023-01-23 18:47:35.694 - info: javascript.0 (806) Stop script script.js.Heizungssteuerung.HeizungssteuerungBenno
    2023-01-23 18:47:35.682 - info: info.0 (1428) cleaned everything up...
    Zeile 47 und 48, wie auch schon davor..
    Thomas BraunT CodierknechtC apollon77A 3 Antworten Letzte Antwort
      @shellyrulestheworld sagte in Raspberry Absturz alle 3 Tage:
      Zeile 47 und 48,
      Da steht nix wildes drin.
        CodierknechtC Offline
        Codierknecht
        Mach mal Deine Credentials für den Google-Kalender unkenntlich - sonst hagelt's womöglich bald Termine 😁
        HmIP|ZigBee|Tasmota|Unifi
        Zabbix Certified Specialist
        • CodierknechtC Codierknecht
          shellyrulestheworld
          @codierknecht 😨 🤣
            @codierknecht 😨 🤣
            shellyrulestheworld
            Zeile 10 --> da hab ich wohl einen Adapter installiert... Da ging es gut
            2023-01-23 06:20:09.729 - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2023-01-23 06:20:59.603 - info: jarvis.0 (1493) Client with IP 192.168.178.37 connected.
            2023-01-23 06:21:55.238 - info: web.0 (1654) ==> Connected system.user.admin from ::ffff:192.168.178.37
            2023-01-23 06:22:09.760 - info: web.0 (1654) <== Disconnect system.user.admin from ::ffff:192.168.178.37 vis.0
            2023-01-23 06:22:13.959 - info: web.0 (1654) ==> Connected system.user.admin from ::ffff:192.168.178.37
            2023-01-23 06:22:19.926 - info: web.0 (1654) <== Disconnect system.user.admin from ::ffff:192.168.178.37 vis.0
            2023-01-23 06:22:32.239 - info: admin.1 (739) ==> Connected system.user.admin from ::ffff:192.168.178.37
            2023-01-23 06:24:08.833 - info: admin.1 (739) ==> Connected system.user.admin from ::ffff:192.168.178.37
            2023-01-23 06:24:45.302 - info: admin.1 (739) ==> Connected system.user.admin from ::ffff:192.168.178.37
            2023-01-23 06:24:49.474 - info: host.raspberrypi Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
            2023-01-23 06:25:02.363 - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 37640
            2023-01-23 06:25:07.766 - info: dwd.0 (37640) starting. Version 2.8.3 in /opt/iobroker/node_modules/iobroker.dwd, node: v16.19.0, js-controller: 4.0.24
            2023-01-23 06:25:10.465 - info: dwd.0 (37640) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            2023-01-23 06:25:11.019 - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2023-01-23 06:25:44.430 - info: admin.1 (739) <== Disconnect system.user.admin from ::ffff:192.168.178.37
            2023-01-23 06:27:53.204 - info: host.raspberrypi iobroker add pollenflug --host raspberrypi
            2023-01-23 06:27:58.536 - info: host.raspberrypi iobroker NPM version: 8.19.3Installing iobroker.pollenflug@1.0.6... (System call)
              shellyrulestheworld
              Es scheint, wenn der admin.1 das anfordert zu krachen. Wie oft macht der admin das denn?
                Codierknecht
                admin.1
                Wieso eigentlich admin.1. Hast Du mehr als eine Admin-Instanz laufen?
                  admin.1
                  shellyrulestheworld
                  @codierknecht nein, nur eine Admin Instanz. Am Anfang wollte mal die 8081 nicht mehr, dann habe ich eine admin.1 aufgemacht, Port 8089 und die als admin.1 gelassen.
                  admin.0 gibt es nicht mehr.
                  Kann das ein Problem sein?
                  S CodierknechtC 2 Antworten Letzte Antwort
                    shellyrulestheworld
                      shellyrulestheworld
                        @shellyrulestheworld meine Frage nach /var/log/syslog und was da zeitlich passend steht ist noch nicht beantwortet gewesen oder?!
                          Codierknecht
                          Nö - in dem Fall eher nicht.
                          • apollon77A apollon77
                            shellyrulestheworld
                            @apollon77 jetzt kommt ne doofe Frage: was möchtest du haben und wie lade ich es am besten herunter? 0c6581bb-4470-4462-ba9d-43db91f99eb3-grafik.png
                              CodeTags verwenden, keine Screenshots.
                              less -R /var/log/syslog
                                shellyrulestheworld
                                @thomas-braun da steht zu viel drin ... das hier in Codetags würde den Rahmen sprengen...
                                Beispiel:
                                videodevice /dev/video0 and input -1
                                Jan 22 00:01:20 raspberrypi motion: [1:ml1] [ALR] [VID] v4l2_device_open: Failed to open video device /dev/video0: No such file or directory
                                Jan 22 00:01:20 raspberrypi motion: [1:ml1] [ERR] [VID] vid_start: V4L2 device failed to open
                                Jan 22 00:01:30 raspberrypi motion: [1:ml1] [WRN] [ALL] mlp_retry: Retrying until successful connection with camera
                                Jan 22 00:01:30 raspberrypi motion: [1:ml1] [NTC] [VID] vid_start: Opening V4L2 device
                                Jan 22 00:01:30 raspberrypi motion: [1:ml1] [NTC] [VID] v4l2_device_open: Using videodevice /dev/video0 and input -1
                                Jan 22 00:01:30 raspberrypi motion: [1:ml1] [ALR] [VID] v4l2_device_open: Failed to open video device /dev/video0: No such file or directory
                                Jan 22 00:01:30 raspberrypi motion: [1:ml1] [ERR] [VID] vid_start: V4L2 device failed to open
                                Jan 22 00:01:40 raspberrypi motion: [1:ml1] [WRN] [ALL] mlp_retry: Retrying unti:
                                  Beispiel:
                                  Deswegen sollst du ja auch den zeitlich passenden Bereich posten.
                                  S 2 Antworten Letzte Antwort
                                    shellyrulestheworld
                                    Jan 23 18:47:10 raspberrypi motion: [1:ml1] [ALR] [VID] v4l2_device_open: Failed to open video device /dev/video0: No such file or directory
                                    Jan 23 18:47:10 raspberrypi motion: [1:ml1] [ERR] [VID] vid_start: V4L2 device failed to open
                                    Jan 23 18:47:20 raspberrypi motion: [1:ml1] [WRN] [ALL] mlp_retry: Retrying until successful connection with camera
                                    Jan 23 18:47:20 raspberrypi motion: [1:ml1] [NTC] [VID] vid_start: Opening V4L2 device
                                    Jan 23 18:47:20 raspberrypi motion: [1:ml1] [NTC] [VID] v4l2_device_open: Using videodevice /dev/video0 and input -1
                                    Jan 23 18:47:20 raspberrypi motion: [1:ml1] [ALR] [VID] v4l2_device_open: Failed to open video device /dev/video0: No such file or directory
                                    Jan 23 18:47:20 raspberrypi motion: [1:ml1] [ERR] [VID] vid_start: V4L2 device failed to open
                                    Jan 23 18:47:25 raspberrypi bash[712]: Send diag info: {"uuid":"f8c37d91-9714-ae1d-5ca5-563211cda069","language":"de","country":"Germany","hosts":[{"version":"4.0.24","platform":"Javascript
                                    /Node.js","type":"linux"}],"node":"v16.19.0","arch":"arm64","docker":false,"adapters":{"admin":{"version":"6.3.5","platform":"Javascript/Node.js"},"discovery":{"version":"3.1.0","platform":
                                    "Javascript/Node.js"},"backitup":{"version":"2.5.10","platform":"Javascript/Node.js"},"alexa2":{"version":"3.23.2","platform":"Javascript/Node.js"},"cloud":{"version":"4.3.0","platform":"Ja
                                    vascript/Node.js"},"devices":{"version":"1.1.2","platform":"Javascript/Node.js"},"dwd":{"version":"2.8.3","platform":"Javascript/Node.js"},"feiertage":{"version":"1.1.0","platform":"Javascr
                                    ipt/Node.js"},"fronius":{"version":"1.1.3","platform":"Javascript/Node.js"},"heizoel":{"version":"1.0.3","platform":"Javascript/Node.js"},"history":{"version":"2.2.4","platform":"Javascript
                                    /Node.js"},"homeconnect":{"version":"1.1.1","platform":"Javascript/Node.js"},"hs100":{"version":"2.1.2","platform":"Javascript/Node.js"},"ical":{"version":"1.13.2","platform":"Javascript/No
                                    de.js"},"icons-mfd-svg":{"version":"1.1.0","platform":"Javascript/Node.js"},"info":{"version":"1.9.19","platform":"Javascript/Node.js"},"iot":{"version":"1.14.2","platform":"Javascript/Node
                                    .js"},"jarvis":{"version":"3.1.2","platform":"Javascript/Node.js"},"javascript":{"version":"6.1.4","platform":"Javascript/Node.js"},"net-tools":{"version":"0.2.0","platform":"Javascript/Nod
                                    e.js"},"philips-air":{"version":"1.0.1","platform":"Javascript/Node.js"},"ping":{"version":"1.5.3","platform":"Javascript/Node.js"},"pvforecast":{"version":"2.3.0","platform":"Javascript/No
                                    de.js"},"shelly":{"version":"6.2.4","platform":"Javascript/Node.js"},"smartthings":{"version":"0.0.4","platform":"Javascript/Node.js"},"synology":{"version":"2.1.13","platform":"Javascript/
                                    Node.js"},"telegram":{"version":"1.15.2","platform":"Javascript/Node.js"},"terminal":{"version":"1.0.0","platform":"Javascript/Node.js"},"text2command":{"version":"2.3.0","platform":"Javasc
                                    ript/Node.js"},"tr-064":{"version":"4.2.17","platform":"Javascript/Node.js"},"trashschedule":{"version":"2.0.3","platform":"Javascript/Node.js"},"vis":{"version":"1.4.15","platform":"Javasc
                                    ript/Node.js"},"vis-hqwidgets":{"version":"1.3.0","platform":"Javascript/Node.js"},"vis-inventwo":{"version":"3.3.1","platform":"Javascript/Node.js"},"vis-material-advanced":{"version":"1.7
                                    .2","platform":"Javascript/Node.js"},"vis-materialdesign":{"version":"0.5.9","platform":"Javascript/Node.js"},"web":{"version":"4.3.0","platform":"Javascript/Node.js"},"zigbee":{"version":"
                                    1.8.10","platform":"Javascript/Node.js"},"influxdb":{"version":"3.2.0","platform":"Javascript/Node.js"},"simple-api":{"version":"2.7.2","platform":"Javascript/Node.js"},"tankerkoenig":{"ver
                                    sion":"3.3.6","platform":"Javascript/Node.js"},"vis-2-beta":{"version":"2.0.16","platform":"Javascript/Node.js"},"vis-2-widgets-material":{"version":"0.2.1","platform":"Javascript/Node.js"}
                                    ,"vis-2-widgets-energy":{"version":"0.1.3","platform":"Javascript/Node.js"},"vis-2-widgets-gauges":{"version":"0.1.4","platform":"Javascript/Node.js"},"upnp":{"version":"1.0.21","platform":
                                    "Javascript/Node.js"},"daswetter":{"version":"3.1.4","platform":"Javascript/Node.js"},"pollenflug":{"version":"1.0.6","platform":"Javascript/Node.js"},"alarm":{"version":"3.3.9","platform":
                                    "Javascript/Node.js"}},"statesType":"jsonl","objectsType":"jsonl","noInstances":50,"compactMode":false,"noCompactInstances":0,"model":"Cortex-A72","cpus":4,"mem":3926355968,"ostype":"Linux"
                                    ,"city":"Mössingen","vis":20}
                                    Jan 23 18:47:30 raspberrypi motion: [1:ml1] [WRN] [ALL] mlp_retry: Retrying until successful connection with camera
                                    Jan 23 18:47:30 raspberrypi motion: [1:ml1] [NTC] [VID] vid_start: Opening V4L2 device
                                    Jan 23 18:47:30 raspberrypi motion: [1:ml1] [NTC] [VID] v4l2_device_open: Using videodevice /dev/video0 and input -1
                                    Jan 23 18:47:30 raspberrypi motion: [1:ml1] [ALR] [VID] v4l2_device_open: Failed to open video device /dev/video0: No such file or directory
                                    Jan 23 18:47:30 raspberrypi motion: [1:ml1] [ERR] [VID] vid_start: V4L2 device failed to open
                                    Jan 23 18:47:34 raspberrypi kernel: [84968.088992] io.text2command invoked oom-killer: gfp_mask=0x1100cca(GFP_HIGHUSER_MOVABLE), order=0, oom_score_adj=0
                                    Jan 23 18:47:34 raspberrypi kernel: [84968.089018] CPU: 2 PID: 1593 Comm: io.text2command Tainted: G         C        5.15.84-v8+ #1613
                                    Jan 23 18:47:34 raspberrypi kernel: [84968.089025] Hardware name: Raspberry Pi 4 Model B Rev 1.5 (DT)
                                    Jan 23 18:47:34 raspberrypi kernel: [84968.089028] Call trace:
                                    Jan 23 18:47:34 raspberrypi kernel: [84968.089030]  dump_backtrace+0x0/0x1b8
                                    Jan 23 18:47:34 raspberrypi kernel: [84968.089045]  show_stack+0x20/0x30
                                    Jan 23 18:47:34 raspberrypi kernel: [84968.089051]  dump_stack_lvl+0x8c/0xb8
                                    Jan 23 18:47:34 raspberrypi kernel: [84968.089057]  dump_stack+0x18/0x34
                                    Jan 23 18:47:34 raspberrypi kernel: [84968.089061]  dump_header+0x4c/0x204
                                      shellyrulestheworld
                                      @thomas-braun reicht die Zeit oder noch mehr davor / danach ?
                                      • GaspodeG Online
                                        GaspodeG Online
                                        Gaspode
                                        Dazu hat @apollon77 schon vor längerer Zeit in einem anderen Thread was geschrieben:
                                        @apollon77 said in Iobroker stuerzt immer wieder mal ab:
                                        Wenn oom_reaper bzw oom_killer im
                                        Syslog stehen dann geht dir der Speicher aus und der Kernel schießt Prozesse ab. Also ramnutzung wird dein Problem sein. Es läuft mehr als du ram hast.
                                        Es ist also wohl so, wie er oben bereits vermutet hat:
                                        @apollon77 said in Raspberry Absturz alle 3 Tage:
                                        Ich tippe auf Zuviele Instanzen bei zu wenig RAM.
                                        • GaspodeG Gaspode
                                          shellyrulestheworld
                                          @gaspode
                                          aktuelle Werte (ich finde die nicht abnormal und RAM --> 11% aktuell)
                                          CPU: 25,85 %
                                          RAM: 11,6 %
                                          Betriebszeit: 14h
                                          Verfügbar: 4.0.24
                                          Installiert: 4.0.24
                                          Ereignisse: ⇥38 / ↦15
                                          Plattform: linux
                                          Betriebssystem: linux
                                          Architektur: arm64
                                          CPUs: 4
                                          Geschwindigkeit: 1800 MHz
                                          Modell: Cortex-A72
                                          RAM: 3.6 GB
                                          System-Betriebszeit: 1 T. 11:21:29
                                          Node.js: v16.19.0
                                          time: 1674538375851
                                          timeOffset: -60
                                          Adapter-Anzahl: 456
                                          NPM: 8.19.3
                                          Datenträgergröße: 58.3 GB
                                          Freier Festplattenspeicher: 47.7 GB
                                          Betriebszeit: 11:45:00
                                          Aktive Instanzen: 38
                                          Pfad: /opt/iobroker/
                                          aktiv: true
                                          _nodeCurrent: 16.19.0
                                          _nodeNewest: 16.19.0
                                          _nodeNewestNext: 16.19.0
                                          _npmCurrent: 8.19.3
                                          _npmNewest: 8.19.3
                                          _npmNewestNext: 8.19.3
                                          Thomas BraunT GaspodeG 2 Antworten Letzte Antwort
