  4. Raspberry Absturz alle 3 Tage
    5.5k
118 Beiträge 9 Kommentatoren 13.4k Aufrufe 7 Beobachtet
  • S shellyrulestheworld
    @shellyrulestheworld
    Zeile 10 --> da hab ich wohl einen Adapter installiert... Da ging es gut
    2023-01-23 06:20:09.729 - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-01-23 06:20:59.603 - info: jarvis.0 (1493) Client with IP 192.168.178.37 connected.
    2023-01-23 06:21:55.238 - info: web.0 (1654) ==> Connected system.user.admin from ::ffff:192.168.178.37
    2023-01-23 06:22:09.760 - info: web.0 (1654) <== Disconnect system.user.admin from ::ffff:192.168.178.37 vis.0
    2023-01-23 06:22:13.959 - info: web.0 (1654) ==> Connected system.user.admin from ::ffff:192.168.178.37
    2023-01-23 06:22:19.926 - info: web.0 (1654) <== Disconnect system.user.admin from ::ffff:192.168.178.37 vis.0
    2023-01-23 06:22:32.239 - info: admin.1 (739) ==> Connected system.user.admin from ::ffff:192.168.178.37
    2023-01-23 06:24:08.833 - info: admin.1 (739) ==> Connected system.user.admin from ::ffff:192.168.178.37
    2023-01-23 06:24:45.302 - info: admin.1 (739) ==> Connected system.user.admin from ::ffff:192.168.178.37
    2023-01-23 06:24:49.474 - info: host.raspberrypi Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
    2023-01-23 06:25:02.363 - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 37640
    2023-01-23 06:25:07.766 - info: dwd.0 (37640) starting. Version 2.8.3 in /opt/iobroker/node_modules/iobroker.dwd, node: v16.19.0, js-controller: 4.0.24
    2023-01-23 06:25:10.465 - info: dwd.0 (37640) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-01-23 06:25:11.019 - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-01-23 06:25:44.430 - info: admin.1 (739) <== Disconnect system.user.admin from ::ffff:192.168.178.37
    2023-01-23 06:27:53.204 - info: host.raspberrypi iobroker add pollenflug --host raspberrypi
    2023-01-23 06:27:58.536 - info: host.raspberrypi iobroker NPM version: 8.19.3Installing iobroker.pollenflug@1.0.6... (System call)
    shellyrulestheworld
    Es scheint, wenn der admin.1 das anfordert zu krachen. Wie oft macht der admin das denn?
      CodierknechtC Online
      Codierknecht
      @shellyrulestheworld sagte in Raspberry Absturz alle 3 Tage:
      admin.1
      Wieso eigentlich admin.1. Hast Du mehr als eine Admin-Instanz laufen?
      HmIP|ZigBee|Tasmota|Unifi
      Zabbix Certified Specialist
      • CodierknechtC Codierknecht
        admin.1
        shellyrulestheworld
        @codierknecht nein, nur eine Admin Instanz. Am Anfang wollte mal die 8081 nicht mehr, dann habe ich eine admin.1 aufgemacht, Port 8089 und die als admin.1 gelassen.
        admin.0 gibt es nicht mehr.
        Kann das ein Problem sein?
        S CodierknechtC 2 Antworten Letzte Antwort
          shellyrulestheworld
            shellyrulestheworld
              Heute leider das gleiche Spiel:
              2023-01-23 18:30:14.828 - warn: trashschedule.0 (1627) no events matches type "Altpapier" with match "Altpapier"
              2023-01-23 18:30:19.839 - info: ical.0 (64838) Terminated (NO_ERROR): Without reason
              2023-01-23 18:30:20.382 - info: host.raspberrypi instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
              2023-01-23 18:30:32.846 - info: admin.1 (739) <== Disconnect system.user.admin from ::ffff:192.168.178.37 admin
              2023-01-23 18:30:40.606 - info: daswetter.0 (64819) still wrong data structure from server received! repaired...
              2023-01-23 18:30:47.585 - info: admin.1 (739) <== Disconnect system.user.admin from ::ffff:192.168.178.37 admin
              2023-01-23 18:30:49.031 - info: daswetter.0 (64819) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
              2023-01-23 18:30:49.555 - info: daswetter.0 (64819) cleaned everything up...
              2023-01-23 18:30:49.584 - info: host.raspberrypi instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
              2023-01-23 18:32:30.483 - info: javascript.0 (806) Stop script script.js.Test.Test
              2023-01-23 18:33:38.234 - info: web.0 (1654) <== Disconnect system.user.admin from ::ffff:192.168.178.37 vis.0
              2023-01-23 18:33:59.666 - info: javascript.0 (806) Start javascript script.js.Test.Test
              2023-01-23 18:33:59.686 - info: javascript.0 (806) script.js.Test.Test: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
              2023-01-23 18:34:46.007 - info: javascript.0 (806) script.js.Test.Test: timeout hat zugeschlagen
              2023-01-23 18:35:00.238 - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 64966
              2023-01-23 18:35:04.018 - info: dwd.0 (64966) starting. Version 2.8.3 in /opt/iobroker/node_modules/iobroker.dwd, node: v16.19.0, js-controller: 4.0.24
              2023-01-23 18:35:09.773 - info: dwd.0 (64966) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
              2023-01-23 18:35:10.322 - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
              2023-01-23 18:35:50.683 - info: javascript.0 (806) script.js.Test.Test: timeout hat zugeschlagen
              2023-01-23 18:40:00.242 - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 65118
              2023-01-23 18:40:04.203 - info: dwd.0 (65118) starting. Version 2.8.3 in /opt/iobroker/node_modules/iobroker.dwd, node: v16.19.0, js-controller: 4.0.24
              2023-01-23 18:40:10.272 - info: dwd.0 (65118) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
              2023-01-23 18:40:10.807 - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
              2023-01-23 18:45:00.041 - info: javascript.0 (806) script.js.PV.VerbrauchsberechnungShellys: Shelly Verbrauch: Verbrauchswerte aktualisiert: 5 | Reboots korrigiert: 0 | Unveränderte Werte: 28
              2023-01-23 18:45:00.292 - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 65289
              2023-01-23 18:45:04.381 - info: host.raspberrypi instance system.adapter.daswetter.0 started with pid 65300
              2023-01-23 18:45:06.108 - info: dwd.0 (65289) starting. Version 2.8.3 in /opt/iobroker/node_modules/iobroker.dwd, node: v16.19.0, js-controller: 4.0.24
              2023-01-23 18:45:08.637 - info: daswetter.0 (65300) starting. Version 3.1.4 in /opt/iobroker/node_modules/iobroker.daswetter, node: v16.19.0, js-controller: 4.0.24
              2023-01-23 18:45:09.580 - error: pvforecast.0 (1536) [updateActualWeatherData] failed to update weather data: TypeError: data.filter is not a function
              2023-01-23 18:45:11.322 - info: dwd.0 (65289) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
              2023-01-23 18:45:11.946 - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
              2023-01-23 18:45:38.150 - info: daswetter.0 (65300) still wrong data structure from server received! repaired...
              2023-01-23 18:45:47.366 - info: daswetter.0 (65300) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
              2023-01-23 18:45:47.883 - info: daswetter.0 (65300) cleaned everything up...
              2023-01-23 18:45:47.907 - info: host.raspberrypi instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
              2023-01-23 18:47:24.927 - info: admin.1 (739) Request actual repository...
              2023-01-23 18:47:25.659 - info: host.raspberrypi Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
              2023-01-23 18:47:35.629 - info: hs100.0 (1413) cleaned everything up...
              2023-01-23 18:47:35.642 - error: pvforecast.0 (1536) States database error: read ECONNRESET
              2023-01-23 18:47:35.823 - error: trashschedule.0 (1627) States database error: read ECONNRESET
              2023-01-23 18:47:35.679 - info: zigbee.0 (1204) cleaned everything up...
              2023-01-23 18:47:35.676 - info: pollenflug.0 (37919) Closing Adapter
              2023-01-23 18:47:35.896 - info: trashschedule.0 (1627) cleaned everything up...
              2023-01-23 18:47:35.694 - info: javascript.0 (806) Stop script script.js.Heizungssteuerung.HeizungssteuerungBenno
              2023-01-23 18:47:35.682 - info: info.0 (1428) cleaned everything up...
              Zeile 47 und 48, wie auch schon davor..
              @shellyrulestheworld meine Frage nach /var/log/syslog und was da zeitlich passend steht ist noch nicht beantwortet gewesen oder?!
                Codierknecht
                Nö - in dem Fall eher nicht.
                • apollon77A apollon77
                  shellyrulestheworld
                  @apollon77 jetzt kommt ne doofe Frage: was möchtest du haben und wie lade ich es am besten herunter? 0c6581bb-4470-4462-ba9d-43db91f99eb3-grafik.png
                    CodeTags verwenden, keine Screenshots.
                    less -R /var/log/syslog
                      shellyrulestheworld
                      schrieb am zuletzt editiert von shellyrulestheworld
                      @thomas-braun da steht zu viel drin ... das hier in Codetags würde den Rahmen sprengen...
                      Beispiel:
                      videodevice /dev/video0 and input -1
                      Jan 22 00:01:20 raspberrypi motion: [1:ml1] [ALR] [VID] v4l2_device_open: Failed to open video device /dev/video0: No such file or directory
                      Jan 22 00:01:20 raspberrypi motion: [1:ml1] [ERR] [VID] vid_start: V4L2 device failed to open
                      Jan 22 00:01:30 raspberrypi motion: [1:ml1] [WRN] [ALL] mlp_retry: Retrying until successful connection with camera
                      Jan 22 00:01:30 raspberrypi motion: [1:ml1] [NTC] [VID] vid_start: Opening V4L2 device
                      Jan 22 00:01:30 raspberrypi motion: [1:ml1] [NTC] [VID] v4l2_device_open: Using videodevice /dev/video0 and input -1
                      Jan 22 00:01:30 raspberrypi motion: [1:ml1] [ALR] [VID] v4l2_device_open: Failed to open video device /dev/video0: No such file or directory
                      Jan 22 00:01:30 raspberrypi motion: [1:ml1] [ERR] [VID] vid_start: V4L2 device failed to open
                      Jan 22 00:01:40 raspberrypi motion: [1:ml1] [WRN] [ALL] mlp_retry: Retrying unti:
                        Beispiel:
                        Deswegen sollst du ja auch den zeitlich passenden Bereich posten.
                        S 2 Antworten Letzte Antwort
                          shellyrulestheworld
                          Jan 23 18:47:10 raspberrypi motion: [1:ml1] [ALR] [VID] v4l2_device_open: Failed to open video device /dev/video0: No such file or directory
                          Jan 23 18:47:10 raspberrypi motion: [1:ml1] [ERR] [VID] vid_start: V4L2 device failed to open
                          Jan 23 18:47:20 raspberrypi motion: [1:ml1] [WRN] [ALL] mlp_retry: Retrying until successful connection with camera
                          Jan 23 18:47:20 raspberrypi motion: [1:ml1] [NTC] [VID] vid_start: Opening V4L2 device
                          Jan 23 18:47:20 raspberrypi motion: [1:ml1] [NTC] [VID] v4l2_device_open: Using videodevice /dev/video0 and input -1
                          Jan 23 18:47:20 raspberrypi motion: [1:ml1] [ALR] [VID] v4l2_device_open: Failed to open video device /dev/video0: No such file or directory
                          Jan 23 18:47:20 raspberrypi motion: [1:ml1] [ERR] [VID] vid_start: V4L2 device failed to open
                          Jan 23 18:47:25 raspberrypi bash[712]: Send diag info: {"uuid":"f8c37d91-9714-ae1d-5ca5-563211cda069","language":"de","country":"Germany","hosts":[{"version":"4.0.24","platform":"Javascript
                          /Node.js","type":"linux"}],"node":"v16.19.0","arch":"arm64","docker":false,"adapters":{"admin":{"version":"6.3.5","platform":"Javascript/Node.js"},"discovery":{"version":"3.1.0","platform":
                          "Javascript/Node.js"},"backitup":{"version":"2.5.10","platform":"Javascript/Node.js"},"alexa2":{"version":"3.23.2","platform":"Javascript/Node.js"},"cloud":{"version":"4.3.0","platform":"Ja
                          vascript/Node.js"},"devices":{"version":"1.1.2","platform":"Javascript/Node.js"},"dwd":{"version":"2.8.3","platform":"Javascript/Node.js"},"feiertage":{"version":"1.1.0","platform":"Javascr
                          ipt/Node.js"},"fronius":{"version":"1.1.3","platform":"Javascript/Node.js"},"heizoel":{"version":"1.0.3","platform":"Javascript/Node.js"},"history":{"version":"2.2.4","platform":"Javascript
                          /Node.js"},"homeconnect":{"version":"1.1.1","platform":"Javascript/Node.js"},"hs100":{"version":"2.1.2","platform":"Javascript/Node.js"},"ical":{"version":"1.13.2","platform":"Javascript/No
                          de.js"},"icons-mfd-svg":{"version":"1.1.0","platform":"Javascript/Node.js"},"info":{"version":"1.9.19","platform":"Javascript/Node.js"},"iot":{"version":"1.14.2","platform":"Javascript/Node
                          .js"},"jarvis":{"version":"3.1.2","platform":"Javascript/Node.js"},"javascript":{"version":"6.1.4","platform":"Javascript/Node.js"},"net-tools":{"version":"0.2.0","platform":"Javascript/Nod
                          e.js"},"philips-air":{"version":"1.0.1","platform":"Javascript/Node.js"},"ping":{"version":"1.5.3","platform":"Javascript/Node.js"},"pvforecast":{"version":"2.3.0","platform":"Javascript/No
                          de.js"},"shelly":{"version":"6.2.4","platform":"Javascript/Node.js"},"smartthings":{"version":"0.0.4","platform":"Javascript/Node.js"},"synology":{"version":"2.1.13","platform":"Javascript/
                          Node.js"},"telegram":{"version":"1.15.2","platform":"Javascript/Node.js"},"terminal":{"version":"1.0.0","platform":"Javascript/Node.js"},"text2command":{"version":"2.3.0","platform":"Javasc
                          ript/Node.js"},"tr-064":{"version":"4.2.17","platform":"Javascript/Node.js"},"trashschedule":{"version":"2.0.3","platform":"Javascript/Node.js"},"vis":{"version":"1.4.15","platform":"Javasc
                          ript/Node.js"},"vis-hqwidgets":{"version":"1.3.0","platform":"Javascript/Node.js"},"vis-inventwo":{"version":"3.3.1","platform":"Javascript/Node.js"},"vis-material-advanced":{"version":"1.7
                          .2","platform":"Javascript/Node.js"},"vis-materialdesign":{"version":"0.5.9","platform":"Javascript/Node.js"},"web":{"version":"4.3.0","platform":"Javascript/Node.js"},"zigbee":{"version":"
                          1.8.10","platform":"Javascript/Node.js"},"influxdb":{"version":"3.2.0","platform":"Javascript/Node.js"},"simple-api":{"version":"2.7.2","platform":"Javascript/Node.js"},"tankerkoenig":{"ver
                          sion":"3.3.6","platform":"Javascript/Node.js"},"vis-2-beta":{"version":"2.0.16","platform":"Javascript/Node.js"},"vis-2-widgets-material":{"version":"0.2.1","platform":"Javascript/Node.js"}
                          ,"vis-2-widgets-energy":{"version":"0.1.3","platform":"Javascript/Node.js"},"vis-2-widgets-gauges":{"version":"0.1.4","platform":"Javascript/Node.js"},"upnp":{"version":"1.0.21","platform":
                          "Javascript/Node.js"},"daswetter":{"version":"3.1.4","platform":"Javascript/Node.js"},"pollenflug":{"version":"1.0.6","platform":"Javascript/Node.js"},"alarm":{"version":"3.3.9","platform":
                          "Javascript/Node.js"}},"statesType":"jsonl","objectsType":"jsonl","noInstances":50,"compactMode":false,"noCompactInstances":0,"model":"Cortex-A72","cpus":4,"mem":3926355968,"ostype":"Linux"
                          ,"city":"Mössingen","vis":20}
                          Jan 23 18:47:30 raspberrypi motion: [1:ml1] [WRN] [ALL] mlp_retry: Retrying until successful connection with camera
                          Jan 23 18:47:30 raspberrypi motion: [1:ml1] [NTC] [VID] vid_start: Opening V4L2 device
                          Jan 23 18:47:30 raspberrypi motion: [1:ml1] [NTC] [VID] v4l2_device_open: Using videodevice /dev/video0 and input -1
                          Jan 23 18:47:30 raspberrypi motion: [1:ml1] [ALR] [VID] v4l2_device_open: Failed to open video device /dev/video0: No such file or directory
                          Jan 23 18:47:30 raspberrypi motion: [1:ml1] [ERR] [VID] vid_start: V4L2 device failed to open
                          Jan 23 18:47:34 raspberrypi kernel: [84968.088992] io.text2command invoked oom-killer: gfp_mask=0x1100cca(GFP_HIGHUSER_MOVABLE), order=0, oom_score_adj=0
                          Jan 23 18:47:34 raspberrypi kernel: [84968.089018] CPU: 2 PID: 1593 Comm: io.text2command Tainted: G         C        5.15.84-v8+ #1613
                          Jan 23 18:47:34 raspberrypi kernel: [84968.089025] Hardware name: Raspberry Pi 4 Model B Rev 1.5 (DT)
                          Jan 23 18:47:34 raspberrypi kernel: [84968.089028] Call trace:
                          Jan 23 18:47:34 raspberrypi kernel: [84968.089030]  dump_backtrace+0x0/0x1b8
                          Jan 23 18:47:34 raspberrypi kernel: [84968.089045]  show_stack+0x20/0x30
                          Jan 23 18:47:34 raspberrypi kernel: [84968.089051]  dump_stack_lvl+0x8c/0xb8
                          Jan 23 18:47:34 raspberrypi kernel: [84968.089057]  dump_stack+0x18/0x34
                          Jan 23 18:47:34 raspberrypi kernel: [84968.089061]  dump_header+0x4c/0x204
                            shellyrulestheworld
                            @thomas-braun reicht die Zeit oder noch mehr davor / danach ?
                            • GaspodeG Offline
                              GaspodeG Offline
                              Gaspode
                              Dazu hat @apollon77 schon vor längerer Zeit in einem anderen Thread was geschrieben:
                              @apollon77 said in Iobroker stuerzt immer wieder mal ab:
                              Wenn oom_reaper bzw oom_killer im
                              Syslog stehen dann geht dir der Speicher aus und der Kernel schießt Prozesse ab. Also ramnutzung wird dein Problem sein. Es läuft mehr als du ram hast.
                              Es ist also wohl so, wie er oben bereits vermutet hat:
                              @apollon77 said in Raspberry Absturz alle 3 Tage:
                              Ich tippe auf Zuviele Instanzen bei zu wenig RAM.
                              • GaspodeG Gaspode
                                shellyrulestheworld
                                @gaspode
                                aktuelle Werte (ich finde die nicht abnormal und RAM --> 11% aktuell)
                                CPU: 25,85 %
                                RAM: 11,6 %
                                Betriebszeit: 14h
                                Verfügbar: 4.0.24
                                Installiert: 4.0.24
                                Ereignisse: ⇥38 / ↦15
                                Plattform: linux
                                Betriebssystem: linux
                                Architektur: arm64
                                CPUs: 4
                                Geschwindigkeit: 1800 MHz
                                Modell: Cortex-A72
                                RAM: 3.6 GB
                                System-Betriebszeit: 1 T. 11:21:29
                                Node.js: v16.19.0
                                time: 1674538375851
                                timeOffset: -60
                                Adapter-Anzahl: 456
                                NPM: 8.19.3
                                Datenträgergröße: 58.3 GB
                                Freier Festplattenspeicher: 47.7 GB
                                Betriebszeit: 11:45:00
                                Aktive Instanzen: 38
                                Pfad: /opt/iobroker/
                                aktiv: true
                                _nodeCurrent: 16.19.0
                                _nodeNewest: 16.19.0
                                _nodeNewestNext: 16.19.0
                                _npmCurrent: 8.19.3
                                _npmNewest: 8.19.3
                                _npmNewestNext: 8.19.3
                                Thomas BraunT GaspodeG 2 Antworten Letzte Antwort
                                  @gaspode
                                  CPU: 25,85 %
                                  RAM: 11,6 %
                                  Betriebszeit: 14h
                                  Verfügbar: 4.0.24
                                  Installiert: 4.0.24
                                  Plattform: linux
                                  Architektur: arm64
                                  CPUs: 4
                                  Modell: Cortex-A72
                                  RAM: 3.6 GB
                                  Node.js: v16.19.0
                                  time: 1674538375851
                                  timeOffset: -60
                                  Adapter-Anzahl: 456
                                  NPM: 8.19.3
                                  aktiv: true
                                  _npmCurrent: 8.19.3
                                  _npmNewest: 8.19.3
                                  Könnte Grenzwertig sein.
                                    @gaspode
                                    CPU: 25,85 %
                                    RAM: 11,6 %
                                    Betriebszeit: 14h
                                    Verfügbar: 4.0.24
                                    Installiert: 4.0.24
                                    Plattform: linux
                                    Architektur: arm64
                                    CPUs: 4
                                    Modell: Cortex-A72
                                    RAM: 3.6 GB
                                    Node.js: v16.19.0
                                    time: 1674538375851
                                    timeOffset: -60
                                    Adapter-Anzahl: 456
                                    NPM: 8.19.3
                                    aktiv: true
                                    _npmCurrent: 8.19.3
                                    _npmNewest: 8.19.3
                                    GaspodeG Offline
                                    GaspodeG Offline
                                    Gaspode
                                    schrieb am zuletzt editiert von Gaspode
                                    @shellyrulestheworld said in Raspberry Absturz alle 3 Tage:
                                    Er läuft jetzt ja auch erst 14 Stunden, und nach drei Tagen kommt es zu dem Problem. In der Zischenzeit kann viel passieren, die RAM Auslastung ist ja nur eine Momentaufnahme. Evtl. hast du auch einen Prozess, der allokierten Speicher nicht mehr sauber freigibt.
                                    Ich würde mir an deiner Stelle mal regelmäßig die RAM Auslastung ansehen, so etwa alle 4 bis 6 Stunden, ob ein Trend erkennbar ist.
                                    Hier zur Hintergrundinfo (was passenderes habe ich auf die Schnelle nicht gefunden, aber das Prinzip wird verständlich erklärt):
                                    https://neo4j.com/developer/kb/linux-out-of-memory-killer/
                                    • GaspodeG Gaspode
                                      @gaspode
                                      https://www.linuxatemyram.com/
                                      Prüf mal ob der v4l2 Kram da erforderlich ist. Kamera im Einsatz? Die scheint jedenfalls nicht korrekt installiert zu sein.
                                      S GaspodeG 3 Antworten Letzte Antwort
                                        @gaspode
                                        shellyrulestheworld
                                        @thomas-braun ich habe eine Netzwerkkamera im Einsatz. Von dem her brauch ich diese Kamera nicht. Deshalb hab ich die montion.conf angepasst und die Kamera "kommentiert" (Zeile 18)
                                        Müsste passen, oder?
                                          GNU nano 5.4                       motion.conf
                                        setup_mode off
                                        # File to store the process ID.
                                        ; pid_file value
                                        # File to write logs messages into.  If not defined stderr and syslog is used.
                                        ; log_file value
                                        # Level of log messages [1..9] (EMG, ALR, CRT, ERR, WRN, NTC, INF, DBG, ALL).
                                        log_level 6
                                        # Target directory for pictures, snapshots and movies
                                        ; target_dir value
                                        # Video device (e.g. /dev/video0) to be used for capturing.
                                        ;video_device /dev/video0
                                        # Parameters to control video device.  See motion_guide.html
                                        ; video_params value
                                          setup_mode off
                                          ; pid_file value
                                          ; log_file value
                                          log_level 6
                                          ; target_dir value
                                          Auskommentiert wird mit dem 'Gartenzaun'/ der Raute. Wie z. B. in Zeile 5 zusehen.
