  4. Raspberry Absturz alle 3 Tage
    5.5k
118 Beiträge 9 Kommentatoren 13.4k Aufrufe 7 Beobachtet
  • S shellyrulestheworld
    @thomas-braun da steht zu viel drin ... das hier in Codetags würde den Rahmen sprengen...
    Beispiel:
    videodevice /dev/video0 and input -1
    Jan 22 00:01:20 raspberrypi motion: [1:ml1] [ALR] [VID] v4l2_device_open: Failed to open video device /dev/video0: No such file or directory
    Jan 22 00:01:20 raspberrypi motion: [1:ml1] [ERR] [VID] vid_start: V4L2 device failed to open
    Jan 22 00:01:30 raspberrypi motion: [1:ml1] [WRN] [ALL] mlp_retry: Retrying until successful connection with camera
    Jan 22 00:01:30 raspberrypi motion: [1:ml1] [NTC] [VID] vid_start: Opening V4L2 device
    Jan 22 00:01:30 raspberrypi motion: [1:ml1] [NTC] [VID] v4l2_device_open: Using videodevice /dev/video0 and input -1
    Jan 22 00:01:30 raspberrypi motion: [1:ml1] [ALR] [VID] v4l2_device_open: Failed to open video device /dev/video0: No such file or directory
    Jan 22 00:01:30 raspberrypi motion: [1:ml1] [ERR] [VID] vid_start: V4L2 device failed to open
    Jan 22 00:01:40 raspberrypi motion: [1:ml1] [WRN] [ALL] mlp_retry: Retrying unti:
    @shellyrulestheworld
    Deswegen sollst du ja auch den zeitlich passenden Bereich posten.
    S 2 Antworten Letzte Antwort
      shellyrulestheworld
      Jan 23 18:47:10 raspberrypi motion: [1:ml1] [ALR] [VID] v4l2_device_open: Failed to open video device /dev/video0: No such file or directory
      Jan 23 18:47:10 raspberrypi motion: [1:ml1] [ERR] [VID] vid_start: V4L2 device failed to open
      Jan 23 18:47:20 raspberrypi motion: [1:ml1] [WRN] [ALL] mlp_retry: Retrying until successful connection with camera
      Jan 23 18:47:20 raspberrypi motion: [1:ml1] [NTC] [VID] vid_start: Opening V4L2 device
      Jan 23 18:47:20 raspberrypi motion: [1:ml1] [NTC] [VID] v4l2_device_open: Using videodevice /dev/video0 and input -1
      Jan 23 18:47:20 raspberrypi motion: [1:ml1] [ALR] [VID] v4l2_device_open: Failed to open video device /dev/video0: No such file or directory
      Jan 23 18:47:20 raspberrypi motion: [1:ml1] [ERR] [VID] vid_start: V4L2 device failed to open
      Jan 23 18:47:25 raspberrypi bash[712]: Send diag info: {"uuid":"f8c37d91-9714-ae1d-5ca5-563211cda069","language":"de","country":"Germany","hosts":[{"version":"4.0.24","platform":"Javascript
      /Node.js","type":"linux"}],"node":"v16.19.0","arch":"arm64","docker":false,"adapters":{"admin":{"version":"6.3.5","platform":"Javascript/Node.js"},"discovery":{"version":"3.1.0","platform":
      "Javascript/Node.js"},"backitup":{"version":"2.5.10","platform":"Javascript/Node.js"},"alexa2":{"version":"3.23.2","platform":"Javascript/Node.js"},"cloud":{"version":"4.3.0","platform":"Ja
      vascript/Node.js"},"devices":{"version":"1.1.2","platform":"Javascript/Node.js"},"dwd":{"version":"2.8.3","platform":"Javascript/Node.js"},"feiertage":{"version":"1.1.0","platform":"Javascr
      ipt/Node.js"},"fronius":{"version":"1.1.3","platform":"Javascript/Node.js"},"heizoel":{"version":"1.0.3","platform":"Javascript/Node.js"},"history":{"version":"2.2.4","platform":"Javascript
      /Node.js"},"homeconnect":{"version":"1.1.1","platform":"Javascript/Node.js"},"hs100":{"version":"2.1.2","platform":"Javascript/Node.js"},"ical":{"version":"1.13.2","platform":"Javascript/No
      de.js"},"icons-mfd-svg":{"version":"1.1.0","platform":"Javascript/Node.js"},"info":{"version":"1.9.19","platform":"Javascript/Node.js"},"iot":{"version":"1.14.2","platform":"Javascript/Node
      .js"},"jarvis":{"version":"3.1.2","platform":"Javascript/Node.js"},"javascript":{"version":"6.1.4","platform":"Javascript/Node.js"},"net-tools":{"version":"0.2.0","platform":"Javascript/Nod
      e.js"},"philips-air":{"version":"1.0.1","platform":"Javascript/Node.js"},"ping":{"version":"1.5.3","platform":"Javascript/Node.js"},"pvforecast":{"version":"2.3.0","platform":"Javascript/No
      de.js"},"shelly":{"version":"6.2.4","platform":"Javascript/Node.js"},"smartthings":{"version":"0.0.4","platform":"Javascript/Node.js"},"synology":{"version":"2.1.13","platform":"Javascript/
      Node.js"},"telegram":{"version":"1.15.2","platform":"Javascript/Node.js"},"terminal":{"version":"1.0.0","platform":"Javascript/Node.js"},"text2command":{"version":"2.3.0","platform":"Javasc
      ript/Node.js"},"tr-064":{"version":"4.2.17","platform":"Javascript/Node.js"},"trashschedule":{"version":"2.0.3","platform":"Javascript/Node.js"},"vis":{"version":"1.4.15","platform":"Javasc
      ript/Node.js"},"vis-hqwidgets":{"version":"1.3.0","platform":"Javascript/Node.js"},"vis-inventwo":{"version":"3.3.1","platform":"Javascript/Node.js"},"vis-material-advanced":{"version":"1.7
      .2","platform":"Javascript/Node.js"},"vis-materialdesign":{"version":"0.5.9","platform":"Javascript/Node.js"},"web":{"version":"4.3.0","platform":"Javascript/Node.js"},"zigbee":{"version":"
      1.8.10","platform":"Javascript/Node.js"},"influxdb":{"version":"3.2.0","platform":"Javascript/Node.js"},"simple-api":{"version":"2.7.2","platform":"Javascript/Node.js"},"tankerkoenig":{"ver
      sion":"3.3.6","platform":"Javascript/Node.js"},"vis-2-beta":{"version":"2.0.16","platform":"Javascript/Node.js"},"vis-2-widgets-material":{"version":"0.2.1","platform":"Javascript/Node.js"}
      ,"vis-2-widgets-energy":{"version":"0.1.3","platform":"Javascript/Node.js"},"vis-2-widgets-gauges":{"version":"0.1.4","platform":"Javascript/Node.js"},"upnp":{"version":"1.0.21","platform":
      "Javascript/Node.js"},"daswetter":{"version":"3.1.4","platform":"Javascript/Node.js"},"pollenflug":{"version":"1.0.6","platform":"Javascript/Node.js"},"alarm":{"version":"3.3.9","platform":
      "Javascript/Node.js"}},"statesType":"jsonl","objectsType":"jsonl","noInstances":50,"compactMode":false,"noCompactInstances":0,"model":"Cortex-A72","cpus":4,"mem":3926355968,"ostype":"Linux"
      ,"city":"Mössingen","vis":20}
      Jan 23 18:47:30 raspberrypi motion: [1:ml1] [WRN] [ALL] mlp_retry: Retrying until successful connection with camera
      Jan 23 18:47:30 raspberrypi motion: [1:ml1] [NTC] [VID] vid_start: Opening V4L2 device
      Jan 23 18:47:30 raspberrypi motion: [1:ml1] [NTC] [VID] v4l2_device_open: Using videodevice /dev/video0 and input -1
      Jan 23 18:47:30 raspberrypi motion: [1:ml1] [ALR] [VID] v4l2_device_open: Failed to open video device /dev/video0: No such file or directory
      Jan 23 18:47:30 raspberrypi motion: [1:ml1] [ERR] [VID] vid_start: V4L2 device failed to open
      Jan 23 18:47:34 raspberrypi kernel: [84968.088992] io.text2command invoked oom-killer: gfp_mask=0x1100cca(GFP_HIGHUSER_MOVABLE), order=0, oom_score_adj=0
      Jan 23 18:47:34 raspberrypi kernel: [84968.089018] CPU: 2 PID: 1593 Comm: io.text2command Tainted: G         C        5.15.84-v8+ #1613
      Jan 23 18:47:34 raspberrypi kernel: [84968.089025] Hardware name: Raspberry Pi 4 Model B Rev 1.5 (DT)
      Jan 23 18:47:34 raspberrypi kernel: [84968.089028] Call trace:
      Jan 23 18:47:34 raspberrypi kernel: [84968.089030]  dump_backtrace+0x0/0x1b8
      Jan 23 18:47:34 raspberrypi kernel: [84968.089045]  show_stack+0x20/0x30
      Jan 23 18:47:34 raspberrypi kernel: [84968.089051]  dump_stack_lvl+0x8c/0xb8
      Jan 23 18:47:34 raspberrypi kernel: [84968.089057]  dump_stack+0x18/0x34
      Jan 23 18:47:34 raspberrypi kernel: [84968.089061]  dump_header+0x4c/0x204
        shellyrulestheworld
        @thomas-braun reicht die Zeit oder noch mehr davor / danach ?
        • GaspodeG Offline
          GaspodeG Offline
          Gaspode
          Dazu hat @apollon77 schon vor längerer Zeit in einem anderen Thread was geschrieben:
          @apollon77 said in Iobroker stuerzt immer wieder mal ab:
          Wenn oom_reaper bzw oom_killer im
          Syslog stehen dann geht dir der Speicher aus und der Kernel schießt Prozesse ab. Also ramnutzung wird dein Problem sein. Es läuft mehr als du ram hast.
          Es ist also wohl so, wie er oben bereits vermutet hat:
          @apollon77 said in Raspberry Absturz alle 3 Tage:
          Ich tippe auf Zuviele Instanzen bei zu wenig RAM.
          • GaspodeG Gaspode
            shellyrulestheworld
            @gaspode
            aktuelle Werte (ich finde die nicht abnormal und RAM --> 11% aktuell)
            CPU: 25,85 %
            RAM: 11,6 %
            Betriebszeit: 14h
            Verfügbar: 4.0.24
            Installiert: 4.0.24
            Ereignisse: ⇥38 / ↦15
            Plattform: linux
            Betriebssystem: linux
            Architektur: arm64
            CPUs: 4
            Geschwindigkeit: 1800 MHz
            Modell: Cortex-A72
            RAM: 3.6 GB
            System-Betriebszeit: 1 T. 11:21:29
            Node.js: v16.19.0
            time: 1674538375851
            timeOffset: -60
            Adapter-Anzahl: 456
            NPM: 8.19.3
            Datenträgergröße: 58.3 GB
            Freier Festplattenspeicher: 47.7 GB
            Betriebszeit: 11:45:00
            Aktive Instanzen: 38
            Pfad: /opt/iobroker/
            aktiv: true
            _nodeCurrent: 16.19.0
            _nodeNewest: 16.19.0
            _nodeNewestNext: 16.19.0
            _npmCurrent: 8.19.3
            _npmNewest: 8.19.3
            _npmNewestNext: 8.19.3
            Thomas BraunT GaspodeG 2 Antworten Letzte Antwort
              @gaspode
              CPU: 25,85 %
              RAM: 11,6 %
              Betriebszeit: 14h
              Verfügbar: 4.0.24
              Installiert: 4.0.24
              Plattform: linux
              Architektur: arm64
              CPUs: 4
              Modell: Cortex-A72
              RAM: 3.6 GB
              Node.js: v16.19.0
              time: 1674538375851
              timeOffset: -60
              Adapter-Anzahl: 456
              NPM: 8.19.3
              aktiv: true
              _npmCurrent: 8.19.3
              _npmNewest: 8.19.3
              @shellyrulestheworld sagte in Raspberry Absturz alle 3 Tage:
              Könnte Grenzwertig sein.
                @gaspode
                CPU: 25,85 %
                RAM: 11,6 %
                Betriebszeit: 14h
                Verfügbar: 4.0.24
                Installiert: 4.0.24
                Plattform: linux
                Architektur: arm64
                CPUs: 4
                Modell: Cortex-A72
                RAM: 3.6 GB
                Node.js: v16.19.0
                time: 1674538375851
                timeOffset: -60
                Adapter-Anzahl: 456
                NPM: 8.19.3
                aktiv: true
                _npmCurrent: 8.19.3
                _npmNewest: 8.19.3
                GaspodeG Offline
                GaspodeG Offline
                Gaspode
                schrieb am zuletzt editiert von Gaspode
                @shellyrulestheworld said in Raspberry Absturz alle 3 Tage:
                Er läuft jetzt ja auch erst 14 Stunden, und nach drei Tagen kommt es zu dem Problem. In der Zischenzeit kann viel passieren, die RAM Auslastung ist ja nur eine Momentaufnahme. Evtl. hast du auch einen Prozess, der allokierten Speicher nicht mehr sauber freigibt.
                Ich würde mir an deiner Stelle mal regelmäßig die RAM Auslastung ansehen, so etwa alle 4 bis 6 Stunden, ob ein Trend erkennbar ist.
                Hier zur Hintergrundinfo (was passenderes habe ich auf die Schnelle nicht gefunden, aber das Prinzip wird verständlich erklärt):
                https://neo4j.com/developer/kb/linux-out-of-memory-killer/
                • GaspodeG Gaspode
                  @gaspode
                  https://www.linuxatemyram.com/
                  Prüf mal ob der v4l2 Kram da erforderlich ist. Kamera im Einsatz? Die scheint jedenfalls nicht korrekt installiert zu sein.
                  S GaspodeG 3 Antworten Letzte Antwort
                    @gaspode
                    shellyrulestheworld
                    @thomas-braun ich habe eine Netzwerkkamera im Einsatz. Von dem her brauch ich diese Kamera nicht. Deshalb hab ich die montion.conf angepasst und die Kamera "kommentiert" (Zeile 18)
                    Müsste passen, oder?
                      GNU nano 5.4                       motion.conf
                    setup_mode off
                    # File to store the process ID.
                    ; pid_file value
                    # File to write logs messages into.  If not defined stderr and syslog is used.
                    ; log_file value
                    # Level of log messages [1..9] (EMG, ALR, CRT, ERR, WRN, NTC, INF, DBG, ALL).
                    log_level 6
                    # Target directory for pictures, snapshots and movies
                    ; target_dir value
                    # Video device (e.g. /dev/video0) to be used for capturing.
                    ;video_device /dev/video0
                    # Parameters to control video device.  See motion_guide.html
                    ; video_params value
                      setup_mode off
                      ; pid_file value
                      ; log_file value
                      log_level 6
                      ; target_dir value
                      Auskommentiert wird mit dem 'Gartenzaun'/ der Raute. Wie z. B. in Zeile 5 zusehen.
                        @gaspode
                        shellyrulestheworld
                        @thomas-braun wie kann man denn ans Ende der syslog springen? Beim scrollen wird man ja wahnsinnig ;-)
                        und ich habe mal nicht genutzte Instanzen deinstalliert bzw. teilweise pausiert.
                          tail -f /var/log/syslog
                            @gaspode
                            GaspodeG Offline
                            GaspodeG Offline
                            Gaspode
                            @thomas-braun said in Raspberry Absturz alle 3 Tage:
                            Ja Danke, in "meinem" Link wird das Prinzip von OOM-Killer erklärt, deshalb hatte ich den gewählt.
                            Auf jeden Fall ist es ein deutlicher Hinweis auf (zu) wenig Memory, wenn OOM-Killer zuschlägt, soweit ich das verstehe.
                            • GaspodeG Gaspode
                              #66
                              @gaspode sagte in Raspberry Absturz alle 3 Tage:
                              Ja, der OOM-Killer haut zunächst für das Kernsystem unwesentliche Prozesse ins Nirvana.
                                shellyrulestheworld
                                #67
                                hab ";" durch "#" ersetzt. Aber leider scheint Motion immer noch nach der Kamera zu suchen. Hat jemand noch einen Tipp bzgl. Motion ? ;-)
                                Jan 24 09:54:20 raspberrypi motion: [1:ml1] [ALR] [VID] v4l2_device_open: Failed                         to open video device /dev/video0: No such file or directory
                                Jan 24 09:54:20 raspberrypi motion: [1:ml1] [ERR] [VID] vid_start: V4L2 device f                        ailed to open
                                Jan 24 09:54:30 raspberrypi motion: [1:ml1] [WRN] [ALL] mlp_retry: Retrying until successful connection with camera
                                Jan 24 09:54:30 raspberrypi motion: [1:ml1] [NTC] [VID] vid_start: Opening V4L2 device
                                Jan 24 09:54:30 raspberrypi motion: [1:ml1] [NTC] [VID] v4l2_device_open: Using videodevice /dev/video0 and input -1
                                Jan 24 09:54:30 raspberrypi motion: [1:ml1] [ALR] [VID] v4l2_device_open: Failed to open video device /dev/video0: No such file or directory
                                Jan 24 09:54:30 raspberrypi motion: [1:ml1] [ERR] [VID] vid_start: V4L2 device failed to open
                                Thomas BraunT GaspodeG ? 3 Antworten Letzte Antwort
                                  #68
                                  Ich kenne motion nicht.
                                  @Gaspode
                                  Steht auch drin:
                                  Warning signs of a genuine low memory situation that you may want to look into:
                                  • available memory (or "free + buffers/cache") is close to zero
                                  • swap used increases or fluctuates
                                  • dmesg | grep oom-killer shows the OutOfMemory-killer at work
                                    GaspodeG Offline
                                    GaspodeG Offline
                                    Gaspode
                                    #69
                                    Hast du Motion danach auch neu gestartet? Ich kenne Motion nicht, aber mich würde überraschen, wenn da eine Konfigurationsänderung im laufenden Betrieb eine Auswirkung hat.
                                    Während der Anzeige mit less kannst du auch durch Eingabe von einem großen G ans Ende der Datei springen.
                                    • GaspodeG Gaspode
                                      shellyrulestheworld
                                      #70
                                      @gaspode
                                      Danke für den Tipp. Service neu starten hat leider nichts gebracht. Ich verstehe das motion noch nicht ganz...
                                        #71
                                        kenne motion auch nicht, aber als ich mit der Fehlermeldung mal gegoogelt habe, bekam ich einige Treffer ;)
                                        Dieser Befehl zeigt Dir welche Devices vom v4l2 erkannt werden.
                                        v4l2-ctl --list-devices
                                        Ist der Treiber geladen, das kannst Du mit dem Befehl unten testen, wenn leer dann ist der Treiber nicht geladen und muss mit dem zweiten Befehl geladen werden.
                                        lsmod | grep -i  "bcm2835-v4l2"
                                        sudo modprobe bcm2835-v4l2
                                        Natürlich den Treiber einsetzen der für Deine Hardware passt.
                                        Mit
                                        man lsmod
                                        man modprobe
                                        bekommst Du die Hilfeseiten, damit Du weist, was du da Tust.
                                        Wie Du das dann reboot fest machst musst Du selbst suchen, habe kein ResPI und auch kein Motion
                                        Bernd
                                          shellyrulestheworld
                                          #72
                                          ich habe die automatischen Updates im iobroker ausgeschaltet und seither läuft das System stabil. Ab und zu mache ich "deinen 3-Satz" um das System aktuell zu halten - klappt bestens.
                                          Wenn ich jetzt aber gelegentlich im Admin auf "Adapter auf Updates prüfen" klicke kommt ein Reboot. Manchmal tut es auch, aber ich habe das Gefühl, dass seit einiger Zeit keine Updates mehr für die Apdater gekommen sind.
