  4. Raspberry Absturz alle 3 Tage
    5.5k
118 Beiträge 9 Kommentatoren 13.4k Aufrufe 7 Beobachtet
  • S shellyrulestheworld
    shellyrulestheworld
      Heute leider das gleiche Spiel:
      2023-01-23 18:30:14.828 - warn: trashschedule.0 (1627) no events matches type "Altpapier" with match "Altpapier"
      2023-01-23 18:30:19.839 - info: ical.0 (64838) Terminated (NO_ERROR): Without reason
      2023-01-23 18:30:20.382 - info: host.raspberrypi instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
      2023-01-23 18:30:32.846 - info: admin.1 (739) <== Disconnect system.user.admin from ::ffff:192.168.178.37 admin
      2023-01-23 18:30:40.606 - info: daswetter.0 (64819) still wrong data structure from server received! repaired...
      2023-01-23 18:30:47.585 - info: admin.1 (739) <== Disconnect system.user.admin from ::ffff:192.168.178.37 admin
      2023-01-23 18:30:49.031 - info: daswetter.0 (64819) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
      2023-01-23 18:30:49.555 - info: daswetter.0 (64819) cleaned everything up...
      2023-01-23 18:30:49.584 - info: host.raspberrypi instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-01-23 18:32:30.483 - info: javascript.0 (806) Stop script script.js.Test.Test
      2023-01-23 18:33:38.234 - info: web.0 (1654) <== Disconnect system.user.admin from ::ffff:192.168.178.37 vis.0
      2023-01-23 18:33:59.666 - info: javascript.0 (806) Start javascript script.js.Test.Test
      2023-01-23 18:33:59.686 - info: javascript.0 (806) script.js.Test.Test: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
      2023-01-23 18:34:46.007 - info: javascript.0 (806) script.js.Test.Test: timeout hat zugeschlagen
      2023-01-23 18:35:00.238 - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 64966
      2023-01-23 18:35:04.018 - info: dwd.0 (64966) starting. Version 2.8.3 in /opt/iobroker/node_modules/iobroker.dwd, node: v16.19.0, js-controller: 4.0.24
      2023-01-23 18:35:09.773 - info: dwd.0 (64966) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-01-23 18:35:10.322 - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-01-23 18:35:50.683 - info: javascript.0 (806) script.js.Test.Test: timeout hat zugeschlagen
      2023-01-23 18:40:00.242 - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 65118
      2023-01-23 18:40:04.203 - info: dwd.0 (65118) starting. Version 2.8.3 in /opt/iobroker/node_modules/iobroker.dwd, node: v16.19.0, js-controller: 4.0.24
      2023-01-23 18:40:10.272 - info: dwd.0 (65118) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-01-23 18:40:10.807 - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-01-23 18:45:00.041 - info: javascript.0 (806) script.js.PV.VerbrauchsberechnungShellys: Shelly Verbrauch: Verbrauchswerte aktualisiert: 5 | Reboots korrigiert: 0 | Unveränderte Werte: 28
      2023-01-23 18:45:00.292 - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 65289
      2023-01-23 18:45:04.381 - info: host.raspberrypi instance system.adapter.daswetter.0 started with pid 65300
      2023-01-23 18:45:06.108 - info: dwd.0 (65289) starting. Version 2.8.3 in /opt/iobroker/node_modules/iobroker.dwd, node: v16.19.0, js-controller: 4.0.24
      2023-01-23 18:45:08.637 - info: daswetter.0 (65300) starting. Version 3.1.4 in /opt/iobroker/node_modules/iobroker.daswetter, node: v16.19.0, js-controller: 4.0.24
      2023-01-23 18:45:09.580 - error: pvforecast.0 (1536) [updateActualWeatherData] failed to update weather data: TypeError: data.filter is not a function
      2023-01-23 18:45:11.322 - info: dwd.0 (65289) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-01-23 18:45:11.946 - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-01-23 18:45:38.150 - info: daswetter.0 (65300) still wrong data structure from server received! repaired...
      2023-01-23 18:45:47.366 - info: daswetter.0 (65300) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
      2023-01-23 18:45:47.883 - info: daswetter.0 (65300) cleaned everything up...
      2023-01-23 18:45:47.907 - info: host.raspberrypi instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-01-23 18:47:24.927 - info: admin.1 (739) Request actual repository...
      2023-01-23 18:47:25.659 - info: host.raspberrypi Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
      2023-01-23 18:47:35.629 - info: hs100.0 (1413) cleaned everything up...
      2023-01-23 18:47:35.642 - error: pvforecast.0 (1536) States database error: read ECONNRESET
      2023-01-23 18:47:35.823 - error: trashschedule.0 (1627) States database error: read ECONNRESET
      2023-01-23 18:47:35.679 - info: zigbee.0 (1204) cleaned everything up...
      2023-01-23 18:47:35.676 - info: pollenflug.0 (37919) Closing Adapter
      2023-01-23 18:47:35.896 - info: trashschedule.0 (1627) cleaned everything up...
      2023-01-23 18:47:35.694 - info: javascript.0 (806) Stop script script.js.Heizungssteuerung.HeizungssteuerungBenno
      2023-01-23 18:47:35.682 - info: info.0 (1428) cleaned everything up...
      Zeile 47 und 48, wie auch schon davor..
      @shellyrulestheworld meine Frage nach /var/log/syslog und was da zeitlich passend steht ist noch nicht beantwortet gewesen oder?!
        @codierknecht nein, nur eine Admin Instanz. Am Anfang wollte mal die 8081 nicht mehr, dann habe ich eine admin.1 aufgemacht, Port 8089 und die als admin.1 gelassen.
        admin.0 gibt es nicht mehr.
        Kann das ein Problem sein?
        CodierknechtC Online
        Codierknecht
        @shellyrulestheworld sagte in Raspberry Absturz alle 3 Tage:
        Nö - in dem Fall eher nicht.
        HmIP|ZigBee|Tasmota|Unifi
        Zabbix Certified Specialist
        • apollon77A apollon77
          shellyrulestheworld
          @apollon77 jetzt kommt ne doofe Frage: was möchtest du haben und wie lade ich es am besten herunter? 0c6581bb-4470-4462-ba9d-43db91f99eb3-grafik.png
            CodeTags verwenden, keine Screenshots.
            less -R /var/log/syslog
              shellyrulestheworld
              schrieb am zuletzt editiert von shellyrulestheworld
              @thomas-braun da steht zu viel drin ... das hier in Codetags würde den Rahmen sprengen...
              Beispiel:
              videodevice /dev/video0 and input -1
              Jan 22 00:01:20 raspberrypi motion: [1:ml1] [ALR] [VID] v4l2_device_open: Failed to open video device /dev/video0: No such file or directory
              Jan 22 00:01:20 raspberrypi motion: [1:ml1] [ERR] [VID] vid_start: V4L2 device failed to open
              Jan 22 00:01:30 raspberrypi motion: [1:ml1] [WRN] [ALL] mlp_retry: Retrying until successful connection with camera
              Jan 22 00:01:30 raspberrypi motion: [1:ml1] [NTC] [VID] vid_start: Opening V4L2 device
              Jan 22 00:01:30 raspberrypi motion: [1:ml1] [NTC] [VID] v4l2_device_open: Using videodevice /dev/video0 and input -1
              Jan 22 00:01:30 raspberrypi motion: [1:ml1] [ALR] [VID] v4l2_device_open: Failed to open video device /dev/video0: No such file or directory
              Jan 22 00:01:30 raspberrypi motion: [1:ml1] [ERR] [VID] vid_start: V4L2 device failed to open
              Jan 22 00:01:40 raspberrypi motion: [1:ml1] [WRN] [ALL] mlp_retry: Retrying unti:
                Beispiel:
                Deswegen sollst du ja auch den zeitlich passenden Bereich posten.
                S 2 Antworten Letzte Antwort
                  shellyrulestheworld
                  Jan 23 18:47:10 raspberrypi motion: [1:ml1] [ALR] [VID] v4l2_device_open: Failed to open video device /dev/video0: No such file or directory
                  Jan 23 18:47:10 raspberrypi motion: [1:ml1] [ERR] [VID] vid_start: V4L2 device failed to open
                  Jan 23 18:47:20 raspberrypi motion: [1:ml1] [WRN] [ALL] mlp_retry: Retrying until successful connection with camera
                  Jan 23 18:47:20 raspberrypi motion: [1:ml1] [NTC] [VID] vid_start: Opening V4L2 device
                  Jan 23 18:47:20 raspberrypi motion: [1:ml1] [NTC] [VID] v4l2_device_open: Using videodevice /dev/video0 and input -1
                  Jan 23 18:47:20 raspberrypi motion: [1:ml1] [ALR] [VID] v4l2_device_open: Failed to open video device /dev/video0: No such file or directory
                  Jan 23 18:47:20 raspberrypi motion: [1:ml1] [ERR] [VID] vid_start: V4L2 device failed to open
                  Jan 23 18:47:25 raspberrypi bash[712]: Send diag info: {"uuid":"f8c37d91-9714-ae1d-5ca5-563211cda069","language":"de","country":"Germany","hosts":[{"version":"4.0.24","platform":"Javascript
                  /Node.js","type":"linux"}],"node":"v16.19.0","arch":"arm64","docker":false,"adapters":{"admin":{"version":"6.3.5","platform":"Javascript/Node.js"},"discovery":{"version":"3.1.0","platform":
                  "Javascript/Node.js"},"backitup":{"version":"2.5.10","platform":"Javascript/Node.js"},"alexa2":{"version":"3.23.2","platform":"Javascript/Node.js"},"cloud":{"version":"4.3.0","platform":"Ja
                  vascript/Node.js"},"devices":{"version":"1.1.2","platform":"Javascript/Node.js"},"dwd":{"version":"2.8.3","platform":"Javascript/Node.js"},"feiertage":{"version":"1.1.0","platform":"Javascr
                  ipt/Node.js"},"fronius":{"version":"1.1.3","platform":"Javascript/Node.js"},"heizoel":{"version":"1.0.3","platform":"Javascript/Node.js"},"history":{"version":"2.2.4","platform":"Javascript
                  /Node.js"},"homeconnect":{"version":"1.1.1","platform":"Javascript/Node.js"},"hs100":{"version":"2.1.2","platform":"Javascript/Node.js"},"ical":{"version":"1.13.2","platform":"Javascript/No
                  de.js"},"icons-mfd-svg":{"version":"1.1.0","platform":"Javascript/Node.js"},"info":{"version":"1.9.19","platform":"Javascript/Node.js"},"iot":{"version":"1.14.2","platform":"Javascript/Node
                  .js"},"jarvis":{"version":"3.1.2","platform":"Javascript/Node.js"},"javascript":{"version":"6.1.4","platform":"Javascript/Node.js"},"net-tools":{"version":"0.2.0","platform":"Javascript/Nod
                  e.js"},"philips-air":{"version":"1.0.1","platform":"Javascript/Node.js"},"ping":{"version":"1.5.3","platform":"Javascript/Node.js"},"pvforecast":{"version":"2.3.0","platform":"Javascript/No
                  de.js"},"shelly":{"version":"6.2.4","platform":"Javascript/Node.js"},"smartthings":{"version":"0.0.4","platform":"Javascript/Node.js"},"synology":{"version":"2.1.13","platform":"Javascript/
                  Node.js"},"telegram":{"version":"1.15.2","platform":"Javascript/Node.js"},"terminal":{"version":"1.0.0","platform":"Javascript/Node.js"},"text2command":{"version":"2.3.0","platform":"Javasc
                  ript/Node.js"},"tr-064":{"version":"4.2.17","platform":"Javascript/Node.js"},"trashschedule":{"version":"2.0.3","platform":"Javascript/Node.js"},"vis":{"version":"1.4.15","platform":"Javasc
                  ript/Node.js"},"vis-hqwidgets":{"version":"1.3.0","platform":"Javascript/Node.js"},"vis-inventwo":{"version":"3.3.1","platform":"Javascript/Node.js"},"vis-material-advanced":{"version":"1.7
                  .2","platform":"Javascript/Node.js"},"vis-materialdesign":{"version":"0.5.9","platform":"Javascript/Node.js"},"web":{"version":"4.3.0","platform":"Javascript/Node.js"},"zigbee":{"version":"
                  1.8.10","platform":"Javascript/Node.js"},"influxdb":{"version":"3.2.0","platform":"Javascript/Node.js"},"simple-api":{"version":"2.7.2","platform":"Javascript/Node.js"},"tankerkoenig":{"ver
                  sion":"3.3.6","platform":"Javascript/Node.js"},"vis-2-beta":{"version":"2.0.16","platform":"Javascript/Node.js"},"vis-2-widgets-material":{"version":"0.2.1","platform":"Javascript/Node.js"}
                  ,"vis-2-widgets-energy":{"version":"0.1.3","platform":"Javascript/Node.js"},"vis-2-widgets-gauges":{"version":"0.1.4","platform":"Javascript/Node.js"},"upnp":{"version":"1.0.21","platform":
                  "Javascript/Node.js"},"daswetter":{"version":"3.1.4","platform":"Javascript/Node.js"},"pollenflug":{"version":"1.0.6","platform":"Javascript/Node.js"},"alarm":{"version":"3.3.9","platform":
                  "Javascript/Node.js"}},"statesType":"jsonl","objectsType":"jsonl","noInstances":50,"compactMode":false,"noCompactInstances":0,"model":"Cortex-A72","cpus":4,"mem":3926355968,"ostype":"Linux"
                  ,"city":"Mössingen","vis":20}
                  Jan 23 18:47:30 raspberrypi motion: [1:ml1] [WRN] [ALL] mlp_retry: Retrying until successful connection with camera
                  Jan 23 18:47:30 raspberrypi motion: [1:ml1] [NTC] [VID] vid_start: Opening V4L2 device
                  Jan 23 18:47:30 raspberrypi motion: [1:ml1] [NTC] [VID] v4l2_device_open: Using videodevice /dev/video0 and input -1
                  Jan 23 18:47:30 raspberrypi motion: [1:ml1] [ALR] [VID] v4l2_device_open: Failed to open video device /dev/video0: No such file or directory
                  Jan 23 18:47:30 raspberrypi motion: [1:ml1] [ERR] [VID] vid_start: V4L2 device failed to open
                  Jan 23 18:47:34 raspberrypi kernel: [84968.088992] io.text2command invoked oom-killer: gfp_mask=0x1100cca(GFP_HIGHUSER_MOVABLE), order=0, oom_score_adj=0
                  Jan 23 18:47:34 raspberrypi kernel: [84968.089018] CPU: 2 PID: 1593 Comm: io.text2command Tainted: G         C        5.15.84-v8+ #1613
                  Jan 23 18:47:34 raspberrypi kernel: [84968.089025] Hardware name: Raspberry Pi 4 Model B Rev 1.5 (DT)
                  Jan 23 18:47:34 raspberrypi kernel: [84968.089028] Call trace:
                  Jan 23 18:47:34 raspberrypi kernel: [84968.089030]  dump_backtrace+0x0/0x1b8
                  Jan 23 18:47:34 raspberrypi kernel: [84968.089045]  show_stack+0x20/0x30
                  Jan 23 18:47:34 raspberrypi kernel: [84968.089051]  dump_stack_lvl+0x8c/0xb8
                  Jan 23 18:47:34 raspberrypi kernel: [84968.089057]  dump_stack+0x18/0x34
                  Jan 23 18:47:34 raspberrypi kernel: [84968.089061]  dump_header+0x4c/0x204
                    shellyrulestheworld
                    @thomas-braun reicht die Zeit oder noch mehr davor / danach ?
                    • GaspodeG Offline
                      GaspodeG Offline
                      Gaspode
                      Dazu hat @apollon77 schon vor längerer Zeit in einem anderen Thread was geschrieben:
                      @apollon77 said in Iobroker stuerzt immer wieder mal ab:
                      Wenn oom_reaper bzw oom_killer im
                      Syslog stehen dann geht dir der Speicher aus und der Kernel schießt Prozesse ab. Also ramnutzung wird dein Problem sein. Es läuft mehr als du ram hast.
                      Es ist also wohl so, wie er oben bereits vermutet hat:
                      @apollon77 said in Raspberry Absturz alle 3 Tage:
                      Ich tippe auf Zuviele Instanzen bei zu wenig RAM.
                      • GaspodeG Gaspode
                        shellyrulestheworld
                        @gaspode
                        aktuelle Werte (ich finde die nicht abnormal und RAM --> 11% aktuell)
                        CPU: 25,85 %
                        RAM: 11,6 %
                        Betriebszeit: 14h
                        Verfügbar: 4.0.24
                        Installiert: 4.0.24
                        Ereignisse: ⇥38 / ↦15
                        Plattform: linux
                        Betriebssystem: linux
                        Architektur: arm64
                        CPUs: 4
                        Geschwindigkeit: 1800 MHz
                        Modell: Cortex-A72
                        RAM: 3.6 GB
                        System-Betriebszeit: 1 T. 11:21:29
                        Node.js: v16.19.0
                        time: 1674538375851
                        timeOffset: -60
                        Adapter-Anzahl: 456
                        NPM: 8.19.3
                        Datenträgergröße: 58.3 GB
                        Freier Festplattenspeicher: 47.7 GB
                        Betriebszeit: 11:45:00
                        Aktive Instanzen: 38
                        Pfad: /opt/iobroker/
                        aktiv: true
                        _nodeCurrent: 16.19.0
                        _nodeNewest: 16.19.0
                        _nodeNewestNext: 16.19.0
                        _npmCurrent: 8.19.3
                        _npmNewest: 8.19.3
                        _npmNewestNext: 8.19.3
                        Thomas BraunT GaspodeG 2 Antworten Letzte Antwort
                          @gaspode
                          CPU: 25,85 %
                          RAM: 11,6 %
                          Betriebszeit: 14h
                          Verfügbar: 4.0.24
                          Installiert: 4.0.24
                          Plattform: linux
                          Architektur: arm64
                          CPUs: 4
                          Modell: Cortex-A72
                          RAM: 3.6 GB
                          Node.js: v16.19.0
                          time: 1674538375851
                          timeOffset: -60
                          Adapter-Anzahl: 456
                          NPM: 8.19.3
                          aktiv: true
                          _npmCurrent: 8.19.3
                          _npmNewest: 8.19.3
                          Könnte Grenzwertig sein.
                            @gaspode
                            CPU: 25,85 %
                            RAM: 11,6 %
                            Betriebszeit: 14h
                            Verfügbar: 4.0.24
                            Installiert: 4.0.24
                            Plattform: linux
                            Architektur: arm64
                            CPUs: 4
                            Modell: Cortex-A72
                            RAM: 3.6 GB
                            Node.js: v16.19.0
                            time: 1674538375851
                            timeOffset: -60
                            Adapter-Anzahl: 456
                            NPM: 8.19.3
                            aktiv: true
                            _npmCurrent: 8.19.3
                            _npmNewest: 8.19.3
                            GaspodeG Offline
                            GaspodeG Offline
                            Gaspode
                            schrieb am zuletzt editiert von Gaspode
                            @shellyrulestheworld said in Raspberry Absturz alle 3 Tage:
                            Er läuft jetzt ja auch erst 14 Stunden, und nach drei Tagen kommt es zu dem Problem. In der Zischenzeit kann viel passieren, die RAM Auslastung ist ja nur eine Momentaufnahme. Evtl. hast du auch einen Prozess, der allokierten Speicher nicht mehr sauber freigibt.
                            Ich würde mir an deiner Stelle mal regelmäßig die RAM Auslastung ansehen, so etwa alle 4 bis 6 Stunden, ob ein Trend erkennbar ist.
                            Hier zur Hintergrundinfo (was passenderes habe ich auf die Schnelle nicht gefunden, aber das Prinzip wird verständlich erklärt):
                            https://neo4j.com/developer/kb/linux-out-of-memory-killer/
                            • GaspodeG Gaspode
                              @gaspode
                              https://www.linuxatemyram.com/
                              Prüf mal ob der v4l2 Kram da erforderlich ist. Kamera im Einsatz? Die scheint jedenfalls nicht korrekt installiert zu sein.
                              S GaspodeG 3 Antworten Letzte Antwort
                                @gaspode
                                shellyrulestheworld
                                @thomas-braun ich habe eine Netzwerkkamera im Einsatz. Von dem her brauch ich diese Kamera nicht. Deshalb hab ich die montion.conf angepasst und die Kamera "kommentiert" (Zeile 18)
                                Müsste passen, oder?
                                  GNU nano 5.4                       motion.conf
                                setup_mode off
                                # File to store the process ID.
                                ; pid_file value
                                # File to write logs messages into.  If not defined stderr and syslog is used.
                                ; log_file value
                                # Level of log messages [1..9] (EMG, ALR, CRT, ERR, WRN, NTC, INF, DBG, ALL).
                                log_level 6
                                # Target directory for pictures, snapshots and movies
                                ; target_dir value
                                # Video device (e.g. /dev/video0) to be used for capturing.
                                ;video_device /dev/video0
                                # Parameters to control video device.  See motion_guide.html
                                ; video_params value
                                  setup_mode off
                                  ; pid_file value
                                  ; log_file value
                                  log_level 6
                                  ; target_dir value
                                  Auskommentiert wird mit dem 'Gartenzaun'/ der Raute. Wie z. B. in Zeile 5 zusehen.
                                    @gaspode
                                    shellyrulestheworld
                                    @thomas-braun wie kann man denn ans Ende der syslog springen? Beim scrollen wird man ja wahnsinnig ;-)
                                    und ich habe mal nicht genutzte Instanzen deinstalliert bzw. teilweise pausiert.
                                      tail -f /var/log/syslog
                                        @gaspode
                                        GaspodeG Offline
                                        GaspodeG Offline
                                        Gaspode
                                        @thomas-braun said in Raspberry Absturz alle 3 Tage:
                                        Ja Danke, in "meinem" Link wird das Prinzip von OOM-Killer erklärt, deshalb hatte ich den gewählt.
                                        Auf jeden Fall ist es ein deutlicher Hinweis auf (zu) wenig Memory, wenn OOM-Killer zuschlägt, soweit ich das verstehe.
                                        • GaspodeG Gaspode
                                          #66
                                          @gaspode sagte in Raspberry Absturz alle 3 Tage:
                                          Ja, der OOM-Killer haut zunächst für das Kernsystem unwesentliche Prozesse ins Nirvana.
