  4. Raspberry Absturz alle 3 Tage
    5.5k
118 Beiträge 9 Kommentatoren 13.4k Aufrufe 7 Beobachtet
  • S shellyrulestheworld
    Skript v.2023-01-02
    *** BASE SYSTEM ***
    Model           : Raspberry Pi 4 Model B Rev 1.5
    Architecture:   aarch64
    Docker:         false
    Virtualization: none
    Distributor ID: Debian
    Description:    Debian GNU/Linux 11 (bullseye)
    Release:        11
    Codename:       bullseye
    PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
    NAME="Debian GNU/Linux"
    VERSION_ID="11"
    VERSION="11 (bullseye)"
    VERSION_CODENAME=bullseye
    ID=debian
    HOME_URL="https://www.debian.org/"
    SUPPORT_URL="https://www.debian.org/support"
    BUG_REPORT_URL="https://bugs.debian.org/"
    Systemuptime and Load:
     19:18:36 up 7 min,  1 user,  load average: 1.62, 2.48, 1.37
    CPU threads: 4
    *** Time and Time Zones ***
    Sun Jan 22 18:18:36 UTC 2023
    Sun Jan 22 19:18:36 CET 2023
    CET +0100
    Europe/Berlin
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:            3.7G        2.3G        579M        1.0M        891M        1.4G
    Swap:            99M          0B         99M
    Total:          3.8G        2.3G        679M
             3744 M total memory
             2273 M used memory
              383 M active memory
             2608 M inactive memory
              579 M free memory
               90 M buffer memory
              800 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    *** FILESYSTEM ***
    /dev/root      ext4       59G   11G   46G  19% /
    devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
    tmpfs          tmpfs     1.9G   16K  1.9G   1% /dev/shm
    tmpfs          tmpfs     749M  1.1M  748M   1% /run
    /dev/sda1      vfat       15G  291M   15G   2% /mnt/usb0
    /dev/mmcblk0p1 vfat      255M   31M  225M  12% /boot
    tmpfs          tmpfs     375M     0  375M   0% /run/user/1000
    Messages in dmesg:
    [Sun Jan 22 19:11:27 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=E4:5F:01:E6:BC:85 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=515bbee9-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Sun Jan 22 19:11:28 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
    [Sun Jan 22 19:11:28 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Sun Jan 22 19:11:30 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null). Quota mode: none.
    TARGET      SOURCE         FSTYPE OPTIONS
    /           /dev/mmcblk0p2 ext4   rw,noatime
    |-/mnt/usb0 /dev/sda1      vfat   rw,nosuid,nodev,noexec,relatime,fmask=0000,dmask=0000,allow_utime=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    `-/boot     /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    4.5G    /var/
    2.7G    /var/lib
    2.6G    /var/lib/influxdb/engine/data/1147cd382d43b18f/autogen
    /opt/iobroker/backups:
    283M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    977M    /opt/iobroker/iobroker-data/
    869M    /opt/iobroker/iobroker-data/files
    582M    /opt/iobroker/iobroker-data/files/vis-2-beta
    545M    /opt/iobroker/iobroker-data/files/vis-2-beta/static
    543M    /opt/iobroker/iobroker-data/files/vis-2-beta/static/js
    33M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.10538062.js.map
    20M     /opt/iobroker/iobroker-data/objects.jsonl
    19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.904d455f.js.map
    15M     /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js.map
    9.7M    /opt/iobroker/iobroker-data/files/vis-2-beta/material-icons/knx-uf.json
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v16.19.0
    /usr/bin/node           v16.19.0
    /usr/bin/npm            8.19.3
    /usr/bin/npx            8.19.3
    nodejs:
      Installed: 16.19.0-deb-1nodesource1
      Candidate: 16.19.0-deb-1nodesource1
      Version table:
     *** 16.19.0-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_16.x bullseye/main arm64 Packages
         12.22.12~dfsg-1~deb11u1 500
            500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
         12.22.5~dfsg-2~11u1 500
            500 http://deb.debian.org/debian bullseye/main arm64 Packages
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  4.0.24
    admin:          6.3.5
    javascript:     6.1.4
    Adapters from github:   0
    Adapter State
    + system.adapter.admin.1                  : admin                 : raspberrypi                              -  enabled, port: 8089, bind: 0.0.0.0, run as: admin
    + system.adapter.cloud.0                  : cloud                 : raspberrypi                              -  enabled
      system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled
      system.adapter.devices.0                : devices               : raspberrypi                              - disabled
      system.adapter.dwd.0                    : dwd                   : raspberrypi                              -  enabled
      system.adapter.feiertage.0              : feiertage             : raspberrypi                              -  enabled
      system.adapter.fritzdect.0              : fritzdect             : raspberrypi                              - disabled
    + system.adapter.fronius.0                : fronius               : raspberrypi                              -  enabled
    + system.adapter.heizoel.0                : heizoel               : raspberrypi                              -  enabled
    + system.adapter.history.0                : history               : raspberrypi                              -  enabled
    + system.adapter.homeconnect.0            : homeconnect           : raspberrypi                              -  enabled
    + system.adapter.hs100.0                  : hs100                 : raspberrypi                              -  enabled
      system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
    + system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: 8086
    + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
    + system.adapter.jarvis.0                 : jarvis                : raspberrypi                              -  enabled
    + system.adapter.net-tools.0              : net-tools             : raspberrypi                              -  enabled
    + system.adapter.philips-air.0            : philips-air           : raspberrypi                              -  enabled
    + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
    + system.adapter.pvforecast.0             : pvforecast            : raspberrypi                              -  enabled
    + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.shelly.1                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.simple-api.0             : simple-api            : raspberrypi                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.smartthings.0            : smartthings           : raspberrypi                              -  enabled
    + system.adapter.synology.0               : synology              : raspberrypi                              -  enabled, port: 5000
    + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              -  enabled
    + system.adapter.telegram.1               : telegram              : raspberrypi                              -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.terminal.0               : terminal              : raspberrypi                              -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
    + system.adapter.text2command.0           : text2command          : raspberrypi                              -  enabled
    + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
    + system.adapter.tr-064.1                 : tr-064                : raspberrypi                              -  enabled
    + system.adapter.tr-064.2                 : tr-064                : raspberrypi                              -  enabled
    + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
    + system.adapter.upnp.0                   : upnp                  : raspberrypi                              -  enabled
      system.adapter.vis-2-beta.0             : vis-2-beta            : raspberrypi                              - disabled
      system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : raspberrypi                              -  enabled
      system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : raspberrypi                              -  enabled
      system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: raspberrypi                              -  enabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : raspberrypi                              -  enabled
    + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2658990-if00
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
    Adapter    "backitup"     : 2.5.10   , installed 2.5.10
    Adapter    "cloud"        : 4.3.0    , installed 4.3.0
    Adapter    "daswetter"    : 3.1.4    , installed 3.1.4
    Adapter    "devices"      : 1.1.2    , installed 1.1.2
    Adapter    "dwd"          : 2.8.3    , installed 2.8.3
    Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
    Adapter    "fritzdect"    : 2.2.6    , installed 2.2.6
    Adapter    "fronius"      : 1.1.3    , installed 1.1.3
    Adapter    "heizoel"      : 1.0.3    , installed 1.0.3
    Adapter    "history"      : 2.2.4    , installed 2.2.4
    Adapter    "homeconnect"  : 1.1.1    , installed 1.1.1
    Adapter    "hs100"        : 2.1.2    , installed 2.1.2
    Adapter    "info"         : 1.9.19   , installed 1.9.19
    Adapter    "iot"          : 1.14.2   , installed 1.14.2
    Adapter    "jarvis"       : 3.1.2    , installed 3.1.2
    Adapter    "javascript"   : 6.1.4    , installed 6.1.4
    Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
    Adapter    "philips-air"  : 1.0.1    , installed 1.0.1
    Adapter    "pvforecast"   : 2.3.0    , installed 2.3.0
    Adapter    "shelly"       : 6.0.0    , installed 6.2.4
    Adapter    "smartthings"  : 0.0.4    , installed 0.0.4
    Adapter    "synology"     : 2.1.13   , installed 2.1.13
    Adapter    "tankerkoenig" : 3.1.0    , installed 3.1.0
    Adapter    "telegram"     : 1.15.2   , installed 1.15.2
    Adapter    "terminal"     : 1.0.0    , installed 1.0.0
    Adapter    "text2command" : 2.3.0    , installed 2.3.0
    Adapter    "tr-064"       : 4.2.17   , installed 4.2.17
    Adapter    "trashschedule": 2.0.3    , installed 2.0.3
    Adapter    "upnp"         : 1.0.21   , installed 1.0.21
    Adapter    "vis-hqwidgets": 1.3.0    , installed 1.3.0
    Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
    Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
    Adapter    "zigbee"       : 1.8.10   , installed 1.8.10
    Objects and States
    Objects:        15853
    States:         13489
    W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://packages.grafana.com/oss/deb stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 9E439B102CF3C0C6
    W: Failed to fetch https://packages.grafana.com/oss/deb/dists/stable/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 9E439B102CF3C0C6
    W: Some index files failed to download. They have been ignored, or old ones used instead.
    Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:2 http://deb.debian.org/debian bullseye InRelease
    Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:5 https://repos.influxdata.com/debian bullseye InRelease
    Get:6 https://packages.grafana.com/oss/deb stable InRelease [5984 B]
    Hit:7 https://deb.nodesource.com/node_16.x bullseye InRelease
    Hit:8 https://phoscon.de/apt/deconz bullseye InRelease
    Hit:9 https://packagecloud.io/ookla/speedtest-cli/debian bullseye InRelease
    Err:6 https://packages.grafana.com/oss/deb stable InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       14808      980/io.shelly.1
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       14519      712/iobroker.js-con
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       14512      712/iobroker.js-con
    tcp        0      0 0.0.0.0:7777            0.0.0.0:*               LISTEN      0          11702      535/motion
    tcp        0      0 0.0.0.0:7778            0.0.0.0:*               LISTEN      0          11703      535/motion
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14348      522/sshd: /usr/sbin
    tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       20523      1493/io.jarvis.0
    tcp        0      0 127.0.0.1:7999          0.0.0.0:*               LISTEN      0          11704      535/motion
    tcp        0      0 127.0.0.1:8080          0.0.0.0:*               LISTEN      112        11150      496/motion
    tcp        0      0 127.0.0.1:8081          0.0.0.0:*               LISTEN      112        11149      496/motion
    tcp        0      0 0.0.0.0:8765            0.0.0.0:*               LISTEN      0          14370      380/python2
    tcp6       0      0 :::8088                 :::*                    LISTEN      1001       20596      1567/io.terminal.0
    tcp6       0      0 :::8089                 :::*                    LISTEN      1001       15477      739/io.admin.1
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       20928      1654/io.web.0
    tcp6       0      0 :::8086                 :::*                    LISTEN      999        14488      640/influxd
    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       18969      1700/io.simple-api.
    tcp6       0      0 :::22                   :::*                    LISTEN      0          14350      522/sshd: /usr/sbin
    tcp6       0      0 :::3000                 :::*                    LISTEN      110        15391      636/grafana-server
    udp        0      0 0.0.0.0:58449           0.0.0.0:*                           1001       23913      2115/io.upnp.0
    udp        0      0 192.168.178.77:5353     0.0.0.0:*                           1001       15016      1066/io.tr-064.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13617      370/avahi-daemon: r
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       14137      958/io.shelly.0
    udp        0      0 0.0.0.0:36608           0.0.0.0:*                           108        13619      370/avahi-daemon: r
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       28701      2115/io.upnp.0
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13680      635/dhcpcd
    udp        0      0 0.0.0.0:43163           0.0.0.0:*                           1001       17157      899/io.philips-air.
    udp6       0      0 :::5353                 :::*                                108        13618      370/avahi-daemon: r
    udp6       0      0 :::42438                :::*                                108        13620      370/avahi-daemon: r
    2023-01-22 19:15:07.347  - error: pvforecast.0 (1536) [updateActualWeatherData] failed to update weather data: TypeError: data.filter is not a function
    2023-01-22 19:15:13.197  - info: dwd.0 (3551) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-01-22 19:15:13.757  - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-01-22 19:15:28.516  - info: cloud.0 (1265) Trying to connect as system.user.admin to cloud
    2023-01-22 19:15:28.693  - info: cloud.0 (1265) Connection changed: connect
    2023-01-22 19:15:42.373  - info: daswetter.0 (2445) still wrong data structure from server received! repaired...
    2023-01-22 19:15:47.231  - error: daswetter.0 (2445) force terminate
    2023-01-22 19:15:47.232  - warn: daswetter.0 (2445) Terminated (UNKNOWN_ERROR): Without reason
    2023-01-22 19:15:47.748  - warn: daswetter.0 (2445) get state error: Connection is closed.
    2023-01-22 19:15:47.750  - error: daswetter.0 (2445) exception in await insertIntoList [Error: DB closed]
    2023-01-22 19:15:47.754  - error: daswetter.0 (2445) Cannot check object existence of "daswetter.0.NextHours2.Location_1.Day_3.Hour_6.wind_symbol": Connection is closed.
    2023-01-22 19:15:47.758  - error: daswetter.0 (2445) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextHours2.Location_1.Day_3.Hour_6.wind_symbol: Cannot check object existence of "daswetter.0.NextHours2.Location_1.Day_3.Hour_6.wind_symbol": Connection is closed.]
    2023-01-22 19:15:47.760  - error: daswetter.0 (2445) Cannot check object existence of "daswetter.0.NextHours2.Location_1.Day_3.Hour_6.wind_symbolB": Connection is closed.
    2023-01-22 19:15:47.764  - error: daswetter.0 (2445) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextHours2.Location_1.Day_3.Hour_6.wind_symbolB: Cannot check object existence of "daswetter.0.NextHours2.Location_1.Day_3.Hour_6.wind_symbolB": Connection is closed.]
    2023-01-22 19:15:47.767  - error: daswetter.0 (2445) Cannot check object existence of "daswetter.0.NextHours2.Location_1.Day_3.Hour_6.windIconURL": Connection is closed.
    2023-01-22 19:15:47.771  - error: daswetter.0 (2445) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextHours2.Location_1.Day_3.Hour_6.windIconURL: Cannot check object existence of "daswetter.0.NextHours2.Location_1.Day_3.Hour_6.windIconURL": Connection is closed.]
    2023-01-22 19:15:47.774  - error: daswetter.0 (2445) Cannot check object existence of "daswetter.0.NextHours2.Location_1.Day_3.Hour_6.wind_gusts": Connection is closed.
    2023-01-22 19:15:47.871  - error: host.raspberrypi instance system.adapter.daswetter.0 terminated with code 15 (UNKNOWN_ERROR)
    2023-01-22 19:16:14.785  - info: alexa2.0 (864) Subscribing to states...
    2023-01-22 19:16:17.450  - info: alexa2.0 (864) Alexa-Push-Connection (macDms = true) established. Disable Polling
    2023-01-22 19:16:41.608  - info: shelly.1 (980) [MQTT] Device with client id "shellytrv-2C1165DAB5E5" connected!
    2023-01-22 19:16:42.416  - info: shelly.1 (980) [MQTT] Device with client id "shellytrv-84FD270A20F4" connected!
    2023-01-22 19:16:43.277  - info: alexa2.0 (864) Initialization Done ...
    2023-01-22 19:17:12.907  - info: admin.1 (739) <== Disconnect system.user.admin from ::ffff:192.168.178.37 admin
    2023-01-22 19:17:14.278  - info: admin.1 (739) ==> Connected system.user.admin from ::ffff:192.168.178.37
    iob diag has finished.
    Press any key for a summary
    @shellyrulestheworld
    Soweit keine erkennbaren Kinken.
    Das Grafana-Repo musst du aber anpacken:
    https://forum.iobroker.net/topic/62040/linux-debian-grafana-repo-muss-aktualisiert-werden
      @thomas-braun sagte in Raspberry Absturz alle 3 Tage:
      ist ja auch frisch nach einem reboot.
      35 aktive Instanzen und noch 1.4G available klingt gut.
      auch die Load ist im grünen Bereich.
      diese Ausgabe solltest du dir ruhig ab und zu ansehen
        shellyrulestheworld
        @homoran @Thomas-Braun Dankeschön !!
          shellyrulestheworld
          grafana auch gefixt. Echt toll :-)
          pi@raspberrypi:~ $ sudo apt update
          Hit:1 http://deb.debian.org/debian bullseye InRelease
          Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
          Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
          Hit:5 https://phoscon.de/apt/deconz bullseye InRelease
          Hit:6 https://repos.influxdata.com/debian bullseye InRelease
          Get:8 https://apt.grafana.com stable InRelease [5,984 B]
          Get:10 https://apt.grafana.com stable/main armhf Packages [62.8 kB]
          Get:11 https://apt.grafana.com stable/main arm64 Packages [64.8 kB]
          Fetched 134 kB in 3s (44.7 kB/s)
          Reading package lists... Done
          All packages are up to date.
            shellyrulestheworld
            schrieb am zuletzt editiert von shellyrulestheworld
            Heute leider das gleiche Spiel:
            2023-01-23 18:30:14.828 - warn: trashschedule.0 (1627) no events matches type "Altpapier" with match "Altpapier"
            2023-01-23 18:30:19.839 - info: ical.0 (64838) Terminated (NO_ERROR): Without reason
            2023-01-23 18:30:20.382 - info: host.raspberrypi instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
            2023-01-23 18:30:32.846 - info: admin.1 (739) <== Disconnect system.user.admin from ::ffff:192.168.178.37 admin
            2023-01-23 18:30:40.606 - info: daswetter.0 (64819) still wrong data structure from server received! repaired...
            2023-01-23 18:30:47.585 - info: admin.1 (739) <== Disconnect system.user.admin from ::ffff:192.168.178.37 admin
            2023-01-23 18:30:49.031 - info: daswetter.0 (64819) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
            2023-01-23 18:30:49.555 - info: daswetter.0 (64819) cleaned everything up...
            2023-01-23 18:30:49.584 - info: host.raspberrypi instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2023-01-23 18:32:30.483 - info: javascript.0 (806) Stop script script.js.Test.Test
            2023-01-23 18:33:38.234 - info: web.0 (1654) <== Disconnect system.user.admin from ::ffff:192.168.178.37 vis.0
            2023-01-23 18:33:59.666 - info: javascript.0 (806) Start javascript script.js.Test.Test
            2023-01-23 18:33:59.686 - info: javascript.0 (806) script.js.Test.Test: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
            2023-01-23 18:34:46.007 - info: javascript.0 (806) script.js.Test.Test: timeout hat zugeschlagen
            2023-01-23 18:35:00.238 - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 64966
            2023-01-23 18:35:04.018 - info: dwd.0 (64966) starting. Version 2.8.3 in /opt/iobroker/node_modules/iobroker.dwd, node: v16.19.0, js-controller: 4.0.24
            2023-01-23 18:35:09.773 - info: dwd.0 (64966) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            2023-01-23 18:35:10.322 - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2023-01-23 18:35:50.683 - info: javascript.0 (806) script.js.Test.Test: timeout hat zugeschlagen
            2023-01-23 18:40:00.242 - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 65118
            2023-01-23 18:40:04.203 - info: dwd.0 (65118) starting. Version 2.8.3 in /opt/iobroker/node_modules/iobroker.dwd, node: v16.19.0, js-controller: 4.0.24
            2023-01-23 18:40:10.272 - info: dwd.0 (65118) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            2023-01-23 18:40:10.807 - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2023-01-23 18:45:00.041 - info: javascript.0 (806) script.js.PV.VerbrauchsberechnungShellys: Shelly Verbrauch: Verbrauchswerte aktualisiert: 5 | Reboots korrigiert: 0 | Unveränderte Werte: 28
            2023-01-23 18:45:00.292 - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 65289
            2023-01-23 18:45:04.381 - info: host.raspberrypi instance system.adapter.daswetter.0 started with pid 65300
            2023-01-23 18:45:06.108 - info: dwd.0 (65289) starting. Version 2.8.3 in /opt/iobroker/node_modules/iobroker.dwd, node: v16.19.0, js-controller: 4.0.24
            2023-01-23 18:45:08.637 - info: daswetter.0 (65300) starting. Version 3.1.4 in /opt/iobroker/node_modules/iobroker.daswetter, node: v16.19.0, js-controller: 4.0.24
            2023-01-23 18:45:09.580 - error: pvforecast.0 (1536) [updateActualWeatherData] failed to update weather data: TypeError: data.filter is not a function
            2023-01-23 18:45:11.322 - info: dwd.0 (65289) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            2023-01-23 18:45:11.946 - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2023-01-23 18:45:38.150 - info: daswetter.0 (65300) still wrong data structure from server received! repaired...
            2023-01-23 18:45:47.366 - info: daswetter.0 (65300) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
            2023-01-23 18:45:47.883 - info: daswetter.0 (65300) cleaned everything up...
            2023-01-23 18:45:47.907 - info: host.raspberrypi instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2023-01-23 18:47:24.927 - info: admin.1 (739) Request actual repository...
            2023-01-23 18:47:25.659 - info: host.raspberrypi Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
            2023-01-23 18:47:35.629 - info: hs100.0 (1413) cleaned everything up...
            2023-01-23 18:47:35.642 - error: pvforecast.0 (1536) States database error: read ECONNRESET
            2023-01-23 18:47:35.823 - error: trashschedule.0 (1627) States database error: read ECONNRESET
            2023-01-23 18:47:35.679 - info: zigbee.0 (1204) cleaned everything up...
            2023-01-23 18:47:35.676 - info: pollenflug.0 (37919) Closing Adapter
            2023-01-23 18:47:35.896 - info: trashschedule.0 (1627) cleaned everything up...
            2023-01-23 18:47:35.694 - info: javascript.0 (806) Stop script script.js.Heizungssteuerung.HeizungssteuerungBenno
            2023-01-23 18:47:35.682 - info: info.0 (1428) cleaned everything up...
            Zeile 47 und 48, wie auch schon davor..
            Thomas BraunT CodierknechtC apollon77A 3 Antworten Letzte Antwort
              @shellyrulestheworld sagte in Raspberry Absturz alle 3 Tage:
              Zeile 47 und 48,
              Da steht nix wildes drin.
                CodierknechtC Online
                Codierknecht
                Mach mal Deine Credentials für den Google-Kalender unkenntlich - sonst hagelt's womöglich bald Termine 😁
                HmIP|ZigBee|Tasmota|Unifi
                Zabbix Certified Specialist
                • CodierknechtC Codierknecht
                  shellyrulestheworld
                  @codierknecht 😨 🤣
                    @codierknecht 😨 🤣
                    shellyrulestheworld
                    Zeile 10 --> da hab ich wohl einen Adapter installiert... Da ging es gut
                    2023-01-23 06:20:09.729 - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2023-01-23 06:20:59.603 - info: jarvis.0 (1493) Client with IP 192.168.178.37 connected.
                    2023-01-23 06:21:55.238 - info: web.0 (1654) ==> Connected system.user.admin from ::ffff:192.168.178.37
                    2023-01-23 06:22:09.760 - info: web.0 (1654) <== Disconnect system.user.admin from ::ffff:192.168.178.37 vis.0
                    2023-01-23 06:22:13.959 - info: web.0 (1654) ==> Connected system.user.admin from ::ffff:192.168.178.37
                    2023-01-23 06:22:19.926 - info: web.0 (1654) <== Disconnect system.user.admin from ::ffff:192.168.178.37 vis.0
                    2023-01-23 06:22:32.239 - info: admin.1 (739) ==> Connected system.user.admin from ::ffff:192.168.178.37
                    2023-01-23 06:24:08.833 - info: admin.1 (739) ==> Connected system.user.admin from ::ffff:192.168.178.37
                    2023-01-23 06:24:45.302 - info: admin.1 (739) ==> Connected system.user.admin from ::ffff:192.168.178.37
                    2023-01-23 06:24:49.474 - info: host.raspberrypi Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
                    2023-01-23 06:25:02.363 - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 37640
                    2023-01-23 06:25:07.766 - info: dwd.0 (37640) starting. Version 2.8.3 in /opt/iobroker/node_modules/iobroker.dwd, node: v16.19.0, js-controller: 4.0.24
                    2023-01-23 06:25:10.465 - info: dwd.0 (37640) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    2023-01-23 06:25:11.019 - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2023-01-23 06:25:44.430 - info: admin.1 (739) <== Disconnect system.user.admin from ::ffff:192.168.178.37
                    2023-01-23 06:27:53.204 - info: host.raspberrypi iobroker add pollenflug --host raspberrypi
                    2023-01-23 06:27:58.536 - info: host.raspberrypi iobroker NPM version: 8.19.3Installing iobroker.pollenflug@1.0.6... (System call)
                      shellyrulestheworld
                      Es scheint, wenn der admin.1 das anfordert zu krachen. Wie oft macht der admin das denn?
                        Codierknecht
                        admin.1
                        Wieso eigentlich admin.1. Hast Du mehr als eine Admin-Instanz laufen?
                          admin.1
                          shellyrulestheworld
                          @codierknecht nein, nur eine Admin Instanz. Am Anfang wollte mal die 8081 nicht mehr, dann habe ich eine admin.1 aufgemacht, Port 8089 und die als admin.1 gelassen.
                          admin.0 gibt es nicht mehr.
                          Kann das ein Problem sein?
                          S CodierknechtC 2 Antworten Letzte Antwort
                            shellyrulestheworld
                              shellyrulestheworld
                                @shellyrulestheworld meine Frage nach /var/log/syslog und was da zeitlich passend steht ist noch nicht beantwortet gewesen oder?!
                                  Codierknecht
                                  Nö - in dem Fall eher nicht.
                                  • apollon77A apollon77
                                    shellyrulestheworld
                                    @apollon77 jetzt kommt ne doofe Frage: was möchtest du haben und wie lade ich es am besten herunter? 0c6581bb-4470-4462-ba9d-43db91f99eb3-grafik.png
                                      CodeTags verwenden, keine Screenshots.
                                      less -R /var/log/syslog
                                        shellyrulestheworld
                                        @thomas-braun da steht zu viel drin ... das hier in Codetags würde den Rahmen sprengen...
                                        Beispiel:
                                        videodevice /dev/video0 and input -1
                                        Jan 22 00:01:20 raspberrypi motion: [1:ml1] [ALR] [VID] v4l2_device_open: Failed to open video device /dev/video0: No such file or directory
                                        Jan 22 00:01:20 raspberrypi motion: [1:ml1] [ERR] [VID] vid_start: V4L2 device failed to open
                                        Jan 22 00:01:30 raspberrypi motion: [1:ml1] [WRN] [ALL] mlp_retry: Retrying until successful connection with camera
                                        Jan 22 00:01:30 raspberrypi motion: [1:ml1] [NTC] [VID] vid_start: Opening V4L2 device
                                        Jan 22 00:01:30 raspberrypi motion: [1:ml1] [NTC] [VID] v4l2_device_open: Using videodevice /dev/video0 and input -1
                                        Jan 22 00:01:30 raspberrypi motion: [1:ml1] [ALR] [VID] v4l2_device_open: Failed to open video device /dev/video0: No such file or directory
                                        Jan 22 00:01:30 raspberrypi motion: [1:ml1] [ERR] [VID] vid_start: V4L2 device failed to open
                                        Jan 22 00:01:40 raspberrypi motion: [1:ml1] [WRN] [ALL] mlp_retry: Retrying unti:
                                          Beispiel:
                                          Deswegen sollst du ja auch den zeitlich passenden Bereich posten.
                                          S 2 Antworten Letzte Antwort
