  4. Raspberry Absturz alle 3 Tage
118 Beiträge 9 Kommentatoren 13.4k Aufrufe 7 Beobachtet
  • S shellyrulestheworld
    @apollon77
    Mar 15 15:33:00 raspberrypi motion: [1:ml1] [NTC] [VID] v4l2_device_open: Using videodevice /dev/video0 and input -1
    Mar 15 15:33:00 raspberrypi motion: [1:ml1] [ALR] [VID] v4l2_device_open: Failed to open video device /dev/video0: No such file or directory
    Mar 15 15:33:00 raspberrypi motion: [1:ml1] [ERR] [VID] vid_start: V4L2 device failed to open
    Mar 15 15:33:03 raspberrypi bash[878]: Send diag info: {"uuid":"f8c37d91-9714-ae1d-5ca5-563211cda069","language":"de","country":"Germany","hosts":[{"vers
    ion":"4.0.24","platform":"Javascript/Node.js","type":"linux"}],"node":"v16.19.1","arch":"arm64","docker":false,"adapters":{"admin":{"version":"6.3.5","pl
    atform":"Javascript/Node.js"},"discovery":{"version":"3.1.0","platform":"Javascript/Node.js"},"backitup":{"version":"2.5.12","platform":"Javascript/Node.
    js"},"alexa2":{"version":"3.23.2","platform":"Javascript/Node.js"},"cloud":{"version":"4.3.0","platform":"Javascript/Node.js"},"devices":{"version":"1.1.
    2","platform":"Javascript/Node.js"},"dwd":{"version":"2.8.3","platform":"Javascript/Node.js"},"feiertage":{"version":"1.1.0","platform":"Javascript/Node.
    js"},"fronius":{"version":"1.1.3","platform":"Javascript/Node.js"},"heizoel":{"version":"1.0.3","platform":"Javascript/Node.js"},"history":{"version":"2.
    2.4","platform":"Javascript/Node.js"},"homeconnect":{"version":"1.1.1","platform":"Javascript/Node.js"},"hs100":{"version":"2.1.2","platform":"Javascript
    /Node.js"},"ical":{"version":"1.13.2","platform":"Javascript/Node.js"},"icons-mfd-svg":{"version":"1.1.0","platform":"Javascript/Node.js"},"info":{"versi
    on":"1.9.19","platform":"Javascript/Node.js"},"iot":{"version":"1.14.2","platform":"Javascript/Node.js"},"jarvis":{"version":"3.1.2","platform":"Javascri
    pt/Node.js"},"javascript":{"version":"6.1.4","platform":"Javascript/Node.js"},"net-tools":{"version":"0.2.0","platform":"Javascript/Node.js"},"philips-ai
    r":{"version":"1.0.1","platform":"Javascript/Node.js"},"ping":{"version":"1.5.3","platform":"Javascript/Node.js"},"pvforecast":{"version":"2.3.0","platfo
    rm":"Javascript/Node.js"},"shelly":{"version":"6.3.1","platform":"Javascript/Node.js"},"smartthings":{"version":"0.0.4","platform":"Javascript/Node.js"},
    "synology":{"version":"2.1.13","platform":"Javascript/Node.js"},"telegram":{"version":"1.15.2","platform":"Javascript/Node.js"},"terminal":{"version":"1.
    0.0","platform":"Javascript/Node.js"},"text2command":{"version":"2.3.0","platform":"Javascript/Node.js"},"tr-064":{"version":"4.2.17","platform":"Javascr
    ipt/Node.js"},"trashschedule":{"version":"2.2.0","platform":"Javascript/Node.js"},"vis":{"version":"1.4.15","platform":"Javascript/Node.js"},"vis-hqwidge
    ts":{"version":"1.3.0","platform":"Javascript/Node.js"},"vis-inventwo":{"version":"3.3.1","platform":"Javascript/Node.js"},"vis-material-advanced":{"vers
    ion":"1.7.2","platform":"Javascript/Node.js"},"vis-materialdesign":{"version":"0.5.9","platform":"Javascript/Node.js"},"web":{"version":"4.3.0","platform
    ":"Javascript/Node.js"},"zigbee":{"version":"1.8.10","platform":"Javascript/Node.js"},"influxdb":{"version":"3.2.0","platform":"Javascript/Node.js"},"sim
    ple-api":{"version":"2.7.2","platform":"Javascript/Node.js"},"tankerkoenig":{"version":"3.3.7","platform":"Javascript/Node.js"},"vis-2-beta":{"version":"
    2.0.16","platform":"Javascript/Node.js"},"vis-2-widgets-material":{"version":"0.2.1","platform":"Javascript/Node.js"},"vis-2-widgets-energy":{"version":"
    0.1.3","platform":"Javascript/Node.js"},"vis-2-widgets-gauges":{"version":"0.1.4","platform":"Javascript/Node.js"},"upnp":{"version":"1.0.21","platform":
    "Javascript/Node.js"},"daswetter":{"version":"3.1.7","platform":"Javascript/Node.js"},"pollenflug":{"version":"1.0.6","platform":"Javascript/Node.js"},"a
    larm":{"version":"3.3.9","platform":"Javascript/Node.js"},"fullybrowser":{"version":"2.1.2","platform":"Javascript/Node.js"},"fritzdect":{"version":"2.2.6","platform":"Javascript/Node.js"},"sourceanalytix":{"version":"0.4.14","platform":"Javascript/Node.js"}},"statesType":"jsonl","objectsType":"jsonl","noInstances":46,"compactMode":false,"noCompactInstances":0,"model":"Cortex-A72","cpus":4,"mem":3926355968,"ostype":"Linux","city":"Mössingen","vis":21}
    Mar 15 15:33:10 raspberrypi kernel: [286331.334752] nc3:Camera1 invoked oom-killer: gfp_mask=0x1100cca(GFP_HIGHUSER_MOVABLE), order=0, oom_score_adj=0
    Mar 15 15:33:10 raspberrypi kernel: [286331.334780] CPU: 3 PID: 871 Comm: nc3:Camera1 Tainted: G         C        5.15.84-v8+ #1613
    Mar 15 15:33:10 raspberrypi kernel: [286331.334786] Hardware name: Raspberry Pi 4 Model B Rev 1.5 (DT)
    Mar 15 15:33:10 raspberrypi kernel: [286331.334791] Call trace:
    Mar 15 15:33:10 raspberrypi kernel: [286331.334792]  dump_backtrace+0x0/0x1b8
    Mar 15 15:33:10 raspberrypi kernel: [286331.334808]  show_stack+0x20/0x30
    Mar 15 15:33:10 raspberrypi kernel: [286331.334814]  dump_stack_lvl+0x8c/0xb8
    Mar 15 15:33:10 raspberrypi kernel: [286331.334820]  dump_stack+0x18/0x34
    shellyrulestheworld
    #81
    es ist halt echt merkwürdig, dass das System wirklich ohne Probleme läuft über Tage und Wochen (seit ich das automatische checken nach Updates deaktiviert habe) und wenn ich dann gelegentlich von Hand auf Updates prüfe der Absturz kommt.
    GaspodeG 1 Antwort Letzte Antwort
      GaspodeG Offline
      GaspodeG Offline
      Gaspode
      #82
      @shellyrulestheworld said in Raspberry Absturz alle 3 Tage:
      Und das hast du gestern um 15:15 gemacht? Anscheinend hast du immer noch ein Problem mit zu wenig RAM, da der OOM Killer wieder zugeschlagen hat. Evtl. Ist die Prüfung auf Updates der Tropfen, der das Fass zum Überlaufen bringt.
      Da aber wieder etwas im Zusammenhang mit der Kamera den OOM-Killer getriggert hat, ist evtl. da was mit der Konfiguration schief?
      Verdächtig finde ich, dass unmittelbar vor dem Ereignis Fehlermeldungen kommen, die mit dem Video Device zu tun haben.
      Was ist denn /dev/video0 und warum greift jemand drauf zu, wenn es nicht existiert?
      • GaspodeG Gaspode
        shellyrulestheworld
        schrieb am zuletzt editiert von shellyrulestheworld
        #83
        @gaspode
        ich habe Motioneye am Laufen und normalerweise ist die Kamera per USB angebunden. Ich habe aber nur Network Kameras dran... und ich habe es in der Config vom Motioneye leider nicht hinbekommen den USB support zu deaktivieren. Deshalb läuft der log ziemlich voll.
        Klar, meine 4 GB RAM sind nicht mega viel, aber es ist schon komisch, dass das Suchen nach Updates immer DER Tropfen ist. Ist das so RAM intensiv? ;-)
        • apollon77A Offline
          #84
          Naja also der RAM Idee folgend ... was sagt denn "free -m " so generell? dann kannste das ja auch mal ansehen nach 24, 48 und 72h nach einem boot und ggf mit !top" schauen ob es einzelne Prozesse gibgt die ggf immer mehr RAM fressen
          • apollon77A apollon77
            shellyrulestheworld
            #85
            @apollon77
            Mem:            3744        2723         729           0         291         949
            Swap:             99          98           1
            wendy2702W apollon77A 2 Antworten Letzte Antwort
              @apollon77
              Swap:             99          98           1
              wendy2702W Online
              wendy2702W Online
              wendy2702
              #86
              @shellyrulestheworld Welche Version von Motion hast du laufen?
              In der aktuellen Version gibt es Fix für
              @shellyrulestheworld sagte in Raspberry Absturz alle 3 Tage:
              Opening V4L2 device
              Siehe:
              Eventuell ein Versuch wert.
              S 2 Antworten Letzte Antwort
              • wendy2702W wendy2702
                Opening V4L2 device
                Siehe:
                shellyrulestheworld
                #87
                @wendy2702
                motionEye Version 0.42.1
                Motion Version 4.5.1
                OS Version Debian 11
                  @apollon77
                  Swap:             99          98           1
                  #88
                  @shellyrulestheworld Na dann schau morgen mal ... Am besten schau dir auch "top" an und sortiere nach Mem usage ... screenshot und morgen vergleichen
                    shellyrulestheworld
                    #89
                    @apollon77
                    85bf73e6-85f1-4e6b-a1bc-ff49deaaf758-grafik.png a13fd22f-37f1-4e68-a95f-9b3e8ef804d4-grafik.png
                      Opening V4L2 device
                      Siehe:
                      shellyrulestheworld
                      #90
                      @wendy2702
                      vielen Dank für deinen Tipp. Ich denke man kann irgendwo in einer Config den V4L2 support ausschalten, aber ich weiß nicht wie und wo. Hab mich mal ein bisschen durch gesucht, aber nichts konkretes gefunden...
                        @wendy2702
                        wendy2702W Online
                        wendy2702W Online
                        wendy2702
                        #91
                        V4L2
                        Kann es sein das die Conf noch existiert?
                        ls -la /etc/motioneye
                          V4L2
                          shellyrulestheworld
                          #92
                          @wendy2702
                          pi@raspberrypi:~ $ ls -la /etc/motioneye
                          total 936
                          drwxr-xr-x  2 root root   4096 Jan 25 13:35 .
                          drwxr-xr-x 98 root root   4096 Mar 12 07:54 ..
                          -rw-r--r--  1 root root   2408 Jan 25 15:23 camera-1.conf
                          -rw-r--r--  1 root root   2426 Jan 25 15:24 camera-2.conf
                          -rw-r--r--  1 root root 307215 Dec 29 19:59 mask_1.pgm
                          -rw-r--r--  1 root root 307215 Jan 23 12:11 mask_2.pgm
                          -rw-r--r--  1 root root 307215 Jan 25 13:31 mask_3.pgm
                          -rw-r--r--  1 root root    249 Jan 25 15:24 motion.conf
                          -rw-r--r--  1 root root   2865 Dec 24 09:07 motioneye.conf
                            @wendy2702
                            total 936
                            wendy2702W Online
                            wendy2702W Online
                            wendy2702
                            #93
                            @shellyrulestheworld Also hast du aktuell 2 Netzwerk Kameras angeschlossen?
                            Warum dann drei mask files und welche Konfig hast du editiert ?
                              shellyrulestheworld
                              #94
                              @wendy2702
                              ich hatte schon mal bis zu 3 Kameras drin, vielleicht sind das noch "Leichen" !? Und ja, ich habe aktuell nur zwei Network cameras drin.
                              naja, in den configs habe ich nichts dazu gefunden. Und ich habe hier mal eine Discussion gestartet, jedoch ohne Erfolg
                              https://github.com/Motion-Project/motion/discussions/1623
                              • wendy2702W Online
                                wendy2702W Online
                                wendy2702
                                #95
                                Hier mal geschaut:
                                  Hier mal geschaut:
                                  shellyrulestheworld
                                  #96
                                  @wendy2702 ja, ist disabled:
                                    shellyrulestheworld
                                    #97
                                    hab die ganzen Meldungen jetzt weg bekommen. Hab in der motion.conf das video device auf 10 gesetzt
                                    ? 1 Antwort Letzte Antwort
                                      #98
                                      Moin,
                                      ich kenne die Software nicht, aber so macht man das normalerweise nicht. Wenn Du etwas in einem Programm nutzen oder deaktivieren möchtest, dann sollte man in der passenden Konfigurationsdatei entweder etwas aktivieren oder deaktivieren.
                                      Du hast nur einen falschen Eintrag erstellt, der Dir irgendwann auf die Füße fallen wird.
                                      Da es leider wieder ein Bild von einer Textdatei ist, kann man leider nicht zitieren.
                                      Aber nur mal so am Rande, das ";" sollte Dein Freund sein, damit kommentierst Du, dass das Programm nicht mehr auf das "video device" achten soll
                                      Ich denke, so sollte es richtig sein.
                                      # video device (e.g. /dev/video.0) to be used for capturing
                                      ; video_device /dev/video.0
                                      VG
                                      Bernd
                                        @apollon77
                                        #99
                                        @shellyrulestheworld I googled that for you .... https://linuxhint.com/make-top-command-sort-by-memory-usage/ ... Shift M
                                          Moin,
                                          VG
                                          Bernd
                                          shellyrulestheworld
                                          #100
                                          @dp20eic Vielen Dank für deinen Hinweis und du hast komplett recht. Ich hatte es auch erst mit einem ";" versehen. Aber genau dann waren die LOG Meldungen da. Und dann habe ich gesucht und nichts gefunden, bis auf den Hinweis im Motion-Dir, dass dort video10 ... videoXX vorkommt. Warum auch immer. Das kopieren von video10 nach video0 ging nicht und deshalb war meine Idee die Config zu ändern.
                                          Danach war Ruhe im LOG und die Network Kameras tun noch ;-)
