  4. Raspberry Absturz alle 3 Tage
    5.5k
118 Beiträge 9 Kommentatoren 13.4k Aufrufe 7 Beobachtet
  • apollon77A Offline
    #79
    /var/log/syslog ?
    • apollon77A apollon77
      /var/log/syslog ?
      shellyrulestheworld
      #80
      @apollon77
      Mar 15 15:33:00 raspberrypi motion: [1:ml1] [NTC] [VID] v4l2_device_open: Using videodevice /dev/video0 and input -1
      Mar 15 15:33:00 raspberrypi motion: [1:ml1] [ALR] [VID] v4l2_device_open: Failed to open video device /dev/video0: No such file or directory
      Mar 15 15:33:00 raspberrypi motion: [1:ml1] [ERR] [VID] vid_start: V4L2 device failed to open
      Mar 15 15:33:03 raspberrypi bash[878]: Send diag info: {"uuid":"f8c37d91-9714-ae1d-5ca5-563211cda069","language":"de","country":"Germany","hosts":[{"vers
      ion":"4.0.24","platform":"Javascript/Node.js","type":"linux"}],"node":"v16.19.1","arch":"arm64","docker":false,"adapters":{"admin":{"version":"6.3.5","pl
      atform":"Javascript/Node.js"},"discovery":{"version":"3.1.0","platform":"Javascript/Node.js"},"backitup":{"version":"2.5.12","platform":"Javascript/Node.
      js"},"alexa2":{"version":"3.23.2","platform":"Javascript/Node.js"},"cloud":{"version":"4.3.0","platform":"Javascript/Node.js"},"devices":{"version":"1.1.
      2","platform":"Javascript/Node.js"},"dwd":{"version":"2.8.3","platform":"Javascript/Node.js"},"feiertage":{"version":"1.1.0","platform":"Javascript/Node.
      js"},"fronius":{"version":"1.1.3","platform":"Javascript/Node.js"},"heizoel":{"version":"1.0.3","platform":"Javascript/Node.js"},"history":{"version":"2.
      2.4","platform":"Javascript/Node.js"},"homeconnect":{"version":"1.1.1","platform":"Javascript/Node.js"},"hs100":{"version":"2.1.2","platform":"Javascript
      /Node.js"},"ical":{"version":"1.13.2","platform":"Javascript/Node.js"},"icons-mfd-svg":{"version":"1.1.0","platform":"Javascript/Node.js"},"info":{"versi
      on":"1.9.19","platform":"Javascript/Node.js"},"iot":{"version":"1.14.2","platform":"Javascript/Node.js"},"jarvis":{"version":"3.1.2","platform":"Javascri
      pt/Node.js"},"javascript":{"version":"6.1.4","platform":"Javascript/Node.js"},"net-tools":{"version":"0.2.0","platform":"Javascript/Node.js"},"philips-ai
      r":{"version":"1.0.1","platform":"Javascript/Node.js"},"ping":{"version":"1.5.3","platform":"Javascript/Node.js"},"pvforecast":{"version":"2.3.0","platfo
      rm":"Javascript/Node.js"},"shelly":{"version":"6.3.1","platform":"Javascript/Node.js"},"smartthings":{"version":"0.0.4","platform":"Javascript/Node.js"},
      "synology":{"version":"2.1.13","platform":"Javascript/Node.js"},"telegram":{"version":"1.15.2","platform":"Javascript/Node.js"},"terminal":{"version":"1.
      0.0","platform":"Javascript/Node.js"},"text2command":{"version":"2.3.0","platform":"Javascript/Node.js"},"tr-064":{"version":"4.2.17","platform":"Javascr
      ipt/Node.js"},"trashschedule":{"version":"2.2.0","platform":"Javascript/Node.js"},"vis":{"version":"1.4.15","platform":"Javascript/Node.js"},"vis-hqwidge
      ts":{"version":"1.3.0","platform":"Javascript/Node.js"},"vis-inventwo":{"version":"3.3.1","platform":"Javascript/Node.js"},"vis-material-advanced":{"vers
      ion":"1.7.2","platform":"Javascript/Node.js"},"vis-materialdesign":{"version":"0.5.9","platform":"Javascript/Node.js"},"web":{"version":"4.3.0","platform
      ":"Javascript/Node.js"},"zigbee":{"version":"1.8.10","platform":"Javascript/Node.js"},"influxdb":{"version":"3.2.0","platform":"Javascript/Node.js"},"sim
      ple-api":{"version":"2.7.2","platform":"Javascript/Node.js"},"tankerkoenig":{"version":"3.3.7","platform":"Javascript/Node.js"},"vis-2-beta":{"version":"
      2.0.16","platform":"Javascript/Node.js"},"vis-2-widgets-material":{"version":"0.2.1","platform":"Javascript/Node.js"},"vis-2-widgets-energy":{"version":"
      0.1.3","platform":"Javascript/Node.js"},"vis-2-widgets-gauges":{"version":"0.1.4","platform":"Javascript/Node.js"},"upnp":{"version":"1.0.21","platform":
      "Javascript/Node.js"},"daswetter":{"version":"3.1.7","platform":"Javascript/Node.js"},"pollenflug":{"version":"1.0.6","platform":"Javascript/Node.js"},"a
      larm":{"version":"3.3.9","platform":"Javascript/Node.js"},"fullybrowser":{"version":"2.1.2","platform":"Javascript/Node.js"},"fritzdect":{"version":"2.2.6","platform":"Javascript/Node.js"},"sourceanalytix":{"version":"0.4.14","platform":"Javascript/Node.js"}},"statesType":"jsonl","objectsType":"jsonl","noInstances":46,"compactMode":false,"noCompactInstances":0,"model":"Cortex-A72","cpus":4,"mem":3926355968,"ostype":"Linux","city":"Mössingen","vis":21}
      Mar 15 15:33:10 raspberrypi kernel: [286331.334752] nc3:Camera1 invoked oom-killer: gfp_mask=0x1100cca(GFP_HIGHUSER_MOVABLE), order=0, oom_score_adj=0
      Mar 15 15:33:10 raspberrypi kernel: [286331.334780] CPU: 3 PID: 871 Comm: nc3:Camera1 Tainted: G         C        5.15.84-v8+ #1613
      Mar 15 15:33:10 raspberrypi kernel: [286331.334786] Hardware name: Raspberry Pi 4 Model B Rev 1.5 (DT)
      Mar 15 15:33:10 raspberrypi kernel: [286331.334791] Call trace:
      Mar 15 15:33:10 raspberrypi kernel: [286331.334792]  dump_backtrace+0x0/0x1b8
      Mar 15 15:33:10 raspberrypi kernel: [286331.334808]  show_stack+0x20/0x30
      Mar 15 15:33:10 raspberrypi kernel: [286331.334814]  dump_stack_lvl+0x8c/0xb8
      Mar 15 15:33:10 raspberrypi kernel: [286331.334820]  dump_stack+0x18/0x34
      • S shellyrulestheworld
        @apollon77
        shellyrulestheworld
        #81
        es ist halt echt merkwürdig, dass das System wirklich ohne Probleme läuft über Tage und Wochen (seit ich das automatische checken nach Updates deaktiviert habe) und wenn ich dann gelegentlich von Hand auf Updates prüfe der Absturz kommt.
        GaspodeG 1 Antwort Letzte Antwort
          GaspodeG Offline
          GaspodeG Offline
          Gaspode
          #82
          @shellyrulestheworld said in Raspberry Absturz alle 3 Tage:
          Und das hast du gestern um 15:15 gemacht? Anscheinend hast du immer noch ein Problem mit zu wenig RAM, da der OOM Killer wieder zugeschlagen hat. Evtl. Ist die Prüfung auf Updates der Tropfen, der das Fass zum Überlaufen bringt.
          Da aber wieder etwas im Zusammenhang mit der Kamera den OOM-Killer getriggert hat, ist evtl. da was mit der Konfiguration schief?
          Verdächtig finde ich, dass unmittelbar vor dem Ereignis Fehlermeldungen kommen, die mit dem Video Device zu tun haben.
          Was ist denn /dev/video0 und warum greift jemand drauf zu, wenn es nicht existiert?
          • GaspodeG Gaspode
            shellyrulestheworld
            schrieb am zuletzt editiert von shellyrulestheworld
            #83
            @gaspode
            ich habe Motioneye am Laufen und normalerweise ist die Kamera per USB angebunden. Ich habe aber nur Network Kameras dran... und ich habe es in der Config vom Motioneye leider nicht hinbekommen den USB support zu deaktivieren. Deshalb läuft der log ziemlich voll.
            Klar, meine 4 GB RAM sind nicht mega viel, aber es ist schon komisch, dass das Suchen nach Updates immer DER Tropfen ist. Ist das so RAM intensiv? ;-)
              #84
              Naja also der RAM Idee folgend ... was sagt denn "free -m " so generell? dann kannste das ja auch mal ansehen nach 24, 48 und 72h nach einem boot und ggf mit !top" schauen ob es einzelne Prozesse gibgt die ggf immer mehr RAM fressen
                shellyrulestheworld
                #85
                @apollon77
                Mem:            3744        2723         729           0         291         949
                Swap:             99          98           1
                wendy2702W apollon77A 2 Antworten Letzte Antwort
                  @apollon77
                  Swap:             99          98           1
                  wendy2702W Online
                  wendy2702W Online
                  #86
                  @shellyrulestheworld Welche Version von Motion hast du laufen?
                  In der aktuellen Version gibt es Fix für
                  @shellyrulestheworld sagte in Raspberry Absturz alle 3 Tage:
                  Opening V4L2 device
                  Siehe:
                  Eventuell ein Versuch wert.
                  S 2 Antworten Letzte Antwort
                  • wendy2702W wendy2702
                    Opening V4L2 device
                    Siehe:
                    shellyrulestheworld
                    #87
                    @wendy2702
                    motionEye Version 0.42.1
                    Motion Version 4.5.1
                    OS Version Debian 11
                      @apollon77
                      Swap:             99          98           1
                      #88
                      @shellyrulestheworld Na dann schau morgen mal ... Am besten schau dir auch "top" an und sortiere nach Mem usage ... screenshot und morgen vergleichen
                        shellyrulestheworld
                        #89
                        @apollon77
                        85bf73e6-85f1-4e6b-a1bc-ff49deaaf758-grafik.png a13fd22f-37f1-4e68-a95f-9b3e8ef804d4-grafik.png
                          Opening V4L2 device
                          Siehe:
                          shellyrulestheworld
                          #90
                          @wendy2702
                          vielen Dank für deinen Tipp. Ich denke man kann irgendwo in einer Config den V4L2 support ausschalten, aber ich weiß nicht wie und wo. Hab mich mal ein bisschen durch gesucht, aber nichts konkretes gefunden...
                            @wendy2702
                            wendy2702W Online
                            wendy2702W Online
                            #91
                            V4L2
                            Kann es sein das die Conf noch existiert?
                            ls -la /etc/motioneye
                              V4L2
                              shellyrulestheworld
                              #92
                              @wendy2702
                              pi@raspberrypi:~ $ ls -la /etc/motioneye
                              total 936
                              drwxr-xr-x  2 root root   4096 Jan 25 13:35 .
                              drwxr-xr-x 98 root root   4096 Mar 12 07:54 ..
                              -rw-r--r--  1 root root   2408 Jan 25 15:23 camera-1.conf
                              -rw-r--r--  1 root root   2426 Jan 25 15:24 camera-2.conf
                              -rw-r--r--  1 root root 307215 Dec 29 19:59 mask_1.pgm
                              -rw-r--r--  1 root root 307215 Jan 23 12:11 mask_2.pgm
                              -rw-r--r--  1 root root 307215 Jan 25 13:31 mask_3.pgm
                              -rw-r--r--  1 root root    249 Jan 25 15:24 motion.conf
                              -rw-r--r--  1 root root   2865 Dec 24 09:07 motioneye.conf
                                @wendy2702
                                total 936
                                wendy2702W Online
                                wendy2702W Online
                                #93
                                @shellyrulestheworld Also hast du aktuell 2 Netzwerk Kameras angeschlossen?
                                Warum dann drei mask files und welche Konfig hast du editiert ?
                                  shellyrulestheworld
                                  #94
                                  @wendy2702
                                  ich hatte schon mal bis zu 3 Kameras drin, vielleicht sind das noch "Leichen" !? Und ja, ich habe aktuell nur zwei Network cameras drin.
                                  naja, in den configs habe ich nichts dazu gefunden. Und ich habe hier mal eine Discussion gestartet, jedoch ohne Erfolg
                                  https://github.com/Motion-Project/motion/discussions/1623
                                  • wendy2702W Online
                                    wendy2702W Online
                                    #95
                                    Hier mal geschaut:
                                      Hier mal geschaut:
                                      shellyrulestheworld
                                      #96
                                      @wendy2702 ja, ist disabled:
                                        shellyrulestheworld
                                        #97
                                        hab die ganzen Meldungen jetzt weg bekommen. Hab in der motion.conf das video device auf 10 gesetzt
                                          #98
                                          Moin,
                                          ich kenne die Software nicht, aber so macht man das normalerweise nicht. Wenn Du etwas in einem Programm nutzen oder deaktivieren möchtest, dann sollte man in der passenden Konfigurationsdatei entweder etwas aktivieren oder deaktivieren.
                                          Du hast nur einen falschen Eintrag erstellt, der Dir irgendwann auf die Füße fallen wird.
                                          Da es leider wieder ein Bild von einer Textdatei ist, kann man leider nicht zitieren.
                                          Aber nur mal so am Rande, das ";" sollte Dein Freund sein, damit kommentierst Du, dass das Programm nicht mehr auf das "video device" achten soll
                                          Ich denke, so sollte es richtig sein.
                                          # video device (e.g. /dev/video.0) to be used for capturing
                                          ; video_device /dev/video.0
                                          Bernd
