    1.7k
  • Weihnachtsangebot 2025! 🎄
    2.1k
lovelace uinspanelsonoff
    @armilar Ansonsten gebt ihr die dependencies ja immer ohne Version an. Eventuell habt ihr dadurch unterschiede? Schon verglichen was installiert wurde?
    https://www.npmjs.com/package/dayjs?activeTab=versions
    1.11.12 ist ja erst 19 Tage alt.
    TT-Tom
    #6021
    @haus-automatisierung
    Das ist das Log von @MichaelF
    Er bekommt trotzdem die Fehlermeldung das dayjs nicht gefunden wird.
    javascript.0
    2024-08-06 12:44:10.233	info	requesting all objects
    javascript.0
    2024-08-06 12:44:10.231	info	requesting all states
    javascript.0
    2024-08-06 12:44:05.205	debug	Loaded TypeScript definitions for request: ["node_modules/@types/request/package.json","node_modules/@types/request/index.d.ts"]
    javascript.0
    2024-08-06 12:44:05.171	debug	Loaded TypeScript definitions for node: ["node_modules/@types/node/package.json","node_modules/@types/node/index.d.ts","node_modules/@types/node/assert.d.ts","node_modules/@types/node/assert/strict.d.ts","node_modules/@types/node/globals.d.ts","node_modules/@types/node/async_hooks.d.ts","node_modules/@types/node/buffer.d.ts","node_modules/@types/node/child_process.d.ts","node_modules/@types/node/cluster.d.ts","node_modules/@types/node/console.d.ts","node_modules/@types/node/constants.d.ts","node_modules/@types/node/crypto.d.ts","node_modules/@types/node/dgram.d.ts","node_modules/@types/node/diagnostics_channel.d.ts","node_modules/@types/node/dns.d.ts","node_modules/@types/node/dns/promises.d.ts","node_modules/@types/node/domain.d.ts","node_modules/@types/node/dom-events.d.ts","node_modules/@types/node/events.d.ts","node_modules/@types/node/fs.d.ts","node_modules/@types/node/fs/promises.d.ts","node_modules/@types/node/http.d.ts","node_modules/@types/node/http2.d.ts","node_modules/@types/node/https.d.ts","node_modules/@types/node/inspector.d.ts","node_modules/@types/node/module.d.ts","node_modules/@types/node/net.d.ts","node_modules/@types/node/os.d.ts","node_modules/@types/node/path.d.ts","node_modules/@types/node/perf_hooks.d.ts","node_modules/@types/node/process.d.ts","node_modules/@types/node/punycode.d.ts","node_modules/@types/node/querystring.d.ts","node_modules/@types/node/readline.d.ts","node_modules/@types/node/readline/promises.d.ts","node_modules/@types/node/repl.d.ts","node_modules/@types/node/sea.d.ts","node_modules/@types/node/stream.d.ts","node_modules/@types/node/stream/promises.d.ts","node_modules/@types/node/stream/consumers.d.ts","node_modules/@types/node/stream/web.d.ts","node_modules/@types/node/string_decoder.d.ts","node_modules/@types/node/test.d.ts","node_modules/@types/node/timers.d.ts","node_modules/@types/node/timers/promises.d.ts","node_modules/@types/node/tls.d.ts","node_modules/@types/node/trace_events.d.ts","node_modules/@types/node/tty.d.ts","node_modules/@types/node/url.d.ts","node_modules/@types/node/util.d.ts","node_modules/@types/node/v8.d.ts","node_modules/@types/node/vm.d.ts","node_modules/@types/node/wasi.d.ts","node_modules/@types/node/worker_threads.d.ts","node_modules/@types/node/zlib.d.ts","node_modules/@types/node/globals.global.d.ts"]
    javascript.0
    2024-08-06 12:44:05.117	debug	Installed custom dependency: "dayjs@latest"
    javascript.0
    2024-08-06 12:43:49.595	debug	Found custom dependency in config: "dayjs@latest"
    javascript.0
    2024-08-06 12:43:49.557	debug	Installed custom dependency: "moment@latest"
    javascript.0
    2024-08-06 12:43:34.083	debug	Found custom dependency in config: "moment@latest"
    javascript.0
    2024-08-06 12:43:34.075	debug	Installed custom dependency: "moment-parseformat@latest"
    javascript.0
    2024-08-06 12:43:18.791	debug	Found custom dependency in config: "moment-parseformat@latest"
    javascript.0
    2024-08-06 12:43:18.741	debug	Installed custom dependency: "node-ssh@latest"
    javascript.0
    2024-08-06 12:43:02.887	debug	Found custom dependency in config: "node-ssh@latest"
    javascript.0
    2024-08-06 12:43:02.730	debug	Installed custom dependency: "simple-ssh@latest"
    javascript.0
    2024-08-06 12:42:46.936	debug	Found custom dependency in config: "simple-ssh@latest"
    javascript.0
    2024-08-06 12:42:46.935	debug	Found installed libraries: ["moment","moment-parseformat","node-ssh","simple-ssh"]
    javascript.0
    2024-08-06 12:42:46.883	debug	config.subscribe (Do not subscribe all states on start): false
    javascript.0
    2024-08-06 12:42:46.840	info	starting. Version 8.7.6 in /opt/iobroker/node_modules/iobroker.javascript, node: v20.16.0, js-controller: 6.0.9
    javascript.0
    2024-08-06 12:42:41.588	debug	Plugin sentry Initialize Plugin (enabled=true)
    post zum Inhalt des Verzeichnis
    Edit: die Daten sind alle da, auch das System ist aktuell. Trotzdem kommt es zu den Meldungen.
    Das ist der Code Ausschnitt vom Script
    async function Init_dayjs() {
        try {
            //Loading dayjs
            const dayjs = require('dayjs');
            const dayjsLanguages: any = ['en','de','nl','da','es','fr','it','ru','nb','nn',
                                         'pl','pt','af','ar','bg','ca','cs','el','et','fa',
                                         'fi','he','hr','hu','hy-am','id','is','lb','lt','ro',
                                         'sk','sl','sv','th','tr','uk','vi','zh-cn','zh-tw']
            for (let i=0; i<dayjsLanguages.length;i++) {
                require('dayjs/locale/'+ dayjsLanguages[i]);
            dayjs.locale(getDayjsLocale());
        } catch (err: any) {
            log('error at function init_dayjs: ' + err.message,'warn');
    Init_dayjs();
    Gruß Tom
    https://github.com/tt-tom17
    NSPanel Script Wiki
    NSPanel Adapter Wiki
    Rene55R 1 Antwort Letzte Antwort
    • T TT-Tom
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
          try {
              //Loading dayjs
      Init_dayjs();
      Rene55R Offline
      Rene55R Offline
      Rene55
      #6022
      @tt-tom Ich habe gerade nochmal ein Backup vom 09.06. draufgeworfen. Darin js-Controller 5.0.19 und javascript-adapter 8.5.0. Hier tritt kein dayjs-Fehler auf.
      Host: Fujitsu Intel(R) Pentium(R) CPU G4560T, 32 GB RAM, Proxmox 8.x + lxc Ubuntu 22.04
      ioBroker (8 GB RAM) Node.js: 20.19.1, NPM: 10.8.2, js-Controller: 7.0.6, Admin: 7.6.3
      Wetterstation: Froggit WH3000SE V1.6.6
      • Rene55R Rene55
        TT-Tom
        #6023
        @rene55
        das ist interessant, kannst du mal bitte die Pfade kontrollieren, wo die npm-Module installiert sind.
        Hast du vom 9.6. dann das Update auf die aktuellen Versionen gemacht?
        @haus-automatisierung der Post von Rene55, vielleicht ist das noch ein wichtiger Hinweis.
        @Armilar was mir jetzt noch einfällt ist der Zusatz mit dem default
        const dayjs = require('dayjs').default;
        Matthias muss/soll das noch so geschrieben werden? Wurde eine zeitlang hier im Forum so erwähnt oder ist das mit der aktuellen JavaScript Version nicht mehr nötig?
        Gruß Tom
        NSPanel Script Wiki
        haus-automatisierungH Rene55R 2 Antworten Letzte Antwort
        • T TT-Tom
          @rene55
          haus-automatisierungH Online
          #6024
          @tt-tom sagte in SONOFF NSPanel mit Lovelace UI:
          Copy to Clipboardconst dayjs = require('dayjs').default;
          Wenn default existiert, wird das automatisch zurückgeliefert. Also nein, weglassen.
            SuFra
            #6025
            Hallo zusammen.
            Ich habe gerade auch mein System auf JS Controller 6.0.9 upgedatet und nun die gleiche Fehlermeldung beim Starten/Compilieren der Scripte.
            frank@iobroker-SuFra:/$ cd /opt/iobroker/node_modules/dayjs
            -bash: cd: /opt/iobroker/node_modules/dayjs: No such file or directory
            frank@iobroker-SuFra:/$ cd /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs
            frank@iobroker-SuFra:/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs$ ls -la
            total 152
            drwxrwxr-x+ 5 iobroker iobroker  4096 Aug  7 17:50 .
            drwxrwxr-x+ 6 iobroker iobroker  4096 Aug  7 17:50 ..
            -rw-rw-r--+ 1 iobroker iobroker 79810 Aug  7 17:50 CHANGELOG.md
            -rw-rw-r--+ 1 iobroker iobroker  7160 Aug  7 17:50 dayjs.min.js
            -rw-rw-r--+ 1 iobroker iobroker    94 Aug  7 17:50 .editorconfig
            drwxrwxr-x+ 4 iobroker iobroker  4096 Aug  7 17:50 esm
            -rw-rw-r--+ 1 iobroker iobroker 13872 Aug  7 17:50 index.d.ts
            -rw-rw-r--+ 1 iobroker iobroker  1072 Aug  7 17:50 LICENSE
            drwxrwxr-x+ 2 iobroker iobroker  4096 Aug  7 17:50 locale
            -rw-rw-r--+ 1 iobroker iobroker  5033 Aug  7 17:50 locale.json
            -rw-rw-r--+ 1 iobroker iobroker  2526 Aug  7 17:50 package.json
            drwxrwxr-x+ 2 iobroker iobroker  4096 Aug  7 17:50 plugin
            -rw-rw-r--+ 1 iobroker iobroker  7411 Aug  7 17:50 README.md
            Gruß Frank
            HA-Cluster 1x NUC11TNHI50L00, 2x NUC11TNHI30L00, 1x BSi3, 1x BSi5
            LXC's: ioBroker, (3x Redis), PiHole, Grafana, Heimdall, MariaDB, InfulxDB, TasmoAdmin, NTP Server, Zabbix, Frigate, nextCloud, PeaNUT
            VM's: PBS, trueNAS (Plex)
              SuFra
              #6026
              iob diag:
              Skript v.2024-05-22
              *** BASE SYSTEM ***
               Static hostname: iobroker-SuFra
                     Icon name: computer-container
                       Chassis: container
                Virtualization: lxc
              Operating System: Ubuntu 22.04.4 LTS
                        Kernel: Linux 6.8.8-4-pve
                  Architecture: x86-64
              model name      : 11th Gen Intel(R) Core(TM) i5-1135G7 @ 2.40GHz
              Docker          : false
              Virtualization  : lxc
              Kernel          : x86_64
              Userland        : 64 bit
              Systemuptime and Load:
               18:11:20 up  5:15,  2 users,  load average: 0.15, 0.41, 0.47
              CPU threads: 4
              *** Time and Time Zones ***
                             Local time: Wed 2024-08-07 18:11:20 CEST
                         Universal time: Wed 2024-08-07 16:11:20 UTC
                               RTC time: n/a
                            NTP service: inactive
                        RTC in local TZ: no
              *** Users and Groups ***
              User that called 'iob diag':
              frank
              HOME=/home/frank
              GROUPS=frank sudo iobroker
              iobroker
              HOME=/home/iobroker
              GROUPS=iobroker tty dialout audio video
              *** Display-Server-Setup ***
              Display-Server: false
              Desktop:
              Terminal:
              Boot Target:    multi-user.target
              *** MEMORY ***
              Mem:            8.2G        1.5G        6.4G        0.0K        347M        6.7G
              Swap:           4.1G          0B        4.1G
              Total:           12G        1.5G         10G
              Active iob-Instances:   20
                       8192 M total memory
                       1475 M used memory
                       1621 M active memory
                        120 M inactive memory
                       6368 M free memory
                          0 M buffer memory
                        347 M swap cache
                       4096 M total swap
                          0 M used swap
                       4096 M free swap
              top - 18:11:20 up  5:15,  2 users,  load average: 0.15, 0.41, 0.47
              Tasks:  47 total,   1 running,  46 sleeping,   0 stopped,   0 zombie
              %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
              MiB Mem :   8192.0 total,   6368.2 free,   1475.8 used,    347.9 buff/cache
              MiB Swap:   4096.0 total,   4096.0 free,      0.0 used.   6716.0 avail Mem
              *** FAILED SERVICES ***
                UNIT                 LOAD   ACTIVE SUB    DESCRIPTION
              * run-rpc_pipefs.mount loaded failed failed RPC Pipe File System
              1 loaded units listed.
              *** FILESYSTEM ***
              /dev/rbd3      ext4       20G   12G  7.4G  61% /
              none           tmpfs     492K  4.0K  488K   1% /dev
              efivarfs       efivarfs  192K  110K   78K  59% /sys/firmware/efi/efivars
              tmpfs          tmpfs      16G     0   16G   0% /dev/shm
              tmpfs          tmpfs     6.3G  116K  6.3G   1% /run
              tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
              tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-sysusers.service
              dmesg: read kernel buffer failed: Operation not permitted
              Show mounted filesystems:
              TARGET                                        SOURCE                         FSTYPE      OPTIONS
              /                                             /dev/rbd3                      ext4        rw,relatime,stripe=16
              |-/run                                        tmpfs                          tmpfs       rw,nosuid,nodev,size=6503388k,nr_inodes=819200,mode=755,uid=100000,gid=100000,inode64
              | |-/run/lock                                 tmpfs                          tmpfs       rw,nosuid,nodev,noexec,relatime,size=5120k,uid=100000,gid=100000,inode64
              | `-/run/credentials/systemd-sysusers.service tmpfs                          tmpfs       ro,nosuid,nodev,noexec,relatime,size=1024k,nr_inodes=1024,mode=700,uid=100000,gid=100000,inode64
              |-/dev                                        none                           tmpfs       rw,relatime,size=492k,mode=755,uid=100000,gid=100000,inode64
              | |-/dev/shm                                  tmpfs                          tmpfs       rw,nosuid,nodev,uid=100000,gid=100000,inode64
              | |-/dev/mqueue                               mqueue                         mqueue      rw,relatime
              | |-/dev/full                                 udev[/full]                    devtmpfs    rw,nosuid,relatime,size=16224644k,nr_inodes=4056161,mode=755,inode64
              | |-/dev/null                                 udev[/null]                    devtmpfs    rw,nosuid,relatime,size=16224644k,nr_inodes=4056161,mode=755,inode64
              | |-/dev/random                               udev[/random]                  devtmpfs    rw,nosuid,relatime,size=16224644k,nr_inodes=4056161,mode=755,inode64
              | |-/dev/tty                                  udev[/tty]                     devtmpfs    rw,nosuid,relatime,size=16224644k,nr_inodes=4056161,mode=755,inode64
              | |-/dev/urandom                              udev[/urandom]                 devtmpfs    rw,nosuid,relatime,size=16224644k,nr_inodes=4056161,mode=755,inode64
              | |-/dev/zero                                 udev[/zero]                    devtmpfs    rw,nosuid,relatime,size=16224644k,nr_inodes=4056161,mode=755,inode64
              | |-/dev/pts                                  devpts                         devpts      rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
              | |-/dev/ptmx                                 devpts[/ptmx]                  devpts      rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
              | |-/dev/console                              devpts[/0]                     devpts      rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
              | |-/dev/tty1                                 devpts[/1]                     devpts      rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
              | `-/dev/tty2                                 devpts[/2]                     devpts      rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
              |-/proc                                       proc                           proc        rw,nosuid,nodev,noexec,relatime
              | |-/proc/sys                                 proc[/sys]                     proc        ro,relatime
              | | |-/proc/sys/net                           proc[/sys/net]                 proc        rw,nosuid,nodev,noexec,relatime
              | | |-/proc/sys/fs/binfmt_misc                binfmt_misc                    binfmt_misc rw,nosuid,nodev,noexec,relatime
              | | `-/proc/sys/kernel/random/boot_id         none[/.lxc-boot-id]            tmpfs       ro,nosuid,nodev,noexec,relatime,size=492k,mode=755,uid=100000,gid=100000,inode64
              | |-/proc/sysrq-trigger                       proc[/sysrq-trigger]           proc        ro,relatime
              | |-/proc/cpuinfo                             lxcfs[/proc/cpuinfo]           fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
              | |-/proc/diskstats                           lxcfs[/proc/diskstats]         fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
              | |-/proc/loadavg                             lxcfs[/proc/loadavg]           fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
              | |-/proc/meminfo                             lxcfs[/proc/meminfo]           fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
              | |-/proc/slabinfo                            lxcfs[/proc/slabinfo]          fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
              | |-/proc/stat                                lxcfs[/proc/stat]              fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
              | |-/proc/swaps                               lxcfs[/proc/swaps]             fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
              | `-/proc/uptime                              lxcfs[/proc/uptime]            fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
              `-/sys                                        sysfs                          sysfs       ro,nosuid,nodev,noexec,relatime
                |-/sys/fs/fuse/connections                  fusectl                        fusectl     rw,nosuid,nodev,noexec,relatime
                |-/sys/devices/virtual/net                  sysfs[/devices/virtual/net]    sysfs       rw,nosuid,nodev,noexec,relatime
                |-/sys/kernel/debug                         debugfs                        debugfs     rw,nosuid,nodev,noexec,relatime
                |-/sys/kernel/security                      securityfs                     securityfs  rw,nosuid,nodev,noexec,relatime
                |-/sys/fs/pstore                            pstore                         pstore      rw,nosuid,nodev,noexec,relatime
                |-/sys/firmware/efi/efivars                 efivarfs                       efivarfs    rw,nosuid,nodev,noexec,relatime
                |-/sys/fs/cgroup                            none                           cgroup2     rw,nosuid,nodev,noexec,relatime
                `-/sys/devices/system/cpu                   lxcfs[/sys/devices/system/cpu] fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
              /var:
              999M    /var/
              491M    /var/log
              488M    /var/log/journal
              337M    /var/log/journal/7ec90df983fc41e487e36202c16059a2
              320M    /var/lib
              Archived and active journals take up 24.5M in the file system.
              /opt/iobroker/backups:
              139M    /opt/iobroker/backups/
              4.0K    /opt/iobroker/backups/redistmp
              /opt/iobroker/iobroker-data:
              716M    /opt/iobroker/iobroker-data/
              424M    /opt/iobroker/iobroker-data/files
              198M    /opt/iobroker/iobroker-data/backup-objects
              89M     /opt/iobroker/iobroker-data/files/echarts.admin
              67M     /opt/iobroker/iobroker-data/files/javascript.admin
              45M     /opt/iobroker/iobroker-data/objects.jsonl
              35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
              33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
              24M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map
              24M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.2b7495c2.js.map
              USB-Devices by-id:
              No Devices found 'by-id'
              HINT:
              Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
              tcp
              *** NodeJS-Installation ***
              /usr/bin/nodejs         v20.16.0
              /usr/bin/node           v20.16.0
              /usr/bin/npm            10.8.1
              /usr/bin/npx            10.8.1
              /usr/bin/corepack       0.28.2
              nodejs:
                Installed: 20.16.0-1nodesource1
                Candidate: 20.16.0-1nodesource1
                Version table:
               *** 20.16.0-1nodesource1 1001
                      500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
                      100 /var/lib/dpkg/status
                   20.15.1-1nodesource1 1001
                   20.15.0-1nodesource1 1001
                   20.14.0-1nodesource1 1001
                   20.13.1-1nodesource1 1001
                   20.13.0-1nodesource1 1001
                   20.12.2-1nodesource1 1001
                   20.12.1-1nodesource1 1001
                   20.12.0-1nodesource1 1001
                   20.11.1-1nodesource1 1001
                   20.11.0-1nodesource1 1001
                   20.10.0-1nodesource1 1001
                   20.9.0-1nodesource1 1001
                   20.8.1-1nodesource1 1001
                   20.8.0-1nodesource1 1001
                   20.7.0-1nodesource1 1001
                   20.6.1-1nodesource1 1001
                   20.6.0-1nodesource1 1001
                   20.5.1-1nodesource1 1001
                   20.5.0-1nodesource1 1001
                   20.4.0-1nodesource1 1001
                   20.3.1-1nodesource1 1001
                   20.3.0-1nodesource1 1001
                   20.2.0-1nodesource1 1001
                   20.1.0-1nodesource1 1001
                   20.0.0-1nodesource1 1001
                   12.22.9~dfsg-1ubuntu3.6 500
                      500 http://archive.ubuntu.com/ubuntu jammy-updates/universe amd64 Packages
                      500 http://archive.ubuntu.com/ubuntu jammy-security/universe amd64 Packages
                   12.22.9~dfsg-1ubuntu3 500
                      500 http://archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
              No problems detected
              Errors in npm tree:
              *** ioBroker-Installation ***
              ioBroker Status
              Objects type: redis
              States  type: redis
              Core adapters versions
              admin:          7.0.22
              javascript:     8.7.6
              nodejs modules from github:     0
              Adapter State
              + system.adapter.accuweather.0            : accuweather           : iobroker-SuFra                           -  enabled
              + system.adapter.admin.0                  : admin                 : iobroker-SuFra                           -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                system.adapter.admin.1                  : admin                 : iobroker-SuFra                           - disabled, port: 8083, bind: 0.0.0.0 (SSL), run as: admin
              + system.adapter.alexa2.0                 : alexa2                : iobroker-SuFra                           -  enabled
                system.adapter.alias-manager.0          : alias-manager         : iobroker-SuFra                           -  enabled
              + system.adapter.daikin-cloud.0           : daikin-cloud          : iobroker-SuFra                           -  enabled
                system.adapter.daswetter.0              : daswetter             : iobroker-SuFra                           -  enabled
                system.adapter.devices.0                : devices               : iobroker-SuFra                           -  enabled
              + system.adapter.discovery.0              : discovery             : iobroker-SuFra                           -  enabled
                system.adapter.echarts.0                : echarts               : iobroker-SuFra                           - disabled
                system.adapter.flot.0                   : flot                  : iobroker-SuFra                           -  enabled
              + system.adapter.heatingcontrol.0         : heatingcontrol        : iobroker-SuFra                           -  enabled
              + system.adapter.iot.0                    : iot                   : iobroker-SuFra                           -  enabled
              + system.adapter.javascript.0             : javascript            : iobroker-SuFra                           -  enabled
              + system.adapter.modbus.0                 : modbus                : iobroker-SuFra                           -  enabled
              + system.adapter.mqtt.0                   : mqtt                  : iobroker-SuFra                           -  enabled, port: 1884, bind: 0.0.0.0
                system.adapter.proxmox.0                : proxmox               : iobroker-SuFra                           - disabled, port: 8006
                system.adapter.proxmox.1                : proxmox               : iobroker-SuFra                           - disabled, port: 8006
                system.adapter.puppeteer.0              : puppeteer             : iobroker-SuFra                           - disabled
              + system.adapter.shelly.0                 : shelly                : iobroker-SuFra                           -  enabled, port: 1882, bind: 0.0.0.0
              + system.adapter.sonoff.0                 : sonoff                : iobroker-SuFra                           -  enabled, port: 1883, bind: 0.0.0.0
              + system.adapter.sql.0                    : sql                   : iobroker-SuFra                           -  enabled, port: 3306
              + system.adapter.sql.1                    : sql                   : iobroker-SuFra                           -  enabled, port: 3306
              + system.adapter.sql.2                    : sql                   : iobroker-SuFra                           -  enabled, port: 3306
              + system.adapter.statistics.0             : statistics            : iobroker-SuFra                           -  enabled
              + system.adapter.tahoma.0                 : tahoma                : iobroker-SuFra                           -  enabled
                system.adapter.tr-064.0                 : tr-064                : iobroker-SuFra                           - disabled
                system.adapter.vis.0                    : vis                   : iobroker-SuFra                           -  enabled
              + system.adapter.web.0                    : web                   : iobroker-SuFra                           -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
              + system.adapter.zigbee.0                 : zigbee                : iobroker-SuFra                           -  enabled, port: tcp://10.10.20.111:6638
              + instance is alive
              ioBroker-Repositories
              Active repo(s): stable
              Upgrade policy: none
              Installed ioBroker-Instances
              Used repository: stable
              Adapter    "accuweather"  : 1.5.0    , installed 1.5.0
              Adapter    "admin"        : 7.0.22   , installed 7.0.22
              Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
              Adapter    "alias-manager": 1.2.6    , installed 1.2.6
              Adapter    "chromecast"   : 3.4.0    , installed 3.4.0
              Adapter    "daikin-cloud" : 0.4.8    , installed 0.4.8
              Adapter    "daswetter"    : 3.1.15   , installed 3.1.15
              Adapter    "devices"      : 1.1.5    , installed 1.1.5
              Adapter    "discovery"    : 4.5.0    , installed 4.5.0
              Adapter    "echarts"      : 1.7.2    , installed 1.7.2
              Adapter    "heatingcontrol": 2.12.8  , installed 2.12.8
              Adapter    "iot"          : 3.3.0    , installed 3.3.0
              Adapter    "javascript"   : 8.7.6    , installed 8.7.6
              Controller "js-controller": 6.0.9    , installed 6.0.9
              Adapter    "modbus"       : 6.2.3    , installed 6.2.3
              Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
              Adapter    "proxmox"      : 2.3.0    , installed 2.3.0
              Adapter    "puppeteer"    : 0.3.0    , installed 0.3.0
              Adapter    "shelly"       : 7.0.0    , installed 7.0.0
              Adapter    "socketio"     : 6.7.1    , installed 6.7.0  [Updatable]
              Adapter    "sonoff"       : 3.1.0    , installed 3.1.0
              Adapter    "sql"          : 3.0.1    , installed 3.0.1
              Adapter    "statistics"   : 2.4.0    , installed 2.4.0
              Adapter    "tahoma"       : 0.10.4   , installed 0.10.4
              Adapter    "ws"           : 2.6.2    , installed 2.6.1  [Updatable]
              Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
              Objects and States
              Objects:        11193
              States:         9228
              Hit:1 http://archive.ubuntu.com/ubuntu jammy InRelease
              Hit:2 http://archive.ubuntu.com/ubuntu jammy-updates InRelease
              Hit:3 http://archive.ubuntu.com/ubuntu jammy-security InRelease
              Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
              Hit:5 https://repo.zabbix.com/zabbix/6.4/ubuntu jammy InRelease
              Reading package lists...
              Pending Updates: 0
              *** Listening Ports ***
              tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      106        8828040    100/systemd-resolve
              tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          8826131    1/init
              tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       8832002    533/io.shelly.0
              tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       8829055    503/io.sonoff.0
              tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       8824769    488/io.mqtt.0
              tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       8824770    488/io.mqtt.0
              tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          8828322    416/master
              tcp6       0      0 :::10050                :::*                    LISTEN      110        8827415    116/zabbix_agent2
              tcp6       0      0 :::22                   :::*                    LISTEN      0          8828000    1/init
              tcp6       0      0 :::111                  :::*                    LISTEN      0          8826133    1/init
              tcp6       0      0 ::1:25                  :::*                    LISTEN      0          8828323    416/master
              tcp6       0      0 :::8082                 :::*                    LISTEN      1001       8831226    652/io.web.0
              tcp6       0      0 :::8081                 :::*                    LISTEN      1001       8824491    173/io.admin.0
              udp        0      0 127.0.0.53:53           0.0.0.0:*                           106        8828039    100/systemd-resolve
              udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          8826132    1/init
              udp6       0      0 :::111                  :::*                                0          8826134    1/init
              2024-08-07 18:02:59.701  - info: javascript.0 (1795) script.js.NSPanel.Panel_2_Büro: registered 30 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
              2024-08-07 18:02:59.704  - info: javascript.0 (1795) script.js.NSPanel.Panel_2_Büro: No Updates for NSPanel available
              2024-08-07 18:02:59.748  - info: javascript.0 (1795) script.js.NSPanel.Panel_2_Büro: Desired TFT Firmware: 53 / v4.4.0
              2024-08-07 18:02:59.748  - info: javascript.0 (1795) script.js.NSPanel.Panel_2_Büro: Installed TFT Firmware: 53 / v4.4.0
              2024-08-07 18:02:59.768  - info: javascript.0 (1795) script.js.NSPanel.Panel_2_Büro: Debug mode disabled
              2024-08-07 18:03:00.206  - info: javascript.0 (1795) script.js.NSPanel.Panel_2_Büro: Desired TFT Firmware: 53 / v4.4.0
              2024-08-07 18:03:00.207  - info: javascript.0 (1795) script.js.NSPanel.Panel_2_Büro: Installed TFT Firmware: 53 / v4.4.0
              2024-08-07 18:03:00.492  - info: javascript.0 (1795) script.js.NSPanel.Panel_2_Büro: Desired TFT Firmware: 53 / v4.4.0
              2024-08-07 18:03:00.492  - info: javascript.0 (1795) script.js.NSPanel.Panel_2_Büro: Installed TFT Firmware: 53 / v4.4.0
              2024-08-07 18:03:01.382  - info: javascript.0 (1795) script.js.NSPanel.Panel_2_Büro: Start MQTT-Port-Check -------------------------------------
              2024-08-07 18:03:01.382  - info: javascript.0 (1795) script.js.NSPanel.Panel_2_Büro: -- admin.0                   - 8081
              2024-08-07 18:03:01.382  - info: javascript.0 (1795) script.js.NSPanel.Panel_2_Büro: -- mqtt.0                    - 1884
              2024-08-07 18:03:01.382  - info: javascript.0 (1795) script.js.NSPanel.Panel_2_Büro: -- shelly.0                  - 1882
              2024-08-07 18:03:01.382  - info: javascript.0 (1795) script.js.NSPanel.Panel_2_Büro: -- sonoff.0                  - 1883
              2024-08-07 18:03:01.382  - info: javascript.0 (1795) script.js.NSPanel.Panel_2_Büro: -- sql.0                     - 3306
              2024-08-07 18:03:01.382  - info: javascript.0 (1795) script.js.NSPanel.Panel_2_Büro: -- sql.1                     - 3306
              2024-08-07 18:03:01.382  - info: javascript.0 (1795) script.js.NSPanel.Panel_2_Büro: -- sql.2                     - 3306
              2024-08-07 18:03:01.382  - info: javascript.0 (1795) script.js.NSPanel.Panel_2_Büro: -- web.0                     - 8082
              2024-08-07 18:03:01.382  - info: javascript.0 (1795) script.js.NSPanel.Panel_2_Büro: -- zigbee.0                  - tcp
              2024-08-07 18:03:01.383  - info: javascript.0 (1795) script.js.NSPanel.Panel_2_Büro: - MQTT-Port-Check OK: Instance of Adapter: mqtt.0 is running on Port:1884
              2024-08-07 18:03:01.383  - info: javascript.0 (1795) script.js.NSPanel.Panel_2_Büro: End MQTT-Port-Check ---------------------------------------
              2024-08-07 18:03:07.443  - info: sonoff.0 (503) Client [Shelly-Wz-Decke] connected with secret 1723046587442_9493
              2024-08-07 18:04:50.965  - info: admin.0 (173) ==> Connected system.user.admin from ::ffff:10.10.20.229
              2024-08-07 18:11:39.077  - info: admin.0 (173) <== Disconnect system.user.admin from ::ffff:10.10.20.229 admin
              2024-08-07 18:11:40.923  - info: admin.0 (173) ==> Connected system.user.admin from ::ffff:10.10.20.229
                                      v.2024-05-22
                       Chassis: container
                Virtualization: lxc
              Installation:           lxc
              Kernel:                 x86_64
              Userland:               64 bit
              Timezone:               Europe/Berlin (CEST, +0200)
              User-ID:                1000
              Pending OS-Updates:     0
              Pending iob updates:    2
              Nodejs-Installation:
              /usr/bin/npm            10.8.1
              /usr/bin/npx            10.8.1
              Recommended versions are nodejs 20.16.0 and npm 10.8.1
              MEMORY:
              Mem:            8.2G        1.6G        5.9G        0.0K        636M        6.6G
              Swap:           4.1G          0B        4.1G
              Total:           12G        1.6G         10G
              ioBroker Core:          js-controller           6.0.9
                                      admin                   7.0.22
              Objects type: redis
              States  type: redis
              Objects:                11193
              States:                 9228
              Size of iob-Database:
              15M     /opt/iobroker/iobroker-data/objects.json.migrated
              15M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
              0       /opt/iobroker/iobroker-data/objects.json.broken
              17M     /opt/iobroker/iobroker-data/states.jsonl
              2.0M    /opt/iobroker/iobroker-data/states.json.migrated
              2.0M    /opt/iobroker/iobroker-data/states.json.bak.migrated
              0       /opt/iobroker/iobroker-data/states.json.broken
              • T TT-Tom
                @rene55
                Rene55R Offline
                Rene55R Offline
                Rene55
                #6027
                @tt-tom Sorry für die späte Antwort. Ich habe in meiner Installation die Module dayjs, moment und moment-parseformat hier /opt/iobroker/node_modules/iobroker.javascript/node_modules/ gefunden.
                Ich hab hier noch nicht weiter upgedatet. Womit sollte ich anfangen?
                ArmilarA 2 Antworten Letzte Antwort
                • Rene55R Rene55
                  ArmilarA Offline
                  ArmilarA Offline
                  Armilar
                  Most Active Forum Testing
                  #6028
                  @rene55
                  gefunden
                  das ist sehr interessant, denn die sollten eigentlich in:
                  etc.
                  liegen.
                  • Rene55R Rene55
                    ArmilarA Offline
                    ArmilarA Offline
                    Armilar
                    #6029
                    @rene55 sagte in SONOFF NSPanel mit Lovelace UI:
                    Wenn das ein altes Backup ist, bringe erstmal das System auf den neuesten Stand
                    sudo apt-get update
                    sudo apt-get full-upgrade
                    sudo reboot
                    dann
                    iob stop
                    iob update
                    iob upgrade self
                    iob upgrade
                    iob fix
                    iob start
                    falls nodeJS noch 18 ist, sollte es jetzt mit nochmaligem:
                    sudo apt-get update
                    sudo reboot
                    aktualisiert werden...
                    Falls das OS ein Debian Buster sein sollte, dann gibt es außer einer Neuinstallation mit anschließenden Backup-Einstellungen keine andere Wahl...
                    • Rene55R Offline
                      Rene55R Offline
                      Rene55
                      #6030
                      @armilar Ich habe gerade nochmals gesucht. In dieser Richtung hab eich nur Fundstelle_atIOB.png
                      Ich habe auf dem System kein '@iobroker-javascript'
                      • ArmilarA Armilar
                        sudo apt-get update
                        sudo reboot
                        dann
                        iob stop
                        iob update
                        iob upgrade self
                        iob upgrade
                        iob fix
                        iob start
                        sudo apt-get update
                        sudo reboot
                        Rene55R Offline
                        Rene55R Offline
                        Rene55
                        #6031
                        @armilar Wie gesagt: ich habe extra ein 'uralt' Backup rausgesucht. Ich wollte jetzt eigentlich Schritt für Schritt updaten um den Fehler -möglicherweise- einzugrenzen. Wenn ich das so mache, wird der Fehler wahrscheinlich wieder da sein. Oder?
                        • Rene55R Rene55
                          ArmilarA Offline
                          ArmilarA Offline
                          Armilar
                          #6032
                          @rene55
                          das Verzeichnis sollte sich nach der beschriebenen Update-Variante aber dann finden lassen.
                          Da wir nicht wissen, warum sich das so unterschiedlich darstellt, können wir auch nicht sagen, ob das Problem danach gelöst ist oder nicht... Lässt sich ja bei uns nicht reproduzieren...
                          • ArmilarA Armilar
                            @rene55
                            Rene55R Offline
                            Rene55R Offline
                            Rene55
                            #6033
                            @armilar OK. Dann arbeite ich mal eben die Updates durch.
                            • ArmilarA Armilar
                              @rene55
                              Rene55R Offline
                              Rene55R Offline
                              Rene55
                              #6034
                              @armilar So. Updates sind komplett durch. Habe jetzt das aktuellste Beta-System. Und der Fehler ist auch wieder da. Und nu??
                              • Rene55R Rene55
                                ArmilarA Offline
                                ArmilarA Offline
                                Armilar
                                #6035
                                @rene55
                                1. Jetzt poste mal ein iob diag
                                2. Stelle sicher, dass dayjs auch in der Javascript Instanz eingetragen ist
                                3. Überprüfe den Verzeichnispfad nochmal
                                • Rene55R Offline
                                  Rene55R Offline
                                  Rene55
                                  schrieb am zuletzt editiert von Rene55
                                  #6036
                                  @armilar Ich bin mir nicht sicher, ob wir hier das gleiche Ziel verfolgen. Diese Übung sollte nur dazu dienen, den Fehler einzugrenzen. Das von dir angegebene Verzeichnis existiert jetzt.Fundstelle_atIOBn.png
                                  Und auch die Ausgabe von Diag:```
                                                          v.2024-05-22
                                   Static hostname: iobroker-pmx
                                           Chassis: container ☐
                                    Virtualization: lxc
                                            Kernel: Linux 6.2.16-3-pve
                                  Installation:           lxc
                                  Kernel:                 x86_64
                                  Userland:               64 bit
                                  User-ID:                1000
                                  Pending iob updates:    0
                                  /usr/bin/npm            10.8.1
                                  /usr/bin/npx            10.8.1
                                  MEMORY:
                                  Mem:            2.1G        1.5G        230M         98K        432M        663M
                                  Swap:           536M         45K        536M
                                  Total:          2.7G        1.5G        767M
                                  Active iob-Instances:   11
                                  ioBroker Core:          js-controller           6.0.10
                                                          admin                   7.0.23
                                  Objects type: jsonl
                                  States  type: jsonl
                                  + system.adapter.admin.0                  : admin                 : iobroker-pmx                             -  enabled, port: 8081, bind: 192.168.69.109, run as: admin
                                    system.adapter.web.0                    : web                   : iobroker-pmx                             - disabled, port: 8082, bind: 0.0.0.0, run as: admin
                                  Objects:                51100
                                  States:                 38730
                                  43M     /opt/iobroker/iobroker-data/objects.jsonl
                                  11M     /opt/iobroker/iobroker-data/states.jsonl
                                  • Rene55R Rene55
                                                            v.2024-05-22
                                      Virtualization: lxc
                                    Installation:           lxc
                                    Kernel:                 x86_64
                                    Userland:               64 bit
                                    User-ID:                1000
                                    /usr/bin/npm            10.8.1
                                    /usr/bin/npx            10.8.1
                                    MEMORY:
                                    Swap:           536M         45K        536M
                                                            admin                   7.0.23
                                    Objects type: jsonl
                                    States  type: jsonl
                                    Objects:                51100
                                    States:                 38730
                                    ArmilarA Offline
                                    ArmilarA Offline
                                    Armilar
                                    #6037
                                    @rene55
                                    ist denn auch dayjs im Verzeichnis?
                                    • ArmilarA Armilar
                                      @rene55
                                      Rene55R Offline
                                      Rene55R Offline
                                      Rene55
                                      #6038
                                      @armilar Ja. Alle in der Instanz eingetragenen Module sind in dem Ordner drin.
                                      • Rene55R Rene55
                                        ArmilarA Offline
                                        ArmilarA Offline
                                        Armilar
                                        #6039
                                        @rene55
                                        @haus-automatisierung jetzt weiß ich auch nicht mehr weiter :confused:
                                        Das System und der ioBroker sollte nun auf dem aktuellsten Stand sein...
                                        @Rene55
                                        sende nochmal die Fehlermeldungen bitte...
                                        • ArmilarA Armilar
                                          @rene55
                                          @Rene55
                                          Rene55R Offline
                                          Rene55R Offline
                                          Rene55
                                          #6040
                                          @armilar Hier das Log vom Start:
                                          2024-08-07 23:31:01.945 - info: javascript.0 (398) Compiling TypeScript source script.js.common.NSPanel.NSPanelTS_44
                                          2024-08-07 23:31:09.877 - info: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: TypeScript compilation successful
                                          2024-08-07 23:31:10.207 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs'
                                          2024-08-07 23:31:10.207 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                          2024-08-07 23:31:10.208 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                          2024-08-07 23:31:10.208 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18)
                                          2024-08-07 23:31:10.208 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/de.js:1:86
                                          2024-08-07 23:31:10.208 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/de.js:1:243)
                                          2024-08-07 23:31:10.208 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                          2024-08-07 23:31:10.208 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                          2024-08-07 23:31:10.208 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                          2024-08-07 23:31:10.208 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                          2024-08-07 23:31:10.211 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs'
                                          2024-08-07 23:31:10.211 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                          2024-08-07 23:31:10.211 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                          2024-08-07 23:31:10.211 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18)
                                          2024-08-07 23:31:10.211 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/nl.js:1:86
                                          2024-08-07 23:31:10.211 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/nl.js:1:243)
                                          2024-08-07 23:31:10.211 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                          2024-08-07 23:31:10.211 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                          2024-08-07 23:31:10.212 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                          2024-08-07 23:31:10.212 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                          2024-08-07 23:31:10.213 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs'
                                          2024-08-07 23:31:10.214 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                          2024-08-07 23:31:10.214 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                          2024-08-07 23:31:10.214 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18)
                                          2024-08-07 23:31:10.214 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/da.js:1:86
                                          2024-08-07 23:31:10.214 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/da.js:1:243)
                                          2024-08-07 23:31:10.214 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                          2024-08-07 23:31:10.214 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                          2024-08-07 23:31:10.217 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                          2024-08-07 23:31:10.217 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                          2024-08-07 23:31:10.219 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs'
                                          2024-08-07 23:31:10.219 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                          2024-08-07 23:31:10.219 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                          2024-08-07 23:31:10.219 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18)
                                          2024-08-07 23:31:10.219 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/es.js:1:86
                                          2024-08-07 23:31:10.220 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/es.js:1:243)
                                          2024-08-07 23:31:10.220 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                          2024-08-07 23:31:10.220 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                          2024-08-07 23:31:10.220 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                          2024-08-07 23:31:10.220 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                          2024-08-07 23:31:10.222 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs'
                                          2024-08-07 23:31:10.222 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                          2024-08-07 23:31:10.222 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                          2024-08-07 23:31:10.222 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18)
                                          2024-08-07 23:31:10.222 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/fr.js:1:86
                                          2024-08-07 23:31:10.227 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/fr.js:1:243)
                                          2024-08-07 23:31:10.227 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                          2024-08-07 23:31:10.227 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                          2024-08-07 23:31:10.227 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                          2024-08-07 23:31:10.227 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                          2024-08-07 23:31:10.237 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs'
                                          2024-08-07 23:31:10.237 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                          2024-08-07 23:31:10.237 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                          2024-08-07 23:31:10.237 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18)
                                          2024-08-07 23:31:10.237 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/it.js:1:86
                                          2024-08-07 23:31:10.237 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/it.js:1:243)
                                          2024-08-07 23:31:10.237 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                          2024-08-07 23:31:10.237 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                          2024-08-07 23:31:10.237 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                          2024-08-07 23:31:10.237 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                          2024-08-07 23:31:10.240 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs'
                                          2024-08-07 23:31:10.240 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                          2024-08-07 23:31:10.240 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                          2024-08-07 23:31:10.240 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18)
                                          2024-08-07 23:31:10.240 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ru.js:1:86
                                          2024-08-07 23:31:10.240 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ru.js:1:243)
                                          2024-08-07 23:31:10.240 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                          2024-08-07 23:31:10.240 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                          2024-08-07 23:31:10.240 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                          2024-08-07 23:31:10.240 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                          2024-08-07 23:31:10.242 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs'
                                          2024-08-07 23:31:10.242 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                          2024-08-07 23:31:10.242 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                          2024-08-07 23:31:10.242 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18)
                                          2024-08-07 23:31:10.243 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/nb.js:1:86
                                          2024-08-07 23:31:10.243 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/nb.js:1:243)
                                          2024-08-07 23:31:10.243 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                          2024-08-07 23:31:10.243 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                          2024-08-07 23:31:10.243 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                          2024-08-07 23:31:10.243 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                          2024-08-07 23:31:10.245 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs'
                                          2024-08-07 23:31:10.245 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                          2024-08-07 23:31:10.245 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                          2024-08-07 23:31:10.245 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18)
                                          2024-08-07 23:31:10.245 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/nn.js:1:86
                                          2024-08-07 23:31:10.245 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/nn.js:1:243)
                                          2024-08-07 23:31:10.245 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                          2024-08-07 23:31:10.245 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                          2024-08-07 23:31:10.245 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                          2024-08-07 23:31:10.245 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                          2024-08-07 23:31:10.247 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs'
                                          2024-08-07 23:31:10.247 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                          2024-08-07 23:31:10.247 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                          2024-08-07 23:31:10.247 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18)
                                          2024-08-07 23:31:10.248 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/pl.js:1:86
                                          2024-08-07 23:31:10.248 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/pl.js:1:243)
                                          2024-08-07 23:31:10.248 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                          2024-08-07 23:31:10.248 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                          2024-08-07 23:31:10.248 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                          2024-08-07 23:31:10.248 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                          2024-08-07 23:31:10.250 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs'
                                          2024-08-07 23:31:10.250 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                          2024-08-07 23:31:10.250 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                          2024-08-07 23:31:10.250 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18)
                                          2024-08-07 23:31:10.250 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/pt.js:1:86
                                          2024-08-07 23:31:10.250 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/pt.js:1:243)
                                          2024-08-07 23:31:10.250 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                          2024-08-07 23:31:10.250 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                          2024-08-07 23:31:10.250 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                          2024-08-07 23:31:10.250 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                          2024-08-07 23:31:10.252 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs'
                                          2024-08-07 23:31:10.252 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                          2024-08-07 23:31:10.252 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                          2024-08-07 23:31:10.253 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18)
                                          2024-08-07 23:31:10.253 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/af.js:1:86
                                          2024-08-07 23:31:10.253 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/af.js:1:243)
                                          2024-08-07 23:31:10.253 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                          2024-08-07 23:31:10.253 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                          2024-08-07 23:31:10.253 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                          2024-08-07 23:31:10.253 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                          2024-08-07 23:31:10.255 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs'
                                          2024-08-07 23:31:10.255 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                          2024-08-07 23:31:10.255 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                          2024-08-07 23:31:10.256 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18)
                                          2024-08-07 23:31:10.256 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ar.js:1:86
                                          2024-08-07 23:31:10.256 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ar.js:1:243)
                                          2024-08-07 23:31:10.256 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                          2024-08-07 23:31:10.256 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                          2024-08-07 23:31:10.256 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                          2024-08-07 23:31:10.256 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                          2024-08-07 23:31:10.258 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs'
                                          2024-08-07 23:31:10.258 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                          2024-08-07 23:31:10.258 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                          2024-08-07 23:31:10.258 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18)
                                          2024-08-07 23:31:10.258 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/bg.js:1:86
                                          2024-08-07 23:31:10.259 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/bg.js:1:243)
                                          2024-08-07 23:31:10.259 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                          2024-08-07 23:31:10.259 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                          2024-08-07 23:31:10.259 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                          2024-08-07 23:31:10.259 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                          2024-08-07 23:31:10.261 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs'
                                          2024-08-07 23:31:10.261 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                          2024-08-07 23:31:10.261 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                          2024-08-07 23:31:10.261 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18)
                                          2024-08-07 23:31:10.261 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ca.js:1:86
                                          2024-08-07 23:31:10.261 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ca.js:1:243)
                                          2024-08-07 23:31:10.261 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                          2024-08-07 23:31:10.261 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                          2024-08-07 23:31:10.261 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                          2024-08-07 23:31:10.261 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                          2024-08-07 23:31:10.263 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs'
                                          2024-08-07 23:31:10.263 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                          2024-08-07 23:31:10.263 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                          2024-08-07 23:31:10.263 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18)
                                          2024-08-07 23:31:10.264 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/cs.js:1:86
                                          2024-08-07 23:31:10.264 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/cs.js:1:243)
                                          2024-08-07 23:31:10.270 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                          2024-08-07 23:31:10.270 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                          2024-08-07 23:31:10.270 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                          2024-08-07 23:31:10.275 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                          2024-08-07 23:31:10.277 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs'
                                          2024-08-07 23:31:10.277 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                          2024-08-07 23:31:10.277 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                          2024-08-07 23:31:10.277 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18)
                                          2024-08-07 23:31:10.278 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/el.js:1:86
                                          2024-08-07 23:31:10.278 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/el.js:1:243)
                                          2024-08-07 23:31:10.278 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                          2024-08-07 23:31:10.278 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                          2024-08-07 23:31:10.278 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                          2024-08-07 23:31:10.278 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                          2024-08-07 23:31:10.280 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs'
                                          2024-08-07 23:31:10.280 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                          2024-08-07 23:31:10.280 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                          2024-08-07 23:31:10.280 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18)
                                          2024-08-07 23:31:10.280 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/et.js:1:86
                                          2024-08-07 23:31:10.280 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/et.js:1:243)
                                          2024-08-07 23:31:10.280 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                          2024-08-07 23:31:10.280 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                          2024-08-07 23:31:10.280 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                          2024-08-07 23:31:10.280 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                          2024-08-07 23:31:10.282 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs'
                                          2024-08-07 23:31:10.282 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                          2024-08-07 23:31:10.282 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                          2024-08-07 23:31:10.282 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18)
                                          2024-08-07 23:31:10.282 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/fa.js:1:86
                                          2024-08-07 23:31:10.283 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/fa.js:1:243)
                                          2024-08-07 23:31:10.283 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                          2024-08-07 23:31:10.283 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                          2024-08-07 23:31:10.283 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                          2024-08-07 23:31:10.283 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                          2024-08-07 23:31:10.284 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs'
                                          2024-08-07 23:31:10.285 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                          2024-08-07 23:31:10.285 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                          2024-08-07 23:31:10.285 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18)
                                          2024-08-07 23:31:10.285 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/fi.js:1:86
                                          2024-08-07 23:31:10.285 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/fi.js:1:243)
                                          2024-08-07 23:31:10.285 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                          2024-08-07 23:31:10.285 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                          2024-08-07 23:31:10.285 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                          2024-08-07 23:31:10.285 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                          2024-08-07 23:31:10.287 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs'
                                          2024-08-07 23:31:10.287 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                          2024-08-07 23:31:10.287 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                          2024-08-07 23:31:10.287 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18)
                                          2024-08-07 23:31:10.287 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/he.js:1:86
                                          2024-08-07 23:31:10.287 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/he.js:1:243)
                                          2024-08-07 23:31:10.287 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                          2024-08-07 23:31:10.287 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                          2024-08-07 23:31:10.288 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                          2024-08-07 23:31:10.288 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                          2024-08-07 23:31:10.289 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs'
                                          2024-08-07 23:31:10.289 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                          2024-08-07 23:31:10.290 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                          2024-08-07 23:31:10.290 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18)
                                          2024-08-07 23:31:10.290 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/hr.js:1:86
                                          2024-08-07 23:31:10.290 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/hr.js:1:243)
                                          2024-08-07 23:31:10.290 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                          2024-08-07 23:31:10.290 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                          2024-08-07 23:31:10.290 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                          2024-08-07 23:31:10.290 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                          2024-08-07 23:31:10.292 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs'
                                          2024-08-07 23:31:10.292 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                          2024-08-07 23:31:10.292 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                          2024-08-07 23:31:10.292 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18)
                                          2024-08-07 23:31:10.292 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/hu.js:1:86
                                          2024-08-07 23:31:10.292 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/hu.js:1:243)
                                          2024-08-07 23:31:10.292 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                          2024-08-07 23:31:10.292 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                          2024-08-07 23:31:10.292 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                          2024-08-07 23:31:10.292 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                          2024-08-07 23:31:10.294 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs'
                                          2024-08-07 23:31:10.294 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                          2024-08-07 23:31:10.294 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                          2024-08-07 23:31:10.294 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18)
                                          2024-08-07 23:31:10.294 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/hy-am.js:1:86
                                          2024-08-07 23:31:10.295 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/hy-am.js:1:246)
                                          2024-08-07 23:31:10.295 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                          2024-08-07 23:31:10.295 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                          2024-08-07 23:31:10.295 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                          2024-08-07 23:31:10.295 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                          2024-08-07 23:31:10.296 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs'
                                          2024-08-07 23:31:10.297 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                          2024-08-07 23:31:10.297 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                          2024-08-07 23:31:10.297 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18)
                                          2024-08-07 23:31:10.297 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/id.js:1:86
                                          2024-08-07 23:31:10.297 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/id.js:1:243)
                                          2024-08-07 23:31:10.297 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                          2024-08-07 23:31:10.297 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                          2024-08-07 23:31:10.297 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                          2024-08-07 23:31:10.297 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                          2024-08-07 23:31:10.299 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs'
                                          2024-08-07 23:31:10.299 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                          2024-08-07 23:31:10.299 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                          2024-08-07 23:31:10.299 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18)
                                          2024-08-07 23:31:10.299 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/is.js:1:86
                                          2024-08-07 23:31:10.299 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/is.js:1:243)
                                          2024-08-07 23:31:10.299 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                          2024-08-07 23:31:10.299 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                          2024-08-07 23:31:10.299 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                          2024-08-07 23:31:10.300 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                          2024-08-07 23:31:10.301 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs'
                                          2024-08-07 23:31:10.301 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                          2024-08-07 23:31:10.301 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                          2024-08-07 23:31:10.301 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18)
                                          2024-08-07 23:31:10.302 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/lb.js:1:86
                                          2024-08-07 23:31:10.302 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/lb.js:1:243)
                                          2024-08-07 23:31:10.302 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                          2024-08-07 23:31:10.302 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                          2024-08-07 23:31:10.302 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                          2024-08-07 23:31:10.302 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                          2024-08-07 23:31:10.304 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs'
                                          2024-08-07 23:31:10.304 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                          2024-08-07 23:31:10.304 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                          2024-08-07 23:31:10.304 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18)
                                          2024-08-07 23:31:10.304 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/lt.js:1:86
                                          2024-08-07 23:31:10.304 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/lt.js:1:243)
                                          2024-08-07 23:31:10.304 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                          2024-08-07 23:31:10.304 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                          2024-08-07 23:31:10.304 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                          2024-08-07 23:31:10.304 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                          2024-08-07 23:31:10.306 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs'
                                          2024-08-07 23:31:10.306 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                          2024-08-07 23:31:10.306 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                          2024-08-07 23:31:10.306 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18)
                                          2024-08-07 23:31:10.306 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ro.js:1:86
                                          2024-08-07 23:31:10.307 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/ro.js:1:243)
                                          2024-08-07 23:31:10.307 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                          2024-08-07 23:31:10.307 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                          2024-08-07 23:31:10.307 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                          2024-08-07 23:31:10.307 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                          2024-08-07 23:31:10.309 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs'
                                          2024-08-07 23:31:10.309 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                          2024-08-07 23:31:10.309 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                          2024-08-07 23:31:10.309 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18)
                                          2024-08-07 23:31:10.309 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/sk.js:1:86
                                          2024-08-07 23:31:10.309 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/sk.js:1:243)
                                          2024-08-07 23:31:10.309 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                          2024-08-07 23:31:10.309 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                          2024-08-07 23:31:10.309 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                          2024-08-07 23:31:10.309 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                          2024-08-07 23:31:10.311 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs'
                                          2024-08-07 23:31:10.311 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                          2024-08-07 23:31:10.311 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                          2024-08-07 23:31:10.311 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18)
                                          2024-08-07 23:31:10.311 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/sl.js:1:86
                                          2024-08-07 23:31:10.311 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/sl.js:1:243)
                                          2024-08-07 23:31:10.312 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                          2024-08-07 23:31:10.312 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                          2024-08-07 23:31:10.312 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                          2024-08-07 23:31:10.312 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                          2024-08-07 23:31:10.313 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs'
                                          2024-08-07 23:31:10.314 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                          2024-08-07 23:31:10.314 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                          2024-08-07 23:31:10.314 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18)
                                          2024-08-07 23:31:10.314 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/sv.js:1:86
                                          2024-08-07 23:31:10.314 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/sv.js:1:243)
                                          2024-08-07 23:31:10.314 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                          2024-08-07 23:31:10.314 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                          2024-08-07 23:31:10.314 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                          2024-08-07 23:31:10.314 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                          2024-08-07 23:31:10.316 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs'
                                          2024-08-07 23:31:10.316 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                          2024-08-07 23:31:10.316 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                          2024-08-07 23:31:10.316 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18)
                                          2024-08-07 23:31:10.316 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/th.js:1:86
                                          2024-08-07 23:31:10.316 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/th.js:1:243)
                                          2024-08-07 23:31:10.316 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                          2024-08-07 23:31:10.316 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                          2024-08-07 23:31:10.317 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                          2024-08-07 23:31:10.317 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                          2024-08-07 23:31:10.318 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs'
                                          2024-08-07 23:31:10.318 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                          2024-08-07 23:31:10.319 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                          2024-08-07 23:31:10.319 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18)
                                          2024-08-07 23:31:10.319 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/tr.js:1:86
                                          2024-08-07 23:31:10.319 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/tr.js:1:243)
                                          2024-08-07 23:31:10.319 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                          2024-08-07 23:31:10.319 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                          2024-08-07 23:31:10.319 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                          2024-08-07 23:31:10.319 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                          2024-08-07 23:31:10.321 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs'
                                          2024-08-07 23:31:10.321 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                          2024-08-07 23:31:10.321 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                          2024-08-07 23:31:10.321 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18)
                                          2024-08-07 23:31:10.321 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/uk.js:1:86
                                          2024-08-07 23:31:10.321 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/uk.js:1:243)
                                          2024-08-07 23:31:10.321 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                          2024-08-07 23:31:10.321 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                          2024-08-07 23:31:10.323 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                          2024-08-07 23:31:10.323 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                          2024-08-07 23:31:10.325 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs'
                                          2024-08-07 23:31:10.325 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                          2024-08-07 23:31:10.325 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                          2024-08-07 23:31:10.325 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18)
                                          2024-08-07 23:31:10.325 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/vi.js:1:86
                                          2024-08-07 23:31:10.325 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/vi.js:1:243)
                                          2024-08-07 23:31:10.325 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                          2024-08-07 23:31:10.334 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                          2024-08-07 23:31:10.334 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                          2024-08-07 23:31:10.334 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                          2024-08-07 23:31:10.335 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs'
                                          2024-08-07 23:31:10.336 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                          2024-08-07 23:31:10.336 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                          2024-08-07 23:31:10.336 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18)
                                          2024-08-07 23:31:10.336 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/zh-cn.js:1:86
                                          2024-08-07 23:31:10.337 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/zh-cn.js:1:246)
                                          2024-08-07 23:31:10.337 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                          2024-08-07 23:31:10.337 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                          2024-08-07 23:31:10.337 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                          2024-08-07 23:31:10.337 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                          2024-08-07 23:31:10.339 - error: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: Error: Cannot find module 'dayjs'
                                          2024-08-07 23:31:10.339 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:986:27)
                                          2024-08-07 23:31:10.339 - error: javascript.0 (398) at Module.require (node:internal/modules/cjs/loader:1233:19)
                                          2024-08-07 23:31:10.339 - error: javascript.0 (398) at require (node:internal/modules/helpers:179:18)
                                          2024-08-07 23:31:10.339 - error: javascript.0 (398) at /opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/zh-tw.js:1:86
                                          2024-08-07 23:31:10.339 - error: javascript.0 (398) at Object. (/opt/iobroker/node_modules/@iobroker-javascript.0/dayjs/locale/zh-tw.js:1:246)
                                          2024-08-07 23:31:10.339 - error: javascript.0 (398) at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                          2024-08-07 23:31:10.339 - error: javascript.0 (398) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                          2024-08-07 23:31:10.339 - error: javascript.0 (398) at Module.load (node:internal/modules/cjs/loader:1208:32)
                                          2024-08-07 23:31:10.339 - error: javascript.0 (398) at Function.Module._load (node:internal/modules/cjs/loader:1024:12)
                                          2024-08-07 23:31:10.339 - info: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: getDayjsLocale de
                                          2024-08-07 23:31:10.360 - info: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: setObjects enabled - create Alias Channels possible
                                          2024-08-07 23:31:10.368 - info: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: weather alias for accuweather.0. already exists
                                          2024-08-07 23:31:10.434 - info: javascript.0 (398) script.js.common.NSPanel.NSPanelTS_44: registered 32 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                                          Host: Fujitsu Intel(R) Pentium(R) CPU G4560T, 32 GB RAM, Proxmox 8.x + lxc Ubuntu 22.04
                                          ioBroker (8 GB RAM) Node.js: 20.19.1, NPM: 10.8.2, js-Controller: 7.0.6, Admin: 7.6.3
                                          Wetterstation: Froggit WH3000SE V1.6.6
                                          32.6k
                                          82.1k
