    1.7k
  • Weihnachtsangebot 2025! 🎄
    2.1k
lovelace uinspanelsonoff
  • R ronny130286
    Irgendwie ist momentan der Wurm drin, ich komme gerade nach Hause und höre wie das Panel permanent die Relay schaltet, zum glück hängt nichts dran nervt aber dennoch.
    Hatte das schon mal jemand?
    19:43:20.482 MQT: cmnd/NSPanel1/POWER =
    19:43:20.760 MQT: stat/NSPanel1/RESULT = {"POWER1":"OFF"}
    19:43:20.770 MQT: stat/NSPanel1/POWER1 = OFF
    19:43:20.809 MQT: stat/NSPanel1/RESULT = {"POWER1":"OFF"}
    19:43:20.815 MQT: stat/NSPanel1/POWER1 = OFF
    19:43:20.859 MQT: stat/NSPanel1/RESULT = {"POWER1":"OFF"}
    19:43:20.865 MQT: stat/NSPanel1/POWER1 = OFF
    19:43:20.935 MQT: stat/NSPanel1/RESULT = {"POWER1":"OFF"}
    19:43:20.939 MQT: stat/NSPanel1/POWER1 = OFF
    19:43:21.016 MQT: stat/NSPanel1/RESULT = {"CustomSend":"Done"}
    19:43:21.050 MQT: stat/NSPanel1/RESULT = {"POWER2":"ON"}
    19:43:21.056 MQT: stat/NSPanel1/POWER2 = ON
    19:43:21.101 MQT: stat/NSPanel1/RESULT = {"POWER1":"ON"}
    19:43:21.110 MQT: stat/NSPanel1/POWER1 = ON
    19:43:21.184 MQT: stat/NSPanel1/RESULT = {"CustomSend":"Done"}
    19:43:21.225 MQT: stat/NSPanel1/RESULT = {"POWER2":"ON"}
    19:43:21.233 MQT: stat/NSPanel1/POWER2 = ON
    19:43:21.274 MQT: stat/NSPanel1/RESULT = {"POWER1":"ON"}
    19:43:21.284 MQT: stat/NSPanel1/POWER1 = ON
    19:43:21.349 MQT: stat/NSPanel1/RESULT = {"CustomSend":"Done"}
    19:43:21.382 MQT: stat/NSPanel1/RESULT = {"POWER2":"ON"}
    19:43:21.393 MQT: stat/NSPanel1/POWER2 = ON
    19:43:21.429 MQT: stat/NSPanel1/RESULT = {"POWER1":"ON"}
    19:43:21.433 MQT: stat/NSPanel1/POWER1 = ON
    19:43:21.629 MQT: stat/NSPanel1/RESULT = {"POWER2":"OFF"}
    19:43:21.638 MQT: stat/NSPanel1/POWER2 = OFF
    19:43:21.730 MQT: stat/NSPanel1/RESULT = {"POWER1":"OFF"}
    19:43:21.738 MQT: stat/NSPanel1/POWER1 = OFF
    19:43:23.181 MQT: stat/NSPanel1/RESULT = {"POWER1":"OFF"}
    19:43:23.185 MQT: stat/NSPanel1/POWER1 = OFF
    19:43:23.267 MQT: stat/NSPanel1/RESULT = {"CustomSend":"Done"}
    19:43:23.293 MQT: stat/NSPanel1/RESULT = {"POWER2":"ON"}
    19:43:23.295 MQT: stat/NSPanel1/POWER2 = ON
    19:43:23.348 MQT: stat/NSPanel1/RESULT = {"POWER1":"ON"}
    19:43:23.356 MQT: stat/NSPanel1/POWER1 = ON
    19:43:23.595 MQT: stat/NSPanel1/RESULT = {"POWER1":"OFF"}
    19:43:23.599 MQT: stat/NSPanel1/POWER1 = OFF
    19:43:23.614 MQT: stat/NSPanel1/RESULT = {"POWER2":"OFF"}
    19:43:23.622 MQT: stat/NSPanel1/POWER2 = OFF
    ArmilarA Offline
    ArmilarA Offline
    Armilar
    Most Active Forum Testing
    #2181
    @ronny130286
    sieht aus wie ein Trigger-Loop. Neues Blockly oder JS geschrieben?
    R 1 Antwort Letzte Antwort
    • ArmilarA Armilar
      @ronny130286
      ronny130286
      schrieb am zuletzt editiert von ronny130286
      #2182
      @armilar
      ich hatte heute nur eins TS geschrieben zum Testen mit den Messages auf Screensaver und Popup.
      Mich wundert es nur wie er überhaupt im Tasmota schaltet, weil die Buttons sind genau an dem Panel entkoppelt und gehen auf andere MQTT Befehle.
      Ich habe mittlerweile meine Fritzbox im verdacht, die hatte letztens ne Update gemacht und danach ging erstmal das 2,4GHz Wlan nicht mehr, musst die Fritz box vom Strom nehmen und dann ging es wieder. Das würde auch das langsame reagieren des Panels erklären obwohl er bei der Verbindung zum Panel >65mbit anzeigt.
      • R ronny130286
        @armilar
        ArmilarA Offline
        ArmilarA Offline
        Armilar
        #2183
        @ronny130286 sagte in SONOFF NSPanel mit Lovelace UI:
        Ich würde jetzt mal ein Script (mit Relais-bezug) nach dem anderen ausschalten, um zu sehen, ob es von einem ScriptTrigger oder Scheduler kommt. Dieses unregelmäßige On/Off könnte auch bedeuten, dass in der MQTT-Leitung mehr Infos hängen, als verarbeitet werden können...
        Hatte ich auch schon (allerdings nicht mit Fritzboxen). Hat mir den letzten nerv geraubt. Dann Downgrade und alles war wieder top --> Definitiv einen Versuch wert.
        • ArmilarA Armilar
          ronny130286
          #2184
          @armilar
          sag mal seit wann gibt es diese Funktion?
          //Control Relays from DP's
          on({id: [].concat(String(NSPanel_Path) + 'Relay.1').concat(String(NSPanel_Path) + 'Relay.2'), change: "ne"}, async function (obj) {
              try {
                  let Button = obj.id.split('.');
                  require("request")((['http://',get_current_tasmota_ip_address(),'/cm?cmnd=Power',Button[Button.length - 1],' ',(obj.state ? obj.state.val : "")].join(''))).on("error", function (err) {console.error(err.message);});
              } catch (err) {
                  console.warn('error at Trigger Relay1/2: ' + err.message);
          Das dumme ist meine Relays waren mal mit PulseTime eingestellt => das liegt daran, dass ich eine SPS habe die auf Monobuttons reagiert. Scheinbar wird das genau hier getriggert. Was anderes schickt eigentlich keine Befehle direkt über MQTT an die Relays.
          Downgraden ist so ne Sache, da muss ich mal gucken ob es einen bestimmte Labor Version noch gibt zum runterladen, weil ich musste leider auf die Labor gehen da damals mit der Standart Version für die 7590AX das IPSec für VPN nicht ging.
          • R ronny130286
            @armilar
                try {
                } catch (err) {
            ArmilarA Offline
            ArmilarA Offline
            Armilar
            #2185
            @ronny130286
            Wollte ich eben schreiben...
            Hast du etwas auf diesen Datenpunkten?
            Irgendein Script?
            Die sind aber auch schon wochenlang drin...
            EDIT: Sagen wir es mal so (und es hilft dir nicht weiter), Aber irgendetwas ist anders seit gestern...
            • ArmilarA Armilar
              @mschmidt sagte in SONOFF NSPanel mit Lovelace UI:
              ich habe mich in den letzten Tagen durch das Wiki und die Installationsanleitung gekämpft und habe mein erstes NSPanel schon in Benutzung. Hat soweit alles ganz gut funktioniert ( Danke an alle die diese Anleitung unterstützt haben) Ich habe nun ein Punkt wo ich selbst keine Idee mehr habe. Es geht um die Implementierung der Seite des Abfallkalenders. Ich bekomme es nicht hin die Farbe der Icons entsprechend des Blocklys anzuzeigen. Alle Icons sind in schwarz dargestellt. So wie ich das verstehe werden in dem Blockly die Farben in Color Datenpunkt gesetzt. Dort stehen sie bei mir jedoch nicht.
              Hat jemand vielleicht einen Hinweis für mich woran das liegen kann?
              Danke!
              Die Farbwerte sind nicht gefüllt... Da sollten Zahlen zugewiesen sein... Irgendetwas stimmt da mit deinem Blockly noch nicht...
              Könntest du aber kurz mal posten
              mschmidt
              schrieb am zuletzt editiert von mschmidt
              #2186
              @armilar
              Ich habe das Blockly aus der Anleitung übernommen und an meine DP angepasst:
              In den color DP steht : {"ack":false}
              • ArmilarA Armilar
                @ronny130286
                Irgendein Script?
                ronny130286
                #2187
                @armilar
                Ja die Datenpunkte habe ich unter 0_Userdata.0 und auch im Alias hat er die angelegt. Vielleicht liegt es wieder an meiner Sonderlocke mit den MonoButtons.
                Weil er macht das Relay nur an im Tasmota und macht es nach 300ms wieder aus, d.h er ändert es ja 2x einmal auf ON und 300ms später wieder auf OFF
                EDIT:
                Ich habe die Pulsetime für beide Relay mal auf 0 genommen und jetzt hört es auch, zumindest bis jetzt :)
                Ich werde es wahrscheinlich im Script einfach ausschalten mit einem Parameter oder gibt es vielleicht ne schöne Lösung wo man das für einen Monobutten und eine Schalter nutzen kann?
                • M mschmidt
                  @armilar
                  ArmilarA Offline
                  ArmilarA Offline
                  Armilar
                  #2188
                  @mschmidt
                  Heißen die Events im ical denn auch so?
                  Mach mal einen Screenshot von den nächsten 4 Events aus dem ical-Adapter
                  EDIT:
                  Das {"ack":false} kommt daher, dass er in den Datenpunkten im Vergleich mit deinen Bezeichnern offensichtlich keine Übereinstimmung findet...
                  • R ronny130286
                    @armilar
                    EDIT:
                    ArmilarA Offline
                    ArmilarA Offline
                    Armilar
                    #2189
                    @ronny130286
                    Kannst ja mal den Trigger testweise auskommentieren. Wenn die Buttons von den Relays entkoppelt werden, benötigen die MonoButtons mit der SPS eventuell noch eine Sonderlocke...
                    Aber warum auf einmal nach Wochen oder Monaten?
                    • ArmilarA Armilar
                      @mschmidt
                      EDIT:
                      mschmidt
                      #2190
                      @armilar ,
                      Ja die heißen so:
                      [{"date":"Heute ","event":" Gelbe Säcke","_class":"ical_Müllabfuhr ical_today","_date":"2023-02-12T23:00:00.000Z","_end":"2023-02-13T23:00:00.000Z","_section":"","_IDID":"entsterm-d6a5b511255d8db31d9414359daab533@sbazv.de","_allDay":true,"_private":false,"_rule":" ","location":"15711 Königs Wusterhausen/Königs Wusterhausen - Zernsdorfer Str.","_calName":"Müllabfuhr","_calColor":"#000000","_object":{"type":"VEVENT","params":[],"start":"2023-02-12T23:00:00.000Z","datetype":"date","end":"2023-02-13T23:00:00.000Z","dtstamp":"2023-02-13T16:00:02.000Z","uid":"entsterm-d6a5b511255d8db31d9414359daab533@sbazv.de","created":"2022-12-28T16:35:34.000Z","description":"","lastmodified":"2022-12-28T15:37:34.000Z","location":"15711 Königs Wusterhausen/Königs Wusterhausen - Zernsdorfer Str.","sequence":"1","status":"CONFIRMED","summary":" Gelbe Säcke","transparency":"TRANSPARENT","method":"PUBLISH"}},{"date":"22.02.2023 ","event":" Papiertonnen","_class":"ical_Müllabfuhr ","_date":"2023-02-21T23:00:00.000Z","_end":"2023-02-22T23:00:00.000Z","_section":"","_IDID":"entsterm-881476c19401d1acca5357addba16630@sbazv.de","_allDay":true,"_private":false,"_rule":" ","location":"15711 Königs Wusterhausen/Königs Wusterhausen - Zernsdorfer Str.","_calName":"Müllabfuhr","_calColor":"#000000","_object":{"type":"VEVENT","params":[],"start":"2023-02-21T23:00:00.000Z","datetype":"date","end":"2023-02-22T23:00:00.000Z","dtstamp":"2023-02-13T16:00:02.000Z","uid":"entsterm-881476c19401d1acca5357addba16630@sbazv.de","created":"2022-12-28T16:35:34.000Z","description":"","lastmodified":"2022-12-28T15:37:34.000Z","location":"15711 Königs Wusterhausen/Königs Wusterhausen - Zernsdorfer Str.","sequence":"1","status":"CONFIRMED","summary":" Papiertonnen","transparency":"TRANSPARENT","method":"PUBLISH"}}
                      evetuell das Leerzeichen vor dem Namen??
                      • ArmilarA Armilar
                        @ronny130286
                        ronny130286
                        #2191
                        @armilar
                        Das ist eine Sehr gute Frage, ich weis das meine Frau das damals schon hinbekommen hat mit Version 3.7.0 glaube war das und da wusste ich nicht wo es herkam, weil es einmalig war, aber dort hat er genau das gleiche gemacht permanent das Licht an und aus => da war am Relay noch ein SPS Eingang dran.
                        Wenn du ein Test Pult hast kannst du ja mal Spaßeshalber in der Tasmota Konsole
                        Pulsetime1 3
                        Pulsetime2 3
                        eingeben und mal den DP auf True steuern, dann fängt er bei mir sofort an mit flakern, manchmal hört er auch manchmal nicht.
                        • M mschmidt
                          @armilar ,
                          Ja die heißen so:
                          ArmilarA Offline
                          ArmilarA Offline
                          Armilar
                          #2192
                          @mschmidt
                          Absolut korrekt. Das Leerzeichen muss mit ins Blockly. Hat sich wieder ein Gemeindeentwickler einen lustigen Spaß erlaubt. Auf der anderen Seite könntest du auch das Event trimmen und das Leerzeichen entfernen. Dann mit dem String vergleichen.
                          • R ronny130286
                            @armilar
                            Pulsetime1 3
                            Pulsetime2 3
                            ArmilarA Offline
                            ArmilarA Offline
                            Armilar
                            #2193
                            @ronny130286
                            Habe es mal ausprobiert. Die Relays schalten bei mir nur beim setzen der Pulsetime (1x) Dann ist ruhe. Habe aber auch nichts, was daraus eine Kettenreaktion macht...
                            Hier mein Log
                            20:38:35.466 CMD: Pulsetime1 3
                            20:38:35.474 MQT: SmartHome/NSPanel_1/stat/RESULT = {"PulseTime1":{"Set":3,"Remaining":3}}
                            20:38:35.885 MQT: SmartHome/NSPanel_1/stat/RESULT = {"POWER1":"OFF"}
                            20:38:35.891 MQT: SmartHome/NSPanel_1/stat/POWER1 = OFF
                            20:38:40.659 MQT: SmartHome/NSPanel_1/stat/RESULT = {"CustomSend":"Done"}
                            20:38:40.773 MQT: SmartHome/NSPanel_1/stat/RESULT = {"CustomSend":"Done"}
                            20:38:40.834 MQT: SmartHome/NSPanel_1/stat/RESULT = {"CustomSend":"Done"}
                            20:38:40.945 MQT: SmartHome/NSPanel_1/stat/RESULT = {"CustomSend":"Done"}
                            20:38:41.063 MQT: SmartHome/NSPanel_1/stat/RESULT = {"CustomSend":"Done"}
                            20:38:41.126 MQT: SmartHome/NSPanel_1/stat/RESULT = {"CustomSend":"Done"}
                            20:38:51.946 MQT: SmartHome/NSPanel_1/stat/RESULT = {"CustomSend":"Done"}
                            20:38:52.076 MQT: SmartHome/NSPanel_1/stat/RESULT = {"CustomSend":"Done"}
                            20:38:52.145 MQT: SmartHome/NSPanel_1/stat/RESULT = {"CustomSend":"Done"}
                            20:39:21.994 MQT: SmartHome/NSPanel_1/stat/RESULT = {"CustomSend":"Done"}
                            20:39:22.109 MQT: SmartHome/NSPanel_1/stat/RESULT = {"CustomSend":"Done"}
                            20:39:22.223 MQT: SmartHome/NSPanel_1/stat/RESULT = {"CustomSend":"Done"}
                            20:39:22.295 MQT: SmartHome/NSPanel_1/stat/RESULT = {"CustomSend":"Done"}
                            20:39:38.918 MQT: SmartHome/NSPanel_1/tele/STATE = {"Time":"2023-02-13T20:39:38","Uptime":"2T09:45:18","UptimeSec":207918,"Heap":132,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":20,"MqttCount":6,"Berry":{"HeapUsed":16,"Objects":236},"POWER1":"OFF","POWER2":"ON","Wifi":{"AP":1,"SSId":"Logint","BSSId":"62:10:C9:A8:CF:01","Channel":9,"Mode":"11n","RSSI":100,"Signal":-37,"LinkCount":1,"Downtime":"0T00:00:12"}}
                            20:39:38.939 MQT: SmartHome/NSPanel_1/tele/SENSOR = {"Time":"2023-02-13T20:39:38","ANALOG":{"Temperature1":22.4},"ESP32":{"Temperature":52.8},"TempUnit":"C"}
                            20:39:46.245 CMD: Pulsetime2 3
                            20:39:46.255 MQT: SmartHome/NSPanel_1/stat/RESULT = {"PulseTime2":{"Set":3,"Remaining":3}}
                            20:39:46.573 MQT: SmartHome/NSPanel_1/stat/RESULT = {"POWER2":"OFF"}
                            20:39:46.576 MQT: SmartHome/NSPanel_1/stat/POWER2 = OFF
                            20:39:51.860 MQT: SmartHome/NSPanel_1/stat/RESULT = {"CustomSend":"Done"}
                            20:39:51.972 MQT: SmartHome/NSPanel_1/stat/RESULT = {"CustomSend":"Done"}
                            20:39:52.047 MQT: SmartHome/NSPanel_1/stat/RESULT = {"CustomSend":"Done"}
                            20:40:22.294 MQT: SmartHome/NSPanel_1/stat/RESULT = {"CustomSend":"Done"}
                            20:40:22.409 MQT: SmartHome/NSPanel_1/stat/RESULT = {"CustomSend":"Done"}
                            20:40:22.521 MQT: SmartHome/NSPanel_1/stat/RESULT = {"CustomSend":"Done"}
                            20:40:22.585 MQT: SmartHome/NSPanel_1/stat/RESULT = {"CustomSend":"Done"}
                            20:40:51.862 MQT: SmartHome/NSPanel_1/stat/RESULT = {"CustomSend":"Done"}
                            20:40:51.981 MQT: SmartHome/NSPanel_1/stat/RESULT = {"CustomSend":"Done"}
                            20:40:52.056 MQT: SmartHome/NSPanel_1/stat/RESULT = {"CustomSend":"Done"}
                            20:41:16.948 MQT: SmartHome/NSPanel_1/stat/RESULT = {"CustomSend":"Done"}
                            20:41:17.072 MQT: SmartHome/NSPanel_1/stat/RESULT = {"CustomSend":"Done"}
                            20:41:17.139 MQT: SmartHome/NSPanel_1/stat/RESULT = {"CustomSend":"Done"}
                            20:41:21.996 MQT: SmartHome/NSPanel_1/stat/RESULT = {"CustomSend":"Done"}
                            20:41:22.108 MQT: SmartHome/NSPanel_1/stat/RESULT = {"CustomSend":"Done"}
                            20:41:22.219 MQT: SmartHome/NSPanel_1/stat/RESULT = {"CustomSend":"Done"}
                            20:41:22.293 MQT: SmartHome/NSPanel_1/stat/RESULT = {"CustomSend":"Done"}
                            20:41:51.839 MQT: SmartHome/NSPanel_1/stat/RESULT = {"CustomSend":"Done"}
                            20:41:51.946 MQT: SmartHome/NSPanel_1/stat/RESULT = {"CustomSend":"Done"}
                            20:41:52.026 MQT: SmartHome/NSPanel_1/stat/RESULT = {"CustomSend":"Done"}
                            20:42:21.803 MQT: SmartHome/NSPanel_1/stat/RESULT = {"CustomSend":"Done"}
                            20:42:21.968 MQT: SmartHome/NSPanel_1/stat/RESULT = {"CustomSend":"Done"}
                            20:42:22.085 MQT: SmartHome/NSPanel_1/stat/RESULT = {"CustomSend":"Done"}
                            20:42:22.148 MQT: SmartHome/NSPanel_1/stat/RESULT = {"CustomSend":"Done"}
                            Okay, habe auch noch auf true gesteuert.
                            20:50:13.386 CMD: Pulsetime1 3
                            20:50:13.396 MQT: SmartHome/NSPanel_1/stat/RESULT = {"PulseTime1":{"Set":3,"Remaining":3}}
                            20:50:13.718 MQT: SmartHome/NSPanel_1/stat/RESULT = {"POWER1":"OFF"}
                            20:50:13.724 MQT: SmartHome/NSPanel_1/stat/POWER1 = OFF
                            20:50:22.562 MQT: SmartHome/NSPanel_1/stat/RESULT = {"CustomSend":"Done"}
                            20:50:27.937 MQT: SmartHome/NSPanel_1/stat/RESULT = {"CustomSend":"Done"}
                            20:50:28.082 MQT: SmartHome/NSPanel_1/stat/RESULT = {"CustomSend":"Done"}
                            20:50:28.146 MQT: SmartHome/NSPanel_1/stat/RESULT = {"CustomSend":"Done"}
                            20:50:52.123 MQT: SmartHome/NSPanel_1/stat/RESULT = {"CustomSend":"Done"}
                            20:50:52.233 MQT: SmartHome/NSPanel_1/stat/RESULT = {"CustomSend":"Done"}
                            20:50:52.309 MQT: SmartHome/NSPanel_1/stat/RESULT = {"CustomSend":"Done"}
                            20:50:55.322 MQT: SmartHome/NSPanel_1/stat/RESULT = {"POWER1":"OFF"}
                            20:50:55.325 MQT: SmartHome/NSPanel_1/stat/POWER1 = OFF
                            20:51:14.664 MQT: SmartHome/NSPanel_1/stat/RESULT = {"POWER1":"ON"}
                            20:51:14.669 MQT: SmartHome/NSPanel_1/stat/POWER1 = ON
                            20:51:14.983 MQT: SmartHome/NSPanel_1/stat/RESULT = {"POWER1":"OFF"}
                            20:51:14.986 MQT: SmartHome/NSPanel_1/stat/POWER1 = OFF
                            20:51:21.961 MQT: SmartHome/NSPanel_1/stat/RESULT = {"CustomSend":"Done"}
                            20:51:22.074 MQT: SmartHome/NSPanel_1/stat/RESULT = {"CustomSend":"Done"}
                            20:51:22.187 MQT: SmartHome/NSPanel_1/stat/RESULT = {"CustomSend":"Done"}
                            20:51:22.259 MQT: SmartHome/NSPanel_1/stat/RESULT = {"CustomSend":"Done"}
                            20:51:25.708 MQT: SmartHome/NSPanel_1/stat/RESULT = {"CustomSend":"Done"}
                            20:51:25.821 MQT: SmartHome/NSPanel_1/stat/RESULT = {"CustomSend":"Done"}
                            20:51:25.894 MQT: SmartHome/NSPanel_1/stat/RESULT = {"CustomSend":"Done"}
                            Einmaliges flackern. Danach aber Ruhe
                            • ArmilarA Armilar
                              @ronny130286
                              Hier mein Log
                              ronny130286
                              #2194
                              @armilar
                              Vielleicht kommt das durch mein Wlan zu standen, der er die Verbindung abbricht und wieder bekommt.
                              Aber pulst er überhaupt? normal muss einmal on und dann wieder off kommen
                              Du musst dann einmal im tasmota schalten auf der Hauptseite
                              Sieht dann bei mir so aus
                              20:59:07.425 CMD: PulseTime2 3
                              20:59:07.432 MQT: stat/NSPanel1/RESULT = {"PulseTime2":{"Set":3,"Remaining":3}}
                              20:59:07.746 MQT: stat/NSPanel1/RESULT = {"POWER2":"OFF"}
                              20:59:07.754 MQT: stat/NSPanel1/POWER2 = OFF
                              20:59:23.198 MQT: stat/NSPanel1/RESULT = {"POWER2":"ON"}
                              20:59:23.206 MQT: stat/NSPanel1/POWER2 = ON
                              20:59:23.528 MQT: stat/NSPanel1/RESULT = {"POWER2":"OFF"}
                              20:59:23.533 MQT: stat/NSPanel1/POWER2 = OFF
                              20:59:26.132 MQT: stat/NSPanel1/RESULT = {"POWER2":"ON"}
                              20:59:26.139 MQT: stat/NSPanel1/POWER2 = ON
                              20:59:26.515 MQT: stat/NSPanel1/RESULT = {"POWER2":"OFF"}
                              20:59:26.520 MQT: stat/NSPanel1/POWER2 = OFF
                              Das ON OFF nacheinander wäre für einem Monobutton normal
                              • R ronny130286
                                @armilar
                                ArmilarA Offline
                                ArmilarA Offline
                                Armilar
                                #2195
                                @ronny130286
                                Ja der hat gepulst. Hab's mal über die Konsole geschaltet.
                                Relais an, Relays sofort wieder aus. Anzeige im Tasmota aber ca. 2-3 Sekunden später erst auf Aus
                                21:01:23.846 CMD: pulsetime1 3
                                21:01:23.854 MQT: SmartHome/NSPanel_1/stat/RESULT = {"PulseTime1":{"Set":3,"Remaining":3}}
                                21:01:24.180 MQT: SmartHome/NSPanel_1/stat/RESULT = {"POWER1":"OFF"}
                                21:01:24.185 MQT: SmartHome/NSPanel_1/stat/POWER1 = OFF
                                21:01:33.052 MQT: SmartHome/NSPanel_1/stat/RESULT = {"POWER1":"ON"}
                                21:01:33.057 MQT: SmartHome/NSPanel_1/stat/POWER1 = ON
                                21:01:33.426 MQT: SmartHome/NSPanel_1/stat/RESULT = {"POWER1":"OFF"}
                                21:01:33.432 MQT: SmartHome/NSPanel_1/stat/POWER1 = OFF
                                21:01:41.964 MQT: SmartHome/NSPanel_1/stat/RESULT = {"POWER1":"ON"}
                                21:01:41.975 MQT: SmartHome/NSPanel_1/stat/POWER1 = ON
                                21:01:42.347 MQT: SmartHome/NSPanel_1/stat/RESULT = {"POWER1":"OFF"}
                                21:01:42.350 MQT: SmartHome/NSPanel_1/stat/POWER1 = OFF
                                21:01:51.858 MQT: SmartHome/NSPanel_1/stat/RESULT = {"CustomSend":"Done"}
                                21:01:51.975 MQT: SmartHome/NSPanel_1/stat/RESULT = {"CustomSend":"Done"}
                                21:01:52.082 MQT: SmartHome/NSPanel_1/stat/RESULT = {"CustomSend":"Done"}
                                21:01:52.715 MQT: SmartHome/NSPanel_1/stat/RESULT = {"POWER1":"ON"}
                                21:01:52.722 MQT: SmartHome/NSPanel_1/stat/POWER1 = ON
                                21:01:53.052 MQT: SmartHome/NSPanel_1/stat/RESULT = {"POWER1":"OFF"}
                                21:01:53.058 MQT: SmartHome/NSPanel_1/stat/POWER1 = OFF
                                21:01:59.648 MQT: SmartHome/NSPanel_1/stat/RESULT = {"CustomSend":"Done"}
                                21:01:59.752 MQT: SmartHome/NSPanel_1/stat/RESULT = {"CustomSend":"Done"}
                                21:01:59.819 MQT: SmartHome/NSPanel_1/stat/RESULT = {"CustomSend":"Done"}
                                21:02:21.895 MQT: SmartHome/NSPanel_1/stat/RESULT = {"CustomSend":"Done"}
                                21:02:22.014 MQT: SmartHome/NSPanel_1/stat/RESULT = {"CustomSend":"Done"}
                                21:02:22.120 MQT: SmartHome/NSPanel_1/stat/RESULT = {"CustomSend":"Done"}
                                21:02:22.189 MQT: SmartHome/NSPanel_1/stat/RESULT = {"CustomSend":"Done"}
                                • ArmilarA Armilar
                                  @mschmidt
                                  mschmidt
                                  #2196
                                  @armilar
                                  Immer wieder verblüffend!
                                  Danke für den Hinweis, habe jetzt einfach das Leerzeichen vor dem Eventnamen gesetzt und die Farben werden korrekt in die DP geschrieben und auf dem NSPanel angezeigt!
                                  • ArmilarA Armilar
                                    @ronny130286
                                    ronny130286
                                    #2197
                                    @armilar
                                    Und jetzt schalt es mal über den DP.
                                    • R ronny130286
                                      @armilar
                                      ArmilarA Offline
                                      ArmilarA Offline
                                      Armilar
                                      #2198
                                      @ronny130286
                                      Bekommt den false nicht mit. Muss ich immer manuell zurücksetzen. Obwohl das Relay true/false macht
                                      Kann die aber auch nicht sagen, ob ich dafür den switchmode benötige, was ich vermute...
                                      • ArmilarA Armilar
                                        @ronny130286
                                        ronny130286
                                        #2199
                                        @armilar
                                        Ich werde mal die Funktion ausschalten, so das er die DP aus dem Script nicht mehr überwacht und triggert.
                                        Wenn es damit weg ist weiß ich zumindest wieso es passiert. Hatte jetzt das Script mal gestoppt und die Technoleucht hört direkt auf :D
                                        Das wird bestimmt wieder ne Sonderlock sein.
                                        • M mschmidt
                                          @armilar
                                          ArmilarA Offline
                                          ArmilarA Offline
                                          Armilar
                                          #2200
                                          @mschmidt
                                          So geht es natürlich auch, da der Vergleich dann auch wieder stimmt...
                                          32.6k
                                          82.1k
