  4. Geofency auf Karte in Vis darstellen
698 Beiträge 3 Kommentatoren 105.8k Aufrufe 3 Beobachtet
  • mickymM mickym
    @damrak2022 Also wenn Du die Inject Node drückst tut sich nichts? - ggf. Browserrefresh - mach mal ein debug-node hinter die letzte ChangeNode und überprüfe im Debug-Fenster ob überall Nachrichten rauskommen.
    Damrak2022D Offline
    Damrak2022D Offline
    Damrak2022
    schrieb am zuletzt editiert von Damrak2022
    #141
    @mickym
    28.8.2022, 22:31:17node: a965b646ec42d746
    geofency.0.andy.My_Home.currentLatitude : msg.payload : Object
    { name: "My Home", lat: "50.091591", lon: "8.673334", color: "orange", weight: 10 … }
    geofency.0.andy.Airport__Tor_31.currentLatitude : msg.payload : Object
    { lat: "50.023373", lon: "8.557803", color: "orange", weight: 10, icon: "circle" … }
    geofency.0.andy.Anne_&_Reiner.currentLatitude : msg.payload : Object
    { lat: "53.838940", lon: "10.684527", color: "orange", weight: 10, icon: "circle" … }
    geofency.0.andy.Auto_Algarve.currentLatitude : msg.payload : Object
    { lat: "50.104462", lon: "8.717999", color: "orange", weight: 10, icon: "circle" … }
    geofency.0.andy.Autostadt_Wolfsburg.currentLatitude : msg.payload : Object
    { lat: "52.433132", lon: "10.800891", color: "orange", weight: 10, icon: "circle" … }
    geofency.0.andy.Dr__Heddäus_.currentLatitude : msg.payload : Object
    { lat: "50.128700", lon: "8.705841", color: "orange", weight: 10, icon: "circle" … }
    geofency.0.andy.Marina.currentLatitude : msg.payload : Object
    { lat: "53.876701", lon: "10.671894", color: "orange", weight: 10, icon: "circle" … }
    geofency.0.andy.Penny_Mörfelden_Walldorf.currentLatitude : msg.payload : Object
    { lat: "50.011295", lon: "8.584640", color: "orange", weight: 10, icon: "circle" … }
    geofency.0.andy.Selgros_.currentLatitude : msg.payload : Object
    { lat: "50.048470", lon: "8.710313", color: "orange", weight: 10, icon: "circle" … }
    geofency.0.andy.Waltraud_&_Heiner.currentLatitude : msg.payload : Object
    { lat: "49.895184", lon: "8.846977", color: "orange", weight: 10, icon: "circle" … }
    Mit besten Grüßen
    Andy
    • Damrak2022D Damrak2022
      @mickym
      mickymM Offline
      mickymM Offline
      mickym
      #142
      @damrak2022 Sehe ich schon auf den ersten Blick - fehl überall der name.
      Also alle get Nodes, die den Namen holen schauen - und ob als Attribute auch überall name und nicht payload drin steht. ;)
      Ich habs mal mit change nodes simuliert und das muss gehen:
      • mickymM mickym
        Damrak2022D Offline
        Damrak2022D Offline
        Damrak2022
        #143
        @mickym Okay ich schaue nach
        Mit besten Grüßen
        Andy
          mickymM Offline
          mickymM Offline
          mickym
          #144
          @damrak2022 Nein - die ganzen IObroker Get Nodes - wo Du den Namen holst.
          • mickymM mickym
            Damrak2022D Offline
            Damrak2022D Offline
            Damrak2022
            #145
            @mickym Geht
            Mit besten Grüßen
            Andy
              @mickym Geht
              mickymM Offline
              mickymM Offline
              mickym
              #146
              @damrak2022 Kaum macht man es richtig. 😁 Aber so lernst Du gleich wie man mit NodeRed auf die Fehlersuche geht. ;)
              Du kannst auch auf Deiner VIS Seite eine eigene Tabelle erstellen und dort dann die Daten eintragen - dann bist Du nicht so beschränkt auf das Popup. Die VIS Seite muss ja nicht die ganze Karte beinhalten, sondern kann ja auch Steuerungselemente und eine eigene Tabelle aufweisen.
              Ich zeige Dir mal - wie Du ein Blockly triggern kannst, wenn Du einen bestimmten Punkt klickst. Mach Dir mal diesbezüglich einen eigenen Datenpunkt unter 0_userdata.0
              Damrak2022D 2 Antworten Letzte Antwort
              • mickymM mickym
                Damrak2022D Offline
                Damrak2022D Offline
                Damrak2022
                #147
                @mickym Du sagst es. Anscheinend schwächelt mein Rechner gerade, denn wann immer ich auf die Verlaufsdaten vom geloggten Datenpunkt Last Enter gehe sehe ich nur den Ladebalken, welcher permanent hin und herläuft. Bei Chrome und Firefox das gleiche
                Mit besten Grüßen
                Andy
                • mickymM mickym
                  Damrak2022D Offline
                  Damrak2022D Offline
                  Damrak2022
                  #148
                  @mickym Habe ich als Datenpunkt - Number erstellt
                  Mit besten Grüßen
                  Andy
                    mickymM Offline
                    mickymM Offline
                    mickym
                    #149
                    @damrak2022 sagte in Geofency auf Karte in Vis darstellen:
                    Und gehts damit?
                    Wie gesagt mit dem Popup bist Du beschränkt - meinst Du nicht Du solltest auf Deiner VIS Seite eine eigene Tabelle mit Blockly füllen. Dann würde ich Dir zeigen, wie Du das Blockly triggern kannst?
                    • mickymM mickym
                      Und gehts damit?
                      Damrak2022D Offline
                      Damrak2022D Offline
                      Damrak2022
                      #150
                      @mickym Ja gerne, deswegen habe ich ja den Datenpunkt erstellt
                      Mit besten Grüßen
                      Andy
                        mickymM Offline
                        mickymM Offline
                        mickym
                        #151
                        @damrak2022 Ja dann muss Dir aber wieder ein fachkundiger Blockly Spezi helfen so eine Tabelle für VIS aufzubereiten.
                        Da bin ich dann raus. ;) - Hast Du schon einen Datenpunkt erstellt - um dann das Blockly zu triggern und kannst Du den Pfad dieses Datenpunktes dann hier posten?
                        • mickymM mickym
                          Damrak2022D Offline
                          Damrak2022D Offline
                          Damrak2022
                          #152
                          @mickym
                          Mit besten Grüßen
                          Andy
                            @mickym
                            mickymM Offline
                            mickymM Offline
                            mickym
                            #153
                            @damrak2022 Bitte den Pfad hier rein kopieren und als Zeichenkette definieren - du willst ja den Namen der Location dann von NodeRed übermittelt bekommen.
                            Diesen Pfad kopieren und hier rein kopieren:
                            0_userdata.0.Test.Ort.name
                            • mickymM mickym
                              Damrak2022D Offline
                              Damrak2022D Offline
                              Damrak2022
                              #154
                              @mickym Sorry, wo reinkopieren?
                              Mit besten Grüßen
                              Andy
                                mickymM Offline
                                mickymM Offline
                                mickym
                                #155
                                @damrak2022 In den Thread hier - damit ich Dir die Node fertig machen kann. ;)
                                • mickymM mickym
                                  Damrak2022D Offline
                                  Damrak2022D Offline
                                  Damrak2022
                                  #156
                                  @mickym Meinst Du so??
                                  0_userdata.0.Geofency
                                  Oder so
                                  geofency.0.andy.My_Home.name
                                  Stehe gerade völlig auf dem Schlauch
                                  Mit besten Grüßen
                                  Andy
                                  mickymM 2 Antworten Letzte Antwort
                                    Oder so
                                    mickymM Offline
                                    mickymM Offline
                                    mickym
                                    #157
                                    Der passt schon - also 0_userdata.0.Geofency - da kommt dann der Name rein - des Ortes den Du angeklickt hast. Also bitte diesen Punkt als Typ Zeichenkette definieren.
                                    Das kannst Du dann im Blockly triggern und dann Deine Daten abrufen und im VIS Deine Tabelle füllen - verstanden?
                                    Wenn Ja dann ziehe bitte eine "Worldmap in" Node in Deinen Flow.
                                    Damrak2022D 3 Antworten Letzte Antwort
                                    • mickymM mickym
                                      Damrak2022D Offline
                                      Damrak2022D Offline
                                      Damrak2022
                                      #158
                                      @mickym Den ersten Satz ja.
                                      Ich habe doch schon eine Worldmap im Flow, oder brauche ich eine zweite wegen dem Blockly?
                                      Mit besten Grüßen
                                      Andy
                                      • mickymM mickym
                                        Damrak2022D Offline
                                        Damrak2022D Offline
                                        Damrak2022
                                        #159
                                        @mickym Dann könnte ich doch auch gleich den Datenpunkt "name" nehmen, oder?
                                        Mit besten Grüßen
                                        Andy
                                          mickymM Offline
                                          mickymM Offline
                                          mickym
                                          #160
                                          @damrak2022 Du brauchst nicht die OUT sonder die IN Node - die brauchst als Input dafür was Du auf der Karte machst.
