  4. Installation ioBroker auf Cubietruck
    5.4k
176 Beiträge 19 Kommentatoren 51.6k Aufrufe
  • E Offline
    exv2
    #141
    @akamia:
    Probier mal der Reihenfolge nach - wie BlueFox geschrieben hat:
    npm install iobroker.js-controller –production
    npm install iobroker.admin --production
    Bei mir wird jetzt die 0.5.4 angezeigt. Die Logs gehen auch wieder.
    akamia `
    Danke akamie
    habe es jetzt mal so gemacht. Und bekomme dabei folgende Meldungen
    sudo npm install iobroker.js-controller –production
    npm WARN package.json daemonize2@0.4.2 No repository field.
    > ws@0.5.0 install /node_modules/iobroker.js-controller/node_modules/socket.io/node_modules/engine.io/node_modules/ws
    > (node-gyp rebuild 2> builderror.log) || (exit 0)
    npm WARN engine hawk@0.10.2: wanted: {"node":"0.8.x"} (current: {"node":"0.10.35","npm":"1.4.28"})
    npm WARN engine hoek@0.7.6: wanted: {"node":"0.8.x"} (current: {"node":"0.10.35","npm":"1.4.28"})
    npm WARN engine sntp@0.1.4: wanted: {"node":"0.8.x"} (current: {"node":"0.10.35","npm":"1.4.28"})
    npm WARN engine boom@0.3.8: wanted: {"node":"0.8.x"} (current: {"node":"0.10.35","npm":"1.4.28"})
    npm WARN engine cryptiles@0.1.3: wanted: {"node":"0.8.x"} (current: {"node":"0.10.35","npm":"1.4.28"})
    > ws@0.4.31 install /node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws
    > iobroker.js-controller@0.5.4 install /node_modules/iobroker.js-controller
    > node lib/setup.js setup first
    creating conf/iobroker.json
    fs.js:654
      return binding.mkdir(pathModule._makeLong(path),
    Error: EACCES, permission denied '/node_modules/iobroker.js-controller/lib/../../../iobroker-data/'
        at Object.fs.mkdirSync (fs.js:654:18)
        at mkpathSync (/node_modules/iobroker.js-controller/lib/setup.js:746:20)
        at setup (/node_modules/iobroker.js-controller/lib/setup.js:828:9)
        at Object. <anonymous>(/node_modules/iobroker.js-controller/lib/setup.js:236:13)
        at Module._compile (module.js:456:26)
        at Object.Module._extensions..js (module.js:474:10)
        at Module.load (module.js:356:32)
        at Function.Module._load (module.js:312:12)
        at Function.Module.runMain (module.js:497:10)
        at startup (node.js:119:16)
    npm ERR! iobroker.js-controller@0.5.4 install: `node lib/setup.js setup first`
    npm ERR! Exit status 8
    npm ERR!
    npm ERR! Failed at the iobroker.js-controller@0.5.4 install script.
    npm ERR! This is most likely a problem with the iobroker.js-controller package,
    npm ERR! not with npm itself.
    npm ERR! Tell the author that this fails on your system:
    npm ERR!     node lib/setup.js setup first
    npm ERR! You can get their info via:
    npm ERR!     npm owner ls iobroker.js-controller
    npm ERR! There is likely additional logging output above.
    npm ERR! System Linux 3.12.35+
    npm ERR! command "/usr/local/bin/node" "/usr/local/bin/npm" "install" "iobroker.js-controller" "--production"
    npm ERR! cwd /
    npm ERR! node -v v0.10.35
    npm ERR! npm -v 1.4.28
    npm ERR! code ELIFECYCLE
    npm ERR! not ok code 0</anonymous>
    sudo npm install iobroker.admin –production
    npm WARN deprecated object-keys@0.2.0: Please update to the latest object-keys
    > ws@0.4.31 install /node_modules/iobroker.admin/node_modules/socket.io/node_modules/engine.io/node_modules/ws
    make: Entering directory '/node_modules/iobroker.admin/node_modules/socket.io/node_modules/engine.io/node_modules/ws/build'
      CXX(target) Release/obj.target/bufferutil/src/bufferutil.o
      SOLINK_MODULE(target) Release/obj.target/bufferutil.node
      SOLINK_MODULE(target) Release/obj.target/bufferutil.node: Finished
      COPY Release/bufferutil.node
      CXX(target) Release/obj.target/validation/src/validation.o
      SOLINK_MODULE(target) Release/obj.target/validation.node
      SOLINK_MODULE(target) Release/obj.target/validation.node: Finished
      COPY Release/validation.node
    make: Leaving directory '/node_modules/iobroker.admin/node_modules/socket.io/node_modules/engine.io/node_modules/ws/build'
    > ws@0.4.31 install /node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws
    make: Entering directory '/node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/build'
    make: Leaving directory '/node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/build'
    iobroker.admin@0.3.14 node_modules/iobroker.admin
    +-- connect-flash@0.1.1
    +-- cookie-parser@1.3.3 (cookie@0.1.2, cookie-signature@1.0.5)
    +-- passport-local@1.0.0 (passport-strategy@1.0.0)
    +-- passport@0.2.1 (pause@0.0.1, passport-strategy@1.0.0)
    +-- xtend@2.0.6 (is-object@0.1.2, object-keys@0.2.0)
    +-- express-session@1.7.6 (utils-merge@1.0.0, cookie@0.1.2, cookie-signature@1.0.4, on-headers@1.0.0, parseurl@1.3.0, buffer-crc32@0.2.3, depd@0.4.4, debug@1.0.4, uid-safe@1.0.1)
    +-- body-parser@1.5.2 (qs@0.6.6, media-typer@0.2.0, bytes@1.0.0, raw-body@1.3.0, depd@0.4.4, type-is@1.3.2, iconv-lite@0.4.4)
    +-- express@4.4.5 (parseurl@1.0.1, utils-merge@1.0.0, merge-descriptors@0.0.2, cookie@0.1.2, escape-html@1.0.1, cookie-signature@1.0.4, range-parser@1.0.0, fresh@0.2.2, vary@0.1.0, qs@0.6.6, methods@1.0.1, serve-static@1.2.3, buffer-crc32@0.2.3, path-to-regexp@0.1.2, debug@1.0.2, proxy-addr@1.0.1, send@0.4.3, type-is@1.2.1, accepts@1.0.7)
    +-- request@2.38.0 (json-stringify-safe@5.0.0, aws-sign2@0.5.0, forever-agent@0.5.2, qs@0.6.6, oauth-sign@0.3.0, stringstream@0.0.4, tunnel-agent@0.4.0, node-uuid@1.4.2, mime-types@1.0.2, form-data@0.1.4, http-signature@0.10.1, tough-cookie@0.12.1, hawk@1.1.1)
    +-- socket.io@1.0.6 (debug@0.7.4, has-binary-data@0.1.1, socket.io-parser@2.2.0, socket.io-adapter@0.2.0, engine.io@1.3.1, socket.io-client@1.0.6)
    Der Adminbereich läst sich danach aufrufen aber unter Hosts werden keine Versionsnummern mehr angezeigt.
    Auch unter Apapters ist alles leer.
    Jemand eine Idee.
    Vielen Dank Nobse
      #142
      Ich hatte auch einige Probleme. Zumal ich gerade eine multihost-installation teste. Gestern hat es dann doch wieder geklappt.
      Ich habe einfach immer wieder diese beiden befehle probiert. Es gab ja immer wieder updates zwischendrin.
      Und zwischendurch auch mal einen reboot des cubie gemacht.
      Gesendet von meinem Cynus T7 mit Tapatalk
      • BluefoxB Offline
        BluefoxB Offline
        #143
        @exv2:
        <code>npm WARN package.json daemonize2@0.4.2 No repository field.
        Vielen Dank Nobse
        Du solltest natürlich die beide Befehle immer in einem Verzeichnis ausführen, wo ioBroker steht. z.B. /opt/iobroker
        Es sieht so aus, als ob du in root Verzeichnis das ausgeführt hast.</code>
        • E Offline
          exv2
          #144
          Hallo
          • habe jetzt die 0.4.2 neu installiert
          • nach installation läuft alles
          • im Adminbereich Update auf 0.5.4 ausgeführt
          • Adminbereich läst sich nicht mehr aufrufen
          • also Installation von Hand aufgerufen aus dem Verzeichnis opt/iobroker
          • folgende Meldungen kommen beim Update
          pi@raspberrypi /opt/iobroker $ sudo npm install iobroker.js-controller --production
          npm WARN install Refusing to install iobroker.js-controller as a dependency of itself
          pi@raspberrypi /opt/iobroker $ sudo npm install iobroker.admin --production
          npm ERR! cb() never called!
          Habe ich nun wieder was falsch gemacht?
          Gruß Norbert und allen einen schönen Abend
            #145
            Setzte doch den cubie neu auf.
            Dann:
            mkdir /opt/iobroker
            cd /opt/iobroker
            Die Pfade haben sich mittlerweile geändert.
            • E Offline
              exv2
              #146
              Danke für die gedult.
              Aber auch das geht nicht. Die installation bricht sofort ab.
              Failed at the iobroker@0.2.2 install script.
              This is most likely a problem with the iobroker package,
              Da ich mit Linux nichts am Hut habe gebe ich an dieser Stelle auf. Muss ich mir wohl eine andere Visualisierung suchen.
              Wünsche euch ein schönes WE
                #147
                Nur falls du es nicht weißt:
                IoBroker ist noch lange nicht fertig. es befindet sich noch nicht einmal im beta Stadium.
                Also: aufgeben gilt nicht [emoji2]
                Hast du node.js installiert?
                Hast du auf Bluefox gehört und die Installation aus /opt/iobroker gestartet?
                EDIT:
                Bin davon ausgegangen dass du auf einem cubietruck installierst - das ist der cubie thread.
                Anscheinend willst du als user pi auf dem raspberry installieren. Das geht nicht!
                Du musst root sein!
                • BluefoxB Offline
                  BluefoxB Offline
                  #148
                  habe heute Raspbery PI 2 B bestellt: 4x900Mhz, 1 GB Ram. Ansonsten alte gute Raspbery PI B+ Platine.
                    #149
                    @Bluefox:
                    habe heute Raspbery PI 2 B bestellt: 4x900Mhz, 1 GB Ram. Ansonsten alte gute Raspbery PI B+ Platine. `
                    Wo?
                    Und wie bist du mit dem odroid zufrieden
                    Emmc oder SD-card
                    • BluefoxB Offline
                      BluefoxB Offline
                      #150
                      @Homoran:
                      @Bluefox:
                      Wo?
                      Emmc oder SD-card
                      Gesendet von meinem Cynus T7 mit Tapatalk `
                      http://www.reichelt.de/RASPBERRY-PI-2-B … rry+pi+2+b
                      Bin mit odroid sehr zufrieden. Aber ich will ioBroker auf rPI2 ausprobieren.
                        starfish
                        #151
                        @Bluefox:
                        Bin mit odroid sehr zufrieden. Aber ich will ioBroker auf rPI2 ausprobieren. `
                        welcher Typ Odroid? und welche Linux-Version (distr.) verwendest Du? Ich habe vor ein paar Tagen selbst Odroid C1 bestellt.
                        Gruss
                        starfish
                        • BluefoxB Offline
                          BluefoxB Offline
                          #152
                          @starfish:
                          @Bluefox:
                          Gruss
                          starfish `
                          Ich habe vor einem Jahr aus Süd-Korea ODROID-U3 mit 8Gb eMMC bestellt und Ubuntu installiert (http://forum.odroid.com/viewtopic.php?f=29&t=5234)
                          Damals ältere. Ubuntu GUI habe ich irgendwie deaktiviert.
                            Sprite01
                            #153
                            Erste Versuche mit ioBroker auf meinem Cubietruck mit HDD.
                            Nach 2 vergeblichen Anläufen ioBroker über npm install iobroker hatte ich nun mittels
                            wget http://download.iobroker.org/ioBroker-0.4.2.deb einen Teilerfolg.
                            Beim npm-Paket blieb irgendwann nach ein paar Minuten (habe über eine halbe Stunde gewartet) der Cubie hängen.
                            Es standen dann (für mich nicht zu deutende) Zeilen auf dem Bildschirm, welche meiner Meinung nach allerdings nichts mit ioBroker zu tun hatten.
                            Die Zeilen habe ich leider nicht mehr zur Verfügung.
                            Bei der Installation über das Debian-Paket ist zumindest die Seite IP:8081 aufrufbar.
                            Gemäß Anleitung die Lizenzbedingungen akzeptiert und HOSTS war grün.
                            Das Update lief dann durch.
                            Nun soll ich ja den hm-rega-Adapter installieren, dies funktioniert jedoch nicht und ein Fehlerlog erscheint.
                            > iobroker 2015-03-28 16:10:18 info error by reading iobroker.example: Error: Cannot find module 'npm'
                            Da ich Beginner bin, komme ich nun erst mal nicht weiter und hoffe auf Unterstützung durch euch.
                            137_log_dewe1.txt
                            Dirk
                            http://www.DessauWetter.de
                            (ioBroker auf IntelNuc und Proxmox)
                              #154
                              Hallo Sprite,
                              ob das .deb-Paket noch funktioniert, weiß ich nicht. Es gab zwischendrin eine komplette Änderung. Bluefox ist leider gerade jetzt zwei Wochen nicht da.
                              Die npm installation läuft mittlerweile –silent. Es wird also sehr lange Zeit nichts angezeigt. Aber 1/2 Stunde wäre schon sehr lange.
                              Die Fehlermeldung beim Versuch rega zu installieren deutet auf das gleiche Problem wie zu Beginn hin.
                              Es gibt hier einen weiteten Thread bei dem es im Moment mit npm nicht klappt. Kann aber auch an verschiedenen Ursachen liegen, die sich ausgerechnet bei dir zu einem größeren Problem kumulierten.
                              • dem abgebrochenen ersten Versuch
                              • dem wahrscheinlich veralteten Paket.
                              Ich nehme an, du gehst nach dem aktuellen Manual im wiki vor.
                              Für mich wäre jetzt der sinnvollste weg:
                              Neue SD Karte mit Igors image. Einstecken und cubie hochfahren.
                              Mit putty als root einloggen.
                              Die Datei /root/hdinstall.sh ausführbar machen mit chmod +x hdinstall.sh
                              Es soll in neueren images nur noch eine datei für nand und HDD geben. Dann diese entsprechend ausführbar machen
                              Anschließend reboot
                              Dann nodejs gemäß Anleitung installieren
                              Zum Schluss Ordner /opt/iobroker anlegen, da hinein wechseln und npm install iobroker ausführen
                                Sprite01
                                #155
                                Kurz gesagt: Platt machen und noch einmal die npm Installation versuchen. :)
                                Dirk
                                  #156
                                  So brutal wollte ich es nicht ausdrücken.
                                  Hier ist es ähnlich auf einem bananapi
                                  http://forum.iobroker.org/viewtopic.php?p=3920#p3920
                                  Vielleicht ist dich im Moment irgendwo der Wurm drin
                                    akamia
                                    #157
                                    Neuaufsetzen ist anscheinend zur Zeit nicht möglich.
                                    host.cubie _design/system missing - call node iobroker.js setup
                                    Bei mir startet das Webinterface nicht
                                    NUC6i3 / ProxMox / HM/FHEM/WifiLight/HUE/Tradfri/KM200/InfluxDB/RFlink/Plex/Smartmeter
                                    piVCCU, Arduinos, X4000, Z2000, Solo4K, SAMSUNG C & H, NAS OMV4/Win10Pro (JRMC/JRemote), 4x4 HDMImatrix, ...
                                      #158
                                      Damit sind es drei.
                                      Hat einer von euch mal ein npm install iobroker.js-controller –production versucht?
                                        akamia
                                        #159
                                        Hallo Homoran,
                                        Dir erst einmal gute Besserung.
                                        Bei mir bleibt die Fehlermeldung.
                                        `2015-03-28 19:44:25.852  - [31merror[39m: host.cubie _design/system missing - call node iobroker.js setup[/code]`
                                        LÄuft sauber außer einigen unwichtigen Warnings:
                                        `~~[code]~~npm WARN engine hawk@0.10.2: wanted: {"node":"0.8.x"} (current: {"node":"v0.10.22","npm":"1.3.14"})[/code]`
                                        akamia
                                          Sprite01
                                          #160
                                          Ich bin dann erst mal raus.
                                          Denke, mir fehlt zu viel um überhaupt wichtige Fehler melden zu können.
                                          Wenn jemand eine lauffähige Variante zur Verfügung hat, mein CT ist wieder bereit.
                                          Inklusive nodejs alles wieder fertig eingerichtet.
                                          Dirk
