  4. Ecovacs Deebot Adapter: Informationen und Praxistipps
    1.5k
deebotecovacsecovacs-deebot adapterhow-tohowtostaubsaugerrobotervacuum
177 Beiträge 31 Kommentatoren 62.7k Aufrufe 32 Beobachtet
  • B broady
    @mrbungle64 Danke, das hat erstmal geklappt. Datenpunkte und Karten sind jetzt vorhanden. Bekomme allerdings im Log die folgenden Fehlermeldungen:
    ecovacs-deebot.0
    	2023-01-30 18:19:11.684	warn	Error message received: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'was compiled against a different Node.js version usingNODE_MODULE_VERSION 108. This version of Node.js requiresNODE_MODULE_VERSION 93. Please try re-compiling or re-installingthe module (for instance, using `npm rebuild` or `npm install`).
    ecovacs-deebot.0
    	2023-01-30 18:19:11.670	warn	Error message received: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'was compiled against a different Node.js version usingNODE_MODULE_VERSION 108. This version of Node.js requiresNODE_MODULE_VERSION 93. Please try re-compiling or re-installingthe module (for instance, using `npm rebuild` or `npm install`).
    ecovacs-deebot.0
    	2023-01-30 18:19:11.658	warn	Error message received: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'was compiled against a different Node.js version usingNODE_MODULE_VERSION 108. This version of Node.js requiresNODE_MODULE_VERSION 93. Please try re-compiling or re-installingthe module (for instance, using `npm rebuild` or `npm install`).
    ecovacs-deebot.0
    	2023-01-30 18:19:11.626	warn	Error message received: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'was compiled against a different Node.js version usingNODE_MODULE_VERSION 108. This version of Node.js requiresNODE_MODULE_VERSION 93. Please try re-compiling or re-installingthe module (for instance, using `npm rebuild` or `npm install`).
    ecovacs-deebot.0
    	2023-01-30 18:18:17.596	warn	Error message received: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'was compiled against a different Node.js version usingNODE_MODULE_VERSION 108. This version of Node.js requiresNODE_MODULE_VERSION 93. Please try re-compiling or re-installingthe module (for instance, using `npm rebuild` or `npm install`).
    ecovacs-deebot.0
    	2023-01-30 18:18:17.579	warn	Error message received: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'was compiled against a different Node.js version usingNODE_MODULE_VERSION 108. This version of Node.js requiresNODE_MODULE_VERSION 93. Please try re-compiling or re-installingthe module (for instance, using `npm rebuild` or `npm install`).
    ecovacs-deebot.0
    	2023-01-30 18:18:17.572	warn	Error message received: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'was compiled against a different Node.js version usingNODE_MODULE_VERSION 108. This version of Node.js requiresNODE_MODULE_VERSION 93. Please try re-compiling or re-installingthe module (for instance, using `npm rebuild` or `npm install`).
    ecovacs-deebot.0
    	2023-01-30 18:18:17.563	warn	Error message received: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'was compiled against a different Node.js version usingNODE_MODULE_VERSION 108. This version of Node.js requiresNODE_MODULE_VERSION 93. Please try re-compiling or re-installingthe module (for instance, using `npm rebuild` or `npm install`).
    mrbungle64M
    mrbungle64M
    mrbungle64
    @broady sagte in Ecovacs Deebot Adapter: Informationen und Praxistipps:
    https://github.com/mrbungle64/ioBroker.ecovacs-deebot/wiki/FAQ#nodejs-upgrade
    B 1 Antwort Letzte Antwort
    • mrbungle64M mrbungle64
      B
      B
      broady
      @mrbungle64 Danke, das hat geklappt.
        @mrbungle64 Das Modell ist der DEEBOT OZMO 905. In "info.deviceClass" steht "2pv572".
        Für das Modell hatte aus irgendwelchen Gründen die Konfig gefehlt. Ich habe die nun eingefügt.
        Wenn Du möchtest kannst du mal die Alpha von GitHub installieren - damit sollte nun insgesamt einiges mehr an Datenpunkten da sein.
        B
        B
        broady
        @mrbungle64 Wie lassen sich die % Werte für Filter und Bürsten unter "ecovacs-deebot.0.consumable" zurücksetzen? Gibt es da einen Datenpunkt?
        mrbungle64M 1 Antwort Letzte Antwort
        • B broady
          mrbungle64M
          mrbungle64M
          mrbungle64
          Ja, das ist aber für den Deebot OZMO 905 noch nicht freigeben.
          Soll ich das mal tun? Dann müsstest du mir aber bitte Feedback geben, ob die Funktion bei deinem Gerät funktioniert hat :)
            B
            B
            broady
            @mrbungle64 Das wäre super. Ich gebe dann Rückmeldung. Ich bin gerade dabei eine VIS zu bauen.
            • B broady
              mrbungle64M
              mrbungle64M
              mrbungle64
              Ok, ich habe gerade die 1.4.12-alpha.18 released und die Änderung noch mit aufgenommen.
                B
                B
                broady
                @mrbungle64 Ich habe den 1.4.12-alpha.18 installiert. Die Funktion für das Zurücksetzen der % Werte für Bürsten und Filter für den DEEBOT OZMO 905 fuktioniert problemlos.
                  ich möchte hier einen Topic bereitstellen, wo man Tipps und Tricks zum Ecovacs Deebot Adapter austauschen kann und Funktionen vorgestellt werden.
                  Das letztgenannte sollte i.d.R. mein Job sein - aber ich begrüße auch jeden anderen Beitrag in der Richtung ;)
                  Feedback und Anregungen zu den vorgestellten Themen und Funktionen sind ebenfalls willkommen :)
                  Übersicht
                  • Der Staubbehälter
                  • Speichern und Wiederverwendung von Benutzerdefinierten Bereichen
                  • Namen der Bereiche (Spot Areas) dauerhaft umbenennen
                  • Automatisches Anhalten
                  • Karte der letzten Reinigung
                  • Aktuelle Karte erstellen
                  • "Spot Areas" für die nächste Bereichs-Reinigung markieren
                  Weitere Informationen:
                  • Informationen und Praxistipps (GitHub)
                  • Datenpunkte (GitHub)
                  • FAQ (GitHub)
                  Möglichkeit für sonstiges Feedback:
                  • Bug reports und feature requests (GitHub)
                  • Status und Feedback (Forum)
                  Nützliche Links:
                  • Deebot Staubsauger in VIS integrieren - ioBroker Tutorial | verdrahtet.info
                  • Ideen-Sammlung "Views für ozmo Deebot" (für Deebot Geräte im Allgemeinen)
                  sigi234S
                  sigi234S
                  sigi234
                  @mrbungle64
                  die Voreinstellungen im Adapter holt er sich von der App? (Vorauswahl verwenden)
                  Immer Daten sichern!
                  • sigi234S sigi234
                    @mrbungle64
                    mrbungle64M
                    mrbungle64M
                    mrbungle64
                    @sigi234 sagte in Ecovacs Deebot Adapter: Informationen und Praxistipps:
                    @mrbungle64
                    Nein, das sind ja weitgehend Einstellungen die sich direkt auf Funktionen im Adapter beziehen.
                    Die Vorauswahl kommt zum aus einem Dictionary aus der Library und zusätzlich aus einem weiteren Dictionary im Adapter. Dort sind versch. Eigenschaften und (Standard-)Freigaben für die einzelnen Modelle und deren Varianten festgehalten. Die Deebot API liefert diese Informationen leider nicht (nach aktuellen Stand).
                    Das ist alles ein bisschen undurchsichtig mit der "Vorauswahl", aber es sind halt auch recht viele Modelle-Varianten von Ecovacs und yeedi. Leider habe ich es auch noch nicht implementiert, dass in den Einstellungen schon das konkrete Modell berücksichtigt wird.
                      Übersicht
                      • Der Staubbehälter
                      • FAQ (GitHub)
                      Nützliche Links:
                      sigi234S
                      sigi234S
                      sigi234
                      @mrbungle64
                      N8 bekommen , verbunden und läuft.
                      Installierte Version:
                      1.4.12
                      Sind ja eine Menge DP. Teste jetzt mal. Er lädt gerade auf, dann mache ich meine erste Kartierung.
                        Übersicht
                        • Der Staubbehälter
                        • FAQ (GitHub)
                        Nützliche Links:
                        sigi234S
                        sigi234S
                        sigi234
                        @mrbungle64
                        wenn ich die Objekte von den SpotAreas lösche, werden die wieder erstellt?
                        Durch das erstellen der Maps sind die durcheinander, jetzt habe ich eine funktionierende Map erstellt .
                        Eine Live Karte gibt es noch nicht?
                        • sigi234S sigi234
                          @mrbungle64
                          mrbungle64M
                          mrbungle64M
                          mrbungle64
                          @mrbungle64
                          Ja, die werden wieder neu erstellt. Damit es direkt gemacht wird starte einfach die Adapter Instanz danach neu.
                          Nein, leider noch nicht. Ich hoffe, dass ich dafür in nicht allzu ferner Zukunft mal die Zeit finde ;)
                            @mrbungle64
                            sigi234S
                            sigi234S
                            sigi234
                            @mrbungle64 sagte in Ecovacs Deebot Adapter: Informationen und Praxistipps:
                            Super, kann man dir einen Kaffee ausgeben? Sehe keinen spenden Button.
                            • sigi234S sigi234
                              mrbungle64M
                              mrbungle64M
                              mrbungle64
                              Aktuell (noch) nicht. Aber danke trotzdem für die Bereitschaft mir einen Kaffee ausgeben :)
                                sigi234S
                                sigi234S
                                sigi234
                                Bitte sehr,es wird schon:
                                Screenshot (5304).png Screenshot (5303).png Screenshot (5302).pngScreenshot (5306).pngScreenshot (5390).png
                                  Übersicht
                                  • Der Staubbehälter
                                  • FAQ (GitHub)
                                  Nützliche Links:
                                  L
                                  L
                                  Langer
                                  @mrbungle64
                                  Als erstes Danke für Deine Arbeit, auch ich würde Dir gerne einen Kaffee spendieren.
                                  Gestern ist unser neuer "DEEBOT X1 OMNI " angekommen, solltest Du Daten oder sonstiges brauchen bitte melden.
                                  MfG
                                  Wastl
                                  • L Langer
                                    @mrbungle64
                                    MfG
                                    Wastl
                                    mrbungle64M
                                    mrbungle64M
                                    mrbungle64
                                    @langer sagte in Ecovacs Deebot Adapter: Informationen und Praxistipps:
                                    @mrbungle64
                                    Hallo Wastl,
                                    danke für das Angebot - inzwischen habe ich auch einen DEEBOT X1 (Turbo).
                                    Wenn Du möchtest kannst du direkt die aktuelle Alpha von GitHub installieren - da sind nun einige Datenpunkte für den X1 hinzugekommen :)
                                    MfG
                                    Wastl
                                      Übersicht
                                      • Der Staubbehälter
                                      • FAQ (GitHub)
                                      Nützliche Links:
                                      mrbungle64M
                                      mrbungle64M
                                      mrbungle64
                                      schrieb am zuletzt editiert von mrbungle64
                                      Ab der Version 1.4.13-alpha.11 habe ich außerdem eine andere URL für die Deebot API in Verwendung.
                                      Die scheint deutlich stabiler zu sein als die bisher verwendete.
                                      Wer also noch die "Request failed with status code 502/504" Warnungen im Log hat, kann auch gerne mal die aktuelle Alpha ausprobieren :)
                                        sigi234S
                                        sigi234S
                                        sigi234
                                        @mrbungle64
                                        kann man beib DP :
                                        ecovacs-deebot.0.cleaninglog.last20Logs
                                        noch den Namen der Spot Area einbauen? (ecovacs-deebot.0.map.990111999.spotAreas.2.spotAreaName)
                                        • sigi234S sigi234
                                          @mrbungle64
                                          kann man beib DP :
                                          mrbungle64M
                                          mrbungle64M
                                          mrbungle64
                                          @mrbungle64
                                          kann man beib DP :
                                          Schwierig, da die Spot Areas nicht im Cleaning Log der API enthalten sind.
                                          Ich könnte separat ein Log führen, welches u.a. die Spot Areas enthält.
                                          Die beiden dann aber zu mergen wird aber tendenziell schwierig, da das Cleaning Log der API zeitverzögert rein kommt und ich einen Identifier (wie einen Timestamp) benötigen würde um die Logs zusammenzuführen. Da das zeitverzögert ist scheidet ein Timestamp aber eher aus... Mal schauen, ob mir dazu noch was einfällt.
                                          L 1 Antwort Letzte Antwort
                                          83.8k
                                          1.4m
