  4. Puppeteer: Screenshots PhantomJS Alternative
    apollon77A
screenshotsheadlessbrowserpuppeteerphantomjsscreenshotwebsite
247 Beiträge 24 Kommentatoren 83.6k Aufrufe 18 Beobachtet
  • arteckA arteck
    ich hätte da ein Problem
    direkt frisch installiert
    iobroker läuft in VM auf proxmox
    foxriver76F
    foxriver76F
    foxriver76
    #161
    @arteck Bitte in Zukunft in Code Tags oder irgendeiner Form in der ich die Meldung direkt kopieren kann.
    Läuft iob in Docker?
    Videotutorials & mehr
    • arteckA
      arteckA
      arteck
      #162
      @foxriver76 so kannst du doch mehr lesen...
      host.iobroker
      2022-12-22 08:33:52.410	error	instance system.adapter.puppeteer.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      puppeteer.0
      2022-12-22 08:33:51.872	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
      puppeteer.0
      2022-12-22 08:33:51.868	error	Failed to launch the browser process![1222/083351.630700:FATAL:zygote_host_impl_linux.cc(117)] No usable sandbox! Update your kernel or see https://chromium.googlesource.com/chromium/src/+/main/docs/linux/suid_sandbox_development.md for more information on developing with the SUID sandbox. If you want to live dangerously and need an immediate workaround, you can try using --no-sandbox.#0 0x55ae0b29fb89 base::debug::CollectStackTrace()#1 0x55ae0b204433 base::debug::StackTrace::StackTrace()#2 0x55ae0b217330 logging::LogMessage::~LogMessage()#3 0x55ae091fc99b content::ZygoteHostImpl::Init()#4 0x55ae0adad372 content::ContentMainRunnerImpl::Initialize()#5 0x55ae0adab439 content::RunContentProcess()#6 0x55ae0adab58e content::ContentMain()#7 0x55ae0ae06d7a headless::(anonymous namespace)::RunContentMain()#8 0x55ae0ae06a85 headless::HeadlessShellMain()#9 0x55ae0786a3e8 ChromeMain#10 0x7f49e348409b __libc_start_main#11 0x55ae0786a22a _startTROUBLESHOOTING: https://github.com/puppeteer/puppeteer/blob/main/docs/troubleshooting.md
      puppeteer.0
      2022-12-22 08:33:51.868	error	Error: Failed to launch the browser process![1222/083351.630700:FATAL:zygote_host_impl_linux.cc(117)] No usable sandbox! Update your kernel or see https://chromium.googlesource.com/chromium/src/+/main/docs/linux/suid_sandbox_development.md for more information on developing with the SUID sandbox. If you want to live dangerously and need an immediate workaround, you can try using --no-sandbox.#0 0x55ae0b29fb89 base::debug::CollectStackTrace()#1 0x55ae0b204433 base::debug::StackTrace::StackTrace()#2 0x55ae0b217330 logging::LogMessage::~LogMessage()#3 0x55ae091fc99b content::ZygoteHostImpl::Init()#4 0x55ae0adad372 content::ContentMainRunnerImpl::Initialize()#5 0x55ae0adab439 content::RunContentProcess()#6 0x55ae0adab58e content::ContentMain()#7 0x55ae0ae06d7a headless::(anonymous namespace)::RunContentMain()#8 0x55ae0ae06a85 headless::HeadlessShellMain()#9 0x55ae0786a3e8 ChromeMain#10 0x7f49e348409b __libc_start_main#11 0x55ae0786a22a _startTROUBLESHOOTING: https://github.com/puppeteer/puppeteer/blob/main/docs/troubleshooting.md at onClose (/opt/iobroker/node_modules/puppeteer/lib/cjs/puppeteer/node/BrowserRunner.js:241:20) at Interface.<anonymous> (/opt/iobroker/node_modules/puppeteer/lib/cjs/puppeteer/node/BrowserRunner.js:231:68) at Interface.emit (node:events:525:35) at Interface.close (node:readline:590:8) at Socket.onend (node:readline:280:10) at Socket.emit (node:events:525:35) at endReadableNT (node:internal/streams/readable:1358:12) at processTicksAndRejections (node:internal/process/task_queues:83:21)
      puppeteer.0
      2022-12-22 08:33:51.867	error	unhandled promise rejection: Failed to launch the browser process![1222/083351.630700:FATAL:zygote_host_impl_linux.cc(117)] No usable sandbox! Update your kernel or see https://chromium.googlesource.com/chromium/src/+/main/docs/linux/suid_sandbox_development.md for more information on developing with the SUID sandbox. If you want to live dangerously and need an immediate workaround, you can try using --no-sandbox.#0 0x55ae0b29fb89 base::debug::CollectStackTrace()#1 0x55ae0b204433 base::debug::StackTrace::StackTrace()#2 0x55ae0b217330 logging::LogMessage::~LogMessage()#3 0x55ae091fc99b content::ZygoteHostImpl::Init()#4 0x55ae0adad372 content::ContentMainRunnerImpl::Initialize()#5 0x55ae0adab439 content::RunContentProcess()#6 0x55ae0adab58e content::ContentMain()#7 0x55ae0ae06d7a headless::(anonymous namespace)::RunContentMain()#8 0x55ae0ae06a85 headless::HeadlessShellMain()#9 0x55ae0786a3e8 ChromeMain#10 0x7f49e348409b __libc_start_main#11 0x55ae0786a22a _startTROUBLESHOOTING: https://github.com/puppeteer/puppeteer/blob/main/docs/troubleshooting.md
      puppeteer.0
      2022-12-22 08:33:51.865	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      host.iobroker
      2022-12-22 08:33:50.856	info	instance system.adapter.puppeteer.0 started with pid 11315
      debian VM in Proxmox
      • arteckA arteck
        host.iobroker
        puppeteer.0
        puppeteer.0
        puppeteer.0
        puppeteer.0
        puppeteer.0
        host.iobroker
        foxriver76F
        foxriver76F
        foxriver76
        #163
        @arteck sagte in Puppeteer: Screenshots PhantomJS Alternative:
        Welche Version von Debian?
        • arteckA
          arteckA
          arteck
          #164
          @foxriver76 buster also 10
          • arteckA arteck
            foxriver76F
            foxriver76F
            foxriver76
            #165
            @arteck Okay, dann habe ich erst mal keine Idee, wie ich das allgemein fixen kann.
            Du könntest für dich speziell, diese Lösung probieren und rückmelden ob das tut: https://github.com/puppeteer/puppeteer/blob/main/docs/troubleshooting.md#recommended-enable-user-namespace-cloning
            • foxriver76F foxriver76
              arteckA
              arteckA
              arteck
              #166
              @foxriver76 ich geh mal auf bullseye mal schauen dann..
              • arteckA arteck
                crunchipC
                crunchipC
                Developer Global Moderator Most Active Forum Testing
                #167
                bullseye
                damit läufts bei mir , siehe https://forum.iobroker.net/post/812880
                • arteckA
                  arteckA
                  arteck
                  #168
                  mit bullseye läuft der ...
                  • arteckA arteck
                    Thomas BraunT
                    Thomas BraunT
                    #169
                    Und deswegen predige ich ja auch immer nicht an abgekündigten Versionen festzuhalten und die Kisten auf Stand zu halten. Bringt nix sich da mit obsoletem Kram zu beschäftigen.
                      arteckA
                      arteckA
                      arteck
                      #170
                      @thomas-braun dir auch schöne Feiertage :-)
                      • arteckA
                        arteckA
                        arteck
                        #171
                        @foxriver76 so weiter gehts
                        puppeteer.0
                        2022-12-22 11:08:33.619	debug	Write file to "wetterstation.png"
                        puppeteer.0
                        2022-12-22 11:08:32.470	debug	Message: {"command":"screenshot","message":{"url":"https://www.yr.no/en/forecast/graph/2-2860410/Germany/North%20Rhine-Westphalia/D%C3%BCsseldorf%20District/Oberhausen","clip":{"x":0,"y":0,"width":1000,"height":757},"ioBrokerOptions":{"storagePath":"wetterstation.png"},"viewportOptions":{"width":1600,"height":1000}},"from":"system.adapter.javascript.2","callback":{"message":{"url":"https://www.yr.no/en/forecast/graph/2-2860410/Germany/North%20Rhine-Westphalia/D%C3%BCsseldorf%20District/Oberhausen","clip":{"x":0,"y":0,"width":1000,"height":757},"ioBrokerOptions":{"storagePath":"wetterstation.png"},"viewportOptions":{"width":1600,"height":1000}},"id":1,"ack":false,"time":1671703712468},"_id":69097945}
                        javascript.2
                        2022-12-22 11:14:19.409	info	script.js.80_system.wetter: Sucessfully took screenshot: �PNG   IHDR��T��sRGB��� IDATx���wTW�g�� MT�bD��bCE콠1�X�+ػb7{7�`�b�(��^������0�� ����w�Gv��̝;w޹edB"""""""�S��1@'""""""� Љ�������t"""""""-��������H0@'""""""�Љ�������t"""""""-��������H0@'""""""�Љ�������t"""""""-��������H0@'""""""�Љ�������t"""""""-��������H0@'""""""�Љ�������t"""""""-��������H0@'""""""�Љ�������t"""""""-��������H0@'""""""�Љ��.........
                        sieht eigentlich gut aus..ich hab das binary gekürzt..
                        aber kein file und die datenpunkte sind auch nicht gefüllt
                        sendTo('puppeteer.0', 'screenshot', {
                                url: 'https://www.yr.no/en/forecast/graph/2-2860410/Germany/North%20Rhine-Westphalia/D%C3%BCsseldorf%20District/Oberhausen',
                                clip: {
                                    x: 0,
                                    y: 0,
                                    width: 1000,
                                    height: 757
                                ioBrokerOptions: {
                                    storagePath: 'wetterstation.png',
                                viewportOptions: {
                                    width: 1600,
                                    height: 1000
                            }, obj => {
                              if (obj.error) {
                                log(`Error taking screenshot: ${obj.error.message}`, 'error');
                              } else {
                                // the binary representation of the image is contained in `obj.result`
                                log(`Sucessfully took screenshot: ${obj.result}`);
                        so rufe ich es auf ..sollte also in /opt/iobroker/iobroker-data/files/0_userdata.0 landen..ist aber nix da
                        • arteckA arteck
                          puppeteer.0
                          puppeteer.0
                          javascript.2
                                  clip: {
                                      x: 0,
                                      y: 0,
                                      width: 1000,
                                      height: 757
                                  ioBrokerOptions: {
                                  viewportOptions: {
                                      width: 1600,
                                      height: 1000
                              }, obj => {
                                if (obj.error) {
                                } else {
                          foxriver76F
                          foxriver76F
                          foxriver76
                          schrieb am zuletzt editiert von foxriver76
                          #172
                          @arteck Siehe:
                          https://github.com/foxriver76/ioBroker.puppeteer#how-to
                          States dienen nur der Konfiguration, falls du via States (sprich das setzen der url) einen Screenshot erstellen möchtest. Wenn du ausschließlich Messages nutzt können dir die States egal sein.
                          Nutzt du eine Redis DB für die Objekte?
                            @arteck Siehe:
                            arteckA
                            arteckA
                            arteck
                            #173
                            @foxriver76 jo Redis
                            ich wollte mir nur ein Bild des meteogramms machen und in die Vis pressen
                            • arteckA arteck
                              foxriver76F
                              foxriver76F
                              foxriver76
                              #174
                              @arteck Wenn Objekte in Redis, dann werden Dateien nicht raw auf dem FS abgespeichert, unabhängig vom Adapter. Du solltest diese z. B. im Admin in Dateien unter Benutzerdaten finden.
                              arteckA foxriver76F 2 Antworten Letzte Antwort
                                arteckA
                                arteckA
                                arteck
                                #175
                                @foxriver76 recht hast du ja
                                da wo man es hinschiebt ist es auch
                                  foxriver76F
                                  foxriver76F
                                  foxriver76
                                  #176
                                  @foxriver76 Falls du es auf dem FS haben möchtest, kannst du die Option path auf Top Level mitgeben. Ist dann Puppeteer intern abgehandelt: https://pptr.dev/api/puppeteer.screenshotoptions.path
                                    arteckA
                                    arteckA
                                    arteck
                                    #177
                                    @foxriver76 ok
                                    aber verstehe jetzt nicht die Nutzung der Datenpunkte ??
                                    wenn ich alle 60 min ein bild haben will.. was nutz ich da.. stehe bissel auf dem Schlauch
                                    • arteckA arteck
                                      @foxriver76 ok
                                      foxriver76F
                                      foxriver76F
                                      foxriver76
                                      #178
                                      @arteck Wenn du nicht so der "Skript Typ" bist, kannst du einige der oft genutzten Optionen direkt über die Datenpunkte festlegen und dann schreibst du eine url in den url state und ein Screenshot wird erstellt. Das ist etwas angelehnt an die Logik vom Phantom.JS Adapter, soweit ich mich erinnere.
                                      Mit sendTo hast du deutlich mehr Optionen zur Verfügung und bekommst z. B. auch das Bild direkt im Callback falls du es codetechnsich weiterverarbeiten möchtest.
                                      • arteckA arteck
                                        @foxriver76 ok
                                        foxriver76F
                                        foxriver76F
                                        foxriver76
                                        #179
                                        @arteck Es gibt keine Option, das regelmäßig festzulegen.
                                        Sprich du würdest dein Code (entweder setState auf den url State oder dein sendTo) in einen schedule packen der jede Minute triggered oder im Callback von der Funktion die Funktion mit setTimeout in 60 Sekunden erneut aufrufen
                                          arteckA
                                          arteckA
                                          arteck
                                          #180
                                          @foxriver76 ahh ok.. jetzt ja..THX
                                          84.0k
                                          1.4m
