  3. Off Topic
  4. Grafana
  5. Grafana Update Probleme
    6.8k
Geplant Angeheftet Gesperrt Verschoben Grafana
104 Beiträge 7 Kommentatoren 13.1k Aufrufe 5 Beobachtet
  • Damrak2022D Damrak2022
    @crunchip sagte in Grafana Update Probleme:
    systemctl status grafana-server
    Nachdem ich die Befehle eingegeben habe ist dies das Ergebnis
    pi@homebridge:~ $ systemctl enable grafana-server
    Synchronizing state of grafana-server.service with SysV service script with /lib/systemd/systemd-sysv-install.
    Executing: /lib/systemd/systemd-sysv-install enable grafana-server
    ==== AUTHENTICATING FOR org.freedesktop.systemd1.reload-daemon ===
    Authentication is required to reload the systemd state.
    Authenticating as: ,,, (pi)
    Password:
    ==== AUTHENTICATION COMPLETE ===
    Password:
    ==== AUTHENTICATING FOR org.freedesktop.systemd1.manage-unit-files ===
    Authentication is required to manage system service or unit files.
    Password:
    Password:
    pi@homebridge:~ $ systemctl start grafana-server
    ==== AUTHENTICATING FOR org.freedesktop.systemd1.manage-units ===
    Authentication is required to start 'grafana-server.service'.
    Password:
    pi@homebridge:~ $ systemctl status grafana-server
    ● grafana-server.service - Grafana instance
         Loaded: loaded (/lib/systemd/system/grafana-server.service; enabled; vendo>
         Active: failed (Result: exit-code) since Tue 2022-04-26 02:28:48 BST; 15s >
           Docs: http://docs.grafana.org
        Process: 22671 ExecStart=/usr/sbin/grafana-server --config=${CONF_FILE} --p>
       Main PID: 22671 (code=exited, status=1/FAILURE)
            CPU: 360ms
    Apr 26 02:28:48 homebridge systemd[1]: grafana-server.service: Scheduled restar>
    Apr 26 02:28:48 homebridge systemd[1]: Stopped Grafana instance.
    Apr 26 02:28:48 homebridge systemd[1]: grafana-server.service: Start request re>
    Apr 26 02:28:48 homebridge systemd[1]: grafana-server.service: Failed with resu>
    Apr 26 02:28:48 homebridge systemd[1]: Failed to start Grafana instance.
    lines 1-13/13 (END)
    crunchipC Offline
    crunchipC Offline
    #41
    @damrak2022 sorry hatte sudo vergessen, bzw probier es so
    sudo /bin/systemctl enable grafana-server
    sudo /bin/systemctl start grafana-server
    sudo /bin/systemctl status grafana-server
      Damrak2022D Offline
      Damrak2022D Offline
      Damrak2022
      schrieb am zuletzt editiert von Damrak2022
      #42
      Das ist das Ergebnis:
      pi@homebridge:~ $ sudo /bin/systemctl enable grafana-server
      pi@homebridge:~ $ sudo /bin/systemctl start grafana-server
      pi@homebridge:~ $ sudo /bin/systemctl status grafana-server
           Active: failed (Result: exit-code) since Tue 2022-04-26 04:26:20 BST; 15s >
          Process: 7077 ExecStart=/usr/sbin/grafana-server --config=${CONF_FILE} --pi>
         Main PID: 7077 (code=exited, status=1/FAILURE)
              CPU: 330ms
      Apr 26 04:26:20 homebridge systemd[1]: grafana-server.service: Scheduled restar>
      Apr 26 04:26:20 homebridge systemd[1]: Stopped Grafana instance.
      Apr 26 04:26:20 homebridge systemd[1]: grafana-server.service: Start request re>
      Apr 26 04:26:20 homebridge systemd[1]: grafana-server.service: Failed with resu>
      Apr 26 04:26:20 homebridge systemd[1]: Failed to start Grafana instance.
      lines 1-13/13 (END)
      Hier lässt Erich garnicht rein, auch nicht mit sudo
      pi@homebridge:~ $ /usr/lib/systemd/system/grafana-server.service
      -bash: /usr/lib/systemd/system/grafana-server.service: Permission denied
      Mit besten Grüßen
      Andy
                CPU: 330ms
        lines 1-13/13 (END)
        crunchipC Offline
        crunchipC Offline
        #43
        @damrak2022 ich muss mir das in Ruhe heute Nachmittag am Pc ansehen. So früh am Morgen mit dem Handy etwas schwierig.
          Damrak2022D Offline
          Damrak2022D Offline
          Damrak2022
          #44
          @crunchip Hast Du noch irgendeine Idee, denn ich kann Grafana weiterhin nicht aufrufen
          Mit besten Grüßen
          Andy
          crunchipC Thomas BraunT 2 Antworten Letzte Antwort
            crunchipC Offline
            crunchipC Offline
            #45
            @damrak2022 ich bin am gucken
              Damrak2022D Offline
              Damrak2022D Offline
              Damrak2022
              #46
              @crunchip Ich danke Dir. Wenn ich da wieder drauf komme lasse ich erstmal die Finger vom Terminal was Grafana betrifft.
              Mit besten Grüßen
              Andy
                #47
                @damrak2022
                Ist denn jetzt grafana 8.4.7 die alleinig installierte Version oder spukt da noch was anderes herum?
                  @damrak2022
                  Damrak2022D Offline
                  Damrak2022D Offline
                  Damrak2022
                  #48
                  @thomas-braun Nur 8.4.7, aber ich kann nochmal schauen
                  pi@homebridge:~ $ apt policy grafana
                  grafana:
                    Installed: 8.4.7
                    Candidate: 8.5.0
                    Version table:
                       8.5.0 500
                          500 https://packages.grafana.com/oss/deb stable/main armhf Packages
                   *** 8.4.7 500
                          100 /var/lib/dpkg/status
                       8.4.6 500
                       8.4.5 500
                       8.4.4 500
                       8.4.3 500
                       8.4.2 500
                       8.4.1 500
                       8.4.0 500
                       8.3.7 500
                       8.3.6 500
                       8.3.5 500
                       8.3.4 500
                       8.3.3 500
                       8.3.2 500
                       8.3.1 500
                       8.3.0 500
                       8.2.7 500
                       8.2.6 500
                       8.2.5 500
                       8.2.4 500
                       8.2.3 500
                       8.2.2 500
                       8.2.1 500
                       8.2.0 500
                       8.1.8 500
                       8.1.7 500
                       8.1.6 500
                       8.1.5 500
                       8.1.4 500
                       8.1.3 500
                       8.1.2 500
                       8.1.1 500
                       8.1.0 500
                       8.0.7 500
                       8.0.6 500
                       8.0.5 500
                       8.0.4 500
                       8.0.3 500
                       8.0.2 500
                       8.0.1 500
                       8.0.0 500
                       7.5.15 500
                       7.5.13 500
                       7.5.12 500
                       7.5.11 500
                       7.5.10 500
                       7.5.9 500
                       7.5.8 500
                       7.5.7 500
                       7.5.6 500
                       7.5.5 500
                       7.5.4 500
                       7.5.3 500
                       7.5.2 500
                       7.5.1 500
                       7.5.0 500
                       7.4.5 500
                       7.4.3 500
                       7.4.2 500
                       7.4.1 500
                       7.4.0 500
                       7.3.10 500
                       7.3.7 500
                       7.3.6 500
                       7.3.5 500
                       7.3.4 500
                       7.3.3 500
                       7.3.2 500
                       7.3.1 500
                       7.3.0 500
                       7.2.2 500
                       7.2.1 500
                       7.2.0 500
                       7.1.5 500
                       7.1.4 500
                       7.1.3 500
                       7.1.2 500
                       7.1.1 500
                       7.1.0 500
                       7.0.6 500
                       7.0.5 500
                       7.0.4 500
                       7.0.3 500
                       7.0.2 500
                       7.0.1 500
                       7.0.0 500
                       6.7.6 500
                       6.7.5 500
                       6.7.4 500
                       6.7.3 500
                       6.7.2 500
                       6.7.1 500
                       6.7.0 500
                       6.6.2 500
                       6.6.1 500
                       6.6.0 500
                       6.5.3 500
                       6.5.2 500
                       6.5.1 500
                       6.5.0 500
                       6.4.5 500
                       6.4.4 500
                       6.4.3 500
                       6.4.2 500
                       6.4.1 500
                       6.4.0 500
                       6.3.7 500
                       6.3.6 500
                       6.3.5 500
                       6.3.4 500
                       6.3.3 500
                       6.3.2 500
                       6.3.1 500
                       6.3.0 500
                       6.2.5 500
                       6.2.4 500
                       6.2.3 500
                       6.2.2 500
                       6.2.1 500
                       6.2.0 500
                       6.1.6 500
                       6.1.5 500
                       6.1.4 500
                       6.1.3 500
                       6.1.2 500
                       6.1.1 500
                       6.1.0 500
                       6.0.2 500
                       6.0.1 500
                       6.0.0 500
                       5.4.5 500
                       5.4.4 500
                       5.4.3 500
                       5.4.2 500
                       5.4.1 500
                       5.4.0 500
                       5.3.4 500
                       5.3.3 500
                       5.3.2 500
                       5.3.1 500
                       5.3.0 500
                       5.2.5 500
                       5.2.4 500
                       5.2.3 500
                       5.2.2 500
                       5.2.1 500
                       5.2.0 500
                  pi@homebridge:~ $
                  Haben die 3* vor der 8.4.7 was zu bedeuten<<ß
                  Mit besten Grüßen
                  Andy
                    grafana:
                      Installed: 8.4.7
                      Candidate: 8.5.0
                      Version table:
                         8.5.0 500
                     *** 8.4.7 500
                         8.4.6 500
                         8.4.5 500
                         8.4.4 500
                         8.4.3 500
                         8.4.2 500
                         8.4.1 500
                         8.4.0 500
                         8.3.7 500
                         8.3.6 500
                         8.3.5 500
                         8.3.4 500
                         8.3.3 500
                         8.3.2 500
                         8.3.1 500
                         8.3.0 500
                         8.2.7 500
                         8.2.6 500
                         8.2.5 500
                         8.2.4 500
                         8.2.3 500
                         8.2.2 500
                         8.2.1 500
                         8.2.0 500
                         8.1.8 500
                         8.1.7 500
                         8.1.6 500
                         8.1.5 500
                         8.1.4 500
                         8.1.3 500
                         8.1.2 500
                         8.1.1 500
                         8.1.0 500
                         8.0.7 500
                         8.0.6 500
                         8.0.5 500
                         8.0.4 500
                         8.0.3 500
                         8.0.2 500
                         8.0.1 500
                         8.0.0 500
                         7.5.15 500
                         7.5.13 500
                         7.5.12 500
                         7.5.11 500
                         7.5.10 500
                         7.5.9 500
                         7.5.8 500
                         7.5.7 500
                         7.5.6 500
                         7.5.5 500
                         7.5.4 500
                         7.5.3 500
                         7.5.2 500
                         7.5.1 500
                         7.5.0 500
                         7.4.5 500
                         7.4.3 500
                         7.4.2 500
                         7.4.1 500
                         7.4.0 500
                         7.3.10 500
                         7.3.7 500
                         7.3.6 500
                         7.3.5 500
                         7.3.4 500
                         7.3.3 500
                         7.3.2 500
                         7.3.1 500
                         7.3.0 500
                         7.2.2 500
                         7.2.1 500
                         7.2.0 500
                         7.1.5 500
                         7.1.4 500
                         7.1.3 500
                         7.1.2 500
                         7.1.1 500
                         7.1.0 500
                         7.0.6 500
                         7.0.5 500
                         7.0.4 500
                         7.0.3 500
                         7.0.2 500
                         7.0.1 500
                         7.0.0 500
                         6.7.6 500
                         6.7.5 500
                         6.7.4 500
                         6.7.3 500
                         6.7.2 500
                         6.7.1 500
                         6.7.0 500
                         6.6.2 500
                         6.6.1 500
                         6.6.0 500
                         6.5.3 500
                         6.5.2 500
                         6.5.1 500
                         6.5.0 500
                         6.4.5 500
                         6.4.4 500
                         6.4.3 500
                         6.4.2 500
                         6.4.1 500
                         6.4.0 500
                         6.3.7 500
                         6.3.6 500
                         6.3.5 500
                         6.3.4 500
                         6.3.3 500
                         6.3.2 500
                         6.3.1 500
                         6.3.0 500
                         6.2.5 500
                         6.2.4 500
                         6.2.3 500
                         6.2.2 500
                         6.2.1 500
                         6.2.0 500
                         6.1.6 500
                         6.1.5 500
                         6.1.4 500
                         6.1.3 500
                         6.1.2 500
                         6.1.1 500
                         6.1.0 500
                         6.0.2 500
                         6.0.1 500
                         6.0.0 500
                         5.4.5 500
                         5.4.4 500
                         5.4.3 500
                         5.4.2 500
                         5.4.1 500
                         5.4.0 500
                         5.3.4 500
                         5.3.3 500
                         5.3.2 500
                         5.3.1 500
                         5.3.0 500
                         5.2.5 500
                         5.2.4 500
                         5.2.3 500
                         5.2.2 500
                         5.2.1 500
                         5.2.0 500
                    pi@homebridge:~ $
                    #49
                    @damrak2022
                    Die drei Sterne kennzeichnen die installierte Version.
                    apt policy grafana*
                      @damrak2022
                      apt policy grafana*
                      Damrak2022D Offline
                      Damrak2022D Offline
                      Damrak2022
                      #50
                      @thomas-braun sagte in Grafana Update Probleme:
                      apt policy grafana*
                      pi@homebridge:~ $ apt policy grafana*
                      N: Unable to locate package grafana-rpi_7.4.3_armhf.deb
                      pi@homebridge:~ $
                      Mit besten Grüßen
                      Andy
                        apt policy grafana*
                        pi@homebridge:~ $
                        #51
                        @damrak2022
                        Da spukt noch irgendwo diese ominöse
                        herum. Wie hast du die denn installiert? Aus dem Paketmanager mit hoher Wahrscheinlichkeit nicht, da ist die nämlich nicht drin. Es sei denn, die ist zurückgezogen worden.
                        • Damrak2022D Offline
                          Damrak2022D Offline
                          Damrak2022
                          #52
                          @thomas-braun Doch alles über das Terminal
                          Mit besten Grüßen
                          Andy
                            #53
                            @damrak2022
                            Über das Terminal gibt es mehrere Wege Pakete zu installieren.
                            Ist die Frage welchen du (nach welcher Anleitung?) genommen hast.
                              #54
                              @damrak2022
                              dpkg -l '*grafana-rpi*'
                              sagt?
                                @damrak2022
                                Damrak2022D Offline
                                Damrak2022D Offline
                                Damrak2022
                                #55
                                @thomas-braun Meiner Meinung nach über die Anleitung Grafana auf einem Raps installieren. Aber mittlerweile sind wir so viele Befehle durchgegangen, das ich es nicht sicher beantworten kann.
                                Mit besten Grüßen
                                Andy
                                Damrak2022D crunchipC 2 Antworten Letzte Antwort
                                  Damrak2022D Offline
                                  Damrak2022D Offline
                                  Damrak2022
                                  #56
                                  @damrak2022
                                  pi@homebridge:~ $ dpkg -l '*grafana-rpi*'
                                  Desired=Unknown/Install/Remove/Purge/Hold
                                  | Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
                                  |/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
                                  ||/ Name           Version      Architecture Description
                                  rc  grafana-rpi    7.4.3        armhf        Grafana
                                  pi@homebridge:~ $
                                  Mit besten Grüßen
                                  Andy
                                    crunchipC Offline
                                    crunchipC Offline
                                    #57
                                    @damrak2022 sagte in Grafana Update Probleme:
                                    weil du auch die rpi, dann die enterprise, dann eine bestimmte version, dann die neuste, dann wieder zurück....
                                    langsam hab ich den Überblick verloren, hab auch nochmal deinen andere thread durch gesehen
                                      Damrak2022D Offline
                                      Damrak2022D Offline
                                      Damrak2022
                                      #58
                                      @crunchip Ich leider auch. Kann man nicht von der 7.4.3 gezielt alles löschen, sodass nur noch die 8.4.7 verbleibt?
                                      Mit besten Grüßen
                                      Andy
                                        crunchipC Offline
                                        crunchipC Offline
                                        #59
                                        @damrak2022 vllt mit
                                        sudo dpkg -r --force-all grafana-rpi
                                        Damrak2022D 2 Antworten Letzte Antwort
                                          Damrak2022D Offline
                                          Damrak2022D Offline
                                          Damrak2022
                                          #60
                                          @crunchip Löscht er dann nicht auch die 8.4.7 mit?
                                          Na egal, ich versuche es
                                          Mit besten Grüßen
                                          Andy
