  3. Off Topic
  4. Grafana
  5. Grafana Update Probleme
    6.8k
Geplant Angeheftet Gesperrt Verschoben Grafana
104 Beiträge 7 Kommentatoren 13.1k Aufrufe 5 Beobachtet
  • Damrak2022D Damrak2022
    @thomas-braun Ich verstehe garnichts mehr. Jetzt komme ich nicht mehr auf die Webseite von Grafana
    pi@homebridge:~ $ sudo reboot
    Connection to homebridge closed by remote host.
    Connection to homebridge closed.
    damrak2021@Andreass-iMac ~ % ssh pi@homebridge
    pi@homebridge's password:
    Linux homebridge 5.15.32-v7l+ #1538 SMP Thu Mar 31 19:39:41 BST 2022 armv7l
    permitted by applicable law.
    Last login: Mon Apr 25 09:03:38 2022 from 2a02:908:171:e900:5da1:8f55:5199:833
    pi@homebridge:~ $ sudo /bin/systemctl daemon-reload
    pi@homebridge:~ $ sudo /bin/systemctl enable grafana-server
    Synchronizing state of grafana-server.service with SysV service script with /lib/systemd/systemd-sysv-install.
    Executing: /lib/systemd/systemd-sysv-install enable grafana-server
    pi@homebridge:~ $ sudo /bin/systemctl start grafana-server
    pi@homebridge:~ $
    Ich schaue mal was in der ini steht
    @damrak2022
    systemctl status grafana-server
      @damrak2022
      Damrak2022D Offline
      Damrak2022D Offline
      Damrak2022
      @thomas-braun sagte in Grafana Update Probleme:
      pi@homebridge:~ $ systemctl status grafana-server
      ● grafana-server.service - Grafana instance
           Loaded: loaded (/lib/systemd/system/grafana-server.service; enabled; vendo>
           Active: failed (Result: exit-code) since Mon 2022-04-25 10:15:03 BST; 4min>
             Docs: http://docs.grafana.org
          Process: 3609 ExecStart=/usr/sbin/grafana-server --config=${CONF_FILE} --pi>
         Main PID: 3609 (code=exited, status=203/EXEC)
              CPU: 7ms
      Apr 25 10:15:03 homebridge systemd[1]: grafana-server.service: Scheduled restar>
      Apr 25 10:15:03 homebridge systemd[1]: Stopped Grafana instance.
      Apr 25 10:15:03 homebridge systemd[1]: grafana-server.service: Start request re>
      Apr 25 10:15:03 homebridge systemd[1]: grafana-server.service: Failed with resu>
      Apr 25 10:15:03 homebridge systemd[1]: Failed to start Grafana instance.
      lines 1-13/13 (END)
      Mit besten Grüßen
      Andy
                CPU: 7ms
        lines 1-13/13 (END)
        @damrak2022
        Bitte vollständig.
        Probier die Vorversion:
        sudo apt install grafana=8.4.7
          @damrak2022
          Bitte vollständig.
          Damrak2022D Offline
          Damrak2022D Offline
          Damrak2022
          pi@homebridge:~ $ sudo apt install grafana=8.4.7
          Reading package lists... Done
          The following packages will be DOWNGRADED:
            grafana
          0 upgraded, 0 newly installed, 1 downgraded, 0 to remove and 0 not upgraded.
          Need to get 71.9 MB of archives.
          After this operation, 9,899 kB disk space will be freed.
          Do you want to continue? [Y/n] y
          Get:1 https://packages.grafana.com/oss/deb stable/main armhf grafana armhf 8.4.7 [71.9 MB]
          Fetched 71.9 MB in 7s (10.5 MB/s)
          dpkg: warning: downgrading grafana from 8.5.0 to 8.4.7
          (Reading database ... 69307 files and directories currently installed.)
          Preparing to unpack .../grafana_8.4.7_armhf.deb ...
          Unpacking grafana (8.4.7) over (8.5.0) ...
          Setting up grafana (8.4.7) ...
          Installing new version of config file /etc/default/grafana-server ...
          Installing new version of config file /usr/lib/systemd/system/grafana-server.service ...
          Restarting grafana-server service... OK
          pi@homebridge:~ $
          Das Problem war doch schon mal da, das ich Grafana nicht mehr aufrufen konnte. Ich weiß nur nicht mehr wie wir das neulich hinbekommen haben.
          Mit besten Grüßen
          Andy
              grafana
            pi@homebridge:~ $
            crunchipC Offline
            crunchipC Offline
            @damrak2022 die 8.5 scheint ein Problem zu haben, daher eine Version zurückspringen.
            Sollte es nach einem reboot immer noch nicht starten, dann manuell nochmal nachlegen.
            RoddiEFR Damrak2022D 2 Antworten Letzte Antwort
              RoddiEFR Offline
              RoddiEFR Offline
              RoddiEF
              @crunchip sagte in Grafana Update Probleme:
              Bei mir läuft die 8.5.0 auf einem Rpi-4-4GB ohne Probleme, denke liegt wohl nicht an Grafana sondern eher an der "verquirlten" Installation....
              Ich bin wie ich bin, was anderes bekommt man nicht !!
              • RoddiEFR RoddiEF
                @roddief
                64bit oder 32bit System?
                Auf meinem 64er startet grafana auch, vermutlich ist die 32bit Version betroffen.
                RoddiEFR 1 Antwort Letzte Antwort
                  @roddief
                  RoddiEFR Offline
                  RoddiEFR Offline
                  RoddiEF
                  @roddief
                  Läuft auf nem 32-Bit System...
                  • RoddiEFR RoddiEF
                    @roddief
                    @roddief
                    Hier melden sich auch user mit dem Phänomen:
                    https://github.com/grafana/grafana/issues/48130
                      Damrak2022D Offline
                      Damrak2022D Offline
                      Damrak2022
                      Nachdem ich die Befehle eingegeben habe ist dies das Ergebnis
                      pi@homebridge:~ $ systemctl enable grafana-server
                      ==== AUTHENTICATING FOR org.freedesktop.systemd1.reload-daemon ===
                      Authentication is required to reload the systemd state.
                      Authenticating as: ,,, (pi)
                      Password:
                      ==== AUTHENTICATION COMPLETE ===
                      Password:
                      ==== AUTHENTICATING FOR org.freedesktop.systemd1.manage-unit-files ===
                      Authentication is required to manage system service or unit files.
                      Password:
                      Password:
                      pi@homebridge:~ $ systemctl start grafana-server
                      ==== AUTHENTICATING FOR org.freedesktop.systemd1.manage-units ===
                      Authentication is required to start 'grafana-server.service'.
                      Password:
                           Active: failed (Result: exit-code) since Tue 2022-04-26 02:28:48 BST; 15s >
                          Process: 22671 ExecStart=/usr/sbin/grafana-server --config=${CONF_FILE} --p>
                         Main PID: 22671 (code=exited, status=1/FAILURE)
                              CPU: 360ms
                      Apr 26 02:28:48 homebridge systemd[1]: grafana-server.service: Scheduled restar>
                      Apr 26 02:28:48 homebridge systemd[1]: Stopped Grafana instance.
                      Apr 26 02:28:48 homebridge systemd[1]: grafana-server.service: Start request re>
                      Apr 26 02:28:48 homebridge systemd[1]: grafana-server.service: Failed with resu>
                      Apr 26 02:28:48 homebridge systemd[1]: Failed to start Grafana instance.
                      lines 1-13/13 (END)
                      Mit besten Grüßen
                      Andy
                        Password:
                        Password:
                        Password:
                        Password:
                        Password:
                                CPU: 360ms
                        lines 1-13/13 (END)
                        crunchipC Offline
                        crunchipC Offline
                        @damrak2022 sorry hatte sudo vergessen, bzw probier es so
                        sudo /bin/systemctl status grafana-server
                          Damrak2022D Offline
                          Damrak2022D Offline
                          Damrak2022
                          Das ist das Ergebnis:
                          pi@homebridge:~ $ sudo /bin/systemctl status grafana-server
                               Active: failed (Result: exit-code) since Tue 2022-04-26 04:26:20 BST; 15s >
                              Process: 7077 ExecStart=/usr/sbin/grafana-server --config=${CONF_FILE} --pi>
                             Main PID: 7077 (code=exited, status=1/FAILURE)
                                  CPU: 330ms
                          Apr 26 04:26:20 homebridge systemd[1]: grafana-server.service: Scheduled restar>
                          Apr 26 04:26:20 homebridge systemd[1]: Stopped Grafana instance.
                          Apr 26 04:26:20 homebridge systemd[1]: grafana-server.service: Start request re>
                          Apr 26 04:26:20 homebridge systemd[1]: grafana-server.service: Failed with resu>
                          Apr 26 04:26:20 homebridge systemd[1]: Failed to start Grafana instance.
                          lines 1-13/13 (END)
                          Hier lässt Erich garnicht rein, auch nicht mit sudo
                          pi@homebridge:~ $ /usr/lib/systemd/system/grafana-server.service
                          -bash: /usr/lib/systemd/system/grafana-server.service: Permission denied
                          Mit besten Grüßen
                          Andy
                                    CPU: 330ms
                            lines 1-13/13 (END)
                            crunchipC Offline
                            crunchipC Offline
                            @damrak2022 ich muss mir das in Ruhe heute Nachmittag am Pc ansehen. So früh am Morgen mit dem Handy etwas schwierig.
                              Damrak2022D Offline
                              Damrak2022D Offline
                              Damrak2022
                              @crunchip Hast Du noch irgendeine Idee, denn ich kann Grafana weiterhin nicht aufrufen
                              Mit besten Grüßen
                              Andy
                              crunchipC Thomas BraunT 2 Antworten Letzte Antwort
                                crunchipC Offline
                                crunchipC Offline
                                @damrak2022 ich bin am gucken
                                  Damrak2022D Offline
                                  Damrak2022D Offline
                                  Damrak2022
                                  @crunchip Ich danke Dir. Wenn ich da wieder drauf komme lasse ich erstmal die Finger vom Terminal was Grafana betrifft.
                                  Mit besten Grüßen
                                  Andy
                                    @damrak2022
                                    Ist denn jetzt grafana 8.4.7 die alleinig installierte Version oder spukt da noch was anderes herum?
                                      @damrak2022
                                      Damrak2022D Offline
                                      Damrak2022D Offline
                                      Damrak2022
                                      @thomas-braun Nur 8.4.7, aber ich kann nochmal schauen
                                      pi@homebridge:~ $ apt policy grafana
                                      grafana:
                                        Installed: 8.4.7
                                        Candidate: 8.5.0
                                        Version table:
                                           8.5.0 500
                                              500 https://packages.grafana.com/oss/deb stable/main armhf Packages
                                       *** 8.4.7 500
                                           8.4.6 500
                                           8.4.5 500
                                           8.4.4 500
                                           8.4.3 500
                                           8.4.2 500
                                           8.4.1 500
                                           8.4.0 500
                                           8.3.7 500
                                           8.3.6 500
                                           8.3.5 500
                                           8.3.4 500
                                           8.3.3 500
                                           8.3.2 500
                                           8.3.1 500
                                           8.3.0 500
                                           8.2.7 500
                                           8.2.6 500
                                           8.2.5 500
                                           8.2.4 500
                                           8.2.3 500
                                           8.2.2 500
                                           8.2.1 500
                                           8.2.0 500
                                           8.1.8 500
                                           8.1.7 500
                                           8.1.6 500
                                           8.1.5 500
                                           8.1.4 500
                                           8.1.3 500
                                           8.1.2 500
                                           8.1.1 500
                                           8.1.0 500
                                           8.0.7 500
                                           8.0.6 500
                                           8.0.5 500
                                           8.0.4 500
                                           8.0.3 500
                                           8.0.2 500
                                           8.0.1 500
                                           8.0.0 500
                                           7.5.15 500
                                           7.5.13 500
                                           7.5.12 500
                                           7.5.11 500
                                           7.5.10 500
                                           7.5.9 500
                                           7.5.8 500
                                           7.5.7 500
                                           7.5.6 500
                                           7.5.5 500
                                           7.5.4 500
                                           7.5.3 500
                                           7.5.2 500
                                           7.5.1 500
                                           7.5.0 500
                                           7.4.5 500
                                           7.4.3 500
                                           7.4.2 500
                                           7.4.1 500
                                           7.4.0 500
                                           7.3.10 500
                                           7.3.7 500
                                           7.3.6 500
                                           7.3.5 500
                                           7.3.4 500
                                           7.3.3 500
                                           7.3.2 500
                                           7.3.1 500
                                           7.3.0 500
                                           7.2.2 500
                                           7.2.1 500
                                           7.2.0 500
                                           7.1.5 500
                                           7.1.4 500
                                           7.1.3 500
                                           7.1.2 500
                                           7.1.1 500
                                           7.1.0 500
                                           7.0.6 500
                                           7.0.5 500
                                           7.0.4 500
                                           7.0.3 500
                                           7.0.2 500
                                           7.0.1 500
                                           7.0.0 500
                                           6.7.6 500
                                           6.7.5 500
                                           6.7.4 500
                                           6.7.3 500
                                           6.7.2 500
                                           6.7.1 500
                                           6.7.0 500
                                           6.6.2 500
                                           6.6.1 500
                                           6.6.0 500
                                           6.5.3 500
                                           6.5.2 500
                                           6.5.1 500
                                           6.5.0 500
                                           6.4.5 500
                                           6.4.4 500
                                           6.4.3 500
                                           6.4.2 500
                                           6.4.1 500
                                           6.4.0 500
                                           6.3.7 500
                                           6.3.6 500
                                           6.3.5 500
                                           6.3.4 500
                                           6.3.3 500
                                           6.3.2 500
                                           6.3.1 500
                                           6.3.0 500
                                           6.2.5 500
                                           6.2.4 500
                                           6.2.3 500
                                           6.2.2 500
                                           6.2.1 500
                                           6.2.0 500
                                           6.1.6 500
                                           6.1.5 500
                                           6.1.4 500
                                           6.1.3 500
                                           6.1.2 500
                                           6.1.1 500
                                           6.1.0 500
                                           6.0.2 500
                                           6.0.1 500
                                           6.0.0 500
                                           5.4.5 500
                                           5.4.4 500
                                           5.4.3 500
                                           5.4.2 500
                                           5.4.1 500
                                           5.4.0 500
                                           5.3.4 500
                                           5.3.3 500
                                           5.3.2 500
                                           5.3.1 500
                                           5.3.0 500
                                           5.2.5 500
                                           5.2.4 500
                                           5.2.3 500
                                           5.2.2 500
                                           5.2.1 500
                                           5.2.0 500
                                      pi@homebridge:~ $
                                      Haben die 3* vor der 8.4.7 was zu bedeuten<<ß
                                      Mit besten Grüßen
                                      Andy
                                        grafana:
                                          Installed: 8.4.7
                                          Candidate: 8.5.0
                                          Version table:
                                             8.5.0 500
                                         *** 8.4.7 500
                                             8.4.6 500
                                             8.4.5 500
                                             8.4.4 500
                                             8.4.3 500
                                             8.4.2 500
                                             8.4.1 500
                                             8.4.0 500
                                             8.3.7 500
                                             8.3.6 500
                                             8.3.5 500
                                             8.3.4 500
                                             8.3.3 500
                                             8.3.2 500
                                             8.3.1 500
                                             8.3.0 500
                                             8.2.7 500
                                             8.2.6 500
                                             8.2.5 500
                                             8.2.4 500
                                             8.2.3 500
                                             8.2.2 500
                                             8.2.1 500
                                             8.2.0 500
                                             8.1.8 500
                                             8.1.7 500
                                             8.1.6 500
                                             8.1.5 500
                                             8.1.4 500
                                             8.1.3 500
                                             8.1.2 500
                                             8.1.1 500
                                             8.1.0 500
                                             8.0.7 500
                                             8.0.6 500
                                             8.0.5 500
                                             8.0.4 500
                                             8.0.3 500
                                             8.0.2 500
                                             8.0.1 500
                                             8.0.0 500
                                             7.5.15 500
                                             7.5.13 500
                                             7.5.12 500
                                             7.5.11 500
                                             7.5.10 500
                                             7.5.9 500
                                             7.5.8 500
                                             7.5.7 500
                                             7.5.6 500
                                             7.5.5 500
                                             7.5.4 500
                                             7.5.3 500
                                             7.5.2 500
                                             7.5.1 500
                                             7.5.0 500
                                             7.4.5 500
                                             7.4.3 500
                                             7.4.2 500
                                             7.4.1 500
                                             7.4.0 500
                                             7.3.10 500
                                             7.3.7 500
                                             7.3.6 500
                                             7.3.5 500
                                             7.3.4 500
                                             7.3.3 500
                                             7.3.2 500
                                             7.3.1 500
                                             7.3.0 500
                                             7.2.2 500
                                             7.2.1 500
                                             7.2.0 500
                                             7.1.5 500
                                             7.1.4 500
                                             7.1.3 500
                                             7.1.2 500
                                             7.1.1 500
                                             7.1.0 500
                                             7.0.6 500
                                             7.0.5 500
                                             7.0.4 500
                                             7.0.3 500
                                             7.0.2 500
                                             7.0.1 500
                                             7.0.0 500
                                             6.7.6 500
                                             6.7.5 500
                                             6.7.4 500
                                             6.7.3 500
                                             6.7.2 500
                                             6.7.1 500
                                             6.7.0 500
                                             6.6.2 500
                                             6.6.1 500
                                             6.6.0 500
                                             6.5.3 500
                                             6.5.2 500
                                             6.5.1 500
                                             6.5.0 500
                                             6.4.5 500
                                             6.4.4 500
                                             6.4.3 500
                                             6.4.2 500
                                             6.4.1 500
                                             6.4.0 500
                                             6.3.7 500
                                             6.3.6 500
                                             6.3.5 500
                                             6.3.4 500
                                             6.3.3 500
                                             6.3.2 500
                                             6.3.1 500
                                             6.3.0 500
                                             6.2.5 500
                                             6.2.4 500
                                             6.2.3 500
                                             6.2.2 500
                                             6.2.1 500
                                             6.2.0 500
                                             6.1.6 500
                                             6.1.5 500
                                             6.1.4 500
                                             6.1.3 500
                                             6.1.2 500
                                             6.1.1 500
                                             6.1.0 500
                                             6.0.2 500
                                             6.0.1 500
                                             6.0.0 500
                                             5.4.5 500
                                             5.4.4 500
                                             5.4.3 500
                                             5.4.2 500
                                             5.4.1 500
                                             5.4.0 500
                                             5.3.4 500
                                             5.3.3 500
                                             5.3.2 500
                                             5.3.1 500
                                             5.3.0 500
                                             5.2.5 500
                                             5.2.4 500
                                             5.2.3 500
                                             5.2.2 500
                                             5.2.1 500
                                             5.2.0 500
                                        pi@homebridge:~ $
                                        @damrak2022
                                        Die drei Sterne kennzeichnen die installierte Version.
                                        apt policy grafana*
                                          @damrak2022
                                          apt policy grafana*
                                          Damrak2022D Offline
                                          Damrak2022D Offline
                                          Damrak2022
                                          apt policy grafana*
                                          pi@homebridge:~ $ apt policy grafana*
                                          N: Unable to locate package grafana-rpi_7.4.3_armhf.deb
                                          pi@homebridge:~ $
                                          Mit besten Grüßen
                                          Andy
