  4. Server Cannot start inMem-objects on port 9001
    5.8k
429 Beiträge 40 Kommentatoren 125.6k Aufrufe 39 Beobachtet
    Doggie
    #361
    @thomas-braun o.k. Danke!
    • D Doggie
      #362
      @doggie
      Und was sagt
      iob diag
      nun in der Langfassung?
        @doggie
        Und was sagt
        iob diag
        Doggie
        schrieb am zuletzt editiert von Doggie
        #363
        o.k. das ist echt lang:
        ======== Start marking the full check here =========
        Skript v.2023-01-02
        *** BASE SYSTEM ***
        Model           : Raspberry Pi 4 Model B Rev 1.2
        Architecture:   armv7l
        Docker:         false
        Virtualization: none
        Distributor ID: Raspbian
        Description:    Raspbian GNU/Linux 11 (bullseye)
        Release:        11
        Codename:       bullseye
        PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)"
        NAME="Raspbian GNU/Linux"
        VERSION_ID="11"
        VERSION="11 (bullseye)"
        VERSION_CODENAME=bullseye
        ID=raspbian
        ID_LIKE=debian
        HOME_URL="http://www.raspbian.org/"
        SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
        BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
        Systemuptime and Load:
         19:10:29 up 50 min,  1 user,  load average: 0.31, 0.37, 0.36
        CPU threads: 4
        *** Time and Time Zones ***
        Fri Jan 27 18:10:29 UTC 2023
        Fri Jan 27 19:10:29 CET 2023
        CET +0100
        Europe/Berlin
        *** User and Groups ***
        pi
        /home/pi
        pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
        *** X-Server-Setup ***
        X-Server:       false
        Desktop:
        Terminal:       tty
        Boot Target:    multi-user.target
        *** MEMORY ***
        Mem:            3.8G        1.3G        2.2G        1.0M        334M        2.8G
        Swap:            99M          0B         99M
        Total:          3.9G        1.3G        2.3G
                 3838 M total memory
                 1280 M used memory
                  151 M active memory
                 1350 M inactive memory
                 2224 M free memory
                   53 M buffer memory
                  281 M swap cache
                   99 M total swap
                    0 M used swap
                   99 M free swap
        *** FILESYSTEM ***
        /dev/root      ext4       59G  6.5G   50G  12% /
        devtmpfs       devtmpfs  1.8G     0  1.8G   0% /dev
        tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
        tmpfs          tmpfs     768M  1.2M  767M   1% /run
        /dev/sda1      exfat     7.5G  7.5G  8.1M 100% /mnt/usb0
        /dev/mmcblk0p1 vfat      255M   50M  206M  20% /boot
        tmpfs          tmpfs     384M   16K  384M   1% /run/user/1000
        Messages in dmesg:
        [Fri Jan 27 18:20:15 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:A6:B0:73 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=4b9b7d8f-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
        [Fri Jan 27 18:20:16 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
        [Fri Jan 27 18:20:16 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
        [Fri Jan 27 18:20:19 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null). Quota mode: none.
        Show mounted filesystems (real ones only):
        TARGET      SOURCE         FSTYPE OPTIONS
        /           /dev/mmcblk0p2 ext4   rw,noatime
        |-/mnt/usb0 /dev/sda1      exfat  rw,nosuid,nodev,noexec,relatime,fmask=0000,dmask=0000,allow_utime=0022,iocharset=utf8,errors=remount-ro
        `-/boot     /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
        /var:
        1.2G    /var/
        860M    /var/log
        841M    /var/log/journal/a67c6b0af55647aea7f6b6889796f9aa
        143M    /var/cache
        /opt/iobroker/backups:
        85M     /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        319M    /opt/iobroker/iobroker-data/
        269M    /opt/iobroker/iobroker-data/files
        72M     /opt/iobroker/iobroker-data/files/telegram.admin
        51M     /opt/iobroker/iobroker-data/files/javascript.admin
        48M     /opt/iobroker/iobroker-data/files/telegram.admin/custom/static/js
        33M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.10538062.js.map
        19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.904d455f.js.map
        15M     /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js.map
        12M     /opt/iobroker/iobroker-data/objects.jsonl
        9.7M    /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.bbfeb1bf.js.map
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v16.19.0
        /usr/bin/node           v16.19.0
        /usr/bin/npm            8.19.3
        /usr/bin/npx            8.19.3
        nodejs:
          Installed: 16.19.0-deb-1nodesource1
          Candidate: 16.19.0-deb-1nodesource1
          Version table:
         *** 16.19.0-deb-1nodesource1 500
                500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
                100 /var/lib/dpkg/status
             12.22.12~dfsg-1~deb11u3 500
                500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Core adapters versions
        js-controller:  4.0.24
        admin:          6.3.5
        javascript:     6.1.4
        Adapters from github:   0
        Adapter State
        + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
        + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
        + system.adapter.ble.0                    : ble                   : raspberrypi                              -  enabled
        + system.adapter.chromecast.0             : chromecast            : raspberrypi                              -  enabled
        + system.adapter.cloud.0                  : cloud                 : raspberrypi                              -  enabled
          system.adapter.devices.0                : devices               : raspberrypi                              -  enabled
        + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
        + system.adapter.history.0                : history               : raspberrypi                              -  enabled
        + system.adapter.info.0                   : info                  : raspberrypi                              -  enabled
        + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
        + system.adapter.jarvis.0                 : jarvis                : raspberrypi                              -  enabled
        + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
        + system.adapter.mqtt-client.0            : mqtt-client           : raspberrypi                              -  enabled, port: 1883
        + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1883, bind: 192.168.178.41
          system.adapter.net-tools.0              : net-tools             : raspberrypi                              - disabled
        + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
        + system.adapter.samsung.0                : samsung               : raspberrypi                              -  enabled
        + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
        + system.adapter.smartthings.0            : smartthings           : raspberrypi                              -  enabled
        + system.adapter.telegram.0               : telegram              : raspberrypi                              -  enabled, port: 8443, bind: 0.0.0.0
        + system.adapter.text2command.0           : text2command          : raspberrypi                              -  enabled
        + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
        + system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled
          system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
        + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
        + instance is alive
        ioBroker-Repositories
        Active repo(s): stable
        Installed ioBroker-Instances
        Used repository: stable
        Cannot download repository hash file from "http://download.iobroker.net/sources-dist-hash.json": timeout of 10000ms exceeded
        Cannot download repository file from "http://download.iobroker.net/sources-dist.json": timeout of 10000ms exceeded
        Adapter    "admin"        : 6.3.5    , installed 6.3.5
        Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
        Adapter    "backitup"     : 2.5.10   , installed 2.5.10
        Adapter    "ble"          : 0.13.0   , installed 0.13.0
        Adapter    "chromecast"   : 2.3.1    , installed 2.3.1
        Adapter    "cloud"        : 4.3.0    , installed 4.3.0
        Adapter    "devices"      : 1.1.2    , installed 1.1.2
        Adapter    "discovery"    : 3.1.0    , installed 3.1.0
        Adapter    "fritzbox"     : 0.2.1    , installed 0.2.1
        Adapter    "fritzdect"    : 2.2.6    , installed 2.2.6
        Adapter    "history"      : 2.2.4    , installed 2.2.4
        Adapter    "info"         : 1.9.19   , installed 1.9.19
        Adapter    "iot"          : 1.14.2   , installed 1.14.2
        Adapter    "jarvis"       : 3.1.2    , installed 3.1.2
        Adapter    "javascript"   : 6.1.4    , installed 6.1.4
        Controller "js-controller": 4.0.24   , installed 4.0.24
        Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
        Adapter    "mqtt-client"  : 1.6.3    , installed 1.6.3
        Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
        Adapter    "ping"         : 1.5.3    , installed 1.5.3
        Adapter    "samsung"      : 0.5.11   , installed 0.5.11
        Adapter    "shelly"       : 6.0.0    , installed 6.0.0
        Adapter    "smartthings"  : 0.0.4    , installed 0.0.4
        Adapter    "socketio"     : 4.2.0    , installed 4.2.0
        Adapter    "telegram"     : 1.15.2   , installed 1.15.2
        Adapter    "text2command" : 2.3.0    , installed 2.3.0
        Adapter    "tr-064"       : 4.2.17   , installed 4.2.17
        Adapter    "tuya"         : 3.12.1   , installed 3.12.1
        Adapter    "web"          : 4.3.0    , installed 4.3.0
        Adapter    "ws"           : 1.3.0    , installed 1.3.0
        Adapter    "zigbee"       : 1.8.10   , installed 1.8.10
        Objects and States
        Objects:        2266
        States:         1820
        Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
        Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
        Hit:3 https://deb.nodesource.com/node_16.x bullseye InRelease
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 192.168.178.41:1883     0.0.0.0:*               LISTEN      1001       17603      1166/io.mqtt.0
        tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       18028      1411/io.jarvis.0
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13055      555/sshd: /usr/sbin
        tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          14282      520/cupsd
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       11055      522/iobroker.js-con
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       14329      522/iobroker.js-con
        tcp6       0      0 :::22                   :::*                    LISTEN      0          13057      555/sshd: /usr/sbin
        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       17958      1351/io.web.0
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       13237      685/io.admin.0
        tcp6       0      0 ::1:631                 :::*                    LISTEN      0          14281      520/cupsd
        udp        0      0 0.0.0.0:40825           0.0.0.0:*                           108        10701      347/avahi-daemon: r
        udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       15752      1275/io.tuya.0
        udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       15753      1275/io.tuya.0
        udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       14914      1215/io.shelly.0
        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13140      472/dhcpcd
        udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          13129      610/cups-browsed
        udp        0      0 192.168.178.29:123      0.0.0.0:*                           116        14608      554/ntpd
        udp        0      0 192.168.178.41:123      0.0.0.0:*                           116        14551      554/ntpd
        udp        0      0 127.0.0.1:123           0.0.0.0:*                           0          10981      554/ntpd
        udp        0      0 0.0.0.0:123             0.0.0.0:*                           0          10977      554/ntpd
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       15969      1381/io.chromecast.
        udp        0      0 192.168.178.29:5353     0.0.0.0:*                           1001       14748      1146/io.tr-064.0
        udp        0      0 192.168.178.41:5353     0.0.0.0:*                           1001       14747      1146/io.tr-064.0
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        10699      347/avahi-daemon: r
        udp6       0      0 :::50030                :::*                                108        10702      347/avahi-daemon: r
        udp6       0      0 :::546                  :::*                                0          13153      472/dhcpcd
        udp6       0      0 2001:9e8:6269:8300::123 :::*                                116        14670      554/ntpd
        udp6       0      0 2001:9e8:6269:8300::123 :::*                                116        14649      554/ntpd
        udp6       0      0 fe80::4017:de71:8ff:123 :::*                                116        14502      554/ntpd
        udp6       0      0 fe80::cb6f:a96d:5ee:123 :::*                                116        11206      554/ntpd
        udp6       0      0 ::1:123                 :::*                                0          10983      554/ntpd
        udp6       0      0 :::123                  :::*                                0          10974      554/ntpd
        udp6       0      0 :::5353                 :::*                                108        10700      347/avahi-daemon: r
        2023-01-27 18:21:50.553  - warn: jarvis.0 (1411) Alias alias.0.Aussenbereich.Aussensteckdose.SET has no target 12
        2023-01-27 18:21:50.555  - warn: jarvis.0 (1411) Alias alias.0.Aussenbereich.Aussensteckdose.AVAILABLE has no target 12
        2023-01-27 18:21:52.523  - info: text2command.0 (1426) starting. Version 2.3.0 in /opt/iobroker/node_modules/iobroker.text2command, node: v16.19.0, js-controller: 4.0.24
        2023-01-27 18:21:54.444  - info: host.raspberrypi instance system.adapter.info.0 started with pid 1450
        2023-01-27 18:21:58.345  - info: host.raspberrypi instance system.adapter.iot.0 started with pid 1473
        2023-01-27 18:21:59.327  - info: info.0 (1450) starting. Version 1.9.19 in /opt/iobroker/node_modules/iobroker.info, node: v16.19.0, js-controller: 4.0.24
        2023-01-27 18:21:59.498  - info: info.0 (1450) Reading/updating systemdata.
        2023-01-27 18:22:00.804  - info: info.0 (1450) cpu Temp res = {"main":39.92,"cores":[],"max":39.92,"socket":[],"chipset":null}
        2023-01-27 18:22:01.852  - info: iot.0 (1473) starting. Version 1.14.2 in /opt/iobroker/node_modules/iobroker.iot, node: v16.19.0, js-controller: 4.0.24
        2023-01-27 18:22:01.991  - info: iot.0 (1473) Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
        2023-01-27 18:22:02.380  - info: host.raspberrypi instance system.adapter.smartthings.0 started with pid 1638
        2023-01-27 18:22:02.896  - info: iot.0 (1473) Connection changed: connect
        2023-01-27 18:22:05.379  - info: smartthings.0 (1638) starting. Version 0.0.4 in /opt/iobroker/node_modules/iobroker.smartthings, node: v16.19.0, js-controller: 4.0.24
        2023-01-27 18:22:05.727  - error: smartthings.0 (1638) AxiosError: Request failed with status code 403
        2023-01-27 18:22:05.728  - error: smartthings.0 (1638) ""
        2023-01-27 18:22:06.333  - info: host.raspberrypi instance system.adapter.ble.0 started with pid 1657
        2023-01-27 18:22:08.944  - info: ble.0 (1657) starting. Version 0.13.0 in /opt/iobroker/node_modules/iobroker.ble, node: v16.19.0, js-controller: 4.0.24
        2023-01-27 18:22:09.090  - info: ble.0 (1657) loaded plugins: Xiaomi, mi-flora, ruuvi-tag, _default
        2023-01-27 18:22:09.092  - info: ble.0 (1657) enabled plugins: _default
        2023-01-27 18:22:09.095  - info: ble.0 (1657) monitored services:
        2023-01-27 18:22:09.176  - info: ble.0 (1657) starting scanner process...
        2023-01-27 18:22:09.843  - info: ble.0 (1657) starting scan for services []
        2023-01-27 18:22:15.400  - info: cloud.0 (1396) Trying to connect as system.user.admin to cloud
        2023-01-27 18:22:15.605  - info: cloud.0 (1396) Connection changed: connect
        2023-01-27 18:52:54.695  - warn: zigbee.0 (1290) DeviceAvailability:Stopping to ping 0xf0d1b8be2408070d A60 DIM T after 4 ping attempts
        iob diag has finished.
        Das Update war ja sicher nötig.
        Das eigentliche Problem - die Nicht-Erreichbarkeit im Browser- besteht aber nach wie vor.
        Ich bin für weitere Vorschläge dankbar.
        Der ioBroker scheint aber zu funktionieren. Er hat die Leuchten, die er schalten soll angeschaltet.
        Thomas BraunT apollon77A 2 Antworten Letzte Antwort
        • D Doggie
          Skript v.2023-01-02
          *** BASE SYSTEM ***
          Docker:         false
          Release:        11
          Codename:       bullseye
          VERSION_ID="11"
          ID=raspbian
          ID_LIKE=debian
          CPU threads: 4
          CET +0100
          Europe/Berlin
          pi
          /home/pi
          X-Server:       false
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Swap:            99M          0B         99M
                   3838 M total memory
                   1280 M used memory
                    151 M active memory
                   2224 M free memory
                     53 M buffer memory
                    281 M swap cache
                     99 M total swap
                      0 M used swap
                     99 M free swap
          *** FILESYSTEM ***
          Messages in dmesg:
          /var:
          1.2G    /var/
          860M    /var/log
          143M    /var/cache
          /usr/bin/npm            8.19.3
          /usr/bin/npx            8.19.3
          nodejs:
            Version table:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          admin:          6.3.5
          javascript:     6.1.4
          Adapter State
          + instance is alive
          Objects and States
          Objects:        2266
          States:         1820
          Pending Updates: 0
          #364
          @doggie
          Deim Gerät /dev/sda1 ist rappelvoll.
          Und mit dem Netzwerk stimmt wohl auch irgendwie was nicht.
            Doggie
            #365
            @thomas-braun ups... das ist mir garnicht aufgefallen. Das ist der USB-Stick für die Backups.
            Dann werd ich mal schauen, wie ich die ältesten Backups lösche.
              @doggie
              Doggie
              #366
              @thomas-braun Tja das Netzwerk...ich frag mich, wie ich da weiter komme.
              • D Doggie
                Skript v.2023-01-02
                *** BASE SYSTEM ***
                Docker:         false
                Release:        11
                Codename:       bullseye
                VERSION_ID="11"
                ID=raspbian
                ID_LIKE=debian
                CPU threads: 4
                CET +0100
                Europe/Berlin
                pi
                /home/pi
                X-Server:       false
                Desktop:
                Terminal:       tty
                *** MEMORY ***
                Swap:            99M          0B         99M
                         3838 M total memory
                         1280 M used memory
                          151 M active memory
                         2224 M free memory
                           53 M buffer memory
                          281 M swap cache
                           99 M total swap
                            0 M used swap
                           99 M free swap
                *** FILESYSTEM ***
                Messages in dmesg:
                /var:
                1.2G    /var/
                860M    /var/log
                143M    /var/cache
                /usr/bin/npm            8.19.3
                /usr/bin/npx            8.19.3
                nodejs:
                  Version table:
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                admin:          6.3.5
                javascript:     6.1.4
                Adapter State
                + instance is alive
                Objects and States
                Objects:        2266
                States:         1820
                Pending Updates: 0
                #367
                @doggie na dann schau doch mal ins log. Dann scheint ja der Admin Adapter ein Problem beim
                Starten zu haben - was aber dann jetzt ggf ein anderer Fehler ist als zu Beginn (oder du hast uns verwirrt in dem thread hier)
                  Doggie
                  #368
                  @apollon77 verwirrt habe ich bestimmt niemanden. Zumindest nicht absichtlich, höchstens aus Unwissenheit.
                    Doggie
                    #369
                    @apollon77 das war mal das log, als der iobroker am 23.1.2023 zum erstenmal im Browser nicht mehr erreichbar war:
                    code_text
                    ```pi@raspberrypi:/opt/iobroker $ node node_modules/iobroker.js-controller/controller.js --logs
                    2023-01-26 20:18:32.217  - info: host.raspberrypi iobroker.js-controller version 4.0.24 js-controller starting
                    2023-01-26 20:18:32.226  - info: host.raspberrypi Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                    2023-01-26 20:18:32.228  - info: host.raspberrypi hostname: raspberrypi, node: v16.17.0
                    2023-01-26 20:18:32.230  - info: host.raspberrypi ip addresses: 192.168.178.41 2001:9e8:6256:ee00:2a69:6134:2330:b0b3 fe80::cb6f:a96d:5ee2:712a 192.168.178.29 2001:9e8:6256:ee00:20a0:2b27:ab07:1ca7 fe80::4017:de71:8ffb:880a
                    2023-01-26 20:18:34.348  - error: host.raspberrypi-Server Cannot start inMem-objects on port 9001: Failed to lock DB file "/opt/iobroker/iobroker-data/objects.jsonl"!```
                    code_text
                    was jetzt drinsteht, schau ich noch mal
                    Ergänzung: Nach den Updates steht noch der gleiche Fehler drin. Es hat sich also nichts geändert. Und das Sympton -keine Erreichbarkeit im Browser- ist auch das gleiche
                    • D Doggie
                      code_text
                      code_text
                      #370
                      @doggie also wenn es dieser Fehler ist der jetzt im log ist dann dürfte gar nichts funktionieren. Das passt nicht zusammen was du schreibst.
                      Reboote mal den Host und schau dann.
                      • apollon77A apollon77
                        Doggie
                        #371
                        @apollon77 Der angegebene Fehler steht ja nicht im "Allgemeinen Log", sondern erscheint nur nach Eingabe von
                        code_text
                        ```pi@raspberrypi:/opt/iobroker $ node node_modules/iobroker.js-controller/controller.js --logs```
                        code_text
                        Bis auf die Erreichbarkeit im Browser funktioniert der ioBrowser, wie ich schon schrieb. Er schaltet z.B. alles was er soll. Den o.a. Befehl habe ich von einer Seite in ioBroker.net (Thema "ioBoker läuft nicht mehr). Möglicherweise ist dieser Befehl nicht so zielführend, wie ich dachte.
                        Im allgemeinen Log sehe ich überhaupt keine Fehlermeldungen.
                        Auch wenn es erstmal nicht erklärbar ist: Es ist wie es ist.
                        Gibt es noch Ansätze oder Ideen?
                        Was mir noch aufgefallen ist:
                        code_text
                        ```system.adapter.net-tools.0              : net-tools             : raspberrypi                              - disabled```
                        code_text
                        Thomas BraunT F 2 Antworten Letzte Antwort
                        • D Doggie
                          code_text
                          code_text
                          code_text
                          code_text
                          #372
                          @doggie sagte in Server Cannot start inMem-objects on port 9001:
                          Der Befehl ist soweit ich das sehe obsolet.
                            Doggie
                            #373
                            @thomas-braun Dann wäre es gut, wenn ein Admin den von der angegebenen ioBroker.net Seite
                            entfernen würde. Leute wie ich fallen nur darauf rein.
                            • D Doggie
                              wendy2702W Offline
                              wendy2702W Offline
                              wendy2702
                              #374
                              wo genau steht der denn?
                              • wendy2702W wendy2702
                                Doggie
                                #375
                                @wendy2702 Seite: https://www.iobroker.net/docu/index-26.htm?page_id=3928&lang=de#installAdapter
                                Thema "IoBroker läuft nicht mehr"
                                "Falls immer noch nicht läuft oder es kommen Fehlermeldungen, dann kann man versuchen controller manuell zu starten...."
                                • D Doggie
                                  code_text
                                  code_text
                                  code_text
                                  code_text
                                  F Online
                                  F Online
                                  fastfoot
                                  #376
                                  ich sehe da 2 ip adressen, evtl ist der iobroke Admin unter der anderen Adresse erreichbar?
                                  192.168.178.41 und 192.168.178.29
                                  iobroker läuft unter Docker auf Windows (WSL2)
                                    Doggie
                                    #377
                                    @fastfoot Nein, ist er leider nicht.
                                    Auch in der Fritzbox stehen merkwürdigerweise die beiden Adressen.
                                    Die 192.168.178.29 unter WLAN, aber auch unter LAN. Die 41 aber auch unter LAN.
                                    • D Doggie
                                      #378
                                      Wo genau? Die beiden Interfaces sollten nicht die gleiche IP haben.
                                        Doggie
                                        #379
                                        @thomas-braun Also der Raspberry hat unter WLAN die Adresse 29 und unter LAN die 41.
                                        War möglicherweise ein Fehler in der Fritzbox. In der Liste waren die Adressen gleich, aber bei den Einzelheiten erschienen die richtigen Adressen
                                          Doggie
                                          #380
                                          Nach einigem Probieren kann ich den ioBroker jetzt im Browser erreichen.
                                          Ich musste nach der Adresseingabe den Port 8081 angeben und das "https" löschen.
                                          Irgendwie hat der Browser die falsche Angabe automatisch eingetragen.
                                          schon komisch: Ich hatte es mit 3 verschiedenen Browsern versucht. Oder die gemachten Änderungen haben doch etwas behoben und ich habe es nicht bemerkt durch die Fehleingabe im Browser.
                                          Manchmal sieht man den Wald vor lauter Bäumen nicht.
                                          Danke an alle, die sich um mein Problem bemüht haben.
