  4. Server Cannot start inMem-objects on port 9001
429 Beiträge 40 Kommentatoren 132.6k Aufrufe 39 Beobachtet
    @doggie
    Und was sagt
    iob diag
    nun in der Langfassung?
    Doggie
    schrieb am zuletzt editiert von Doggie
    #363
    o.k. das ist echt lang:
    Skript v.2023-01-02
    *** BASE SYSTEM ***
    Model           : Raspberry Pi 4 Model B Rev 1.2
    Architecture:   armv7l
    Docker:         false
    Virtualization: none
    Distributor ID: Raspbian
    Description:    Raspbian GNU/Linux 11 (bullseye)
    Release:        11
    Codename:       bullseye
    PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)"
    NAME="Raspbian GNU/Linux"
    VERSION_ID="11"
    VERSION="11 (bullseye)"
    VERSION_CODENAME=bullseye
    ID=raspbian
    ID_LIKE=debian
    HOME_URL="http://www.raspbian.org/"
    SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
    BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
    Systemuptime and Load:
     19:10:29 up 50 min,  1 user,  load average: 0.31, 0.37, 0.36
    CPU threads: 4
    *** Time and Time Zones ***
    Fri Jan 27 18:10:29 UTC 2023
    Fri Jan 27 19:10:29 CET 2023
    CET +0100
    Europe/Berlin
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:            3.8G        1.3G        2.2G        1.0M        334M        2.8G
    Swap:            99M          0B         99M
    Total:          3.9G        1.3G        2.3G
             3838 M total memory
             1280 M used memory
              151 M active memory
             1350 M inactive memory
             2224 M free memory
               53 M buffer memory
              281 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    *** FILESYSTEM ***
    /dev/root      ext4       59G  6.5G   50G  12% /
    devtmpfs       devtmpfs  1.8G     0  1.8G   0% /dev
    tmpfs          tmpfs     768M  1.2M  767M   1% /run
    /dev/sda1      exfat     7.5G  7.5G  8.1M 100% /mnt/usb0
    /dev/mmcblk0p1 vfat      255M   50M  206M  20% /boot
    tmpfs          tmpfs     384M   16K  384M   1% /run/user/1000
    Messages in dmesg:
    [Fri Jan 27 18:20:15 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:A6:B0:73 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=4b9b7d8f-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
    [Fri Jan 27 18:20:16 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
    [Fri Jan 27 18:20:16 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Fri Jan 27 18:20:19 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null). Quota mode: none.
    TARGET      SOURCE         FSTYPE OPTIONS
    /           /dev/mmcblk0p2 ext4   rw,noatime
    |-/mnt/usb0 /dev/sda1      exfat  rw,nosuid,nodev,noexec,relatime,fmask=0000,dmask=0000,allow_utime=0022,iocharset=utf8,errors=remount-ro
    `-/boot     /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    1.2G    /var/
    860M    /var/log
    841M    /var/log/journal/a67c6b0af55647aea7f6b6889796f9aa
    143M    /var/cache
    /opt/iobroker/backups:
    85M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    319M    /opt/iobroker/iobroker-data/
    269M    /opt/iobroker/iobroker-data/files
    72M     /opt/iobroker/iobroker-data/files/telegram.admin
    51M     /opt/iobroker/iobroker-data/files/javascript.admin
    48M     /opt/iobroker/iobroker-data/files/telegram.admin/custom/static/js
    33M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.10538062.js.map
    19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.904d455f.js.map
    15M     /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js.map
    12M     /opt/iobroker/iobroker-data/objects.jsonl
    9.7M    /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.bbfeb1bf.js.map
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v16.19.0
    /usr/bin/node           v16.19.0
    /usr/bin/npm            8.19.3
    /usr/bin/npx            8.19.3
    nodejs:
      Installed: 16.19.0-deb-1nodesource1
      Candidate: 16.19.0-deb-1nodesource1
      Version table:
     *** 16.19.0-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
         12.22.12~dfsg-1~deb11u3 500
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  4.0.24
    admin:          6.3.5
    javascript:     6.1.4
    Adapters from github:   0
    Adapter State
    + system.adapter.ble.0                    : ble                   : raspberrypi                              -  enabled
    + system.adapter.chromecast.0             : chromecast            : raspberrypi                              -  enabled
    + system.adapter.cloud.0                  : cloud                 : raspberrypi                              -  enabled
      system.adapter.devices.0                : devices               : raspberrypi                              -  enabled
    + system.adapter.history.0                : history               : raspberrypi                              -  enabled
    + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
    + system.adapter.jarvis.0                 : jarvis                : raspberrypi                              -  enabled
    + system.adapter.mqtt-client.0            : mqtt-client           : raspberrypi                              -  enabled, port: 1883
    + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1883, bind: 192.168.178.41
      system.adapter.net-tools.0              : net-tools             : raspberrypi                              - disabled
    + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
    + system.adapter.samsung.0                : samsung               : raspberrypi                              -  enabled
    + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.smartthings.0            : smartthings           : raspberrypi                              -  enabled
    + system.adapter.text2command.0           : text2command          : raspberrypi                              -  enabled
    + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
    + system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled
    + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Cannot download repository hash file from "http://download.iobroker.net/sources-dist-hash.json": timeout of 10000ms exceeded
    Cannot download repository file from "http://download.iobroker.net/sources-dist.json": timeout of 10000ms exceeded
    Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
    Adapter    "backitup"     : 2.5.10   , installed 2.5.10
    Adapter    "ble"          : 0.13.0   , installed 0.13.0
    Adapter    "chromecast"   : 2.3.1    , installed 2.3.1
    Adapter    "cloud"        : 4.3.0    , installed 4.3.0
    Adapter    "devices"      : 1.1.2    , installed 1.1.2
    Adapter    "fritzbox"     : 0.2.1    , installed 0.2.1
    Adapter    "fritzdect"    : 2.2.6    , installed 2.2.6
    Adapter    "history"      : 2.2.4    , installed 2.2.4
    Adapter    "info"         : 1.9.19   , installed 1.9.19
    Adapter    "iot"          : 1.14.2   , installed 1.14.2
    Adapter    "jarvis"       : 3.1.2    , installed 3.1.2
    Adapter    "javascript"   : 6.1.4    , installed 6.1.4
    Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
    Adapter    "mqtt-client"  : 1.6.3    , installed 1.6.3
    Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
    Adapter    "samsung"      : 0.5.11   , installed 0.5.11
    Adapter    "shelly"       : 6.0.0    , installed 6.0.0
    Adapter    "smartthings"  : 0.0.4    , installed 0.0.4
    Adapter    "telegram"     : 1.15.2   , installed 1.15.2
    Adapter    "text2command" : 2.3.0    , installed 2.3.0
    Adapter    "tr-064"       : 4.2.17   , installed 4.2.17
    Adapter    "tuya"         : 3.12.1   , installed 3.12.1
    Adapter    "zigbee"       : 1.8.10   , installed 1.8.10
    Objects and States
    Objects:        2266
    States:         1820
    Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:3 https://deb.nodesource.com/node_16.x bullseye InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 192.168.178.41:1883     0.0.0.0:*               LISTEN      1001       17603      1166/io.mqtt.0
    tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       18028      1411/io.jarvis.0
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13055      555/sshd: /usr/sbin
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          14282      520/cupsd
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       11055      522/iobroker.js-con
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       14329      522/iobroker.js-con
    tcp6       0      0 :::22                   :::*                    LISTEN      0          13057      555/sshd: /usr/sbin
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       17958      1351/io.web.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       13237      685/io.admin.0
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          14281      520/cupsd
    udp        0      0 0.0.0.0:40825           0.0.0.0:*                           108        10701      347/avahi-daemon: r
    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       15752      1275/io.tuya.0
    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       15753      1275/io.tuya.0
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       14914      1215/io.shelly.0
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13140      472/dhcpcd
    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          13129      610/cups-browsed
    udp        0      0 192.168.178.29:123      0.0.0.0:*                           116        14608      554/ntpd
    udp        0      0 192.168.178.41:123      0.0.0.0:*                           116        14551      554/ntpd
    udp        0      0 127.0.0.1:123           0.0.0.0:*                           0          10981      554/ntpd
    udp        0      0 0.0.0.0:123             0.0.0.0:*                           0          10977      554/ntpd
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       15969      1381/io.chromecast.
    udp        0      0 192.168.178.29:5353     0.0.0.0:*                           1001       14748      1146/io.tr-064.0
    udp        0      0 192.168.178.41:5353     0.0.0.0:*                           1001       14747      1146/io.tr-064.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        10699      347/avahi-daemon: r
    udp6       0      0 :::50030                :::*                                108        10702      347/avahi-daemon: r
    udp6       0      0 :::546                  :::*                                0          13153      472/dhcpcd
    udp6       0      0 2001:9e8:6269:8300::123 :::*                                116        14670      554/ntpd
    udp6       0      0 2001:9e8:6269:8300::123 :::*                                116        14649      554/ntpd
    udp6       0      0 fe80::4017:de71:8ff:123 :::*                                116        14502      554/ntpd
    udp6       0      0 fe80::cb6f:a96d:5ee:123 :::*                                116        11206      554/ntpd
    udp6       0      0 ::1:123                 :::*                                0          10983      554/ntpd
    udp6       0      0 :::123                  :::*                                0          10974      554/ntpd
    udp6       0      0 :::5353                 :::*                                108        10700      347/avahi-daemon: r
    2023-01-27 18:21:50.553  - warn: jarvis.0 (1411) Alias alias.0.Aussenbereich.Aussensteckdose.SET has no target 12
    2023-01-27 18:21:50.555  - warn: jarvis.0 (1411) Alias alias.0.Aussenbereich.Aussensteckdose.AVAILABLE has no target 12
    2023-01-27 18:21:52.523  - info: text2command.0 (1426) starting. Version 2.3.0 in /opt/iobroker/node_modules/iobroker.text2command, node: v16.19.0, js-controller: 4.0.24
    2023-01-27 18:21:54.444  - info: host.raspberrypi instance system.adapter.info.0 started with pid 1450
    2023-01-27 18:21:58.345  - info: host.raspberrypi instance system.adapter.iot.0 started with pid 1473
    2023-01-27 18:21:59.327  - info: info.0 (1450) starting. Version 1.9.19 in /opt/iobroker/node_modules/iobroker.info, node: v16.19.0, js-controller: 4.0.24
    2023-01-27 18:21:59.498  - info: info.0 (1450) Reading/updating systemdata.
    2023-01-27 18:22:00.804  - info: info.0 (1450) cpu Temp res = {"main":39.92,"cores":[],"max":39.92,"socket":[],"chipset":null}
    2023-01-27 18:22:01.852  - info: iot.0 (1473) starting. Version 1.14.2 in /opt/iobroker/node_modules/iobroker.iot, node: v16.19.0, js-controller: 4.0.24
    2023-01-27 18:22:01.991  - info: iot.0 (1473) Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
    2023-01-27 18:22:02.380  - info: host.raspberrypi instance system.adapter.smartthings.0 started with pid 1638
    2023-01-27 18:22:02.896  - info: iot.0 (1473) Connection changed: connect
    2023-01-27 18:22:05.379  - info: smartthings.0 (1638) starting. Version 0.0.4 in /opt/iobroker/node_modules/iobroker.smartthings, node: v16.19.0, js-controller: 4.0.24
    2023-01-27 18:22:05.727  - error: smartthings.0 (1638) AxiosError: Request failed with status code 403
    2023-01-27 18:22:05.728  - error: smartthings.0 (1638) ""
    2023-01-27 18:22:06.333  - info: host.raspberrypi instance system.adapter.ble.0 started with pid 1657
    2023-01-27 18:22:08.944  - info: ble.0 (1657) starting. Version 0.13.0 in /opt/iobroker/node_modules/iobroker.ble, node: v16.19.0, js-controller: 4.0.24
    2023-01-27 18:22:09.090  - info: ble.0 (1657) loaded plugins: Xiaomi, mi-flora, ruuvi-tag, _default
    2023-01-27 18:22:09.092  - info: ble.0 (1657) enabled plugins: _default
    2023-01-27 18:22:09.095  - info: ble.0 (1657) monitored services:
    2023-01-27 18:22:09.176  - info: ble.0 (1657) starting scanner process...
    2023-01-27 18:22:09.843  - info: ble.0 (1657) starting scan for services []
    2023-01-27 18:22:15.400  - info: cloud.0 (1396) Trying to connect as system.user.admin to cloud
    2023-01-27 18:22:15.605  - info: cloud.0 (1396) Connection changed: connect
    2023-01-27 18:52:54.695  - warn: zigbee.0 (1290) DeviceAvailability:Stopping to ping 0xf0d1b8be2408070d A60 DIM T after 4 ping attempts
    iob diag has finished.
    Das Update war ja sicher nötig.
    Das eigentliche Problem - die Nicht-Erreichbarkeit im Browser- besteht aber nach wie vor.
    Ich bin für weitere Vorschläge dankbar.
    Der ioBroker scheint aber zu funktionieren. Er hat die Leuchten, die er schalten soll angeschaltet.
    Thomas BraunT apollon77A 2 Antworten Letzte Antwort
    • D Doggie
      Skript v.2023-01-02
      *** BASE SYSTEM ***
      Docker:         false
      Release:        11
      Codename:       bullseye
      VERSION_ID="11"
      ID=raspbian
      ID_LIKE=debian
      CPU threads: 4
      CET +0100
      Europe/Berlin
      pi
      /home/pi
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:            99M          0B         99M
               3838 M total memory
               1280 M used memory
                151 M active memory
               2224 M free memory
                 53 M buffer memory
                281 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      *** FILESYSTEM ***
      Messages in dmesg:
      /var:
      1.2G    /var/
      860M    /var/log
      143M    /var/cache
      /usr/bin/npm            8.19.3
      /usr/bin/npx            8.19.3
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          6.3.5
      javascript:     6.1.4
      Adapter State
      + instance is alive
      Objects and States
      Objects:        2266
      States:         1820
      Pending Updates: 0
      #364
      @doggie
      Deim Gerät /dev/sda1 ist rappelvoll.
      Und mit dem Netzwerk stimmt wohl auch irgendwie was nicht.
        Doggie
        #365
        @thomas-braun ups... das ist mir garnicht aufgefallen. Das ist der USB-Stick für die Backups.
        Dann werd ich mal schauen, wie ich die ältesten Backups lösche.
          @doggie
          Doggie
          #366
          @thomas-braun Tja das Netzwerk...ich frag mich, wie ich da weiter komme.
          • D Doggie
            Skript v.2023-01-02
            *** BASE SYSTEM ***
            Docker:         false
            Release:        11
            Codename:       bullseye
            VERSION_ID="11"
            ID=raspbian
            ID_LIKE=debian
            CPU threads: 4
            CET +0100
            Europe/Berlin
            pi
            /home/pi
            X-Server:       false
            Desktop:
            Terminal:       tty
            *** MEMORY ***
            Swap:            99M          0B         99M
                     3838 M total memory
                     1280 M used memory
                      151 M active memory
                     2224 M free memory
                       53 M buffer memory
                      281 M swap cache
                       99 M total swap
                        0 M used swap
                       99 M free swap
            *** FILESYSTEM ***
            Messages in dmesg:
            /var:
            1.2G    /var/
            860M    /var/log
            143M    /var/cache
            /usr/bin/npm            8.19.3
            /usr/bin/npx            8.19.3
            nodejs:
              Version table:
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            admin:          6.3.5
            javascript:     6.1.4
            Adapter State
            + instance is alive
            Objects and States
            Objects:        2266
            States:         1820
            Pending Updates: 0
            #367
            @doggie na dann schau doch mal ins log. Dann scheint ja der Admin Adapter ein Problem beim
            Starten zu haben - was aber dann jetzt ggf ein anderer Fehler ist als zu Beginn (oder du hast uns verwirrt in dem thread hier)
              Doggie
              #368
              @apollon77 verwirrt habe ich bestimmt niemanden. Zumindest nicht absichtlich, höchstens aus Unwissenheit.
                Doggie
                #369
                @apollon77 das war mal das log, als der iobroker am 23.1.2023 zum erstenmal im Browser nicht mehr erreichbar war:
                code_text
                ```pi@raspberrypi:/opt/iobroker $ node node_modules/iobroker.js-controller/controller.js --logs
                2023-01-26 20:18:32.217  - info: host.raspberrypi iobroker.js-controller version 4.0.24 js-controller starting
                2023-01-26 20:18:32.226  - info: host.raspberrypi Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                2023-01-26 20:18:32.228  - info: host.raspberrypi hostname: raspberrypi, node: v16.17.0
                2023-01-26 20:18:32.230  - info: host.raspberrypi ip addresses: 192.168.178.41 2001:9e8:6256:ee00:2a69:6134:2330:b0b3 fe80::cb6f:a96d:5ee2:712a 192.168.178.29 2001:9e8:6256:ee00:20a0:2b27:ab07:1ca7 fe80::4017:de71:8ffb:880a
                2023-01-26 20:18:34.348  - error: host.raspberrypi-Server Cannot start inMem-objects on port 9001: Failed to lock DB file "/opt/iobroker/iobroker-data/objects.jsonl"!```
                code_text
                was jetzt drinsteht, schau ich noch mal
                Ergänzung: Nach den Updates steht noch der gleiche Fehler drin. Es hat sich also nichts geändert. Und das Sympton -keine Erreichbarkeit im Browser- ist auch das gleiche
                • D Doggie
                  code_text
                  code_text
                  #370
                  @doggie also wenn es dieser Fehler ist der jetzt im log ist dann dürfte gar nichts funktionieren. Das passt nicht zusammen was du schreibst.
                  Reboote mal den Host und schau dann.
                  • apollon77A apollon77
                    Doggie
                    #371
                    @apollon77 Der angegebene Fehler steht ja nicht im "Allgemeinen Log", sondern erscheint nur nach Eingabe von
                    code_text
                    ```pi@raspberrypi:/opt/iobroker $ node node_modules/iobroker.js-controller/controller.js --logs```
                    code_text
                    Bis auf die Erreichbarkeit im Browser funktioniert der ioBrowser, wie ich schon schrieb. Er schaltet z.B. alles was er soll. Den o.a. Befehl habe ich von einer Seite in ioBroker.net (Thema "ioBoker läuft nicht mehr). Möglicherweise ist dieser Befehl nicht so zielführend, wie ich dachte.
                    Im allgemeinen Log sehe ich überhaupt keine Fehlermeldungen.
                    Auch wenn es erstmal nicht erklärbar ist: Es ist wie es ist.
                    Gibt es noch Ansätze oder Ideen?
                    Was mir noch aufgefallen ist:
                    code_text
                    ```system.adapter.net-tools.0              : net-tools             : raspberrypi                              - disabled```
                    code_text
                    Thomas BraunT F 2 Antworten Letzte Antwort
                    • D Doggie
                      code_text
                      code_text
                      code_text
                      code_text
                      #372
                      @doggie sagte in Server Cannot start inMem-objects on port 9001:
                      Der Befehl ist soweit ich das sehe obsolet.
                        Doggie
                        #373
                        @thomas-braun Dann wäre es gut, wenn ein Admin den von der angegebenen ioBroker.net Seite
                        entfernen würde. Leute wie ich fallen nur darauf rein.
                        • D Doggie
                          wendy2702W Offline
                          wendy2702W Offline
                          #374
                          wo genau steht der denn?
                          • wendy2702W wendy2702
                            Doggie
                            #375
                            @wendy2702 Seite: https://www.iobroker.net/docu/index-26.htm?page_id=3928&lang=de#installAdapter
                            Thema "IoBroker läuft nicht mehr"
                            "Falls immer noch nicht läuft oder es kommen Fehlermeldungen, dann kann man versuchen controller manuell zu starten...."
                            • D Doggie
                              code_text
                              code_text
                              code_text
                              code_text
                              F Online
                              F Online
                              fastfoot
                              #376
                              ich sehe da 2 ip adressen, evtl ist der iobroke Admin unter der anderen Adresse erreichbar?
                              192.168.178.41 und 192.168.178.29
                                Doggie
                                #377
                                @fastfoot Nein, ist er leider nicht.
                                Auch in der Fritzbox stehen merkwürdigerweise die beiden Adressen.
                                Die 192.168.178.29 unter WLAN, aber auch unter LAN. Die 41 aber auch unter LAN.
                                • D Doggie
                                  #378
                                  Wo genau? Die beiden Interfaces sollten nicht die gleiche IP haben.
                                    Doggie
                                    #379
                                    @thomas-braun Also der Raspberry hat unter WLAN die Adresse 29 und unter LAN die 41.
                                    War möglicherweise ein Fehler in der Fritzbox. In der Liste waren die Adressen gleich, aber bei den Einzelheiten erschienen die richtigen Adressen
                                      Doggie
                                      #380
                                      Nach einigem Probieren kann ich den ioBroker jetzt im Browser erreichen.
                                      Ich musste nach der Adresseingabe den Port 8081 angeben und das "https" löschen.
                                      Irgendwie hat der Browser die falsche Angabe automatisch eingetragen.
                                      schon komisch: Ich hatte es mit 3 verschiedenen Browsern versucht. Oder die gemachten Änderungen haben doch etwas behoben und ich habe es nicht bemerkt durch die Fehleingabe im Browser.
                                      Manchmal sieht man den Wald vor lauter Bäumen nicht.
                                      Danke an alle, die sich um mein Problem bemüht haben.
                                      • D Doggie
                                        BananaJoeB Offline
                                        BananaJoeB Offline
                                        BananaJoe
                                        #381
                                        Ist mir vor ein paar Tagen bei einem Kunden aufgefallen.
                                        Die Browser fangen an wenn eine Seite per http nicht erreichbar ist es gleich noch einmal per https zu versuchen.
                                        Und wenn es doof läuft merken die sich den letzten Versuch im Autovervollständigen so das auch wenn die Seite wieder per http erreichbar ist es trotzdem mit https zu tun.
                                        Beobachtet bei aktuellen Firefox
                                        apollon77A D 2 Antworten Letzte Antwort
                                        • BananaJoeB BananaJoe
                                          #382
                                          @bananajoe das machen die Browser schon ewig so und hat nichts mit der Fritzbox zu tun ;-)
