  4. Server Cannot start inMem-objects on port 9001
    5.8k
429 Beiträge 40 Kommentatoren 125.6k Aufrufe 39 Beobachtet
  • K Karl 1
    @thomas-braun Es gibt keine Meldungen!
    #301
    @karl-1 Was sagt "curl https://iobroker.net/fix.sh"?
    K 1 Antwort Letzte Antwort
    • apollon77A apollon77
      Karl 1
      #302
      @apollon77
      pi@raspberrypi:/ $ curl https://iobroker.net/fix.sh
      curl: (60) SSL certificate problem: certificate has expired
      More details here: https://curl.haxx.se/docs/sslcerts.html
      curl performs SSL certificate verification by default, using a "bundle"
       of Certificate Authority (CA) public keys (CA certs). If the default
       bundle file isn't adequate, you can specify an alternate file
       using the --cacert option.
      If this HTTPS server uses a certificate signed by a CA represented in
       the bundle, the certificate verification probably failed due to a
       problem with the certificate (it might be expired, or the name might
       not match the domain name in the URL).
      If you'd like to turn off curl's verification of the certificate, use
       the -k (or --insecure) option.
      • K Karl 1
        @apollon77
        #303
        @karl-1 ist bei dir alles aktuell. Auf dem
        System? Alle Updates eingespielt? Wenn ja mach bei dem Curl ein „k“ bei den Parametern dazu. Aber warum
        Du das bekommst weiß ich nicht weil s das as Zertifikat an sich passt. Sieht mit eher wie fehlende Systemupdates aus
          Karl 1
          #304
          @apollon77
                              v.2022-12-31
          Operatingsystem:        Raspbian GNU/Linux 9.13 (stretch)
          Installation:           Native
          Timezone:               Europe/Berlin
          User-ID:                1000
          X-Server:               true
          Pending OS-Updates:     0
          Nodejs-Installation:    /usr/bin/nodejs         v14.21.1
                                 /usr/bin/node           v14.21.1
                                 /usr/bin/npm            6.14.17
          ioBroker Core:          js-controller           4.0.23
                                 admin                   6.3.5
          ioBroker Status:        Server Cannot start inMem-objects on port 9001: Failed to lock DB file "/opt/iobroker/iobroker-data/objects.j        sonl"!
          Status admin:
          Pending iob updates:    0
          No connection to databases possible ...
          Objects:                1
          States:                 1
          Size of iob-Database:
          500M    /opt/iobroker/iobroker-data/objects.jsonl
          3.6M    /opt/iobroker/iobroker-data/objects.json.migrated
          3.6M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
          564K    /opt/iobroker/iobroker-data/states.jsonl
          436K    /opt/iobroker/iobroker-data/states.json.migrated
          436K    /opt/iobroker/iobroker-data/states.json.bak.migrated
          apollon77A Thomas BraunT 2 Antworten Letzte Antwort
          • K Karl 1
            @apollon77
                                v.2022-12-31
            User-ID:                1000
            X-Server:               true
                                   admin                   6.3.5
            Status admin:
            Objects:                1
            States:                 1
            #305
            @karl-1 das ist was? Ausgabe des diag Skriptes was zeigen soll das keine Updates offen sind? Ok, verstehe den Fehler bei dir dann dennoch nicht.
            Dann Versuch
            curl -skLf https://iobroker.net/fix.sh | bash -
            • K Karl 1
              @apollon77
                                  v.2022-12-31
              User-ID:                1000
              X-Server:               true
                                     admin                   6.3.5
              Status admin:
              Objects:                1
              States:                 1
              #306
              @karl-1
              Das Stretch-Release ist seit geraumer Zeit abgekündigt.
              Installier da das aktuelle stable-Release Bullseye.
              Natürlich ohne Desktop.
                @karl-1
                Karl 1
                #307
                Gibt es eine Anleitung für iobroker und RPI?
                • K Karl 1
                  #308
                  @karl-1
                  Wenn du die Frage stellen musst: Nein, das ist dann zu aufwändig für dich. Installier es frisch neu.
                  https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
                    @karl-1
                    Karl 1
                    #309
                    Ich habe, wie vorgeschlagen die Neuinstallation mit Erfolg durchgeführt.
                    Ich möchte jetzt die mit backitup gespeicherten Daten der alten Installation auf die neue übertragen.
                    alt
                    2023-01-02_09-26_objects.jsonl.gz
                    2023-01-02_09-26_states.jsonl.gz
                    neu
                    iobroker_2023_01_04-11_44_01_backupiobroker.tar.gz
                    iobroker_2023_01_04-14_04_43_backupiobroker.tar.gz
                    Kann ich as alte in das neue Format umwandeln?
                    Müssen die Adapter vorher angelegt werden?
                    • K Karl 1
                      alt
                      neu
                      #310
                      @karl-1 sagte in Server Cannot start inMem-objects on port 9001:
                      Welches neue Format?
                      Der ioBroker selber war doch auf Stand.
                      Die im Altsystem erstellte Backup-Datei sollte jetzt im neuen System einfach so einzulesen sein.
                      Die vis würde ich vorher anlegen. Alles andere sollte sich von alleine neubauen.
                        Karl 1
                        #311
                        Das Directory
                        pi@raspberrypi:/opt/iobroker/backups $
                        iobroker_2023_01_04-11_40_24_backupiobroker.tar.gz
                        Im ioBroker tauchen nur die neuesten files auf
                        Wie komme ich an die alten Files?
                        • K Karl 1
                          Das Directory
                          #312
                          @karl-1
                          ist ja auch kein richtiges Backup. Hast du kein volles Backup angelegt?
                            @karl-1
                            Karl 1
                            #313
                            Ich habe das Backup auf dem alten System mit backitup angelegt!
                            Das sind die Files, die ich dort gefunden habe!
                            • K Karl 1
                              #314
                              @karl-1
                              Das sind keine Backitup-Dateien. Das ist nur was von der states bzw. objects-Datenbank.
                              Die richtigen Files sehen so aus:
                              iobroker_yyyy_mm_dd-hh_mm_ss_backupiobroker.tar.gz
                              Hast du kein Backup auf ein externes Medium gemacht? "Backups" auf dem gleichen Datenträger sind keine.
                                @karl-1
                                Karl 1
                                #315
                                Wie gesagt, ich habe das Backup im ioBroker mit dem Adapter backitup gemacht.
                                Wo die Daten gepeichert werden, sollte der Struktur egal sein.
                                Im Augenblick speichere ich auch intern (ich werde das ändern und in Zukunft extern speichern) und die Struktur stimmt jetzt mit
                                überein!
                                Warum hat es das Tool mit dem aktuellen Adapter von backitup in der alten Installation dann anders gemacht?
                                • K Karl 1
                                  überein!
                                  #316
                                  Dann liegen die Daten da wo du sie hinplatziert hast oder in /opt/iobroker/backups.
                                  • K Karl 1
                                    überein!
                                    HomoranH Offline
                                    HomoranH Offline
                                    #317
                                    aber wenn du sie in einem nicht zulässigen Systemverzeichnis speicherst kann es sein, dass sie bei einem Update gelöscht werden.
                                    und wohin genau?
                                    Standard ist /opt/iobroker/backups
                                    Und nichts anderes
                                      Karl 1
                                      #318
                                      Um die Backup Daten extern zu speichern habe ich einen USB Stick gemountet.
                                      pi@raspberrypi:/media $ ls
                                      usb  usb0  usb1  usb2  usb3  usb4  usb5  usb6  usb7  usbstick
                                      Von der Konsole aus kann ich darauf zugreifen und Files dort auch abspeichern!
                                      Der ioBroker verweigert aber den Zugriff:
                                      started iobroker ...
                                      [DEBUG] [iobroker] - host.raspberrypi 716 states saved
                                      [DEBUG] [iobroker] - host.raspberrypi 924 objects saved
                                      [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2023_01_05-16_13_41_backupiobroker.tar.gz
                                      [DEBUG] [iobroker] - done
                                      [DEBUG] [cifs] - used copy path: /media/usbstick
                                      [DEBUG] [cifs] - Copy iobroker_2023_01_05-16_13_41_backupiobroker.tar.gz...
                                      [ERROR] [cifs] - Error: EACCES: permission denied, open '/media/usbstick/iobroker_2023_01_05-16_13_41_backupiobroker.tar.gz'
                                      [DEBUG] [cifs] - done
                                      [ERROR] [clean] - Backup files not deleted from /opt/iobroker/backups because some errors.
                                      [DEBUG] [clean] - done
                                      Ich habe trotz intensiver Suche im Internet nichts gefunden, was mir weiterhilft!
                                      • K Karl 1
                                        #319
                                        @karl-1 iobroker läuft als user "iobroker" ...darf der da zugreifen?
                                        • K Karl 1
                                          #320
                                          @karl-1
                                          Warum dann per cifs, wenn der schon herkömmlich gemountet ist?
                                          Mit welchen Optionen wird das Dateisystem des Sticks (welches ist es?) gemountet?
