  4. Server Cannot start inMem-objects on port 9001
429 Beiträge 40 Kommentatoren 132.6k Aufrufe 39 Beobachtet
  • W woehrer
    @woehrer
                            v.2022-12-13
    Operatingsystem:        Ubuntu 22.04.1 LTS
    Installation:           microsoft
    Timezone:               Europe/Berlin
    User-ID:                1000
    X-Server:               false
    Pending OS-Updates:     0
    Nodejs-Installation:    /usr/bin/nodejs         v16.19.0
                            /usr/bin/node           v16.19.0
                            /usr/bin/npm            8.19.3
    ioBroker Core:          js-controller           4.0.23
                            admin                   6.3.3
    Objects type: jsonl
    States  type: jsonl
    Pending iob updates:    2
    Active repo(s): stable
    Objects:                6726
    States:                 6193
    Size of iob-Database:
    7.5M    /opt/iobroker/iobroker-data/objects.jsonl
    4.7M    /opt/iobroker/iobroker-data/objects.json.migrated
    4.7M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
    5.0M    /opt/iobroker/iobroker-data/states.jsonl
    1.2M    /opt/iobroker/iobroker-data/states.json.migrated
    1.2M    /opt/iobroker/iobroker-data/states.json.bak.migrated
    ====================== END OF SUMMARY ==================
    2022-12-22 09:47:26.773  - info: host.iobrokerifa instance system.adapter.admin.0 started with pid 3788
    2022-12-22 09:47:27.787  - info: admin.0 (3788) starting. Version 6.3.3 in /opt/iobroker/node_modules/iobroker.admin, node: v16.19.0, js-controller: 4.0.23
    2022-12-22 09:47:27.814  - info: admin.0 (3788) requesting all states
    2022-12-22 09:47:27.816  - info: admin.0 (3788) requesting all objects
    2022-12-22 09:47:27.956  - warn: admin.0 (3788) Cannot check node.js versions: Error: unexpected end of file
    2022-12-22 09:47:28.326  - info: admin.0 (3788) received all objects
    2022-12-22 09:47:28.438  - info: admin.0 (3788) Request actual repository...
    2022-12-22 09:47:28.523  - info: admin.0 (3788) http server listening on port 8081
    2022-12-22 09:47:28.523  - info: admin.0 (3788) Use link "http://localhost:8081" to configure.
    2022-12-22 09:47:28.527  - info: admin.0 (3788) socket.io server listening on port 8081
    2022-12-22 09:47:28.539  - error: admin.0 (3788) uncaught exception: Cannot read properties of null (reading '_acl')
    2022-12-22 09:47:28.539  - error: admin.0 (3788) TypeError: Cannot read properties of null (reading '_acl')
        at SocketCommandsAdmin.subscribe (/opt/iobroker/node_modules/@iobroker/socket-classes/lib/socketCommands.js:288:117)
        at SocketAdmin.subscribe (/opt/iobroker/node_modules/@iobroker/socket-classes/lib/socketAdmin.js:181:23)
        at initSocket (/opt/iobroker/node_modules/iobroker.admin/main.js:499:12)
        at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/lib/web.js:1048:29)
        at processImmediate (node:internal/timers:468:21)
    2022-12-22 09:47:28.540  - error: admin.0 (3788) Cannot read properties of null (reading '_acl')
    2022-12-22 09:47:28.556  - info: admin.0 (3788) terminating http server on port 8081
    2022-12-22 09:47:28.560  - info: admin.0 (3788) terminating
    2022-12-22 09:47:28.561  - warn: admin.0 (3788) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2022-12-22 09:47:28.779  - info: host.iobrokerifa Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
    2022-12-22 09:47:28.814  - error: host.iobrokerifa Caught by controller[0]: TypeError: Cannot read properties of null (reading '_acl')
    2022-12-22 09:47:28.814  - error: host.iobrokerifa Caught by controller[0]:     at SocketCommandsAdmin.subscribe (/opt/iobroker/node_modules/@iobroker/socket-classes/lib/socketCommands.js:288:117)
    2022-12-22 09:47:28.814  - error: host.iobrokerifa Caught by controller[0]:     at SocketAdmin.subscribe (/opt/iobroker/node_modules/@iobroker/socket-classes/lib/socketAdmin.js:181:23)
    2022-12-22 09:47:28.814  - error: host.iobrokerifa Caught by controller[0]:     at initSocket (/opt/iobroker/node_modules/iobroker.admin/main.js:499:12)
    2022-12-22 09:47:28.814  - error: host.iobrokerifa Caught by controller[0]:     at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/lib/web.js:1048:29)
    2022-12-22 09:47:28.814  - error: host.iobrokerifa Caught by controller[0]:     at processImmediate (node:internal/timers:468:21)
    2022-12-22 09:47:28.814  - error: host.iobrokerifa instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2022-12-22 09:47:28.814  - info: host.iobrokerifa Restart adapter system.adapter.admin.0 because enabled
    apollon77A Online
    apollon77A Online
    #293
    @woehrer Admin 6.3.5 installieren!
      Karl 1
      #294
      Bei mir ist ein ähnliches Problem aufgetreten wie bei bischemer am 14. März 2022 und bei offensichtlich mehreren anderen.
      Ich habe den RPI mit sudo shutdown -h 0 runtergefahren, die Stromversorgung abgeklemmt und mit Win32DiskImager die SD auf eine Backup Platte kopiert.
      Nach dem erneuten Einlegen der SD und Anlegen der Versorgungsspannung startet der RPI und auch der ioBroker, der Zugriff über das Web Interface und Vis ist nicht mehr möglich.
      Den gleichen Effekt hatte ich schon vor einigen Wochen, ich habe mich damit beholfen, dass ich mit einem früheren Backup alle zwischenzeitlichen Änderungen nachgezogen habe (was man einmal machen kann, was aber keine Dauerlösung ist).
      Da der Effekt m.E. entweder mit dem Shutdown oder dem Abklemmen der Versorgung zu tun hat, kann dieses Problem immer wieder auftauchen, sei es bei einem regulären Backup oder bei einem Spannungsausfall im Versorgungsnetz.
      Ich habe alles hier Geschriebene gelesen und nachvollzogen aber keine Lösung für mich gefunden!
      Angefügt einige Infos zu meinem Problem:
      pi@raspberrypi:~ $ iob info
      Server Cannot start inMem-objects on port 9001: Failed to lock DB file "/opt/iobroker/iobroker-data/objects.jsonl"!
      2023-01-02 19:09:42.694  - error: host.raspberrypi No connection to databases possible, restart
      2023-01-02 19:09:42.748  - info: host.raspberrypi iobroker _restart
      2023-01-02 19:09:48.841  - info: host.raspberrypi iobroker.js-controller version 4.0.23 js-controller starting
      2023-01-02 19:09:48.862  - info: host.raspberrypi Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
      2023-01-02 19:09:48.865  - info: host.raspberrypi hostname: raspberrypi, node: v14.19.1
      2023-01-02 19:09:48.867  - info: host.raspberrypi ip addresses: 192.168.178.43 2003:ea:f10:b800:e3c1:cab5:4a9b:7a32 fe80::78fb:de3d:17ae:be62
      2023-01-02 19:10:18.939  - error: host.raspberrypi No connection to databases possible, restart
      ```pi@raspberrypi:/opt/iobroker/iobroker-data $ ls -l
      insgesamt 529504
      drwxrwxrwx+   2 iobroker iobroker      4096 Mai  2  2022 backitup
      drwxrwxrwx+   2 iobroker iobroker      4096 Jan  2 09:26 backup-objects
      drwxrwxrwx+  21 iobroker iobroker      4096 Nov 26 11:59 files
      drwxrwxrwx+ 185 iobroker iobroker     12288 Jan  2 00:02 history
      -rw-rwxrw-+   1 iobroker iobroker      4715 Mai  2  2022 iobroker.json
      -rw-rw-rw-+   1 iobroker iobroker         3 Jan  2 11:11 notifications.json
      -rw-rw-rw-+   1 iobroker iobroker   3715730 Mai  2  2022 objects.json.bak.migrated
      -rw-rw-rw-+   1 iobroker iobroker 524134421 Jan  2 10:52 objects.jsonl
      drwxrwxrwx+   2 iobroker iobroker      4096 Jan  2 19:44 objects.jsonl.lock
      -rw-rw-rw-+   1 iobroker iobroker   3718224 Mai  2  2022 objects.json.migrated
      -rw-rw-rw-+   1 iobroker iobroker    442833 Mai  2  2022 states.json.bak.migrated
      -rw-rw-rw-+   1 iobroker iobroker   9691615 Jan  2 11:11 states.jsonl
      -rw-rw-rw-+   1 iobroker iobroker    442977 Mai  2  2022 states.json.migrated
      • K Karl 1
        insgesamt 529504
        apollon77A Online
        apollon77A Online
        #295
        @karl-1 Dann fang doch mal mit "iob fix" an ... danach sollte deine objects.jsonl kleiner sein ... gehts dann besser?
        • apollon77A apollon77
          Karl 1
          #296
          @apollon77 iob fix ändert nichts an der Größe der Daten!
          iob fix wird innerhalb kürzester Zeit beendet. Kann es sein, dass es überhaupt nicht läuft?
          Thomas BraunT apollon77A 2 Antworten Letzte Antwort
          • K Karl 1
            #297
            @karl-1 sagte in Server Cannot start inMem-objects on port 9001:
            Mit welchen Meldungen?
            • K Karl 1
              apollon77A Online
              apollon77A Online
              #298
              Das gibt an sich eeeiniges aus .... Alternativ lass mal curl -sLf https://iobroker.net/fix.sh | bash - laufen
                Karl 1
                #299
                @apollon77 sagte in Server Cannot start inMem-objects on port 9001:
                Da scheint nichts zu passieren!
                  Karl 1
                  #300
                  @thomas-braun Es gibt keine Meldungen!
                  • K Karl 1
                    apollon77A Online
                    apollon77A Online
                    #301
                    @karl-1 Was sagt "curl https://iobroker.net/fix.sh"?
                      Karl 1
                      #302
                      @apollon77
                      pi@raspberrypi:/ $ curl https://iobroker.net/fix.sh
                      curl: (60) SSL certificate problem: certificate has expired
                      More details here: https://curl.haxx.se/docs/sslcerts.html
                      curl performs SSL certificate verification by default, using a "bundle"
                       of Certificate Authority (CA) public keys (CA certs). If the default
                       bundle file isn't adequate, you can specify an alternate file
                       using the --cacert option.
                      If this HTTPS server uses a certificate signed by a CA represented in
                       the bundle, the certificate verification probably failed due to a
                       problem with the certificate (it might be expired, or the name might
                       not match the domain name in the URL).
                      If you'd like to turn off curl's verification of the certificate, use
                       the -k (or --insecure) option.
                      • K Karl 1
                        @apollon77
                        apollon77A Online
                        apollon77A Online
                        #303
                        @karl-1 ist bei dir alles aktuell. Auf dem
                        System? Alle Updates eingespielt? Wenn ja mach bei dem Curl ein „k“ bei den Parametern dazu. Aber warum
                        Du das bekommst weiß ich nicht weil s das as Zertifikat an sich passt. Sieht mit eher wie fehlende Systemupdates aus
                          Karl 1
                          #304
                          @apollon77
                                              v.2022-12-31
                          Operatingsystem:        Raspbian GNU/Linux 9.13 (stretch)
                          Installation:           Native
                          User-ID:                1000
                          X-Server:               true
                          Nodejs-Installation:    /usr/bin/nodejs         v14.21.1
                                                 /usr/bin/node           v14.21.1
                                                 /usr/bin/npm            6.14.17
                                                 admin                   6.3.5
                          ioBroker Status:        Server Cannot start inMem-objects on port 9001: Failed to lock DB file "/opt/iobroker/iobroker-data/objects.j        sonl"!
                          Status admin:
                          Pending iob updates:    0
                          No connection to databases possible ...
                          Objects:                1
                          States:                 1
                          500M    /opt/iobroker/iobroker-data/objects.jsonl
                          3.6M    /opt/iobroker/iobroker-data/objects.json.migrated
                          3.6M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
                          564K    /opt/iobroker/iobroker-data/states.jsonl
                          436K    /opt/iobroker/iobroker-data/states.json.migrated
                          436K    /opt/iobroker/iobroker-data/states.json.bak.migrated
                          apollon77A Thomas BraunT 2 Antworten Letzte Antwort
                          • K Karl 1
                            @apollon77
                                                v.2022-12-31
                            User-ID:                1000
                            X-Server:               true
                                                   admin                   6.3.5
                            Status admin:
                            Objects:                1
                            States:                 1
                            apollon77A Online
                            apollon77A Online
                            #305
                            @karl-1 das ist was? Ausgabe des diag Skriptes was zeigen soll das keine Updates offen sind? Ok, verstehe den Fehler bei dir dann dennoch nicht.
                            Dann Versuch
                            curl -skLf https://iobroker.net/fix.sh | bash -
                            • K Karl 1
                              @apollon77
                                                  v.2022-12-31
                              User-ID:                1000
                              X-Server:               true
                                                     admin                   6.3.5
                              Status admin:
                              Objects:                1
                              States:                 1
                              #306
                              @karl-1
                              Das Stretch-Release ist seit geraumer Zeit abgekündigt.
                              Installier da das aktuelle stable-Release Bullseye.
                              Natürlich ohne Desktop.
                                @karl-1
                                Karl 1
                                #307
                                Gibt es eine Anleitung für iobroker und RPI?
                                • K Karl 1
                                  #308
                                  @karl-1
                                  Wenn du die Frage stellen musst: Nein, das ist dann zu aufwändig für dich. Installier es frisch neu.
                                  https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
                                    @karl-1
                                    Karl 1
                                    #309
                                    Ich habe, wie vorgeschlagen die Neuinstallation mit Erfolg durchgeführt.
                                    Ich möchte jetzt die mit backitup gespeicherten Daten der alten Installation auf die neue übertragen.
                                    alt
                                    2023-01-02_09-26_objects.jsonl.gz
                                    2023-01-02_09-26_states.jsonl.gz
                                    neu
                                    iobroker_2023_01_04-11_44_01_backupiobroker.tar.gz
                                    iobroker_2023_01_04-14_04_43_backupiobroker.tar.gz
                                    Kann ich as alte in das neue Format umwandeln?
                                    Müssen die Adapter vorher angelegt werden?
                                    • K Karl 1
                                      alt
                                      neu
                                      #310
                                      Welches neue Format?
                                      Der ioBroker selber war doch auf Stand.
                                      Die im Altsystem erstellte Backup-Datei sollte jetzt im neuen System einfach so einzulesen sein.
                                      Die vis würde ich vorher anlegen. Alles andere sollte sich von alleine neubauen.
                                        Karl 1
                                        #311
                                        Das Directory
                                        pi@raspberrypi:/opt/iobroker/backups $
                                        iobroker_2023_01_04-11_40_24_backupiobroker.tar.gz
                                        Im ioBroker tauchen nur die neuesten files auf
                                        Wie komme ich an die alten Files?
                                        • K Karl 1
                                          Das Directory
                                          #312
                                          @karl-1
                                          ist ja auch kein richtiges Backup. Hast du kein volles Backup angelegt?
