  4. js-controller 4.0.x jetzt für alle User im STABLE!
    apollon77A
501 Beiträge 83 Kommentatoren 219.6k Aufrufe 58 Beobachtet
  • J
    J
    jensven
    schrieb am zuletzt editiert von jensven
    #41
    Habe auch gerade nen Update von 3.3.22 auf 4.0.15 gemacht
    Es läuft alles auch soweit, bis auf die bekannten error Probleme von den objekten.
    Aber während des Updates gab es folgende Errors:
    pi@raspberrypi:~ $ iob upgrade self
    Update js-controller from @3.3.22 to @4.0.15
    NPM version: 6.14.16
    npm install iobroker.js-controller@4.0.15 --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call)
    In file included from ../src/unix_dgram.cc:5:
    ../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:
    ../../nan/nan.h:2298:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
         , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)
    In file included from ../../nan/nan.h:54,
    ../src/unix_dgram.cc: At global scope:
    /home/iobroker/.cache/node-gyp/14.19.0/include/node/node.h:793:43: warning: cast between incompatible function types from ‘void (*)(v8::Local<v8::Object>)’ to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
           (node::addon_register_func) (regfunc),                          \
    /home/iobroker/.cache/node-gyp/14.19.0/include/node/node.h:827:3: note: in expansion of macro ‘NODE_MODULE_X’
       NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
    ../src/unix_dgram.cc:404:1: note: in expansion of macro ‘NODE_MODULE’
     NODE_MODULE(unix_dgram, Initialize)
    Server Objects 127.0.0.1:45710 Error from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.features.useSets"]
    Server States 127.0.0.1:58302 Error from InMemDB: Error: GET-UNSUPPORTED for namespace meta.: Data=["meta.states.protocolVersion"]
    Server Objects 127.0.0.1:45710 Error from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.protocolVersion"]
    Server States 127.0.0.1:58304 Error from InMemDB: Error: PSUBSCRIBE-UNSUPPORTED for namespace meta.: Data=["meta.*"]
    Server Objects 127.0.0.1:45710 Error from InMemDB: Error: Unknown LUA script load
    Server Objects 127.0.0.1:45710 Error from InMemDB: Error: SET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.features.useSets",{"type":"Buffer","data":[49]}]
    Could not migrate objects to corresponding sets: Error SET-UNSUPPORTED for names pace cfg.: Data=["meta.objects.features.useSets",{"type":"Buffer","data":[49]}]
    Sollte man da was machen? Hat das was mit den bekannten Problemen zu tun ?
    • J jensven
      apollon77A
      apollon77A
      #42
      @jensven alles gut. Sind übliche Warnungen von einem Paket. Ignorieren
      E Meister MopperM 2 Antworten Letzte Antwort
      • apollon77A apollon77
        FAQ
        Informationen zu pot. angezeigten Meldungen und Logs
        (info) "Sets unsupported"
        In MutliHost-Umgebungen wo noch nicht alle Hosts aktualisiert sind arbeitet eine Optimierung in einem Kompatibilitätsmodus. In diesem wird ggf vom js-controller und von Adaptern beim Start einmalig die Meldung "Sets unsupported" im Loglevel "info" geloggt. Diese verschwindet wenn alle Hosts auf js-controller 4.0+ sind.
        (warn) Object XXX is invalid: obj.common.min/max has an invalid type!
        Dies ist eine neue Prüfung, wie oben bereits erwähnt, welche prüft das der Minimum bzw Maximum Wert eines Objekts auch eine Zahl ist. Wenn diese Meldung kommt dann diese bitte per Issue an den Adapter-Entwickler weitergeben, das dies im Adapter behoben wird.
        "Ignoring Directory "benchmark.files" because officially not created as meta ob ject. Please remove directory!"
        Wenn bei der Inatallation des js-controller diese Meldung kommt:
        The following notifications happened during sync:
        - Ignoring Directory "benchmark.files" because officially not created as meta ob ject. Please remove directory!
        Bitte ein iob upload all ausführen. Falls Einträge von Adaptern enthalten sein sollten die nicht mehr installiert sind, dann können diese Dateien manuell gelöscht werden.
        TypeError: Cannot read property 'warn' of undefined
        Falls der iobroker nicht mehr startet und im /var/log/syslog die untenstehende Fehlermeldung enthalten ist dann ist die backup Konfigurtation fehlerhaft.
        /opt/iobroker/node_modules/@iobroker/db-base/lib/inMemFileDB.js:187
                     this.log.warn(
             at ObjectsInMemoryServer.initBackupDir (/opt/iobroker/node_modules/@iobroker/db-base/lib/inMemFileDB.js:187:22)
        Bitte in /opt/iobroker/iobroker-data/iobroker.json im Bereich backup beo objects und states schauen das der Wert "period" eine Zahl in Minuten ist. Standard ist 120. Falls hier ein Wert über 10.000 drin steht so ist dieser warum auch immer falsch eingetragen und muss bitte korrigiert werden. Danach tut alles wieder.
        Warning: Accessing non-existent property '...' of module exports inside circular dependency
        Wenn beim Ausführen von CLI Befehlen oder im ioBroker Log Meldungen wie die nachstehenden angezeigt werden so liegt dies an einer alten version der Library "mogodb" im System. Diese Meldungen kommen nicht vom js-controller Upgrade sondern von der Nutzung von Node.js 14+ und dieser Library. Diese wurde vom node-red Adapter ggf. installiert.
        (node:2218) Warning: Accessing non-existent property 'count' of module exports inside circular dependency
        (Use `node --trace-warnings ...` to show where the warning was created)
        (node:2218) Warning: Accessing non-existent property 'findOne' of module exports inside circular dependency
        (node:2218) Warning: Accessing non-existent property 'remove' of module exports inside circular dependency
        (node:2218) Warning: Accessing non-existent property 'updateOne' of module exports inside circular dependency
        Wenn ein Update des node-red Adapters (bzw Uninstall falls nicht benötigt) nicht hilft dann bitte mit npm list mongodb (im iobroker Verzeichnis /opt/iobroker) rausfinden wo es herkommt. Falls etwas von "extranous" steht dann einfach per npm uninstall mongodb (im iobroker Verzeichnis /opt/iobroker) löschen.
        Eine Backitup Instanz wird automatisch erstellt
        Dies passiert weil Backitup für Neuinstallationen ein Standardadapter ist. Der kleine Nebeneffekt ist, das, wenn noch keine Backitup Instanz existiert ABER der Adapter-Code auf einem Host installiert ist, dann dort eine Instanz angelegt wird. Wer das nicht will kann diese manuell wieder entfernen und dann aber am besten auch den Adapter deinstallieren. Dann passiert dies nicht noch einmal.
        Infos zum Thema "Rebuilds bei Node.js Aktualisierungen"
        Generell gilt das Node.js Updates wie unter https://forum.iobroker.net/topic/44566/how-to-node-js-für-iobroker-richtig-updaten-2021-edition beschrieben funktionieren. Der js-controller 4.0 führt nur die automatisierten Rebuilds etwas anders aus als die 3.3.
        In der neuen Version versuchen wir zuerst generell alle Module neu zu erstellen. Das sollte alle Probleme auf einen Schlag lösen. Falls das (und ja da kann es Gründe geben) nicht funktioniert ist der zweite Versuch das wirklich betroffene NPM-Paket zu identifizieren (also z.B. direkt "serialport" o.ä.) und dieses neu zu kompilieren. Das hat deutlich weniger Nebeneffekte wie die bisherigen Versuche.
        Aktuell sind zwei Module bekannt die leider eine manuelle Korrekt benötigen (wir haben es bei den Modulen gemeldet, sodass sich das in Zukunft löst). Dazu dann die Meldungen im Log befolgen.
        FAQ zur DB Umstellung File -> JSONL
        Ich nutze Redis. Betrifft mich das?
        Wenn Du für beide Datenbanken einen Redis einsetzt dann nicht. Es ist nur relevant wenn eine oder beide DBs "File" sind.
        Was ist denn so besser an der "JSONL"-Datenbank anstelle "File"?
        Von der Funktionalität ist alles identisch! Die beiden Datenbanken unterscheiden sich nur darin wie die Daten gespeichert werden.
        Die File-DB schreibt hier alles in einem großen JSON-File regelmäßig - bei Objekten sind dies schnell mal 20MB. Dies kann durchaus viel I/O verursachen und ist vor allem bei SD-Karten-Basierten Systemen nicht optimal, weil es die Karte sehr belastet. Aber auch für SSDs ist dies nicht optimal. Zusätzlich besteht das Problem das ein Absturz beim Schreiben dazu führt das das ganze File defekt ist. ioBroker greift in diesen Fällen auf ein Backup-File zurück.
        JSONL arbeitet hier anders. Änderungen werden erst einmal nur an die Datei angehangen und - nur wenn nötig - wird dann das File "komprimiert" und so neu geschrieben. Dies erfolgt aber viel seltener als bei der File-DB.
        Für JSONL hat es @AlCalzone mal folgendermaßen zusammengefasst:
        ➕ JSONL ist resistenter. Ein kaputtes Byte in der DB macht nicht alles kaputt und ein Absturz beim Schreibvorgang sorgt nur dafür, dass die ausstehenden Änderungen verloren gehen, nicht alles.
        ➕ JSONL schont die SD-Karte durch weniger und kleinere Schreibvorgänge (nur wenn nötig).
        ➖ JSONL braucht zumindest phasenweise etwas mehr Platz (die DB ist bis auf Kompaktierungsvorgänge append-only)
        ➖ JSONL braucht etwas länger, wenn viele Objekte in kurzer Zeit geschrieben werden sollen (wobei meine letzten Tests nur noch Unterschiede im Rahmen der Standardabweichung ergeben haben)
        Wir denken das das neue Datenbank-Handling mehr Vorteile hat - vor allem für SD-Karten- und SSD-basierte Systeme.
        Was bedeutet es das die Datenbank jetzt jsonl ist?
        Im Normalfall bedeutet hies für den täglichen Betrieb nichts. Auch die Umstellung erfolg vollautomatisch im Rahmen des js-controller Updates.
        Ein iob status wird nach der Installation anstelle "file" jetzt "jsonl" anzeigen. Das wars auch schon. Backups über BackItUp oder iob backup und auch restores funktionieren weiterhin ohne Änderungen.
        WICHTIG: Durch die automatische Datenbankumstellung ist ein direkter Downgrade oder Backup Restore eines mit 4.0 erstellten Backups nur noch auf js-controller 3.3.x möglich! Für andere Downgrade Optionen bitte im nächsten Eintrag lesen. Ein Downgrade mit Redis als Datenbank ist problemlos weiterhin möglich!
        Die Datenfiles im iobroker-data Verzeichnis haben jetzt .jsonl am Ende und nicht mehr .json. Die letzten "file DB .json"-Files werden umbenannt und liegen noch im Verzeichnis mit der Endung ".migrated".
        Kann man die Einstellungen der JSONL ändern?
        Ja, auch die JSONL Datenbank hat einige Einstellungen (wie das "writeFileInterval" der File-DB früher, welches bei jsonl nicht genutzt wird). Üblicherweise muss da niemand Hand anlegen, weil die Defaults von uns bereits optimiert wurden.
        Wer dennoch schauen will finden unter https://github.com/ioBroker/ioBroker.js-controller/blob/master/packages/controller/conf/iobroker-dist.json#L53-L71 (Objects) bzw https://github.com/ioBroker/ioBroker.js-controller/blob/master/packages/controller/conf/iobroker-dist.json#L99-L117 die jeweiligen Default-Werte. Anpassungen können einfach in Eurer iobroker.json manuell gemacht werden.
        Wie kann ich doch auf js-controller 3.2 oder kleiner downgraden wenn "jsonl" der DB Typ ist?
        js-controller Versionen kleiner als 3.3.x hatten die nötigen Dateien für eine "jsonl" Datenbank nicht an Board. Daher ist ein direkter Downgrade nicht möglich weil dann die Daten nicht lesbar sind!
        Daher muss ZUERST (!!) unter js-controller 4.0 die Datenbank manuell zurück auf "file" migriert werden. Dies erfolgt per iob setup custom und dort bei der Abfrage des DB Typs file angeben. Alle weiteren Fragen beantworten und dann die Migration abwarten. Danach zeigt iob statuswieder "file" an. Dann kann ein Backup für den Restore in einer kleineren Version erstellt werden oder ein Downgrade via npm i iobroker.js-controller@version (Vorher ins ioBroker Verzeichnis wechseln!) auf die gewünschte Version erfolgen.
        FAQ zu Redis "Sets" Optimierungen
        Für Redis-basierte Systeme bringt der js-controller 4.0 einige Optimierungen mit. Eine davon nutzt spezielle interne Datenstrukturen, die konsistent initialisiert werden müssen. Aufgrund einiger Edge Cases wird diese Optimierung daher automatisch nur für Single-Host Redis-Systeme genutzt. Wer auch im Multi-Host-Umfeld mit Redis für Objekte von den Optimierungen profitieren möchte kann diese manuell aktivieren. VORAB müssen aber alle Hosts auf js-controller 4.0 sein und soweit alles gut sein das es keinen partiellen Downgrade mehr gibt.
        Dann können die Optimierungen über iob object activateSets aktiviert werden, nachdem ALLE Hosts beendet wurden. So wird sichergestellt das die Datenstrukturen konsistent initialisiert werden können. Danach können alle Hosts wieder gestartet werden. Eine Deaktivierung der Optimierungen ist per iob object deactivateSets ebenso möglich.
        FabioF
        FabioF
        Fabio
        #43
        @apollon77 vielen Dank an euch. Update war erfolgreich keine Probleme. 👍😉👌
        Iobroker:
        • Matter over Thread Hilfe
          E
          E
          Einstein67
          schrieb am zuletzt editiert von Einstein67
          #44
          @apollon77 Ich hab eine komplette Neuinstallation mit dem Script vom 13.2. durchgeführt (Debian11 und Node 16).
          JS-Controller, Admin, Backitup und Discovery wurden in der aktuellsten Version installiert.
          Backup (Grafana, InfluxDB und IOBroker) wieder hergestellt.
          Keine Probleme bei Installation und Restore, alles läuft perfekt. TOP!!
          Edit: Auch das Popup (jsonl Konvertierung) ist weg!
            Meister MopperM
            Meister MopperM
            Meister Mopper
            #45
            @apollon77
            Nach dem upgrade und Neustart des ioBroker auf meinem master startete der admin-Adapter nicht mit.
            Mit iobroker start admin lief's wieder rund 👍
            Proxmox und HA ...
            • liv-in-skyL
              liv-in-skyL
              liv-in-sky
              #46
              Danke für's entwickeln - nach update läuft alles soweit - keine fehler
              vis scheint schneller beim laden der views zu sein :-)
              • bahnuhrB
                bahnuhrB
                bahnuhr
                #47
                bekomme nun folgende warn und error im log:
                telegram.0
                2022-02-26 11:10:34.726	error	getMe (reconnect #0) Error:Error: EFATAL: Error: getaddrinfo EAI_AGAIN api.telegram.org
                dwd.0
                2022-02-26 11:10:33.508	error	Empty or invalid JSON: Cannot read JSON file: Error: getaddrinfo EAI_AGAIN www.dwd.de
                hm-rega.0
                2022-02-26 11:10:29.731	warn	Script "!# programs.fn 1.3 !# Dieses Script gibt eine Liste der Programme als JSON Strin" ignored, because still pending.
                hm-rega.0
                2022-02-26 11:10:29.689	warn	Script "!# polling.fn 1.3 !# !# Dieses Script gibt die Werte aller Systemvariablen als J" ignored, because still pending.
                telegram.1
                2022-02-26 11:10:27.301	error	getMe (reconnect #0) Error:Error: EFATAL: Error: getaddrinfo EAI_AGAIN api.telegram.org
                javascript.0
                2022-02-26 11:10:20.101	error	Request error: Error: getaddrinfo EAI_AGAIN www.bild.de
                javascript.0
                2022-02-26 11:10:20.100	error	script.js.Scripte.Sonstige.RSS-Feed: {'errno':-3001,'code':'EAI_AGAIN','syscall':'getaddrinfo','hostname':'www.bild.de'}
                host.VM-iobroker
                2022-02-26 11:10:17.650	error	instance system.adapter.hm-rpc.1 terminated with code 6 (UNCAUGHT_EXCEPTION)
                hm-rpc.1
                2022-02-26 11:10:17.016	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                hm-rpc.1
                2022-02-26 11:10:17.013	error	Cannot call init: [xmlrpc_bin://192.168.243.12:8701, ""] Cannot call write after a stream was destroyed
                hm-rpc.1
                2022-02-26 11:10:17.000	error	Exception-Code: ETIMEDOUT: read ETIMEDOUT
                hm-rpc.1
                2022-02-26 11:10:16.999	error	Error: read ETIMEDOUT at TCP.onStreamRead (internal/stream_base_commons.js:209:20)
                hm-rpc.1
                2022-02-26 11:10:16.994	error	uncaught exception: read ETIMEDOUT
                telegram.0
                2022-02-26 11:10:14.696	warn	polling_error: EFATAL, EFATAL: Error: read ETIMEDOUT
                Vielleicht habt ihr dafür eine Erklärung.
                Danke.
                gute Forenbeiträge: https://forum.iobroker.net/topic/51555/hinweise-für-gute-forenbeiträge
                • bahnuhrB bahnuhr
                  telegram.0
                  dwd.0
                  hm-rega.0
                  hm-rega.0
                  telegram.1
                  javascript.0
                  javascript.0
                  host.VM-iobroker
                  hm-rpc.1
                  hm-rpc.1
                  hm-rpc.1
                  hm-rpc.1
                  hm-rpc.1
                  telegram.0
                  apollon77A
                  apollon77A
                  #48
                  @bahnuhr ja. Dein System hat scheinbar gerade ein Problem mit DNS namensauflösungen. Also vor allem die EAGAIN sagen genau das. Check also mal Netzwerk und DNS. Vllt mal reboot? Sollte aber alles nix mit dem Controller zu tun haben.
                  Würde erst das fixen. Falls dann hm-Rpc weiter was sagt muss man da schauen.
                    @apollon77
                    apollon77A
                    apollon77A
                    #49
                    @meister-mopper was stand im log? Falls du schauen willst.
                    • R
                      R
                      rasrol
                      schrieb am zuletzt editiert von rasrol
                      #50
                      Läuft perfekt.
                      Ich musste zwar ein Neuinstallation per Script durchführen, aber seither keine Fehler.
                      Debian 11
                      Node.js:v14.19.0
                      NPM:6.14.16
                        liv-in-skyL
                        liv-in-skyL
                        liv-in-sky
                        #51
                        @apollon77
                        hat das was mit controller 4 zu tun - versuch javascript update - ging vor js-c update auch nicht zum updaten - mit controller 4 kommt beim update des javasc. adapters diese meldung:
                        host.iobroker59
                        2022-02-26 11:11:00.509	error	iobroker (node:27388) Warning: Accessing non-existent property 'findOne' of module exports inside circular dependency(node:27388) Warning: Accessing non-existent property 'remove' of module exports inside circular dependency(node:27388) Warning: Accessing non-existent property 'updateOne' of module exports inside circular dependency
                        host.iobroker59
                        2022-02-26 11:11:00.505	error	iobroker (node:27388) Warning: Accessing non-existent property 'count' of module exports inside circular dependency(Use `node --trace-warnings ...` to show where the warning was created)
                        siehe auch:https://forum.iobroker.net/post/768862
                        nehme an, ist anderes topic - nicht für hier?
                        • liv-in-skyL liv-in-sky
                          @apollon77
                          host.iobroker59
                          host.iobroker59
                          apollon77A
                          apollon77A
                          #52
                          @liv-in-sky ließ mal in der faq. Du hast ne alte mongodb lib wohl von nem node-red. Liegt eher an nodejs 14+ als am Controller.
                          LatziL 1 Antwort Letzte Antwort
                          • andiko2A
                            andiko2A
                            andiko2
                            #53
                            Habe heute die Updates gemacht und alles läuft soweit gut.
                            Plattform
                            linux
                            Betriebssystem
                            linux
                            Architektur
                            x64
                            CPUs
                            Geschwindigkeit
                            1692 MHz
                            Modell
                            Intel(R) Celeron(R) CPU J3455 @ 1.50GHz
                            RAM
                            7.64 GB
                            System-Betriebszeit
                            7 T. 01:15:35
                            Node.js
                            v12.22.10 (Empfohlene Version v14.19.0)
                            time
                            1645873156427
                            timeOffset
                            -60
                            Anzahl der Adapter
                            399
                            NPM
                            6.14.16
                            Datenträgergröße
                            109.04 GB
                            freier Festplattenspeicher
                            58.43 GB
                            Betriebszeit
                            00:29:23
                            Aktive Instanzen
                            26
                            location
                            /opt/iobroker/
                            Hostname
                            ioBrokerPC
                            Einzigster Fehler mein Adapter Systeminfo geht nicht mehr. im Log steht volgendes:
                            host.ioBrokerPC
                            2022-02-26 12:25:34.470 error instance system.adapter.systeminfo.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                            systeminfo.0
                            2022-02-26 12:25:33.842 error Cannot read property 'getObjectList' of undefined
                            systeminfo.0
                            2022-02-26 12:25:33.841 error TypeError: Cannot read property 'getObjectList' of undefined at Function.initAdapter (/opt/iobroker/node_modules/iobroker.systeminfo/myAdapter.js:44:55) at Adapter.<anonymous> (/opt/iobroker/node_modules/iobroker.systeminfo/myAdapter.js:118:37) at Adapter.emit (events.js:314:20) at /opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8223:26
                            systeminfo.0
                            2022-02-26 12:25:33.838 error unhandled promise rejection: Cannot read property 'getObjectList' of undefined
                            systeminfo.0
                            2022-02-26 12:25:33.838 error Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                            • andiko2A andiko2
                              Plattform
                              linux
                              Betriebssystem
                              linux
                              Architektur
                              x64
                              CPUs
                              Geschwindigkeit
                              1692 MHz
                              Modell
                              RAM
                              7.64 GB
                              System-Betriebszeit
                              7 T. 01:15:35
                              Node.js
                              time
                              1645873156427
                              timeOffset
                              -60
                              Anzahl der Adapter
                              399
                              NPM
                              6.14.16
                              Datenträgergröße
                              109.04 GB
                              58.43 GB
                              Betriebszeit
                              00:29:23
                              Aktive Instanzen
                              26
                              location
                              /opt/iobroker/
                              Hostname
                              ioBrokerPC
                              host.ioBrokerPC
                              systeminfo.0
                              systeminfo.0
                              systeminfo.0
                              systeminfo.0
                              apollon77A
                              apollon77A
                              #54
                              @andiko2 Zu systeminfo: siehe Post #1 ... da stehts drin inkkl. wie du es fixen kannst bis es ein Update gibt
                              andiko2A 1 Antwort Letzte Antwort
                                andiko2A
                                andiko2A
                                andiko2
                                schrieb am zuletzt editiert von andiko2
                                #55
                                @apollon77 was ist Post '#1? Bin nicht so der Forumkenner. Wenn möglich Link.
                                apollon77A T 2 Antworten Letzte Antwort
                                • andiko2A andiko2
                                  apollon77A
                                  apollon77A
                                  #56
                                  @andiko2 Der erste Post in diesem Thread? Einfach gaaaaaaaaaaaaaaaaaaaanz nach oben Scrollen. Dort im Abschnitt "VOR der Installation"
                                  • andiko2A andiko2
                                    T
                                    T
                                    tobrog
                                    schrieb am zuletzt editiert von tobrog
                                    #57
                                    @andiko2 Einfach in der Datei /opt/iobroker/node_modules/iobroker.systeminfo/myAdapter.js in Zeile 44 von"adapter.objects.getObjectList" zu "adapter.getObjectList" ändern.
                                    • T
                                      T
                                      TDCroPower
                                      #58
                                      Update des js-controllers auf dem Docker Image von buanet ist durch, lediglich der rebuild vom BLE Adapter läuft bei 3 Versuchen nicht durch und im Log sieht man jetzt folgendes...
                                      host.helios64
                                      2022-02-26 12:48:17.793	info	Rebuild for adapter system.adapter.ble.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
                                      host.helios64
                                      2022-02-26 12:48:17.792	info	instance system.adapter.ble.0 requested a rebuild of its dependencies and will be restarted after that is done.
                                      wenn ich den Befehl in der Konsole eingebe kommt folgendes...
                                      root@helios64:/opt/iobroker# npm install --production
                                      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/fsevents):
                                      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm64"})
                                      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.7 (node_modules/osx-temperature-sensor):
                                      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm64"})
                                      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/zigbee-herdsman-converters/node_modules/fsevents):
                                      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/fsevents):
                                      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/zigbee-herdsman/node_modules/fsevents):
                                      removed 3 packages and updated 1 package in 34.934s
                                      137 packages are looking for funding
                                        run `npm fund` for details
                                      was nun !?
                                      • T tobrog
                                        andiko2A
                                        andiko2A
                                        andiko2
                                        #59
                                        @tobrog said in js-controller 4.0.x jetzt für alle User im STABLE!:
                                        Dankeschön. Genau diese Info hat geholfen.
                                        • T TDCroPower
                                          host.helios64
                                          host.helios64
                                          was nun !?
                                          apollon77A
                                          apollon77A
                                          #60
                                          @tdcropower Naja du solltest den "npm install" in einem bestimmten Verzeichnis ausführen - steht an sich in den Anweisungen im Log. Du hast es im iobroker "root" verzeichnis ausgeführt. Das hilft nicht, ja.
                                          Du musst es in /opt/iobroker/node_modules/iobroker.ble ausführen
                                          Und ja leider ist der BLE Adapter bze eine Library davon gerade nicht rebuild-fähig. Wir haben dort schon eine Änderung eingereicht, die ist aber noch nicht released.
                                          84.0k
                                          1.4m
