js-controller 4.0.x jetzt für alle User im STABLE!
Moin moin, ich habe auch das Update gemacht. Instanzen sind bis auf Zigbee problmlos gestartet. Ich habe imForum dann die vorgeschlagen Vorgehensweisen ausgeführt aber Zigbee blieb rot. Ich habe den Adapter dann gelöscht und neu installiert, danach startete der Zigbee-Adapter problemlos.
2022-02-26 06:06:58.295 - error: host.PI-IOBROKER Caught by controller[0]: /opt/iobroker/node_modules/zigbee-herdsman/node_modules/bindings/bindings.js:121 2022-02-26 06:06:58.296 - error: host.PI-IOBROKER Caught by controller[0]: throw e; 2022-02-26 06:06:58.296 - error: host.PI-IOBROKER Caught by controller[0]: ^ 2022-02-26 06:06:58.296 - error: host.PI-IOBROKER Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/build/Release/bindings.node' 2022-02-26 06:06:58.297 - error: host.PI-IOBROKER Caught by controller[0]: was compiled against a different Node.js version using 2022-02-26 06:06:58.297 - error: host.PI-IOBROKER Caught by controller[0]: NODE_MODULE_VERSION 83. This version of Node.js requires 2022-02-26 06:06:58.297 - error: host.PI-IOBROKER Caught by controller[0]: NODE_MODULE_VERSION 93. Please try re-compiling or re-installing 2022-02-26 06:06:58.297 - error: host.PI-IOBROKER Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`). 2022-02-26 06:06:58.297 - error: host.PI-IOBROKER Caught by controller[0]: at Object.Module._extensions..node (node:internal/modules/cjs/loader:1185:18) 2022-02-26 06:06:58.298 - error: host.PI-IOBROKER Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:981:32) 2022-02-26 06:06:58.298 - error: host.PI-IOBROKER Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:822:12) 2022-02-26 06:06:58.298 - error: host.PI-IOBROKER Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1005:19) 2022-02-26 06:06:58.298 - error: host.PI-IOBROKER Caught by controller[0]: at require (node:internal/modules/cjs/helpers:102:18) 2022-02-26 06:06:58.299 - error: host.PI-IOBROKER Caught by controller[0]: at bindings (/opt/iobroker/node_modules/zigbee-herdsman/node_modules/bindings/bindings.js:112:48) 2022-02-26 06:06:58.299 - error: host.PI-IOBROKER Caught by controller[0]: at Object. (/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/lib/linux.js:2:36) 2022-02-26 06:06:58.299 - error: host.PI-IOBROKER Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1103:14) 2022-02-26 06:06:58.299 - error: host.PI-IOBROKER Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1155:10) 2022-02-26 06:06:58.299 - error: host.PI-IOBROKER Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:981:32) { 2022-02-26 06:06:58.300 - error: host.PI-IOBROKER Caught by controller[0]: code: 'ERR_DLOPEN_FAILED' 2022-02-26 06:06:58.300 - error: host.PI-IOBROKER Caught by controller[0]: } 2022-02-26 06:06:58.300 - error: host.PI-IOBROKER instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED) 2022-02-26 06:06:58.300 - info: host.PI-IOBROKER Rebuild for adapter system.adapter.zigbee.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually. 2022-02-26 06:23:00.080 - info: host.PI-IOBROKER instance system.adapter.openweathermap.0 started with pid 2589 2022-02-26 06:23:01.236 - info: host.PI-IOBROKER "system.adapter.zigbee.0" disabled 2022-02-26 06:23:02.161 - info: openweathermap.0 (2589) starting. Version 0.1.0 in /opt/iobroker/node_modules/iobroker.openweathermap, node: v16.14.0, js-controller: 3.3.22 2022-02-26 06:23:03.603 - info: host.PI-IOBROKER "system.adapter.zigbee.0" enabled 2022-02-26 06:23:03.720 - info: host.PI-IOBROKER instance system.adapter.zigbee.0 started with pid 2604 2022-02-26 06:23:04.548 - error: host.PI-IOBROKER Caught by controller[0]: /opt/iobroker/node_modules/zigbee-herdsman/node_modules/bindings/bindings.js:121 2022-02-26 06:23:04.549 - error: host.PI-IOBROKER Caught by controller[0]: throw e; 2022-02-26 06:23:04.549 - error: host.PI-IOBROKER Caught by controller[0]: ^ 2022-02-26 06:23:04.549 - error: host.PI-IOBROKER Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/build/Release/bindings.node' 2022-02-26 06:23:04.550 - error: host.PI-IOBROKER Caught by controller[0]: was compiled against a different Node.js version using 2022-02-26 06:23:04.550 - error: host.PI-IOBROKER Caught by controller[0]: NODE_MODULE_VERSION 83. This version of Node.js requires 2022-02-26 06:23:04.550 - error: host.PI-IOBROKER Caught by controller[0]: NODE_MODULE_VERSION 93. Please try re-compiling or re-installing 2022-02-26 06:23:04.551 - error: host.PI-IOBROKER Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`). 2022-02-26 06:23:04.551 - error: host.PI-IOBROKER Caught by controller[0]: at Object.Module._extensions..node (node:internal/modules/cjs/loader:1185:18) 2022-02-26 06:23:04.551 - error: host.PI-IOBROKER Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:981:32) 2022-02-26 06:23:04.551 - error: host.PI-IOBROKER Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:822:12) 2022-02-26 06:23:04.552 - error: host.PI-IOBROKER Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1005:19) 2022-02-26 06:23:04.552 - error: host.PI-IOBROKER Caught by controller[0]: at require (node:internal/modules/cjs/helpers:102:18) 2022-02-26 06:23:04.552 - error: host.PI-IOBROKER Caught by controller[0]: at bindings (/opt/iobroker/node_modules/zigbee-herdsman/node_modules/bindings/bindings.js:112:48) 2022-02-26 06:23:04.552 - error: host.PI-IOBROKER Caught by controller[0]: at Object. (/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/lib/linux.js:2:36) 2022-02-26 06:23:04.553 - error: host.PI-IOBROKER Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1103:14) 2022-02-26 06:23:04.553 - error: host.PI-IOBROKER Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1155:10) 2022-02-26 06:23:04.553 - error: host.PI-IOBROKER Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:981:32) { 2022-02-26 06:23:04.553 - error: host.PI-IOBROKER Caught by controller[0]: code: 'ERR_DLOPEN_FAILED' 2022-02-26 06:23:04.553 - error: host.PI-IOBROKER Caught by controller[0]: } 2022-02-26 06:23:04.554 - error: host.PI-IOBROKER instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)VG
@thomas4170 haste mal bitte das ganze log. Hier ist nur der letzte rebuild try drin. Würde gern mal alle drei sehen. Also am besten ganzen log ab start des Controllers. Danke
@apollon77 allerdings tauchenjetzt warnmeldungen auf nach dem update.
ELEVATED publishToState: value generated 'false' from device 00158d0006b79823 for 'Time from last motion' zigbee.0 2022-02-26 09:04:37.708 warn ELEVATED publishToState: value generated 'false' from device 00158d0006b79823 for 'Occupancy' zigbee.0 2022-02-26 09:04:37.707 warn ELEVATED publishToState: message received '{"occupancy":false}' from device 00158d0006b79823 type 'RTCGQ11LM' zigbee.0 2022-02-26 09:03:37.709 warn ELEVATED publishToState: value generated 'true' from device 00158d0006b79823 for 'Time from last motion' zigbee.0 2022-02-26 09:03:37.709 warn ELEVATED publishToState: value generated 'true' from device 00158d0006b79823 for 'Occupancy' zigbee.0 2022-02-26 09:03:37.708 warn ELEVATED publishToState: message received '{"occupancy":true}' from device 00158d0006b79823 type 'RTCGQ11LM' zigbee.0 2022-02-26 09:03:37.703 warn ELEVATED publishToState: value generated '255' from device 00158d0006b79823 for 'Link quality' zigbee.0 2022-02-26 09:03:37.702 warn ELEVATED publishToState: message received '{"linkquality":255}' from device 00158d0006b79823 type 'RTCGQ11LM' zigbee.0 2022-02-26 09:03:37.691 warn ELEVATED publishToState: value generated '3' from device 00158d0006b79823 for 'Illuminance' zigbee.0 2022-02-26 09:03:37.689 warn ELEVATED publishToState: value generated 'true' from device 00158d0006b79823 for 'Time from last motion' zigbee.0 2022-02-26 09:03:37.689 warn ELEVATED publishToState: value generated 'true' from device 00158d0006b79823 for 'Occupancy' zigbee.0 2022-02-26 09:03:37.688 warn ELEVATED publishToState: message received '{"occupancy":true,"illuminance":3,"illuminance_lux":3}' from device 00158d0006b79823 type 'RTCGQ11LM' zigbee.0 2022-02-26 09:03:37.683 warn ELEVATED publishToState: value generated '255' from device 00158d0006b79823 for 'Link quality' zigbee.0 2022-02-26 09:03:37.683 warn ELEVATED publishToState: message received '{"linkquality":255}' from device 00158d0006b79823 type 'RTCGQ11LM' zigbee.0 2022-02-26 09:03:35.418 warn ELEVATED publishToState: value generated 'false' from device 00158d0006b79823 for 'Time from last motion' zigbee.0 2022-02-26 09:03:35.417 warn ELEVATED publishToState: value generated 'false' from device 00158d0006b79823 for 'Occupancy' zigbee.0 2022-02-26 09:03:35.417 warn ELEVATED publishToState: message received '{"occupancy":false}' from device 00158d0006b79823 type 'RTCGQ11LM' zigbee.0 2022-02-26 09:02:35.419 warn ELEVATED publishToState: value generated 'true' from device 00158d0006b79823 for 'Time from last motion' zigbee.0 2022-02-26 09:02:35.419 warn ELEVATED publishToState: value generated 'true' from device 00158d0006b79823 for 'Occupancy' zigbee.0 2022-02-26 09:02:35.418 warn ELEVATED publishToState: message received '{"occupancy":true}' from device 00158d0006b79823 type 'RTCGQ11LM' zigbee.0 2022-02-26 09:02:35.413 warn ELEVATED publishToState: value generated '255' from device 00158d0006b79823 for 'Link quality' zigbee.0 2022-02-26 09:02:35.412 warn ELEVATED publishToState: message received '{"linkquality":255}' from device 00158d0006b79823 type 'RTCGQ11LM' zigbee.0 2022-02-26 09:02:35.398 warn ELEVATED publishToState: value generated '3' from device 00158d0006b79823 for 'Illuminance' zigbee.0 2022-02-26 09:02:35.396 warn ELEVATED publishToState: value generated 'true' from device 00158d0006b79823 for 'Time from last motion' zigbee.0 2022-02-26 09:02:35.396 warn ELEVATED publishToState: value generated 'true' from device 00158d0006b79823 for 'Occupancy' zigbee.0 2022-02-26 09:02:35.395 warn ELEVATED publishToState: message received '{"occupancy":true,"illuminance":3,"illuminance_lux":3}' from device 00158d0006b79823 type 'RTCGQ11LM' zigbee.0 2022-02-26 09:02:35.389 warn ELEVATED publishToState: value generated '255' from device 00158d0006b79823 for 'Link quality' zigbee.0 2022-02-26 09:02:35.389 warn ELEVATED publishToState: message received '{"linkquality":255}' from device 00158d0006b79823 type 'RTCGQ11LM'Was kann ich tun?
@david-g denke das selbe. Klingt für mich nach nem rebuild der automatisch alles gefixt hat. Kannst ja mal im log schauen.
Das war es. Hab ich gestern schon im Log gesehen. Hatte aber erst Angst, daß was zerschossen wäre ^^.
@apollon77 Alles gut, Problem gelöst, die ID Nummer des Zigbee Geräts war im Debug Messages vom Zigbee Adapter angegeben und daher kamen die Meldungen, also alles gut.
@schimi sagte in js-controller 4.0.x jetzt für alle User im STABLE!:
edit
fehlaalarm.... hätte genauer gucken sollen :-D
Prima, jetzt weis niemand, was gemeint war.
Andere die auch nicht so genau gucken können, finden es eventuell auch nicht und die Antworten sind sinnlos geworden.Habe es nochmal editiert.... als ich es "löschen" wollte waren noch keine Antworten da ;-)
Wobei ich es vorher besser fand, als man es einfach auswählen konnte (gerade wenn man mit dem Handy drauf zugegriffen hat)..
Jetzt kann man auch beide Repositories auswählen.... ich denke das es mehr Verwirrung stiften wird...
Vielen Dank an alle Beteiligten, install ohne Probleme
Habe auch gerade nen Update von 3.3.22 auf 4.0.15 gemacht
Es läuft alles auch soweit, bis auf die bekannten error Probleme von den objekten.Aber während des Updates gab es folgende Errors:
pi@raspberrypi:~ $ iob upgrade self Update js-controller from @3.3.22 to @4.0.15 NPM version: 6.14.16 npm install iobroker.js-controller@4.0.15 --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call) In file included from ../src/unix_dgram.cc:5: ../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’: ../../nan/nan.h:2298:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete) ^ In file included from ../../nan/nan.h:54, from ../src/unix_dgram.cc:5: ../src/unix_dgram.cc: At global scope: /home/iobroker/.cache/node-gyp/14.19.0/include/node/node.h:793:43: warning: cast between incompatible function types from ‘void (*)(v8::Local<v8::Object>)’ to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type] (node::addon_register_func) (regfunc), \ ^ /home/iobroker/.cache/node-gyp/14.19.0/include/node/node.h:827:3: note: in expansion of macro ‘NODE_MODULE_X’ NODE_MODULE_X(modname, regfunc, NULL, 0) // NOLINT (readability/null_usage) ^~~~~~~~~~~~~ ../src/unix_dgram.cc:404:1: note: in expansion of macro ‘NODE_MODULE’ NODE_MODULE(unix_dgram, Initialize) ^~~~~~~~~~~ Server Objects 127.0.0.1:45710 Error from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.features.useSets"] Server States 127.0.0.1:58302 Error from InMemDB: Error: GET-UNSUPPORTED for namespace meta.: Data=["meta.states.protocolVersion"] Server Objects 127.0.0.1:45710 Error from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.protocolVersion"] Server States 127.0.0.1:58304 Error from InMemDB: Error: PSUBSCRIBE-UNSUPPORTED for namespace meta.: Data=["meta.*"] Server Objects 127.0.0.1:45710 Error from InMemDB: Error: Unknown LUA script load Server Objects 127.0.0.1:45710 Error from InMemDB: Error: Unknown LUA script load Server Objects 127.0.0.1:45710 Error from InMemDB: Error: Unknown LUA script load Server Objects 127.0.0.1:45710 Error from InMemDB: Error: SET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.features.useSets",{"type":"Buffer","data":[49]}] Could not migrate objects to corresponding sets: Error SET-UNSUPPORTED for names pace cfg.: Data=["meta.objects.features.useSets",{"type":"Buffer","data":[49]}]Sollte man da was machen? Hat das was mit den bekannten Problemen zu tun ?
FAQ
Informationen zu pot. angezeigten Meldungen und Logs
(info) "Sets unsupported"
In MutliHost-Umgebungen wo noch nicht alle Hosts aktualisiert sind arbeitet eine Optimierung in einem Kompatibilitätsmodus. In diesem wird ggf vom js-controller und von Adaptern beim Start einmalig die Meldung "Sets unsupported" im Loglevel "info" geloggt. Diese verschwindet wenn alle Hosts auf js-controller 4.0+ sind.
(warn) Object XXX is invalid: obj.common.min/max has an invalid type!
Dies ist eine neue Prüfung, wie oben bereits erwähnt, welche prüft das der Minimum bzw Maximum Wert eines Objekts auch eine Zahl ist. Wenn diese Meldung kommt dann diese bitte per Issue an den Adapter-Entwickler weitergeben, das dies im Adapter behoben wird.
"Ignoring Directory "benchmark.files" because officially not created as meta ob ject. Please remove directory!"
Wenn bei der Inatallation des js-controller diese Meldung kommt:
The following notifications happened during sync: - Ignoring Directory "benchmark.files" because officially not created as meta ob ject. Please remove directory!Bitte ein
iob upload allausführen. Falls Einträge von Adaptern enthalten sein sollten die nicht mehr installiert sind, dann können diese Dateien manuell gelöscht werden.TypeError: Cannot read property 'warn' of undefined
Falls der iobroker nicht mehr startet und im /var/log/syslog die untenstehende Fehlermeldung enthalten ist dann ist die backup Konfigurtation fehlerhaft.
/opt/iobroker/node_modules/@iobroker/db-base/lib/inMemFileDB.js:187 this.log.warn( ^ TypeError: Cannot read property 'warn' of undefined at ObjectsInMemoryServer.initBackupDir (/opt/iobroker/node_modules/@iobroker/db-base/lib/inMemFileDB.js:187:22)Bitte in /opt/iobroker/iobroker-data/iobroker.json im Bereich backup beo objects und states schauen das der Wert "period" eine Zahl in Minuten ist. Standard ist 120. Falls hier ein Wert über 10.000 drin steht so ist dieser warum auch immer falsch eingetragen und muss bitte korrigiert werden. Danach tut alles wieder.
Warning: Accessing non-existent property '...' of module exports inside circular dependency
Wenn beim Ausführen von CLI Befehlen oder im ioBroker Log Meldungen wie die nachstehenden angezeigt werden so liegt dies an einer alten version der Library "mogodb" im System. Diese Meldungen kommen nicht vom js-controller Upgrade sondern von der Nutzung von Node.js 14+ und dieser Library. Diese wurde vom node-red Adapter ggf. installiert.
(node:2218) Warning: Accessing non-existent property 'count' of module exports inside circular dependency (Use `node --trace-warnings ...` to show where the warning was created) (node:2218) Warning: Accessing non-existent property 'findOne' of module exports inside circular dependency (node:2218) Warning: Accessing non-existent property 'remove' of module exports inside circular dependency (node:2218) Warning: Accessing non-existent property 'updateOne' of module exports inside circular dependencyWenn ein Update des node-red Adapters (bzw Uninstall falls nicht benötigt) nicht hilft dann bitte mit
npm list mongodb(im iobroker Verzeichnis/opt/iobroker) rausfinden wo es herkommt. Falls etwas von "extranous" steht dann einfach pernpm uninstall mongodb(im iobroker Verzeichnis/opt/iobroker) löschen.Eine Backitup Instanz wird automatisch erstellt
Dies passiert weil Backitup für Neuinstallationen ein Standardadapter ist. Der kleine Nebeneffekt ist, das, wenn noch keine Backitup Instanz existiert ABER der Adapter-Code auf einem Host installiert ist, dann dort eine Instanz angelegt wird. Wer das nicht will kann diese manuell wieder entfernen und dann aber am besten auch den Adapter deinstallieren. Dann passiert dies nicht noch einmal.
Infos zum Thema "Rebuilds bei Node.js Aktualisierungen"
Generell gilt das Node.js Updates wie unter https://forum.iobroker.net/topic/44566/how-to-node-js-für-iobroker-richtig-updaten-2021-edition beschrieben funktionieren. Der js-controller 4.0 führt nur die automatisierten Rebuilds etwas anders aus als die 3.3.
In der neuen Version versuchen wir zuerst generell alle Module neu zu erstellen. Das sollte alle Probleme auf einen Schlag lösen. Falls das (und ja da kann es Gründe geben) nicht funktioniert ist der zweite Versuch das wirklich betroffene NPM-Paket zu identifizieren (also z.B. direkt "serialport" o.ä.) und dieses neu zu kompilieren. Das hat deutlich weniger Nebeneffekte wie die bisherigen Versuche.
Aktuell sind zwei Module bekannt die leider eine manuelle Korrekt benötigen (wir haben es bei den Modulen gemeldet, sodass sich das in Zukunft löst). Dazu dann die Meldungen im Log befolgen.
FAQ zur DB Umstellung File -> JSONL
Ich nutze Redis. Betrifft mich das?
Wenn Du für beide Datenbanken einen Redis einsetzt dann nicht. Es ist nur relevant wenn eine oder beide DBs "File" sind.
Was ist denn so besser an der "JSONL"-Datenbank anstelle "File"?
Von der Funktionalität ist alles identisch! Die beiden Datenbanken unterscheiden sich nur darin wie die Daten gespeichert werden.
Die File-DB schreibt hier alles in einem großen JSON-File regelmäßig - bei Objekten sind dies schnell mal 20MB. Dies kann durchaus viel I/O verursachen und ist vor allem bei SD-Karten-Basierten Systemen nicht optimal, weil es die Karte sehr belastet. Aber auch für SSDs ist dies nicht optimal. Zusätzlich besteht das Problem das ein Absturz beim Schreiben dazu führt das das ganze File defekt ist. ioBroker greift in diesen Fällen auf ein Backup-File zurück.
JSONL arbeitet hier anders. Änderungen werden erst einmal nur an die Datei angehangen und - nur wenn nötig - wird dann das File "komprimiert" und so neu geschrieben. Dies erfolgt aber viel seltener als bei der File-DB.
Für JSONL hat es @AlCalzone mal folgendermaßen zusammengefasst:
➕ JSONL ist resistenter. Ein kaputtes Byte in der DB macht nicht alles kaputt und ein Absturz beim Schreibvorgang sorgt nur dafür, dass die ausstehenden Änderungen verloren gehen, nicht alles.
➕ JSONL schont die SD-Karte durch weniger und kleinere Schreibvorgänge (nur wenn nötig).
➖ JSONL braucht zumindest phasenweise etwas mehr Platz (die DB ist bis auf Kompaktierungsvorgänge append-only)
➖ JSONL braucht etwas länger, wenn viele Objekte in kurzer Zeit geschrieben werden sollen (wobei meine letzten Tests nur noch Unterschiede im Rahmen der Standardabweichung ergeben haben)Wir denken das das neue Datenbank-Handling mehr Vorteile hat - vor allem für SD-Karten- und SSD-basierte Systeme.
Was bedeutet es das die Datenbank jetzt jsonl ist?
Im Normalfall bedeutet hies für den täglichen Betrieb nichts. Auch die Umstellung erfolg vollautomatisch im Rahmen des js-controller Updates.
Einiob statuswird nach der Installation anstelle "file" jetzt "jsonl" anzeigen. Das wars auch schon. Backups über BackItUp oderiob backupund auch restores funktionieren weiterhin ohne Änderungen.WICHTIG: Durch die automatische Datenbankumstellung ist ein direkter Downgrade oder Backup Restore eines mit 4.0 erstellten Backups nur noch auf js-controller 3.3.x möglich! Für andere Downgrade Optionen bitte im nächsten Eintrag lesen. Ein Downgrade mit Redis als Datenbank ist problemlos weiterhin möglich!
Die Datenfiles im iobroker-data Verzeichnis haben jetzt .jsonl am Ende und nicht mehr .json. Die letzten "file DB .json"-Files werden umbenannt und liegen noch im Verzeichnis mit der Endung ".migrated".
Kann man die Einstellungen der JSONL ändern?
Ja, auch die JSONL Datenbank hat einige Einstellungen (wie das "writeFileInterval" der File-DB früher, welches bei jsonl nicht genutzt wird). Üblicherweise muss da niemand Hand anlegen, weil die Defaults von uns bereits optimiert wurden.
Wer dennoch schauen will finden unter https://github.com/ioBroker/ioBroker.js-controller/blob/master/packages/controller/conf/iobroker-dist.json#L53-L71 (Objects) bzw https://github.com/ioBroker/ioBroker.js-controller/blob/master/packages/controller/conf/iobroker-dist.json#L99-L117 die jeweiligen Default-Werte. Anpassungen können einfach in Eurer iobroker.json manuell gemacht werden.
Wie kann ich doch auf js-controller 3.2 oder kleiner downgraden wenn "jsonl" der DB Typ ist?
js-controller Versionen kleiner als 3.3.x hatten die nötigen Dateien für eine "jsonl" Datenbank nicht an Board. Daher ist ein direkter Downgrade nicht möglich weil dann die Daten nicht lesbar sind!
Daher muss ZUERST (!!) unter js-controller 4.0 die Datenbank manuell zurück auf "file" migriert werden. Dies erfolgt per
iob setup customund dort bei der Abfrage des DB Typsfileangeben. Alle weiteren Fragen beantworten und dann die Migration abwarten. Danach zeigtiob statuswieder "file" an. Dann kann ein Backup für den Restore in einer kleineren Version erstellt werden oder ein Downgrade vianpm i iobroker.js-controller@version(Vorher ins ioBroker Verzeichnis wechseln!) auf die gewünschte Version erfolgen.FAQ zu Redis "Sets" Optimierungen
Für Redis-basierte Systeme bringt der js-controller 4.0 einige Optimierungen mit. Eine davon nutzt spezielle interne Datenstrukturen, die konsistent initialisiert werden müssen. Aufgrund einiger Edge Cases wird diese Optimierung daher automatisch nur für Single-Host Redis-Systeme genutzt. Wer auch im Multi-Host-Umfeld mit Redis für Objekte von den Optimierungen profitieren möchte kann diese manuell aktivieren. VORAB müssen aber alle Hosts auf js-controller 4.0 sein und soweit alles gut sein das es keinen partiellen Downgrade mehr gibt.
Dann können die Optimierungen über
iob object activateSetsaktiviert werden, nachdem ALLE Hosts beendet wurden. So wird sichergestellt das die Datenstrukturen konsistent initialisiert werden können. Danach können alle Hosts wieder gestartet werden. Eine Deaktivierung der Optimierungen ist periob object deactivateSetsebenso möglich.@apollon77 vielen Dank an euch. Update war erfolgreich keine Probleme. 👍😉👌
@apollon77 Ich hab eine komplette Neuinstallation mit dem Script vom 13.2. durchgeführt (Debian11 und Node 16).
JS-Controller, Admin, Backitup und Discovery wurden in der aktuellsten Version installiert.
Backup (Grafana, InfluxDB und IOBroker) wieder hergestellt.
Keine Probleme bei Installation und Restore, alles läuft perfekt. TOP!!
Edit: Auch das Popup (jsonl Konvertierung) ist weg!
@apollon77
Nach dem upgrade und Neustart des ioBroker auf meinem master startete der admin-Adapter nicht mit.Mit
iobroker start adminlief's wieder rund
Danke für's entwickeln - nach update läuft alles soweit - keine fehler
vis scheint schneller beim laden der views zu sein :-)
bekomme nun folgende warn und error im log:
telegram.0 2022-02-26 11:10:34.726 error getMe (reconnect #0) Error:Error: EFATAL: Error: getaddrinfo EAI_AGAIN api.telegram.org dwd.0 2022-02-26 11:10:33.508 error Empty or invalid JSON: Cannot read JSON file: Error: getaddrinfo EAI_AGAIN www.dwd.de hm-rega.0 2022-02-26 11:10:29.731 warn Script "!# programs.fn 1.3 !# Dieses Script gibt eine Liste der Programme als JSON Strin" ignored, because still pending. hm-rega.0 2022-02-26 11:10:29.689 warn Script "!# polling.fn 1.3 !# !# Dieses Script gibt die Werte aller Systemvariablen als J" ignored, because still pending. telegram.1 2022-02-26 11:10:27.301 error getMe (reconnect #0) Error:Error: EFATAL: Error: getaddrinfo EAI_AGAIN api.telegram.org javascript.0 2022-02-26 11:10:20.101 error Request error: Error: getaddrinfo EAI_AGAIN www.bild.de javascript.0 2022-02-26 11:10:20.100 error script.js.Scripte.Sonstige.RSS-Feed: {'errno':-3001,'code':'EAI_AGAIN','syscall':'getaddrinfo','hostname':'www.bild.de'} host.VM-iobroker 2022-02-26 11:10:17.650 error instance system.adapter.hm-rpc.1 terminated with code 6 (UNCAUGHT_EXCEPTION) hm-rpc.1 2022-02-26 11:10:17.016 warn Terminated (UNCAUGHT_EXCEPTION): Without reason hm-rpc.1 2022-02-26 11:10:17.013 error Cannot call init: [xmlrpc_bin://192.168.243.12:8701, ""] Cannot call write after a stream was destroyed hm-rpc.1 2022-02-26 11:10:17.000 error Exception-Code: ETIMEDOUT: read ETIMEDOUT hm-rpc.1 2022-02-26 11:10:16.999 error Error: read ETIMEDOUT at TCP.onStreamRead (internal/stream_base_commons.js:209:20) hm-rpc.1 2022-02-26 11:10:16.994 error uncaught exception: read ETIMEDOUT telegram.0 2022-02-26 11:10:14.696 warn polling_error: EFATAL, EFATAL: Error: read ETIMEDOUTVielleicht habt ihr dafür eine Erklärung.
@bahnuhr ja. Dein System hat scheinbar gerade ein Problem mit DNS namensauflösungen. Also vor allem die EAGAIN sagen genau das. Check also mal Netzwerk und DNS. Vllt mal reboot? Sollte aber alles nix mit dem Controller zu tun haben.
Würde erst das fixen. Falls dann hm-Rpc weiter was sagt muss man da schauen.
@apollon77
@meister-mopper was stand im log? Falls du schauen willst.
hat das was mit controller 4 zu tun - versuch javascript update - ging vor js-c update auch nicht zum updaten - mit controller 4 kommt beim update des javasc. adapters diese meldung:
host.iobroker59 2022-02-26 11:11:00.509 error iobroker (node:27388) Warning: Accessing non-existent property 'findOne' of module exports inside circular dependency(node:27388) Warning: Accessing non-existent property 'remove' of module exports inside circular dependency(node:27388) Warning: Accessing non-existent property 'updateOne' of module exports inside circular dependency host.iobroker59 2022-02-26 11:11:00.505 error iobroker (node:27388) Warning: Accessing non-existent property 'count' of module exports inside circular dependency(Use `node --trace-warnings ...` to show where the warning was created)siehe auch:https://forum.iobroker.net/post/768862
nehme an, ist anderes topic - nicht für hier?
@liv-in-sky ließ mal in der faq. Du hast ne alte mongodb lib wohl von nem node-red. Liegt eher an nodejs 14+ als am Controller.
Habe heute die Updates gemacht und alles läuft soweit gut.
Plattform
linux
Betriebssystem
linux
Architektur
x64
CPUs
Geschwindigkeit
1692 MHz
Modell
Intel(R) Celeron(R) CPU J3455 @ 1.50GHz
RAM
7.64 GB
System-Betriebszeit
7 T. 01:15:35
Node.js
v12.22.10 (Empfohlene Version v14.19.0)
time
1645873156427
timeOffset
-60
Anzahl der Adapter
399
NPM
6.14.16
Datenträgergröße
109.04 GB
freier Festplattenspeicher
58.43 GB
Betriebszeit
00:29:23
Aktive Instanzen
26
location
/opt/iobroker/
Hostname
ioBrokerPC
Einzigster Fehler mein Adapter Systeminfo geht nicht mehr. im Log steht volgendes:
host.ioBrokerPC
2022-02-26 12:25:34.470 error instance system.adapter.systeminfo.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
systeminfo.0
2022-02-26 12:25:33.842 error Cannot read property 'getObjectList' of undefined
systeminfo.0
2022-02-26 12:25:33.841 error TypeError: Cannot read property 'getObjectList' of undefined at Function.initAdapter (/opt/iobroker/node_modules/iobroker.systeminfo/myAdapter.js:44:55) at Adapter.<anonymous> (/opt/iobroker/node_modules/iobroker.systeminfo/myAdapter.js:118:37) at Adapter.emit (events.js:314:20) at /opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8223:26
systeminfo.0
2022-02-26 12:25:33.838 error unhandled promise rejection: Cannot read property 'getObjectList' of undefined
systeminfo.0
2022-02-26 12:25:33.838 error Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). -
Plattform
linux
Betriebssystem
linux
Architektur
x64
CPUs
Geschwindigkeit
1692 MHz
Modell
RAM
7.64 GB
System-Betriebszeit
7 T. 01:15:35
Node.js
time
1645873156427
timeOffset
-60
Anzahl der Adapter
399
NPM
6.14.16
Datenträgergröße
109.04 GB
58.43 GB
Betriebszeit
00:29:23
Aktive Instanzen
26
location
/opt/iobroker/
Hostname
ioBrokerPC
host.ioBrokerPC
systeminfo.0
systeminfo.0
systeminfo.0
systeminfo.0
