  4. Tester für WireGuard Adapter gesucht
    6.6k
118 Beiträge 12 Kommentatoren 25.2k Aufrufe 17 Beobachtet
  • NegaleinN Negalein
    @grizzelbee sagte in Tester für WireGuard Adapter gesucht:
    Benutzer, der für die Anmeldung benutzt wird
    Ahh, also nicht Benutzer+Passwort für Wireguard UI, sondern für den SSH?
    SSH ist installiert
    * ssh.service - OpenBSD Secure Shell server
         Loaded: loaded (/lib/systemd/system/ssh.service; enabled; vendor preset: enabled)
         Active: active (running) since Mon 2022-01-03 10:25:26 CET; 1 months 19 days ago
           Docs: man:sshd(8)
                 man:sshd_config(5)
       Main PID: 355 (sshd)
          Tasks: 1 (limit: 18984)
         Memory: 3.7M
            CPU: 17ms
         CGroup: /system.slice/ssh.service
                 `-355 sshd: /usr/sbin/sshd -D [listener] 0 of 10-100 startups
    Jan 03 10:25:22 Wireguard-VPN systemd[1]: Starting OpenBSD Secure Shell server...
    Jan 03 10:25:26 Wireguard-VPN sshd[355]: Server listening on 0.0.0.0 port 22.
    Jan 03 10:25:26 Wireguard-VPN sshd[355]: Server listening on :: port 22.
    Jan 03 10:25:26 Wireguard-VPN systemd[1]: Started OpenBSD Secure Shell server.
    bekomme keine Verbindung
    wireguard.0
    2022-02-22 12:38:59.173	error	Exception-Code: ENOTFOUND: getaddrinfo ENOTFOUND 10.0.1.204:5000
    wireguard.0
    2022-02-22 12:38:59.173	error	Error: getaddrinfo ENOTFOUND 10.0.1.204:5000 at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:69:26)
    wireguard.0
    2022-02-22 12:38:59.173	error	uncaught exception: getaddrinfo ENOTFOUND 10.0.1.204:5000
    wireguard.0
    2022-02-22 12:38:59.166	info	Connecting to host [Nega] on address [10.0.1.204:5000]
    wireguard.0
    2022-02-22 12:38:29.166	info	Started 30 seconds monitoring interval for host [Nega]
    wireguard.0
    2022-02-22 12:38:29.165	debug	{"name":"Nega","hostaddress":"10.0.1.204:5000","user":"A\f\t\u0016","password":"d\u0006\n\u0001]\u000eVS\u0001","pollInterval":"30"}
    wireguard.0
    2022-02-22 12:38:29.165	info	There is 1 wireguard host to monitor.
    wireguard.0
    2022-02-22 12:38:29.148	info	starting. Version 0.9.5 in /opt/iobroker/node_modules/iobroker.wireguard, node: v14.17.1, js-controller: 3.3.22
    Wireguard läuft auf einem standalone Server
    GrizzelbeeG Offline
    GrizzelbeeG Offline
    Grizzelbee
    @negalein sagte in Tester für WireGuard Adapter gesucht:
    Ich wusste nicht einmal das es eine WireGuard UI gibt! 😆
    Richtig. Und der benutze user muss eben die Rechte haben das wg Kommando ohne sudo aufzurufen. Da sudo eine erneute passwort eingabe erfordern würde.
    Okay. Das ist ja durchaus so vorgesehen.
    wireguard.0 2022-02-22 12:38:29.165 debug {"name":"Nega","hostaddress":"10.0.1.204:5000","user":"A\f\t\u0016","password":"d\u0006\n\u0001]\u000eVS\u0001","pollInterval":"30"}
    Der Port 5000 muss dort weg. Der Adapter braucht nur die banke IP (10.0.1.204), da er selbst auf Port 22 (ssh) connected.
    dslraserD NegaleinN 2 Antworten Letzte Antwort
    • GrizzelbeeG Grizzelbee
      dslraserD Offline
      dslraserD Offline
      dslraser
      mein User hat das scheinbar nicht, deshalb habe ich root im Adapter benutzt. Wie gebe ich denn einem User (ist schon angelegt) unter Debian11 die Rechte diese Kommandos auszuführen? (Konsole kenn ich mich nicht aus...)
        NegaleinN Offline
        NegaleinN Offline
        Negalein
        Ok, jetzt müsste mir wer weiterhelfen.
        SSH ist aktiv (gehe hier über die Konsole von Proxmox drauf)
               Docs: man:sshd(8)
                     man:sshd_config(5)
             Memory: 3.7M
                CPU: 17ms
        Versuche ich mich mit Putty zu verbinden, funktionierts nicht.
        Wo liegt da der Fehler?
        ° Fixer ---> iob fix
        GrizzelbeeG 1 Antwort Letzte Antwort
        • dslraserD dslraser
          @dslraser sagte in Tester für WireGuard Adapter gesucht:
          Da musst du mal schauen welche Rechte erforderlich sind.
          which wg
          ls -la /pfad/zu/wg
          dslraserD GrizzelbeeG 3 Antworten Letzte Antwort
                   Docs: man:sshd(8)
                         man:sshd_config(5)
                 Memory: 3.7M
                    CPU: 17ms
            GrizzelbeeG Offline
            GrizzelbeeG Offline
            Grizzelbee
            okay. Fangen wir vorne an:
            Du hast einen Server (Ubuntu) und eine Workstation (Windows oder Linux)?
            Wenn du auf der Workstation Linux oder Windows >= 10 hast kannst du einfach eine Konsole (Linux=Terminal, Windows=cmd/Eingabeaufforderung) öffnen und
            >ssh root@10.0.1.204
            eingeben. Dann wird das root passwort abgefragt und du bist auf dem Ubuntu-Server.
            dort kannst Du
            >wg show
            eingeben und bekommst den Status deines WireGuard angezeigt.
            Bei älterem Windows musst du dich über putty als ssh client verbinden. Da gibt es noch keinen eingebauten Konsolen ssh-client.
            Thomas BraunT NegaleinN 2 Antworten Letzte Antwort
              >ssh root@10.0.1.204
              dort kannst Du
              >wg show
              @grizzelbee
              root ist im Regelfall nicht von außen via ssh erreichbar.
              Bei *buntu ist der nicht mal von innen aktiv.
                >ssh root@10.0.1.204
                dort kannst Du
                >wg show
                NegaleinN Offline
                NegaleinN Offline
                Negalein
                wie gesagt, das funktioniert leider nicht
                ssh: connect to host 10.0.1.204 port 22: Connection timed out
                liegt es event. an der Config?
                #       $OpenBSD: sshd_config,v 1.103 2018/04/09 20:41:22 tj Exp $
                # This is the sshd server system-wide configuration file.  See
                # sshd_config(5) for more information.
                # This sshd was compiled with PATH=/usr/bin:/bin:/usr/sbin:/sbin
                # The strategy used for options in the default sshd_config shipped with
                # OpenSSH is to specify options with their default value where
                # possible, but leave them commented.  Uncommented options override the
                # default value.
                Include /etc/ssh/sshd_config.d/*.conf
                #Port 22
                #AddressFamily any
                #ListenAddress 0.0.0.0
                #ListenAddress ::
                #HostKey /etc/ssh/ssh_host_rsa_key
                #HostKey /etc/ssh/ssh_host_ecdsa_key
                #HostKey /etc/ssh/ssh_host_ed25519_key
                # Ciphers and keying
                #RekeyLimit default none
                # Logging
                #SyslogFacility AUTH
                #LogLevel INFO
                # Authentication:
                #LoginGraceTime 2m
                #PermitRootLogin prohibit-password
                #StrictModes yes
                #MaxAuthTries 6
                #MaxSessions 10
                #PubkeyAuthentication yes
                # Expect .ssh/authorized_keys2 to be disregarded by default in future.
                #AuthorizedKeysFile     .ssh/authorized_keys .ssh/authorized_keys2
                #AuthorizedPrincipalsFile none
                #AuthorizedKeysCommand none
                #AuthorizedKeysCommandUser nobody
                # For this to work you will also need host keys in /etc/ssh/ssh_known_hosts
                #HostbasedAuthentication no
                # Change to yes if you don't trust ~/.ssh/known_hosts for
                # HostbasedAuthentication
                #IgnoreUserKnownHosts no
                # Don't read the user's ~/.rhosts and ~/.shosts files
                #IgnoreRhosts yes
                # To disable tunneled clear text passwords, change to no here!
                #PasswordAuthentication yes
                #PermitEmptyPasswords no
                # Change to yes to enable challenge-response passwords (beware issues with
                # some PAM modules and threads)
                ChallengeResponseAuthentication no
                # Kerberos options
                #KerberosAuthentication no
                #KerberosOrLocalPasswd yes
                #KerberosTicketCleanup yes
                #KerberosGetAFSToken no
                  which wg
                  ls -la /pfad/zu/wg
                  dslraserD Offline
                  dslraserD Offline
                  dslraser
                  @thomas-braun sagte in Tester für WireGuard Adapter gesucht:
                  /pfad/zu/wg
                  danke Dir. Wie bekomme ich den Pfad raus ?
                  /pfad/zu/wg
                    which wg
                    ls -la /pfad/zu/wg
                    GrizzelbeeG Offline
                    GrizzelbeeG Offline
                    Grizzelbee
                    Ja - Ich nutze (genau wie Du) aus bequemlichkeit auch noch root.
                    Bei mir (Debian 11) liegt wg unter /usr/bin und erfordert root:root.
                    Das muss ich jetzt auch mal ändern - habe da aber noch keinen Plan in der Tasche. da muss ich mich auch noch reinarbeiten. Am besten dürfte es wahrscheinlich sein das wg kommando in eine eigene Gruppe zu packen und das dann alles wasserdicht zu machen. Aber wg braucht halt aufgrund seiner Natur sehr hohe Rechte.
                    @grizzelbee
                    Da kenne ich mich tatsächlich nicht mit aus. Ich bin debian-user. ;)
                      which wg
                      ls -la /pfad/zu/wg
                      dslraserD Offline
                      dslraserD Offline
                      dslraser
                      which wg
                      ls -la /pfad/zu/wg
                      das stet dann da bei wg
                      -rwxr-xr-x  1 root root      97376 Feb 25  2021  wg
                        @grizzelbee
                        Schau dir setuid an. Damit kann man erweiterte Rechte auch an einfache User weitergeben.
                        GrizzelbeeG dslraserD 2 Antworten Letzte Antwort
                          GrizzelbeeG Offline
                          GrizzelbeeG Offline
                          Grizzelbee
                          schrieb am zuletzt editiert von Grizzelbee
                          Mache ich. Danke für den Tipp. 👍
                          @Negalein
                          Ich habe mal schnell gegoogelt und habe das hier gefunden: https://linuxize.com/post/how-to-enable-ssh-on-ubuntu-20-04/
                          Dort steht, dass Ubuntu standartmäßig die Firewall ufw aktiv hat. Dort musst du den Zugriff über ssh noch zulassen:
                          $ sudo ufw allow ssh
                          Schau bitte ggf. mal in den Artikel rein. Aber der timeout deutet schon stark auf die firewall hin.
                            @Negalein
                            NegaleinN Offline
                            NegaleinN Offline
                            Negalein
                            Merci, das wars!! :)
                            Läuft und ist grün :)
                              dslraserD Offline
                              dslraserD Offline
                              dslraser
                              @Grizzelbee @Thomas-Braun
                              Ich habe mal für setuid Google bemüht und habe das hier gefunden und gemacht
                              chmod u+s /usr/bin/wg
                              Danach konnte ich mich als User im Adapter anmelden und es funktioniert. Das ist ein "sudo User". Ist damit alles okay, oder muss ich das anders machen, oder ist da jetzt was bedenklich was die Sicherheit angeht ?
                              GrizzelbeeG 2 Antworten Letzte Antwort
                                @grizzelbee
                                Ich nutze keinen root. Hab ich nicht genug Ahnung für.
                                -1
                                  dslraserD Offline
                                  dslraserD Offline
                                  dslraser
                                  oha, und das sagst gerade Du...😊
                                  Stephan SchleichS 1 Antwort Letzte Antwort
                                    Stephan SchleichS Offline
                                    Stephan Schleich
                                    @Grizzelbee Sau geil, hat alles geklappt - Darauf haben viele gewartet :)
                                      GrizzelbeeG Offline
                                      GrizzelbeeG Offline
                                      Grizzelbee
                                      Soweit ich das verstehe darf damit jetzt jeder beliebige User wg ausführen. Das ist aus meiner Sicht für die Sicherheit von WireGuard etwas bedenklich, nicht aber für den ganzen Server. Denn das wg Kommando ist durchaus mächtig:
                                      ~$ wg --help
                                      Usage: wg <cmd> [<args>]
                                      Available subcommands:
                                        show: Shows the current configuration and device information
                                        showconf: Shows the current configuration of a given WireGuard interface, for use with `setconf'
                                        set: Change the current configuration, add peers, remove peers, or change peers
                                        setconf: Applies a configuration file to a WireGuard interface
                                        addconf: Appends a configuration file to a WireGuard interface
                                        syncconf: Synchronizes a configuration file to a WireGuard interface
                                        genkey: Generates a new private key and writes it to stdout
                                        genpsk: Generates a new preshared key and writes it to stdout
                                        pubkey: Reads a private key from stdin and writes a public key to stdout
                                      You may pass `--help' to any of these subcommands to view usage.
                                      Ich gebe aber zu, das ich weder in WireGuard (und dem wg Kommando) noch in Linux tief genug drin bin um wirklich die komplette Tragweite beurteilen zu können. Die Frage muss wahrscheinlich am ehesten lauten: Wird der aktuelle Sicherheitslevel des Servers dadurch gravierend beeinträchtigt? Ich persönlich empfinde es aber durchaus als Gewinn, das ich jetzt die Anzahl der Peers überwachen kann und überhaupt merke, wenn da plötzlich eins hinzu kommt.
                                        ~$ wg --help
                                        dslraserD Offline
                                        dslraserD Offline
                                        dslraser
                                        @grizzelbee
                                        ich habe es mal rückgängig gemacht und bin im Adapter nun erstmal wieder auf root.
                                        (Ich hatte zum testen mal einen einfachen User angelegt, der durfte dann tatsächlich wg ausführen....)
                                          @negalein
                                          ich habe mir den Status der möglichen Geräte, die per Wireguard VPN verbunden sein könnten auch mal in mein iQontrol eingebaut
                                          dirk1962D Offline
                                          dirk1962D Offline
                                          dirk1962
                                          Hallo @dslraser,
                                          cool, kannst Du bitte erklären, wie Du das in Iqontrol gemacht hast.
                                          Danke.
                                          NUC8i5 mit Proxmox; Raspberrymatic in VM, iobroker, Motioneye, infuxDB und Grafana in CT.
