  4. js-controller 4.0 jetzt im BETA/LATEST!
    6.0k
747 Beiträge 70 Kommentatoren 275.3k Aufrufe 60 Beobachtet
  • apollon77A apollon77
    @ofbeqnpolkkl6mby5e13 Issue bei vis bitte
    O Abwesend
    O Abwesend
    oFbEQnpoLKKl6mbY5e13
    schrieb am zuletzt editiert von oFbEQnpoLKKl6mbY5e13
    #541
    @apollon77
    Das behebt das Problem nicht:
    2022-02-21 10:40:38.147  - info: host.iobroker "system.adapter.vis.0" enabled
    2022-02-21 10:40:39.910  - info: vis.0 (2892) starting. Version 1.4.5 in /opt/iobroker/node_modules/iobroker.vis, node: v14.19.0, js-controller: 4.0.12
    2022-02-21 10:40:40.184  - info: vis.0 (2892) vis license is OK.
    2022-02-21 10:40:40.242  - error: vis.0 (2892) uncaught exception: EACCES: permission denied, open '/opt/iobroker/node_modules/iobroker.vis/www/widgets/fritzdect/css/style.css'
    2022-02-21 10:40:40.245  - error: vis.0 (2892) Error: EACCES: permission denied, open '/opt/iobroker/node_modules/iobroker.vis/www/widgets/fritzdect/css/style.css'
        at Object.openSync (fs.js:497:3)
        at Object.writeFileSync (fs.js:1528:35)
        at copyFileSync (/opt/iobroker/node_modules/iobroker.vis/lib/install.js:16:8)
        at /opt/iobroker/node_modules/iobroker.vis/lib/install.js:36:17
        at Array.forEach (<anonymous>)
        at copyFolderRecursiveSync (/opt/iobroker/node_modules/iobroker.vis/lib/install.js:31:15)
        at /opt/iobroker/node_modules/iobroker.vis/lib/install.js:34:17
    2022-02-21 10:40:40.246  - error: vis.0 (2892) Exception-Code: EACCES: EACCES: permission denied, open '/opt/iobroker/node_modules/iobroker.vis/www/widgets/fritzdect/css/style.css'
    2022-02-21 10:40:40.762  - info: vis.0 (2892) terminating
    2022-02-21 10:40:40.764  - warn: vis.0 (2892) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2022-02-21 10:40:41.371  - info: host.iobroker instance system.adapter.vis.0 terminated while should be started once
    Ich führe mal ein iobroker fix durch.
    Nach iobroker fix:
    2022-02-21 10:51:21.640  - info: vis.0 (1348) starting. Version 1.4.5 in /opt/iobroker/node_modules/iobroker.vis, node: v14.19.0, js-controller: 4.0.12
    2022-02-21 10:51:21.904  - info: vis.0 (1348) vis license is OK.
    2022-02-21 10:51:23.094  - info: vis.0 (1348) Terminated (NO_ERROR): Without reason
    2022-02-21 10:51:23.691  - info: host.iobroker instance system.adapter.vis.0 terminated while should be started once
    Danach wieder hoch zu 1.4.12. Jetzt läuft vis wieder. Nur hätte ich mir das alles sparen können, weil mein ursprüngliches Problem weiterhin existiert...
    Thomas BraunT apollon77A 2 Antworten Letzte Antwort
    • O oFbEQnpoLKKl6mbY5e13
      @apollon77
      Nach iobroker fix:
      #542
      Wie sehen die Rechte denn an
      aus?
      O 1 Antwort Letzte Antwort
        aus?
        O Abwesend
        O Abwesend
        #543
        Wie gesagt, das Problem konnte durch iobroker fix behoben werden.
        # ls -l /opt/iobroker/node_modules/iobroker.vis/www/widgets/fritzdect/css/style.css
        -rw-rw-rw- 1 iobroker iobroker 70 Feb 21 11:05 /opt/iobroker/node_modules/iobroker.vis/www/widgets/fritzdect/css/style.css
          @saeft_2003 naja mit 630MB frei ist dann die Frage wie gross denn so das Backup ist wenn es tut? bzw wieviele Daten sind es denn die da gesichert werden
          saeft_2003
          schrieb am zuletzt editiert von saeft_2003
          #544
          @apollon77 sagte in js-controller 4.0 jetzt im BETA/LATEST!:
          Das backup hat 90MB.
          edit: ich habe ohne den ram zu erhöhen ein Backup manuell gestartet das lief ohne Probleme durch.
            @apollon77
            Nach iobroker fix:
            #545
            @ofbeqnpolkkl6mby5e13 sagte in js-controller 4.0 jetzt im BETA/LATEST!:
              O Abwesend
              O Abwesend
              #546
              @apollon77
              Restore mit VIS v1.4.12 geht mindestens bei mir nicht und hat mit JS-Controller nichts zu tun. Das Problem, weshalb ich auf einen älteren Stand wollte, ist aber Off-Topic.
              Danke für die Hilfe!
              • S saeft_2003
                @wendy2702
                Ja so zeigt es proxmox an. Eingestellt habe ich 5GB ich kann der Iobroker VM ohne Probleme noch mehr RAM geben.
                Muss ich mir nachher mal anschauen…
                Edit:
                root@iobroker:~# free -m
                              gesamt       benutzt     frei      gemns.  Puffer/Cache verfügbar
                Speicher:       4812        3954         541           0         316         630
                Swap:            974         221         753
                #547
                @saeft_2003 Kannst du mir mal einen gefallen tun?
                Mach mal eine Shell auf mit "top", dann drücke "Shift-M" - das sortiert dir die EInträge nach RAM nutzung. Dnan am besten davon nen Screenshot
                Jetzt bitte mal zwei Dinge tun:
                1.) in einer zweiten Shell ein "iob backup" ausführen
                2.) Backup über BackItUp manuell starten
                Und bei beiden Dingen bitte mal das "top" beobachten ... Wo steigt der RAM Verbrauch an und wenn ja in welchem prozess?
                Vllt kommen wir so ein bissl dahinter
                  Marty56
                  #548
                  @apollon77
                  Ich habe meine zweite iobroker Instanz (Raspberry 3) ohne Probleme umgestellt.
                  Dort hatte ich früher die States auf redis umgestellt und würde jetzt gern auf JSONL migrieren.
                  iobroker status
                  Objects type: jsonl
                  States  type: redis
                  Ist das unproblematisch?
                  HW:NUC (16 GB Ram)
                  OS: Debian Bullseye, Promox V7, node v16.x npm 8.19.3
                  • M Marty56
                    @apollon77
                    iobroker status
                    Objects type: jsonl
                    States  type: redis
                    #549
                    @marty56 Na klar, einfach per iob setup custom machen
                      Marty56
                      #550
                      @apollon77 Danke. Hat unproblematisch geklappt.
                      HW:NUC (16 GB Ram)
                      • E Offline
                        e-i-k-e
                        schrieb am zuletzt editiert von e-i-k-e
                        #551
                        Aktualisiere gerade ein Slave von 4.0.10 auf 4.0.15.
                        Habe es nun bereits mit sudo -H -u iobroker npm install iobroker.js-controller versucht.
                        Bei den anderen Geräten hatte ich dieses Problem nicht.
                        Was kann ich tun?
                        pi@raspberrypi-display2:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
                        > iobroker.js-controller@4.0.10 preinstall /opt/iobroker/node_modules/iobroker.js-controller
                        > node lib/preinstallCheck.js
                        NPM version: 6.14.16
                        > iobroker.js-controller@4.0.10 install /opt/iobroker/node_modules/iobroker.js-controller
                        > node iobroker.js setup first
                        No connection to objects 192.168.3.100:6379[redis]
                        /opt/iobroker/node_modules/standard-as-callback/built/index.js:6
                                throw e;
                        Error: Connection is closed.
                            at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25)
                            at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20)
                            at Object.onceWrapper (events.js:520:26)
                            at Socket.emit (events.js:400:28)
                            at TCP.<anonymous> (net.js:686:12)
                        Emitted 'error' event on ScanStream instance at:
                            at /opt/iobroker/node_modules/ioredis/built/ScanStream.js:38:22
                            at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:12:23)
                            at /opt/iobroker/node_modules/standard-as-callback/built/index.js:33:51
                            at processTicksAndRejections (internal/process/task_queues.js:95:5)
                        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents):
                        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                        npm ERR! code ELIFECYCLE
                        npm ERR! errno 1
                        npm ERR! iobroker.js-controller@4.0.10 install: `node iobroker.js setup first`
                        npm ERR! Exit status 1
                        npm ERR!
                        npm ERR! Failed at the iobroker.js-controller@4.0.10 install script.
                        npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
                        npm ERR!     /home/iobroker/.npm/_logs/2022-02-21T20_58_28_730Z-debug.l
                        Keine Ahnung was jetzt los ist.. 😲
                        pi@raspberrypi-display2:~ $ iobroker stop
                        pi@raspberrypi-display2:~ $ iobroker fix
                        library: loaded
                        Library version=2022-02-10
                        ioBroker is not installed in /opt/iobroker! Cannot fix anything...
                        • E e-i-k-e
                          Was kann ich tun?
                                  throw e;
                          npm ERR! errno 1
                          npm ERR!
                          library: loaded
                          #552
                          @e-i-k-e Wie geht es dem Redis? Steht ggf etwas im Redis log? Ich hab das gefühl das sich der beendet mittendrin.
                          E 1 Antwort Letzte Antwort
                            e-i-k-e
                            #553
                            @apollon77
                            Hast du zufällig den Pfad parat?
                            Ich habe den kompletten Container inkl. Reids mal neu gestartet. Keine Änderung.
                            • E e-i-k-e
                              @apollon77
                              #554
                              @e-i-k-e
                              less -R /var/log/redis/redis-server.log
                              und
                              systemctl status redis
                              anschauen.
                              • DiginixD Offline
                                DiginixD Offline
                                Diginix
                                schrieb am zuletzt editiert von Diginix
                                #555
                                @AlCalzone @apollon77
                                Hab eben per CLI admin, web und ws aktualisiert und dann ist der js-controller mal wieder RAM technisch eskaliert mit über 2 GB. Hat sich dann aber ohne mein Zutun wieder stabilisiert. Wahrs. reichten die 6 GB RAM der VM gerade so aus.
                                Mem:           5941        4407         131           1        1402        1242
                                Swap:             0           0           0
                                ..:: So long! Tom ::..
                                apollon77A 3 Antworten Letzte Antwort
                                  @e-i-k-e
                                  und
                                  anschauen.
                                  e-i-k-e
                                  #556
                                  Danke.
                                  Im Log steht immer das gleiche, nichts auffälliges.
                                  11670:C 20 Feb 2022 22:13:49.210 * DB saved on disk
                                  11670:C 20 Feb 2022 22:13:49.228 * RDB: 7 MB of memory used by copy-on-write
                                  139:M 20 Feb 2022 22:13:49.345 * Background saving terminated with success
                                  139:M 20 Feb 2022 22:15:49.680 * 10000 changes in 60 seconds. Saving...
                                  139:M 20 Feb 2022 22:15:49.698 * Background saving started by pid 11703
                                  11703:C 20 Feb 2022 22:16:04.583 * DB saved on disk
                                  11703:C 20 Feb 2022 22:16:04.601 * RDB: 14 MB of memory used by copy-on-write
                                  139:M 20 Feb 2022 22:16:04.688 * Background saving terminated with success
                                  139:M 20 Feb 2022 22:18:21.814 * 10000 changes in 60 seconds. Saving...
                                  pi@ioBroker-Rock:~$ systemctl status redis
                                  * redis-server.service - Advanced key-value store
                                       Loaded: loaded (/lib/systemd/system/redis-server.service; enabled; vendor preset: enabled)
                                       Active: active (running) since Mon 2022-02-21 22:27:17 CET; 46min ago
                                         Docs: http://redis.io/documentation,
                                               man:redis-server(1)
                                      Process: 114 ExecStart=/usr/bin/redis-server /etc/redis/redis.conf (code=exited, status=0/SUCCESS)
                                     Main PID: 135 (redis-server)
                                        Tasks: 4 (limit: 18952)
                                       Memory: 1.7G
                                          CPU: 6min 39.212s
                                       CGroup: /system.slice/redis-server.service
                                               `-135 /usr/bin/redis-server 0.0.0.0:6379
                                  Fünf weitere Slave laufen aber auch problemlos mit dem Master und der Redis DB.
                                  M apollon77A 2 Antworten Letzte Antwort
                                  • E e-i-k-e
                                    Danke.
                                                 man:redis-server(1)
                                         Memory: 1.7G
                                            CPU: 6min 39.212s
                                    Marty56
                                    #557
                                    Ich beobachte einen seltsamen Effekt, den ich nicht verstehe.
                                    Ich habe iob mit dem Update auf von js-controller 4 von Objects type: jsonl
                                    States type: redis auf Objects type: jsonl States type: jsonl umgestellt, was auch ohne Probleme geklappt hat und einige Stunden stabil lief.
                                    Dann hatte ich mir gedacht, dass ich redis ausschalte, um ein bisschen Speicher zu sparen. Diese Änderung führte zu einer dramatischen Instabilität. Iob konnte kein Web Interface mehr anzeigen, die über SSH gestartet Console hat mich nach einigen Sekunden wieder rausgeschmissen und Debmatic ist auch nicht mehr gestartet. Ansonsten habe ich noch NextPVR installiert. Debmatic und NextPVR haben keine Abhängigkeiten von redis.
                                    Es wirkt so, als ob es dennoch Prozesse gibt, die immer noch redis Verfügbarkeit benötigen und wenn sie die nicht bekommen, das System extrem belasten.
                                    Gottseidank konnte ich in der kurzen Zeitspanne, in der die Console funktioniert hat, den redis Server wieder via SSH einschalten und jetzt läuft es wieder stabil.
                                    Hat jemand eine Idee? Kann man irgendwie herausbekommen, wer den Redis Server benutzt?
                                    HW:NUC (16 GB Ram)
                                    M arteckA apollon77A 3 Antworten Letzte Antwort
                                    • M Marty56
                                      Marty56
                                      schrieb am zuletzt editiert von Marty56
                                      #558
                                      gelöscht
                                      HW:NUC (16 GB Ram)
                                      F 1 Antwort Letzte Antwort
                                      • M Marty56
                                        gelöscht
                                        Fortune95
                                        #559
                                        @apollon77
                                        Node.js: v14.19.0
                                        js-controller: 4.0.15
                                        Habe gerade folgendes nach einem Neustart des Shelly Adapters im Log gefunden:
                                        2022-02-22 06:12:00.875 - error: shelly.0 (15030) uncaught exception: This socket has been ended by the other party
                                        2022-02-22 06:12:00.876 - error: shelly.0 (15030) Error: This socket has been ended by the other party
                                        at Socket.writeAfterFIN [as write] (net.js:468:14)
                                        at connack (/opt/iobroker/node_modules/mqtt-connection/node_modules/mqtt-packet/writeToStream.js:300:10)
                                        at generate (/opt/iobroker/node_modules/mqtt-connection/node_modules/mqtt-packet/writeToStream.js:32:14)
                                        at Writable.write [as _write] (/opt/iobroker/node_modules/mqtt-connection/lib/writeToStream.js:13:9)
                                        at writeOrBuffer (internal/streams/writable.js:358:12)
                                        at Writable.write (internal/streams/writable.js:303:10)
                                        at Connection.Duplexify._write (/opt/iobroker/node_modules/duplexify/index.js:208:22)
                                        at doWrite (/opt/iobroker/node_modules/duplexify/node_modules/readable-stream/lib/_stream_writable.js:428:64)
                                        at writeOrBuffer (/opt/iobroker/node_modules/duplexify/node_modules/readable-stream/lib/_stream_writable.js:417:5)
                                        at Connection.Writable.write (/opt/iobroker/node_modules/duplexify/node_modules/readable-stream/lib/_stream_writable.js:334:11)
                                        2022-02-22 06:12:00.877 - error: shelly.0 (15030) Exception-Code: EPIPE: This socket has been ended by the other party
                                        2022-02-22 06:12:00.880 - error: shelly.0 (15030) uncaught exception: This socket has been ended by the other party
                                        2022-02-22 06:12:00.880 - error: shelly.0 (15030) Error: This socket has been ended by the other party
                                        at writeVarByteInt (/opt/iobroker/node_modules/mqtt-connection/node_modules/mqtt-packet/writeToStream.js:804:17)
                                        at connack (/opt/iobroker/node_modules/mqtt-connection/node_modules/mqtt-packet/writeToStream.js:302:3)
                                        2022-02-22 06:12:00.880 - error: shelly.0 (15030) Exception-Code: EPIPE: This socket has been ended by the other party
                                        2022-02-22 06:12:00.881 - error: shelly.0 (15030) uncaught exception: This socket has been ended by the other party
                                        2022-02-22 06:12:00.881 - error: shelly.0 (15030) Error: This socket has been ended by the other party
                                        at connack (/opt/iobroker/node_modules/mqtt-connection/node_modules/mqtt-packet/writeToStream.js:303:10)
                                        2022-02-22 06:12:00.881 - error: shelly.0 (15030) Exception-Code: EPIPE: This socket has been ended by the other party
                                        2022-02-22 06:12:00.882 - error: shelly.0 (15030) uncaught exception: This socket has been ended by the other party
                                        2022-02-22 06:12:00.882 - error: shelly.0 (15030) Error: This socket has been ended by the other party
                                        at connack (/opt/iobroker/node_modules/mqtt-connection/node_modules/mqtt-packet/writeToStream.js:305:10)
                                        2022-02-22 06:12:00.882 - error: shelly.0 (15030) Exception-Code: EPIPE: This socket has been ended by the other party
                                        2022-02-22 06:12:00.883 - warn: shelly.0 (15030) Terminated (UNCAUGHT_EXCEPTION): Without reason
                                        2022-02-22 06:12:00.950 - error: host.iobroker Caught by controller[1]: Error: This socket has been ended by the other party
                                        2022-02-22 06:12:00.955 - error: host.iobroker Caught by controller[1]: at Socket.writeAfterFIN [as write] (net.js:468:14)
                                        2022-02-22 06:12:00.955 - error: host.iobroker Caught by controller[1]: at connack (/opt/iobroker/node_modules/mqtt-connection/node_modules/mqtt-packet/writeToStream.js:300:10)
                                        2022-02-22 06:12:00.955 - error: host.iobroker Caught by controller[1]: at generate (/opt/iobroker/node_modules/mqtt-connection/node_modules/mqtt-packet/writeToStream.js:32:14)
                                        2022-02-22 06:12:00.955 - error: host.iobroker Caught by controller[1]: at Writable.write [as _write] (/opt/iobroker/node_modules/mqtt-connection/lib/writeToStream.js:13:9)
                                        2022-02-22 06:12:00.955 - error: host.iobroker Caught by controller[1]: at writeOrBuffer (internal/streams/writable.js:358:12)
                                        2022-02-22 06:12:00.956 - error: host.iobroker Caught by controller[1]: at Writable.write (internal/streams/writable.js:303:10)
                                        2022-02-22 06:12:00.956 - error: host.iobroker Caught by controller[1]: at Connection.Duplexify._write (/opt/iobroker/node_modules/duplexify/index.js:208:22)
                                        2022-02-22 06:12:00.956 - error: host.iobroker Caught by controller[1]: at doWrite (/opt/iobroker/node_modules/duplexify/node_modules/readable-stream/lib/_stream_writable.js:428:64)
                                        2022-02-22 06:12:00.956 - error: host.iobroker Caught by controller[1]: at writeOrBuffer (/opt/iobroker/node_modules/duplexify/node_modules/readable-stream/lib/_stream_writable.js:417:5)
                                        2022-02-22 06:12:00.956 - error: host.iobroker Caught by controller[1]: at Connection.Writable.write (/opt/iobroker/node_modules/duplexify/node_modules/readable-stream/lib/_stream_writable.js:334:11)
                                        2022-02-22 06:12:00.956 - error: host.iobroker Caught by controller[2]: Error: This socket has been ended by the other party
                                        2022-02-22 06:12:00.956 - error: host.iobroker Caught by controller[2]: at Socket.writeAfterFIN [as write] (net.js:468:14)
                                        2022-02-22 06:12:00.956 - error: host.iobroker Caught by controller[2]: at writeVarByteInt (/opt/iobroker/node_modules/mqtt-connection/node_modules/mqtt-packet/writeToStream.js:804:17)
                                        2022-02-22 06:12:00.956 - error: host.iobroker Caught by controller[2]: at connack (/opt/iobroker/node_modules/mqtt-connection/node_modules/mqtt-packet/writeToStream.js:302:3)
                                        2022-02-22 06:12:00.957 - error: host.iobroker Caught by controller[2]: at generate (/opt/iobroker/node_modules/mqtt-connection/node_modules/mqtt-packet/writeToStream.js:32:14)
                                        2022-02-22 06:12:00.957 - error: host.iobroker Caught by controller[2]: at Writable.write [as _write] (/opt/iobroker/node_modules/mqtt-connection/lib/writeToStream.js:13:9)
                                        2022-02-22 06:12:00.957 - error: host.iobroker Caught by controller[2]: at writeOrBuffer (internal/streams/writable.js:358:12)
                                        2022-02-22 06:12:00.957 - error: host.iobroker Caught by controller[2]: at Writable.write (internal/streams/writable.js:303:10)
                                        2022-02-22 06:12:00.957 - error: host.iobroker Caught by controller[2]: at Connection.Duplexify._write (/opt/iobroker/node_modules/duplexify/index.js:208:22)
                                        2022-02-22 06:12:00.957 - error: host.iobroker Caught by controller[2]: at doWrite (/opt/iobroker/node_modules/duplexify/node_modules/readable-stream/lib/_stream_writable.js:428:64)
                                        2022-02-22 06:12:00.957 - error: host.iobroker Caught by controller[2]: at writeOrBuffer (/opt/iobroker/node_modules/duplexify/node_modules/readable-stream/lib/_stream_writable.js:417:5)
                                        2022-02-22 06:12:00.957 - error: host.iobroker Caught by controller[2]: Error: This socket has been ended by the other party
                                        2022-02-22 06:12:00.957 - error: host.iobroker Caught by controller[2]: at Socket.writeAfterFIN [as write] (net.js:468:14)
                                        2022-02-22 06:12:00.957 - error: host.iobroker Caught by controller[2]: at connack (/opt/iobroker/node_modules/mqtt-connection/node_modules/mqtt-packet/writeToStream.js:303:10)
                                        2022-02-22 06:12:00.958 - error: host.iobroker Caught by controller[2]: at generate (/opt/iobroker/node_modules/mqtt-connection/node_modules/mqtt-packet/writeToStream.js:32:14)
                                        2022-02-22 06:12:00.958 - error: host.iobroker Caught by controller[2]: at Writable.write [as _write] (/opt/iobroker/node_modules/mqtt-connection/lib/writeToStream.js:13:9)
                                        2022-02-22 06:12:00.958 - error: host.iobroker Caught by controller[2]: at writeOrBuffer (internal/streams/writable.js:358:12)
                                        2022-02-22 06:12:00.958 - error: host.iobroker Caught by controller[2]: at Writable.write (internal/streams/writable.js:303:10)
                                        2022-02-22 06:12:00.958 - error: host.iobroker Caught by controller[2]: at Connection.Duplexify._write (/opt/iobroker/node_modules/duplexify/index.js:208:22)
                                        2022-02-22 06:12:00.958 - error: host.iobroker Caught by controller[2]: at doWrite (/opt/iobroker/node_modules/duplexify/node_modules/readable-stream/lib/_stream_writable.js:428:64)
                                        2022-02-22 06:12:00.958 - error: host.iobroker Caught by controller[2]: at writeOrBuffer (/opt/iobroker/node_modules/duplexify/node_modules/readable-stream/lib/_stream_writable.js:417:5)
                                        2022-02-22 06:12:00.958 - error: host.iobroker Caught by controller[2]: at Connection.Writable.write (/opt/iobroker/node_modules/duplexify/node_modules/readable-stream/lib/_stream_writable.js:334:11)
                                        2022-02-22 06:12:00.958 - error: host.iobroker Caught by controller[3]: Error: This socket has been ended by the other party
                                        2022-02-22 06:12:00.958 - error: host.iobroker Caught by controller[3]: at Socket.writeAfterFIN [as write] (net.js:468:14)
                                        2022-02-22 06:12:00.959 - error: host.iobroker Caught by controller[3]: at connack (/opt/iobroker/node_modules/mqtt-connection/node_modules/mqtt-packet/writeToStream.js:305:10)
                                        2022-02-22 06:12:00.959 - error: host.iobroker Caught by controller[3]: at generate (/opt/iobroker/node_modules/mqtt-connection/node_modules/mqtt-packet/writeToStream.js:32:14)
                                        2022-02-22 06:12:00.959 - error: host.iobroker Caught by controller[3]: at Writable.write [as _write] (/opt/iobroker/node_modules/mqtt-connection/lib/writeToStream.js:13:9)
                                        2022-02-22 06:12:00.959 - error: host.iobroker Caught by controller[3]: at writeOrBuffer (internal/streams/writable.js:358:12)
                                        2022-02-22 06:12:00.959 - error: host.iobroker Caught by controller[3]: at Writable.write (internal/streams/writable.js:303:10)
                                        2022-02-22 06:12:00.959 - error: host.iobroker Caught by controller[3]: at Connection.Duplexify._write (/opt/iobroker/node_modules/duplexify/index.js:208:22)
                                        2022-02-22 06:12:00.961 - error: host.iobroker Caught by controller[3]: at doWrite (/opt/iobroker/node_modules/duplexify/node_modules/readable-stream/lib/_stream_writable.js:428:64)
                                        2022-02-22 06:12:00.961 - error: host.iobroker Caught by controller[3]: at writeOrBuffer (/opt/iobroker/node_modules/duplexify/node_modules/readable-stream/lib/_stream_writable.js:417:5)
                                        2022-02-22 06:12:00.962 - error: host.iobroker Caught by controller[3]: at Connection.Writable.write (/opt/iobroker/node_modules/duplexify/node_modules/readable-stream/lib/_stream_writable.js:334:11)
                                        2022-02-22 06:12:00.962 - error: host.iobroker instance system.adapter.shelly.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                        • DiginixD Diginix
                                          Swap:             0           0           0
                                          #560
                                          @diginix welche nodejs Version nutzt du?
