  4. js-controller 4.0 jetzt im BETA/LATEST!
747 Beiträge 70 Kommentatoren 289.4k Aufrufe 60 Beobachtet
  • apollon77A apollon77
    @marty56 Na klar, einfach per iob setup custom machen
    Marty56
    #550
    @apollon77 Danke. Hat unproblematisch geklappt.
    HW:NUC (16 GB Ram)
    OS: Debian Bullseye, Promox V7, node v16.x npm 8.19.3
    • E Offline
      e-i-k-e
      schrieb am zuletzt editiert von e-i-k-e
      #551
      Aktualisiere gerade ein Slave von 4.0.10 auf 4.0.15.
      Habe es nun bereits mit sudo -H -u iobroker npm install iobroker.js-controller versucht.
      Bei den anderen Geräten hatte ich dieses Problem nicht.
      Was kann ich tun?
      pi@raspberrypi-display2:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
      > iobroker.js-controller@4.0.10 preinstall /opt/iobroker/node_modules/iobroker.js-controller
      > node lib/preinstallCheck.js
      NPM version: 6.14.16
      > iobroker.js-controller@4.0.10 install /opt/iobroker/node_modules/iobroker.js-controller
      > node iobroker.js setup first
      No connection to objects 192.168.3.100:6379[redis]
      /opt/iobroker/node_modules/standard-as-callback/built/index.js:6
              throw e;
      Error: Connection is closed.
          at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25)
          at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20)
          at Object.onceWrapper (events.js:520:26)
          at Socket.emit (events.js:400:28)
          at TCP.<anonymous> (net.js:686:12)
      Emitted 'error' event on ScanStream instance at:
          at /opt/iobroker/node_modules/ioredis/built/ScanStream.js:38:22
          at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:12:23)
          at /opt/iobroker/node_modules/standard-as-callback/built/index.js:33:51
          at processTicksAndRejections (internal/process/task_queues.js:95:5)
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
      npm ERR! code ELIFECYCLE
      npm ERR! errno 1
      npm ERR! iobroker.js-controller@4.0.10 install: `node iobroker.js setup first`
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the iobroker.js-controller@4.0.10 install script.
      npm ERR!     /home/iobroker/.npm/_logs/2022-02-21T20_58_28_730Z-debug.l
      Keine Ahnung was jetzt los ist.. 😲
      pi@raspberrypi-display2:~ $ iobroker stop
      pi@raspberrypi-display2:~ $ iobroker fix
      library: loaded
      Library version=2022-02-10
      ioBroker is not installed in /opt/iobroker! Cannot fix anything...
      apollon77A 2 Antworten Letzte Antwort
      • E e-i-k-e
        Was kann ich tun?
                throw e;
        npm ERR! errno 1
        npm ERR!
        library: loaded
        #552
        @e-i-k-e Wie geht es dem Redis? Steht ggf etwas im Redis log? Ich hab das gefühl das sich der beendet mittendrin.
        E 1 Antwort Letzte Antwort
          e-i-k-e
          #553
          @apollon77
          Hast du zufällig den Pfad parat?
          Ich habe den kompletten Container inkl. Reids mal neu gestartet. Keine Änderung.
          • E e-i-k-e
            @apollon77
            #554
            @e-i-k-e
            less -R /var/log/redis/redis-server.log
            und
            systemctl status redis
            anschauen.
            • DiginixD Offline
              DiginixD Offline
              Diginix
              #555
              @AlCalzone @apollon77
              Hab eben per CLI admin, web und ws aktualisiert und dann ist der js-controller mal wieder RAM technisch eskaliert mit über 2 GB. Hat sich dann aber ohne mein Zutun wieder stabilisiert. Wahrs. reichten die 6 GB RAM der VM gerade so aus.
              Mem:           5941        4407         131           1        1402        1242
              Swap:             0           0           0
              ..:: So long! Tom ::..
              apollon77A 3 Antworten Letzte Antwort
                @e-i-k-e
                und
                anschauen.
                e-i-k-e
                #556
                Danke.
                Im Log steht immer das gleiche, nichts auffälliges.
                11670:C 20 Feb 2022 22:13:49.210 * DB saved on disk
                11670:C 20 Feb 2022 22:13:49.228 * RDB: 7 MB of memory used by copy-on-write
                139:M 20 Feb 2022 22:13:49.345 * Background saving terminated with success
                139:M 20 Feb 2022 22:15:49.680 * 10000 changes in 60 seconds. Saving...
                139:M 20 Feb 2022 22:15:49.698 * Background saving started by pid 11703
                11703:C 20 Feb 2022 22:16:04.583 * DB saved on disk
                11703:C 20 Feb 2022 22:16:04.601 * RDB: 14 MB of memory used by copy-on-write
                139:M 20 Feb 2022 22:16:04.688 * Background saving terminated with success
                139:M 20 Feb 2022 22:18:21.814 * 10000 changes in 60 seconds. Saving...
                pi@ioBroker-Rock:~$ systemctl status redis
                * redis-server.service - Advanced key-value store
                     Loaded: loaded (/lib/systemd/system/redis-server.service; enabled; vendor preset: enabled)
                     Active: active (running) since Mon 2022-02-21 22:27:17 CET; 46min ago
                       Docs: http://redis.io/documentation,
                             man:redis-server(1)
                    Process: 114 ExecStart=/usr/bin/redis-server /etc/redis/redis.conf (code=exited, status=0/SUCCESS)
                   Main PID: 135 (redis-server)
                      Tasks: 4 (limit: 18952)
                     Memory: 1.7G
                        CPU: 6min 39.212s
                     CGroup: /system.slice/redis-server.service
                             `-135 /usr/bin/redis-server 0.0.0.0:6379
                Fünf weitere Slave laufen aber auch problemlos mit dem Master und der Redis DB.
                M apollon77A 2 Antworten Letzte Antwort
                • E e-i-k-e
                  Danke.
                               man:redis-server(1)
                       Memory: 1.7G
                          CPU: 6min 39.212s
                  Marty56
                  #557
                  Ich beobachte einen seltsamen Effekt, den ich nicht verstehe.
                  Ich habe iob mit dem Update auf von js-controller 4 von Objects type: jsonl
                  States type: redis auf Objects type: jsonl States type: jsonl umgestellt, was auch ohne Probleme geklappt hat und einige Stunden stabil lief.
                  Dann hatte ich mir gedacht, dass ich redis ausschalte, um ein bisschen Speicher zu sparen. Diese Änderung führte zu einer dramatischen Instabilität. Iob konnte kein Web Interface mehr anzeigen, die über SSH gestartet Console hat mich nach einigen Sekunden wieder rausgeschmissen und Debmatic ist auch nicht mehr gestartet. Ansonsten habe ich noch NextPVR installiert. Debmatic und NextPVR haben keine Abhängigkeiten von redis.
                  Es wirkt so, als ob es dennoch Prozesse gibt, die immer noch redis Verfügbarkeit benötigen und wenn sie die nicht bekommen, das System extrem belasten.
                  Gottseidank konnte ich in der kurzen Zeitspanne, in der die Console funktioniert hat, den redis Server wieder via SSH einschalten und jetzt läuft es wieder stabil.
                  Hat jemand eine Idee? Kann man irgendwie herausbekommen, wer den Redis Server benutzt?
                  HW:NUC (16 GB Ram)
                  M arteckA apollon77A 3 Antworten Letzte Antwort
                  • M Marty56
                    Marty56
                    schrieb am zuletzt editiert von Marty56
                    #558
                    gelöscht
                    HW:NUC (16 GB Ram)
                    F 1 Antwort Letzte Antwort
                    • M Marty56
                      gelöscht
                      Fortune95
                      #559
                      @apollon77
                      Node.js: v14.19.0
                      js-controller: 4.0.15
                      Habe gerade folgendes nach einem Neustart des Shelly Adapters im Log gefunden:
                      2022-02-22 06:12:00.875 - error: shelly.0 (15030) uncaught exception: This socket has been ended by the other party
                      2022-02-22 06:12:00.876 - error: shelly.0 (15030) Error: This socket has been ended by the other party
                      at Socket.writeAfterFIN [as write] (net.js:468:14)
                      at connack (/opt/iobroker/node_modules/mqtt-connection/node_modules/mqtt-packet/writeToStream.js:300:10)
                      at generate (/opt/iobroker/node_modules/mqtt-connection/node_modules/mqtt-packet/writeToStream.js:32:14)
                      at Writable.write [as _write] (/opt/iobroker/node_modules/mqtt-connection/lib/writeToStream.js:13:9)
                      at writeOrBuffer (internal/streams/writable.js:358:12)
                      at Writable.write (internal/streams/writable.js:303:10)
                      at Connection.Duplexify._write (/opt/iobroker/node_modules/duplexify/index.js:208:22)
                      at doWrite (/opt/iobroker/node_modules/duplexify/node_modules/readable-stream/lib/_stream_writable.js:428:64)
                      at writeOrBuffer (/opt/iobroker/node_modules/duplexify/node_modules/readable-stream/lib/_stream_writable.js:417:5)
                      at Connection.Writable.write (/opt/iobroker/node_modules/duplexify/node_modules/readable-stream/lib/_stream_writable.js:334:11)
                      2022-02-22 06:12:00.877 - error: shelly.0 (15030) Exception-Code: EPIPE: This socket has been ended by the other party
                      2022-02-22 06:12:00.880 - error: shelly.0 (15030) uncaught exception: This socket has been ended by the other party
                      2022-02-22 06:12:00.880 - error: shelly.0 (15030) Error: This socket has been ended by the other party
                      at writeVarByteInt (/opt/iobroker/node_modules/mqtt-connection/node_modules/mqtt-packet/writeToStream.js:804:17)
                      at connack (/opt/iobroker/node_modules/mqtt-connection/node_modules/mqtt-packet/writeToStream.js:302:3)
                      2022-02-22 06:12:00.880 - error: shelly.0 (15030) Exception-Code: EPIPE: This socket has been ended by the other party
                      2022-02-22 06:12:00.881 - error: shelly.0 (15030) uncaught exception: This socket has been ended by the other party
                      2022-02-22 06:12:00.881 - error: shelly.0 (15030) Error: This socket has been ended by the other party
                      at connack (/opt/iobroker/node_modules/mqtt-connection/node_modules/mqtt-packet/writeToStream.js:303:10)
                      2022-02-22 06:12:00.881 - error: shelly.0 (15030) Exception-Code: EPIPE: This socket has been ended by the other party
                      2022-02-22 06:12:00.882 - error: shelly.0 (15030) uncaught exception: This socket has been ended by the other party
                      2022-02-22 06:12:00.882 - error: shelly.0 (15030) Error: This socket has been ended by the other party
                      at connack (/opt/iobroker/node_modules/mqtt-connection/node_modules/mqtt-packet/writeToStream.js:305:10)
                      2022-02-22 06:12:00.882 - error: shelly.0 (15030) Exception-Code: EPIPE: This socket has been ended by the other party
                      2022-02-22 06:12:00.883 - warn: shelly.0 (15030) Terminated (UNCAUGHT_EXCEPTION): Without reason
                      2022-02-22 06:12:00.950 - error: host.iobroker Caught by controller[1]: Error: This socket has been ended by the other party
                      2022-02-22 06:12:00.955 - error: host.iobroker Caught by controller[1]: at Socket.writeAfterFIN [as write] (net.js:468:14)
                      2022-02-22 06:12:00.955 - error: host.iobroker Caught by controller[1]: at connack (/opt/iobroker/node_modules/mqtt-connection/node_modules/mqtt-packet/writeToStream.js:300:10)
                      2022-02-22 06:12:00.955 - error: host.iobroker Caught by controller[1]: at generate (/opt/iobroker/node_modules/mqtt-connection/node_modules/mqtt-packet/writeToStream.js:32:14)
                      2022-02-22 06:12:00.955 - error: host.iobroker Caught by controller[1]: at Writable.write [as _write] (/opt/iobroker/node_modules/mqtt-connection/lib/writeToStream.js:13:9)
                      2022-02-22 06:12:00.955 - error: host.iobroker Caught by controller[1]: at writeOrBuffer (internal/streams/writable.js:358:12)
                      2022-02-22 06:12:00.956 - error: host.iobroker Caught by controller[1]: at Writable.write (internal/streams/writable.js:303:10)
                      2022-02-22 06:12:00.956 - error: host.iobroker Caught by controller[1]: at Connection.Duplexify._write (/opt/iobroker/node_modules/duplexify/index.js:208:22)
                      2022-02-22 06:12:00.956 - error: host.iobroker Caught by controller[1]: at doWrite (/opt/iobroker/node_modules/duplexify/node_modules/readable-stream/lib/_stream_writable.js:428:64)
                      2022-02-22 06:12:00.956 - error: host.iobroker Caught by controller[1]: at writeOrBuffer (/opt/iobroker/node_modules/duplexify/node_modules/readable-stream/lib/_stream_writable.js:417:5)
                      2022-02-22 06:12:00.956 - error: host.iobroker Caught by controller[1]: at Connection.Writable.write (/opt/iobroker/node_modules/duplexify/node_modules/readable-stream/lib/_stream_writable.js:334:11)
                      2022-02-22 06:12:00.956 - error: host.iobroker Caught by controller[2]: Error: This socket has been ended by the other party
                      2022-02-22 06:12:00.956 - error: host.iobroker Caught by controller[2]: at Socket.writeAfterFIN [as write] (net.js:468:14)
                      2022-02-22 06:12:00.956 - error: host.iobroker Caught by controller[2]: at writeVarByteInt (/opt/iobroker/node_modules/mqtt-connection/node_modules/mqtt-packet/writeToStream.js:804:17)
                      2022-02-22 06:12:00.956 - error: host.iobroker Caught by controller[2]: at connack (/opt/iobroker/node_modules/mqtt-connection/node_modules/mqtt-packet/writeToStream.js:302:3)
                      2022-02-22 06:12:00.957 - error: host.iobroker Caught by controller[2]: at generate (/opt/iobroker/node_modules/mqtt-connection/node_modules/mqtt-packet/writeToStream.js:32:14)
                      2022-02-22 06:12:00.957 - error: host.iobroker Caught by controller[2]: at Writable.write [as _write] (/opt/iobroker/node_modules/mqtt-connection/lib/writeToStream.js:13:9)
                      2022-02-22 06:12:00.957 - error: host.iobroker Caught by controller[2]: at writeOrBuffer (internal/streams/writable.js:358:12)
                      2022-02-22 06:12:00.957 - error: host.iobroker Caught by controller[2]: at Writable.write (internal/streams/writable.js:303:10)
                      2022-02-22 06:12:00.957 - error: host.iobroker Caught by controller[2]: at Connection.Duplexify._write (/opt/iobroker/node_modules/duplexify/index.js:208:22)
                      2022-02-22 06:12:00.957 - error: host.iobroker Caught by controller[2]: at doWrite (/opt/iobroker/node_modules/duplexify/node_modules/readable-stream/lib/_stream_writable.js:428:64)
                      2022-02-22 06:12:00.957 - error: host.iobroker Caught by controller[2]: at writeOrBuffer (/opt/iobroker/node_modules/duplexify/node_modules/readable-stream/lib/_stream_writable.js:417:5)
                      2022-02-22 06:12:00.957 - error: host.iobroker Caught by controller[2]: Error: This socket has been ended by the other party
                      2022-02-22 06:12:00.957 - error: host.iobroker Caught by controller[2]: at Socket.writeAfterFIN [as write] (net.js:468:14)
                      2022-02-22 06:12:00.957 - error: host.iobroker Caught by controller[2]: at connack (/opt/iobroker/node_modules/mqtt-connection/node_modules/mqtt-packet/writeToStream.js:303:10)
                      2022-02-22 06:12:00.958 - error: host.iobroker Caught by controller[2]: at generate (/opt/iobroker/node_modules/mqtt-connection/node_modules/mqtt-packet/writeToStream.js:32:14)
                      2022-02-22 06:12:00.958 - error: host.iobroker Caught by controller[2]: at Writable.write [as _write] (/opt/iobroker/node_modules/mqtt-connection/lib/writeToStream.js:13:9)
                      2022-02-22 06:12:00.958 - error: host.iobroker Caught by controller[2]: at writeOrBuffer (internal/streams/writable.js:358:12)
                      2022-02-22 06:12:00.958 - error: host.iobroker Caught by controller[2]: at Writable.write (internal/streams/writable.js:303:10)
                      2022-02-22 06:12:00.958 - error: host.iobroker Caught by controller[2]: at Connection.Duplexify._write (/opt/iobroker/node_modules/duplexify/index.js:208:22)
                      2022-02-22 06:12:00.958 - error: host.iobroker Caught by controller[2]: at doWrite (/opt/iobroker/node_modules/duplexify/node_modules/readable-stream/lib/_stream_writable.js:428:64)
                      2022-02-22 06:12:00.958 - error: host.iobroker Caught by controller[2]: at writeOrBuffer (/opt/iobroker/node_modules/duplexify/node_modules/readable-stream/lib/_stream_writable.js:417:5)
                      2022-02-22 06:12:00.958 - error: host.iobroker Caught by controller[2]: at Connection.Writable.write (/opt/iobroker/node_modules/duplexify/node_modules/readable-stream/lib/_stream_writable.js:334:11)
                      2022-02-22 06:12:00.958 - error: host.iobroker Caught by controller[3]: Error: This socket has been ended by the other party
                      2022-02-22 06:12:00.958 - error: host.iobroker Caught by controller[3]: at Socket.writeAfterFIN [as write] (net.js:468:14)
                      2022-02-22 06:12:00.959 - error: host.iobroker Caught by controller[3]: at connack (/opt/iobroker/node_modules/mqtt-connection/node_modules/mqtt-packet/writeToStream.js:305:10)
                      2022-02-22 06:12:00.959 - error: host.iobroker Caught by controller[3]: at generate (/opt/iobroker/node_modules/mqtt-connection/node_modules/mqtt-packet/writeToStream.js:32:14)
                      2022-02-22 06:12:00.959 - error: host.iobroker Caught by controller[3]: at Writable.write [as _write] (/opt/iobroker/node_modules/mqtt-connection/lib/writeToStream.js:13:9)
                      2022-02-22 06:12:00.959 - error: host.iobroker Caught by controller[3]: at writeOrBuffer (internal/streams/writable.js:358:12)
                      2022-02-22 06:12:00.959 - error: host.iobroker Caught by controller[3]: at Writable.write (internal/streams/writable.js:303:10)
                      2022-02-22 06:12:00.959 - error: host.iobroker Caught by controller[3]: at Connection.Duplexify._write (/opt/iobroker/node_modules/duplexify/index.js:208:22)
                      2022-02-22 06:12:00.961 - error: host.iobroker Caught by controller[3]: at doWrite (/opt/iobroker/node_modules/duplexify/node_modules/readable-stream/lib/_stream_writable.js:428:64)
                      2022-02-22 06:12:00.961 - error: host.iobroker Caught by controller[3]: at writeOrBuffer (/opt/iobroker/node_modules/duplexify/node_modules/readable-stream/lib/_stream_writable.js:417:5)
                      2022-02-22 06:12:00.962 - error: host.iobroker Caught by controller[3]: at Connection.Writable.write (/opt/iobroker/node_modules/duplexify/node_modules/readable-stream/lib/_stream_writable.js:334:11)
                      2022-02-22 06:12:00.962 - error: host.iobroker instance system.adapter.shelly.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                      • DiginixD Diginix
                        Swap:             0           0           0
                        #560
                        @diginix welche nodejs Version nutzt du?
                        • DiginixD Diginix
                          Swap:             0           0           0
                          #561
                          @diginix hast du bitte mal das log dieser Updates und paar mins davor und danach bitte? Auch: wie genau wurden die Updates ausgeführt? Einzeln? Uplgrade all?
                          • E e-i-k-e
                            Danke.
                                         man:redis-server(1)
                                 Memory: 1.7G
                                    CPU: 6min 39.212s
                            #562
                            @e-i-k-e und das log ist vom Update Zeitraum? Ja komisch. Dann Versuchs nochmal bitte
                            • M Marty56
                              arteckA Offline
                              arteckA Offline
                              arteck
                              #563
                              @marty56 zeigmal
                              iob setup custom
                              wenn alle hosts bei dir auf jsonl laufen dann ist redis überflüssig.. da läuft nix mehr im hintergrund
                              • E e-i-k-e
                                Was kann ich tun?
                                        throw e;
                                npm ERR! errno 1
                                npm ERR!
                                library: loaded
                                #564
                                @e-i-k-e bitte auch mal die Ausgabe von iob Upgrade Self zeigen.
                                M E 2 Antworten Letzte Antwort
                                • M Marty56
                                  #565
                                  @marty56 also wenn iobroker es nicht mehr nutzt dann wäre super wenn wir das in einem eigenen thread klären könnten. Wenn es so eine Auswirkung auf dein System hat dann sollte Top (falls Prozesse Amok laufen) Bzw /var/log/syslog Einblicke geben
                                  • F Fortune95
                                    @apollon77
                                    Node.js: v14.19.0
                                    #566
                                    @fortune95 ja. Issue bei shelly Bitte. Scheinbar verkraftet der es nicht so gut wenn eine MQTT Verbindung abbricht. Hat nichts mit dem Controller zu tun
                                    • arteckA arteck
                                      @marty56 zeigmal
                                      iob setup custom
                                      #567
                                      @arteck …oder eine der anderen von ihm genannten Softwares nutzen auf redis. Müsste er aber wissen ;-)) aber bitte in einem extra thread.
                                        MCU
                                        #568
                                        @apollon77 Hab gerade mal ein upgrade gemacht von 3.3.22 -> 4.0.15
                                        Sind die Fehler normal?
                                        Frische Installation , iot gestoppt, da Test-System
                                        pi@raspberrypi:~ $ iob upgrade self
                                        Update js-controller from @3.3.22 to @4.0.15
                                        npm install iobroker.js-controller@4.0.15 --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call)
                                        Server Objects 127.0.0.1:54854 Error from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.features.useSets"]
                                        Server States 127.0.0.1:51330 Error from InMemDB: Error: GET-UNSUPPORTED for namespace meta.: Data=["meta.states.protocolVersion"]
                                        Server Objects 127.0.0.1:54854 Error from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.protocolVersion"]
                                        Server States 127.0.0.1:51332 Error from InMemDB: Error: PSUBSCRIBE-UNSUPPORTED for namespace meta.: Data=["meta.*"]
                                        Server Objects 127.0.0.1:54854 Error from InMemDB: Error: Unknown LUA script load
                                        Server Objects 127.0.0.1:54854 Error from InMemDB: Error: SET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.features.useSets",{"type":"Buffer","data":[49]}]
                                        Could not migrate objects to corresponding sets: Error SET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.features.useSets",{"type":"Buffer","data":[49]}]
                                        • M MCU
                                          #569
                                          @mcu wie du im zweiten post in diesem thread klar lesen kannst. Ja sind leider normal.
