  4. js-controller 4.0 jetzt im BETA/LATEST!
747 Beiträge 70 Kommentatoren 289.4k Aufrufe 60 Beobachtet
  • E Offline
    e-i-k-e
    schrieb am zuletzt editiert von e-i-k-e
    #551
    Aktualisiere gerade ein Slave von 4.0.10 auf 4.0.15.
    Habe es nun bereits mit sudo -H -u iobroker npm install iobroker.js-controller versucht.
    Bei den anderen Geräten hatte ich dieses Problem nicht.
    Was kann ich tun?
    pi@raspberrypi-display2:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
    > iobroker.js-controller@4.0.10 preinstall /opt/iobroker/node_modules/iobroker.js-controller
    > node lib/preinstallCheck.js
    NPM version: 6.14.16
    > iobroker.js-controller@4.0.10 install /opt/iobroker/node_modules/iobroker.js-controller
    > node iobroker.js setup first
    No connection to objects 192.168.3.100:6379[redis]
    /opt/iobroker/node_modules/standard-as-callback/built/index.js:6
            throw e;
    Error: Connection is closed.
        at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25)
        at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20)
        at Object.onceWrapper (events.js:520:26)
        at Socket.emit (events.js:400:28)
        at TCP.<anonymous> (net.js:686:12)
    Emitted 'error' event on ScanStream instance at:
        at /opt/iobroker/node_modules/ioredis/built/ScanStream.js:38:22
        at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:12:23)
        at /opt/iobroker/node_modules/standard-as-callback/built/index.js:33:51
        at processTicksAndRejections (internal/process/task_queues.js:95:5)
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    npm ERR! code ELIFECYCLE
    npm ERR! errno 1
    npm ERR! iobroker.js-controller@4.0.10 install: `node iobroker.js setup first`
    npm ERR! Exit status 1
    npm ERR!
    npm ERR! Failed at the iobroker.js-controller@4.0.10 install script.
    npm ERR!     /home/iobroker/.npm/_logs/2022-02-21T20_58_28_730Z-debug.l
    Keine Ahnung was jetzt los ist.. 😲
    pi@raspberrypi-display2:~ $ iobroker stop
    pi@raspberrypi-display2:~ $ iobroker fix
    library: loaded
    Library version=2022-02-10
    ioBroker is not installed in /opt/iobroker! Cannot fix anything...
    apollon77A 2 Antworten Letzte Antwort
    • E e-i-k-e
      Was kann ich tun?
              throw e;
      npm ERR! errno 1
      npm ERR!
      library: loaded
      #552
      @e-i-k-e Wie geht es dem Redis? Steht ggf etwas im Redis log? Ich hab das gefühl das sich der beendet mittendrin.
      E 1 Antwort Letzte Antwort
      • apollon77A apollon77
        e-i-k-e
        #553
        @apollon77
        Hast du zufällig den Pfad parat?
        Ich habe den kompletten Container inkl. Reids mal neu gestartet. Keine Änderung.
        • E e-i-k-e
          @apollon77
          #554
          @e-i-k-e
          less -R /var/log/redis/redis-server.log
          und
          systemctl status redis
          anschauen.
          • DiginixD Offline
            DiginixD Offline
            Diginix
            #555
            @AlCalzone @apollon77
            Hab eben per CLI admin, web und ws aktualisiert und dann ist der js-controller mal wieder RAM technisch eskaliert mit über 2 GB. Hat sich dann aber ohne mein Zutun wieder stabilisiert. Wahrs. reichten die 6 GB RAM der VM gerade so aus.
            Mem:           5941        4407         131           1        1402        1242
            Swap:             0           0           0
            ..:: So long! Tom ::..
            apollon77A 3 Antworten Letzte Antwort
              @e-i-k-e
              und
              anschauen.
              e-i-k-e
              #556
              Danke.
              Im Log steht immer das gleiche, nichts auffälliges.
              11670:C 20 Feb 2022 22:13:49.210 * DB saved on disk
              11670:C 20 Feb 2022 22:13:49.228 * RDB: 7 MB of memory used by copy-on-write
              139:M 20 Feb 2022 22:13:49.345 * Background saving terminated with success
              139:M 20 Feb 2022 22:15:49.680 * 10000 changes in 60 seconds. Saving...
              139:M 20 Feb 2022 22:15:49.698 * Background saving started by pid 11703
              11703:C 20 Feb 2022 22:16:04.583 * DB saved on disk
              11703:C 20 Feb 2022 22:16:04.601 * RDB: 14 MB of memory used by copy-on-write
              139:M 20 Feb 2022 22:16:04.688 * Background saving terminated with success
              139:M 20 Feb 2022 22:18:21.814 * 10000 changes in 60 seconds. Saving...
              pi@ioBroker-Rock:~$ systemctl status redis
              * redis-server.service - Advanced key-value store
                   Loaded: loaded (/lib/systemd/system/redis-server.service; enabled; vendor preset: enabled)
                   Active: active (running) since Mon 2022-02-21 22:27:17 CET; 46min ago
                     Docs: http://redis.io/documentation,
                           man:redis-server(1)
                  Process: 114 ExecStart=/usr/bin/redis-server /etc/redis/redis.conf (code=exited, status=0/SUCCESS)
                 Main PID: 135 (redis-server)
                    Tasks: 4 (limit: 18952)
                   Memory: 1.7G
                      CPU: 6min 39.212s
                   CGroup: /system.slice/redis-server.service
                           `-135 /usr/bin/redis-server 0.0.0.0:6379
              Fünf weitere Slave laufen aber auch problemlos mit dem Master und der Redis DB.
              M apollon77A 2 Antworten Letzte Antwort
              • E e-i-k-e
                Danke.
                             man:redis-server(1)
                     Memory: 1.7G
                        CPU: 6min 39.212s
                Marty56
                #557
                Ich beobachte einen seltsamen Effekt, den ich nicht verstehe.
                Ich habe iob mit dem Update auf von js-controller 4 von Objects type: jsonl
                States type: redis auf Objects type: jsonl States type: jsonl umgestellt, was auch ohne Probleme geklappt hat und einige Stunden stabil lief.
                Dann hatte ich mir gedacht, dass ich redis ausschalte, um ein bisschen Speicher zu sparen. Diese Änderung führte zu einer dramatischen Instabilität. Iob konnte kein Web Interface mehr anzeigen, die über SSH gestartet Console hat mich nach einigen Sekunden wieder rausgeschmissen und Debmatic ist auch nicht mehr gestartet. Ansonsten habe ich noch NextPVR installiert. Debmatic und NextPVR haben keine Abhängigkeiten von redis.
                Es wirkt so, als ob es dennoch Prozesse gibt, die immer noch redis Verfügbarkeit benötigen und wenn sie die nicht bekommen, das System extrem belasten.
                Gottseidank konnte ich in der kurzen Zeitspanne, in der die Console funktioniert hat, den redis Server wieder via SSH einschalten und jetzt läuft es wieder stabil.
                Hat jemand eine Idee? Kann man irgendwie herausbekommen, wer den Redis Server benutzt?
                HW:NUC (16 GB Ram)
                OS: Debian Bullseye, Promox V7, node v16.x npm 8.19.3
                M arteckA apollon77A 3 Antworten Letzte Antwort
                • M Marty56
                  Marty56
                  schrieb am zuletzt editiert von Marty56
                  #558
                  gelöscht
                  HW:NUC (16 GB Ram)
                  F 1 Antwort Letzte Antwort
                  • M Marty56
                    gelöscht
                    Fortune95
                    #559
                    @apollon77
                    Node.js: v14.19.0
                    js-controller: 4.0.15
                    Habe gerade folgendes nach einem Neustart des Shelly Adapters im Log gefunden:
                    2022-02-22 06:12:00.875 - error: shelly.0 (15030) uncaught exception: This socket has been ended by the other party
                    2022-02-22 06:12:00.876 - error: shelly.0 (15030) Error: This socket has been ended by the other party
                    at Socket.writeAfterFIN [as write] (net.js:468:14)
                    at connack (/opt/iobroker/node_modules/mqtt-connection/node_modules/mqtt-packet/writeToStream.js:300:10)
                    at generate (/opt/iobroker/node_modules/mqtt-connection/node_modules/mqtt-packet/writeToStream.js:32:14)
                    at Writable.write [as _write] (/opt/iobroker/node_modules/mqtt-connection/lib/writeToStream.js:13:9)
                    at writeOrBuffer (internal/streams/writable.js:358:12)
                    at Writable.write (internal/streams/writable.js:303:10)
                    at Connection.Duplexify._write (/opt/iobroker/node_modules/duplexify/index.js:208:22)
                    at doWrite (/opt/iobroker/node_modules/duplexify/node_modules/readable-stream/lib/_stream_writable.js:428:64)
                    at writeOrBuffer (/opt/iobroker/node_modules/duplexify/node_modules/readable-stream/lib/_stream_writable.js:417:5)
                    at Connection.Writable.write (/opt/iobroker/node_modules/duplexify/node_modules/readable-stream/lib/_stream_writable.js:334:11)
                    2022-02-22 06:12:00.877 - error: shelly.0 (15030) Exception-Code: EPIPE: This socket has been ended by the other party
                    2022-02-22 06:12:00.880 - error: shelly.0 (15030) uncaught exception: This socket has been ended by the other party
                    2022-02-22 06:12:00.880 - error: shelly.0 (15030) Error: This socket has been ended by the other party
                    at writeVarByteInt (/opt/iobroker/node_modules/mqtt-connection/node_modules/mqtt-packet/writeToStream.js:804:17)
                    at connack (/opt/iobroker/node_modules/mqtt-connection/node_modules/mqtt-packet/writeToStream.js:302:3)
                    2022-02-22 06:12:00.880 - error: shelly.0 (15030) Exception-Code: EPIPE: This socket has been ended by the other party
                    2022-02-22 06:12:00.881 - error: shelly.0 (15030) uncaught exception: This socket has been ended by the other party
                    2022-02-22 06:12:00.881 - error: shelly.0 (15030) Error: This socket has been ended by the other party
                    at connack (/opt/iobroker/node_modules/mqtt-connection/node_modules/mqtt-packet/writeToStream.js:303:10)
                    2022-02-22 06:12:00.881 - error: shelly.0 (15030) Exception-Code: EPIPE: This socket has been ended by the other party
                    2022-02-22 06:12:00.882 - error: shelly.0 (15030) uncaught exception: This socket has been ended by the other party
                    2022-02-22 06:12:00.882 - error: shelly.0 (15030) Error: This socket has been ended by the other party
                    at connack (/opt/iobroker/node_modules/mqtt-connection/node_modules/mqtt-packet/writeToStream.js:305:10)
                    2022-02-22 06:12:00.882 - error: shelly.0 (15030) Exception-Code: EPIPE: This socket has been ended by the other party
                    2022-02-22 06:12:00.883 - warn: shelly.0 (15030) Terminated (UNCAUGHT_EXCEPTION): Without reason
                    2022-02-22 06:12:00.950 - error: host.iobroker Caught by controller[1]: Error: This socket has been ended by the other party
                    2022-02-22 06:12:00.955 - error: host.iobroker Caught by controller[1]: at Socket.writeAfterFIN [as write] (net.js:468:14)
                    2022-02-22 06:12:00.955 - error: host.iobroker Caught by controller[1]: at connack (/opt/iobroker/node_modules/mqtt-connection/node_modules/mqtt-packet/writeToStream.js:300:10)
                    2022-02-22 06:12:00.955 - error: host.iobroker Caught by controller[1]: at generate (/opt/iobroker/node_modules/mqtt-connection/node_modules/mqtt-packet/writeToStream.js:32:14)
                    2022-02-22 06:12:00.955 - error: host.iobroker Caught by controller[1]: at Writable.write [as _write] (/opt/iobroker/node_modules/mqtt-connection/lib/writeToStream.js:13:9)
                    2022-02-22 06:12:00.955 - error: host.iobroker Caught by controller[1]: at writeOrBuffer (internal/streams/writable.js:358:12)
                    2022-02-22 06:12:00.956 - error: host.iobroker Caught by controller[1]: at Writable.write (internal/streams/writable.js:303:10)
                    2022-02-22 06:12:00.956 - error: host.iobroker Caught by controller[1]: at Connection.Duplexify._write (/opt/iobroker/node_modules/duplexify/index.js:208:22)
                    2022-02-22 06:12:00.956 - error: host.iobroker Caught by controller[1]: at doWrite (/opt/iobroker/node_modules/duplexify/node_modules/readable-stream/lib/_stream_writable.js:428:64)
                    2022-02-22 06:12:00.956 - error: host.iobroker Caught by controller[1]: at writeOrBuffer (/opt/iobroker/node_modules/duplexify/node_modules/readable-stream/lib/_stream_writable.js:417:5)
                    2022-02-22 06:12:00.956 - error: host.iobroker Caught by controller[1]: at Connection.Writable.write (/opt/iobroker/node_modules/duplexify/node_modules/readable-stream/lib/_stream_writable.js:334:11)
                    2022-02-22 06:12:00.956 - error: host.iobroker Caught by controller[2]: Error: This socket has been ended by the other party
                    2022-02-22 06:12:00.956 - error: host.iobroker Caught by controller[2]: at Socket.writeAfterFIN [as write] (net.js:468:14)
                    2022-02-22 06:12:00.956 - error: host.iobroker Caught by controller[2]: at writeVarByteInt (/opt/iobroker/node_modules/mqtt-connection/node_modules/mqtt-packet/writeToStream.js:804:17)
                    2022-02-22 06:12:00.956 - error: host.iobroker Caught by controller[2]: at connack (/opt/iobroker/node_modules/mqtt-connection/node_modules/mqtt-packet/writeToStream.js:302:3)
                    2022-02-22 06:12:00.957 - error: host.iobroker Caught by controller[2]: at generate (/opt/iobroker/node_modules/mqtt-connection/node_modules/mqtt-packet/writeToStream.js:32:14)
                    2022-02-22 06:12:00.957 - error: host.iobroker Caught by controller[2]: at Writable.write [as _write] (/opt/iobroker/node_modules/mqtt-connection/lib/writeToStream.js:13:9)
                    2022-02-22 06:12:00.957 - error: host.iobroker Caught by controller[2]: at writeOrBuffer (internal/streams/writable.js:358:12)
                    2022-02-22 06:12:00.957 - error: host.iobroker Caught by controller[2]: at Writable.write (internal/streams/writable.js:303:10)
                    2022-02-22 06:12:00.957 - error: host.iobroker Caught by controller[2]: at Connection.Duplexify._write (/opt/iobroker/node_modules/duplexify/index.js:208:22)
                    2022-02-22 06:12:00.957 - error: host.iobroker Caught by controller[2]: at doWrite (/opt/iobroker/node_modules/duplexify/node_modules/readable-stream/lib/_stream_writable.js:428:64)
                    2022-02-22 06:12:00.957 - error: host.iobroker Caught by controller[2]: at writeOrBuffer (/opt/iobroker/node_modules/duplexify/node_modules/readable-stream/lib/_stream_writable.js:417:5)
                    2022-02-22 06:12:00.957 - error: host.iobroker Caught by controller[2]: Error: This socket has been ended by the other party
                    2022-02-22 06:12:00.957 - error: host.iobroker Caught by controller[2]: at Socket.writeAfterFIN [as write] (net.js:468:14)
                    2022-02-22 06:12:00.957 - error: host.iobroker Caught by controller[2]: at connack (/opt/iobroker/node_modules/mqtt-connection/node_modules/mqtt-packet/writeToStream.js:303:10)
                    2022-02-22 06:12:00.958 - error: host.iobroker Caught by controller[2]: at generate (/opt/iobroker/node_modules/mqtt-connection/node_modules/mqtt-packet/writeToStream.js:32:14)
                    2022-02-22 06:12:00.958 - error: host.iobroker Caught by controller[2]: at Writable.write [as _write] (/opt/iobroker/node_modules/mqtt-connection/lib/writeToStream.js:13:9)
                    2022-02-22 06:12:00.958 - error: host.iobroker Caught by controller[2]: at writeOrBuffer (internal/streams/writable.js:358:12)
                    2022-02-22 06:12:00.958 - error: host.iobroker Caught by controller[2]: at Writable.write (internal/streams/writable.js:303:10)
                    2022-02-22 06:12:00.958 - error: host.iobroker Caught by controller[2]: at Connection.Duplexify._write (/opt/iobroker/node_modules/duplexify/index.js:208:22)
                    2022-02-22 06:12:00.958 - error: host.iobroker Caught by controller[2]: at doWrite (/opt/iobroker/node_modules/duplexify/node_modules/readable-stream/lib/_stream_writable.js:428:64)
                    2022-02-22 06:12:00.958 - error: host.iobroker Caught by controller[2]: at writeOrBuffer (/opt/iobroker/node_modules/duplexify/node_modules/readable-stream/lib/_stream_writable.js:417:5)
                    2022-02-22 06:12:00.958 - error: host.iobroker Caught by controller[2]: at Connection.Writable.write (/opt/iobroker/node_modules/duplexify/node_modules/readable-stream/lib/_stream_writable.js:334:11)
                    2022-02-22 06:12:00.958 - error: host.iobroker Caught by controller[3]: Error: This socket has been ended by the other party
                    2022-02-22 06:12:00.958 - error: host.iobroker Caught by controller[3]: at Socket.writeAfterFIN [as write] (net.js:468:14)
                    2022-02-22 06:12:00.959 - error: host.iobroker Caught by controller[3]: at connack (/opt/iobroker/node_modules/mqtt-connection/node_modules/mqtt-packet/writeToStream.js:305:10)
                    2022-02-22 06:12:00.959 - error: host.iobroker Caught by controller[3]: at generate (/opt/iobroker/node_modules/mqtt-connection/node_modules/mqtt-packet/writeToStream.js:32:14)
                    2022-02-22 06:12:00.959 - error: host.iobroker Caught by controller[3]: at Writable.write [as _write] (/opt/iobroker/node_modules/mqtt-connection/lib/writeToStream.js:13:9)
                    2022-02-22 06:12:00.959 - error: host.iobroker Caught by controller[3]: at writeOrBuffer (internal/streams/writable.js:358:12)
                    2022-02-22 06:12:00.959 - error: host.iobroker Caught by controller[3]: at Writable.write (internal/streams/writable.js:303:10)
                    2022-02-22 06:12:00.959 - error: host.iobroker Caught by controller[3]: at Connection.Duplexify._write (/opt/iobroker/node_modules/duplexify/index.js:208:22)
                    2022-02-22 06:12:00.961 - error: host.iobroker Caught by controller[3]: at doWrite (/opt/iobroker/node_modules/duplexify/node_modules/readable-stream/lib/_stream_writable.js:428:64)
                    2022-02-22 06:12:00.961 - error: host.iobroker Caught by controller[3]: at writeOrBuffer (/opt/iobroker/node_modules/duplexify/node_modules/readable-stream/lib/_stream_writable.js:417:5)
                    2022-02-22 06:12:00.962 - error: host.iobroker Caught by controller[3]: at Connection.Writable.write (/opt/iobroker/node_modules/duplexify/node_modules/readable-stream/lib/_stream_writable.js:334:11)
                    2022-02-22 06:12:00.962 - error: host.iobroker instance system.adapter.shelly.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                    • DiginixD Diginix
                      Swap:             0           0           0
                      #560
                      @diginix welche nodejs Version nutzt du?
                      • DiginixD Diginix
                        Swap:             0           0           0
                        #561
                        @diginix hast du bitte mal das log dieser Updates und paar mins davor und danach bitte? Auch: wie genau wurden die Updates ausgeführt? Einzeln? Uplgrade all?
                        • E e-i-k-e
                          Danke.
                                       man:redis-server(1)
                               Memory: 1.7G
                                  CPU: 6min 39.212s
                          #562
                          @e-i-k-e und das log ist vom Update Zeitraum? Ja komisch. Dann Versuchs nochmal bitte
                          • M Marty56
                            arteckA Offline
                            arteckA Offline
                            arteck
                            #563
                            @marty56 zeigmal
                            iob setup custom
                            wenn alle hosts bei dir auf jsonl laufen dann ist redis überflüssig.. da läuft nix mehr im hintergrund
                            • E e-i-k-e
                              Was kann ich tun?
                                      throw e;
                              npm ERR! errno 1
                              npm ERR!
                              library: loaded
                              #564
                              @e-i-k-e bitte auch mal die Ausgabe von iob Upgrade Self zeigen.
                              M E 2 Antworten Letzte Antwort
                              • M Marty56
                                #565
                                @marty56 also wenn iobroker es nicht mehr nutzt dann wäre super wenn wir das in einem eigenen thread klären könnten. Wenn es so eine Auswirkung auf dein System hat dann sollte Top (falls Prozesse Amok laufen) Bzw /var/log/syslog Einblicke geben
                                • F Fortune95
                                  @apollon77
                                  Node.js: v14.19.0
                                  #566
                                  @fortune95 ja. Issue bei shelly Bitte. Scheinbar verkraftet der es nicht so gut wenn eine MQTT Verbindung abbricht. Hat nichts mit dem Controller zu tun
                                  • arteckA arteck
                                    @marty56 zeigmal
                                    iob setup custom
                                    #567
                                    @arteck …oder eine der anderen von ihm genannten Softwares nutzen auf redis. Müsste er aber wissen ;-)) aber bitte in einem extra thread.
                                      MCU
                                      #568
                                      @apollon77 Hab gerade mal ein upgrade gemacht von 3.3.22 -> 4.0.15
                                      Sind die Fehler normal?
                                      Frische Installation , iot gestoppt, da Test-System
                                      pi@raspberrypi:~ $ iob upgrade self
                                      Update js-controller from @3.3.22 to @4.0.15
                                      npm install iobroker.js-controller@4.0.15 --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call)
                                      Server Objects 127.0.0.1:54854 Error from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.features.useSets"]
                                      Server States 127.0.0.1:51330 Error from InMemDB: Error: GET-UNSUPPORTED for namespace meta.: Data=["meta.states.protocolVersion"]
                                      Server Objects 127.0.0.1:54854 Error from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.protocolVersion"]
                                      Server States 127.0.0.1:51332 Error from InMemDB: Error: PSUBSCRIBE-UNSUPPORTED for namespace meta.: Data=["meta.*"]
                                      Server Objects 127.0.0.1:54854 Error from InMemDB: Error: Unknown LUA script load
                                      Server Objects 127.0.0.1:54854 Error from InMemDB: Error: SET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.features.useSets",{"type":"Buffer","data":[49]}]
                                      Could not migrate objects to corresponding sets: Error SET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.features.useSets",{"type":"Buffer","data":[49]}]
                                      • M MCU
                                        #569
                                        @mcu wie du im zweiten post in diesem thread klar lesen kannst. Ja sind leider normal.
                                        • DiginixD Diginix
                                          Swap:             0           0           0
                                          #570
                                          @diginix Also ichhabe gerade mal mein jsonl testsystem mit upgrades maltretiert ... Mein Controller hat dort 150MB und ist meistens maximal auf 170MB hoch, einmal kurz auf 190MB, aber nur um spätestens 30s später wieder auf 150MB zu sinken ... Zeig mal bitte auch deine iobroker.json Konfig
