  4. Alpha Test js-controller 4.0
  • Neuer Installer und neuer Fixer: übersichtliche Oberfläche und `iob docker`
  • Mitmachen: Sprich „ioBroker“ ein – für ein lokales Aktivierungswort
  • Neuer Blogbeitrag: KI in ioBroker, vom Helfer im Admin bis zum eigenen Smart Assistant
196 Beiträge 20 Kommentatoren 43.4k Aufrufe 22 Beobachtet
  • FeuersturmF Feuersturm
    @apollon77
    Ich hab gerade auf die Version Alpha73 aktualisiert.
    proxmox@ioBrokerTestsystem:/opt/iobroker$ iobroker version
    4.0.0-alpha.73-20220203-4ff5b7b6
    Beim Update hatte ich wieder folgendes in der Konsole.
    - Ignoring Directory "benchmark.files" because officially not created as meta ob        ject. Please remove directory!
    - Ignoring Directory "daswetter" because officially not created as meta object.        Please remove directory!
    - Ignoring Directory "hm-rega" because officially not created as meta object. Pl        ease remove directory!
    - Ignoring Directory "iogo.admin" because officially not created as meta object.        Please remove directory!
    - Ignoring Directory "tr-064-community.admin" because officially not created as        meta object. Please remove directory!
    Ich hatte das gleiche Verhalten ja hier https://forum.iobroker.net/topic/52033/alpha-test-js-controller-4-0/45 auch schon.
    Damals hatte ich das iobroker upload all gemacht
    Meine aktuellen Objekte die angemeckert werden sehen so aus:
    foxriver76F
    foxriver76F
    foxriver76
    #121
    @feuersturm sagte in Alpha Test js-controller 4.0:
    • Ignoring Directory "benchmark.files" because officially not created as meta ob ject. Please remove directory!
    • Ignoring Directory "daswetter" because officially not created as meta object. Please remove directory!
    • Ignoring Directory "hm-rega" because officially not created as meta object. Pl ease remove directory!
    • Ignoring Directory "iogo.admin" because officially not created as meta object. Please remove directory!
    • Ignoring Directory "tr-064-community.admin" because officially not created as
    Danke, da passt was nicht, aber schon vor 4.0!
    Videotutorials & mehr
    • foxriver76F foxriver76
      @thomas-braun Benutze mal den logger statt console, sonst tauch das nicht im logfile auf. Also logger.warn('blabla')
      Thomas BraunT
      Thomas BraunT
      Most Active Developer
      #122
      @foxriver76
      Da weiß ich gerade nicht was du wo meinst...
      • M mrjeschke
        @foxriver76
        Ja sehe ich auch so. In der Doku gibt‘s aber ein Beispiel mit einem boolean
        und min+max Wert. Egal, ich habe bei allen booleans die min/max Werte gelöscht. Jetzt ist Ruhe.
        apollon77A
        apollon77A
        #123
        @maik-0 Doku wo? Muss gefixt werden
          FeuersturmF
          FeuersturmF
          Feuersturm
          #124
          @foxriver76 sagte in Alpha Test js-controller 4.0:
          Ich könnte auf einen Stand zurückgehen wo noch die 3.3.22 drauf ist.Würde das helfen? Wonach müsste ich dort schauen?
            @apollon77
            apollon77A
            apollon77A
            #125
            @feuersturm Najaok sagen wir so:
            • die mit .admin solten nach einem "upload all" weg sein - wenn die Adapter noch da sind! Wenn die Adapter ggf gelöscht sind dann File smanuell löschen, ende
            • die anderen sollten verschwinden wenn du den relevanten Adapter einmalig startest- wenn er noch da ist (sonst löschen)
            • apollon77A apollon77
              M
              M
              mrjeschke
              #126
              @apollon77
              https://www.iobroker.net/#de/documentation/dev/objectsschema.md
              Unter Kanalbeschreibungen.
                @foxriver76
                apollon77A
                apollon77A
                #127
                @thomas-braun Nee alles gut. Es ist erstmal was ich sehen wollte
                  foxriver76F
                  foxriver76F
                  foxriver76
                  #128
                  @feuersturm habe den Fehler schon gefunden, fix kommt in nächste Version
                  • M mrjeschke
                    @apollon77
                    apollon77A
                    apollon77A
                    #129
                    @maik-0 FIxed, hoffe hab alle erwischt https://github.com/ioBroker/ioBroker.docs/commit/63bcf4acc09803f1ce8fd1e03e4ba3881b3bf666
                      Thomas BraunT
                      Thomas BraunT
                      #130
                      Dieser Beitrag wurde gelöscht!
                        Thomas BraunT
                        Thomas BraunT
                        #131
                          @apollon77
                          Leider haben die Änderungen in der main.js nix gebracht, soweit ich sehe:
                          main.js hat jetzt drin:
                          Line 4443
                                                  // show for debug
                                                  console.error(text);
                                                  if (
                                                      text.includes('NODE_MODULE_VERSION') ||
                                                      text.includes('npm rebuild') ||
                                                      text.includes('Error: The module \'') ||
                                                      text.includes('Cannot find module')
                          Line 3016
                              case 'rebuildAdapter':
                                  if (!msg.message.id) {
                                      if (msg.callback && msg.from) {
                                          sendTo(msg.from, msg.command, { error: 'Adapter to rebuild not provided.' }, msg.callback);
                                  } else if (!installQueue.some(entry => entry.id === msg.message.id)) {
                                      logger.info(`${hostLogPrefix} ${msg.message.id} will be rebuilt ( ${msg.message.rebuildArgs})`);
                                      const installObj = { id: msg.message.id, rebuild: true };
                                      if (msg.message.rebuildArgs) {
                                          installObj.rebuildArgs = msg.message.rebuildArgs;
                          Leider kommt da immer noch das um's Eck:
                          2022-02-03 20:18:45.732  - info: host.chet instance system.adapter.parcel.0 started with pid 76304
                          2022-02-03 20:18:46.983  - error: host.chet Caught by controller[0]: node:internal/modules/cjs/loader:1183
                          2022-02-03 20:18:46.983  - error: host.chet Caught by controller[0]:   return process.dlopen(module, path.toNamespacedPath(filename));
                          2022-02-03 20:18:46.985  - error: host.chet Caught by controller[0]:                  ^
                          2022-02-03 20:18:46.985  - error: host.chet Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'
                          2022-02-03 20:18:46.985  - error: host.chet Caught by controller[0]: was compiled against a different Node.js version using
                          2022-02-03 20:18:46.985  - error: host.chet Caught by controller[0]: NODE_MODULE_VERSION 83. This version of Node.js requires
                          2022-02-03 20:18:46.986  - error: host.chet Caught by controller[0]: NODE_MODULE_VERSION 93. Please try re-compiling or re-installing
                          2022-02-03 20:18:46.986  - error: host.chet Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
                          2022-02-03 20:18:46.986  - error: host.chet Caught by controller[0]:     at Object.Module._extensions..node (node:internal/modules/cjs/loader:1183:18)
                          2022-02-03 20:18:46.986  - error: host.chet Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:981:32)
                          2022-02-03 20:18:46.986  - error: host.chet Caught by controller[0]:     at Function.Module._load (node:internal/modules/cjs/loader:822:12)
                          2022-02-03 20:18:46.986  - error: host.chet Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1005:19)
                          2022-02-03 20:18:46.987  - error: host.chet Caught by controller[0]:     at require (node:internal/modules/cjs/helpers:102:18)
                          2022-02-03 20:18:46.987  - error: host.chet Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/canvas/lib/bindings.js:3:18)
                          2022-02-03 20:18:46.987  - error: host.chet Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1101:14)
                          2022-02-03 20:18:46.988  - error: host.chet Caught by controller[0]:     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1153:10)
                          2022-02-03 20:18:46.988  - error: host.chet Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:981:32)
                          2022-02-03 20:18:46.988  - error: host.chet Caught by controller[0]:     at Function.Module._load (node:internal/modules/cjs/loader:822:12) {
                          2022-02-03 20:18:46.988  - error: host.chet Caught by controller[0]:   code: 'ERR_DLOPEN_FAILED'
                          2022-02-03 20:18:46.988  - error: host.chet Caught by controller[0]: }
                          2022-02-03 20:18:46.989  - error: host.chet instance system.adapter.parcel.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                          2022-02-03 20:18:46.989  - info: host.chet Adapter system.adapter.parcel.0 needs rebuild and will be restarted afterwards.
                          2022-02-03 20:18:46.989  - info: host.chet system.adapter.parcel.0 will be rebuilt ( undefined)
                          2022-02-03 20:18:46.990  - warn: host.chet adapter "parcel" seems to be installed for a different version of Node.js. Trying to rebuild it... 1 attempt
                          2022-02-03 20:18:46.991  - info: host.chet iobroker rebuild
                          2022-02-03 20:18:47.764  - info: miio.0 (76030) discover stoped after 30 seconds.
                          2022-02-03 20:18:48.067  - info: host.chet iobroker npm-rebuild: Rebuilding native modules ...
                          2022-02-03 20:19:30.209  - info: host.chet iobroker npm-rebuild: rebuilt dependencies successfully
                          2022-02-03 20:19:30.246  - info: host.chet iobroker npm-rebuild:
                          2022-02-03 20:19:30.248  - info: host.chet iobroker npm-rebuild: Rebuilding native modules done
                          2022-02-03 20:19:31.259  - info: host.chet iobroker npm-rebuild: exit 0
                          2022-02-03 20:19:31.356  - info: host.chet instance system.adapter.parcel.0 started with pid 76951
                          2022-02-03 20:19:32.606  - error: host.chet Caught by controller[0]: node:internal/modules/cjs/loader:1183
                          2022-02-03 20:19:32.606  - error: host.chet Caught by controller[0]:   return process.dlopen(module, path.toNamespacedPath(filename));
                          2022-02-03 20:19:32.607  - error: host.chet Caught by controller[0]:                  ^
                          2022-02-03 20:19:32.607  - error: host.chet Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'
                          2022-02-03 20:19:32.607  - error: host.chet Caught by controller[0]: was compiled against a different Node.js version using
                          2022-02-03 20:19:32.607  - error: host.chet Caught by controller[0]: NODE_MODULE_VERSION 83. This version of Node.js requires
                          2022-02-03 20:19:32.607  - error: host.chet Caught by controller[0]: NODE_MODULE_VERSION 93. Please try re-compiling or re-installing
                          2022-02-03 20:19:32.608  - error: host.chet Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
                          2022-02-03 20:19:32.608  - error: host.chet Caught by controller[0]:     at Object.Module._extensions..node (node:internal/modules/cjs/loader:1183:18)
                          2022-02-03 20:19:32.608  - error: host.chet Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:981:32)
                          2022-02-03 20:19:32.608  - error: host.chet Caught by controller[0]:     at Function.Module._load (node:internal/modules/cjs/loader:822:12)
                          2022-02-03 20:19:32.609  - error: host.chet Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1005:19)
                          2022-02-03 20:19:32.609  - error: host.chet Caught by controller[0]:     at require (node:internal/modules/cjs/helpers:102:18)
                          2022-02-03 20:19:32.609  - error: host.chet Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/canvas/lib/bindings.js:3:18)
                          2022-02-03 20:19:32.609  - error: host.chet Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1101:14)
                          2022-02-03 20:19:32.609  - error: host.chet Caught by controller[0]:     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1153:10)
                          2022-02-03 20:19:32.610  - error: host.chet Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:981:32)
                          2022-02-03 20:19:32.610  - error: host.chet Caught by controller[0]:     at Function.Module._load (node:internal/modules/cjs/loader:822:12) {
                          2022-02-03 20:19:32.610  - error: host.chet Caught by controller[0]:   code: 'ERR_DLOPEN_FAILED'
                          2022-02-03 20:19:32.610  - error: host.chet Caught by controller[0]: }
                          2022-02-03 20:19:32.610  - error: host.chet instance system.adapter.parcel.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                          2022-02-03 20:19:32.611  - info: host.chet Adapter system.adapter.parcel.0 needs rebuild and will be restarted afterwards.
                          2022-02-03 20:19:32.611  - info: host.chet system.adapter.parcel.0 will be rebuilt ( undefined)
                          2022-02-03 20:19:32.611  - warn: host.chet adapter "parcel" seems to be installed for a different version of Node.js. Trying to rebuild it... 2 attempt
                          2022-02-03 20:19:32.612  - info: host.chet iobroker rebuild
                          2022-02-03 20:19:33.581  - info: host.chet iobroker npm-rebuild: Rebuilding native modules ...
                          2022-02-03 20:20:15.070  - info: host.chet iobroker npm-rebuild: rebuilt dependencies successfully
                          2022-02-03 20:20:15.110  - info: host.chet iobroker npm-rebuild:
                          2022-02-03 20:20:15.111  - info: host.chet iobroker npm-rebuild: Rebuilding native modules done
                          2022-02-03 20:20:16.125  - info: host.chet iobroker npm-rebuild: exit 0
                          2022-02-03 20:20:16.265  - info: host.chet instance system.adapter.parcel.0 started with pid 77583
                          2022-02-03 20:20:17.605  - error: host.chet Caught by controller[0]: node:internal/modules/cjs/loader:1183
                          2022-02-03 20:20:17.606  - error: host.chet Caught by controller[0]:   return process.dlopen(module, path.toNamespacedPath(filename));
                          2022-02-03 20:20:17.606  - error: host.chet Caught by controller[0]:                  ^
                          2022-02-03 20:20:17.606  - error: host.chet Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'
                          2022-02-03 20:20:17.606  - error: host.chet Caught by controller[0]: was compiled against a different Node.js version using
                          2022-02-03 20:20:17.606  - error: host.chet Caught by controller[0]: NODE_MODULE_VERSION 83. This version of Node.js requires
                          2022-02-03 20:20:17.606  - error: host.chet Caught by controller[0]: NODE_MODULE_VERSION 93. Please try re-compiling or re-installing
                          2022-02-03 20:20:17.606  - error: host.chet Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
                          2022-02-03 20:20:17.607  - error: host.chet Caught by controller[0]:     at Object.Module._extensions..node (node:internal/modules/cjs/loader:1183:18)
                          2022-02-03 20:20:17.607  - error: host.chet Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:981:32)
                          2022-02-03 20:20:17.607  - error: host.chet Caught by controller[0]:     at Function.Module._load (node:internal/modules/cjs/loader:822:12)
                          2022-02-03 20:20:17.607  - error: host.chet Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1005:19)
                          2022-02-03 20:20:17.607  - error: host.chet Caught by controller[0]:     at require (node:internal/modules/cjs/helpers:102:18)
                          2022-02-03 20:20:17.607  - error: host.chet Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/canvas/lib/bindings.js:3:18)
                          2022-02-03 20:20:17.608  - error: host.chet Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1101:14)
                          2022-02-03 20:20:17.608  - error: host.chet Caught by controller[0]:     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1153:10)
                          2022-02-03 20:20:17.608  - error: host.chet Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:981:32)
                          2022-02-03 20:20:17.608  - error: host.chet Caught by controller[0]:     at Function.Module._load (node:internal/modules/cjs/loader:822:12) {
                          2022-02-03 20:20:17.608  - error: host.chet Caught by controller[0]:   code: 'ERR_DLOPEN_FAILED'
                          2022-02-03 20:20:17.609  - error: host.chet Caught by controller[0]: }
                          2022-02-03 20:20:17.609  - error: host.chet instance system.adapter.parcel.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                          2022-02-03 20:20:17.609  - info: host.chet Adapter system.adapter.parcel.0 needs rebuild and will be restarted afterwards.
                          2022-02-03 20:20:17.610  - info: host.chet system.adapter.parcel.0 will be rebuilt ( undefined)
                          2022-02-03 20:20:17.610  - warn: host.chet adapter "parcel" seems to be installed for a different version of Node.js. Trying to rebuild it... 3 attempt
                          2022-02-03 20:20:17.610  - info: host.chet iobroker rebuild
                          2022-02-03 20:20:18.792  - info: host.chet iobroker npm-rebuild: Rebuilding native modules ...
                          2022-02-03 20:21:00.528  - info: host.chet iobroker npm-rebuild: rebuilt dependencies successfully
                          2022-02-03 20:21:00.570  - info: host.chet iobroker npm-rebuild:
                          2022-02-03 20:21:00.571  - info: host.chet iobroker npm-rebuild: Rebuilding native modules done
                          2022-02-03 20:21:01.582  - info: host.chet iobroker npm-rebuild: exit 0
                          2022-02-03 20:21:01.677  - info: host.chet instance system.adapter.parcel.0 started with pid 78216
                          2022-02-03 20:21:02.929  - error: host.chet Caught by controller[0]: node:internal/modules/cjs/loader:1183
                          2022-02-03 20:21:02.929  - error: host.chet Caught by controller[0]:   return process.dlopen(module, path.toNamespacedPath(filename));
                          2022-02-03 20:21:02.930  - error: host.chet Caught by controller[0]:                  ^
                          2022-02-03 20:21:02.930  - error: host.chet Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'
                          2022-02-03 20:21:02.930  - error: host.chet Caught by controller[0]: was compiled against a different Node.js version using
                          2022-02-03 20:21:02.930  - error: host.chet Caught by controller[0]: NODE_MODULE_VERSION 83. This version of Node.js requires
                          2022-02-03 20:21:02.930  - error: host.chet Caught by controller[0]: NODE_MODULE_VERSION 93. Please try re-compiling or re-installing
                          2022-02-03 20:21:02.931  - error: host.chet Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
                          2022-02-03 20:21:02.931  - error: host.chet Caught by controller[0]:     at Object.Module._extensions..node (node:internal/modules/cjs/loader:1183:18)
                          2022-02-03 20:21:02.931  - error: host.chet Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:981:32)
                          2022-02-03 20:21:02.931  - error: host.chet Caught by controller[0]:     at Function.Module._load (node:internal/modules/cjs/loader:822:12)
                          2022-02-03 20:21:02.931  - error: host.chet Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1005:19)
                          2022-02-03 20:21:02.932  - error: host.chet Caught by controller[0]:     at require (node:internal/modules/cjs/helpers:102:18)
                          2022-02-03 20:21:02.932  - error: host.chet Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/canvas/lib/bindings.js:3:18)
                          2022-02-03 20:21:02.932  - error: host.chet Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1101:14)
                          2022-02-03 20:21:02.933  - error: host.chet Caught by controller[0]:     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1153:10)
                          2022-02-03 20:21:02.933  - error: host.chet Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:981:32)
                          2022-02-03 20:21:02.933  - error: host.chet Caught by controller[0]:     at Function.Module._load (node:internal/modules/cjs/loader:822:12) {
                          2022-02-03 20:21:02.934  - error: host.chet Caught by controller[0]:   code: 'ERR_DLOPEN_FAILED'
                          2022-02-03 20:21:02.934  - error: host.chet Caught by controller[0]: }
                          2022-02-03 20:21:02.934  - error: host.chet instance system.adapter.parcel.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                          2022-02-03 20:21:02.934  - info: host.chet Rebuild for adapter system.adapter.parcel.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
                          foxriver76F
                          foxriver76F
                          foxriver76
                          #132
                          @thomas-braun sagte in Alpha Test js-controller 4.0:
                          Das meinte ich nur, aber ihr seid ja schon in Kontakt - all good ;-)
                            apollon77A
                            apollon77A
                            #133
                            @foxriver76 Jo das ist original im Code drin von uns :-))
                              Thomas BraunT
                              Thomas BraunT
                              #134
                                [[topic:post-is-deleted]]
                                Thomas BraunT
                                Thomas BraunT
                                #135
                                • apollon77A
                                  apollon77A
                                  #136
                                  So, dann sind wir nun mit @next bei alpha.74 :-)
                                  • (Apollon77) Optimize rebuild handling
                                  • (foxriver76) Optimize meta object sync
                                    @wendy2702 Ja, hatte ich danach auch gesehen :-)) und das finde ich mega interessant weil "iob fix" an sich das alles glatt ziehen sollte. zeig mal "ls -la" von so einem der angemeckerten Verzeichnisse, vllt sieht man ja was.
                                    Ansonsten (wenn keinem sonst mehr was einfällt) wäre ich bei nem krassen neustart "node_modules löschen", controller manuell installieren, starten ... dann installiert der alle adapter neu
                                    wendy2702W
                                    wendy2702W
                                    wendy2702
                                    #137
                                    @apollon77 sagte in Alpha Test js-controller 4.0:
                                    Guten Morgen,
                                    Holzhammer probiert:
                                    mirko@iobroker:/opt/iobroker$ sudo rm -r node_modules
                                    [sudo] password for mirko:
                                    mirko@iobroker:/opt/iobroker$ ls -la
                                    total 1036
                                    drwxrwxr-x+ 10 iobroker iobroker   4096 Feb  4 07:41 .
                                    drwxr-xr-x   4 root     root       4096 Jan 10  2021 ..
                                    -rw-rwxr--+  1 iobroker iobroker     91 Feb  3 17:11 .npmrc
                                    -rw-rwxr--+  1 iobroker iobroker   1049 Mar 31  2020 CHANGELOG_FIXER_LINUX.md
                                    -rw-rwxr--+  1 iobroker iobroker   3556 Mar 31  2020 CHANGELOG_INSTALLER_LINUX.md
                                    -rw-rwxr--+  1 iobroker iobroker      0 Jul 11  2020 GarageKlein_Einfahrt_JPG.txt
                                    -rw-rwxr--+  1 iobroker iobroker      0 Jul 11  2020 GarageKlein_JPG.txt
                                    -rw-rwxr--+  1 iobroker iobroker      0 Jul 11  2020 Haustuer_JPG.txt
                                    -rwxrwxrwx+  1 iobroker iobroker    359 Feb  3 17:11 INSTALLER_INFO.txt
                                    -rw-rwxr--+  1 iobroker iobroker   1137 Mar 31  2020 LICENSE
                                    -rw-rwxr--+  1 iobroker iobroker   6101 Mar 31  2020 README.md
                                    drwxrwxrwx+  2 iobroker iobroker   4096 Feb  3 16:40 backups
                                    drwxrwxr-x+  2 iobroker iobroker   4096 Jan 29 15:02 cache
                                    -rw-rwxr--+  1 iobroker iobroker  23988 Mar 31  2020 fix_installation.sh
                                    drwxrwxr-x+  2 iobroker iobroker  12288 Aug 22 12:56 history
                                    drwxrwxr-x+  3 iobroker iobroker   4096 Mar 31  2020 install
                                    lrwxrwxrwx   1 iobroker iobroker     22 Feb  3 17:11 iob -> /opt/iobroker/iobroker
                                    -rwxr-xr-x+  1 iobroker iobroker    305 Feb  3 17:11 iobroker
                                    drwxrwxr-x+ 14 iobroker iobroker   4096 Feb  4 07:39 iobroker-data
                                    drwxrwxr-x+  2 iobroker iobroker   4096 Mar 31  2020 lib
                                    drwxrwxr-x+  2 iobroker iobroker   4096 Feb  4 07:39 log
                                    -rw-rwxr--+  1 iobroker iobroker 129561 Feb  4 07:26 out2.mp4
                                    -rw-rwxr--+  1 iobroker iobroker 169136 Feb  4 05:47 out3.mp4
                                    -rw-rwxr--+  1 iobroker iobroker 637615 Feb  3 18:10 package-lock.json
                                    -rw-rwxr--+  1 iobroker iobroker   3392 Feb  3 18:10 package.json
                                    -rw-rwxr--+  1 iobroker iobroker   5693 Feb  3 17:06 reinstall.js
                                    drwxrwxrwx+  5 iobroker iobroker   4096 Jan 10  2021 scripte-backup
                                    mirko@iobroker:/opt/iobroker$ npm i iobroker.js-controller@next
                                    npm WARN tarball tarball data for iobroker.icons-open-icon-library-png@https://github.com/ioBroker/ioBroker.icons-open-icon-library-png/tarball/master (sha512-qGFFRFfv/uSaVT+z3v01bwdZYjfIES0YwaHNOgy+OO28NMa8/8fh2rkBKGHNeHfFPBTo3juTeH+p6ngZ6s//7w==) seems to be corrupted. Trying one more time.
                                    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents):
                                    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
                                    npm ERR! code EINTEGRITY
                                    npm ERR! Verification failed while extracting iobroker.icons-open-icon-library-png@https://github.com/ioBroker/ioBroker.icons-open-icon-library-png/tarball/master:
                                    npm ERR! sha512-qGFFRFfv/uSaVT+z3v01bwdZYjfIES0YwaHNOgy+OO28NMa8/8fh2rkBKGHNeHfFPBTo3juTeH+p6ngZ6s//7w== integrity checksum failed when using sha512: wanted sha512-qGFFRFfv/uSaVT+z3v01bwdZYjfIES0YwaHNOgy+OO28NMa8/8fh2rkBKGHNeHfFPBTo3juTeH+p6ngZ6s//7w== but got sha512-ZH4lj95sM6IpZEL2H1HR0hXTo6GMqbUBPbQyylgdRd6TDEdU+fgohUVGW4gPI0UnrAzqM/kx5+mozLqCVh2DCg==. (64751136 bytes)
                                    npm ERR!     /home/iobroker/.npm/_logs/2022-02-04T06_43_35_307Z-debug.log
                                    Hier das npm log:
                                    iob startet nicht.
                                    arteckA apollon77A 2 Antworten Letzte Antwort
                                    • wendy2702W wendy2702
                                      Guten Morgen,
                                      total 1036
                                      Hier das npm log:
                                      iob startet nicht.
                                      arteckA
                                      arteckA
                                      arteck
                                      #138
                                      @wendy2702 da stimmt mit dem REPO was nicht
                                      bekomme es nichtmal installiert
                                      liegt nicht am 4.x
                                      wendy2702W apollon77A 2 Antworten Letzte Antwort
                                      • arteckA arteck
                                        liegt nicht am 4.x
                                        wendy2702W
                                        wendy2702W
                                        wendy2702
                                        #139
                                        @arteck sagte in Alpha Test js-controller 4.0:
                                        Danke!
                                        JS4.0 mag mich scheinbar nicht :-)
                                        • wendy2702W
                                          wendy2702W
                                          wendy2702
                                          #140
                                          Habe gerade etwas Zeit. Neuen LXC aufgesetzt mit Debian 11. iobroker frisch installiert per einzeiler. Dann versucht JS4 zu installieren und wieder erhalte ich die "missing write access" fehler.
                                          Hier das vollständige inklusive installation:
                                          mirko@iobroker:~$ sudo apt update && sudo apt full-upgrade
                                          Wir gehen davon aus, dass der lokale Systemadministrator Ihnen die
                                          Regeln erklärt hat.  Normalerweise läuft es auf drei Regeln hinaus:
                                              #1) Respektieren Sie die Privatsphäre anderer.
                                              #2) Denken Sie nach, bevor Sie tippen.
                                              #3) Mit großer Macht kommt große Verantwortung.
                                          [sudo] Passwort für mirko:
                                          OK:1 http://security.debian.org/debian-security bullseye-security InRelease
                                          OK:2 http://ftp.halifax.rwth-aachen.de/debian bullseye InRelease
                                          OK:3 http://ftp.halifax.rwth-aachen.de/debian bullseye-updates InRelease
                                          Alle Pakete sind aktuell.
                                          Paketaktualisierung (Upgrade) wird berechnet… Fertig
                                          0 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
                                          mirko@iobroker:~$ curl -sLf https://iobroker.net/install.sh | bash -
                                          -bash: curl: Kommando nicht gefunden.
                                          mirko@iobroker:~$ sudo apt install curl
                                          Die folgenden zusätzlichen Pakete werden installiert:
                                            libcurl4
                                          Die folgenden NEUEN Pakete werden installiert:
                                            curl libcurl4
                                          0 aktualisiert, 2 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
                                          Es müssen 608 kB an Archiven heruntergeladen werden.
                                          Nach dieser Operation werden 1.186 kB Plattenplatz zusätzlich benutzt.
                                          Möchten Sie fortfahren? [J/n] j
                                          Holen:1 http://ftp.halifax.rwth-aachen.de/debian bullseye/main amd64 libcurl4 amd64 7.74.0-1.3+deb11u1 [341 kB]
                                          Holen:2 http://ftp.halifax.rwth-aachen.de/debian bullseye/main amd64 curl amd64 7.74.0-1.3+deb11u1 [267 kB]
                                          Es wurden 608 kB in 0 s geholt (3.144 kB/s).
                                          Vormals nicht ausgewähltes Paket libcurl4:amd64 wird gewählt.
                                          (Lese Datenbank ... 33963 Dateien und Verzeichnisse sind derzeit installiert.)
                                          Vorbereitung zum Entpacken von .../libcurl4_7.74.0-1.3+deb11u1_amd64.deb ...
                                          Entpacken von libcurl4:amd64 (7.74.0-1.3+deb11u1) ...
                                          Vormals nicht ausgewähltes Paket curl wird gewählt.
                                          Vorbereitung zum Entpacken von .../curl_7.74.0-1.3+deb11u1_amd64.deb ...
                                          Entpacken von curl (7.74.0-1.3+deb11u1) ...
                                          libcurl4:amd64 (7.74.0-1.3+deb11u1) wird eingerichtet ...
                                          curl (7.74.0-1.3+deb11u1) wird eingerichtet ...
                                          Trigger für man-db (2.9.4-2) werden verarbeitet ...
                                          Trigger für libc-bin (2.31-13+deb11u2) werden verarbeitet ...
                                          library: loaded
                                          Library version=2021-12-27
                                              Welcome to the ioBroker installer!
                                              Installer version: 2021-12-27
                                              You might need to enter your password a couple of times.
                                              Installing prerequisites (1/4)
                                          OK:1 http://ftp.halifax.rwth-aachen.de/debian bullseye InRelease
                                          OK:2 http://security.debian.org/debian-security bullseye-security InRelease
                                              Node.js not found. Installing...
                                          ## Installing the NodeSource Node.js 14.x repo...
                                          ## Populating apt-get cache...
                                          + apt-get update
                                          ## Installing packages required for setup: gnupg...
                                          + apt-get install -y gnupg > /dev/null 2>&1
                                          ## Confirming "bullseye" is supported...
                                          + curl -sLf -o /dev/null 'https://deb.nodesource.com/node_14.x/dists/bullseye/Release'
                                          ## Adding the NodeSource signing key to your keyring...
                                          + curl -s https://deb.nodesource.com/gpgkey/nodesource.gpg.key | gpg --dearmor | tee /usr/share/keyrings/nodesource.gpg >/dev/null
                                          ## Creating apt sources list file for the NodeSource Node.js 14.x repo...
                                          + echo 'deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_14.x bullseye main' > /etc/apt/sources.list.d/nodesource.list
                                          + echo 'deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_14.x bullseye main' >> /etc/apt/sources.list.d/nodesource.list
                                          ## Running `apt-get update` for you...
                                          + apt-get update
                                          Holen:4 https://deb.nodesource.com/node_14.x bullseye InRelease [4.586 B]
                                          Holen:5 https://deb.nodesource.com/node_14.x bullseye/main amd64 Packages [773 B]
                                          Es wurden 5.359 B in 1 s geholt (4.229 B/s).
                                          ## Run `sudo apt-get install -y nodejs` to install Node.js 14.x and npm
                                          ## You may also need development tools to build native addons:
                                               sudo apt-get install gcc g++ make
                                          ## To install the Yarn package manager, run:
                                               curl -sL https://dl.yarnpkg.com/debian/pubkey.gpg | gpg --dearmor | sudo tee /usr/share/keyrings/yarnkey.gpg >/dev/null
                                               echo "deb [signed-by=/usr/share/keyrings/yarnkey.gpg] https://dl.yarnpkg.com/debian stable main" | sudo tee /etc/apt/sources.list.d/yarn.list
                                               sudo apt-get update && sudo apt-get install yarn
                                          Installed nodejs
                                          Node.js Installed successfully!
                                          Changing npm registry to https://registry.npmjs.org
                                          Installed acl
                                          Installed build-essential
                                          Installed gcc-c++
                                          Installed libavahi-compat-libdnssd-dev
                                          Installed libudev-dev
                                          Installed libpam0g-dev
                                          Installed git
                                          Installed unzip
                                          Installed libcairo2-dev
                                          Installed libpango1.0-dev
                                          Installed libjpeg-dev
                                          Installed libgif-dev
                                          Installed librsvg2-dev
                                          Installed net-tools
                                          Installed python-dev
                                          Installed cmake
                                              Creating ioBroker user and directory (2/4)
                                          User iobroker created
                                          Created /etc/sudoers.d/iobroker
                                          Directory /opt/iobroker created
                                              Installing ioBroker (3/4)
                                          In file included from ../../nan/nan.h:58,
                                                           from ../src/main.cpp:3:
                                          /home/mirko/.cache/node-gyp/14.19.0/include/node/node.h:793:7: warning: cast between incompatible function types from ‘void (*)(v8::Local<v8::Object>)’ to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
                                            793 |       (node::addon_register_func) (regfunc),                          \
                                          /home/mirko/.cache/node-gyp/14.19.0/include/node/node.h:827:3: note: in expansion of macro ‘NODE_MODULE_X’
                                            827 |   NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
                                          ../src/main.cpp:42:1: note: in expansion of macro ‘NODE_MODULE’
                                             42 | NODE_MODULE(diskusage, Init)
                                                           from ../src/unix_dgram.cc:5:
                                          ../src/unix_dgram.cc:404:1: note: in expansion of macro ‘NODE_MODULE’
                                            404 | NODE_MODULE(unix_dgram, Initialize)
                                          ATTENTION: Error reporting via Sentry will be activated on next start of ioBroker
                                          ioBroker wants to make sure to deliver the most stable smart home system.
                                          To allow this we decided to implement an automatic error and crash reporting solution into the js-controller and also into adapters.
                                          THIS REPORTING WILL BE ENABLED WITH THE NEXT START OF YOUR IOBROKER!
                                          For any error that leads to the crash of the js-controller or one of the relevant adapters the error details are send to a server. For the js-controller and core adapters this server is located and operated in germany. For community adapters please check the Github Readme of the affected adapter for details which Sentry server is used.
                                          If you want to disable the error reporting you can use the command
                                          'iobroker plugin disable sentry'
                                          This command will also make sure that no adapter that runs on this host will send crash reporting data to sentry.
                                              Finalizing installation (4/4)
                                          Enabling autostart...
                                          Created symlink /etc/systemd/system/multi-user.target.wants/iobroker.service → /lib/systemd/system/iobroker.service.
                                          Autostart enabled!
                                              ioBroker was installed successfully
                                              Open http://192.168.178.108:8081 in a browser and start configuring!
                                          You need to re-login before doing anything else on the console!
                                          mirko@iobroker:~$ iob -v
                                          3.3.22
                                          mirko@iobroker:~$ iob stop
                                          mirko@iobroker:~$ iob update
                                          Used repository: default
                                          hash changed or no sources cached => force download of new sources
                                          update done
                                          Adapter    "admin"         : 5.2.3    , installed 5.2.3
                                          Adapter    "backitup"      : 2.2.3    , installed 2.2.3
                                          Adapter    "discovery"     : 2.7.3    , installed 2.7.3
                                          Controller "js-controller" : 3.3.22   , installed 3.3.22
                                          mirko@iobroker:~$ cd /opt/iobroker/
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@iobroker/db-base/node_modules/fs-extra
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@iobroker/db-objects-file/node_modules/fs-extra
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@iobroker/db-objects-jsonl/node_modules/fs-extra
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/alcalzone-shared
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@alcalzone/jsonl-db
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/@types/node
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/@types/iobroker
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/adapter-core
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/array-flatten
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/assert-plus
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/asynckit
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/aws-sign2
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/aws4
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/bytes
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/caseless
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/connect-flash
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/content-type
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/cookie
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/cookie-signature
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/cookie-parser
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/core-util-is
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/dashdash
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/delayed-stream
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/combined-stream
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/depd
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/destroy
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/ee-first
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/encodeurl
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/escape-html
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/etag
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/express-session/node_modules/depd
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/extend
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/extsprintf
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/fast-deep-equal
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/fast-json-stable-stringify
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/forever-agent
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/forwarded
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/fresh
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/getpass
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/har-schema
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/inherits
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/ipaddr.js
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/is-typedarray
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/isstream
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/jsbn
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/json-schema
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/json-schema-traverse
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/json-stringify-safe
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/media-typer
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/merge-descriptors
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/methods
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/mime
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/mime-db
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/mime-types
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/form-data
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/ms
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/debug
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/negotiator
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/accepts
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/oauth-sign
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/on-finished
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/on-headers
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/parseurl
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/passport-strategy
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/passport-local
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/path-to-regexp
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/pause
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/performance-now
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/proxy-addr
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/psl
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/punycode
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/qs
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/random-bytes
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/range-parser
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/request/node_modules/qs
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/safe-buffer
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/content-disposition
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/safer-buffer
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/asn1
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/ecc-jsbn
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/iconv-lite
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/send/node_modules/ms
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/setprototypeof
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/statuses
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/streamsearch
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/dicer
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/busboy
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/express-fileupload
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/toidentifier
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/http-errors
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/serve-static
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/tough-cookie
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/tunnel-agent
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/tweetnacl
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/bcrypt-pbkdf
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/sshpk
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/type-is
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/uid-safe
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/unpipe
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/finalhandler
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/raw-body
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/body-parser
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/uri-js
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/har-validator
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/utils-merge
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/ajv
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/uuid
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/vary
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/verror
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/http-signature
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/jsprim
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/ws
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/xtend
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/passport.socketio
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/yallist
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/lru-cache
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/semver
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/@types/node
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/@types/iobroker
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/@iobroker/adapter-core
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/agent-base
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/array-flatten
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/arrify
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/assert-plus
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/asynckit
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/aws-sign2
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/aws4
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/balanced-match
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/base-64
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/base64-js
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/bignumber.js
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/body-parser/node_modules/ms
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/body-parser/node_modules/debug
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/body-parser/node_modules/qs
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/buffer-equal-constant-time
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/bytes
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/caseless
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/charenc
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/chownr
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/concat-map
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/brace-expansion
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/content-type
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/cookie
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/cookie-signature
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/core-util-is
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/crypt
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/dashdash
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/delayed-stream
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/combined-stream
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/depd
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/destroy
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/ee-first
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/encodeurl
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/escape-html
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/etag
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/event-target-shim
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/abort-controller
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/express/node_modules/ms
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/express/node_modules/debug
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/express/node_modules/qs
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/extend
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/extsprintf
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/fast-deep-equal
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/fast-json-stable-stringify
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/fast-text-encoding
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/finalhandler/node_modules/ms
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/finalhandler/node_modules/debug
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/follow-redirects
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/axios
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/forever-agent
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/forwarded
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/fresh
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/fs-constants
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/function-bind
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/getpass
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/graceful-fs
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/har-schema
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/has
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/has-symbols
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/get-intrinsic
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/call-bind
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/he
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/hot-patcher
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/https-proxy-agent
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/ieee754
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/inherits
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/ipaddr.js
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/is-buffer
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/is-stream
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/is-typedarray
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/isarray
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/isstream
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/jsbn
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/json-bigint
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/json-schema
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/json-schema-traverse
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/json-stringify-safe
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/layerr
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/long-timeout
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/luxon
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/md5
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/media-typer
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/merge-descriptors
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/methods
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/mime
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/mime-db
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/mime-types
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/form-data
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/minimatch
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/mkdirp-classic
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/negotiator
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/accepts
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/nested-property
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/node-forge
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/google-p12-pem
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/node-wol
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/oauth-sign
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/object-inspect
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/object-keys
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/define-properties
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/is-nan
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/cron-parser
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/on-finished
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/parseurl
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/path-posix
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/path-to-regexp
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/performance-now
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/proxy-addr
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/psl
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/punycode
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/querystringify
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/range-parser
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/request/node_modules/qs
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/request/node_modules/uuid
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/requires-port
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/safe-buffer
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/bl/node_modules/string_decoder
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/content-disposition
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/ecdsa-sig-formatter
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/jwa
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/jws
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/safer-buffer
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/asn1
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/ecc-jsbn
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/iconv-lite
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/send/node_modules/debug/node_modules/ms
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/send/node_modules/ms
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/setprototypeof
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/side-channel
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/qs
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/sorted-array-functions
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/node-schedule
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/statuses
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/string_decoder
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/readable-stream
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/strnum
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/fast-xml-parser
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/tar-stream/node_modules/string_decoder
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/toidentifier
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/http-errors
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/serve-static
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/tough-cookie
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/tr46
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/tunnel-agent
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/tweetnacl
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/bcrypt-pbkdf
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/sshpk
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/type-is
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/universalify
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/jsonfile
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/fs-extra
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/unpipe
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/raw-body
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/uri-js
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/ajv
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/har-validator
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/url-join
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/url-parse
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/url-template
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/util-deprecate
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/bl/node_modules/readable-stream
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/tar-stream/node_modules/readable-stream
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/utils-merge
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/uuid
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/vary
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/verror
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/jsprim
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/http-signature
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/dropbox-v2-api
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/webdav
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/webidl-conversions
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/whatwg-url
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/node-fetch
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/gaxios
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/gcp-metadata
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/gtoken
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/wrappy
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/once
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/end-of-stream
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/pump
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/tar-fs
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/xregexp
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/ftp
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/yallist
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/lru-cache
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/google-auth-library
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/googleapis-common
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/@googleapis/drive
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/binding-abstract/node_modules/ms
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/binding-abstract/node_modules/debug
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/binding-mock/node_modules/ms
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/binding-mock/node_modules/debug
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/bindings/node_modules/ms
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/bindings/node_modules/debug
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/parser-byte-length
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/parser-cctalk
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/parser-delimiter
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/parser-inter-byte-timeout
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/parser-readline
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/parser-ready
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/parser-regex
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/stream/node_modules/ms
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/stream/node_modules/debug
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@types/node
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@types/iobroker
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@iobroker/adapter-core
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/ansi-regex
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/aproba
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/base64-js
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/bluebird
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/chownr
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/code-point-at
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/console-control-strings
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/core-util-is
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/deep-extend
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/delegates
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/detect-libc
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/dgram
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/expand-template
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/extend
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/file-uri-to-path
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/bindings
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/fs-constants
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/github-from-package
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/has-unicode
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/ieee754
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/buffer
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/inherits
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/ini
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/ip
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/isarray
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/lodash
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/async
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/mimic-response
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/decompress-response
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/minimist
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/mkdirp-classic
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/ms
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/debug
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/nan
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/napi-build-utils
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/netmask
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/node-mndp
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/node-ssdp/node_modules/ms
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/node-ssdp/node_modules/debug
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/number-is-nan
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/is-fullwidth-code-point
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/object-assign
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/process-nextick-args
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/readable-stream/node_modules/safe-buffer
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/safe-buffer
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/dns-packet
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/mdns-discovery
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/serialport/node_modules/ms
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/serialport/node_modules/debug
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/set-blocking
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/signal-exit
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/simple-concat
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/string_decoder/node_modules/safe-buffer
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/strip-ansi
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/string-width
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/strip-json-comments
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/rc
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/tunnel-agent
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/util-deprecate
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/bl/node_modules/readable-stream
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/are-we-there-yet
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/tar-stream/node_modules/readable-stream
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/wide-align
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/gauge
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/npmlog
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/wrappy
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/once
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/end-of-stream
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/pump
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/tar-fs
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/simple-get
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/yallist
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/lru-cache
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/semver
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/node-abi
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/prebuild-install
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.js-controller/node_modules/fs-extra
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.js-controller/node_modules/node-forge
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/logform/node_modules/safe-stable-stringify
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/ncp
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/pidusage
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/safe-stable-stringify
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/seq-logging
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@iobroker/db-objects-redis
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@iobroker/db-states-redis
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@iobroker/db-states-file
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@iobroker/db-states-jsonl
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/yargs-parser
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.js-controller/node_modules/mime
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/winston/node_modules
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/winston-seq-updated
                                          npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@alcalzone/jsonl-db/node_modules
                                          npm ERR! code EACCES
                                          npm ERR! syscall access
                                          npm ERR! path /opt/iobroker/node_modules/@iobroker/db-base/node_modules/fs-extra
                                          npm ERR! errno -13
                                          npm ERR! Error: EACCES: permission denied, access '/opt/iobroker/node_modules/@iobroker/db-base/node_modules/fs-extra'
                                          npm ERR!  [Error: EACCES: permission denied, access '/opt/iobroker/node_modules/@iobroker/db-base/node_modules/fs-extra'] {
                                          npm ERR!   errno: -13,
                                          npm ERR!   code: 'EACCES',
                                          npm ERR!   syscall: 'access',
                                          npm ERR!   path: '/opt/iobroker/node_modules/@iobroker/db-base/node_modules/fs-extra'
                                          npm ERR! }
                                          npm ERR!
                                          npm ERR! The operation was rejected by your operating system.
                                          npm ERR! It is likely you do not have the permissions to access this file as the current user
                                          npm ERR!
                                          npm ERR! If you believe this might be a permissions issue, please double-check the
                                          npm ERR! permissions of the file and its containing directories, or try running
                                          npm ERR! the command again as root/Administrator.
                                          npm ERR!     /home/mirko/.npm/_logs/2022-02-04T07_26_29_636Z-debug.log
                                          mirko@iobroker:/opt/iobroker$
                                          84.1k
                                          1.4m
