Alpha Test js-controller 4.0
@apollon77
https://www.iobroker.net/#de/documentation/dev/objectsschema.mdUnter Kanalbeschreibungen.
@maik-0 FIxed, hoffe hab alle erwischt https://github.com/ioBroker/ioBroker.docs/commit/63bcf4acc09803f1ce8fd1e03e4ba3881b3bf666
Dieser Beitrag wurde gelöscht! -
Leider haben die Änderungen in der main.js nix gebracht, soweit ich sehe:
main.js hat jetzt drin:
Line 4443
// show for debug console.error(text); if ( text.includes('NODE_MODULE_VERSION') || text.includes('npm rebuild') || text.includes('Error: The module \'') || text.includes('Cannot find module') ) {Line 3016
case 'rebuildAdapter': if (!msg.message.id) { if (msg.callback && msg.from) { sendTo(msg.from, msg.command, { error: 'Adapter to rebuild not provided.' }, msg.callback); } } else if (!installQueue.some(entry => entry.id === msg.message.id)) { logger.info(`${hostLogPrefix} ${msg.message.id} will be rebuilt ( ${msg.message.rebuildArgs})`); const installObj = { id: msg.message.id, rebuild: true }; if (msg.message.rebuildArgs) { installObj.rebuildArgs = msg.message.rebuildArgs; }Leider kommt da immer noch das um's Eck:
2022-02-03 20:18:45.732 - info: host.chet instance system.adapter.parcel.0 started with pid 76304 2022-02-03 20:18:46.983 - error: host.chet Caught by controller[0]: node:internal/modules/cjs/loader:1183 2022-02-03 20:18:46.983 - error: host.chet Caught by controller[0]: return process.dlopen(module, path.toNamespacedPath(filename)); 2022-02-03 20:18:46.985 - error: host.chet Caught by controller[0]: ^ 2022-02-03 20:18:46.985 - error: host.chet Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node' 2022-02-03 20:18:46.985 - error: host.chet Caught by controller[0]: was compiled against a different Node.js version using 2022-02-03 20:18:46.985 - error: host.chet Caught by controller[0]: NODE_MODULE_VERSION 83. This version of Node.js requires 2022-02-03 20:18:46.986 - error: host.chet Caught by controller[0]: NODE_MODULE_VERSION 93. Please try re-compiling or re-installing 2022-02-03 20:18:46.986 - error: host.chet Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`). 2022-02-03 20:18:46.986 - error: host.chet Caught by controller[0]: at Object.Module._extensions..node (node:internal/modules/cjs/loader:1183:18) 2022-02-03 20:18:46.986 - error: host.chet Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:981:32) 2022-02-03 20:18:46.986 - error: host.chet Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:822:12) 2022-02-03 20:18:46.986 - error: host.chet Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1005:19) 2022-02-03 20:18:46.987 - error: host.chet Caught by controller[0]: at require (node:internal/modules/cjs/helpers:102:18) 2022-02-03 20:18:46.987 - error: host.chet Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/canvas/lib/bindings.js:3:18) 2022-02-03 20:18:46.987 - error: host.chet Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1101:14) 2022-02-03 20:18:46.988 - error: host.chet Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1153:10) 2022-02-03 20:18:46.988 - error: host.chet Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:981:32) 2022-02-03 20:18:46.988 - error: host.chet Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:822:12) { 2022-02-03 20:18:46.988 - error: host.chet Caught by controller[0]: code: 'ERR_DLOPEN_FAILED' 2022-02-03 20:18:46.988 - error: host.chet Caught by controller[0]: } 2022-02-03 20:18:46.989 - error: host.chet instance system.adapter.parcel.0 terminated with code 1 (JS_CONTROLLER_STOPPED) 2022-02-03 20:18:46.989 - info: host.chet Adapter system.adapter.parcel.0 needs rebuild and will be restarted afterwards. 2022-02-03 20:18:46.989 - info: host.chet system.adapter.parcel.0 will be rebuilt ( undefined) 2022-02-03 20:18:46.990 - warn: host.chet adapter "parcel" seems to be installed for a different version of Node.js. Trying to rebuild it... 1 attempt 2022-02-03 20:18:46.991 - info: host.chet iobroker rebuild 2022-02-03 20:18:47.764 - info: miio.0 (76030) discover stoped after 30 seconds. 2022-02-03 20:18:48.067 - info: host.chet iobroker npm-rebuild: Rebuilding native modules ... 2022-02-03 20:19:30.209 - info: host.chet iobroker npm-rebuild: rebuilt dependencies successfully 2022-02-03 20:19:30.246 - info: host.chet iobroker npm-rebuild: 2022-02-03 20:19:30.248 - info: host.chet iobroker npm-rebuild: Rebuilding native modules done 2022-02-03 20:19:31.259 - info: host.chet iobroker npm-rebuild: exit 0 2022-02-03 20:19:31.356 - info: host.chet instance system.adapter.parcel.0 started with pid 76951 2022-02-03 20:19:32.606 - error: host.chet Caught by controller[0]: node:internal/modules/cjs/loader:1183 2022-02-03 20:19:32.606 - error: host.chet Caught by controller[0]: return process.dlopen(module, path.toNamespacedPath(filename)); 2022-02-03 20:19:32.607 - error: host.chet Caught by controller[0]: ^ 2022-02-03 20:19:32.607 - error: host.chet Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node' 2022-02-03 20:19:32.607 - error: host.chet Caught by controller[0]: was compiled against a different Node.js version using 2022-02-03 20:19:32.607 - error: host.chet Caught by controller[0]: NODE_MODULE_VERSION 83. This version of Node.js requires 2022-02-03 20:19:32.607 - error: host.chet Caught by controller[0]: NODE_MODULE_VERSION 93. Please try re-compiling or re-installing 2022-02-03 20:19:32.608 - error: host.chet Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`). 2022-02-03 20:19:32.608 - error: host.chet Caught by controller[0]: at Object.Module._extensions..node (node:internal/modules/cjs/loader:1183:18) 2022-02-03 20:19:32.608 - error: host.chet Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:981:32) 2022-02-03 20:19:32.608 - error: host.chet Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:822:12) 2022-02-03 20:19:32.609 - error: host.chet Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1005:19) 2022-02-03 20:19:32.609 - error: host.chet Caught by controller[0]: at require (node:internal/modules/cjs/helpers:102:18) 2022-02-03 20:19:32.609 - error: host.chet Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/canvas/lib/bindings.js:3:18) 2022-02-03 20:19:32.609 - error: host.chet Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1101:14) 2022-02-03 20:19:32.609 - error: host.chet Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1153:10) 2022-02-03 20:19:32.610 - error: host.chet Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:981:32) 2022-02-03 20:19:32.610 - error: host.chet Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:822:12) { 2022-02-03 20:19:32.610 - error: host.chet Caught by controller[0]: code: 'ERR_DLOPEN_FAILED' 2022-02-03 20:19:32.610 - error: host.chet Caught by controller[0]: } 2022-02-03 20:19:32.610 - error: host.chet instance system.adapter.parcel.0 terminated with code 1 (JS_CONTROLLER_STOPPED) 2022-02-03 20:19:32.611 - info: host.chet Adapter system.adapter.parcel.0 needs rebuild and will be restarted afterwards. 2022-02-03 20:19:32.611 - info: host.chet system.adapter.parcel.0 will be rebuilt ( undefined) 2022-02-03 20:19:32.611 - warn: host.chet adapter "parcel" seems to be installed for a different version of Node.js. Trying to rebuild it... 2 attempt 2022-02-03 20:19:32.612 - info: host.chet iobroker rebuild 2022-02-03 20:19:33.581 - info: host.chet iobroker npm-rebuild: Rebuilding native modules ... 2022-02-03 20:20:15.070 - info: host.chet iobroker npm-rebuild: rebuilt dependencies successfully 2022-02-03 20:20:15.110 - info: host.chet iobroker npm-rebuild: 2022-02-03 20:20:15.111 - info: host.chet iobroker npm-rebuild: Rebuilding native modules done 2022-02-03 20:20:16.125 - info: host.chet iobroker npm-rebuild: exit 0 2022-02-03 20:20:16.265 - info: host.chet instance system.adapter.parcel.0 started with pid 77583 2022-02-03 20:20:17.605 - error: host.chet Caught by controller[0]: node:internal/modules/cjs/loader:1183 2022-02-03 20:20:17.606 - error: host.chet Caught by controller[0]: return process.dlopen(module, path.toNamespacedPath(filename)); 2022-02-03 20:20:17.606 - error: host.chet Caught by controller[0]: ^ 2022-02-03 20:20:17.606 - error: host.chet Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node' 2022-02-03 20:20:17.606 - error: host.chet Caught by controller[0]: was compiled against a different Node.js version using 2022-02-03 20:20:17.606 - error: host.chet Caught by controller[0]: NODE_MODULE_VERSION 83. This version of Node.js requires 2022-02-03 20:20:17.606 - error: host.chet Caught by controller[0]: NODE_MODULE_VERSION 93. Please try re-compiling or re-installing 2022-02-03 20:20:17.606 - error: host.chet Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`). 2022-02-03 20:20:17.607 - error: host.chet Caught by controller[0]: at Object.Module._extensions..node (node:internal/modules/cjs/loader:1183:18) 2022-02-03 20:20:17.607 - error: host.chet Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:981:32) 2022-02-03 20:20:17.607 - error: host.chet Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:822:12) 2022-02-03 20:20:17.607 - error: host.chet Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1005:19) 2022-02-03 20:20:17.607 - error: host.chet Caught by controller[0]: at require (node:internal/modules/cjs/helpers:102:18) 2022-02-03 20:20:17.607 - error: host.chet Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/canvas/lib/bindings.js:3:18) 2022-02-03 20:20:17.608 - error: host.chet Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1101:14) 2022-02-03 20:20:17.608 - error: host.chet Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1153:10) 2022-02-03 20:20:17.608 - error: host.chet Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:981:32) 2022-02-03 20:20:17.608 - error: host.chet Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:822:12) { 2022-02-03 20:20:17.608 - error: host.chet Caught by controller[0]: code: 'ERR_DLOPEN_FAILED' 2022-02-03 20:20:17.609 - error: host.chet Caught by controller[0]: } 2022-02-03 20:20:17.609 - error: host.chet instance system.adapter.parcel.0 terminated with code 1 (JS_CONTROLLER_STOPPED) 2022-02-03 20:20:17.609 - info: host.chet Adapter system.adapter.parcel.0 needs rebuild and will be restarted afterwards. 2022-02-03 20:20:17.610 - info: host.chet system.adapter.parcel.0 will be rebuilt ( undefined) 2022-02-03 20:20:17.610 - warn: host.chet adapter "parcel" seems to be installed for a different version of Node.js. Trying to rebuild it... 3 attempt 2022-02-03 20:20:17.610 - info: host.chet iobroker rebuild 2022-02-03 20:20:18.792 - info: host.chet iobroker npm-rebuild: Rebuilding native modules ... 2022-02-03 20:21:00.528 - info: host.chet iobroker npm-rebuild: rebuilt dependencies successfully 2022-02-03 20:21:00.570 - info: host.chet iobroker npm-rebuild: 2022-02-03 20:21:00.571 - info: host.chet iobroker npm-rebuild: Rebuilding native modules done 2022-02-03 20:21:01.582 - info: host.chet iobroker npm-rebuild: exit 0 2022-02-03 20:21:01.677 - info: host.chet instance system.adapter.parcel.0 started with pid 78216 2022-02-03 20:21:02.929 - error: host.chet Caught by controller[0]: node:internal/modules/cjs/loader:1183 2022-02-03 20:21:02.929 - error: host.chet Caught by controller[0]: return process.dlopen(module, path.toNamespacedPath(filename)); 2022-02-03 20:21:02.930 - error: host.chet Caught by controller[0]: ^ 2022-02-03 20:21:02.930 - error: host.chet Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node' 2022-02-03 20:21:02.930 - error: host.chet Caught by controller[0]: was compiled against a different Node.js version using 2022-02-03 20:21:02.930 - error: host.chet Caught by controller[0]: NODE_MODULE_VERSION 83. This version of Node.js requires 2022-02-03 20:21:02.930 - error: host.chet Caught by controller[0]: NODE_MODULE_VERSION 93. Please try re-compiling or re-installing 2022-02-03 20:21:02.931 - error: host.chet Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`). 2022-02-03 20:21:02.931 - error: host.chet Caught by controller[0]: at Object.Module._extensions..node (node:internal/modules/cjs/loader:1183:18) 2022-02-03 20:21:02.931 - error: host.chet Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:981:32) 2022-02-03 20:21:02.931 - error: host.chet Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:822:12) 2022-02-03 20:21:02.931 - error: host.chet Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1005:19) 2022-02-03 20:21:02.932 - error: host.chet Caught by controller[0]: at require (node:internal/modules/cjs/helpers:102:18) 2022-02-03 20:21:02.932 - error: host.chet Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/canvas/lib/bindings.js:3:18) 2022-02-03 20:21:02.932 - error: host.chet Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1101:14) 2022-02-03 20:21:02.933 - error: host.chet Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1153:10) 2022-02-03 20:21:02.933 - error: host.chet Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:981:32) 2022-02-03 20:21:02.933 - error: host.chet Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:822:12) { 2022-02-03 20:21:02.934 - error: host.chet Caught by controller[0]: code: 'ERR_DLOPEN_FAILED' 2022-02-03 20:21:02.934 - error: host.chet Caught by controller[0]: } 2022-02-03 20:21:02.934 - error: host.chet instance system.adapter.parcel.0 terminated with code 1 (JS_CONTROLLER_STOPPED) 2022-02-03 20:21:02.934 - info: host.chet Rebuild for adapter system.adapter.parcel.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.@thomas-braun sagte in Alpha Test js-controller 4.0:
console.error(text);Das meinte ich nur, aber ihr seid ja schon in Kontakt - all good ;-)
@foxriver76 Jo das ist original im Code drin von uns :-))
[[topic:post-is-deleted]]Dieser Beitrag wurde gelöscht!
@wendy2702 Ja, hatte ich danach auch gesehen :-)) und das finde ich mega interessant weil "iob fix" an sich das alles glatt ziehen sollte. zeig mal "ls -la" von so einem der angemeckerten Verzeichnisse, vllt sieht man ja was.
Ansonsten (wenn keinem sonst mehr was einfällt) wäre ich bei nem krassen neustart "node_modules löschen", controller manuell installieren, starten ... dann installiert der alle adapter neu
@apollon77 sagte in Alpha Test js-controller 4.0:
Guten Morgen,
Holzhammer probiert:
mirko@iobroker:/opt/iobroker$ sudo rm -r node_modules [sudo] password for mirko: mirko@iobroker:/opt/iobroker$ ls -la total 1036 drwxrwxr-x+ 10 iobroker iobroker 4096 Feb 4 07:41 . drwxr-xr-x 4 root root 4096 Jan 10 2021 .. -rw-rwxr--+ 1 iobroker iobroker 91 Feb 3 17:11 .npmrc -rw-rwxr--+ 1 iobroker iobroker 1049 Mar 31 2020 CHANGELOG_FIXER_LINUX.md -rw-rwxr--+ 1 iobroker iobroker 3556 Mar 31 2020 CHANGELOG_INSTALLER_LINUX.md -rw-rwxr--+ 1 iobroker iobroker 0 Jul 11 2020 GarageKlein_Einfahrt_JPG.txt -rw-rwxr--+ 1 iobroker iobroker 0 Jul 11 2020 GarageKlein_JPG.txt -rw-rwxr--+ 1 iobroker iobroker 0 Jul 11 2020 Haustuer_JPG.txt -rwxrwxrwx+ 1 iobroker iobroker 359 Feb 3 17:11 INSTALLER_INFO.txt -rw-rwxr--+ 1 iobroker iobroker 1137 Mar 31 2020 LICENSE -rw-rwxr--+ 1 iobroker iobroker 6101 Mar 31 2020 README.md drwxrwxrwx+ 2 iobroker iobroker 4096 Feb 3 16:40 backups drwxrwxr-x+ 2 iobroker iobroker 4096 Jan 29 15:02 cache -rw-rwxr--+ 1 iobroker iobroker 23988 Mar 31 2020 fix_installation.sh drwxrwxr-x+ 2 iobroker iobroker 12288 Aug 22 12:56 history drwxrwxr-x+ 3 iobroker iobroker 4096 Mar 31 2020 install lrwxrwxrwx 1 iobroker iobroker 22 Feb 3 17:11 iob -> /opt/iobroker/iobroker -rwxr-xr-x+ 1 iobroker iobroker 305 Feb 3 17:11 iobroker drwxrwxr-x+ 14 iobroker iobroker 4096 Feb 4 07:39 iobroker-data drwxrwxr-x+ 2 iobroker iobroker 4096 Mar 31 2020 lib drwxrwxr-x+ 2 iobroker iobroker 4096 Feb 4 07:39 log -rw-rwxr--+ 1 iobroker iobroker 129561 Feb 4 07:26 out2.mp4 -rw-rwxr--+ 1 iobroker iobroker 169136 Feb 4 05:47 out3.mp4 -rw-rwxr--+ 1 iobroker iobroker 637615 Feb 3 18:10 package-lock.json -rw-rwxr--+ 1 iobroker iobroker 3392 Feb 3 18:10 package.json -rw-rwxr--+ 1 iobroker iobroker 5693 Feb 3 17:06 reinstall.js drwxrwxrwx+ 5 iobroker iobroker 4096 Jan 10 2021 scripte-backup mirko@iobroker:/opt/iobroker$ npm i iobroker.js-controller@next npm WARN tarball tarball data for iobroker.icons-open-icon-library-png@https://github.com/ioBroker/ioBroker.icons-open-icon-library-png/tarball/master (sha512-qGFFRFfv/uSaVT+z3v01bwdZYjfIES0YwaHNOgy+OO28NMa8/8fh2rkBKGHNeHfFPBTo3juTeH+p6ngZ6s//7w==) seems to be corrupted. Trying one more time. npm WARN tarball tarball data for iobroker.icons-open-icon-library-png@https://github.com/ioBroker/ioBroker.icons-open-icon-library-png/tarball/master (sha512-qGFFRFfv/uSaVT+z3v01bwdZYjfIES0YwaHNOgy+OO28NMa8/8fh2rkBKGHNeHfFPBTo3juTeH+p6ngZ6s//7w==) seems to be corrupted. Trying one more time. npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents): npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"}) npm ERR! code EINTEGRITY npm ERR! Verification failed while extracting iobroker.icons-open-icon-library-png@https://github.com/ioBroker/ioBroker.icons-open-icon-library-png/tarball/master: npm ERR! Verification failed while extracting iobroker.icons-open-icon-library-png@https://github.com/ioBroker/ioBroker.icons-open-icon-library-png/tarball/master: npm ERR! sha512-qGFFRFfv/uSaVT+z3v01bwdZYjfIES0YwaHNOgy+OO28NMa8/8fh2rkBKGHNeHfFPBTo3juTeH+p6ngZ6s//7w== integrity checksum failed when using sha512: wanted sha512-qGFFRFfv/uSaVT+z3v01bwdZYjfIES0YwaHNOgy+OO28NMa8/8fh2rkBKGHNeHfFPBTo3juTeH+p6ngZ6s//7w== but got sha512-ZH4lj95sM6IpZEL2H1HR0hXTo6GMqbUBPbQyylgdRd6TDEdU+fgohUVGW4gPI0UnrAzqM/kx5+mozLqCVh2DCg==. (64751136 bytes) npm ERR! A complete log of this run can be found in: npm ERR! /home/iobroker/.npm/_logs/2022-02-04T06_43_35_307Z-debug.log mirko@iobroker:/opt/iobroker$Hier das npm log:
iob startet nicht.
Guten Morgen,
iob startet nicht.
@wendy2702 da stimmt mit dem REPO was nicht
https://github.com/ioBroker/ioBroker.icons-open-icon-library-pngbekomme es nichtmal installiert
liegt nicht am 4.x
liegt nicht am 4.x
@arteck sagte in Alpha Test js-controller 4.0:
Danke!
JS4.0 mag mich scheinbar nicht :-)
Habe gerade etwas Zeit. Neuen LXC aufgesetzt mit Debian 11. iobroker frisch installiert per einzeiler. Dann versucht JS4 zu installieren und wieder erhalte ich die "missing write access" fehler.
Hier das vollständige inklusive installation:
mirko@iobroker:~$ sudo apt update && sudo apt full-upgrade Wir gehen davon aus, dass der lokale Systemadministrator Ihnen die Regeln erklärt hat. Normalerweise läuft es auf drei Regeln hinaus: #1) Respektieren Sie die Privatsphäre anderer. #2) Denken Sie nach, bevor Sie tippen. #3) Mit großer Macht kommt große Verantwortung. [sudo] Passwort für mirko: OK:1 http://security.debian.org/debian-security bullseye-security InRelease OK:2 http://ftp.halifax.rwth-aachen.de/debian bullseye InRelease OK:3 http://ftp.halifax.rwth-aachen.de/debian bullseye-updates InRelease Paketlisten werden gelesen… Fertig Abhängigkeitsbaum wird aufgebaut… Fertig Statusinformationen werden eingelesen… Fertig Alle Pakete sind aktuell. Paketlisten werden gelesen… Fertig Abhängigkeitsbaum wird aufgebaut… Fertig Statusinformationen werden eingelesen… Fertig Paketaktualisierung (Upgrade) wird berechnet… Fertig 0 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert. mirko@iobroker:~$ curl -sLf https://iobroker.net/install.sh | bash - -bash: curl: Kommando nicht gefunden. mirko@iobroker:~$ sudo apt install curl Paketlisten werden gelesen… Fertig Abhängigkeitsbaum wird aufgebaut… Fertig Statusinformationen werden eingelesen… Fertig Die folgenden zusätzlichen Pakete werden installiert: libcurl4 Die folgenden NEUEN Pakete werden installiert: curl libcurl4 0 aktualisiert, 2 neu installiert, 0 zu entfernen und 0 nicht aktualisiert. Es müssen 608 kB an Archiven heruntergeladen werden. Nach dieser Operation werden 1.186 kB Plattenplatz zusätzlich benutzt. Möchten Sie fortfahren? [J/n] j Holen:1 http://ftp.halifax.rwth-aachen.de/debian bullseye/main amd64 libcurl4 amd64 7.74.0-1.3+deb11u1 [341 kB] Holen:2 http://ftp.halifax.rwth-aachen.de/debian bullseye/main amd64 curl amd64 7.74.0-1.3+deb11u1 [267 kB] Es wurden 608 kB in 0 s geholt (3.144 kB/s). Vormals nicht ausgewähltes Paket libcurl4:amd64 wird gewählt. (Lese Datenbank ... 33963 Dateien und Verzeichnisse sind derzeit installiert.) Vorbereitung zum Entpacken von .../libcurl4_7.74.0-1.3+deb11u1_amd64.deb ... Entpacken von libcurl4:amd64 (7.74.0-1.3+deb11u1) ... Vormals nicht ausgewähltes Paket curl wird gewählt. Vorbereitung zum Entpacken von .../curl_7.74.0-1.3+deb11u1_amd64.deb ... Entpacken von curl (7.74.0-1.3+deb11u1) ... libcurl4:amd64 (7.74.0-1.3+deb11u1) wird eingerichtet ... curl (7.74.0-1.3+deb11u1) wird eingerichtet ... Trigger für man-db (2.9.4-2) werden verarbeitet ... Trigger für libc-bin (2.31-13+deb11u2) werden verarbeitet ... mirko@iobroker:~$ curl -sLf https://iobroker.net/install.sh | bash - library: loaded Library version=2021-12-27 ========================================================================== Welcome to the ioBroker installer! Installer version: 2021-12-27 You might need to enter your password a couple of times. ========================================================================== ========================================================================== Installing prerequisites (1/4) ========================================================================== OK:1 http://ftp.halifax.rwth-aachen.de/debian bullseye InRelease OK:2 http://security.debian.org/debian-security bullseye-security InRelease OK:3 http://ftp.halifax.rwth-aachen.de/debian bullseye-updates InRelease Paketlisten werden gelesen… Fertig ========================================================================== Node.js not found. Installing... ========================================================================== ## Installing the NodeSource Node.js 14.x repo... ## Populating apt-get cache... + apt-get update OK:1 http://security.debian.org/debian-security bullseye-security InRelease OK:2 http://ftp.halifax.rwth-aachen.de/debian bullseye InRelease OK:3 http://ftp.halifax.rwth-aachen.de/debian bullseye-updates InRelease Paketlisten werden gelesen… Fertig ## Installing packages required for setup: gnupg... + apt-get install -y gnupg > /dev/null 2>&1 ## Confirming "bullseye" is supported... + curl -sLf -o /dev/null 'https://deb.nodesource.com/node_14.x/dists/bullseye/Release' ## Adding the NodeSource signing key to your keyring... + curl -s https://deb.nodesource.com/gpgkey/nodesource.gpg.key | gpg --dearmor | tee /usr/share/keyrings/nodesource.gpg >/dev/null ## Creating apt sources list file for the NodeSource Node.js 14.x repo... + echo 'deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_14.x bullseye main' > /etc/apt/sources.list.d/nodesource.list + echo 'deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_14.x bullseye main' >> /etc/apt/sources.list.d/nodesource.list ## Running `apt-get update` for you... + apt-get update OK:1 http://security.debian.org/debian-security bullseye-security InRelease OK:2 http://ftp.halifax.rwth-aachen.de/debian bullseye InRelease OK:3 http://ftp.halifax.rwth-aachen.de/debian bullseye-updates InRelease Holen:4 https://deb.nodesource.com/node_14.x bullseye InRelease [4.586 B] Holen:5 https://deb.nodesource.com/node_14.x bullseye/main amd64 Packages [773 B] Es wurden 5.359 B in 1 s geholt (4.229 B/s). Paketlisten werden gelesen… Fertig ## Run `sudo apt-get install -y nodejs` to install Node.js 14.x and npm ## You may also need development tools to build native addons: sudo apt-get install gcc g++ make ## To install the Yarn package manager, run: curl -sL https://dl.yarnpkg.com/debian/pubkey.gpg | gpg --dearmor | sudo tee /usr/share/keyrings/yarnkey.gpg >/dev/null echo "deb [signed-by=/usr/share/keyrings/yarnkey.gpg] https://dl.yarnpkg.com/debian stable main" | sudo tee /etc/apt/sources.list.d/yarn.list sudo apt-get update && sudo apt-get install yarn Installed nodejs Node.js Installed successfully! Changing npm registry to https://registry.npmjs.org Installed acl Installed build-essential Installed gcc-c++ Installed libavahi-compat-libdnssd-dev Installed libudev-dev Installed libpam0g-dev Installed git Installed unzip Installed libcairo2-dev Installed libpango1.0-dev Installed libjpeg-dev Installed libgif-dev Installed librsvg2-dev Installed net-tools Installed python-dev Installed cmake ========================================================================== Creating ioBroker user and directory (2/4) ========================================================================== User iobroker created Created /etc/sudoers.d/iobroker Directory /opt/iobroker created ========================================================================== Installing ioBroker (3/4) ========================================================================== In file included from ../../nan/nan.h:58, from ../src/main.cpp:3: /home/mirko/.cache/node-gyp/14.19.0/include/node/node.h:793:7: warning: cast between incompatible function types from ‘void (*)(v8::Local<v8::Object>)’ to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type] 793 | (node::addon_register_func) (regfunc), \ | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ /home/mirko/.cache/node-gyp/14.19.0/include/node/node.h:827:3: note: in expansion of macro ‘NODE_MODULE_X’ 827 | NODE_MODULE_X(modname, regfunc, NULL, 0) // NOLINT (readability/null_usage) | ^~~~~~~~~~~~~ ../src/main.cpp:42:1: note: in expansion of macro ‘NODE_MODULE’ 42 | NODE_MODULE(diskusage, Init) | ^~~~~~~~~~~ In file included from ../../nan/nan.h:58, from ../src/unix_dgram.cc:5: /home/mirko/.cache/node-gyp/14.19.0/include/node/node.h:793:7: warning: cast between incompatible function types from ‘void (*)(v8::Local<v8::Object>)’ to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type] 793 | (node::addon_register_func) (regfunc), \ | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ /home/mirko/.cache/node-gyp/14.19.0/include/node/node.h:827:3: note: in expansion of macro ‘NODE_MODULE_X’ 827 | NODE_MODULE_X(modname, regfunc, NULL, 0) // NOLINT (readability/null_usage) | ^~~~~~~~~~~~~ ../src/unix_dgram.cc:404:1: note: in expansion of macro ‘NODE_MODULE’ 404 | NODE_MODULE(unix_dgram, Initialize) | ^~~~~~~~~~~ ATTENTION: Error reporting via Sentry will be activated on next start of ioBroker ioBroker wants to make sure to deliver the most stable smart home system. To allow this we decided to implement an automatic error and crash reporting solution into the js-controller and also into adapters. THIS REPORTING WILL BE ENABLED WITH THE NEXT START OF YOUR IOBROKER! For any error that leads to the crash of the js-controller or one of the relevant adapters the error details are send to a server. For the js-controller and core adapters this server is located and operated in germany. For community adapters please check the Github Readme of the affected adapter for details which Sentry server is used. If you want to disable the error reporting you can use the command 'iobroker plugin disable sentry' This command will also make sure that no adapter that runs on this host will send crash reporting data to sentry. ========================================================================== Finalizing installation (4/4) ========================================================================== Enabling autostart... Created symlink /etc/systemd/system/multi-user.target.wants/iobroker.service → /lib/systemd/system/iobroker.service. Autostart enabled! Fixing directory permissions... ========================================================================== ioBroker was installed successfully Open http://192.168.178.108:8081 in a browser and start configuring! ========================================================================== You need to re-login before doing anything else on the console! mirko@iobroker:~$ iob -v 3.3.22 mirko@iobroker:~$ iob stop mirko@iobroker:~$ iob update Used repository: default hash changed or no sources cached => force download of new sources update done Adapter "admin" : 5.2.3 , installed 5.2.3 Adapter "backitup" : 2.2.3 , installed 2.2.3 Adapter "discovery" : 2.7.3 , installed 2.7.3 Controller "js-controller" : 3.3.22 , installed 3.3.22 mirko@iobroker:~$ cd /opt/iobroker/ mirko@iobroker:/opt/iobroker$ npm i iobroker.js-controller@next npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@iobroker/db-base/node_modules/fs-extra npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@iobroker/db-objects-file/node_modules/fs-extra npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@iobroker/db-objects-jsonl/node_modules/fs-extra npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/alcalzone-shared npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@alcalzone/jsonl-db npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/@types/node npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/@types/iobroker npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/adapter-core npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/array-flatten npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/assert-plus npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/asynckit npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/aws-sign2 npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/aws4 npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/bytes npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/caseless npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/connect-flash npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/content-type npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/cookie npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/cookie-signature npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/cookie-parser npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/core-util-is npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/dashdash npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/delayed-stream npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/combined-stream npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/depd npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/destroy npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/ee-first npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/encodeurl npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/escape-html npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/etag npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/express-session/node_modules/depd npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/extend npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/extsprintf npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/fast-deep-equal npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/fast-json-stable-stringify npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/forever-agent npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/forwarded npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/fresh npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/getpass npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/har-schema npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/inherits npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/ipaddr.js npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/is-typedarray npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/isstream npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/jsbn npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/json-schema npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/json-schema-traverse npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/json-stringify-safe npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/media-typer npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/merge-descriptors npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/methods npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/mime npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/mime-db npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/mime-types npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/form-data npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/ms npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/debug npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/negotiator npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/accepts npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/oauth-sign npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/on-finished npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/on-headers npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/parseurl npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/passport-strategy npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/passport-local npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/path-to-regexp npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/pause npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/passport npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/performance-now npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/proxy-addr npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/psl npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/punycode npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/qs npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/random-bytes npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/range-parser npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/request/node_modules/qs npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/safe-buffer npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/content-disposition npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/safer-buffer npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/asn1 npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/ecc-jsbn npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/iconv-lite npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/send/node_modules/ms npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/setprototypeof npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/statuses npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/streamsearch npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/dicer npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/busboy npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/express-fileupload npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/toidentifier npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/http-errors npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/send npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/serve-static npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/tough-cookie npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/tunnel-agent npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/tweetnacl npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/bcrypt-pbkdf npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/sshpk npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/type-is npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/uid-safe npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/express-session npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/unpipe npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/finalhandler npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/raw-body npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/body-parser npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/uri-js npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/har-validator npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/utils-merge npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/ajv npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/uuid npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/vary npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/express npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/verror npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/http-signature npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/jsprim npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/request npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/ws npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/xtend npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/passport.socketio npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/yallist npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/lru-cache npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/semver npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/@types/node npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/@types/iobroker npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/@iobroker/adapter-core npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/agent-base npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/array-flatten npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/arrify npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/assert-plus npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/asynckit npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/aws-sign2 npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/aws4 npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/balanced-match npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/base-64 npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/base64-js npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/bignumber.js npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/body-parser/node_modules/ms npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/body-parser/node_modules/debug npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/body-parser/node_modules/qs npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/buffer-equal-constant-time npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/bytes npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/caseless npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/charenc npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/chownr npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/concat-map npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/brace-expansion npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/content-type npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/cookie npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/cookie-signature npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/core-util-is npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/crypt npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/dashdash npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/delayed-stream npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/combined-stream npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/depd npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/destroy npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/ee-first npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/encodeurl npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/escape-html npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/etag npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/event-target-shim npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/abort-controller npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/express/node_modules/ms npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/express/node_modules/debug npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/express/node_modules/qs npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/extend npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/extsprintf npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/fast-deep-equal npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/fast-json-stable-stringify npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/fast-text-encoding npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/finalhandler/node_modules/ms npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/finalhandler/node_modules/debug npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/follow-redirects npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/axios npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/forever-agent npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/forwarded npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/fresh npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/fs-constants npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/function-bind npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/getpass npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/graceful-fs npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/har-schema npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/has npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/has-symbols npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/get-intrinsic npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/call-bind npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/he npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/hot-patcher npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/https-proxy-agent npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/ieee754 npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/buffer npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/inherits npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/ipaddr.js npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/is-buffer npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/is-stream npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/is-typedarray npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/isarray npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/isstream npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/jsbn npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/json-bigint npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/json-schema npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/json-schema-traverse npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/json-stringify-safe npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/layerr npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/long-timeout npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/luxon npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/md5 npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/media-typer npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/merge-descriptors npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/methods npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/mime npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/mime-db npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/mime-types npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/form-data npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/minimatch npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/mkdirp-classic npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/negotiator npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/accepts npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/nested-property npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/node-forge npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/google-p12-pem npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/node-wol npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/oauth-sign npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/object-inspect npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/object-keys npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/define-properties npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/is-nan npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/cron-parser npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/on-finished npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/parseurl npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/path-posix npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/path-to-regexp npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/performance-now npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/proxy-addr npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/psl npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/punycode npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/querystringify npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/range-parser npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/request/node_modules/qs npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/request/node_modules/uuid npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/requires-port npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/safe-buffer npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/bl/node_modules/string_decoder npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/content-disposition npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/ecdsa-sig-formatter npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/jwa npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/jws npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/safer-buffer npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/asn1 npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/ecc-jsbn npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/iconv-lite npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/send/node_modules/debug/node_modules/ms npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/send/node_modules/debug npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/send/node_modules/ms npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/setprototypeof npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/side-channel npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/qs npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/sorted-array-functions npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/node-schedule npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/statuses npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/string_decoder npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/readable-stream npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/strnum npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/fast-xml-parser npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/tar-stream/node_modules/string_decoder npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/toidentifier npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/http-errors npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/send npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/serve-static npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/tough-cookie npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/tr46 npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/tunnel-agent npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/tweetnacl npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/bcrypt-pbkdf npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/sshpk npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/type-is npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/universalify npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/jsonfile npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/fs-extra npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/unpipe npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/finalhandler npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/raw-body npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/body-parser npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/uri-js npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/ajv npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/har-validator npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/url-join npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/url-parse npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/url-template npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/util-deprecate npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/bl/node_modules/readable-stream npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/bl npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/tar-stream/node_modules/readable-stream npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/utils-merge npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/uuid npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/vary npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/express npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/verror npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/jsprim npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/http-signature npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/request npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/dropbox-v2-api npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/webdav npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/webidl-conversions npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/whatwg-url npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/node-fetch npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/gaxios npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/gcp-metadata npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/gtoken npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/wrappy npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/once npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/end-of-stream npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/tar-stream npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/pump npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/tar-fs npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/xregexp npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/ftp npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/yallist npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/lru-cache npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/google-auth-library npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/googleapis-common npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/@googleapis/drive npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/binding-abstract/node_modules/ms npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/binding-abstract/node_modules/debug npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/binding-abstract npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/binding-mock/node_modules/ms npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/binding-mock/node_modules/debug npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/binding-mock npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/bindings/node_modules/ms npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/bindings/node_modules/debug npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/parser-byte-length npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/parser-cctalk npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/parser-delimiter npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/parser-inter-byte-timeout npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/parser-readline npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/parser-ready npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/parser-regex npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/stream/node_modules/ms npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/stream/node_modules/debug npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/stream npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@types/node npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@types/iobroker npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@iobroker/adapter-core npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/ansi-regex npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/aproba npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/base64-js npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/bluebird npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/chownr npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/code-point-at npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/console-control-strings npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/core-util-is npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/deep-extend npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/delegates npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/detect-libc npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/dgram npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/expand-template npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/extend npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/file-uri-to-path npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/bindings npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/fs-constants npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/github-from-package npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/has-unicode npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/ieee754 npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/buffer npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/inherits npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/ini npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/ip npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/isarray npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/lodash npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/async npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/mimic-response npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/decompress-response npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/minimist npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/mkdirp-classic npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/ms npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/debug npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/nan npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/napi-build-utils npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/netmask npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/node-mndp npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/node-ssdp/node_modules/ms npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/node-ssdp/node_modules/debug npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/node-ssdp npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/number-is-nan npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/is-fullwidth-code-point npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/object-assign npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/process-nextick-args npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/readable-stream/node_modules/safe-buffer npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/safe-buffer npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/dns-packet npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/mdns-discovery npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/serialport/node_modules/ms npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/serialport/node_modules/debug npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/set-blocking npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/signal-exit npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/simple-concat npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/string_decoder/node_modules/safe-buffer npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/string_decoder npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/strip-ansi npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/string-width npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/strip-json-comments npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/rc npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/tunnel-agent npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/util-deprecate npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/bl/node_modules/readable-stream npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/bl npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/readable-stream npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/are-we-there-yet npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/tar-stream/node_modules/readable-stream npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/wide-align npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/gauge npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/npmlog npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/wrappy npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/once npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/end-of-stream npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/tar-stream npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/pump npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/tar-fs npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/simple-get npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/yallist npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/lru-cache npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/semver npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/node-abi npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/prebuild-install npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/bindings npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/serialport npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.js-controller/node_modules/fs-extra npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.js-controller/node_modules/node-forge npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/logform/node_modules/safe-stable-stringify npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/ncp npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/pidusage npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/safe-stable-stringify npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/seq-logging npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@iobroker/db-base npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@iobroker/db-objects-redis npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@iobroker/db-objects-file npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@iobroker/db-objects-jsonl npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@iobroker/db-states-redis npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@iobroker/db-states-file npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@iobroker/db-states-jsonl npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/yargs-parser npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.js-controller/node_modules/mime npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/yargs npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.js-controller npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@iobroker/db-objects-file/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@iobroker/db-objects-jsonl/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@alcalzone npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@iobroker/db-base/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/@types npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/express-session/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/request/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/send/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/@types npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/@iobroker npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/body-parser/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/express/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/finalhandler/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/request/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/bl/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/send/node_modules/debug/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/send/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/tar-stream/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/@googleapis npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/binding-abstract/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/binding-mock/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/bindings/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/stream/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@types npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@iobroker npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/node-ssdp/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/readable-stream/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/serialport/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/string_decoder/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/bl/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/tar-stream/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.js-controller/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/logform/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@iobroker npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/winston/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/winston-seq-updated npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@alcalzone/jsonl-db/node_modules npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents): npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"}) npm ERR! code EACCES npm ERR! syscall access npm ERR! path /opt/iobroker/node_modules/@iobroker/db-base/node_modules/fs-extra npm ERR! errno -13 npm ERR! Error: EACCES: permission denied, access '/opt/iobroker/node_modules/@iobroker/db-base/node_modules/fs-extra' npm ERR! [Error: EACCES: permission denied, access '/opt/iobroker/node_modules/@iobroker/db-base/node_modules/fs-extra'] { npm ERR! errno: -13, npm ERR! code: 'EACCES', npm ERR! syscall: 'access', npm ERR! path: '/opt/iobroker/node_modules/@iobroker/db-base/node_modules/fs-extra' npm ERR! } npm ERR! npm ERR! The operation was rejected by your operating system. npm ERR! It is likely you do not have the permissions to access this file as the current user npm ERR! npm ERR! If you believe this might be a permissions issue, please double-check the npm ERR! permissions of the file and its containing directories, or try running npm ERR! the command again as root/Administrator. npm ERR! A complete log of this run can be found in: npm ERR! /home/mirko/.npm/_logs/2022-02-04T07_26_29_636Z-debug.log mirko@iobroker:/opt/iobroker$ -
@apollon77 sagte in Alpha Test js-controller 4.0:
Ansonsten (wenn keinem sonst mehr was einfällt) wäre ich bei nem krassen neustart "node_modules löschen", controller manuell installieren, starten ... dann installiert der alle adapter neu
Guten Morgen,
Holzhammer probiert:
mirko@iobroker:/opt/iobroker$ sudo rm -r node_modules [sudo] password for mirko: mirko@iobroker:/opt/iobroker$ ls -la total 1036 drwxrwxr-x+ 10 iobroker iobroker 4096 Feb 4 07:41 . drwxr-xr-x 4 root root 4096 Jan 10 2021 .. -rw-rwxr--+ 1 iobroker iobroker 91 Feb 3 17:11 .npmrc -rw-rwxr--+ 1 iobroker iobroker 1049 Mar 31 2020 CHANGELOG_FIXER_LINUX.md -rw-rwxr--+ 1 iobroker iobroker 3556 Mar 31 2020 CHANGELOG_INSTALLER_LINUX.md -rw-rwxr--+ 1 iobroker iobroker 0 Jul 11 2020 GarageKlein_Einfahrt_JPG.txt -rw-rwxr--+ 1 iobroker iobroker 0 Jul 11 2020 GarageKlein_JPG.txt -rw-rwxr--+ 1 iobroker iobroker 0 Jul 11 2020 Haustuer_JPG.txt -rwxrwxrwx+ 1 iobroker iobroker 359 Feb 3 17:11 INSTALLER_INFO.txt -rw-rwxr--+ 1 iobroker iobroker 1137 Mar 31 2020 LICENSE -rw-rwxr--+ 1 iobroker iobroker 6101 Mar 31 2020 README.md drwxrwxrwx+ 2 iobroker iobroker 4096 Feb 3 16:40 backups drwxrwxr-x+ 2 iobroker iobroker 4096 Jan 29 15:02 cache -rw-rwxr--+ 1 iobroker iobroker 23988 Mar 31 2020 fix_installation.sh drwxrwxr-x+ 2 iobroker iobroker 12288 Aug 22 12:56 history drwxrwxr-x+ 3 iobroker iobroker 4096 Mar 31 2020 install lrwxrwxrwx 1 iobroker iobroker 22 Feb 3 17:11 iob -> /opt/iobroker/iobroker -rwxr-xr-x+ 1 iobroker iobroker 305 Feb 3 17:11 iobroker drwxrwxr-x+ 14 iobroker iobroker 4096 Feb 4 07:39 iobroker-data drwxrwxr-x+ 2 iobroker iobroker 4096 Mar 31 2020 lib drwxrwxr-x+ 2 iobroker iobroker 4096 Feb 4 07:39 log -rw-rwxr--+ 1 iobroker iobroker 129561 Feb 4 07:26 out2.mp4 -rw-rwxr--+ 1 iobroker iobroker 169136 Feb 4 05:47 out3.mp4 -rw-rwxr--+ 1 iobroker iobroker 637615 Feb 3 18:10 package-lock.json -rw-rwxr--+ 1 iobroker iobroker 3392 Feb 3 18:10 package.json -rw-rwxr--+ 1 iobroker iobroker 5693 Feb 3 17:06 reinstall.js drwxrwxrwx+ 5 iobroker iobroker 4096 Jan 10 2021 scripte-backup mirko@iobroker:/opt/iobroker$ npm i iobroker.js-controller@next npm WARN tarball tarball data for iobroker.icons-open-icon-library-png@https://github.com/ioBroker/ioBroker.icons-open-icon-library-png/tarball/master (sha512-qGFFRFfv/uSaVT+z3v01bwdZYjfIES0YwaHNOgy+OO28NMa8/8fh2rkBKGHNeHfFPBTo3juTeH+p6ngZ6s//7w==) seems to be corrupted. Trying one more time. npm WARN tarball tarball data for iobroker.icons-open-icon-library-png@https://github.com/ioBroker/ioBroker.icons-open-icon-library-png/tarball/master (sha512-qGFFRFfv/uSaVT+z3v01bwdZYjfIES0YwaHNOgy+OO28NMa8/8fh2rkBKGHNeHfFPBTo3juTeH+p6ngZ6s//7w==) seems to be corrupted. Trying one more time. npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents): npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"}) npm ERR! code EINTEGRITY npm ERR! Verification failed while extracting iobroker.icons-open-icon-library-png@https://github.com/ioBroker/ioBroker.icons-open-icon-library-png/tarball/master: npm ERR! Verification failed while extracting iobroker.icons-open-icon-library-png@https://github.com/ioBroker/ioBroker.icons-open-icon-library-png/tarball/master: npm ERR! sha512-qGFFRFfv/uSaVT+z3v01bwdZYjfIES0YwaHNOgy+OO28NMa8/8fh2rkBKGHNeHfFPBTo3juTeH+p6ngZ6s//7w== integrity checksum failed when using sha512: wanted sha512-qGFFRFfv/uSaVT+z3v01bwdZYjfIES0YwaHNOgy+OO28NMa8/8fh2rkBKGHNeHfFPBTo3juTeH+p6ngZ6s//7w== but got sha512-ZH4lj95sM6IpZEL2H1HR0hXTo6GMqbUBPbQyylgdRd6TDEdU+fgohUVGW4gPI0UnrAzqM/kx5+mozLqCVh2DCg==. (64751136 bytes) npm ERR! A complete log of this run can be found in: npm ERR! /home/iobroker/.npm/_logs/2022-02-04T06_43_35_307Z-debug.log mirko@iobroker:/opt/iobroker$Hier das npm log:
iob startet nicht.
@wendy2702 Mal den npm cache unter user iobroker löschen?
Habe gerade etwas Zeit. Neuen LXC aufgesetzt mit Debian 11. iobroker frisch installiert per einzeiler. Dann versucht JS4 zu installieren und wieder erhalte ich die "missing write access" fehler.
Hier das vollständige inklusive installation:
mirko@iobroker:~$ sudo apt update && sudo apt full-upgrade Wir gehen davon aus, dass der lokale Systemadministrator Ihnen die Regeln erklärt hat. Normalerweise läuft es auf drei Regeln hinaus: #1) Respektieren Sie die Privatsphäre anderer. #2) Denken Sie nach, bevor Sie tippen. #3) Mit großer Macht kommt große Verantwortung. [sudo] Passwort für mirko: OK:1 http://security.debian.org/debian-security bullseye-security InRelease OK:2 http://ftp.halifax.rwth-aachen.de/debian bullseye InRelease OK:3 http://ftp.halifax.rwth-aachen.de/debian bullseye-updates InRelease Paketlisten werden gelesen… Fertig Abhängigkeitsbaum wird aufgebaut… Fertig Statusinformationen werden eingelesen… Fertig Alle Pakete sind aktuell. Paketlisten werden gelesen… Fertig Abhängigkeitsbaum wird aufgebaut… Fertig Statusinformationen werden eingelesen… Fertig Paketaktualisierung (Upgrade) wird berechnet… Fertig 0 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert. mirko@iobroker:~$ curl -sLf https://iobroker.net/install.sh | bash - -bash: curl: Kommando nicht gefunden. mirko@iobroker:~$ sudo apt install curl Paketlisten werden gelesen… Fertig Abhängigkeitsbaum wird aufgebaut… Fertig Statusinformationen werden eingelesen… Fertig Die folgenden zusätzlichen Pakete werden installiert: libcurl4 Die folgenden NEUEN Pakete werden installiert: curl libcurl4 0 aktualisiert, 2 neu installiert, 0 zu entfernen und 0 nicht aktualisiert. Es müssen 608 kB an Archiven heruntergeladen werden. Nach dieser Operation werden 1.186 kB Plattenplatz zusätzlich benutzt. Möchten Sie fortfahren? [J/n] j Holen:1 http://ftp.halifax.rwth-aachen.de/debian bullseye/main amd64 libcurl4 amd64 7.74.0-1.3+deb11u1 [341 kB] Holen:2 http://ftp.halifax.rwth-aachen.de/debian bullseye/main amd64 curl amd64 7.74.0-1.3+deb11u1 [267 kB] Es wurden 608 kB in 0 s geholt (3.144 kB/s). Vormals nicht ausgewähltes Paket libcurl4:amd64 wird gewählt. (Lese Datenbank ... 33963 Dateien und Verzeichnisse sind derzeit installiert.) Vorbereitung zum Entpacken von .../libcurl4_7.74.0-1.3+deb11u1_amd64.deb ... Entpacken von libcurl4:amd64 (7.74.0-1.3+deb11u1) ... Vormals nicht ausgewähltes Paket curl wird gewählt. Vorbereitung zum Entpacken von .../curl_7.74.0-1.3+deb11u1_amd64.deb ... Entpacken von curl (7.74.0-1.3+deb11u1) ... libcurl4:amd64 (7.74.0-1.3+deb11u1) wird eingerichtet ... curl (7.74.0-1.3+deb11u1) wird eingerichtet ... Trigger für man-db (2.9.4-2) werden verarbeitet ... Trigger für libc-bin (2.31-13+deb11u2) werden verarbeitet ... mirko@iobroker:~$ curl -sLf https://iobroker.net/install.sh | bash - library: loaded Library version=2021-12-27 ========================================================================== Welcome to the ioBroker installer! Installer version: 2021-12-27 You might need to enter your password a couple of times. ========================================================================== ========================================================================== Installing prerequisites (1/4) ========================================================================== OK:1 http://ftp.halifax.rwth-aachen.de/debian bullseye InRelease OK:2 http://security.debian.org/debian-security bullseye-security InRelease OK:3 http://ftp.halifax.rwth-aachen.de/debian bullseye-updates InRelease Paketlisten werden gelesen… Fertig ========================================================================== Node.js not found. Installing... ========================================================================== ## Installing the NodeSource Node.js 14.x repo... ## Populating apt-get cache... + apt-get update OK:1 http://security.debian.org/debian-security bullseye-security InRelease OK:2 http://ftp.halifax.rwth-aachen.de/debian bullseye InRelease OK:3 http://ftp.halifax.rwth-aachen.de/debian bullseye-updates InRelease Paketlisten werden gelesen… Fertig ## Installing packages required for setup: gnupg... + apt-get install -y gnupg > /dev/null 2>&1 ## Confirming "bullseye" is supported... + curl -sLf -o /dev/null 'https://deb.nodesource.com/node_14.x/dists/bullseye/Release' ## Adding the NodeSource signing key to your keyring... + curl -s https://deb.nodesource.com/gpgkey/nodesource.gpg.key | gpg --dearmor | tee /usr/share/keyrings/nodesource.gpg >/dev/null ## Creating apt sources list file for the NodeSource Node.js 14.x repo... + echo 'deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_14.x bullseye main' > /etc/apt/sources.list.d/nodesource.list + echo 'deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_14.x bullseye main' >> /etc/apt/sources.list.d/nodesource.list ## Running `apt-get update` for you... + apt-get update OK:1 http://security.debian.org/debian-security bullseye-security InRelease OK:2 http://ftp.halifax.rwth-aachen.de/debian bullseye InRelease OK:3 http://ftp.halifax.rwth-aachen.de/debian bullseye-updates InRelease Holen:4 https://deb.nodesource.com/node_14.x bullseye InRelease [4.586 B] Holen:5 https://deb.nodesource.com/node_14.x bullseye/main amd64 Packages [773 B] Es wurden 5.359 B in 1 s geholt (4.229 B/s). Paketlisten werden gelesen… Fertig ## Run `sudo apt-get install -y nodejs` to install Node.js 14.x and npm ## You may also need development tools to build native addons: sudo apt-get install gcc g++ make ## To install the Yarn package manager, run: curl -sL https://dl.yarnpkg.com/debian/pubkey.gpg | gpg --dearmor | sudo tee /usr/share/keyrings/yarnkey.gpg >/dev/null echo "deb [signed-by=/usr/share/keyrings/yarnkey.gpg] https://dl.yarnpkg.com/debian stable main" | sudo tee /etc/apt/sources.list.d/yarn.list sudo apt-get update && sudo apt-get install yarn Installed nodejs Node.js Installed successfully! Changing npm registry to https://registry.npmjs.org Installed acl Installed build-essential Installed gcc-c++ Installed libavahi-compat-libdnssd-dev Installed libudev-dev Installed libpam0g-dev Installed git Installed unzip Installed libcairo2-dev Installed libpango1.0-dev Installed libjpeg-dev Installed libgif-dev Installed librsvg2-dev Installed net-tools Installed python-dev Installed cmake ========================================================================== Creating ioBroker user and directory (2/4) ========================================================================== User iobroker created Created /etc/sudoers.d/iobroker Directory /opt/iobroker created ========================================================================== Installing ioBroker (3/4) ========================================================================== In file included from ../../nan/nan.h:58, from ../src/main.cpp:3: /home/mirko/.cache/node-gyp/14.19.0/include/node/node.h:793:7: warning: cast between incompatible function types from ‘void (*)(v8::Local<v8::Object>)’ to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type] 793 | (node::addon_register_func) (regfunc), \ | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ /home/mirko/.cache/node-gyp/14.19.0/include/node/node.h:827:3: note: in expansion of macro ‘NODE_MODULE_X’ 827 | NODE_MODULE_X(modname, regfunc, NULL, 0) // NOLINT (readability/null_usage) | ^~~~~~~~~~~~~ ../src/main.cpp:42:1: note: in expansion of macro ‘NODE_MODULE’ 42 | NODE_MODULE(diskusage, Init) | ^~~~~~~~~~~ In file included from ../../nan/nan.h:58, from ../src/unix_dgram.cc:5: /home/mirko/.cache/node-gyp/14.19.0/include/node/node.h:793:7: warning: cast between incompatible function types from ‘void (*)(v8::Local<v8::Object>)’ to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type] 793 | (node::addon_register_func) (regfunc), \ | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ /home/mirko/.cache/node-gyp/14.19.0/include/node/node.h:827:3: note: in expansion of macro ‘NODE_MODULE_X’ 827 | NODE_MODULE_X(modname, regfunc, NULL, 0) // NOLINT (readability/null_usage) | ^~~~~~~~~~~~~ ../src/unix_dgram.cc:404:1: note: in expansion of macro ‘NODE_MODULE’ 404 | NODE_MODULE(unix_dgram, Initialize) | ^~~~~~~~~~~ ATTENTION: Error reporting via Sentry will be activated on next start of ioBroker ioBroker wants to make sure to deliver the most stable smart home system. To allow this we decided to implement an automatic error and crash reporting solution into the js-controller and also into adapters. THIS REPORTING WILL BE ENABLED WITH THE NEXT START OF YOUR IOBROKER! For any error that leads to the crash of the js-controller or one of the relevant adapters the error details are send to a server. For the js-controller and core adapters this server is located and operated in germany. For community adapters please check the Github Readme of the affected adapter for details which Sentry server is used. If you want to disable the error reporting you can use the command 'iobroker plugin disable sentry' This command will also make sure that no adapter that runs on this host will send crash reporting data to sentry. ========================================================================== Finalizing installation (4/4) ========================================================================== Enabling autostart... Created symlink /etc/systemd/system/multi-user.target.wants/iobroker.service → /lib/systemd/system/iobroker.service. Autostart enabled! Fixing directory permissions... ========================================================================== ioBroker was installed successfully Open http://192.168.178.108:8081 in a browser and start configuring! ========================================================================== You need to re-login before doing anything else on the console! mirko@iobroker:~$ iob -v 3.3.22 mirko@iobroker:~$ iob stop mirko@iobroker:~$ iob update Used repository: default hash changed or no sources cached => force download of new sources update done Adapter "admin" : 5.2.3 , installed 5.2.3 Adapter "backitup" : 2.2.3 , installed 2.2.3 Adapter "discovery" : 2.7.3 , installed 2.7.3 Controller "js-controller" : 3.3.22 , installed 3.3.22 mirko@iobroker:~$ cd /opt/iobroker/ mirko@iobroker:/opt/iobroker$ npm i iobroker.js-controller@next npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@iobroker/db-base/node_modules/fs-extra npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@iobroker/db-objects-file/node_modules/fs-extra npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@iobroker/db-objects-jsonl/node_modules/fs-extra npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/alcalzone-shared npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@alcalzone/jsonl-db npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/@types/node npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/@types/iobroker npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/adapter-core npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/array-flatten npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/assert-plus npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/asynckit npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/aws-sign2 npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/aws4 npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/bytes npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/caseless npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/connect-flash npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/content-type npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/cookie npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/cookie-signature npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/cookie-parser npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/core-util-is npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/dashdash npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/delayed-stream npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/combined-stream npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/depd npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/destroy npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/ee-first npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/encodeurl npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/escape-html npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/etag npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/express-session/node_modules/depd npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/extend npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/extsprintf npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/fast-deep-equal npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/fast-json-stable-stringify npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/forever-agent npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/forwarded npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/fresh npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/getpass npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/har-schema npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/inherits npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/ipaddr.js npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/is-typedarray npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/isstream npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/jsbn npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/json-schema npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/json-schema-traverse npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/json-stringify-safe npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/media-typer npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/merge-descriptors npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/methods npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/mime npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/mime-db npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/mime-types npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/form-data npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/ms npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/debug npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/negotiator npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/accepts npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/oauth-sign npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/on-finished npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/on-headers npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/parseurl npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/passport-strategy npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/passport-local npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/path-to-regexp npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/pause npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/passport npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/performance-now npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/proxy-addr npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/psl npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/punycode npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/qs npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/random-bytes npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/range-parser npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/request/node_modules/qs npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/safe-buffer npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/content-disposition npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/safer-buffer npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/asn1 npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/ecc-jsbn npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/iconv-lite npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/send/node_modules/ms npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/setprototypeof npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/statuses npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/streamsearch npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/dicer npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/busboy npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/express-fileupload npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/toidentifier npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/http-errors npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/send npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/serve-static npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/tough-cookie npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/tunnel-agent npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/tweetnacl npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/bcrypt-pbkdf npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/sshpk npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/type-is npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/uid-safe npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/express-session npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/unpipe npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/finalhandler npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/raw-body npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/body-parser npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/uri-js npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/har-validator npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/utils-merge npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/ajv npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/uuid npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/vary npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/express npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/verror npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/http-signature npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/jsprim npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/request npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/ws npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/xtend npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/passport.socketio npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/yallist npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/lru-cache npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/semver npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/@types/node npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/@types/iobroker npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/@iobroker/adapter-core npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/agent-base npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/array-flatten npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/arrify npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/assert-plus npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/asynckit npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/aws-sign2 npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/aws4 npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/balanced-match npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/base-64 npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/base64-js npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/bignumber.js npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/body-parser/node_modules/ms npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/body-parser/node_modules/debug npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/body-parser/node_modules/qs npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/buffer-equal-constant-time npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/bytes npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/caseless npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/charenc npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/chownr npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/concat-map npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/brace-expansion npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/content-type npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/cookie npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/cookie-signature npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/core-util-is npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/crypt npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/dashdash npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/delayed-stream npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/combined-stream npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/depd npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/destroy npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/ee-first npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/encodeurl npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/escape-html npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/etag npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/event-target-shim npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/abort-controller npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/express/node_modules/ms npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/express/node_modules/debug npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/express/node_modules/qs npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/extend npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/extsprintf npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/fast-deep-equal npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/fast-json-stable-stringify npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/fast-text-encoding npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/finalhandler/node_modules/ms npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/finalhandler/node_modules/debug npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/follow-redirects npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/axios npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/forever-agent npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/forwarded npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/fresh npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/fs-constants npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/function-bind npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/getpass npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/graceful-fs npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/har-schema npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/has npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/has-symbols npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/get-intrinsic npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/call-bind npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/he npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/hot-patcher npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/https-proxy-agent npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/ieee754 npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/buffer npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/inherits npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/ipaddr.js npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/is-buffer npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/is-stream npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/is-typedarray npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/isarray npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/isstream npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/jsbn npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/json-bigint npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/json-schema npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/json-schema-traverse npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/json-stringify-safe npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/layerr npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/long-timeout npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/luxon npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/md5 npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/media-typer npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/merge-descriptors npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/methods npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/mime npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/mime-db npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/mime-types npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/form-data npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/minimatch npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/mkdirp-classic npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/negotiator npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/accepts npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/nested-property npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/node-forge npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/google-p12-pem npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/node-wol npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/oauth-sign npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/object-inspect npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/object-keys npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/define-properties npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/is-nan npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/cron-parser npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/on-finished npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/parseurl npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/path-posix npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/path-to-regexp npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/performance-now npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/proxy-addr npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/psl npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/punycode npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/querystringify npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/range-parser npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/request/node_modules/qs npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/request/node_modules/uuid npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/requires-port npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/safe-buffer npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/bl/node_modules/string_decoder npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/content-disposition npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/ecdsa-sig-formatter npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/jwa npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/jws npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/safer-buffer npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/asn1 npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/ecc-jsbn npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/iconv-lite npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/send/node_modules/debug/node_modules/ms npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/send/node_modules/debug npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/send/node_modules/ms npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/setprototypeof npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/side-channel npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/qs npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/sorted-array-functions npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/node-schedule npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/statuses npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/string_decoder npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/readable-stream npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/strnum npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/fast-xml-parser npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/tar-stream/node_modules/string_decoder npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/toidentifier npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/http-errors npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/send npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/serve-static npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/tough-cookie npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/tr46 npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/tunnel-agent npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/tweetnacl npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/bcrypt-pbkdf npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/sshpk npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/type-is npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/universalify npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/jsonfile npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/fs-extra npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/unpipe npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/finalhandler npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/raw-body npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/body-parser npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/uri-js npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/ajv npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/har-validator npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/url-join npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/url-parse npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/url-template npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/util-deprecate npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/bl/node_modules/readable-stream npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/bl npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/tar-stream/node_modules/readable-stream npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/utils-merge npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/uuid npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/vary npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/express npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/verror npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/jsprim npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/http-signature npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/request npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/dropbox-v2-api npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/webdav npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/webidl-conversions npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/whatwg-url npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/node-fetch npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/gaxios npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/gcp-metadata npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/gtoken npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/wrappy npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/once npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/end-of-stream npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/tar-stream npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/pump npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/tar-fs npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/xregexp npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/ftp npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/yallist npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/lru-cache npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/google-auth-library npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/googleapis-common npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/@googleapis/drive npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/binding-abstract/node_modules/ms npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/binding-abstract/node_modules/debug npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/binding-abstract npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/binding-mock/node_modules/ms npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/binding-mock/node_modules/debug npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/binding-mock npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/bindings/node_modules/ms npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/bindings/node_modules/debug npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/parser-byte-length npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/parser-cctalk npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/parser-delimiter npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/parser-inter-byte-timeout npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/parser-readline npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/parser-ready npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/parser-regex npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/stream/node_modules/ms npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/stream/node_modules/debug npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/stream npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@types/node npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@types/iobroker npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@iobroker/adapter-core npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/ansi-regex npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/aproba npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/base64-js npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/bluebird npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/chownr npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/code-point-at npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/console-control-strings npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/core-util-is npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/deep-extend npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/delegates npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/detect-libc npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/dgram npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/expand-template npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/extend npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/file-uri-to-path npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/bindings npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/fs-constants npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/github-from-package npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/has-unicode npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/ieee754 npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/buffer npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/inherits npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/ini npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/ip npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/isarray npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/lodash npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/async npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/mimic-response npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/decompress-response npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/minimist npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/mkdirp-classic npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/ms npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/debug npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/nan npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/napi-build-utils npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/netmask npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/node-mndp npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/node-ssdp/node_modules/ms npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/node-ssdp/node_modules/debug npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/node-ssdp npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/number-is-nan npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/is-fullwidth-code-point npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/object-assign npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/process-nextick-args npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/readable-stream/node_modules/safe-buffer npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/safe-buffer npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/dns-packet npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/mdns-discovery npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/serialport/node_modules/ms npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/serialport/node_modules/debug npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/set-blocking npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/signal-exit npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/simple-concat npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/string_decoder/node_modules/safe-buffer npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/string_decoder npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/strip-ansi npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/string-width npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/strip-json-comments npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/rc npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/tunnel-agent npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/util-deprecate npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/bl/node_modules/readable-stream npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/bl npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/readable-stream npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/are-we-there-yet npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/tar-stream/node_modules/readable-stream npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/wide-align npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/gauge npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/npmlog npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/wrappy npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/once npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/end-of-stream npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/tar-stream npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/pump npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/tar-fs npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/simple-get npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/yallist npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/lru-cache npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/semver npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/node-abi npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/prebuild-install npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/bindings npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/serialport npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.js-controller/node_modules/fs-extra npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.js-controller/node_modules/node-forge npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/logform/node_modules/safe-stable-stringify npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/ncp npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/pidusage npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/safe-stable-stringify npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/seq-logging npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@iobroker/db-base npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@iobroker/db-objects-redis npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@iobroker/db-objects-file npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@iobroker/db-objects-jsonl npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@iobroker/db-states-redis npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@iobroker/db-states-file npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@iobroker/db-states-jsonl npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/yargs-parser npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.js-controller/node_modules/mime npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/yargs npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.js-controller npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@iobroker/db-objects-file/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@iobroker/db-objects-jsonl/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@alcalzone npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@iobroker/db-base/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/@types npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/express-session/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/request/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/send/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/@types npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/@iobroker npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/body-parser/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/express/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/finalhandler/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/request/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/bl/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/send/node_modules/debug/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/send/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/tar-stream/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/@googleapis npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/binding-abstract/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/binding-mock/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/bindings/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/stream/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@types npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@iobroker npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/node-ssdp/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/readable-stream/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/serialport/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/string_decoder/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/bl/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/tar-stream/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.js-controller/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/logform/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@iobroker npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/winston/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/winston-seq-updated npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@alcalzone/jsonl-db/node_modules npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents): npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"}) npm ERR! code EACCES npm ERR! syscall access npm ERR! path /opt/iobroker/node_modules/@iobroker/db-base/node_modules/fs-extra npm ERR! errno -13 npm ERR! Error: EACCES: permission denied, access '/opt/iobroker/node_modules/@iobroker/db-base/node_modules/fs-extra' npm ERR! [Error: EACCES: permission denied, access '/opt/iobroker/node_modules/@iobroker/db-base/node_modules/fs-extra'] { npm ERR! errno: -13, npm ERR! code: 'EACCES', npm ERR! syscall: 'access', npm ERR! path: '/opt/iobroker/node_modules/@iobroker/db-base/node_modules/fs-extra' npm ERR! } npm ERR! npm ERR! The operation was rejected by your operating system. npm ERR! It is likely you do not have the permissions to access this file as the current user npm ERR! npm ERR! If you believe this might be a permissions issue, please double-check the npm ERR! permissions of the file and its containing directories, or try running npm ERR! the command again as root/Administrator. npm ERR! A complete log of this run can be found in: npm ERR! /home/mirko/.npm/_logs/2022-02-04T07_26_29_636Z-debug.log mirko@iobroker:/opt/iobroker$@wendy2702 WTF ... alle meine Testsysteme sind Proxmox im lxc ... und eins in ner VM ... bei mir tut alles. wie sind denn die container einstellungen? Wil ja bin ehrlich beiu mir laufen die container der testsysteme unter root und nicht nem user ... das mag der unterschied sein?
Aber nochmal: Sollte nichts mit js-controller zu tun haben ... Das ist npm und irgendwelche File Rechte
@wendy2702 da stimmt mit dem REPO was nicht
https://github.com/ioBroker/ioBroker.icons-open-icon-library-pngbekomme es nichtmal installiert
liegt nicht am 4.x
@wendy2702 Mal den npm cache unter user iobroker löschen?
@apollon77 sagte in Alpha Test js-controller 4.0:
Bei einer neu installation ?
Kann ich aber gerne noch versuchen.
Habe auf dem neuen System mal noch
iob fixlaufen lassen. Danach immer noch write access fehler
mirko@iobroker:/opt/iobroker$ iob fix library: loaded Library version=2021-12-27 ========================================================================== Welcome to the ioBroker installation fixer! Script version: 2021-12-27 You might need to enter your password a couple of times. ========================================================================== ========================================================================== Installing prerequisites (1/3) ========================================================================== OK:1 http://security.debian.org/debian-security bullseye-security InRelease OK:2 http://ftp.halifax.rwth-aachen.de/debian bullseye InRelease OK:3 http://ftp.halifax.rwth-aachen.de/debian bullseye-updates InRelease OK:4 https://deb.nodesource.com/node_14.x bullseye InRelease Paketlisten werden gelesen… Fertig Installed gcc-c++ Installed python-dev ========================================================================== Checking ioBroker user and directory permissions (2/3) ========================================================================== Created /etc/sudoers.d/iobroker Fixing directory permissions... ========================================================================== Checking autostart (3/3) ========================================================================== Enabling autostart... Autostart enabled! ========================================================================== Your installation was fixed successfully Run iobroker start to start ioBroker again! ========================================================================== mirko@iobroker:/opt/iobroker$ iob start mirko@iobroker:/opt/iobroker$ tail -f /opt/iobroker/log/iobroker iobroker.2022-02-04.log iobroker-audit.json iobroker.current.log mirko@iobroker:/opt/iobroker$ tail -f /opt/iobroker/log/iobroker iobroker.2022-02-04.log iobroker-audit.json iobroker.current.log mirko@iobroker:/opt/iobroker$ tail -f /opt/iobroker/log/iobroker.current.log 2022-02-04 08:30:27.060 - info: admin.0 (11589) requesting all states 2022-02-04 08:30:27.060 - info: admin.0 (11589) requesting all objects 2022-02-04 08:30:27.185 - info: admin.0 (11589) received all objects 2022-02-04 08:30:27.297 - info: admin.0 (11589) http server listening on port 8081 2022-02-04 08:30:27.298 - info: admin.0 (11589) Use link "http://localhost:8081" to configure. 2022-02-04 08:30:30.017 - info: host.iobroker instance system.adapter.discovery.0 started with pid 11604 2022-02-04 08:30:30.634 - info: discovery.0 (11604) starting. Version 2.7.3 in /opt/iobroker/node_modules/iobroker.discovery, node: v14.19.0, js-controller: 3.3.22 2022-02-04 08:30:34.011 - info: host.iobroker instance system.adapter.backitup.0 started with pid 11627 2022-02-04 08:30:34.715 - info: backitup.0 (11627) starting. Version 2.2.3 in /opt/iobroker/node_modules/iobroker.backitup, node: v14.19.0, js-controller: 3.3.22 2022-02-04 08:30:34.783 - info: backitup.0 (11627) [iobroker] backup was activated at 02:40 every 1 day(s) ^C mirko@iobroker:/opt/iobroker$ iob stop mirko@iobroker:/opt/iobroker$ ps auxww|grep io root 13 0.0 0.0 0 0 ? S 08:18 0:00 [migration/0] root 17 0.0 0.0 0 0 ? S 08:18 0:00 [migration/1] root 22 0.0 0.0 0 0 ? S 08:18 0:00 [migration/2] root 27 0.0 0.0 0 0 ? S 08:18 0:00 [migration/3] root 65 0.0 0.0 0 0 ? I< 08:18 0:00 [blkcg_punt_bio] message+ 305 0.0 0.0 8208 4540 ? Ss 08:18 0:00 /usr/bin/dbus-daemon --system --address=systemd: --nofork --nopidfile --systemd-activation --syslog-only root 11487 0.0 0.0 0 0 ? I 08:29 0:00 [kworker/u8:1-ext4-rsv-conversion] mirko 11666 0.0 0.0 6200 712 pts/0 R+ 08:31 0:00 grep io mirko@iobroker:/opt/iobroker$ ps auxww|grep backup mirko 11668 0.0 0.0 6200 652 pts/0 R+ 08:31 0:00 grep backup mirko@iobroker:/opt/iobroker$ npm i iobroker.js-controller@next npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@iobroker/db-base/node_modules/fs-extra npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@iobroker/db-objects-file/node_modules/fs-extra npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@iobroker/db-objects-jsonl/node_modules/fs-extra npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/alcalzone-shared npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@alcalzone/jsonl-db npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/@types/node npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/@types/iobroker npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/adapter-core npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/array-flatten npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/assert-plus npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/asynckit npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/aws-sign2 npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/aws4 npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/bytes npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/caseless npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/connect-flash npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/content-type npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/cookie npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/cookie-signature npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/cookie-parser npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/core-util-is npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/dashdash npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/delayed-stream npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/combined-stream npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/depd npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/destroy npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/ee-first npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/encodeurl npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/escape-html npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/etag npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/express-session/node_modules/depd npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/extend npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/extsprintf npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/fast-deep-equal npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/fast-json-stable-stringify npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/forever-agent npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/forwarded npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/fresh npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/getpass npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/har-schema npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/inherits npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/ipaddr.js npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/is-typedarray npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/isstream npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/jsbn npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/json-schema npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/json-schema-traverse npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/json-stringify-safe npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/media-typer npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/merge-descriptors npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/methods npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/mime npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/mime-db npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/mime-types npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/form-data npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/ms npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/debug npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/negotiator npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/accepts npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/oauth-sign npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/on-finished npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/on-headers npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/parseurl npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/passport-strategy npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/passport-local npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/path-to-regexp npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/pause npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/passport npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/performance-now npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/proxy-addr npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/psl npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/punycode npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/qs npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/random-bytes npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/range-parser npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/request/node_modules/qs npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/safe-buffer npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/content-disposition npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/safer-buffer npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/asn1 npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/ecc-jsbn npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/iconv-lite npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/send/node_modules/ms npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/setprototypeof npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/statuses npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/streamsearch npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/dicer npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/busboy npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/express-fileupload npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/toidentifier npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/http-errors npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/send npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/serve-static npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/tough-cookie npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/tunnel-agent npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/tweetnacl npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/bcrypt-pbkdf npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/sshpk npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/type-is npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/uid-safe npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/express-session npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/unpipe npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/finalhandler npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/raw-body npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/body-parser npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/uri-js npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/ajv npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/har-validator npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/utils-merge npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/uuid npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/vary npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/express npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/verror npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/jsprim npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/http-signature npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/request npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/ws npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/xtend npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/passport.socketio npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/yallist npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/lru-cache npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/semver npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/@types/node npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/@types/iobroker npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/@iobroker/adapter-core npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/agent-base npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/array-flatten npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/arrify npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/assert-plus npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/asynckit npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/aws-sign2 npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/aws4 npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/balanced-match npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/base-64 npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/base64-js npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/bignumber.js npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/body-parser/node_modules/ms npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/body-parser/node_modules/debug npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/body-parser/node_modules/qs npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/buffer-equal-constant-time npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/bytes npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/caseless npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/charenc npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/chownr npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/concat-map npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/brace-expansion npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/content-type npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/cookie npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/cookie-signature npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/core-util-is npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/crypt npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/dashdash npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/delayed-stream npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/combined-stream npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/depd npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/destroy npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/ee-first npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/encodeurl npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/escape-html npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/etag npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/event-target-shim npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/abort-controller npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/express/node_modules/ms npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/express/node_modules/debug npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/express/node_modules/qs npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/extend npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/extsprintf npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/fast-deep-equal npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/fast-json-stable-stringify npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/fast-text-encoding npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/finalhandler/node_modules/ms npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/finalhandler/node_modules/debug npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/follow-redirects npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/axios npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/forever-agent npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/forwarded npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/fresh npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/fs-constants npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/function-bind npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/getpass npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/graceful-fs npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/har-schema npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/has npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/has-symbols npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/get-intrinsic npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/call-bind npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/he npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/hot-patcher npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/https-proxy-agent npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/ieee754 npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/buffer npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/inherits npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/ipaddr.js npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/is-buffer npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/is-stream npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/is-typedarray npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/isarray npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/isstream npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/jsbn npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/json-bigint npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/json-schema npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/json-schema-traverse npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/json-stringify-safe npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/layerr npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/long-timeout npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/luxon npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/md5 npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/media-typer npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/merge-descriptors npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/methods npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/mime npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/mime-db npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/mime-types npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/form-data npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/minimatch npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/mkdirp-classic npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/negotiator npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/accepts npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/nested-property npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/node-forge npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/google-p12-pem npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/node-wol npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/oauth-sign npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/object-inspect npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/object-keys npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/define-properties npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/is-nan npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/cron-parser npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/on-finished npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/parseurl npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/path-posix npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/path-to-regexp npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/performance-now npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/proxy-addr npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/psl npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/punycode npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/querystringify npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/range-parser npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/request/node_modules/qs npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/request/node_modules/uuid npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/requires-port npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/safe-buffer npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/bl/node_modules/string_decoder npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/content-disposition npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/ecdsa-sig-formatter npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/jwa npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/jws npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/safer-buffer npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/asn1 npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/ecc-jsbn npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/iconv-lite npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/send/node_modules/debug/node_modules/ms npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/send/node_modules/debug npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/send/node_modules/ms npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/setprototypeof npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/side-channel npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/qs npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/sorted-array-functions npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/node-schedule npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/statuses npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/string_decoder npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/readable-stream npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/strnum npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/fast-xml-parser npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/tar-stream/node_modules/string_decoder npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/toidentifier npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/http-errors npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/send npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/serve-static npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/tough-cookie npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/tr46 npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/tunnel-agent npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/tweetnacl npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/bcrypt-pbkdf npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/sshpk npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/type-is npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/universalify npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/jsonfile npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/fs-extra npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/unpipe npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/finalhandler npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/raw-body npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/body-parser npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/uri-js npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/ajv npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/har-validator npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/url-join npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/url-parse npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/url-template npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/util-deprecate npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/bl/node_modules/readable-stream npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/bl npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/tar-stream/node_modules/readable-stream npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/utils-merge npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/uuid npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/vary npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/express npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/verror npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/jsprim npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/http-signature npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/request npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/dropbox-v2-api npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/webdav npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/webidl-conversions npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/whatwg-url npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/node-fetch npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/gaxios npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/gcp-metadata npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/gtoken npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/wrappy npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/once npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/end-of-stream npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/tar-stream npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/pump npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/tar-fs npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/xregexp npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/ftp npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/yallist npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/lru-cache npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/google-auth-library npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/googleapis-common npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/@googleapis/drive npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/binding-abstract/node_modules/ms npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/binding-abstract/node_modules/debug npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/binding-abstract npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/binding-mock/node_modules/ms npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/binding-mock/node_modules/debug npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/binding-mock npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/bindings/node_modules/ms npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/bindings/node_modules/debug npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/parser-byte-length npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/parser-cctalk npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/parser-delimiter npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/parser-inter-byte-timeout npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/parser-readline npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/parser-ready npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/parser-regex npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/stream/node_modules/ms npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/stream/node_modules/debug npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/stream npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@types/node npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@types/iobroker npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@iobroker/adapter-core npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/ansi-regex npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/aproba npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/base64-js npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/bluebird npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/chownr npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/code-point-at npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/console-control-strings npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/core-util-is npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/deep-extend npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/delegates npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/detect-libc npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/dgram npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/expand-template npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/extend npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/file-uri-to-path npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/bindings npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/fs-constants npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/github-from-package npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/has-unicode npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/ieee754 npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/buffer npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/inherits npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/ini npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/ip npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/isarray npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/lodash npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/async npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/mimic-response npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/decompress-response npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/minimist npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/mkdirp-classic npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/ms npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/debug npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/nan npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/napi-build-utils npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/netmask npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/node-mndp npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/node-ssdp/node_modules/ms npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/node-ssdp/node_modules/debug npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/node-ssdp npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/number-is-nan npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/is-fullwidth-code-point npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/object-assign npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/process-nextick-args npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/readable-stream/node_modules/safe-buffer npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/safe-buffer npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/dns-packet npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/mdns-discovery npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/serialport/node_modules/ms npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/serialport/node_modules/debug npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/set-blocking npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/signal-exit npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/simple-concat npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/string_decoder/node_modules/safe-buffer npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/string_decoder npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/strip-ansi npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/string-width npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/strip-json-comments npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/rc npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/tunnel-agent npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/util-deprecate npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/bl/node_modules/readable-stream npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/bl npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/readable-stream npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/are-we-there-yet npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/tar-stream/node_modules/readable-stream npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/wide-align npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/gauge npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/npmlog npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/wrappy npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/once npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/end-of-stream npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/tar-stream npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/pump npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/tar-fs npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/simple-get npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/yallist npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/lru-cache npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/semver npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/node-abi npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/prebuild-install npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/bindings npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/serialport npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.js-controller/node_modules/fs-extra npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.js-controller/node_modules/node-forge npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/logform/node_modules/safe-stable-stringify npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/ncp npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/pidusage npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/safe-stable-stringify npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/seq-logging npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@iobroker/db-base npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@iobroker/db-objects-redis npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@iobroker/db-objects-file npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@iobroker/db-objects-jsonl npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@iobroker/db-states-redis npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@iobroker/db-states-file npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@iobroker/db-states-jsonl npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/yargs-parser npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.js-controller/node_modules/mime npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/yargs npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.js-controller npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@iobroker/db-base/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@iobroker/db-objects-file/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@iobroker/db-objects-jsonl/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@alcalzone npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/@types npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/express-session/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/request/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/send/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/@types npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/@iobroker npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/body-parser/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/express/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/finalhandler/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/request/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/bl/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/send/node_modules/debug/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/send/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/tar-stream/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/@googleapis npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/binding-abstract/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/binding-mock/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/bindings/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/stream/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@types npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@iobroker npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/node-ssdp/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/readable-stream/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/serialport/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/string_decoder/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/bl/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/tar-stream/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.js-controller/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/logform/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@iobroker npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/winston/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/winston-seq-updated npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@alcalzone/jsonl-db/node_modules npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents): npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"}) npm ERR! code EACCES npm ERR! syscall access npm ERR! path /opt/iobroker/node_modules/@iobroker/db-base/node_modules/fs-extra npm ERR! errno -13 npm ERR! Error: EACCES: permission denied, access '/opt/iobroker/node_modules/@iobroker/db-base/node_modules/fs-extra' npm ERR! [Error: EACCES: permission denied, access '/opt/iobroker/node_modules/@iobroker/db-base/node_modules/fs-extra'] { npm ERR! errno: -13, npm ERR! code: 'EACCES', npm ERR! syscall: 'access', npm ERR! path: '/opt/iobroker/node_modules/@iobroker/db-base/node_modules/fs-extra' npm ERR! } npm ERR! npm ERR! The operation was rejected by your operating system. npm ERR! It is likely you do not have the permissions to access this file as the current user npm ERR! npm ERR! If you believe this might be a permissions issue, please double-check the npm ERR! permissions of the file and its containing directories, or try running npm ERR! the command again as root/Administrator. npm ERR! A complete log of this run can be found in: npm ERR! /home/mirko/.npm/_logs/2022-02-04T07_32_08_765Z-debug.log mirko@iobroker:/opt/iobroker$Kann mal noch eine VM probieren und eine mit root
@apollon77 sagte in Alpha Test js-controller 4.0:
@wendy2702 Mal den npm cache unter user iobroker löschen?
Bei einer neu installation ?
Kann ich aber gerne noch versuchen.
Habe auf dem neuen System mal noch
iob fixlaufen lassen. Danach immer noch write access fehler
mirko@iobroker:/opt/iobroker$ iob fix library: loaded Library version=2021-12-27 ========================================================================== Welcome to the ioBroker installation fixer! Script version: 2021-12-27 You might need to enter your password a couple of times. ========================================================================== ========================================================================== Installing prerequisites (1/3) ========================================================================== OK:1 http://security.debian.org/debian-security bullseye-security InRelease OK:2 http://ftp.halifax.rwth-aachen.de/debian bullseye InRelease OK:3 http://ftp.halifax.rwth-aachen.de/debian bullseye-updates InRelease OK:4 https://deb.nodesource.com/node_14.x bullseye InRelease Paketlisten werden gelesen… Fertig Installed gcc-c++ Installed python-dev ========================================================================== Checking ioBroker user and directory permissions (2/3) ========================================================================== Created /etc/sudoers.d/iobroker Fixing directory permissions... ========================================================================== Checking autostart (3/3) ========================================================================== Enabling autostart... Autostart enabled! ========================================================================== Your installation was fixed successfully Run iobroker start to start ioBroker again! ========================================================================== mirko@iobroker:/opt/iobroker$ iob start mirko@iobroker:/opt/iobroker$ tail -f /opt/iobroker/log/iobroker iobroker.2022-02-04.log iobroker-audit.json iobroker.current.log mirko@iobroker:/opt/iobroker$ tail -f /opt/iobroker/log/iobroker iobroker.2022-02-04.log iobroker-audit.json iobroker.current.log mirko@iobroker:/opt/iobroker$ tail -f /opt/iobroker/log/iobroker.current.log 2022-02-04 08:30:27.060 - info: admin.0 (11589) requesting all states 2022-02-04 08:30:27.060 - info: admin.0 (11589) requesting all objects 2022-02-04 08:30:27.185 - info: admin.0 (11589) received all objects 2022-02-04 08:30:27.297 - info: admin.0 (11589) http server listening on port 8081 2022-02-04 08:30:27.298 - info: admin.0 (11589) Use link "http://localhost:8081" to configure. 2022-02-04 08:30:30.017 - info: host.iobroker instance system.adapter.discovery.0 started with pid 11604 2022-02-04 08:30:30.634 - info: discovery.0 (11604) starting. Version 2.7.3 in /opt/iobroker/node_modules/iobroker.discovery, node: v14.19.0, js-controller: 3.3.22 2022-02-04 08:30:34.011 - info: host.iobroker instance system.adapter.backitup.0 started with pid 11627 2022-02-04 08:30:34.715 - info: backitup.0 (11627) starting. Version 2.2.3 in /opt/iobroker/node_modules/iobroker.backitup, node: v14.19.0, js-controller: 3.3.22 2022-02-04 08:30:34.783 - info: backitup.0 (11627) [iobroker] backup was activated at 02:40 every 1 day(s) ^C mirko@iobroker:/opt/iobroker$ iob stop mirko@iobroker:/opt/iobroker$ ps auxww|grep io root 13 0.0 0.0 0 0 ? S 08:18 0:00 [migration/0] root 17 0.0 0.0 0 0 ? S 08:18 0:00 [migration/1] root 22 0.0 0.0 0 0 ? S 08:18 0:00 [migration/2] root 27 0.0 0.0 0 0 ? S 08:18 0:00 [migration/3] root 65 0.0 0.0 0 0 ? I< 08:18 0:00 [blkcg_punt_bio] message+ 305 0.0 0.0 8208 4540 ? Ss 08:18 0:00 /usr/bin/dbus-daemon --system --address=systemd: --nofork --nopidfile --systemd-activation --syslog-only root 11487 0.0 0.0 0 0 ? I 08:29 0:00 [kworker/u8:1-ext4-rsv-conversion] mirko 11666 0.0 0.0 6200 712 pts/0 R+ 08:31 0:00 grep io mirko@iobroker:/opt/iobroker$ ps auxww|grep backup mirko 11668 0.0 0.0 6200 652 pts/0 R+ 08:31 0:00 grep backup mirko@iobroker:/opt/iobroker$ npm i iobroker.js-controller@next npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@iobroker/db-base/node_modules/fs-extra npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@iobroker/db-objects-file/node_modules/fs-extra npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@iobroker/db-objects-jsonl/node_modules/fs-extra npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/alcalzone-shared npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@alcalzone/jsonl-db npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/@types/node npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/@types/iobroker npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/adapter-core npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/array-flatten npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/assert-plus npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/asynckit npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/aws-sign2 npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/aws4 npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/bytes npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/caseless npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/connect-flash npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/content-type npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/cookie npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/cookie-signature npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/cookie-parser npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/core-util-is npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/dashdash npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/delayed-stream npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/combined-stream npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/depd npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/destroy npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/ee-first npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/encodeurl npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/escape-html npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/etag npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/express-session/node_modules/depd npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/extend npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/extsprintf npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/fast-deep-equal npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/fast-json-stable-stringify npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/forever-agent npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/forwarded npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/fresh npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/getpass npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/har-schema npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/inherits npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/ipaddr.js npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/is-typedarray npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/isstream npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/jsbn npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/json-schema npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/json-schema-traverse npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/json-stringify-safe npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/media-typer npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/merge-descriptors npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/methods npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/mime npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/mime-db npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/mime-types npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/form-data npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/ms npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/debug npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/negotiator npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/accepts npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/oauth-sign npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/on-finished npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/on-headers npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/parseurl npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/passport-strategy npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/passport-local npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/path-to-regexp npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/pause npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/passport npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/performance-now npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/proxy-addr npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/psl npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/punycode npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/qs npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/random-bytes npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/range-parser npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/request/node_modules/qs npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/safe-buffer npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/content-disposition npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/safer-buffer npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/asn1 npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/ecc-jsbn npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/iconv-lite npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/send/node_modules/ms npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/setprototypeof npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/statuses npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/streamsearch npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/dicer npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/busboy npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/express-fileupload npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/toidentifier npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/http-errors npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/send npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/serve-static npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/tough-cookie npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/tunnel-agent npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/tweetnacl npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/bcrypt-pbkdf npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/sshpk npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/type-is npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/uid-safe npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/express-session npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/unpipe npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/finalhandler npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/raw-body npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/body-parser npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/uri-js npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/ajv npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/har-validator npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/utils-merge npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/uuid npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/vary npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/express npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/verror npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/jsprim npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/http-signature npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/request npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/ws npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/xtend npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/passport.socketio npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/yallist npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/lru-cache npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/semver npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/@types/node npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/@types/iobroker npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/@iobroker/adapter-core npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/agent-base npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/array-flatten npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/arrify npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/assert-plus npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/asynckit npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/aws-sign2 npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/aws4 npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/balanced-match npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/base-64 npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/base64-js npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/bignumber.js npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/body-parser/node_modules/ms npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/body-parser/node_modules/debug npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/body-parser/node_modules/qs npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/buffer-equal-constant-time npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/bytes npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/caseless npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/charenc npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/chownr npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/concat-map npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/brace-expansion npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/content-type npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/cookie npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/cookie-signature npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/core-util-is npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/crypt npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/dashdash npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/delayed-stream npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/combined-stream npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/depd npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/destroy npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/ee-first npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/encodeurl npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/escape-html npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/etag npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/event-target-shim npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/abort-controller npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/express/node_modules/ms npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/express/node_modules/debug npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/express/node_modules/qs npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/extend npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/extsprintf npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/fast-deep-equal npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/fast-json-stable-stringify npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/fast-text-encoding npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/finalhandler/node_modules/ms npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/finalhandler/node_modules/debug npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/follow-redirects npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/axios npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/forever-agent npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/forwarded npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/fresh npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/fs-constants npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/function-bind npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/getpass npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/graceful-fs npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/har-schema npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/has npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/has-symbols npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/get-intrinsic npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/call-bind npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/he npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/hot-patcher npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/https-proxy-agent npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/ieee754 npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/buffer npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/inherits npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/ipaddr.js npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/is-buffer npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/is-stream npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/is-typedarray npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/isarray npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/isstream npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/jsbn npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/json-bigint npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/json-schema npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/json-schema-traverse npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/json-stringify-safe npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/layerr npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/long-timeout npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/luxon npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/md5 npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/media-typer npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/merge-descriptors npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/methods npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/mime npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/mime-db npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/mime-types npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/form-data npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/minimatch npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/mkdirp-classic npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/negotiator npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/accepts npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/nested-property npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/node-forge npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/google-p12-pem npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/node-wol npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/oauth-sign npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/object-inspect npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/object-keys npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/define-properties npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/is-nan npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/cron-parser npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/on-finished npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/parseurl npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/path-posix npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/path-to-regexp npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/performance-now npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/proxy-addr npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/psl npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/punycode npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/querystringify npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/range-parser npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/request/node_modules/qs npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/request/node_modules/uuid npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/requires-port npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/safe-buffer npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/bl/node_modules/string_decoder npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/content-disposition npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/ecdsa-sig-formatter npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/jwa npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/jws npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/safer-buffer npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/asn1 npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/ecc-jsbn npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/iconv-lite npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/send/node_modules/debug/node_modules/ms npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/send/node_modules/debug npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/send/node_modules/ms npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/setprototypeof npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/side-channel npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/qs npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/sorted-array-functions npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/node-schedule npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/statuses npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/string_decoder npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/readable-stream npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/strnum npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/fast-xml-parser npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/tar-stream/node_modules/string_decoder npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/toidentifier npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/http-errors npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/send npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/serve-static npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/tough-cookie npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/tr46 npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/tunnel-agent npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/tweetnacl npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/bcrypt-pbkdf npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/sshpk npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/type-is npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/universalify npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/jsonfile npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/fs-extra npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/unpipe npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/finalhandler npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/raw-body npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/body-parser npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/uri-js npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/ajv npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/har-validator npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/url-join npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/url-parse npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/url-template npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/util-deprecate npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/bl/node_modules/readable-stream npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/bl npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/tar-stream/node_modules/readable-stream npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/utils-merge npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/uuid npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/vary npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/express npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/verror npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/jsprim npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/http-signature npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/request npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/dropbox-v2-api npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/webdav npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/webidl-conversions npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/whatwg-url npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/node-fetch npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/gaxios npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/gcp-metadata npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/gtoken npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/wrappy npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/once npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/end-of-stream npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/tar-stream npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/pump npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/tar-fs npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/xregexp npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/ftp npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/yallist npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/lru-cache npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/google-auth-library npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/googleapis-common npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/@googleapis/drive npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/binding-abstract/node_modules/ms npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/binding-abstract/node_modules/debug npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/binding-abstract npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/binding-mock/node_modules/ms npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/binding-mock/node_modules/debug npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/binding-mock npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/bindings/node_modules/ms npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/bindings/node_modules/debug npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/parser-byte-length npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/parser-cctalk npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/parser-delimiter npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/parser-inter-byte-timeout npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/parser-readline npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/parser-ready npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/parser-regex npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/stream/node_modules/ms npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/stream/node_modules/debug npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/stream npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@types/node npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@types/iobroker npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@iobroker/adapter-core npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/ansi-regex npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/aproba npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/base64-js npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/bluebird npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/chownr npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/code-point-at npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/console-control-strings npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/core-util-is npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/deep-extend npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/delegates npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/detect-libc npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/dgram npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/expand-template npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/extend npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/file-uri-to-path npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/bindings npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/fs-constants npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/github-from-package npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/has-unicode npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/ieee754 npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/buffer npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/inherits npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/ini npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/ip npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/isarray npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/lodash npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/async npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/mimic-response npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/decompress-response npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/minimist npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/mkdirp-classic npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/ms npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/debug npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/nan npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/napi-build-utils npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/netmask npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/node-mndp npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/node-ssdp/node_modules/ms npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/node-ssdp/node_modules/debug npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/node-ssdp npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/number-is-nan npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/is-fullwidth-code-point npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/object-assign npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/process-nextick-args npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/readable-stream/node_modules/safe-buffer npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/safe-buffer npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/dns-packet npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/mdns-discovery npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/serialport/node_modules/ms npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/serialport/node_modules/debug npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/set-blocking npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/signal-exit npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/simple-concat npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/string_decoder/node_modules/safe-buffer npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/string_decoder npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/strip-ansi npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/string-width npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/strip-json-comments npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/rc npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/tunnel-agent npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/util-deprecate npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/bl/node_modules/readable-stream npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/bl npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/readable-stream npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/are-we-there-yet npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/tar-stream/node_modules/readable-stream npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/wide-align npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/gauge npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/npmlog npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/wrappy npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/once npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/end-of-stream npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/tar-stream npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/pump npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/tar-fs npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/simple-get npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/yallist npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/lru-cache npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/semver npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/node-abi npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/prebuild-install npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/bindings npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/serialport npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.js-controller/node_modules/fs-extra npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.js-controller/node_modules/node-forge npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/logform/node_modules/safe-stable-stringify npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/ncp npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/pidusage npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/safe-stable-stringify npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/seq-logging npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@iobroker/db-base npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@iobroker/db-objects-redis npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@iobroker/db-objects-file npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@iobroker/db-objects-jsonl npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@iobroker/db-states-redis npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@iobroker/db-states-file npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@iobroker/db-states-jsonl npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/yargs-parser npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.js-controller/node_modules/mime npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/yargs npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.js-controller npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@iobroker/db-base/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@iobroker/db-objects-file/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@iobroker/db-objects-jsonl/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@alcalzone npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/@types npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/express-session/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/request/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/send/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/@types npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/@iobroker npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/body-parser/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/express/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/finalhandler/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/request/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/bl/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/send/node_modules/debug/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/send/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/tar-stream/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/@googleapis npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/binding-abstract/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/binding-mock/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/bindings/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/stream/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@types npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@iobroker npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/node-ssdp/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/readable-stream/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/serialport/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/string_decoder/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/bl/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/tar-stream/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.js-controller/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/logform/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@iobroker npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/winston/node_modules npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/winston-seq-updated npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@alcalzone/jsonl-db/node_modules npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents): npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"}) npm ERR! code EACCES npm ERR! syscall access npm ERR! path /opt/iobroker/node_modules/@iobroker/db-base/node_modules/fs-extra npm ERR! errno -13 npm ERR! Error: EACCES: permission denied, access '/opt/iobroker/node_modules/@iobroker/db-base/node_modules/fs-extra' npm ERR! [Error: EACCES: permission denied, access '/opt/iobroker/node_modules/@iobroker/db-base/node_modules/fs-extra'] { npm ERR! errno: -13, npm ERR! code: 'EACCES', npm ERR! syscall: 'access', npm ERR! path: '/opt/iobroker/node_modules/@iobroker/db-base/node_modules/fs-extra' npm ERR! } npm ERR! npm ERR! The operation was rejected by your operating system. npm ERR! It is likely you do not have the permissions to access this file as the current user npm ERR! npm ERR! If you believe this might be a permissions issue, please double-check the npm ERR! permissions of the file and its containing directories, or try running npm ERR! the command again as root/Administrator. npm ERR! A complete log of this run can be found in: npm ERR! /home/mirko/.npm/_logs/2022-02-04T07_32_08_765Z-debug.log mirko@iobroker:/opt/iobroker$Kann mal noch eine VM probieren und eine mit root
@wendy2702 Auch: Versuch doch mal einen 3.3.22 controller zu installieren. Da wirst Du denke die gleiche Meldungen haben ... damit npm und generelles Rechte thema
@apollon77 kann ich vielleicht später noch versuchen. Jetzt ruft die Arbeit
@wendy2702 WTF ... alle meine Testsysteme sind Proxmox im lxc ... und eins in ner VM ... bei mir tut alles. wie sind denn die container einstellungen? Wil ja bin ehrlich beiu mir laufen die container der testsysteme unter root und nicht nem user ... das mag der unterschied sein?
Aber nochmal: Sollte nichts mit js-controller zu tun haben ... Das ist npm und irgendwelche File Rechte
@apollon77
Hier läuft iobroker im (privilegierten) lxc (debian) unter proxmox. Installation des js-controller als "normaler" Benutzer funktioniert ohne Probleme.Node.js v14.19.0
NPM v6.14.16 -
Mal noch einen anderen Versuch gewagt: Key und Cert etwas gekürzt.
mirko@iobroker:/opt/iobroker$ sudo -H -u iobroker npm i iobroker.js-controller@next > iobroker.js-controller@4.0.0-alpha.74-20220203-a06ae9e1 preinstall /opt/iobroker/node_modules/iobroker.js-controller > node lib/preinstallCheck.js NPM version: 6.14.16 > iobroker.js-controller@4.0.0-alpha.74-20220203-a06ae9e1 install /opt/iobroker/node_modules/iobroker.js-controller > node iobroker.js setup first Cannot clean up invalid user group assignments: Cannot read property 'length' of null object system.licenses created object _design/system updated The following notifications happened during sync: - Ignoring Directory "_temp" because officially not created as meta object. Please remove directory! - Ignoring Directory "terminal" because officially not created as meta object. Please remove directory! - Ignoring Directory "terminal.admin" because officially not created as meta object. Please remove directory! - Ignoring Directory "tr-064.admin" because officially not created as meta object. Please remove directory! { "defaultPrivate": "-----BEGIN RSA PRIVATE KEY-----\r\nxxxxOHqAJ6mqZ\r\n-----END RSA PRIVATE KEY-----\r\n", "defaultPublic": "-----BEGIN CERTIFICATE-----\rxxxfraHQ==\r\n-----END CERTIFICATE-----\r\n" } Update certificate defaultPrivate The object "system.certificates" was updated successfully. Update certificate defaultPublic The object "system.certificates" was updated successfully. States DB type migrated from "file" to "jsonl" Objects DB type migrated from "file" to "jsonl" ioBroker configuration updated npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents): npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"}) npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.12 (node_modules/iobroker.js2fs/node_modules/fsevents): npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.12: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"}) + iobroker.js-controller@4.0.0-alpha.74-20220203-a06ae9e1 added 37 packages from 42 contributors, removed 109 packages, updated 42 packages and moved 2 packages in 32.791s 163 packages are looking for funding run `npm fund` for details mirko@iobroker:/opt/iobroker$Startet erstmal:
2022-02-04 12:17:07.056 - info: host.iobroker iobroker.js-controller version 4.0.0 js-controller starting 2022-02-04 12:17:07.059 - info: host.iobroker Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker 2022-02-04 12:17:07.059 - info: host.iobroker hostname: iobroker, node: v14.19.0 2022-02-04 12:17:07.059 - info: host.iobroker ip addresses: 192.168.178.18 fd30:4253:5f21:46be:805a:fcff:fedc:3d66 2a01:c22:b4d1:b000:805a:fcff:fedc:3d66 fe80::805a:fcff:fedc:3d66 2022-02-04 12:17:08.206 - info: host.iobroker Sets unsupported 2022-02-04 12:17:08.206 - info: host.iobroker Sets unsupported 2022-02-04 12:17:08.708 - info: host.iobroker connected to Objects and States 2022-02-04 12:17:08.715 - info: host.iobroker added notifications configuration of host 2022-02-04 12:17:08.716 - info: host.iobroker Node.js version has changed from unknown to 14.19.0 2022-02-04 12:17:08.748 - info: host.iobroker Successfully updated capabilities "cap_net_admin, cap_net_bind_service, cap_net_raw" for /usr/bin/node 2022-02-04 12:17:09.188 - info: host.iobroker 95 instances found 2022-02-04 12:17:09.255 - info: host.iobroker starting 53 instances 2022-02-04 12:17:09.378 - info: host.iobroker instance system.adapter.admin.0 started with pid 12443 2022-02-04 12:17:10.133 - info: admin.0 (12443) Sets unsupported 2022-02-04 12:17:10.134 - info: admin.0 (12443) Sets unsupported 2022-02-04 12:17:10.453 - info: admin.0 (12443) starting. Version 5.2.3 in /opt/iobroker/node_modules/iobroker.admin, node: v14.19.0, js-controller: 4.0.0-alpha.74-20220203-a06ae9e1 2022-02-04 12:17:10.470 - info: admin.0 (12443) requesting all states 2022-02-04 12:17:10.470 - info: admin.0 (12443) requesting all objects 2022-02-04 12:17:11.958 - info: admin.0 (12443) received all objects 2022-02-04 12:17:12.246 - info: admin.0 (12443) http server listening on port 8081 2022-02-04 12:17:12.246 - info: admin.0 (12443) Use link "http://localhost:8081" to configure. 2022-02-04 12:17:13.284 - info: host.iobroker instance system.adapter.email.0 started with pid 12460 2022-02-04 12:17:13.848 - info: email.0 (12460) Sets unsupported 2022-02-04 12:17:13.849 - info: email.0 (12460) Sets unsupported 2022-02-04 12:17:14.158 - info: email.0 (12460) starting. Version 1.0.10 in /opt/iobroker/node_modules/iobroker.email, node: v14.19.0, js-controller: 4.0.0-alpha.74-20220203-a06ae9e1 2022-02-04 12:17:17.376 - info: host.iobroker instance system.adapter.history.0 started with pid 12477 2022-02-04 12:17:18.051 - info: history.0 (12477) Sets unsupported 2022-02-04 12:17:18.052 - info: history.0 (12477) Sets unsupported 2022-02-04 12:17:18.345 - info: history.0 (12477) starting. Version 1.10.5 in /opt/iobroker/node_modules/iobroker.history, node: v14.19.0, js-controller: 4.0.0-alpha.74-20220203-a06ae9e1 2022-02-04 12:17:21.425 - info: host.iobroker instance system.adapter.javascript.0 started with pid 12494 2022-02-04 12:17:22.471 - info: javascript.0 (12494) Sets unsupported 2022-02-04 12:17:22.472 - info: javascript.0 (12494) Sets unsupported 2022-02-04 12:17:22.808 - info: javascript.0 (12494) starting. Version 5.2.21 in /opt/iobroker/node_modules/iobroker.javascript, node: v14.19.0, js-controller: 4.0.0-alpha.74-20220203-a06ae9e1 2022-02-04 12:17:22.849 - info: javascript.0 (12494) npm install jsftp --production (System call) 2022-02-04 12:17:25.381 - info: host.iobroker instance system.adapter.javascript.1 started with pid 12522 2022-02-04 12:17:26.603 - info: javascript.1 (12522) Sets unsupported 2022-02-04 12:17:26.604 - info: javascript.1 (12522) Sets unsupported 2022-02-04 12:17:26.999 - info: javascript.1 (12522) starting. Version 5.2.21 in /opt/iobroker/node_modules/iobroker.javascript, node: v14.19.0, js-controller: 4.0.0-alpha.74-20220203-a06ae9e1 2022-02-04 12:17:27.030 - info: javascript.1 (12522) npm install xml2js --production (System call)
