  4. Alpha Test js-controller 4.0
196 Beiträge 20 Kommentatoren 39.7k Aufrufe 22 Beobachtet
  • apollon77A apollon77
    @maik-0 FIxed, hoffe hab alle erwischt https://github.com/ioBroker/ioBroker.docs/commit/63bcf4acc09803f1ce8fd1e03e4ba3881b3bf666
    #130
    Dieser Beitrag wurde gelöscht!
      #131
        @apollon77
        Leider haben die Änderungen in der main.js nix gebracht, soweit ich sehe:
        main.js hat jetzt drin:
        Line 4443
                                // show for debug
                                console.error(text);
                                if (
                                    text.includes('NODE_MODULE_VERSION') ||
                                    text.includes('npm rebuild') ||
                                    text.includes('Error: The module \'') ||
                                    text.includes('Cannot find module')
        Line 3016
            case 'rebuildAdapter':
                if (!msg.message.id) {
                    if (msg.callback && msg.from) {
                        sendTo(msg.from, msg.command, { error: 'Adapter to rebuild not provided.' }, msg.callback);
                } else if (!installQueue.some(entry => entry.id === msg.message.id)) {
                    logger.info(`${hostLogPrefix} ${msg.message.id} will be rebuilt ( ${msg.message.rebuildArgs})`);
                    const installObj = { id: msg.message.id, rebuild: true };
                    if (msg.message.rebuildArgs) {
                        installObj.rebuildArgs = msg.message.rebuildArgs;
        Leider kommt da immer noch das um's Eck:
        2022-02-03 20:18:45.732  - info: host.chet instance system.adapter.parcel.0 started with pid 76304
        2022-02-03 20:18:46.983  - error: host.chet Caught by controller[0]: node:internal/modules/cjs/loader:1183
        2022-02-03 20:18:46.983  - error: host.chet Caught by controller[0]:   return process.dlopen(module, path.toNamespacedPath(filename));
        2022-02-03 20:18:46.985  - error: host.chet Caught by controller[0]:                  ^
        2022-02-03 20:18:46.985  - error: host.chet Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'
        2022-02-03 20:18:46.985  - error: host.chet Caught by controller[0]: was compiled against a different Node.js version using
        2022-02-03 20:18:46.985  - error: host.chet Caught by controller[0]: NODE_MODULE_VERSION 83. This version of Node.js requires
        2022-02-03 20:18:46.986  - error: host.chet Caught by controller[0]: NODE_MODULE_VERSION 93. Please try re-compiling or re-installing
        2022-02-03 20:18:46.986  - error: host.chet Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
        2022-02-03 20:18:46.986  - error: host.chet Caught by controller[0]:     at Object.Module._extensions..node (node:internal/modules/cjs/loader:1183:18)
        2022-02-03 20:18:46.986  - error: host.chet Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:981:32)
        2022-02-03 20:18:46.986  - error: host.chet Caught by controller[0]:     at Function.Module._load (node:internal/modules/cjs/loader:822:12)
        2022-02-03 20:18:46.986  - error: host.chet Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1005:19)
        2022-02-03 20:18:46.987  - error: host.chet Caught by controller[0]:     at require (node:internal/modules/cjs/helpers:102:18)
        2022-02-03 20:18:46.987  - error: host.chet Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/canvas/lib/bindings.js:3:18)
        2022-02-03 20:18:46.987  - error: host.chet Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1101:14)
        2022-02-03 20:18:46.988  - error: host.chet Caught by controller[0]:     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1153:10)
        2022-02-03 20:18:46.988  - error: host.chet Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:981:32)
        2022-02-03 20:18:46.988  - error: host.chet Caught by controller[0]:     at Function.Module._load (node:internal/modules/cjs/loader:822:12) {
        2022-02-03 20:18:46.988  - error: host.chet Caught by controller[0]:   code: 'ERR_DLOPEN_FAILED'
        2022-02-03 20:18:46.988  - error: host.chet Caught by controller[0]: }
        2022-02-03 20:18:46.989  - error: host.chet instance system.adapter.parcel.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-02-03 20:18:46.989  - info: host.chet Adapter system.adapter.parcel.0 needs rebuild and will be restarted afterwards.
        2022-02-03 20:18:46.989  - info: host.chet system.adapter.parcel.0 will be rebuilt ( undefined)
        2022-02-03 20:18:46.990  - warn: host.chet adapter "parcel" seems to be installed for a different version of Node.js. Trying to rebuild it... 1 attempt
        2022-02-03 20:18:46.991  - info: host.chet iobroker rebuild
        2022-02-03 20:18:47.764  - info: miio.0 (76030) discover stoped after 30 seconds.
        2022-02-03 20:18:48.067  - info: host.chet iobroker npm-rebuild: Rebuilding native modules ...
        2022-02-03 20:19:30.209  - info: host.chet iobroker npm-rebuild: rebuilt dependencies successfully
        2022-02-03 20:19:30.246  - info: host.chet iobroker npm-rebuild:
        2022-02-03 20:19:30.248  - info: host.chet iobroker npm-rebuild: Rebuilding native modules done
        2022-02-03 20:19:31.259  - info: host.chet iobroker npm-rebuild: exit 0
        2022-02-03 20:19:31.356  - info: host.chet instance system.adapter.parcel.0 started with pid 76951
        2022-02-03 20:19:32.606  - error: host.chet Caught by controller[0]: node:internal/modules/cjs/loader:1183
        2022-02-03 20:19:32.606  - error: host.chet Caught by controller[0]:   return process.dlopen(module, path.toNamespacedPath(filename));
        2022-02-03 20:19:32.607  - error: host.chet Caught by controller[0]:                  ^
        2022-02-03 20:19:32.607  - error: host.chet Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'
        2022-02-03 20:19:32.607  - error: host.chet Caught by controller[0]: was compiled against a different Node.js version using
        2022-02-03 20:19:32.607  - error: host.chet Caught by controller[0]: NODE_MODULE_VERSION 83. This version of Node.js requires
        2022-02-03 20:19:32.607  - error: host.chet Caught by controller[0]: NODE_MODULE_VERSION 93. Please try re-compiling or re-installing
        2022-02-03 20:19:32.608  - error: host.chet Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
        2022-02-03 20:19:32.608  - error: host.chet Caught by controller[0]:     at Object.Module._extensions..node (node:internal/modules/cjs/loader:1183:18)
        2022-02-03 20:19:32.608  - error: host.chet Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:981:32)
        2022-02-03 20:19:32.608  - error: host.chet Caught by controller[0]:     at Function.Module._load (node:internal/modules/cjs/loader:822:12)
        2022-02-03 20:19:32.609  - error: host.chet Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1005:19)
        2022-02-03 20:19:32.609  - error: host.chet Caught by controller[0]:     at require (node:internal/modules/cjs/helpers:102:18)
        2022-02-03 20:19:32.609  - error: host.chet Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/canvas/lib/bindings.js:3:18)
        2022-02-03 20:19:32.609  - error: host.chet Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1101:14)
        2022-02-03 20:19:32.609  - error: host.chet Caught by controller[0]:     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1153:10)
        2022-02-03 20:19:32.610  - error: host.chet Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:981:32)
        2022-02-03 20:19:32.610  - error: host.chet Caught by controller[0]:     at Function.Module._load (node:internal/modules/cjs/loader:822:12) {
        2022-02-03 20:19:32.610  - error: host.chet Caught by controller[0]:   code: 'ERR_DLOPEN_FAILED'
        2022-02-03 20:19:32.610  - error: host.chet Caught by controller[0]: }
        2022-02-03 20:19:32.610  - error: host.chet instance system.adapter.parcel.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-02-03 20:19:32.611  - info: host.chet Adapter system.adapter.parcel.0 needs rebuild and will be restarted afterwards.
        2022-02-03 20:19:32.611  - info: host.chet system.adapter.parcel.0 will be rebuilt ( undefined)
        2022-02-03 20:19:32.611  - warn: host.chet adapter "parcel" seems to be installed for a different version of Node.js. Trying to rebuild it... 2 attempt
        2022-02-03 20:19:32.612  - info: host.chet iobroker rebuild
        2022-02-03 20:19:33.581  - info: host.chet iobroker npm-rebuild: Rebuilding native modules ...
        2022-02-03 20:20:15.070  - info: host.chet iobroker npm-rebuild: rebuilt dependencies successfully
        2022-02-03 20:20:15.110  - info: host.chet iobroker npm-rebuild:
        2022-02-03 20:20:15.111  - info: host.chet iobroker npm-rebuild: Rebuilding native modules done
        2022-02-03 20:20:16.125  - info: host.chet iobroker npm-rebuild: exit 0
        2022-02-03 20:20:16.265  - info: host.chet instance system.adapter.parcel.0 started with pid 77583
        2022-02-03 20:20:17.605  - error: host.chet Caught by controller[0]: node:internal/modules/cjs/loader:1183
        2022-02-03 20:20:17.606  - error: host.chet Caught by controller[0]:   return process.dlopen(module, path.toNamespacedPath(filename));
        2022-02-03 20:20:17.606  - error: host.chet Caught by controller[0]:                  ^
        2022-02-03 20:20:17.606  - error: host.chet Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'
        2022-02-03 20:20:17.606  - error: host.chet Caught by controller[0]: was compiled against a different Node.js version using
        2022-02-03 20:20:17.606  - error: host.chet Caught by controller[0]: NODE_MODULE_VERSION 83. This version of Node.js requires
        2022-02-03 20:20:17.606  - error: host.chet Caught by controller[0]: NODE_MODULE_VERSION 93. Please try re-compiling or re-installing
        2022-02-03 20:20:17.606  - error: host.chet Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
        2022-02-03 20:20:17.607  - error: host.chet Caught by controller[0]:     at Object.Module._extensions..node (node:internal/modules/cjs/loader:1183:18)
        2022-02-03 20:20:17.607  - error: host.chet Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:981:32)
        2022-02-03 20:20:17.607  - error: host.chet Caught by controller[0]:     at Function.Module._load (node:internal/modules/cjs/loader:822:12)
        2022-02-03 20:20:17.607  - error: host.chet Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1005:19)
        2022-02-03 20:20:17.607  - error: host.chet Caught by controller[0]:     at require (node:internal/modules/cjs/helpers:102:18)
        2022-02-03 20:20:17.607  - error: host.chet Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/canvas/lib/bindings.js:3:18)
        2022-02-03 20:20:17.608  - error: host.chet Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1101:14)
        2022-02-03 20:20:17.608  - error: host.chet Caught by controller[0]:     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1153:10)
        2022-02-03 20:20:17.608  - error: host.chet Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:981:32)
        2022-02-03 20:20:17.608  - error: host.chet Caught by controller[0]:     at Function.Module._load (node:internal/modules/cjs/loader:822:12) {
        2022-02-03 20:20:17.608  - error: host.chet Caught by controller[0]:   code: 'ERR_DLOPEN_FAILED'
        2022-02-03 20:20:17.609  - error: host.chet Caught by controller[0]: }
        2022-02-03 20:20:17.609  - error: host.chet instance system.adapter.parcel.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-02-03 20:20:17.609  - info: host.chet Adapter system.adapter.parcel.0 needs rebuild and will be restarted afterwards.
        2022-02-03 20:20:17.610  - info: host.chet system.adapter.parcel.0 will be rebuilt ( undefined)
        2022-02-03 20:20:17.610  - warn: host.chet adapter "parcel" seems to be installed for a different version of Node.js. Trying to rebuild it... 3 attempt
        2022-02-03 20:20:17.610  - info: host.chet iobroker rebuild
        2022-02-03 20:20:18.792  - info: host.chet iobroker npm-rebuild: Rebuilding native modules ...
        2022-02-03 20:21:00.528  - info: host.chet iobroker npm-rebuild: rebuilt dependencies successfully
        2022-02-03 20:21:00.570  - info: host.chet iobroker npm-rebuild:
        2022-02-03 20:21:00.571  - info: host.chet iobroker npm-rebuild: Rebuilding native modules done
        2022-02-03 20:21:01.582  - info: host.chet iobroker npm-rebuild: exit 0
        2022-02-03 20:21:01.677  - info: host.chet instance system.adapter.parcel.0 started with pid 78216
        2022-02-03 20:21:02.929  - error: host.chet Caught by controller[0]: node:internal/modules/cjs/loader:1183
        2022-02-03 20:21:02.929  - error: host.chet Caught by controller[0]:   return process.dlopen(module, path.toNamespacedPath(filename));
        2022-02-03 20:21:02.930  - error: host.chet Caught by controller[0]:                  ^
        2022-02-03 20:21:02.930  - error: host.chet Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'
        2022-02-03 20:21:02.930  - error: host.chet Caught by controller[0]: was compiled against a different Node.js version using
        2022-02-03 20:21:02.930  - error: host.chet Caught by controller[0]: NODE_MODULE_VERSION 83. This version of Node.js requires
        2022-02-03 20:21:02.930  - error: host.chet Caught by controller[0]: NODE_MODULE_VERSION 93. Please try re-compiling or re-installing
        2022-02-03 20:21:02.931  - error: host.chet Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
        2022-02-03 20:21:02.931  - error: host.chet Caught by controller[0]:     at Object.Module._extensions..node (node:internal/modules/cjs/loader:1183:18)
        2022-02-03 20:21:02.931  - error: host.chet Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:981:32)
        2022-02-03 20:21:02.931  - error: host.chet Caught by controller[0]:     at Function.Module._load (node:internal/modules/cjs/loader:822:12)
        2022-02-03 20:21:02.931  - error: host.chet Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1005:19)
        2022-02-03 20:21:02.932  - error: host.chet Caught by controller[0]:     at require (node:internal/modules/cjs/helpers:102:18)
        2022-02-03 20:21:02.932  - error: host.chet Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/canvas/lib/bindings.js:3:18)
        2022-02-03 20:21:02.932  - error: host.chet Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1101:14)
        2022-02-03 20:21:02.933  - error: host.chet Caught by controller[0]:     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1153:10)
        2022-02-03 20:21:02.933  - error: host.chet Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:981:32)
        2022-02-03 20:21:02.933  - error: host.chet Caught by controller[0]:     at Function.Module._load (node:internal/modules/cjs/loader:822:12) {
        2022-02-03 20:21:02.934  - error: host.chet Caught by controller[0]:   code: 'ERR_DLOPEN_FAILED'
        2022-02-03 20:21:02.934  - error: host.chet Caught by controller[0]: }
        2022-02-03 20:21:02.934  - error: host.chet instance system.adapter.parcel.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2022-02-03 20:21:02.934  - info: host.chet Rebuild for adapter system.adapter.parcel.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
        foxriver76F Offline
        foxriver76F Offline
        foxriver76
        #132
        @thomas-braun sagte in Alpha Test js-controller 4.0:
        Das meinte ich nur, aber ihr seid ja schon in Kontakt - all good ;-)
        Videotutorials & mehr
        • foxriver76F foxriver76
          #133
          @foxriver76 Jo das ist original im Code drin von uns :-))
            #134
              #135
              • apollon77A Offline
                #136
                So, dann sind wir nun mit @next bei alpha.74 :-)
                • (Apollon77) Optimize rebuild handling
                • (foxriver76) Optimize meta object sync
                  @wendy2702 Ja, hatte ich danach auch gesehen :-)) und das finde ich mega interessant weil "iob fix" an sich das alles glatt ziehen sollte. zeig mal "ls -la" von so einem der angemeckerten Verzeichnisse, vllt sieht man ja was.
                  Ansonsten (wenn keinem sonst mehr was einfällt) wäre ich bei nem krassen neustart "node_modules löschen", controller manuell installieren, starten ... dann installiert der alle adapter neu
                  wendy2702W Online
                  wendy2702W Online
                  #137
                  @apollon77 sagte in Alpha Test js-controller 4.0:
                  Guten Morgen,
                  Holzhammer probiert:
                  mirko@iobroker:/opt/iobroker$ sudo rm -r node_modules
                  [sudo] password for mirko:
                  mirko@iobroker:/opt/iobroker$ ls -la
                  total 1036
                  drwxrwxr-x+ 10 iobroker iobroker   4096 Feb  4 07:41 .
                  drwxr-xr-x   4 root     root       4096 Jan 10  2021 ..
                  -rw-rwxr--+  1 iobroker iobroker     91 Feb  3 17:11 .npmrc
                  -rw-rwxr--+  1 iobroker iobroker   1049 Mar 31  2020 CHANGELOG_FIXER_LINUX.md
                  -rw-rwxr--+  1 iobroker iobroker   3556 Mar 31  2020 CHANGELOG_INSTALLER_LINUX.md
                  -rw-rwxr--+  1 iobroker iobroker      0 Jul 11  2020 GarageKlein_Einfahrt_JPG.txt
                  -rw-rwxr--+  1 iobroker iobroker      0 Jul 11  2020 GarageKlein_JPG.txt
                  -rw-rwxr--+  1 iobroker iobroker      0 Jul 11  2020 Haustuer_JPG.txt
                  -rwxrwxrwx+  1 iobroker iobroker    359 Feb  3 17:11 INSTALLER_INFO.txt
                  -rw-rwxr--+  1 iobroker iobroker   1137 Mar 31  2020 LICENSE
                  -rw-rwxr--+  1 iobroker iobroker   6101 Mar 31  2020 README.md
                  drwxrwxrwx+  2 iobroker iobroker   4096 Feb  3 16:40 backups
                  drwxrwxr-x+  2 iobroker iobroker   4096 Jan 29 15:02 cache
                  -rw-rwxr--+  1 iobroker iobroker  23988 Mar 31  2020 fix_installation.sh
                  drwxrwxr-x+  2 iobroker iobroker  12288 Aug 22 12:56 history
                  drwxrwxr-x+  3 iobroker iobroker   4096 Mar 31  2020 install
                  lrwxrwxrwx   1 iobroker iobroker     22 Feb  3 17:11 iob -> /opt/iobroker/iobroker
                  -rwxr-xr-x+  1 iobroker iobroker    305 Feb  3 17:11 iobroker
                  drwxrwxr-x+ 14 iobroker iobroker   4096 Feb  4 07:39 iobroker-data
                  drwxrwxr-x+  2 iobroker iobroker   4096 Mar 31  2020 lib
                  drwxrwxr-x+  2 iobroker iobroker   4096 Feb  4 07:39 log
                  -rw-rwxr--+  1 iobroker iobroker 129561 Feb  4 07:26 out2.mp4
                  -rw-rwxr--+  1 iobroker iobroker 169136 Feb  4 05:47 out3.mp4
                  -rw-rwxr--+  1 iobroker iobroker 637615 Feb  3 18:10 package-lock.json
                  -rw-rwxr--+  1 iobroker iobroker   3392 Feb  3 18:10 package.json
                  -rw-rwxr--+  1 iobroker iobroker   5693 Feb  3 17:06 reinstall.js
                  drwxrwxrwx+  5 iobroker iobroker   4096 Jan 10  2021 scripte-backup
                  mirko@iobroker:/opt/iobroker$ npm i iobroker.js-controller@next
                  npm WARN tarball tarball data for iobroker.icons-open-icon-library-png@https://github.com/ioBroker/ioBroker.icons-open-icon-library-png/tarball/master (sha512-qGFFRFfv/uSaVT+z3v01bwdZYjfIES0YwaHNOgy+OO28NMa8/8fh2rkBKGHNeHfFPBTo3juTeH+p6ngZ6s//7w==) seems to be corrupted. Trying one more time.
                  npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents):
                  npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
                  npm ERR! code EINTEGRITY
                  npm ERR! Verification failed while extracting iobroker.icons-open-icon-library-png@https://github.com/ioBroker/ioBroker.icons-open-icon-library-png/tarball/master:
                  npm ERR! sha512-qGFFRFfv/uSaVT+z3v01bwdZYjfIES0YwaHNOgy+OO28NMa8/8fh2rkBKGHNeHfFPBTo3juTeH+p6ngZ6s//7w== integrity checksum failed when using sha512: wanted sha512-qGFFRFfv/uSaVT+z3v01bwdZYjfIES0YwaHNOgy+OO28NMa8/8fh2rkBKGHNeHfFPBTo3juTeH+p6ngZ6s//7w== but got sha512-ZH4lj95sM6IpZEL2H1HR0hXTo6GMqbUBPbQyylgdRd6TDEdU+fgohUVGW4gPI0UnrAzqM/kx5+mozLqCVh2DCg==. (64751136 bytes)
                  npm ERR!     /home/iobroker/.npm/_logs/2022-02-04T06_43_35_307Z-debug.log
                  Hier das npm log:
                  iob startet nicht.
                  arteckA apollon77A 2 Antworten Letzte Antwort
                  • wendy2702W wendy2702
                    Guten Morgen,
                    total 1036
                    Hier das npm log:
                    iob startet nicht.
                    arteckA Offline
                    arteckA Offline
                    arteck
                    #138
                    @wendy2702 da stimmt mit dem REPO was nicht
                    bekomme es nichtmal installiert
                    liegt nicht am 4.x
                    wendy2702W apollon77A 2 Antworten Letzte Antwort
                    • arteckA arteck
                      liegt nicht am 4.x
                      wendy2702W Online
                      wendy2702W Online
                      #139
                      @arteck sagte in Alpha Test js-controller 4.0:
                      Danke!
                      JS4.0 mag mich scheinbar nicht :-)
                      • wendy2702W Online
                        wendy2702W Online
                        #140
                        Habe gerade etwas Zeit. Neuen LXC aufgesetzt mit Debian 11. iobroker frisch installiert per einzeiler. Dann versucht JS4 zu installieren und wieder erhalte ich die "missing write access" fehler.
                        Hier das vollständige inklusive installation:
                        mirko@iobroker:~$ sudo apt update && sudo apt full-upgrade
                        Wir gehen davon aus, dass der lokale Systemadministrator Ihnen die
                        Regeln erklärt hat.  Normalerweise läuft es auf drei Regeln hinaus:
                            #1) Respektieren Sie die Privatsphäre anderer.
                            #2) Denken Sie nach, bevor Sie tippen.
                            #3) Mit großer Macht kommt große Verantwortung.
                        [sudo] Passwort für mirko:
                        OK:1 http://security.debian.org/debian-security bullseye-security InRelease
                        OK:2 http://ftp.halifax.rwth-aachen.de/debian bullseye InRelease
                        OK:3 http://ftp.halifax.rwth-aachen.de/debian bullseye-updates InRelease
                        Alle Pakete sind aktuell.
                        Paketaktualisierung (Upgrade) wird berechnet… Fertig
                        0 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
                        mirko@iobroker:~$ curl -sLf https://iobroker.net/install.sh | bash -
                        -bash: curl: Kommando nicht gefunden.
                        mirko@iobroker:~$ sudo apt install curl
                        Die folgenden zusätzlichen Pakete werden installiert:
                          libcurl4
                        Die folgenden NEUEN Pakete werden installiert:
                          curl libcurl4
                        0 aktualisiert, 2 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
                        Es müssen 608 kB an Archiven heruntergeladen werden.
                        Nach dieser Operation werden 1.186 kB Plattenplatz zusätzlich benutzt.
                        Möchten Sie fortfahren? [J/n] j
                        Holen:1 http://ftp.halifax.rwth-aachen.de/debian bullseye/main amd64 libcurl4 amd64 7.74.0-1.3+deb11u1 [341 kB]
                        Holen:2 http://ftp.halifax.rwth-aachen.de/debian bullseye/main amd64 curl amd64 7.74.0-1.3+deb11u1 [267 kB]
                        Es wurden 608 kB in 0 s geholt (3.144 kB/s).
                        Vormals nicht ausgewähltes Paket libcurl4:amd64 wird gewählt.
                        (Lese Datenbank ... 33963 Dateien und Verzeichnisse sind derzeit installiert.)
                        Vorbereitung zum Entpacken von .../libcurl4_7.74.0-1.3+deb11u1_amd64.deb ...
                        Entpacken von libcurl4:amd64 (7.74.0-1.3+deb11u1) ...
                        Vormals nicht ausgewähltes Paket curl wird gewählt.
                        Vorbereitung zum Entpacken von .../curl_7.74.0-1.3+deb11u1_amd64.deb ...
                        Entpacken von curl (7.74.0-1.3+deb11u1) ...
                        libcurl4:amd64 (7.74.0-1.3+deb11u1) wird eingerichtet ...
                        curl (7.74.0-1.3+deb11u1) wird eingerichtet ...
                        Trigger für man-db (2.9.4-2) werden verarbeitet ...
                        Trigger für libc-bin (2.31-13+deb11u2) werden verarbeitet ...
                        library: loaded
                        Library version=2021-12-27
                            Welcome to the ioBroker installer!
                            Installer version: 2021-12-27
                            You might need to enter your password a couple of times.
                            Installing prerequisites (1/4)
                        OK:1 http://ftp.halifax.rwth-aachen.de/debian bullseye InRelease
                        OK:2 http://security.debian.org/debian-security bullseye-security InRelease
                            Node.js not found. Installing...
                        ## Installing the NodeSource Node.js 14.x repo...
                        ## Populating apt-get cache...
                        + apt-get update
                        ## Installing packages required for setup: gnupg...
                        + apt-get install -y gnupg > /dev/null 2>&1
                        ## Confirming "bullseye" is supported...
                        + curl -sLf -o /dev/null 'https://deb.nodesource.com/node_14.x/dists/bullseye/Release'
                        ## Adding the NodeSource signing key to your keyring...
                        + curl -s https://deb.nodesource.com/gpgkey/nodesource.gpg.key | gpg --dearmor | tee /usr/share/keyrings/nodesource.gpg >/dev/null
                        ## Creating apt sources list file for the NodeSource Node.js 14.x repo...
                        + echo 'deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_14.x bullseye main' > /etc/apt/sources.list.d/nodesource.list
                        + echo 'deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_14.x bullseye main' >> /etc/apt/sources.list.d/nodesource.list
                        ## Running `apt-get update` for you...
                        + apt-get update
                        Holen:4 https://deb.nodesource.com/node_14.x bullseye InRelease [4.586 B]
                        Holen:5 https://deb.nodesource.com/node_14.x bullseye/main amd64 Packages [773 B]
                        Es wurden 5.359 B in 1 s geholt (4.229 B/s).
                        ## Run `sudo apt-get install -y nodejs` to install Node.js 14.x and npm
                        ## You may also need development tools to build native addons:
                             sudo apt-get install gcc g++ make
                        ## To install the Yarn package manager, run:
                             curl -sL https://dl.yarnpkg.com/debian/pubkey.gpg | gpg --dearmor | sudo tee /usr/share/keyrings/yarnkey.gpg >/dev/null
                             echo "deb [signed-by=/usr/share/keyrings/yarnkey.gpg] https://dl.yarnpkg.com/debian stable main" | sudo tee /etc/apt/sources.list.d/yarn.list
                             sudo apt-get update && sudo apt-get install yarn
                        Installed nodejs
                        Node.js Installed successfully!
                        Changing npm registry to https://registry.npmjs.org
                        Installed acl
                        Installed build-essential
                        Installed gcc-c++
                        Installed libavahi-compat-libdnssd-dev
                        Installed libudev-dev
                        Installed libpam0g-dev
                        Installed git
                        Installed unzip
                        Installed libcairo2-dev
                        Installed libpango1.0-dev
                        Installed libjpeg-dev
                        Installed libgif-dev
                        Installed librsvg2-dev
                        Installed net-tools
                        Installed python-dev
                        Installed cmake
                            Creating ioBroker user and directory (2/4)
                        User iobroker created
                        Directory /opt/iobroker created
                            Installing ioBroker (3/4)
                        In file included from ../../nan/nan.h:58,
                                         from ../src/main.cpp:3:
                        /home/mirko/.cache/node-gyp/14.19.0/include/node/node.h:793:7: warning: cast between incompatible function types from ‘void (*)(v8::Local<v8::Object>)’ to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
                          793 |       (node::addon_register_func) (regfunc),                          \
                        /home/mirko/.cache/node-gyp/14.19.0/include/node/node.h:827:3: note: in expansion of macro ‘NODE_MODULE_X’
                          827 |   NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
                        ../src/main.cpp:42:1: note: in expansion of macro ‘NODE_MODULE’
                           42 | NODE_MODULE(diskusage, Init)
                                         from ../src/unix_dgram.cc:5:
                        ../src/unix_dgram.cc:404:1: note: in expansion of macro ‘NODE_MODULE’
                          404 | NODE_MODULE(unix_dgram, Initialize)
                        ATTENTION: Error reporting via Sentry will be activated on next start of ioBroker
                        ioBroker wants to make sure to deliver the most stable smart home system.
                        To allow this we decided to implement an automatic error and crash reporting solution into the js-controller and also into adapters.
                        THIS REPORTING WILL BE ENABLED WITH THE NEXT START OF YOUR IOBROKER!
                        For any error that leads to the crash of the js-controller or one of the relevant adapters the error details are send to a server. For the js-controller and core adapters this server is located and operated in germany. For community adapters please check the Github Readme of the affected adapter for details which Sentry server is used.
                        If you want to disable the error reporting you can use the command
                        'iobroker plugin disable sentry'
                        This command will also make sure that no adapter that runs on this host will send crash reporting data to sentry.
                            Finalizing installation (4/4)
                        Enabling autostart...
                        Created symlink /etc/systemd/system/multi-user.target.wants/iobroker.service → /lib/systemd/system/iobroker.service.
                        Autostart enabled!
                            ioBroker was installed successfully
                            Open http://192.168.178.108:8081 in a browser and start configuring!
                        You need to re-login before doing anything else on the console!
                        mirko@iobroker:~$ iob -v
                        3.3.22
                        mirko@iobroker:~$ iob stop
                        mirko@iobroker:~$ iob update
                        Used repository: default
                        hash changed or no sources cached => force download of new sources
                        update done
                        Adapter    "admin"         : 5.2.3    , installed 5.2.3
                        Adapter    "backitup"      : 2.2.3    , installed 2.2.3
                        Adapter    "discovery"     : 2.7.3    , installed 2.7.3
                        Controller "js-controller" : 3.3.22   , installed 3.3.22
                        mirko@iobroker:~$ cd /opt/iobroker/
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@iobroker/db-base/node_modules/fs-extra
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@iobroker/db-objects-file/node_modules/fs-extra
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@iobroker/db-objects-jsonl/node_modules/fs-extra
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/alcalzone-shared
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@alcalzone/jsonl-db
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/@types/node
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/@types/iobroker
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/adapter-core
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/array-flatten
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/assert-plus
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/asynckit
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/aws-sign2
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/aws4
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/bytes
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/caseless
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/connect-flash
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/content-type
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/cookie
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/cookie-signature
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/cookie-parser
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/core-util-is
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/dashdash
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/delayed-stream
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/combined-stream
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/depd
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/destroy
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/ee-first
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/encodeurl
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/escape-html
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/etag
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/express-session/node_modules/depd
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/extend
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/extsprintf
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/fast-deep-equal
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/fast-json-stable-stringify
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/forever-agent
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/forwarded
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/fresh
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/getpass
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/har-schema
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/inherits
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/ipaddr.js
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/is-typedarray
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/isstream
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/jsbn
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/json-schema
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/json-schema-traverse
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/json-stringify-safe
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/media-typer
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/merge-descriptors
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/methods
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/mime
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/mime-db
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/mime-types
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/form-data
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/ms
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/debug
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/negotiator
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/accepts
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/oauth-sign
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/on-finished
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/on-headers
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/parseurl
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/passport-strategy
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/passport-local
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/path-to-regexp
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/pause
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/performance-now
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/proxy-addr
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/psl
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/punycode
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/qs
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/random-bytes
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/range-parser
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/request/node_modules/qs
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/safe-buffer
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/content-disposition
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/safer-buffer
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/asn1
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/ecc-jsbn
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/iconv-lite
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/send/node_modules/ms
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/setprototypeof
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/statuses
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/streamsearch
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/dicer
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/busboy
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/express-fileupload
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/toidentifier
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/http-errors
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/serve-static
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/tough-cookie
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/tunnel-agent
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/tweetnacl
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/bcrypt-pbkdf
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/sshpk
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/type-is
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/uid-safe
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/unpipe
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/finalhandler
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/raw-body
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/body-parser
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/uri-js
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/har-validator
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/utils-merge
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/ajv
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/uuid
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/vary
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/verror
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/http-signature
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/jsprim
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/ws
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/xtend
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/passport.socketio
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/yallist
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/lru-cache
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/semver
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/@types/node
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/@types/iobroker
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/@iobroker/adapter-core
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/agent-base
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/array-flatten
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/arrify
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/assert-plus
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/asynckit
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/aws-sign2
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/aws4
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/balanced-match
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/base-64
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/base64-js
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/bignumber.js
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/body-parser/node_modules/ms
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/body-parser/node_modules/debug
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/body-parser/node_modules/qs
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/buffer-equal-constant-time
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/bytes
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/caseless
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/charenc
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/chownr
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/concat-map
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/brace-expansion
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/content-type
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/cookie
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/cookie-signature
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/core-util-is
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/crypt
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/dashdash
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/delayed-stream
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/combined-stream
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/depd
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/destroy
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/ee-first
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/encodeurl
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/escape-html
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/etag
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/event-target-shim
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/abort-controller
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/express/node_modules/ms
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/express/node_modules/debug
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/express/node_modules/qs
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/extend
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/extsprintf
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/fast-deep-equal
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/fast-json-stable-stringify
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/fast-text-encoding
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/finalhandler/node_modules/ms
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/finalhandler/node_modules/debug
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/follow-redirects
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/axios
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/forever-agent
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/forwarded
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/fresh
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/fs-constants
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/function-bind
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/getpass
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/graceful-fs
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/har-schema
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/has
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/has-symbols
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/get-intrinsic
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/call-bind
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/he
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/hot-patcher
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/https-proxy-agent
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/ieee754
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/inherits
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/ipaddr.js
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/is-buffer
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/is-stream
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/is-typedarray
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/isarray
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/isstream
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/jsbn
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/json-bigint
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/json-schema
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/json-schema-traverse
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/json-stringify-safe
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/layerr
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/long-timeout
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/luxon
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/md5
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/media-typer
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/merge-descriptors
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/methods
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/mime
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/mime-db
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/mime-types
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/form-data
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/minimatch
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/mkdirp-classic
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/negotiator
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/accepts
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/nested-property
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/node-forge
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/google-p12-pem
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/node-wol
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/oauth-sign
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/object-inspect
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/object-keys
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/define-properties
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/is-nan
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/cron-parser
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/on-finished
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/parseurl
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/path-posix
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/path-to-regexp
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/performance-now
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/proxy-addr
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/psl
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/punycode
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/querystringify
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/range-parser
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/request/node_modules/qs
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/request/node_modules/uuid
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/requires-port
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/safe-buffer
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/bl/node_modules/string_decoder
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/content-disposition
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/ecdsa-sig-formatter
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/jwa
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/jws
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/safer-buffer
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/asn1
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/ecc-jsbn
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/iconv-lite
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/send/node_modules/debug/node_modules/ms
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/send/node_modules/ms
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/setprototypeof
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/side-channel
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/qs
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/sorted-array-functions
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/node-schedule
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/statuses
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/string_decoder
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/readable-stream
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/strnum
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/fast-xml-parser
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/tar-stream/node_modules/string_decoder
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/toidentifier
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/http-errors
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/serve-static
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/tough-cookie
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/tr46
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/tunnel-agent
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/tweetnacl
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/bcrypt-pbkdf
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/sshpk
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/type-is
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/universalify
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/jsonfile
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/fs-extra
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/unpipe
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/raw-body
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/uri-js
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/ajv
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/har-validator
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/url-join
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/url-parse
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/url-template
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/util-deprecate
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/bl/node_modules/readable-stream
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/tar-stream/node_modules/readable-stream
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/utils-merge
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/uuid
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/vary
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/verror
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/jsprim
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/http-signature
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/dropbox-v2-api
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/webdav
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/webidl-conversions
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/whatwg-url
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/node-fetch
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/gaxios
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/gcp-metadata
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/gtoken
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/wrappy
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/once
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/end-of-stream
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/pump
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/tar-fs
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/xregexp
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/ftp
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/yallist
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/lru-cache
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/google-auth-library
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/googleapis-common
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/@googleapis/drive
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/binding-abstract/node_modules/ms
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/binding-abstract/node_modules/debug
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/binding-mock/node_modules/ms
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/binding-mock/node_modules/debug
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/bindings/node_modules/ms
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/bindings/node_modules/debug
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/parser-byte-length
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/parser-cctalk
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/parser-delimiter
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/parser-inter-byte-timeout
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/parser-readline
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/parser-ready
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/parser-regex
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/stream/node_modules/ms
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/stream/node_modules/debug
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@types/node
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@types/iobroker
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@iobroker/adapter-core
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/ansi-regex
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/aproba
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/base64-js
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/bluebird
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/chownr
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/code-point-at
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/console-control-strings
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/core-util-is
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/deep-extend
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/delegates
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/detect-libc
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/dgram
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/expand-template
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/extend
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/file-uri-to-path
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/bindings
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/fs-constants
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/github-from-package
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/has-unicode
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/ieee754
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/buffer
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/inherits
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/ini
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/ip
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/isarray
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/lodash
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/async
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/mimic-response
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/decompress-response
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/minimist
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/mkdirp-classic
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/ms
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/debug
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/nan
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/napi-build-utils
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/netmask
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/node-mndp
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/node-ssdp/node_modules/ms
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/node-ssdp/node_modules/debug
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/number-is-nan
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/is-fullwidth-code-point
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/object-assign
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/process-nextick-args
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/readable-stream/node_modules/safe-buffer
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/safe-buffer
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/dns-packet
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/mdns-discovery
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/serialport/node_modules/ms
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/serialport/node_modules/debug
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/set-blocking
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/signal-exit
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/simple-concat
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/string_decoder/node_modules/safe-buffer
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/strip-ansi
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/string-width
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/strip-json-comments
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/rc
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/tunnel-agent
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/util-deprecate
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/bl/node_modules/readable-stream
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/are-we-there-yet
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/tar-stream/node_modules/readable-stream
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/wide-align
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/gauge
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/npmlog
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/wrappy
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/once
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/end-of-stream
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/pump
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/tar-fs
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/simple-get
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/yallist
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/lru-cache
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/semver
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/node-abi
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/prebuild-install
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.js-controller/node_modules/fs-extra
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.js-controller/node_modules/node-forge
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/logform/node_modules/safe-stable-stringify
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/ncp
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/pidusage
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/safe-stable-stringify
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/seq-logging
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@iobroker/db-objects-redis
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@iobroker/db-states-redis
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@iobroker/db-states-file
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@iobroker/db-states-jsonl
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/yargs-parser
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.js-controller/node_modules/mime
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/winston/node_modules
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/winston-seq-updated
                        npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@alcalzone/jsonl-db/node_modules
                        npm ERR! code EACCES
                        npm ERR! syscall access
                        npm ERR! path /opt/iobroker/node_modules/@iobroker/db-base/node_modules/fs-extra
                        npm ERR! errno -13
                        npm ERR! Error: EACCES: permission denied, access '/opt/iobroker/node_modules/@iobroker/db-base/node_modules/fs-extra'
                        npm ERR!  [Error: EACCES: permission denied, access '/opt/iobroker/node_modules/@iobroker/db-base/node_modules/fs-extra'] {
                        npm ERR!   errno: -13,
                        npm ERR!   code: 'EACCES',
                        npm ERR!   syscall: 'access',
                        npm ERR!   path: '/opt/iobroker/node_modules/@iobroker/db-base/node_modules/fs-extra'
                        npm ERR! }
                        npm ERR!
                        npm ERR! The operation was rejected by your operating system.
                        npm ERR! It is likely you do not have the permissions to access this file as the current user
                        npm ERR!
                        npm ERR! If you believe this might be a permissions issue, please double-check the
                        npm ERR! permissions of the file and its containing directories, or try running
                        npm ERR! the command again as root/Administrator.
                        npm ERR!     /home/mirko/.npm/_logs/2022-02-04T07_26_29_636Z-debug.log
                        mirko@iobroker:/opt/iobroker$
                          @apollon77 sagte in Alpha Test js-controller 4.0:
                          Ansonsten (wenn keinem sonst mehr was einfällt) wäre ich bei nem krassen neustart "node_modules löschen", controller manuell installieren, starten ... dann installiert der alle adapter neu
                          Guten Morgen,
                          Holzhammer probiert:
                          mirko@iobroker:/opt/iobroker$ sudo rm -r node_modules
                          [sudo] password for mirko:
                          mirko@iobroker:/opt/iobroker$ ls -la
                          total 1036
                          drwxrwxr-x+ 10 iobroker iobroker   4096 Feb  4 07:41 .
                          drwxr-xr-x   4 root     root       4096 Jan 10  2021 ..
                          -rw-rwxr--+  1 iobroker iobroker     91 Feb  3 17:11 .npmrc
                          -rw-rwxr--+  1 iobroker iobroker   1049 Mar 31  2020 CHANGELOG_FIXER_LINUX.md
                          -rw-rwxr--+  1 iobroker iobroker   3556 Mar 31  2020 CHANGELOG_INSTALLER_LINUX.md
                          -rw-rwxr--+  1 iobroker iobroker      0 Jul 11  2020 GarageKlein_Einfahrt_JPG.txt
                          -rw-rwxr--+  1 iobroker iobroker      0 Jul 11  2020 GarageKlein_JPG.txt
                          -rw-rwxr--+  1 iobroker iobroker      0 Jul 11  2020 Haustuer_JPG.txt
                          -rwxrwxrwx+  1 iobroker iobroker    359 Feb  3 17:11 INSTALLER_INFO.txt
                          -rw-rwxr--+  1 iobroker iobroker   1137 Mar 31  2020 LICENSE
                          -rw-rwxr--+  1 iobroker iobroker   6101 Mar 31  2020 README.md
                          drwxrwxrwx+  2 iobroker iobroker   4096 Feb  3 16:40 backups
                          drwxrwxr-x+  2 iobroker iobroker   4096 Jan 29 15:02 cache
                          -rw-rwxr--+  1 iobroker iobroker  23988 Mar 31  2020 fix_installation.sh
                          drwxrwxr-x+  2 iobroker iobroker  12288 Aug 22 12:56 history
                          drwxrwxr-x+  3 iobroker iobroker   4096 Mar 31  2020 install
                          lrwxrwxrwx   1 iobroker iobroker     22 Feb  3 17:11 iob -> /opt/iobroker/iobroker
                          -rwxr-xr-x+  1 iobroker iobroker    305 Feb  3 17:11 iobroker
                          drwxrwxr-x+ 14 iobroker iobroker   4096 Feb  4 07:39 iobroker-data
                          drwxrwxr-x+  2 iobroker iobroker   4096 Mar 31  2020 lib
                          drwxrwxr-x+  2 iobroker iobroker   4096 Feb  4 07:39 log
                          -rw-rwxr--+  1 iobroker iobroker 129561 Feb  4 07:26 out2.mp4
                          -rw-rwxr--+  1 iobroker iobroker 169136 Feb  4 05:47 out3.mp4
                          -rw-rwxr--+  1 iobroker iobroker 637615 Feb  3 18:10 package-lock.json
                          -rw-rwxr--+  1 iobroker iobroker   3392 Feb  3 18:10 package.json
                          -rw-rwxr--+  1 iobroker iobroker   5693 Feb  3 17:06 reinstall.js
                          drwxrwxrwx+  5 iobroker iobroker   4096 Jan 10  2021 scripte-backup
                          mirko@iobroker:/opt/iobroker$ npm i iobroker.js-controller@next
                          npm WARN tarball tarball data for iobroker.icons-open-icon-library-png@https://github.com/ioBroker/ioBroker.icons-open-icon-library-png/tarball/master (sha512-qGFFRFfv/uSaVT+z3v01bwdZYjfIES0YwaHNOgy+OO28NMa8/8fh2rkBKGHNeHfFPBTo3juTeH+p6ngZ6s//7w==) seems to be corrupted. Trying one more time.
                          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents):
                          npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
                          npm ERR! code EINTEGRITY
                          npm ERR! Verification failed while extracting iobroker.icons-open-icon-library-png@https://github.com/ioBroker/ioBroker.icons-open-icon-library-png/tarball/master:
                          npm ERR! sha512-qGFFRFfv/uSaVT+z3v01bwdZYjfIES0YwaHNOgy+OO28NMa8/8fh2rkBKGHNeHfFPBTo3juTeH+p6ngZ6s//7w== integrity checksum failed when using sha512: wanted sha512-qGFFRFfv/uSaVT+z3v01bwdZYjfIES0YwaHNOgy+OO28NMa8/8fh2rkBKGHNeHfFPBTo3juTeH+p6ngZ6s//7w== but got sha512-ZH4lj95sM6IpZEL2H1HR0hXTo6GMqbUBPbQyylgdRd6TDEdU+fgohUVGW4gPI0UnrAzqM/kx5+mozLqCVh2DCg==. (64751136 bytes)
                          npm ERR!     /home/iobroker/.npm/_logs/2022-02-04T06_43_35_307Z-debug.log
                          Hier das npm log:
                          iob startet nicht.
                          #141
                          @wendy2702 Mal den npm cache unter user iobroker löschen?
                          • wendy2702W wendy2702
                            Habe gerade etwas Zeit. Neuen LXC aufgesetzt mit Debian 11. iobroker frisch installiert per einzeiler. Dann versucht JS4 zu installieren und wieder erhalte ich die "missing write access" fehler.
                            Hier das vollständige inklusive installation:
                            mirko@iobroker:~$ sudo apt update && sudo apt full-upgrade
                            Wir gehen davon aus, dass der lokale Systemadministrator Ihnen die
                            Regeln erklärt hat.  Normalerweise läuft es auf drei Regeln hinaus:
                                #1) Respektieren Sie die Privatsphäre anderer.
                                #2) Denken Sie nach, bevor Sie tippen.
                                #3) Mit großer Macht kommt große Verantwortung.
                            [sudo] Passwort für mirko:
                            OK:1 http://security.debian.org/debian-security bullseye-security InRelease
                            OK:2 http://ftp.halifax.rwth-aachen.de/debian bullseye InRelease
                            OK:3 http://ftp.halifax.rwth-aachen.de/debian bullseye-updates InRelease
                            Alle Pakete sind aktuell.
                            Paketaktualisierung (Upgrade) wird berechnet… Fertig
                            0 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
                            mirko@iobroker:~$ curl -sLf https://iobroker.net/install.sh | bash -
                            -bash: curl: Kommando nicht gefunden.
                            mirko@iobroker:~$ sudo apt install curl
                            Die folgenden zusätzlichen Pakete werden installiert:
                              libcurl4
                            Die folgenden NEUEN Pakete werden installiert:
                              curl libcurl4
                            0 aktualisiert, 2 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
                            Es müssen 608 kB an Archiven heruntergeladen werden.
                            Nach dieser Operation werden 1.186 kB Plattenplatz zusätzlich benutzt.
                            Möchten Sie fortfahren? [J/n] j
                            Holen:1 http://ftp.halifax.rwth-aachen.de/debian bullseye/main amd64 libcurl4 amd64 7.74.0-1.3+deb11u1 [341 kB]
                            Holen:2 http://ftp.halifax.rwth-aachen.de/debian bullseye/main amd64 curl amd64 7.74.0-1.3+deb11u1 [267 kB]
                            Es wurden 608 kB in 0 s geholt (3.144 kB/s).
                            Vormals nicht ausgewähltes Paket libcurl4:amd64 wird gewählt.
                            (Lese Datenbank ... 33963 Dateien und Verzeichnisse sind derzeit installiert.)
                            Vorbereitung zum Entpacken von .../libcurl4_7.74.0-1.3+deb11u1_amd64.deb ...
                            Entpacken von libcurl4:amd64 (7.74.0-1.3+deb11u1) ...
                            Vormals nicht ausgewähltes Paket curl wird gewählt.
                            Vorbereitung zum Entpacken von .../curl_7.74.0-1.3+deb11u1_amd64.deb ...
                            Entpacken von curl (7.74.0-1.3+deb11u1) ...
                            libcurl4:amd64 (7.74.0-1.3+deb11u1) wird eingerichtet ...
                            curl (7.74.0-1.3+deb11u1) wird eingerichtet ...
                            Trigger für man-db (2.9.4-2) werden verarbeitet ...
                            Trigger für libc-bin (2.31-13+deb11u2) werden verarbeitet ...
                            library: loaded
                            Library version=2021-12-27
                                Welcome to the ioBroker installer!
                                Installer version: 2021-12-27
                                You might need to enter your password a couple of times.
                                Installing prerequisites (1/4)
                            OK:1 http://ftp.halifax.rwth-aachen.de/debian bullseye InRelease
                            OK:2 http://security.debian.org/debian-security bullseye-security InRelease
                                Node.js not found. Installing...
                            ## Installing the NodeSource Node.js 14.x repo...
                            ## Populating apt-get cache...
                            + apt-get update
                            ## Installing packages required for setup: gnupg...
                            + apt-get install -y gnupg > /dev/null 2>&1
                            ## Confirming "bullseye" is supported...
                            + curl -sLf -o /dev/null 'https://deb.nodesource.com/node_14.x/dists/bullseye/Release'
                            ## Adding the NodeSource signing key to your keyring...
                            + curl -s https://deb.nodesource.com/gpgkey/nodesource.gpg.key | gpg --dearmor | tee /usr/share/keyrings/nodesource.gpg >/dev/null
                            ## Creating apt sources list file for the NodeSource Node.js 14.x repo...
                            + echo 'deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_14.x bullseye main' > /etc/apt/sources.list.d/nodesource.list
                            + echo 'deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_14.x bullseye main' >> /etc/apt/sources.list.d/nodesource.list
                            ## Running `apt-get update` for you...
                            + apt-get update
                            Holen:4 https://deb.nodesource.com/node_14.x bullseye InRelease [4.586 B]
                            Holen:5 https://deb.nodesource.com/node_14.x bullseye/main amd64 Packages [773 B]
                            Es wurden 5.359 B in 1 s geholt (4.229 B/s).
                            ## Run `sudo apt-get install -y nodejs` to install Node.js 14.x and npm
                            ## You may also need development tools to build native addons:
                                 sudo apt-get install gcc g++ make
                            ## To install the Yarn package manager, run:
                                 curl -sL https://dl.yarnpkg.com/debian/pubkey.gpg | gpg --dearmor | sudo tee /usr/share/keyrings/yarnkey.gpg >/dev/null
                                 echo "deb [signed-by=/usr/share/keyrings/yarnkey.gpg] https://dl.yarnpkg.com/debian stable main" | sudo tee /etc/apt/sources.list.d/yarn.list
                                 sudo apt-get update && sudo apt-get install yarn
                            Installed nodejs
                            Node.js Installed successfully!
                            Changing npm registry to https://registry.npmjs.org
                            Installed acl
                            Installed build-essential
                            Installed gcc-c++
                            Installed libavahi-compat-libdnssd-dev
                            Installed libudev-dev
                            Installed libpam0g-dev
                            Installed git
                            Installed unzip
                            Installed libcairo2-dev
                            Installed libpango1.0-dev
                            Installed libjpeg-dev
                            Installed libgif-dev
                            Installed librsvg2-dev
                            Installed net-tools
                            Installed python-dev
                            Installed cmake
                                Creating ioBroker user and directory (2/4)
                            User iobroker created
                            Directory /opt/iobroker created
                                Installing ioBroker (3/4)
                            In file included from ../../nan/nan.h:58,
                                             from ../src/main.cpp:3:
                            /home/mirko/.cache/node-gyp/14.19.0/include/node/node.h:793:7: warning: cast between incompatible function types from ‘void (*)(v8::Local<v8::Object>)’ to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
                              793 |       (node::addon_register_func) (regfunc),                          \
                            /home/mirko/.cache/node-gyp/14.19.0/include/node/node.h:827:3: note: in expansion of macro ‘NODE_MODULE_X’
                              827 |   NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
                            ../src/main.cpp:42:1: note: in expansion of macro ‘NODE_MODULE’
                               42 | NODE_MODULE(diskusage, Init)
                                             from ../src/unix_dgram.cc:5:
                            ../src/unix_dgram.cc:404:1: note: in expansion of macro ‘NODE_MODULE’
                              404 | NODE_MODULE(unix_dgram, Initialize)
                            ATTENTION: Error reporting via Sentry will be activated on next start of ioBroker
                            ioBroker wants to make sure to deliver the most stable smart home system.
                            To allow this we decided to implement an automatic error and crash reporting solution into the js-controller and also into adapters.
                            THIS REPORTING WILL BE ENABLED WITH THE NEXT START OF YOUR IOBROKER!
                            For any error that leads to the crash of the js-controller or one of the relevant adapters the error details are send to a server. For the js-controller and core adapters this server is located and operated in germany. For community adapters please check the Github Readme of the affected adapter for details which Sentry server is used.
                            If you want to disable the error reporting you can use the command
                            'iobroker plugin disable sentry'
                            This command will also make sure that no adapter that runs on this host will send crash reporting data to sentry.
                                Finalizing installation (4/4)
                            Enabling autostart...
                            Created symlink /etc/systemd/system/multi-user.target.wants/iobroker.service → /lib/systemd/system/iobroker.service.
                            Autostart enabled!
                                ioBroker was installed successfully
                                Open http://192.168.178.108:8081 in a browser and start configuring!
                            You need to re-login before doing anything else on the console!
                            mirko@iobroker:~$ iob -v
                            3.3.22
                            mirko@iobroker:~$ iob stop
                            mirko@iobroker:~$ iob update
                            Used repository: default
                            hash changed or no sources cached => force download of new sources
                            update done
                            Adapter    "admin"         : 5.2.3    , installed 5.2.3
                            Adapter    "backitup"      : 2.2.3    , installed 2.2.3
                            Adapter    "discovery"     : 2.7.3    , installed 2.7.3
                            Controller "js-controller" : 3.3.22   , installed 3.3.22
                            mirko@iobroker:~$ cd /opt/iobroker/
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@iobroker/db-base/node_modules/fs-extra
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@iobroker/db-objects-file/node_modules/fs-extra
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@iobroker/db-objects-jsonl/node_modules/fs-extra
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/alcalzone-shared
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/@types/node
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/@types/iobroker
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/adapter-core
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/array-flatten
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/assert-plus
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/asynckit
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/aws-sign2
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/aws4
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/bytes
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/caseless
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/connect-flash
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/content-type
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/cookie
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/cookie-signature
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/cookie-parser
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/core-util-is
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/dashdash
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/delayed-stream
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/combined-stream
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/depd
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/destroy
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/ee-first
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/encodeurl
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/escape-html
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/etag
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/express-session/node_modules/depd
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/extend
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/extsprintf
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/fast-deep-equal
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/fast-json-stable-stringify
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/forever-agent
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/forwarded
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/fresh
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/getpass
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/har-schema
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/inherits
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/ipaddr.js
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/is-typedarray
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/isstream
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/jsbn
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/json-schema
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/json-schema-traverse
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/json-stringify-safe
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/media-typer
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/merge-descriptors
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/methods
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/mime
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/mime-db
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/mime-types
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/form-data
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/ms
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/debug
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/negotiator
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/accepts
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/oauth-sign
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/on-finished
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/on-headers
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/parseurl
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/passport-strategy
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/passport-local
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/path-to-regexp
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/pause
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/performance-now
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/proxy-addr
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/psl
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/punycode
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/qs
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/random-bytes
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/range-parser
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/request/node_modules/qs
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/safe-buffer
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/content-disposition
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/safer-buffer
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/asn1
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/ecc-jsbn
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/iconv-lite
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/send/node_modules/ms
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/setprototypeof
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/statuses
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/streamsearch
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/dicer
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/busboy
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/express-fileupload
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/toidentifier
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/http-errors
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/serve-static
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/tough-cookie
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/tunnel-agent
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/tweetnacl
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/bcrypt-pbkdf
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/sshpk
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/type-is
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/uid-safe
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/unpipe
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/finalhandler
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/raw-body
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/body-parser
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/uri-js
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/har-validator
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/utils-merge
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/ajv
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/uuid
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/vary
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/verror
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/http-signature
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/jsprim
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/ws
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/xtend
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/passport.socketio
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/yallist
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/lru-cache
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.admin/node_modules/semver
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/@types/node
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/@types/iobroker
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/@iobroker/adapter-core
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/agent-base
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/array-flatten
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/arrify
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/assert-plus
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/asynckit
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/aws-sign2
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/aws4
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/balanced-match
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/base-64
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/base64-js
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/bignumber.js
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/body-parser/node_modules/ms
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/body-parser/node_modules/debug
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/body-parser/node_modules/qs
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/buffer-equal-constant-time
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/bytes
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/caseless
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/charenc
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/chownr
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/concat-map
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/brace-expansion
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/content-type
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/cookie
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/cookie-signature
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/core-util-is
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/crypt
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/dashdash
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/delayed-stream
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/combined-stream
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/depd
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/destroy
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/ee-first
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/encodeurl
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/escape-html
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/etag
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/event-target-shim
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/abort-controller
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/express/node_modules/ms
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/express/node_modules/debug
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/express/node_modules/qs
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/extend
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/extsprintf
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/fast-deep-equal
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/fast-json-stable-stringify
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/fast-text-encoding
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/finalhandler/node_modules/ms
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/finalhandler/node_modules/debug
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/follow-redirects
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/axios
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/forever-agent
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/forwarded
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/fresh
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/fs-constants
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/function-bind
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/getpass
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/graceful-fs
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/har-schema
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/has
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/has-symbols
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/get-intrinsic
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/call-bind
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/he
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/hot-patcher
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/https-proxy-agent
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/ieee754
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/inherits
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/ipaddr.js
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/is-buffer
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/is-stream
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/is-typedarray
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/isarray
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/isstream
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/jsbn
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/json-bigint
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/json-schema
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/json-schema-traverse
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/json-stringify-safe
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/layerr
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/long-timeout
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/luxon
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/md5
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/media-typer
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/merge-descriptors
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/methods
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/mime
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/mime-db
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/mime-types
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/form-data
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/minimatch
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/mkdirp-classic
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/negotiator
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/accepts
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/nested-property
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/node-forge
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/google-p12-pem
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/node-wol
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/oauth-sign
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/object-inspect
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/object-keys
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/define-properties
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/is-nan
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/cron-parser
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/on-finished
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/parseurl
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/path-posix
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/path-to-regexp
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/performance-now
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/proxy-addr
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/psl
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/punycode
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/querystringify
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/range-parser
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/request/node_modules/qs
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/request/node_modules/uuid
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/requires-port
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/safe-buffer
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/bl/node_modules/string_decoder
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/content-disposition
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/ecdsa-sig-formatter
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/jwa
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/jws
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/safer-buffer
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/asn1
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/ecc-jsbn
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/iconv-lite
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/send/node_modules/debug/node_modules/ms
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/send/node_modules/ms
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/setprototypeof
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/side-channel
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/qs
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/sorted-array-functions
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/node-schedule
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/statuses
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/string_decoder
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/readable-stream
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/strnum
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/fast-xml-parser
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/tar-stream/node_modules/string_decoder
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/toidentifier
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/http-errors
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/serve-static
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/tough-cookie
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/tr46
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/tunnel-agent
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/tweetnacl
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/bcrypt-pbkdf
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/sshpk
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/type-is
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/universalify
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/jsonfile
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/fs-extra
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/unpipe
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/raw-body
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/uri-js
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/ajv
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/har-validator
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/url-join
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/url-parse
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/url-template
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/util-deprecate
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/bl/node_modules/readable-stream
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/tar-stream/node_modules/readable-stream
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/utils-merge
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/uuid
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/vary
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/verror
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/jsprim
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/http-signature
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/dropbox-v2-api
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/webdav
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/webidl-conversions
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/whatwg-url
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/node-fetch
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/gaxios
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/gcp-metadata
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/gtoken
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/wrappy
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/once
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/end-of-stream
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/pump
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/tar-fs
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/xregexp
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/ftp
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/yallist
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/lru-cache
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/google-auth-library
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/googleapis-common
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.backitup/node_modules/@googleapis/drive
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/binding-abstract/node_modules/ms
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/binding-abstract/node_modules/debug
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/binding-mock/node_modules/ms
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/binding-mock/node_modules/debug
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/bindings/node_modules/ms
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/bindings/node_modules/debug
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/parser-byte-length
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/parser-cctalk
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/parser-delimiter
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/parser-inter-byte-timeout
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/parser-readline
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/parser-ready
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/parser-regex
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/stream/node_modules/ms
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@serialport/stream/node_modules/debug
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@types/node
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@types/iobroker
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/@iobroker/adapter-core
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/ansi-regex
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/aproba
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/base64-js
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/bluebird
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/chownr
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/code-point-at
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/console-control-strings
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/core-util-is
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/deep-extend
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/delegates
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/detect-libc
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/dgram
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/expand-template
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/extend
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/file-uri-to-path
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/bindings
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/fs-constants
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/github-from-package
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/has-unicode
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/ieee754
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/buffer
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/inherits
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/ini
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/ip
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/isarray
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/lodash
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/async
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/mimic-response
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/decompress-response
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/minimist
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/mkdirp-classic
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/ms
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/debug
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/nan
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/napi-build-utils
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/netmask
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/node-mndp
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/node-ssdp/node_modules/ms
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/node-ssdp/node_modules/debug
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/number-is-nan
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/is-fullwidth-code-point
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/object-assign
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/process-nextick-args
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/readable-stream/node_modules/safe-buffer
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/safe-buffer
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/dns-packet
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/mdns-discovery
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/serialport/node_modules/ms
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/serialport/node_modules/debug
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/set-blocking
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/signal-exit
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/simple-concat
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/string_decoder/node_modules/safe-buffer
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/strip-ansi
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/string-width
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/strip-json-comments
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/rc
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/tunnel-agent
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/util-deprecate
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/bl/node_modules/readable-stream
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/are-we-there-yet
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/tar-stream/node_modules/readable-stream
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/wide-align
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/gauge
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/npmlog
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/wrappy
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/once
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/end-of-stream
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/pump
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/tar-fs
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/simple-get
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/yallist
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/lru-cache
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/semver
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/node-abi
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.discovery/node_modules/prebuild-install
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.js-controller/node_modules/fs-extra
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.js-controller/node_modules/node-forge
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/logform/node_modules/safe-stable-stringify
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/ncp
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/pidusage
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/safe-stable-stringify
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/seq-logging
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@iobroker/db-objects-redis
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@iobroker/db-states-redis
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@iobroker/db-states-file
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@iobroker/db-states-jsonl
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/yargs-parser
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.js-controller/node_modules/mime
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@alcalzone
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/winston/node_modules
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/winston-seq-updated
                            npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/@alcalzone/jsonl-db/node_modules
                            npm ERR! code EACCES
                            npm ERR! syscall access
                            npm ERR! path /opt/iobroker/node_modules/@iobroker/db-base/node_modules/fs-extra
                            npm ERR! errno -13
                            npm ERR! Error: EACCES: permission denied, access '/opt/iobroker/node_modules/@iobroker/db-base/node_modules/fs-extra'
                            npm ERR!  [Error: EACCES: permission denied, access '/opt/iobroker/node_modules/@iobroker/db-base/node_modules/fs-extra'] {
                            npm ERR!   errno: -13,
                            npm ERR!   code: 'EACCES',
                            npm ERR!   syscall: 'access',
                            npm ERR!   path: '/opt/iobroker/node_modules/@iobroker/db-base/node_modules/fs-extra'
                            npm ERR! }
                            npm ERR!
                            npm ERR! The operation was rejected by your operating system.
                            npm ERR! It is likely you do not have the permissions to access this file as the current user
                            npm ERR!
                            npm ERR! If you believe this might be a permissions issue, please double-check the
                            npm ERR! permissions of the file and its containing directories, or try running
                            npm ERR! the command again as root/Administrator.
                            npm ERR!     /home/mirko/.npm/_logs/2022-02-04T07_26_29_636Z-debug.log
                            mirko@iobroker:/opt/iobroker$
                            #142
                            @wendy2702 WTF ... alle meine Testsysteme sind Proxmox im lxc ... und eins in ner VM ... bei mir tut alles. wie sind denn die container einstellungen? Wil ja bin ehrlich beiu mir laufen die container der testsysteme unter root und nicht nem user ... das mag der unterschied sein?
                            Aber nochmal: Sollte nichts mit js-controller zu tun haben ... Das ist npm und irgendwelche File Rechte
                            L 1 Antwort Letzte Antwort
                            • arteckA arteck
                              @wendy2702 da stimmt mit dem REPO was nicht
                              https://github.com/ioBroker/ioBroker.icons-open-icon-library-png
                              bekomme es nichtmal installiert
                              liegt nicht am 4.x
                              #143
                              @arteck Und was stimmt nicht?
                              • apollon77A apollon77
                                wendy2702W Online
                                wendy2702W Online
                                #144
                                @apollon77 sagte in Alpha Test js-controller 4.0:
                                Bei einer neu installation ?
                                Kann ich aber gerne noch versuchen.
                                Habe auf dem neuen System mal noch
                                iob fix
                                laufen lassen. Danach immer noch write access fehler
                                mirko@iobroker:/opt/iobroker$ iob fix
                                library: loaded
                                    Welcome to the ioBroker installation fixer!
                                    Script version: 2021-12-27
                                    Installing prerequisites (1/3)
                                OK:4 https://deb.nodesource.com/node_14.x bullseye InRelease
                                Installed gcc-c++
                                    Checking ioBroker user and directory permissions (2/3)
                                    Checking autostart (3/3)
                                Autostart enabled!
                                    Your installation was fixed successfully
                                    Run iobroker start to start ioBroker again!
                                mirko@iobroker:/opt/iobroker$ iob start
                                mirko@iobroker:/opt/iobroker$ tail -f /opt/iobroker/log/iobroker
                                iobroker.2022-02-04.log  iobroker-audit.json      iobroker.current.log
                                mirko@iobroker:/opt/iobroker$ tail -f /opt/iobroker/log/iobroker.current.log
                                2022-02-04 08:30:27.060  - info: admin.0 (11589) requesting all states
                                2022-02-04 08:30:27.060  - info: admin.0 (11589) requesting all objects
                                2022-02-04 08:30:27.185  - info: admin.0 (11589) received all objects
                                2022-02-04 08:30:27.297  - info: admin.0 (11589) http server listening on port 8081
                                2022-02-04 08:30:27.298  - info: admin.0 (11589) Use link "http://localhost:8081" to configure.
                                2022-02-04 08:30:30.017  - info: host.iobroker instance system.adapter.discovery.0 started with pid 11604
                                2022-02-04 08:30:30.634  - info: discovery.0 (11604) starting. Version 2.7.3 in /opt/iobroker/node_modules/iobroker.discovery, node: v14.19.0, js-controller: 3.3.22
                                2022-02-04 08:30:34.011  - info: host.iobroker instance system.adapter.backitup.0 started with pid 11627
                                2022-02-04 08:30:34.715  - info: backitup.0 (11627) starting. Version 2.2.3 in /opt/iobroker/node_modules/iobroker.backitup, node: v14.19.0, js-controller: 3.3.22
                                2022-02-04 08:30:34.783  - info: backitup.0 (11627) [iobroker] backup was activated at 02:40 every 1 day(s)
                                ^C
                                mirko@iobroker:/opt/iobroker$ iob stop
                                mirko@iobroker:/opt/iobroker$ ps auxww|grep io
                                root          13  0.0  0.0      0     0 ?        S    08:18   0:00 [migration/0]
                                root          17  0.0  0.0      0     0 ?        S    08:18   0:00 [migration/1]
                                root          22  0.0  0.0      0     0 ?        S    08:18   0:00 [migration/2]
                                root          27  0.0  0.0      0     0 ?        S    08:18   0:00 [migration/3]
                                root          65  0.0  0.0      0     0 ?        I<   08:18   0:00 [blkcg_punt_bio]
                                message+     305  0.0  0.0   8208  4540 ?        Ss   08:18   0:00 /usr/bin/dbus-daemon --system --address=systemd: --nofork --nopidfile --systemd-activation --syslog-only
                                root       11487  0.0  0.0      0     0 ?        I    08:29   0:00 [kworker/u8:1-ext4-rsv-conversion]
                                mirko      11666  0.0  0.0   6200   712 pts/0    R+   08:31   0:00 grep io
                                mirko@iobroker:/opt/iobroker$ ps auxww|grep backup
                                mirko      11668  0.0  0.0   6200   652 pts/0    R+   08:31   0:00 grep backup
                                mirko@iobroker:/opt/iobroker$ npm i iobroker.js-controller@next
                                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents):
                                npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
                                npm ERR! errno -13
                                npm ERR! }
                                npm ERR!
                                npm ERR!
                                npm ERR!     /home/mirko/.npm/_logs/2022-02-04T07_32_08_765Z-debug.log
                                Kann mal noch eine VM probieren und eine mit root
                                • wendy2702W wendy2702
                                  @wendy2702 Mal den npm cache unter user iobroker löschen?
                                  iob fix
                                  library: loaded
                                  Library version=2021-12-27
                                      You might need to enter your password a couple of times.
                                  OK:1 http://security.debian.org/debian-security bullseye-security InRelease
                                  OK:2 http://ftp.halifax.rwth-aachen.de/debian bullseye InRelease
                                  OK:3 http://ftp.halifax.rwth-aachen.de/debian bullseye-updates InRelease
                                  Installed gcc-c++
                                  Autostart enabled!
                                  ^C
                                  npm ERR! errno -13
                                  npm ERR! }
                                  npm ERR!
                                  npm ERR!
                                  #145
                                  @wendy2702 Auch: Versuch doch mal einen 3.3.22 controller zu installieren. Da wirst Du denke die gleiche Meldungen haben ... damit npm und generelles Rechte thema
                                    wendy2702W Online
                                    wendy2702W Online
                                    #146
                                    @apollon77 kann ich vielleicht später noch versuchen. Jetzt ruft die Arbeit
                                      lonsimbt
                                      #147
                                      @apollon77
                                      Hier läuft iobroker im (privilegierten) lxc (debian) unter proxmox. Installation des js-controller als "normaler" Benutzer funktioniert ohne Probleme.
                                      Node.js v14.19.0
                                      NPM v6.14.16
                                      iobroker im Container (debian Bullseye) unter proxmox 7.1
                                      debmatic in VM (debian Buster) unter proxmox 7.1 mit HB-RF-USB und RPI-RF-MOD
                                      40 HomeMatic Geräte, Phillips Hue, Ikea Tradfri, Logitech Harmony Hub, Botvac Connected, Robonect
                                      • wendy2702W Online
                                        wendy2702W Online
                                        #148
                                        @apollon77
                                        Mal noch einen anderen Versuch gewagt: Key und Cert etwas gekürzt.
                                        mirko@iobroker:/opt/iobroker$ sudo -H -u iobroker npm i iobroker.js-controller@next
                                        > iobroker.js-controller@4.0.0-alpha.74-20220203-a06ae9e1 preinstall /opt/iobroker/node_modules/iobroker.js-controller
                                        > node lib/preinstallCheck.js
                                        NPM version: 6.14.16
                                        > iobroker.js-controller@4.0.0-alpha.74-20220203-a06ae9e1 install /opt/iobroker/node_modules/iobroker.js-controller
                                        > node iobroker.js setup first
                                        Cannot clean up invalid user group assignments: Cannot read property 'length' of null
                                        object system.licenses created
                                        object _design/system updated
                                        The following notifications happened during sync:
                                        - Ignoring Directory "_temp" because officially not created as meta object. Please remove directory!
                                        - Ignoring Directory "terminal" because officially not created as meta object. Please remove directory!
                                        - Ignoring Directory "terminal.admin" because officially not created as meta object. Please remove directory!
                                        - Ignoring Directory "tr-064.admin" because officially not created as meta object. Please remove directory!
                                          "defaultPrivate": "-----BEGIN RSA PRIVATE KEY-----\r\nxxxxOHqAJ6mqZ\r\n-----END RSA PRIVATE KEY-----\r\n",
                                          "defaultPublic": "-----BEGIN CERTIFICATE-----\rxxxfraHQ==\r\n-----END CERTIFICATE-----\r\n"
                                        Update certificate defaultPrivate
                                        The object "system.certificates" was updated successfully.
                                        Update certificate defaultPublic
                                        States DB type migrated from "file" to "jsonl"
                                        Objects DB type migrated from "file" to "jsonl"
                                        ioBroker configuration updated
                                        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.12 (node_modules/iobroker.js2fs/node_modules/fsevents):
                                        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.12: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
                                        + iobroker.js-controller@4.0.0-alpha.74-20220203-a06ae9e1
                                        added 37 packages from 42 contributors, removed 109 packages, updated 42 packages and moved 2 packages in 32.791s
                                        163 packages are looking for funding
                                          run `npm fund` for details
                                        Startet erstmal:
                                        2022-02-04 12:17:07.056  - info: host.iobroker iobroker.js-controller version 4.0.0 js-controller starting
                                        2022-02-04 12:17:07.059  - info: host.iobroker Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                                        2022-02-04 12:17:07.059  - info: host.iobroker hostname: iobroker, node: v14.19.0
                                        2022-02-04 12:17:07.059  - info: host.iobroker ip addresses: 192.168.178.18 fd30:4253:5f21:46be:805a:fcff:fedc:3d66 2a01:c22:b4d1:b000:805a:fcff:fedc:3d66 fe80::805a:fcff:fedc:3d66
                                        2022-02-04 12:17:08.206  - info: host.iobroker Sets unsupported
                                        2022-02-04 12:17:08.708  - info: host.iobroker connected to Objects and States
                                        2022-02-04 12:17:08.715  - info: host.iobroker added notifications configuration of host
                                        2022-02-04 12:17:08.716  - info: host.iobroker Node.js version has changed from unknown to 14.19.0
                                        2022-02-04 12:17:08.748  - info: host.iobroker Successfully updated capabilities "cap_net_admin, cap_net_bind_service, cap_net_raw" for /usr/bin/node
                                        2022-02-04 12:17:09.188  - info: host.iobroker 95 instances found
                                        2022-02-04 12:17:09.255  - info: host.iobroker starting 53 instances
                                        2022-02-04 12:17:09.378  - info: host.iobroker instance system.adapter.admin.0 started with pid 12443
                                        2022-02-04 12:17:10.133  - info: admin.0 (12443) Sets unsupported
                                        2022-02-04 12:17:10.134  - info: admin.0 (12443) Sets unsupported
                                        2022-02-04 12:17:10.453  - info: admin.0 (12443) starting. Version 5.2.3 in /opt/iobroker/node_modules/iobroker.admin, node: v14.19.0, js-controller: 4.0.0-alpha.74-20220203-a06ae9e1
                                        2022-02-04 12:17:10.470  - info: admin.0 (12443) requesting all states
                                        2022-02-04 12:17:10.470  - info: admin.0 (12443) requesting all objects
                                        2022-02-04 12:17:11.958  - info: admin.0 (12443) received all objects
                                        2022-02-04 12:17:12.246  - info: admin.0 (12443) http server listening on port 8081
                                        2022-02-04 12:17:12.246  - info: admin.0 (12443) Use link "http://localhost:8081" to configure.
                                        2022-02-04 12:17:13.284  - info: host.iobroker instance system.adapter.email.0 started with pid 12460
                                        2022-02-04 12:17:13.848  - info: email.0 (12460) Sets unsupported
                                        2022-02-04 12:17:13.849  - info: email.0 (12460) Sets unsupported
                                        2022-02-04 12:17:14.158  - info: email.0 (12460) starting. Version 1.0.10 in /opt/iobroker/node_modules/iobroker.email, node: v14.19.0, js-controller: 4.0.0-alpha.74-20220203-a06ae9e1
                                        2022-02-04 12:17:17.376  - info: host.iobroker instance system.adapter.history.0 started with pid 12477
                                        2022-02-04 12:17:18.051  - info: history.0 (12477) Sets unsupported
                                        2022-02-04 12:17:18.052  - info: history.0 (12477) Sets unsupported
                                        2022-02-04 12:17:18.345  - info: history.0 (12477) starting. Version 1.10.5 in /opt/iobroker/node_modules/iobroker.history, node: v14.19.0, js-controller: 4.0.0-alpha.74-20220203-a06ae9e1
                                        2022-02-04 12:17:21.425  - info: host.iobroker instance system.adapter.javascript.0 started with pid 12494
                                        2022-02-04 12:17:22.471  - info: javascript.0 (12494) Sets unsupported
                                        2022-02-04 12:17:22.472  - info: javascript.0 (12494) Sets unsupported
                                        2022-02-04 12:17:22.808  - info: javascript.0 (12494) starting. Version 5.2.21 in /opt/iobroker/node_modules/iobroker.javascript, node: v14.19.0, js-controller: 4.0.0-alpha.74-20220203-a06ae9e1
                                        2022-02-04 12:17:22.849  - info: javascript.0 (12494) npm install jsftp --production (System call)
                                        2022-02-04 12:17:25.381  - info: host.iobroker instance system.adapter.javascript.1 started with pid 12522
                                        2022-02-04 12:17:26.603  - info: javascript.1 (12522) Sets unsupported
                                        2022-02-04 12:17:26.604  - info: javascript.1 (12522) Sets unsupported
                                        2022-02-04 12:17:26.999  - info: javascript.1 (12522) starting. Version 5.2.21 in /opt/iobroker/node_modules/iobroker.javascript, node: v14.19.0, js-controller: 4.0.0-alpha.74-20220203-a06ae9e1
                                        2022-02-04 12:17:27.030  - info: javascript.1 (12522) npm install xml2js --production (System call)
                                        apollon77A foxriver76F 2 Antworten Letzte Antwort
                                          @apollon77
                                          Startet erstmal:
                                          #149
                                          @wendy2702 Das siht auch alles perfekt aus. Was war der Unterschied? Das obige sudo-Kommando was es unter dem iobroker user ausführt?
