  4. Alpha Test js-controller 4.0
196 Beiträge 20 Kommentatoren 46.2k Aufrufe 22 Beobachtet
  • apollon77A apollon77
    @thomas-braun sagte in Alpha Test js-controller 4.0:
    Nur der iobroker.parcel-Adapter muss bei jedem update des controllers neugebaut werden.
    Das wäre aber interessant warum das so ist. Was bringt der als Fehler? Läuft der renbuild machenaismus an?
    Thomas BraunT
    Thomas BraunT
    Most Active Developer
    #107
    @apollon77 sagte in Alpha Test js-controller 4.0:
    Hier das Log dazu:
    2022-02-03 15:24:15.366  - info: host.chet instance system.adapter.parcel.0 started with pid 66699
    2022-02-03 15:24:15.411  - info: miio.0 (66537) discover stoped after 30 seconds.
    2022-02-03 15:24:16.645  - error: host.chet Caught by controller[0]: node:internal/modules/cjs/loader:1183
    2022-02-03 15:24:16.645  - error: host.chet Caught by controller[0]:   return process.dlopen(module, path.toNamespacedPath(filename));
    2022-02-03 15:24:16.646  - error: host.chet Caught by controller[0]:                  ^
    2022-02-03 15:24:16.646  - error: host.chet Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'
    2022-02-03 15:24:16.646  - error: host.chet Caught by controller[0]: was compiled against a different Node.js version using
    2022-02-03 15:24:16.646  - error: host.chet Caught by controller[0]: NODE_MODULE_VERSION 83. This version of Node.js requires
    2022-02-03 15:24:16.646  - error: host.chet Caught by controller[0]: NODE_MODULE_VERSION 93. Please try re-compiling or re-installing
    2022-02-03 15:24:16.647  - error: host.chet Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
    2022-02-03 15:24:16.647  - error: host.chet Caught by controller[0]:     at Object.Module._extensions..node (node:internal/modules/cjs/loader:1183:18)
    2022-02-03 15:24:16.647  - error: host.chet Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:981:32)
    2022-02-03 15:24:16.647  - error: host.chet Caught by controller[0]:     at Function.Module._load (node:internal/modules/cjs/loader:822:12)
    2022-02-03 15:24:16.647  - error: host.chet Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1005:19)
    2022-02-03 15:24:16.648  - error: host.chet Caught by controller[0]:     at require (node:internal/modules/cjs/helpers:102:18)
    2022-02-03 15:24:16.649  - error: host.chet Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/canvas/lib/bindings.js:3:18)
    2022-02-03 15:24:16.649  - error: host.chet Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1101:14)
    2022-02-03 15:24:16.649  - error: host.chet Caught by controller[0]:     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1153:10)
    2022-02-03 15:24:16.649  - error: host.chet Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:981:32)
    2022-02-03 15:24:16.649  - error: host.chet Caught by controller[0]:     at Function.Module._load (node:internal/modules/cjs/loader:822:12) {
    2022-02-03 15:24:16.650  - error: host.chet Caught by controller[0]:   code: 'ERR_DLOPEN_FAILED'
    2022-02-03 15:24:16.650  - error: host.chet Caught by controller[0]: }
    2022-02-03 15:24:16.650  - error: host.chet instance system.adapter.parcel.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2022-02-03 15:24:16.651  - info: host.chet Adapter system.adapter.parcel.0 needs rebuild and will be restarted afterwards.
    2022-02-03 15:24:16.655  - info: host.chet system.adapter.parcel.0 will be rebuilt
    2022-02-03 15:24:16.656  - warn: host.chet adapter "parcel" seems to be installed for a different version of Node.js. Trying to rebuild it... 1 attempt
    2022-02-03 15:24:16.656  - info: host.chet iobroker rebuild
    2022-02-03 15:24:17.635  - info: host.chet iobroker npm-rebuild: Rebuilding native modules ...
    2022-02-03 15:25:05.335  - info: host.chet iobroker npm-rebuild: rebuilt dependencies successfully
    2022-02-03 15:25:05.370  - info: host.chet iobroker npm-rebuild:
    2022-02-03 15:25:05.371  - info: host.chet iobroker npm-rebuild: Rebuilding native modules done
    2022-02-03 15:25:06.387  - info: host.chet iobroker npm-rebuild: exit 0
    2022-02-03 15:25:06.542  - info: host.chet instance system.adapter.parcel.0 started with pid 67346
    2022-02-03 15:25:07.862  - error: host.chet Caught by controller[0]: node:internal/modules/cjs/loader:1183
    2022-02-03 15:25:07.863  - error: host.chet Caught by controller[0]:   return process.dlopen(module, path.toNamespacedPath(filename));
    2022-02-03 15:25:07.864  - error: host.chet Caught by controller[0]:                  ^
    2022-02-03 15:25:07.864  - error: host.chet Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'
    2022-02-03 15:25:07.864  - error: host.chet Caught by controller[0]: was compiled against a different Node.js version using
    2022-02-03 15:25:07.864  - error: host.chet Caught by controller[0]: NODE_MODULE_VERSION 83. This version of Node.js requires
    2022-02-03 15:25:07.865  - error: host.chet Caught by controller[0]: NODE_MODULE_VERSION 93. Please try re-compiling or re-installing
    2022-02-03 15:25:07.865  - error: host.chet Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
    2022-02-03 15:25:07.865  - error: host.chet Caught by controller[0]:     at Object.Module._extensions..node (node:internal/modules/cjs/loader:1183:18)
    2022-02-03 15:25:07.865  - error: host.chet Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:981:32)
    2022-02-03 15:25:07.865  - error: host.chet Caught by controller[0]:     at Function.Module._load (node:internal/modules/cjs/loader:822:12)
    2022-02-03 15:25:07.866  - error: host.chet Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1005:19)
    2022-02-03 15:25:07.866  - error: host.chet Caught by controller[0]:     at require (node:internal/modules/cjs/helpers:102:18)
    2022-02-03 15:25:07.866  - error: host.chet Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/canvas/lib/bindings.js:3:18)
    2022-02-03 15:25:07.866  - error: host.chet Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1101:14)
    2022-02-03 15:25:07.866  - error: host.chet Caught by controller[0]:     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1153:10)
    2022-02-03 15:25:07.873  - error: host.chet Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:981:32)
    2022-02-03 15:25:07.874  - error: host.chet Caught by controller[0]:     at Function.Module._load (node:internal/modules/cjs/loader:822:12) {
    2022-02-03 15:25:07.874  - error: host.chet Caught by controller[0]:   code: 'ERR_DLOPEN_FAILED'
    2022-02-03 15:25:07.874  - error: host.chet Caught by controller[0]: }
    2022-02-03 15:25:07.874  - error: host.chet instance system.adapter.parcel.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2022-02-03 15:25:07.875  - info: host.chet Adapter system.adapter.parcel.0 needs rebuild and will be restarted afterwards.
    2022-02-03 15:25:07.878  - info: host.chet system.adapter.parcel.0 will be rebuilt
    2022-02-03 15:25:07.878  - warn: host.chet adapter "parcel" seems to be installed for a different version of Node.js. Trying to rebuild it... 2 attempt
    2022-02-03 15:25:07.879  - info: host.chet iobroker rebuild
    2022-02-03 15:25:08.977  - info: host.chet iobroker npm-rebuild: Rebuilding native modules ...
    2022-02-03 15:25:50.623  - info: host.chet iobroker npm-rebuild: rebuilt dependencies successfully
    2022-02-03 15:25:50.666  - info: host.chet iobroker npm-rebuild:
    2022-02-03 15:25:50.667  - info: host.chet iobroker npm-rebuild: Rebuilding native modules done
    2022-02-03 15:25:51.687  - info: host.chet iobroker npm-rebuild: exit 0
    2022-02-03 15:25:51.839  - info: host.chet instance system.adapter.parcel.0 started with pid 67981
    2022-02-03 15:25:53.048  - error: host.chet Caught by controller[0]: node:internal/modules/cjs/loader:1183
    2022-02-03 15:25:53.049  - error: host.chet Caught by controller[0]:   return process.dlopen(module, path.toNamespacedPath(filename));
    2022-02-03 15:25:53.049  - error: host.chet Caught by controller[0]:                  ^
    2022-02-03 15:25:53.049  - error: host.chet Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'
    2022-02-03 15:25:53.050  - error: host.chet Caught by controller[0]: was compiled against a different Node.js version using
    2022-02-03 15:25:53.050  - error: host.chet Caught by controller[0]: NODE_MODULE_VERSION 83. This version of Node.js requires
    2022-02-03 15:25:53.051  - error: host.chet Caught by controller[0]: NODE_MODULE_VERSION 93. Please try re-compiling or re-installing
    2022-02-03 15:25:53.051  - error: host.chet Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
    2022-02-03 15:25:53.051  - error: host.chet Caught by controller[0]:     at Object.Module._extensions..node (node:internal/modules/cjs/loader:1183:18)
    2022-02-03 15:25:53.051  - error: host.chet Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:981:32)
    2022-02-03 15:25:53.052  - error: host.chet Caught by controller[0]:     at Function.Module._load (node:internal/modules/cjs/loader:822:12)
    2022-02-03 15:25:53.052  - error: host.chet Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1005:19)
    2022-02-03 15:25:53.052  - error: host.chet Caught by controller[0]:     at require (node:internal/modules/cjs/helpers:102:18)
    2022-02-03 15:25:53.052  - error: host.chet Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/canvas/lib/bindings.js:3:18)
    2022-02-03 15:25:53.052  - error: host.chet Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1101:14)
    2022-02-03 15:25:53.052  - error: host.chet Caught by controller[0]:     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1153:10)
    2022-02-03 15:25:53.053  - error: host.chet Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:981:32)
    2022-02-03 15:25:53.053  - error: host.chet Caught by controller[0]:     at Function.Module._load (node:internal/modules/cjs/loader:822:12) {
    2022-02-03 15:25:53.053  - error: host.chet Caught by controller[0]:   code: 'ERR_DLOPEN_FAILED'
    2022-02-03 15:25:53.053  - error: host.chet Caught by controller[0]: }
    2022-02-03 15:25:53.054  - error: host.chet instance system.adapter.parcel.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2022-02-03 15:25:53.054  - info: host.chet Adapter system.adapter.parcel.0 needs rebuild and will be restarted afterwards.
    2022-02-03 15:25:53.054  - info: host.chet system.adapter.parcel.0 will be rebuilt
    2022-02-03 15:25:53.055  - warn: host.chet adapter "parcel" seems to be installed for a different version of Node.js. Trying to rebuild it... 3 attempt
    2022-02-03 15:25:53.055  - info: host.chet iobroker rebuild
    2022-02-03 15:25:54.004  - info: host.chet iobroker npm-rebuild: Rebuilding native modules ...
    2022-02-03 15:26:35.390  - info: host.chet iobroker npm-rebuild: rebuilt dependencies successfully
    2022-02-03 15:26:35.433  - info: host.chet iobroker npm-rebuild:
    2022-02-03 15:26:35.434  - info: host.chet iobroker npm-rebuild: Rebuilding native modules done
    2022-02-03 15:26:36.447  - info: host.chet iobroker npm-rebuild: exit 0
    2022-02-03 15:26:36.588  - info: host.chet instance system.adapter.parcel.0 started with pid 68611
    2022-02-03 15:26:37.838  - error: host.chet Caught by controller[0]: node:internal/modules/cjs/loader:1183
    2022-02-03 15:26:37.839  - error: host.chet Caught by controller[0]:   return process.dlopen(module, path.toNamespacedPath(filename));
    2022-02-03 15:26:37.839  - error: host.chet Caught by controller[0]:                  ^
    2022-02-03 15:26:37.839  - error: host.chet Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'
    2022-02-03 15:26:37.840  - error: host.chet Caught by controller[0]: was compiled against a different Node.js version using
    2022-02-03 15:26:37.841  - error: host.chet Caught by controller[0]: NODE_MODULE_VERSION 83. This version of Node.js requires
    2022-02-03 15:26:37.842  - error: host.chet Caught by controller[0]: NODE_MODULE_VERSION 93. Please try re-compiling or re-installing
    2022-02-03 15:26:37.842  - error: host.chet Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
    2022-02-03 15:26:37.842  - error: host.chet Caught by controller[0]:     at Object.Module._extensions..node (node:internal/modules/cjs/loader:1183:18)
    2022-02-03 15:26:37.843  - error: host.chet Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:981:32)
    2022-02-03 15:26:37.843  - error: host.chet Caught by controller[0]:     at Function.Module._load (node:internal/modules/cjs/loader:822:12)
    2022-02-03 15:26:37.843  - error: host.chet Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1005:19)
    2022-02-03 15:26:37.843  - error: host.chet Caught by controller[0]:     at require (node:internal/modules/cjs/helpers:102:18)
    2022-02-03 15:26:37.843  - error: host.chet Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/canvas/lib/bindings.js:3:18)
    2022-02-03 15:26:37.844  - error: host.chet Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1101:14)
    2022-02-03 15:26:37.845  - error: host.chet Caught by controller[0]:     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1153:10)
    2022-02-03 15:26:37.845  - error: host.chet Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:981:32)
    2022-02-03 15:26:37.845  - error: host.chet Caught by controller[0]:     at Function.Module._load (node:internal/modules/cjs/loader:822:12) {
    2022-02-03 15:26:37.845  - error: host.chet Caught by controller[0]:   code: 'ERR_DLOPEN_FAILED'
    2022-02-03 15:26:37.845  - error: host.chet Caught by controller[0]: }
    2022-02-03 15:26:37.846  - error: host.chet instance system.adapter.parcel.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2022-02-03 15:26:37.846  - info: host.chet Rebuild for adapter system.adapter.parcel.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
    habe ich dann gemacht, danach ging der iobroker.parcel.0 auch. Hat aber eher mit canvas zu tun, wenn ich das richtig sehe.
    • wendy2702W wendy2702
      getfacl
      Das hier z.B.:
      mirko@iobroker:/opt/iobroker$ getfacl /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/node
      getfacl: Removing leading '/' from absolute path names
      # file: opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/node
      # owner: iobroker
      # group: iobroker
      user::rwx
      group::r-x
      group:iobroker:rwx
      mask::rwx
      other::r-x
      default:user::rwx
      default:group::r-x
      default:group:iobroker:rwx
      default:mask::rwx
      default:other::r-x
      Sehe da auf Anhieb nichts verdächtiges.... bin aber mit einem Auge noch in einem Online Training
      apollon77A
      apollon77A
      #108
      @wendy2702 sagte in Alpha Test js-controller 4.0:
      mine
        mine
        wendy2702W
        wendy2702W
        #109
        @apollon77 Arrrgghhhhh.... Ein Screenshot :-)
        Sieht aber aus wie bei mir.
        Thomas BraunT apollon77A 2 Antworten Letzte Antwort
          Thomas BraunT
          Thomas BraunT
          #110
          @wendy2702
          mount | sort
          Ich frag mich noch was das für ein komisches mount da bei dir immer ist.
          Aber Container... :-(
            apollon77A
            apollon77A
            #111
            @wendy2702 grad schneller ... sorry
              @wendy2702
              mount | sort
              wendy2702W
              wendy2702W
              #112
              mirko@iobroker:/opt/iobroker$ mount | sort
              /dev/mapper/pve-vm--101--disk--0 on / type ext4 (rw,relatime,stripe=16)
              cgroup on /sys/fs/cgroup/blkio type cgroup (rw,nosuid,nodev,noexec,relatime,blkio)
              cgroup on /sys/fs/cgroup/cpu,cpuacct type cgroup (rw,nosuid,nodev,noexec,relatime,cpu,cpuacct)
              cgroup on /sys/fs/cgroup/cpuset type cgroup (rw,nosuid,nodev,noexec,relatime,cpuset)
              cgroup on /sys/fs/cgroup/devices type cgroup (rw,nosuid,nodev,noexec,relatime,devices)
              cgroup on /sys/fs/cgroup/freezer type cgroup (rw,nosuid,nodev,noexec,relatime,freezer)
              cgroup on /sys/fs/cgroup/hugetlb type cgroup (rw,nosuid,nodev,noexec,relatime,hugetlb)
              cgroup on /sys/fs/cgroup/memory type cgroup (rw,nosuid,nodev,noexec,relatime,memory)
              cgroup on /sys/fs/cgroup/net_cls,net_prio type cgroup (rw,nosuid,nodev,noexec,relatime,net_cls,net_prio)
              cgroup on /sys/fs/cgroup/perf_event type cgroup (rw,nosuid,nodev,noexec,relatime,perf_event)
              cgroup on /sys/fs/cgroup/pids type cgroup (rw,nosuid,nodev,noexec,relatime,pids)
              cgroup on /sys/fs/cgroup/rdma type cgroup (rw,nosuid,nodev,noexec,relatime,rdma)
              cgroup on /sys/fs/cgroup/systemd type cgroup (rw,nosuid,nodev,noexec,relatime,xattr,name=systemd)
              cgroup2 on /sys/fs/cgroup/unified type cgroup2 (rw,nosuid,nodev,noexec,relatime)
              devpts on /dev/console type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000)
              devpts on /dev/ptmx type devpts (rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1024)
              devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1024)
              devpts on /dev/tty1 type devpts (rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1024)
              devpts on /dev/tty2 type devpts (rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1024)
              fusectl on /sys/fs/fuse/connections type fusectl (rw,relatime)
              lxcfs on /proc/cpuinfo type fuse.lxcfs (rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other)
              lxcfs on /proc/diskstats type fuse.lxcfs (rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other)
              lxcfs on /proc/loadavg type fuse.lxcfs (rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other)
              lxcfs on /proc/meminfo type fuse.lxcfs (rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other)
              lxcfs on /proc/stat type fuse.lxcfs (rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other)
              lxcfs on /proc/swaps type fuse.lxcfs (rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other)
              lxcfs on /proc/uptime type fuse.lxcfs (rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other)
              lxcfs on /sys/devices/system/cpu/online type fuse.lxcfs (rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other)
              mqueue on /dev/mqueue type mqueue (rw,relatime)
              none on /dev type tmpfs (rw,relatime,size=492k,mode=755,uid=100000,gid=100000)
              none on /proc/sys/kernel/random/boot_id type tmpfs (ro,nosuid,nodev,noexec,relatime,size=492k,mode=755,uid=100000,gid=100000)
              proc on /proc type proc (rw,nosuid,nodev,noexec,relatime)
              proc on /proc/sys type proc (ro,nosuid,nodev,noexec,relatime)
              proc on /proc/sys/net type proc (rw,nosuid,nodev,noexec,relatime)
              proc on /proc/sysrq-trigger type proc (ro,nosuid,nodev,noexec,relatime)
              sysfs on /sys type sysfs (ro,nosuid,nodev,noexec,relatime)
              sysfs on /sys type sysfs (rw,nosuid,nodev,noexec,relatime)
              sysfs on /sys/devices/virtual/net type sysfs (rw,nosuid,nodev,noexec,relatime)
              sysfs on /sys/devices/virtual/net type sysfs (rw,relatime)
              tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev,uid=100000,gid=100000)
              tmpfs on /run type tmpfs (rw,nosuid,nodev,mode=755,uid=100000,gid=100000)
              tmpfs on /run/lock type tmpfs (rw,nosuid,nodev,noexec,relatime,size=5120k,uid=100000,gid=100000)
              tmpfs on /run/user/0 type tmpfs (rw,nosuid,nodev,relatime,size=3275760k,mode=700,uid=100000,gid=100000)
              tmpfs on /run/user/1001 type tmpfs (rw,nosuid,nodev,relatime,size=3275760k,mode=700,uid=101001,gid=101001)
              tmpfs on /sys/fs/cgroup type tmpfs (ro,nosuid,nodev,noexec,mode=755,uid=100000,gid=100000)
              udev on /dev/full type devtmpfs (rw,nosuid,relatime,size=16354028k,nr_inodes=4088507,mode=755)
              udev on /dev/null type devtmpfs (rw,nosuid,relatime,size=16354028k,nr_inodes=4088507,mode=755)
              udev on /dev/random type devtmpfs (rw,nosuid,relatime,size=16354028k,nr_inodes=4088507,mode=755)
              udev on /dev/tty type devtmpfs (rw,nosuid,relatime,size=16354028k,nr_inodes=4088507,mode=755)
              udev on /dev/urandom type devtmpfs (rw,nosuid,relatime,size=16354028k,nr_inodes=4088507,mode=755)
              udev on /dev/zero type devtmpfs (rw,nosuid,relatime,size=16354028k,nr_inodes=4088507,mode=755)
              Allerdings, wie gesagt bis JS3.3.22 ging alles Problemlos
              Alles gut ;-)
                Alles gut ;-)
                apollon77A
                apollon77A
                #113
                Das ist es ja ... das ist "soooo low level" das kann mit dem controller nix zu tun haben
                M wendy2702W 2 Antworten Letzte Antwort
                  M
                  M
                  mrjeschke
                  #114
                  @apollon77
                  Moin,
                  Ich habe mal eine kurze Zwischenfrage.
                  Ich habe den weiter oben erwähnten Yamaha-Adapter installiert und
                  bekomme jetzt auch die genannten Warnungen. z.B.
                  2022-02-03 18:32:52.225 - warn: yamaha.0 (8368) Object yamaha.0.powerAllZones is invalid: obj.common.min has an invalid type! Expected "number", received "boolean"
                  Was ich daran nicht vestehe, ist das der Datentyp boolean ist und
                  der min-Wert ist false. Warum Expected „number“?
                    "_id": "yamaha.0.powerAllZones",
                    "type": "state",
                    "common": {
                      "name": "PowerAllZones",
                      "type": "boolean",
                      "role": "state",
                      "read": true,
                      "write": true,
                      "min": false,
                      "max": true,
                      "def": false,
                      "desc": "Power all Zones"
                    "native": {},
                    "from": "system.adapter.yamaha.0",
                    "ts": 1643912423847,
                    "acl": {
                      "object": 1636,
                      "state": 1636,
                      "owner": "system.user.admin",
                    "user": "system.user.admin"
                  Liegt es an mir das ich es nicht verstehe?
                  Ein ja wäre eine ausreichende Antwort.
                    Hier das Log dazu:
                    Thomas BraunT
                    Thomas BraunT
                    #115
                    @apollon77
                    Leider haben die Änderungen in der main.js nix gebracht, soweit ich sehe:
                    main.js hat jetzt drin:
                    Line 4443
                                            // show for debug
                                            console.error(text);
                                            if (
                                                text.includes('NODE_MODULE_VERSION') ||
                                                text.includes('npm rebuild') ||
                                                text.includes('Error: The module \'') ||
                                                text.includes('Cannot find module')
                    Line 3016
                        case 'rebuildAdapter':
                            if (!msg.message.id) {
                                if (msg.callback && msg.from) {
                                    sendTo(msg.from, msg.command, { error: 'Adapter to rebuild not provided.' }, msg.callback);
                            } else if (!installQueue.some(entry => entry.id === msg.message.id)) {
                                logger.info(`${hostLogPrefix} ${msg.message.id} will be rebuilt ( ${msg.message.rebuildArgs})`);
                                const installObj = { id: msg.message.id, rebuild: true };
                                if (msg.message.rebuildArgs) {
                                    installObj.rebuildArgs = msg.message.rebuildArgs;
                    Leider kommt da immer noch das um's Eck:
                    2022-02-03 20:18:45.732  - info: host.chet instance system.adapter.parcel.0 started with pid 76304
                    2022-02-03 20:18:46.983  - error: host.chet Caught by controller[0]: node:internal/modules/cjs/loader:1183
                    2022-02-03 20:18:46.983  - error: host.chet Caught by controller[0]:   return process.dlopen(module, path.toNamespacedPath(filename));
                    2022-02-03 20:18:46.985  - error: host.chet Caught by controller[0]:                  ^
                    2022-02-03 20:18:46.985  - error: host.chet Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'
                    2022-02-03 20:18:46.985  - error: host.chet Caught by controller[0]: was compiled against a different Node.js version using
                    2022-02-03 20:18:46.985  - error: host.chet Caught by controller[0]: NODE_MODULE_VERSION 83. This version of Node.js requires
                    2022-02-03 20:18:46.986  - error: host.chet Caught by controller[0]: NODE_MODULE_VERSION 93. Please try re-compiling or re-installing
                    2022-02-03 20:18:46.986  - error: host.chet Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
                    2022-02-03 20:18:46.986  - error: host.chet Caught by controller[0]:     at Object.Module._extensions..node (node:internal/modules/cjs/loader:1183:18)
                    2022-02-03 20:18:46.986  - error: host.chet Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:981:32)
                    2022-02-03 20:18:46.986  - error: host.chet Caught by controller[0]:     at Function.Module._load (node:internal/modules/cjs/loader:822:12)
                    2022-02-03 20:18:46.986  - error: host.chet Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1005:19)
                    2022-02-03 20:18:46.987  - error: host.chet Caught by controller[0]:     at require (node:internal/modules/cjs/helpers:102:18)
                    2022-02-03 20:18:46.987  - error: host.chet Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/canvas/lib/bindings.js:3:18)
                    2022-02-03 20:18:46.987  - error: host.chet Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1101:14)
                    2022-02-03 20:18:46.988  - error: host.chet Caught by controller[0]:     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1153:10)
                    2022-02-03 20:18:46.988  - error: host.chet Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:981:32)
                    2022-02-03 20:18:46.988  - error: host.chet Caught by controller[0]:     at Function.Module._load (node:internal/modules/cjs/loader:822:12) {
                    2022-02-03 20:18:46.988  - error: host.chet Caught by controller[0]:   code: 'ERR_DLOPEN_FAILED'
                    2022-02-03 20:18:46.988  - error: host.chet Caught by controller[0]: }
                    2022-02-03 20:18:46.989  - error: host.chet instance system.adapter.parcel.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                    2022-02-03 20:18:46.989  - info: host.chet Adapter system.adapter.parcel.0 needs rebuild and will be restarted afterwards.
                    2022-02-03 20:18:46.989  - info: host.chet system.adapter.parcel.0 will be rebuilt ( undefined)
                    2022-02-03 20:18:46.990  - warn: host.chet adapter "parcel" seems to be installed for a different version of Node.js. Trying to rebuild it... 1 attempt
                    2022-02-03 20:18:46.991  - info: host.chet iobroker rebuild
                    2022-02-03 20:18:47.764  - info: miio.0 (76030) discover stoped after 30 seconds.
                    2022-02-03 20:18:48.067  - info: host.chet iobroker npm-rebuild: Rebuilding native modules ...
                    2022-02-03 20:19:30.209  - info: host.chet iobroker npm-rebuild: rebuilt dependencies successfully
                    2022-02-03 20:19:30.246  - info: host.chet iobroker npm-rebuild:
                    2022-02-03 20:19:30.248  - info: host.chet iobroker npm-rebuild: Rebuilding native modules done
                    2022-02-03 20:19:31.259  - info: host.chet iobroker npm-rebuild: exit 0
                    2022-02-03 20:19:31.356  - info: host.chet instance system.adapter.parcel.0 started with pid 76951
                    2022-02-03 20:19:32.606  - error: host.chet Caught by controller[0]: node:internal/modules/cjs/loader:1183
                    2022-02-03 20:19:32.606  - error: host.chet Caught by controller[0]:   return process.dlopen(module, path.toNamespacedPath(filename));
                    2022-02-03 20:19:32.607  - error: host.chet Caught by controller[0]:                  ^
                    2022-02-03 20:19:32.607  - error: host.chet Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'
                    2022-02-03 20:19:32.607  - error: host.chet Caught by controller[0]: was compiled against a different Node.js version using
                    2022-02-03 20:19:32.607  - error: host.chet Caught by controller[0]: NODE_MODULE_VERSION 83. This version of Node.js requires
                    2022-02-03 20:19:32.607  - error: host.chet Caught by controller[0]: NODE_MODULE_VERSION 93. Please try re-compiling or re-installing
                    2022-02-03 20:19:32.608  - error: host.chet Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
                    2022-02-03 20:19:32.608  - error: host.chet Caught by controller[0]:     at Object.Module._extensions..node (node:internal/modules/cjs/loader:1183:18)
                    2022-02-03 20:19:32.608  - error: host.chet Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:981:32)
                    2022-02-03 20:19:32.608  - error: host.chet Caught by controller[0]:     at Function.Module._load (node:internal/modules/cjs/loader:822:12)
                    2022-02-03 20:19:32.609  - error: host.chet Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1005:19)
                    2022-02-03 20:19:32.609  - error: host.chet Caught by controller[0]:     at require (node:internal/modules/cjs/helpers:102:18)
                    2022-02-03 20:19:32.609  - error: host.chet Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/canvas/lib/bindings.js:3:18)
                    2022-02-03 20:19:32.609  - error: host.chet Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1101:14)
                    2022-02-03 20:19:32.609  - error: host.chet Caught by controller[0]:     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1153:10)
                    2022-02-03 20:19:32.610  - error: host.chet Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:981:32)
                    2022-02-03 20:19:32.610  - error: host.chet Caught by controller[0]:     at Function.Module._load (node:internal/modules/cjs/loader:822:12) {
                    2022-02-03 20:19:32.610  - error: host.chet Caught by controller[0]:   code: 'ERR_DLOPEN_FAILED'
                    2022-02-03 20:19:32.610  - error: host.chet Caught by controller[0]: }
                    2022-02-03 20:19:32.610  - error: host.chet instance system.adapter.parcel.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                    2022-02-03 20:19:32.611  - info: host.chet Adapter system.adapter.parcel.0 needs rebuild and will be restarted afterwards.
                    2022-02-03 20:19:32.611  - info: host.chet system.adapter.parcel.0 will be rebuilt ( undefined)
                    2022-02-03 20:19:32.611  - warn: host.chet adapter "parcel" seems to be installed for a different version of Node.js. Trying to rebuild it... 2 attempt
                    2022-02-03 20:19:32.612  - info: host.chet iobroker rebuild
                    2022-02-03 20:19:33.581  - info: host.chet iobroker npm-rebuild: Rebuilding native modules ...
                    2022-02-03 20:20:15.070  - info: host.chet iobroker npm-rebuild: rebuilt dependencies successfully
                    2022-02-03 20:20:15.110  - info: host.chet iobroker npm-rebuild:
                    2022-02-03 20:20:15.111  - info: host.chet iobroker npm-rebuild: Rebuilding native modules done
                    2022-02-03 20:20:16.125  - info: host.chet iobroker npm-rebuild: exit 0
                    2022-02-03 20:20:16.265  - info: host.chet instance system.adapter.parcel.0 started with pid 77583
                    2022-02-03 20:20:17.605  - error: host.chet Caught by controller[0]: node:internal/modules/cjs/loader:1183
                    2022-02-03 20:20:17.606  - error: host.chet Caught by controller[0]:   return process.dlopen(module, path.toNamespacedPath(filename));
                    2022-02-03 20:20:17.606  - error: host.chet Caught by controller[0]:                  ^
                    2022-02-03 20:20:17.606  - error: host.chet Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'
                    2022-02-03 20:20:17.606  - error: host.chet Caught by controller[0]: was compiled against a different Node.js version using
                    2022-02-03 20:20:17.606  - error: host.chet Caught by controller[0]: NODE_MODULE_VERSION 83. This version of Node.js requires
                    2022-02-03 20:20:17.606  - error: host.chet Caught by controller[0]: NODE_MODULE_VERSION 93. Please try re-compiling or re-installing
                    2022-02-03 20:20:17.606  - error: host.chet Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
                    2022-02-03 20:20:17.607  - error: host.chet Caught by controller[0]:     at Object.Module._extensions..node (node:internal/modules/cjs/loader:1183:18)
                    2022-02-03 20:20:17.607  - error: host.chet Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:981:32)
                    2022-02-03 20:20:17.607  - error: host.chet Caught by controller[0]:     at Function.Module._load (node:internal/modules/cjs/loader:822:12)
                    2022-02-03 20:20:17.607  - error: host.chet Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1005:19)
                    2022-02-03 20:20:17.607  - error: host.chet Caught by controller[0]:     at require (node:internal/modules/cjs/helpers:102:18)
                    2022-02-03 20:20:17.607  - error: host.chet Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/canvas/lib/bindings.js:3:18)
                    2022-02-03 20:20:17.608  - error: host.chet Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1101:14)
                    2022-02-03 20:20:17.608  - error: host.chet Caught by controller[0]:     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1153:10)
                    2022-02-03 20:20:17.608  - error: host.chet Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:981:32)
                    2022-02-03 20:20:17.608  - error: host.chet Caught by controller[0]:     at Function.Module._load (node:internal/modules/cjs/loader:822:12) {
                    2022-02-03 20:20:17.608  - error: host.chet Caught by controller[0]:   code: 'ERR_DLOPEN_FAILED'
                    2022-02-03 20:20:17.609  - error: host.chet Caught by controller[0]: }
                    2022-02-03 20:20:17.609  - error: host.chet instance system.adapter.parcel.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                    2022-02-03 20:20:17.609  - info: host.chet Adapter system.adapter.parcel.0 needs rebuild and will be restarted afterwards.
                    2022-02-03 20:20:17.610  - info: host.chet system.adapter.parcel.0 will be rebuilt ( undefined)
                    2022-02-03 20:20:17.610  - warn: host.chet adapter "parcel" seems to be installed for a different version of Node.js. Trying to rebuild it... 3 attempt
                    2022-02-03 20:20:17.610  - info: host.chet iobroker rebuild
                    2022-02-03 20:20:18.792  - info: host.chet iobroker npm-rebuild: Rebuilding native modules ...
                    2022-02-03 20:21:00.528  - info: host.chet iobroker npm-rebuild: rebuilt dependencies successfully
                    2022-02-03 20:21:00.570  - info: host.chet iobroker npm-rebuild:
                    2022-02-03 20:21:00.571  - info: host.chet iobroker npm-rebuild: Rebuilding native modules done
                    2022-02-03 20:21:01.582  - info: host.chet iobroker npm-rebuild: exit 0
                    2022-02-03 20:21:01.677  - info: host.chet instance system.adapter.parcel.0 started with pid 78216
                    2022-02-03 20:21:02.929  - error: host.chet Caught by controller[0]: node:internal/modules/cjs/loader:1183
                    2022-02-03 20:21:02.929  - error: host.chet Caught by controller[0]:   return process.dlopen(module, path.toNamespacedPath(filename));
                    2022-02-03 20:21:02.930  - error: host.chet Caught by controller[0]:                  ^
                    2022-02-03 20:21:02.930  - error: host.chet Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'
                    2022-02-03 20:21:02.930  - error: host.chet Caught by controller[0]: was compiled against a different Node.js version using
                    2022-02-03 20:21:02.930  - error: host.chet Caught by controller[0]: NODE_MODULE_VERSION 83. This version of Node.js requires
                    2022-02-03 20:21:02.930  - error: host.chet Caught by controller[0]: NODE_MODULE_VERSION 93. Please try re-compiling or re-installing
                    2022-02-03 20:21:02.931  - error: host.chet Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
                    2022-02-03 20:21:02.931  - error: host.chet Caught by controller[0]:     at Object.Module._extensions..node (node:internal/modules/cjs/loader:1183:18)
                    2022-02-03 20:21:02.931  - error: host.chet Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:981:32)
                    2022-02-03 20:21:02.931  - error: host.chet Caught by controller[0]:     at Function.Module._load (node:internal/modules/cjs/loader:822:12)
                    2022-02-03 20:21:02.931  - error: host.chet Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1005:19)
                    2022-02-03 20:21:02.932  - error: host.chet Caught by controller[0]:     at require (node:internal/modules/cjs/helpers:102:18)
                    2022-02-03 20:21:02.932  - error: host.chet Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/canvas/lib/bindings.js:3:18)
                    2022-02-03 20:21:02.932  - error: host.chet Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1101:14)
                    2022-02-03 20:21:02.933  - error: host.chet Caught by controller[0]:     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1153:10)
                    2022-02-03 20:21:02.933  - error: host.chet Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:981:32)
                    2022-02-03 20:21:02.933  - error: host.chet Caught by controller[0]:     at Function.Module._load (node:internal/modules/cjs/loader:822:12) {
                    2022-02-03 20:21:02.934  - error: host.chet Caught by controller[0]:   code: 'ERR_DLOPEN_FAILED'
                    2022-02-03 20:21:02.934  - error: host.chet Caught by controller[0]: }
                    2022-02-03 20:21:02.934  - error: host.chet instance system.adapter.parcel.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                    2022-02-03 20:21:02.934  - info: host.chet Rebuild for adapter system.adapter.parcel.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
                    foxriver76F 2 Antworten Letzte Antwort
                    • FeuersturmF
                      FeuersturmF
                      Feuersturm
                      #116
                      @apollon77
                      Ich hab gerade auf die Version Alpha73 aktualisiert.
                      proxmox@ioBrokerTestsystem:/opt/iobroker$ iobroker version
                      4.0.0-alpha.73-20220203-4ff5b7b6
                      Beim Update hatte ich wieder folgendes in der Konsole.
                      - Ignoring Directory "benchmark.files" because officially not created as meta ob        ject. Please remove directory!
                      - Ignoring Directory "daswetter" because officially not created as meta object.        Please remove directory!
                      - Ignoring Directory "hm-rega" because officially not created as meta object. Pl        ease remove directory!
                      - Ignoring Directory "iogo.admin" because officially not created as meta object.        Please remove directory!
                      - Ignoring Directory "tr-064-community.admin" because officially not created as        meta object. Please remove directory!
                      Ich hatte das gleiche Verhalten ja hier https://forum.iobroker.net/topic/52033/alpha-test-js-controller-4-0/45 auch schon.
                      Damals hatte ich das iobroker upload all gemacht
                      Meine aktuellen Objekte die angemeckert werden sehen so aus:
                      foxriver76F apollon77A 2 Antworten Letzte Antwort
                      • M mrjeschke
                        @apollon77
                        Moin,
                          "type": "state",
                          "common": {
                            "type": "boolean",
                            "role": "state",
                            "read": true,
                            "write": true,
                            "min": false,
                            "max": true,
                            "def": false,
                          "native": {},
                          "acl": {
                            "object": 1636,
                            "state": 1636,
                        foxriver76F
                        foxriver76F
                        foxriver76
                        #117
                        @maik-0 offensichtlich kann jeder Boolean true und false sein, ein min max wert macht nur bei einem numerischen Wert Sinn.
                        Videotutorials & mehr
                          wendy2702W
                          wendy2702W
                          #118
                          Da stimme ich dir zu. Frage bleibt nur wo.
                          Wenn morgen Zeit ist kommt der Holzhammer zum Einsatz
                            @apollon77
                            Line 4443
                                                    // show for debug
                                                    if (
                            Line 3016
                            foxriver76F
                            foxriver76F
                            foxriver76
                            #119
                            @thomas-braun Benutze mal den logger statt console, sonst tauch das nicht im logfile auf. Also logger.warn('blabla')
                            • foxriver76F foxriver76
                              M
                              M
                              mrjeschke
                              #120
                              @foxriver76
                              Ja sehe ich auch so. In der Doku gibt‘s aber ein Beispiel mit einem boolean
                              und min+max Wert. Egal, ich habe bei allen booleans die min/max Werte gelöscht. Jetzt ist Ruhe.
                              • FeuersturmF Feuersturm
                                @apollon77
                                foxriver76F
                                foxriver76F
                                foxriver76
                                #121
                                @feuersturm sagte in Alpha Test js-controller 4.0:
                                • Ignoring Directory "benchmark.files" because officially not created as meta ob ject. Please remove directory!
                                • Ignoring Directory "daswetter" because officially not created as meta object. Please remove directory!
                                • Ignoring Directory "hm-rega" because officially not created as meta object. Pl ease remove directory!
                                • Ignoring Directory "iogo.admin" because officially not created as meta object. Please remove directory!
                                • Ignoring Directory "tr-064-community.admin" because officially not created as
                                Danke, da passt was nicht, aber schon vor 4.0!
                                  Thomas BraunT
                                  Thomas BraunT
                                  #122
                                  @foxriver76
                                  Da weiß ich gerade nicht was du wo meinst...
                                  • M mrjeschke
                                    @foxriver76
                                    apollon77A
                                    apollon77A
                                    #123
                                    @maik-0 Doku wo? Muss gefixt werden
                                      FeuersturmF
                                      FeuersturmF
                                      Feuersturm
                                      #124
                                      @foxriver76 sagte in Alpha Test js-controller 4.0:
                                      Ich könnte auf einen Stand zurückgehen wo noch die 3.3.22 drauf ist.Würde das helfen? Wonach müsste ich dort schauen?
                                        @apollon77
                                        apollon77A
                                        apollon77A
                                        #125
                                        @feuersturm Najaok sagen wir so:
                                        • die mit .admin solten nach einem "upload all" weg sein - wenn die Adapter noch da sind! Wenn die Adapter ggf gelöscht sind dann File smanuell löschen, ende
                                        • die anderen sollten verschwinden wenn du den relevanten Adapter einmalig startest- wenn er noch da ist (sonst löschen)
                                          M
                                          M
                                          mrjeschke
                                          #126
                                          @apollon77
                                          https://www.iobroker.net/#de/documentation/dev/objectsschema.md
                                          Unter Kanalbeschreibungen.
                                          33.2k
                                          84.3k
