  4. Speedtest-Skript von kreyenborg.koeln für Kabel-Gigabit
    2.6k
    4.6k
    4.0k
391 Beiträge 33 Kommentatoren 99.9k Aufrufe 33 Beobachtet
    @negalein sagte in Speedtest-Skript von kreyenborg.koeln für Kabel-Gigabit:
    154 packages can be upgraded.
    Bist du des Wahnsinns?
    Updaten, aber schnell!
    sudo apt full-upgrade
    sudo reboot
    NegaleinN Offline
    NegaleinN Offline
    Negalein
    #81
    @thomas-braun sagte in Speedtest-Skript von kreyenborg.koeln für Kabel-Gigabit:
    Aye, aye, Käpt’n! ;)
    Und dann wie weiter?
    ° Fixer ---> iob fix
    • NegaleinN Negalein
      #82
      @negalein
      speedtest installieren? Das Repo passt ja nun.
      sudo apt install speedtest
        #83
        Künftig REGELMÄSSIG das System auf Stand halten.
          @negalein
          NegaleinN Offline
          NegaleinN Offline
          Negalein
          #84
          nega@ioBroker:~$ sudo apt install speedtest
          [sudo] password for nega:
          Reading package lists... Done
          Building dependency tree
          The following package was automatically installed and is no longer required:
            libllvm11
          Use 'sudo apt autoremove' to remove it.
          The following NEW packages will be installed:
            speedtest
          0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
          Need to get 0 B/1055 kB of archives.
          After this operation, 2549 kB of additional disk space will be used.
          (Reading database ... 36354 files and directories currently installed.)
          Preparing to unpack .../speedtest_1.1.1.28-1.c732eb82cf_amd64.deb ...
          Unpacking speedtest (1.1.1.28-1.c732eb82cf) ...
          dpkg: error processing archive /var/cache/apt/archives/speedtest_1.1.1.28-1.c732eb82cf_amd64.deb (--unpack):
           trying to overwrite '/usr/bin/speedtest', which is also in package speedtest-cli 2.1.2-2ubuntu0.20.04.1
          dpkg-deb: error: paste subprocess was killed by signal (Broken pipe)
          Errors were encountered while processing:
          E: Sub-process /usr/bin/dpkg returned an error code (1)
          nega@ioBroker:~$ speedtest
          Retrieving speedtest.net configuration...
          Testing from Fonira Telekom GmbH (185.129.173.57)...
          Retrieving speedtest.net server list...
          Selecting best server based on ping...
          Hosted by Netprotect (Vienna) [214.89 km]: 13.237 ms
          Testing download speed................................................................................
          Download: 743.13 Mbit/s
          Testing upload speed......................................................................................................
          Upload: 429.67 Mbit/s
              libllvm11
              speedtest
            #85
            sudo apt remove speedtest-cli
            Damrak2022D NegaleinN 2 Antworten Letzte Antwort
              Damrak2022D Offline
              Damrak2022D Offline
              Damrak2022
              #86
              @thomas-braun Okay, gemacht
              pi@homebridge:~ $ sudo apt full-upgrade
              Building dependency tree... Done
              Calculating upgrade... Done
              The following packages will be upgraded:
                nodejs
              1 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
              Need to get 23.3 MB of archives.
              After this operation, 31.2 MB of additional disk space will be used.
              Do you want to continue? [Y/n] y
              Get:1 https://deb.nodesource.com/node_14.x bullseye/main armhf nodejs armhf 14.19.1-deb-1nodesource1 [23.3 MB]
              Fetched 23.3 MB in 1s (15.6 MB/s)
              Reading changelogs... Done
              (Reading database ... 62196 files and directories currently installed.)
              Preparing to unpack .../nodejs_14.19.1-deb-1nodesource1_armhf.deb ...
              Unpacking nodejs (14.19.1-deb-1nodesource1) over (12.22.12-deb-1nodesource1) ...
              Setting up nodejs (14.19.1-deb-1nodesource1) ...
              Processing triggers for man-db (2.9.4-2) ...
              pi@homebridge:~ $ sudo apt install speedtest
              speedtest is already the newest version (1.1.1.28-1.c732eb82cf).
              0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
              pi@homebridge:~ $
              Mit besten Grüßen
              Andy
                NegaleinN Offline
                NegaleinN Offline
                Negalein
                #87
                Merci, funktioniert! :)
                10:13:18.127	info	javascript.0 (1887) script.js.Netzwerk.Speedtest: Speedtest mit Server 5476 gestartet! Der Test dauert zwischen 10 - 20 Sekunden!
                10:13:37.909	info	javascript.0 (1887) script.js.Netzwerk.Speedtest: Speedtest durchgeführt. Ergebnisse: Download: 92.81 MB/s | Upload: 94.15 MB/s | Ping: 10.806ms
                   Speedtest by Ookla
                     Server: Energie AG Oberoesterreich Telekom GmbH - Gmunden (id = 5476)
                        ISP: Fonira Telekom GmbH
                    Latency:    10.78 ms   (0.09 ms jitter)
                   Download:   777.98 Mbps (data used: 846.2 MB )
                     Upload:   782.09 Mbps (data used: 850.7 MB )
                Packet Loss:     0.0%
                 Result URL: https://www.speedtest.net/result/c/7bcefc71-fa63-4b37-8cc4-6515c2bd1a92
                     Speedtest by Ookla
                  Packet Loss:     0.0%
                  #88
                  @negalein
                  Siehste, sogar ein Server aus Oberösterreich.
                    Die beiden für ioBroker verfügbaren Adapter um Speedtests zu monitoren haben die Eigenschaft an meinem Gigabit-Anschluss über Kabel sehr unbeständige Werte abzuliefern. Ein Flot-Chart sieht dann aus wie ein Kamm, dem ein paar Zinken fehlen.
                    Sehr viel beständigere und realistischere Werte liefert mir ein skript von https://www.kreyenborg.koeln/speedtest-fuer-iobroker/
                    Ich dokumentiere hier mal, wie ich das etwas abweichend von Stephan Kreyenborgs Anleitung auf meinem System eingerichtet habe.
                    Zunächst habe ich sowohl den webspeedy wie auch den vofo-speedtest-Adapter im ioBroker deinstalliert.
                    Dann habe ich per
                    sudo apt remove speedtest-cli speedtest
                    den bisherigen Kommandozeilen-Speedtest deinstalliert.
                    Dann per
                    sudo apt install curl
                    curl -s https://packagecloud.io/install/repositories/ookla/speedtest-cli/script.deb.sh | sudo bash
                    sudo apt update
                    das aktuelle Repo von ookla/speedtest.net eingespielt.
                    [EXKURS]
                    Falls das skript nicht durchläuft kann man 'zu Fuß' eine passende Datei unter /etc/apt/sources.list.d/ookla_speedtest-cli.list für Debian Bullseye mit folgendem Inhalt angelegen:
                    # this file was generated by packagecloud.io for
                    # the repository at https://packagecloud.io/ookla/speedtest-cli
                    deb [signed-by=/etc/apt/trusted.gpg.d/ookla_speedtest-cli-archive-keyring.gpg] https://packagecloud.io/ookla/speedtest-cli/debian/ bullseye main
                    deb-src [signed-by=/etc/apt/trusted.gpg.d/ookla_speedtest-cli-archive-keyring.gpg] https://packagecloud.io/ookla/speedtest-cli/debian/ bullseye main
                    Dann noch den Schlüssel importieren:
                    curl -fsSL https://packagecloud.io/ookla/speedtest-cli/gpgkey | gpg --dearmor | sudo tee /etc/apt/trusted.gpg.d/ookla_speedtest-cli-archive-keyring.gpg
                    Andere Distributionen wie z. B. ubuntu dann analog (DISTRIBUTION und RELEASE entsprechend ersetzen):
                    deb https://packagecloud.io/ookla/speedtest-cli/DISTRIBUTION/ RELEASE main
                    deb-src https://packagecloud.io/ookla/speedtest-cli/DISTRIBUTION/ RELEASE main
                    Ein
                    sudo apt update
                    spült die gewünschte Version dann in mein System.
                    [EXKURS ENDE]
                    Erster Test in der Kommandozeile liefert:
                    echad@chet:/opt/iobroker $ speedtest
                       Speedtest by Ookla
                         Server: fiberONE - Darmstadt (id = 25942)
                            ISP: Vodafone Germany Cable
                        Latency:    11.86 ms   (1.27 ms jitter)
                       Download:   930.24 Mbps (data used: 1.2 GB)
                         Upload:    51.74 Mbps (data used: 25.9 MB)
                    Packet Loss:     0.0%
                    Prima, funktioniert.
                    Dann das skript von kreyenborg.koeln in den javaskript-Adapter geladen und in Zeile 210 oder 217 die Zeile
                    var kommando = "/etc/speedtest/speedtest -f json --accept-license --accept-gdpr";
                    an den anderen Pfad angepasst:
                    var kommando = "/usr/bin/speedtest -f json --accept-license --accept-gdpr";
                    Danach lief das skript und ich kann per eCharts so ein Diagramm bewundern:
                    Tip am Rande:
                    Per
                    https://c.speedtest.net/speedtest-servers-static.php
                    sollte man eine ID (hier z. B. 12345) eines zuverlässigen Servers identifizieren und im skript in Zeile 32 fix eintragen.
                    var fav_server = 12345;
                    ps1304
                    #89
                    Danke für deinen Beitrag - ich habe nach der Webseite installiert und bekomme beim Befehl "sudo apt update" jetzt folgenden Fehler:
                    E: Das Depot »https://packagecloud.io/ookla/speedtest-cli/ubuntu impish Release« enthält keine Release-Datei.
                    N: Eine Aktualisierung von solch einem Depot kann nicht auf eine sichere Art durchgeführt werden, daher ist es standardmäßig deaktiviert.
                    N: Weitere Details zur Erzeugung von Paketdepots sowie zu deren Benutzerkonfiguration finden Sie in der Handbuchseite apt-secure(8).
                    Hast du nen Tipp?
                    Gruß Peter
                    • P ps1304
                      Hast du nen Tipp?
                      Gruß Peter
                      #90
                      @ps1304
                      Hab kein Ubuntu im Einsatz.
                      Aber offenbar bauen die keine Pakete für impish.
                      Könnte sein, dass hier nur für LTS-Versionen gebaut wird. Die Zwischenversionen leben ja nur 9 Monate.
                      Trag mal ausnahmsweise statt impish die Vorversion focal in die Datei
                      /etc/apt/sources.list.d/ookla_speedtest-cli.list ein.
                      • P ps1304
                        Hast du nen Tipp?
                        Gruß Peter
                        #91
                        @ps1304
                        Edit. Siehe oben.
                        Und daran denken, dass am 14.07.2022 Schluss ist mit 'impish'. Ich würde da auf die jetzt aktuelle LTS-Version wechseln.
                          ps1304
                          #92
                          super vielen Dank - der Tipp war schon mal gut !!! das Update mache ich gerade.
                          Gruß Peter
                          • David G.D Online
                            David G.D Online
                            David G.
                            #93
                            bei mir mag er das irgendwie nicht installieren.
                            pi@pi:~ $ curl -s https://packagecloud.io/install/repositories/ookla/speedtest-cli/script.deb.sh | sudo bash
                            Detected operating system as raspbian/bullseye.
                            Checking for curl...
                            Detected curl...
                            Checking for gpg...
                            Detected gpg...
                            Running apt-get update... done.
                            Installing apt-transport-https... done.
                            Installing /etc/apt/sources.list.d/ookla_speedtest-cli.list...done.Importing packagecloud gpg key... done.
                            The repository is setup! You can now install packages.
                            pi@pi:~ $ sudo apt update                                          Ign:1 https://packagecloud.io/ookla/speedtest-cli/raspbian bullseye InRelease
                            Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                            Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
                            Err:4 https://packagecloud.io/ookla/speedtest-cli/raspbian bullseye Release
                              404  Not Found [IP: 54.183.164.179 443]
                            Hit:5 https://deb.nodesource.com/node_16.x bullseye InRelease
                            E: The repository 'https://packagecloud.io/ookla/speedtest-cli/raspbian bullseye Release' does not have a Release file.
                            N: Updating from such a repository can't be done securely, and is therefore disabled by default.
                            N: See apt-secure(8) manpage for repository creation and user configuration details.
                            pi@pi:~ $ sudo apt install speedtest
                            E: Unable to locate package speedtest
                            pi@pi:~ $ lsb_release -a
                            No LSB modules are available.
                            Distributor ID: Raspbian
                            Description:    Raspbian GNU/Linux 11 (bullseye)
                            Release:        11
                            Codename:       bullseye
                            GNU nano 5.4  /etc/apt/sources.list.d/nodesource.list            deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nod>deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb>
                            • David G.D David G.
                              Detected curl...
                              Checking for gpg...
                              Detected gpg...
                              Release:        11
                              Codename:       bullseye
                              #94
                              @david-g
                              uname -a
                              cat /etc/apt/sources.list.d/nodesource.list
                                Detected curl...
                                Checking for gpg...
                                Detected gpg...
                                Release:        11
                                Codename:       bullseye
                                #95
                                @david-g
                                Trag das mal so ein:
                                echad@chet:~ $ cat /etc/apt/sources.list.d/ookla_speedtest-cli.list
                                deb [signed-by=/etc/apt/keyrings/ookla_speedtest-cli-archive-keyring.gpg] https://packagecloud.io/ookla/speedtest-cli/debian/ bullseye main
                                deb-src [signed-by=/etc/apt/keyrings/ookla_speedtest-cli-archive-keyring.gpg] https://packagecloud.io/ookla/speedtest-cli/debian/ bullseye main
                                echad@chet:~ $
                                Also statt raspbian debian eintragen. Da ist das Installationsskript immer noch unsauber und passt nicht für Raspberry OS.
                                  @david-g
                                  echad@chet:~ $
                                  David G.D Online
                                  David G.D Online
                                  David G.
                                  #96
                                  So klappt es,
                                  vielen Dank.
                                  Dann begebe ich mich nachher mal an das Skript.
                                  • David G.D Online
                                    David G.D Online
                                    David G.
                                    #97
                                    Habe mal eine ganz allgemeine Frage zum Skript.
                                    Die Datenpunkte werden ja im javascript.0 angelegt.
                                    Jetzt hab ich hier schon ein paar mal gelesen, dass man für eigene Datenpunkte eher den userdata.0 bevorzugen soll.
                                    Macht das für so ein Skript auch mehr Sinn?
                                    ? 1 Antwort Letzte Antwort
                                      #98
                                      @david-g eigene Datenpunkte unter 0_userdata.0 haben den Vorteil, dass wenn du z.Bsp. die Javascript-Instanz loeschen wuerdest deine Datenpunkte erhalten bleibn, incl. History.. daher wenn moeglich, immer eigene Datenpunkte in userdata anlegen.
                                      Zeile 28 dann anstatt
                                      var datenpunkt = "Speedtest.";
                                      in
                                      var datenpunkt = "0_userdata.0.Speedtest.";
                                      • David G.D Online
                                        David G.D Online
                                        David G.
                                        #99
                                        Habt ihr auch, dass das Skript mehrfach läuft, wenn ihr Änderungen vorgenommen habt?
                                        Hatte 1-2 mal den shedule geändert und ein paar Server getestet.
                                        Als die Testergebnisse dann viel zu gering waren habe ich im Log (und der History) gesehen, dass der Test innerhalb einer Sekunde 8 mal gestartet wird, regelmäßig.
                                        liv-in-skyL NegaleinN 2 Antworten Letzte Antwort
                                          liv-in-skyL Offline
                                          liv-in-skyL Offline
                                          liv-in-sky
                                          #100
                                          @david-g starte die javascript instanz neu - evtl hängt da noch was im system
