  4. Speedtest-Skript von kreyenborg.koeln für Kabel-Gigabit
    6.1k
391 Beiträge 33 Kommentatoren 105.1k Aufrufe 33 Beobachtet
  • NegaleinN Negalein
    @thomas-braun sagte in Speedtest-Skript von kreyenborg.koeln für Kabel-Gigabit:
    dann
    nega@ioBroker:~$ sudo apt update
    Hit:1 https://deb.nodesource.com/node_14.x focal InRelease
    Hit:2 http://archive.ubuntu.com/ubuntu focal InRelease
    Get:3 http://archive.ubuntu.com/ubuntu focal-updates InRelease [114 kB]
    Get:5 http://archive.ubuntu.com/ubuntu focal-security InRelease [114 kB]
    Get:6 http://archive.ubuntu.com/ubuntu focal-updates/main amd64 Packages [1744 kB]
    Get:7 http://archive.ubuntu.com/ubuntu focal-updates/universe amd64 Packages [918 kB]
    Hit:4 https://packagecloud.io/ookla/speedtest-cli/ubuntu focal InRelease
    Fetched 2891 kB in 2s (1669 kB/s)
    Reading package lists... Done
    Building dependency tree
    154 packages can be upgraded. Run 'apt list --upgradable' to see them.
    nega@ioBroker:~$ apt policy speedtest
    speedtest:
      Installed: (none)
      Candidate: 1.1.1.28-1.c732eb82cf
      Version table:
         1.1.1.28-1.c732eb82cf 500
            500 https://packagecloud.io/ookla/speedtest-cli/ubuntu focal/main amd64 Packages
         1.1.0.75-1.810304edbd 500
         1.0.0.2-1.5ae238b 500
    #78
    @negalein sagte in Speedtest-Skript von kreyenborg.koeln für Kabel-Gigabit:
    Bist du des Wahnsinns?
    Updaten, aber schnell!
    sudo apt full-upgrade
    sudo reboot
    • Damrak2022D Damrak2022
      Jetzt sieht es so aus:
      pi@homebridge:~ $ sudo apt update
      Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
      Hit:3 https://packages.grafana.com/enterprise/deb stable InRelease
      Hit:4 https://repos.influxdata.com/debian bullseye InRelease
      Hit:5 https://deb.nodesource.com/node_12.x bullseye InRelease
      Hit:6 https://packagecloud.io/ookla/speedtest-cli/debian bullseye InRelease
      All packages are up to date.
      pi@homebridge:~ $ apt policy speedtest
      speedtest:
        Installed: 1.1.1.28-1.c732eb82cf
        Version table:
       *** 1.1.1.28-1.c732eb82cf 500
              500 https://packagecloud.io/ookla/speedtest-cli/debian bullseye/main armhf Packages
      pi@homebridge:~ $
      Wieso kann ich mein node js nicht upgraden. Wieso habe ich hier Permission denied
      Damrak2022D Offline
      Damrak2022D Offline
      Damrak2022
      #79
      @damrak2022 Jetzt so
      pi@homebridge:~ $ sudo nano /etc/apt/sources.list.d/nodesource.list
      Get:5 https://deb.nodesource.com/node_14.x bullseye InRelease [4,586 B]
      Get:7 https://deb.nodesource.com/node_14.x bullseye/main armhf Packages [780 B]
      Fetched 5,366 B in 2s (2,687 B/s)
      1 package can be upgraded. Run 'apt list --upgradable' to see it.
      speedtest:
        Version table:
      pi@homebridge:~ $ apt list --upgradable
      Listing... Done
      nodejs/unknown 14.19.1-deb-1nodesource1 armhf [upgradable from: 12.22.12-deb-1nodesource1]
      N: There are 2 additional versions. Please use the '-a' switch to see them.
      pi@homebridge:~ $
      Mit besten Grüßen
      Andy
        speedtest:
          Version table:
        Listing... Done
        pi@homebridge:~ $
        #80
        @damrak2022
        Ja, passt.
        iobroker stoppen, updates einspielen
        , iobroker wieder starten.
          sudo reboot
          NegaleinN Offline
          NegaleinN Offline
          Negalein
          #81
          Aye, aye, Käpt’n! ;)
          Und dann wie weiter?
          ° Fixer ---> iob fix
            #82
            @negalein
            speedtest installieren? Das Repo passt ja nun.
            sudo apt install speedtest
              #83
              Künftig REGELMÄSSIG das System auf Stand halten.
                @negalein
                NegaleinN Offline
                NegaleinN Offline
                Negalein
                #84
                nega@ioBroker:~$ sudo apt install speedtest
                [sudo] password for nega:
                The following package was automatically installed and is no longer required:
                  libllvm11
                Use 'sudo apt autoremove' to remove it.
                The following NEW packages will be installed:
                  speedtest
                0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
                Need to get 0 B/1055 kB of archives.
                After this operation, 2549 kB of additional disk space will be used.
                (Reading database ... 36354 files and directories currently installed.)
                Preparing to unpack .../speedtest_1.1.1.28-1.c732eb82cf_amd64.deb ...
                Unpacking speedtest (1.1.1.28-1.c732eb82cf) ...
                dpkg: error processing archive /var/cache/apt/archives/speedtest_1.1.1.28-1.c732eb82cf_amd64.deb (--unpack):
                 trying to overwrite '/usr/bin/speedtest', which is also in package speedtest-cli 2.1.2-2ubuntu0.20.04.1
                dpkg-deb: error: paste subprocess was killed by signal (Broken pipe)
                Errors were encountered while processing:
                E: Sub-process /usr/bin/dpkg returned an error code (1)
                nega@ioBroker:~$ speedtest
                Retrieving speedtest.net configuration...
                Testing from Fonira Telekom GmbH (185.129.173.57)...
                Retrieving speedtest.net server list...
                Selecting best server based on ping...
                Hosted by Netprotect (Vienna) [214.89 km]: 13.237 ms
                Testing download speed................................................................................
                Download: 743.13 Mbit/s
                Testing upload speed......................................................................................................
                Upload: 429.67 Mbit/s
                    libllvm11
                    speedtest
                  #85
                  sudo apt remove speedtest-cli
                  Damrak2022D NegaleinN 2 Antworten Letzte Antwort
                    Damrak2022D Offline
                    Damrak2022D Offline
                    Damrak2022
                    #86
                    @thomas-braun Okay, gemacht
                    pi@homebridge:~ $ sudo apt full-upgrade
                    Calculating upgrade... Done
                    The following packages will be upgraded:
                      nodejs
                    1 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                    Need to get 23.3 MB of archives.
                    After this operation, 31.2 MB of additional disk space will be used.
                    Do you want to continue? [Y/n] y
                    Get:1 https://deb.nodesource.com/node_14.x bullseye/main armhf nodejs armhf 14.19.1-deb-1nodesource1 [23.3 MB]
                    Fetched 23.3 MB in 1s (15.6 MB/s)
                    Reading changelogs... Done
                    (Reading database ... 62196 files and directories currently installed.)
                    Preparing to unpack .../nodejs_14.19.1-deb-1nodesource1_armhf.deb ...
                    Unpacking nodejs (14.19.1-deb-1nodesource1) over (12.22.12-deb-1nodesource1) ...
                    Setting up nodejs (14.19.1-deb-1nodesource1) ...
                    Processing triggers for man-db (2.9.4-2) ...
                    pi@homebridge:~ $ sudo apt install speedtest
                    speedtest is already the newest version (1.1.1.28-1.c732eb82cf).
                    0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                    pi@homebridge:~ $
                    Mit besten Grüßen
                    Andy
                      NegaleinN Offline
                      NegaleinN Offline
                      Negalein
                      #87
                      Merci, funktioniert! :)
                      10:13:18.127	info	javascript.0 (1887) script.js.Netzwerk.Speedtest: Speedtest mit Server 5476 gestartet! Der Test dauert zwischen 10 - 20 Sekunden!
                      10:13:37.909	info	javascript.0 (1887) script.js.Netzwerk.Speedtest: Speedtest durchgeführt. Ergebnisse: Download: 92.81 MB/s | Upload: 94.15 MB/s | Ping: 10.806ms
                         Speedtest by Ookla
                           Server: Energie AG Oberoesterreich Telekom GmbH - Gmunden (id = 5476)
                              ISP: Fonira Telekom GmbH
                          Latency:    10.78 ms   (0.09 ms jitter)
                         Download:   777.98 Mbps (data used: 846.2 MB )
                           Upload:   782.09 Mbps (data used: 850.7 MB )
                      Packet Loss:     0.0%
                       Result URL: https://www.speedtest.net/result/c/7bcefc71-fa63-4b37-8cc4-6515c2bd1a92
                           Speedtest by Ookla
                        Packet Loss:     0.0%
                        #88
                        @negalein
                        Siehste, sogar ein Server aus Oberösterreich.
                          Die beiden für ioBroker verfügbaren Adapter um Speedtests zu monitoren haben die Eigenschaft an meinem Gigabit-Anschluss über Kabel sehr unbeständige Werte abzuliefern. Ein Flot-Chart sieht dann aus wie ein Kamm, dem ein paar Zinken fehlen.
                          Sehr viel beständigere und realistischere Werte liefert mir ein skript von https://www.kreyenborg.koeln/speedtest-fuer-iobroker/
                          Ich dokumentiere hier mal, wie ich das etwas abweichend von Stephan Kreyenborgs Anleitung auf meinem System eingerichtet habe.
                          Zunächst habe ich sowohl den webspeedy wie auch den vofo-speedtest-Adapter im ioBroker deinstalliert.
                          Dann habe ich per
                          sudo apt remove speedtest-cli speedtest
                          den bisherigen Kommandozeilen-Speedtest deinstalliert.
                          Dann per
                          sudo apt install curl
                          curl -s https://packagecloud.io/install/repositories/ookla/speedtest-cli/script.deb.sh | sudo bash
                          sudo apt update
                          das aktuelle Repo von ookla/speedtest.net eingespielt.
                          [EXKURS]
                          Falls das skript nicht durchläuft kann man 'zu Fuß' eine passende Datei unter /etc/apt/sources.list.d/ookla_speedtest-cli.list für Debian Bullseye mit folgendem Inhalt angelegen:
                          # this file was generated by packagecloud.io for
                          # the repository at https://packagecloud.io/ookla/speedtest-cli
                          deb [signed-by=/etc/apt/trusted.gpg.d/ookla_speedtest-cli-archive-keyring.gpg] https://packagecloud.io/ookla/speedtest-cli/debian/ bullseye main
                          deb-src [signed-by=/etc/apt/trusted.gpg.d/ookla_speedtest-cli-archive-keyring.gpg] https://packagecloud.io/ookla/speedtest-cli/debian/ bullseye main
                          Dann noch den Schlüssel importieren:
                          curl -fsSL https://packagecloud.io/ookla/speedtest-cli/gpgkey | gpg --dearmor | sudo tee /etc/apt/trusted.gpg.d/ookla_speedtest-cli-archive-keyring.gpg
                          Andere Distributionen wie z. B. ubuntu dann analog (DISTRIBUTION und RELEASE entsprechend ersetzen):
                          deb https://packagecloud.io/ookla/speedtest-cli/DISTRIBUTION/ RELEASE main
                          deb-src https://packagecloud.io/ookla/speedtest-cli/DISTRIBUTION/ RELEASE main
                          Ein
                          sudo apt update
                          spült die gewünschte Version dann in mein System.
                          [EXKURS ENDE]
                          Erster Test in der Kommandozeile liefert:
                          echad@chet:/opt/iobroker $ speedtest
                             Speedtest by Ookla
                               Server: fiberONE - Darmstadt (id = 25942)
                                  ISP: Vodafone Germany Cable
                              Latency:    11.86 ms   (1.27 ms jitter)
                             Download:   930.24 Mbps (data used: 1.2 GB)
                               Upload:    51.74 Mbps (data used: 25.9 MB)
                          Packet Loss:     0.0%
                          Prima, funktioniert.
                          Dann das skript von kreyenborg.koeln in den javaskript-Adapter geladen und in Zeile 210 oder 217 die Zeile
                          var kommando = "/etc/speedtest/speedtest -f json --accept-license --accept-gdpr";
                          an den anderen Pfad angepasst:
                          var kommando = "/usr/bin/speedtest -f json --accept-license --accept-gdpr";
                          Danach lief das skript und ich kann per eCharts so ein Diagramm bewundern:
                          Tip am Rande:
                          Per
                          https://c.speedtest.net/speedtest-servers-static.php
                          sollte man eine ID (hier z. B. 12345) eines zuverlässigen Servers identifizieren und im skript in Zeile 32 fix eintragen.
                          var fav_server = 12345;
                          ps1304
                          #89
                          Danke für deinen Beitrag - ich habe nach der Webseite installiert und bekomme beim Befehl "sudo apt update" jetzt folgenden Fehler:
                          E: Das Depot »https://packagecloud.io/ookla/speedtest-cli/ubuntu impish Release« enthält keine Release-Datei.
                          N: Eine Aktualisierung von solch einem Depot kann nicht auf eine sichere Art durchgeführt werden, daher ist es standardmäßig deaktiviert.
                          N: Weitere Details zur Erzeugung von Paketdepots sowie zu deren Benutzerkonfiguration finden Sie in der Handbuchseite apt-secure(8).
                          Hast du nen Tipp?
                          Gruß Peter
                          • P ps1304
                            Hast du nen Tipp?
                            Gruß Peter
                            #90
                            @ps1304
                            Hab kein Ubuntu im Einsatz.
                            Aber offenbar bauen die keine Pakete für impish.
                            Könnte sein, dass hier nur für LTS-Versionen gebaut wird. Die Zwischenversionen leben ja nur 9 Monate.
                            Trag mal ausnahmsweise statt impish die Vorversion focal in die Datei
                            /etc/apt/sources.list.d/ookla_speedtest-cli.list ein.
                            • P ps1304
                              Hast du nen Tipp?
                              Gruß Peter
                              #91
                              @ps1304
                              Edit. Siehe oben.
                              Und daran denken, dass am 14.07.2022 Schluss ist mit 'impish'. Ich würde da auf die jetzt aktuelle LTS-Version wechseln.
                              • P Offline
                                ps1304
                                #92
                                super vielen Dank - der Tipp war schon mal gut !!! das Update mache ich gerade.
                                Gruß Peter
                                • David G.D Online
                                  David G.D Online
                                  David G.
                                  #93
                                  bei mir mag er das irgendwie nicht installieren.
                                  pi@pi:~ $ curl -s https://packagecloud.io/install/repositories/ookla/speedtest-cli/script.deb.sh | sudo bash
                                  Detected operating system as raspbian/bullseye.
                                  Checking for curl...
                                  Detected curl...
                                  Checking for gpg...
                                  Detected gpg...
                                  Running apt-get update... done.
                                  Installing apt-transport-https... done.
                                  Installing /etc/apt/sources.list.d/ookla_speedtest-cli.list...done.Importing packagecloud gpg key... done.
                                  The repository is setup! You can now install packages.
                                  pi@pi:~ $ sudo apt update                                          Ign:1 https://packagecloud.io/ookla/speedtest-cli/raspbian bullseye InRelease
                                  Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
                                  Err:4 https://packagecloud.io/ookla/speedtest-cli/raspbian bullseye Release
                                    404  Not Found [IP: 54.183.164.179 443]
                                  Hit:5 https://deb.nodesource.com/node_16.x bullseye InRelease
                                  E: The repository 'https://packagecloud.io/ookla/speedtest-cli/raspbian bullseye Release' does not have a Release file.
                                  N: Updating from such a repository can't be done securely, and is therefore disabled by default.
                                  N: See apt-secure(8) manpage for repository creation and user configuration details.
                                  pi@pi:~ $ sudo apt install speedtest
                                  E: Unable to locate package speedtest
                                  pi@pi:~ $ lsb_release -a
                                  No LSB modules are available.
                                  Distributor ID: Raspbian
                                  Description:    Raspbian GNU/Linux 11 (bullseye)
                                  Release:        11
                                  Codename:       bullseye
                                  GNU nano 5.4  /etc/apt/sources.list.d/nodesource.list            deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nod>deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb>
                                  • David G.D David G.
                                    Detected curl...
                                    Checking for gpg...
                                    Detected gpg...
                                    Release:        11
                                    Codename:       bullseye
                                    #94
                                    @david-g
                                    uname -a
                                    cat /etc/apt/sources.list.d/nodesource.list
                                      Detected curl...
                                      Checking for gpg...
                                      Detected gpg...
                                      Release:        11
                                      Codename:       bullseye
                                      #95
                                      @david-g
                                      Trag das mal so ein:
                                      echad@chet:~ $ cat /etc/apt/sources.list.d/ookla_speedtest-cli.list
                                      deb [signed-by=/etc/apt/keyrings/ookla_speedtest-cli-archive-keyring.gpg] https://packagecloud.io/ookla/speedtest-cli/debian/ bullseye main
                                      deb-src [signed-by=/etc/apt/keyrings/ookla_speedtest-cli-archive-keyring.gpg] https://packagecloud.io/ookla/speedtest-cli/debian/ bullseye main
                                      echad@chet:~ $
                                      Also statt raspbian debian eintragen. Da ist das Installationsskript immer noch unsauber und passt nicht für Raspberry OS.
                                        @david-g
                                        echad@chet:~ $
                                        David G.D Online
                                        David G.D Online
                                        David G.
                                        #96
                                        So klappt es,
                                        vielen Dank.
                                        Dann begebe ich mich nachher mal an das Skript.
                                        • David G.D Online
                                          David G.D Online
                                          David G.
                                          #97
                                          Habe mal eine ganz allgemeine Frage zum Skript.
                                          Die Datenpunkte werden ja im javascript.0 angelegt.
                                          Jetzt hab ich hier schon ein paar mal gelesen, dass man für eigene Datenpunkte eher den userdata.0 bevorzugen soll.
                                          Macht das für so ein Skript auch mehr Sinn?
