  4. Speedtest-Skript von kreyenborg.koeln für Kabel-Gigabit
    1.0k
    6.1k
391 Beiträge 33 Kommentatoren 105.1k Aufrufe 33 Beobachtet
  • Damrak2022D Damrak2022
    @thomas-braun So, ich hoffe das ich das nun richtig gemacht habe.
    Last login: Wed Apr 20 09:05:04 on ttys000
    damrak2021@Andreass-iMac ~ % ssh pi@homebridge
    pi@homebridge's password:
    Linux homebridge 5.15.32-v7l+ #1538 SMP Thu Mar 31 19:39:41 BST 2022 armv7l
    permitted by applicable law.
    Last login: Wed Apr 20 08:05:22 2022 from 2a02:908:171:e900:303c:c240:9f73:977d
    pi@homebridge:~ $ /etc/apt/sources.list.d/ookla_speedtest-cli.list
    -bash: /etc/apt/sources.list.d/ookla_speedtest-cli.list: No such file or directory
    pi@homebridge:~ $ sudo nano /etc/apt/sources.list.d/ookla_speedtest-cli.list
    pi@homebridge:~ $ sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys 8E61C2AB9A6D1557
    Warning: apt-key is deprecated. Manage keyring files in trusted.gpg.d instead (see apt-key(8)).
    Executing: /tmp/apt-key-gpghome.9TwcOtjpDI/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys 8E61C2AB9A6D1557
    gpg: key 31EB3981E723ACAA: "https://packagecloud.io/ookla/speedtest-cli (https://packagecloud.io/docs#gpg_signing) <support@packagecloud.io>" not changed
    gpg: Total number processed: 1
    gpg:              unchanged: 1
    pi@homebridge:~ $ sudo apt update
    Get:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease [15.0 kB]
    Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:3 https://packages.grafana.com/enterprise/deb stable InRelease
    Hit:4 https://repos.influxdata.com/debian bullseye InRelease
    Hit:5 https://deb.nodesource.com/node_12.x bullseye InRelease
    Get:6 https://packagecloud.io/ookla/speedtest-cli/debian bullseye InRelease [24.5 kB]
    Get:7 https://packagecloud.io/ookla/speedtest-cli/debian bullseye/main armhf Packages [988 B]
    Fetched 40.4 kB in 4s (10.6 kB/s)
    Reading package lists... Done
    All packages are up to date.
    pi@homebridge:~ $ sudo apt install speedtest
    The following NEW packages will be installed:
      speedtest
    0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
    Need to get 989 kB of archives.
    After this operation, 2,232 kB of additional disk space will be used.
    Get:1 https://packagecloud.io/ookla/speedtest-cli/debian bullseye/main armhf speedtest armhf 1.1.1.28-1.c732eb82cf [989 kB]
    Fetched 989 kB in 1s (973 kB/s)
    Selecting previously unselected package speedtest.
    (Reading database ... 62192 files and directories currently installed.)
    Preparing to unpack .../speedtest_1.1.1.28-1.c732eb82cf_armhf.deb ...
    Unpacking speedtest (1.1.1.28-1.c732eb82cf) ...
    Setting up speedtest (1.1.1.28-1.c732eb82cf) ...
    Processing triggers for man-db (2.9.4-2) ...
    pi@homebridge:~ $ curl -s https://install.speedtest.net/app/cli/install.deb.sh | sudo bash
    This distribution version is not currently supported via package management, please use the direct download builds per architecture found at https://www.speedtest.net/apps/cli
    pi@homebridge:~ $
    @damrak2022
    apt policy speedtest
      @damrak2022
      Damrak2022D Offline
      Damrak2022D Offline
      Damrak2022
      @thomas-braun sagte in Speedtest-Skript von kreyenborg.koeln für Kabel-Gigabit:
      Da kommt folgendes
      pi@homebridge:~ $ apt policy speedtest
      speedtest:
        Installed: 1.1.1.28-1.c732eb82cf
        Candidate: 1.1.1.28-1.c732eb82cf
        Version table:
       *** 1.1.1.28-1.c732eb82cf 500
              500 https://packagecloud.io/ookla/speedtest-cli/debian bullseye/main armhf Packages
           1.1.0.75-1.810304edbd 500
           1.0.0.2-1.5ae238b 500
      Danke für Deine Geduld
      Mit besten Grüßen
      Andy
        gpg:              unchanged: 1
          speedtest
        pi@homebridge:~ $
        @damrak2022
        Auf nodeJS@14 könntest du in jetzt in einem auch springen, wenn du eh die *.list files pflegst.
        In /etc/apt/sources.list.d/nodesource.list die 12 durch eine 14 ersetzen.
        Node12 erreicht in wenigen Tagen das EndOfLife.
        • NegaleinN Offline
          NegaleinN Offline
          Negalein
          #66
          Doch, gibt es wohl.
          Habe die Datei angepasst.
          # this file was generated by packagecloud.io for
          # the repository at https://packagecloud.io/ookla/speedtest-cli
          deb https://packagecloud.io/ookla/speedtest-cli/ubuntu/ jammy main
          deb-src https://packagecloud.io/ookla/speedtest-cli/ubuntu/ jammy bullseye main
          Dann
          sudo apt update
          Und da kommt dann
          nega@ioBroker:~$ sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys 8E61C2AB9A6D1557
          Executing: /tmp/apt-key-gpghome.ZjkZwFOrNP/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys 8E61C2AB9A6D1557
          gpg: key 31EB3981E723ACAA: public key "https://packagecloud.io/ookla/speedtest-cli (https://packagecloud.io/docs#gpg_signing) <support@packagecloud.io>" imported
          gpg:               imported: 1
          nega@ioBroker:~$ sudo apt update
          Hit:1 https://deb.nodesource.com/node_14.x focal InRelease
          Hit:2 http://archive.ubuntu.com/ubuntu focal InRelease
          Hit:3 http://archive.ubuntu.com/ubuntu focal-updates InRelease
          Hit:4 http://archive.ubuntu.com/ubuntu focal-security InRelease
          Ign:5 https://packagecloud.io/ookla/speedtest-cli/ubuntu jammy InRelease
          Err:6 https://packagecloud.io/ookla/speedtest-cli/ubuntu jammy Release
            404  Not Found [IP: 50.18.207.89 443]
          E: The repository 'https://packagecloud.io/ookla/speedtest-cli/ubuntu jammy Release' does not have a Release file.
          N: Updating from such a repository can't be done securely, and is therefore disabled by default.
          N: See apt-secure(8) manpage for repository creation and user configuration details.
          nega@ioBroker:~$ sudo apt install speedtest
          E: Unable to locate package speedtest
          nega@ioBroker:~$ nano /etc/apt/sources.list.d/ookla_speedtest-cli.list
          Script liefert immer noch
          09:32:13.219	error	javascript.0 (408896) script.js.Netzwerk.Speedtest: SyntaxError: Unexpected end of JSON input
          09:32:13.219	error	javascript.0 (408896) at generiere_array (script.js.Netzwerk.Speedtest:181:14)
          09:32:13.219	error	javascript.0 (408896) at script.js.Netzwerk.Speedtest:229:12
          09:32:13.342	error	host.ioBroker Caught by controller[0]: at generiere_array (script.js.Netzwerk.Speedtest:182:14)
          09:32:13.342	error	host.ioBroker Caught by controller[0]: at script.js.Netzwerk.Speedtest:230:12
          Speedtest funktioniert aber
          nega@ioBroker:~$ speedtest
          Retrieving speedtest.net configuration...
          Testing from Fonira Telekom GmbH (185.129.173.57)...
          Retrieving speedtest.net server list...
          Selecting best server based on ping...
          Hosted by Netprotect (Vienna) [214.89 km]: 13.606 ms
          Testing download speed................................................................................
          Download: 751.51 Mbit/s
          Testing upload speed......................................................................................................
          Upload: 85.11 Mbit/s
          nega@ioBroker:~$
          ° Fixer ---> iob fix
            Da kommt folgendes
            speedtest:
              Version table:
            #67
            @damrak2022
            Gut,
            speedtest
            ist also jetzt installiert und sollte Ergebnisse liefern.
            • NegaleinN Negalein
              Doch, gibt es wohl.
              Dann
              sudo apt update
              Und da kommt dann
              gpg:               imported: 1
              nega@ioBroker:~$
              #68
              @negalein sagte in Speedtest-Skript von kreyenborg.koeln für Kabel-Gigabit:
              Die Zeile ist falsch, das bullseye gehört raus.
              Offenbar ist das Repo aber noch nicht gefüllt, wie gesagt, Ubuntu 22.04 ist noch nicht offiziell freigegeben.
                @damrak2022
                Damrak2022D Offline
                Damrak2022D Offline
                Damrak2022
                #69
                Das wollte ich gerade machen, aber da bekomme ich das, oder muss ich da wieder irgendwo rein und wenn ja mit welchem Befehl?
                pi@homebridge:~ $ /etc/apt/sources.list.d/nodesource.list
                -bash: /etc/apt/sources.list.d/nodesource.list: Permission denied
                Mit besten Grüßen
                Andy
                  Doch, gibt es wohl.
                  Dann
                  sudo apt update
                  Und da kommt dann
                  gpg:               imported: 1
                  nega@ioBroker:~$
                  #70
                  Das ist aber soweit ich das sehe das alte/falsche speedtest.
                  sudo apt update
                  Damrak2022D NegaleinN 2 Antworten Letzte Antwort
                    #71
                    @damrak2022 sagte in Speedtest-Skript von kreyenborg.koeln für Kabel-Gigabit:
                    Das ist halt Quatsch. Du musst schon sagen, mit welchem Befehl du die Datei anpacken willst.
                    sudo nano /etc/apt/sources.list.d/nodesource.list
                    Wäre eine einfache Transferleistung, die /etc/apt/sources.list.d/ookla_speedtest-cli.list
                    hast du doch genauso angepackt.
                      sudo apt update
                      Damrak2022D Offline
                      Damrak2022D Offline
                      Damrak2022
                      #72
                      Jetzt sieht es so aus:
                      Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
                      Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                      Hit:6 https://packagecloud.io/ookla/speedtest-cli/debian bullseye InRelease
                      speedtest:
                        Version table:
                      pi@homebridge:~ $
                      Wieso kann ich mein node js nicht upgraden. Wieso habe ich hier Permission denied
                      Mit besten Grüßen
                      Andy
                        sudo apt update
                        NegaleinN Offline
                        NegaleinN Offline
                        Negalein
                        #73
                        sudo apt update
                          404  Not Found [IP: 184.72.30.82 443]
                        nega@ioBroker:~$ apt policy speedtest
                        N: Unable to locate package speedtest
                        nega@ioBroker:~$
                        also kann ich das Script derzeit nicht nutzen?
                          sudo apt update
                          nega@ioBroker:~$
                          #74
                          @negalein
                          Das ist auch wieder Kraut und Rüben...
                          Was hast du denn da nun? Focal (20.04) oder Jammy (22.04)
                          Die Releases dürfen nicht vermischt werden, das gibt nur Chaos.
                          Erstmal prüfen, wo du da überhaupt unterwegs bist:
                          lsb_release -a
                            @negalein
                            lsb_release -a
                            NegaleinN Offline
                            NegaleinN Offline
                            Negalein
                            #75
                            Upps sorry, meinte 20.04
                            nega@ioBroker:~$ lsb_release -a
                            No LSB modules are available.
                            Distributor ID: Ubuntu
                            Description:    Ubuntu 20.04.2 LTS
                            Release:        20.04
                            Codename:       focal
                              Release:        20.04
                              Codename:       focal
                              #76
                              @negalein
                              Dann muss das auch in den *.list-files focal lauten, nicht jammy.
                              Stell das richtig, dann
                              sudo apt update
                                @negalein
                                sudo apt update
                                NegaleinN Offline
                                NegaleinN Offline
                                Negalein
                                #77
                                dann
                                Get:3 http://archive.ubuntu.com/ubuntu focal-updates InRelease [114 kB]
                                Get:5 http://archive.ubuntu.com/ubuntu focal-security InRelease [114 kB]
                                Get:6 http://archive.ubuntu.com/ubuntu focal-updates/main amd64 Packages [1744 kB]
                                Get:7 http://archive.ubuntu.com/ubuntu focal-updates/universe amd64 Packages [918 kB]
                                Hit:4 https://packagecloud.io/ookla/speedtest-cli/ubuntu focal InRelease
                                Fetched 2891 kB in 2s (1669 kB/s)
                                154 packages can be upgraded. Run 'apt list --upgradable' to see them.
                                speedtest:
                                  Installed: (none)
                                  Version table:
                                        500 https://packagecloud.io/ookla/speedtest-cli/ubuntu focal/main amd64 Packages
                                  dann
                                  speedtest:
                                    Installed: (none)
                                    Version table:
                                  #78
                                  Bist du des Wahnsinns?
                                  Updaten, aber schnell!
                                  sudo apt full-upgrade
                                  sudo reboot
                                    speedtest:
                                      Version table:
                                    pi@homebridge:~ $
                                    Damrak2022D Offline
                                    Damrak2022D Offline
                                    Damrak2022
                                    #79
                                    @damrak2022 Jetzt so
                                    pi@homebridge:~ $ sudo nano /etc/apt/sources.list.d/nodesource.list
                                    Get:5 https://deb.nodesource.com/node_14.x bullseye InRelease [4,586 B]
                                    Get:7 https://deb.nodesource.com/node_14.x bullseye/main armhf Packages [780 B]
                                    Fetched 5,366 B in 2s (2,687 B/s)
                                    1 package can be upgraded. Run 'apt list --upgradable' to see it.
                                    speedtest:
                                      Version table:
                                    pi@homebridge:~ $ apt list --upgradable
                                    Listing... Done
                                    nodejs/unknown 14.19.1-deb-1nodesource1 armhf [upgradable from: 12.22.12-deb-1nodesource1]
                                    N: There are 2 additional versions. Please use the '-a' switch to see them.
                                    pi@homebridge:~ $
                                    Mit besten Grüßen
                                    Andy
                                      speedtest:
                                        Version table:
                                      Listing... Done
                                      pi@homebridge:~ $
                                      #80
                                      @damrak2022
                                      Ja, passt.
                                      iobroker stoppen, updates einspielen
                                      , iobroker wieder starten.
                                        sudo reboot
                                        NegaleinN Offline
                                        NegaleinN Offline
                                        Negalein
                                        #81
                                        Aye, aye, Käpt’n! ;)
                                        Und dann wie weiter?
                                          #82
                                          @negalein
                                          speedtest installieren? Das Repo passt ja nun.
