  4. Speedtest-Skript von kreyenborg.koeln für Kabel-Gigabit
    1.0k
    6.1k
391 Beiträge 33 Kommentatoren 105.1k Aufrufe 33 Beobachtet
  • NegaleinN Offline
    NegaleinN Offline
    Negalein
    #66
    @thomas-braun sagte in Speedtest-Skript von kreyenborg.koeln für Kabel-Gigabit:
    Doch, gibt es wohl.
    Habe die Datei angepasst.
    # this file was generated by packagecloud.io for
    # the repository at https://packagecloud.io/ookla/speedtest-cli
    deb https://packagecloud.io/ookla/speedtest-cli/ubuntu/ jammy main
    deb-src https://packagecloud.io/ookla/speedtest-cli/ubuntu/ jammy bullseye main
    Dann
    sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys 8E61C2AB9A6D1557
    sudo apt update
    sudo apt install speedtest
    Und da kommt dann
    nega@ioBroker:~$ sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys 8E61C2AB9A6D1557
    Executing: /tmp/apt-key-gpghome.ZjkZwFOrNP/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys 8E61C2AB9A6D1557
    gpg: key 31EB3981E723ACAA: public key "https://packagecloud.io/ookla/speedtest-cli (https://packagecloud.io/docs#gpg_signing) <support@packagecloud.io>" imported
    gpg: Total number processed: 1
    gpg:               imported: 1
    nega@ioBroker:~$ sudo apt update
    Hit:1 https://deb.nodesource.com/node_14.x focal InRelease
    Hit:2 http://archive.ubuntu.com/ubuntu focal InRelease
    Hit:3 http://archive.ubuntu.com/ubuntu focal-updates InRelease
    Hit:4 http://archive.ubuntu.com/ubuntu focal-security InRelease
    Ign:5 https://packagecloud.io/ookla/speedtest-cli/ubuntu jammy InRelease
    Err:6 https://packagecloud.io/ookla/speedtest-cli/ubuntu jammy Release
      404  Not Found [IP: 50.18.207.89 443]
    Reading package lists... Done
    E: The repository 'https://packagecloud.io/ookla/speedtest-cli/ubuntu jammy Release' does not have a Release file.
    N: Updating from such a repository can't be done securely, and is therefore disabled by default.
    N: See apt-secure(8) manpage for repository creation and user configuration details.
    nega@ioBroker:~$ sudo apt install speedtest
    Building dependency tree
    E: Unable to locate package speedtest
    nega@ioBroker:~$ nano /etc/apt/sources.list.d/ookla_speedtest-cli.list
    Script liefert immer noch
    09:32:13.219	error	javascript.0 (408896) script.js.Netzwerk.Speedtest: SyntaxError: Unexpected end of JSON input
    09:32:13.219	error	javascript.0 (408896) at generiere_array (script.js.Netzwerk.Speedtest:181:14)
    09:32:13.219	error	javascript.0 (408896) at script.js.Netzwerk.Speedtest:229:12
    09:32:13.342	error	host.ioBroker Caught by controller[0]: at generiere_array (script.js.Netzwerk.Speedtest:182:14)
    09:32:13.342	error	host.ioBroker Caught by controller[0]: at script.js.Netzwerk.Speedtest:230:12
    Speedtest funktioniert aber
    nega@ioBroker:~$ speedtest
    Retrieving speedtest.net configuration...
    Testing from Fonira Telekom GmbH (185.129.173.57)...
    Retrieving speedtest.net server list...
    Selecting best server based on ping...
    Hosted by Netprotect (Vienna) [214.89 km]: 13.606 ms
    Testing download speed................................................................................
    Download: 751.51 Mbit/s
    Testing upload speed......................................................................................................
    Upload: 85.11 Mbit/s
    nega@ioBroker:~$
    ° Fixer ---> iob fix
    • Damrak2022D Damrak2022
      apt policy speedtest
      Da kommt folgendes
      pi@homebridge:~ $ apt policy speedtest
      speedtest:
        Installed: 1.1.1.28-1.c732eb82cf
        Candidate: 1.1.1.28-1.c732eb82cf
        Version table:
       *** 1.1.1.28-1.c732eb82cf 500
              500 https://packagecloud.io/ookla/speedtest-cli/debian bullseye/main armhf Packages
           1.1.0.75-1.810304edbd 500
           1.0.0.2-1.5ae238b 500
      Danke für Deine Geduld
      #67
      @damrak2022
      Gut,
      speedtest
      ist also jetzt installiert und sollte Ergebnisse liefern.
      • NegaleinN Negalein
        Doch, gibt es wohl.
        Dann
        sudo apt update
        Und da kommt dann
        gpg:               imported: 1
        nega@ioBroker:~$
        #68
        @negalein sagte in Speedtest-Skript von kreyenborg.koeln für Kabel-Gigabit:
        Die Zeile ist falsch, das bullseye gehört raus.
        Offenbar ist das Repo aber noch nicht gefüllt, wie gesagt, Ubuntu 22.04 ist noch nicht offiziell freigegeben.
          @damrak2022
          Auf nodeJS@14 könntest du in jetzt in einem auch springen, wenn du eh die *.list files pflegst.
          In /etc/apt/sources.list.d/nodesource.list die 12 durch eine 14 ersetzen.
          Node12 erreicht in wenigen Tagen das EndOfLife.
          Damrak2022D Offline
          Damrak2022D Offline
          Damrak2022
          #69
          Das wollte ich gerade machen, aber da bekomme ich das, oder muss ich da wieder irgendwo rein und wenn ja mit welchem Befehl?
          pi@homebridge:~ $ /etc/apt/sources.list.d/nodesource.list
          -bash: /etc/apt/sources.list.d/nodesource.list: Permission denied
          Mit besten Grüßen
          Andy
            Doch, gibt es wohl.
            Dann
            sudo apt update
            Und da kommt dann
            gpg:               imported: 1
            nega@ioBroker:~$
            #70
            Das ist aber soweit ich das sehe das alte/falsche speedtest.
            sudo apt update
            Damrak2022D NegaleinN 2 Antworten Letzte Antwort
              #71
              @damrak2022 sagte in Speedtest-Skript von kreyenborg.koeln für Kabel-Gigabit:
              Das ist halt Quatsch. Du musst schon sagen, mit welchem Befehl du die Datei anpacken willst.
              sudo nano /etc/apt/sources.list.d/nodesource.list
              Wäre eine einfache Transferleistung, die /etc/apt/sources.list.d/ookla_speedtest-cli.list
              hast du doch genauso angepackt.
                sudo apt update
                Damrak2022D Offline
                Damrak2022D Offline
                Damrak2022
                #72
                Jetzt sieht es so aus:
                pi@homebridge:~ $ sudo apt update
                Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
                Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                Hit:3 https://packages.grafana.com/enterprise/deb stable InRelease
                Hit:4 https://repos.influxdata.com/debian bullseye InRelease
                Hit:5 https://deb.nodesource.com/node_12.x bullseye InRelease
                Hit:6 https://packagecloud.io/ookla/speedtest-cli/debian bullseye InRelease
                All packages are up to date.
                speedtest:
                  Version table:
                pi@homebridge:~ $
                Wieso kann ich mein node js nicht upgraden. Wieso habe ich hier Permission denied
                Mit besten Grüßen
                Andy
                  sudo apt update
                  NegaleinN Offline
                  NegaleinN Offline
                  Negalein
                  #73
                  sudo apt update
                    404  Not Found [IP: 184.72.30.82 443]
                  nega@ioBroker:~$ apt policy speedtest
                  N: Unable to locate package speedtest
                  nega@ioBroker:~$
                  also kann ich das Script derzeit nicht nutzen?
                    sudo apt update
                    nega@ioBroker:~$
                    #74
                    @negalein
                    Das ist auch wieder Kraut und Rüben...
                    Was hast du denn da nun? Focal (20.04) oder Jammy (22.04)
                    Die Releases dürfen nicht vermischt werden, das gibt nur Chaos.
                    Erstmal prüfen, wo du da überhaupt unterwegs bist:
                    lsb_release -a
                      @negalein
                      lsb_release -a
                      NegaleinN Offline
                      NegaleinN Offline
                      Negalein
                      #75
                      Upps sorry, meinte 20.04
                      nega@ioBroker:~$ lsb_release -a
                      No LSB modules are available.
                      Distributor ID: Ubuntu
                      Description:    Ubuntu 20.04.2 LTS
                      Release:        20.04
                      Codename:       focal
                        Release:        20.04
                        Codename:       focal
                        #76
                        @negalein
                        Dann muss das auch in den *.list-files focal lauten, nicht jammy.
                        Stell das richtig, dann
                        sudo apt update
                          @negalein
                          sudo apt update
                          NegaleinN Offline
                          NegaleinN Offline
                          Negalein
                          #77
                          dann
                          Get:3 http://archive.ubuntu.com/ubuntu focal-updates InRelease [114 kB]
                          Get:5 http://archive.ubuntu.com/ubuntu focal-security InRelease [114 kB]
                          Get:6 http://archive.ubuntu.com/ubuntu focal-updates/main amd64 Packages [1744 kB]
                          Get:7 http://archive.ubuntu.com/ubuntu focal-updates/universe amd64 Packages [918 kB]
                          Hit:4 https://packagecloud.io/ookla/speedtest-cli/ubuntu focal InRelease
                          Fetched 2891 kB in 2s (1669 kB/s)
                          154 packages can be upgraded. Run 'apt list --upgradable' to see them.
                          speedtest:
                            Installed: (none)
                            Version table:
                                  500 https://packagecloud.io/ookla/speedtest-cli/ubuntu focal/main amd64 Packages
                            dann
                            speedtest:
                              Installed: (none)
                              Version table:
                            #78
                            Bist du des Wahnsinns?
                            Updaten, aber schnell!
                            sudo apt full-upgrade
                            sudo reboot
                              speedtest:
                                Version table:
                              pi@homebridge:~ $
                              Damrak2022D Offline
                              Damrak2022D Offline
                              Damrak2022
                              #79
                              @damrak2022 Jetzt so
                              pi@homebridge:~ $ sudo nano /etc/apt/sources.list.d/nodesource.list
                              Get:5 https://deb.nodesource.com/node_14.x bullseye InRelease [4,586 B]
                              Get:7 https://deb.nodesource.com/node_14.x bullseye/main armhf Packages [780 B]
                              Fetched 5,366 B in 2s (2,687 B/s)
                              1 package can be upgraded. Run 'apt list --upgradable' to see it.
                              speedtest:
                                Version table:
                              pi@homebridge:~ $ apt list --upgradable
                              Listing... Done
                              nodejs/unknown 14.19.1-deb-1nodesource1 armhf [upgradable from: 12.22.12-deb-1nodesource1]
                              N: There are 2 additional versions. Please use the '-a' switch to see them.
                              pi@homebridge:~ $
                              Mit besten Grüßen
                              Andy
                                speedtest:
                                  Version table:
                                Listing... Done
                                pi@homebridge:~ $
                                #80
                                @damrak2022
                                Ja, passt.
                                iobroker stoppen, updates einspielen
                                , iobroker wieder starten.
                                  sudo reboot
                                  NegaleinN Offline
                                  NegaleinN Offline
                                  Negalein
                                  #81
                                  Aye, aye, Käpt’n! ;)
                                  Und dann wie weiter?
                                    #82
                                    @negalein
                                    speedtest installieren? Das Repo passt ja nun.
                                      #83
                                      Künftig REGELMÄSSIG das System auf Stand halten.
                                        @negalein
                                        NegaleinN Offline
                                        NegaleinN Offline
                                        Negalein
                                        #84
                                        [sudo] password for nega:
                                        The following package was automatically installed and is no longer required:
                                          libllvm11
                                        Use 'sudo apt autoremove' to remove it.
                                        The following NEW packages will be installed:
                                          speedtest
                                        0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
                                        Need to get 0 B/1055 kB of archives.
                                        After this operation, 2549 kB of additional disk space will be used.
                                        (Reading database ... 36354 files and directories currently installed.)
                                        Preparing to unpack .../speedtest_1.1.1.28-1.c732eb82cf_amd64.deb ...
                                        Unpacking speedtest (1.1.1.28-1.c732eb82cf) ...
                                        dpkg: error processing archive /var/cache/apt/archives/speedtest_1.1.1.28-1.c732eb82cf_amd64.deb (--unpack):
                                         trying to overwrite '/usr/bin/speedtest', which is also in package speedtest-cli 2.1.2-2ubuntu0.20.04.1
                                        dpkg-deb: error: paste subprocess was killed by signal (Broken pipe)
                                        Errors were encountered while processing:
                                        E: Sub-process /usr/bin/dpkg returned an error code (1)
                                        Hosted by Netprotect (Vienna) [214.89 km]: 13.237 ms
                                        Download: 743.13 Mbit/s
                                        Upload: 429.67 Mbit/s
                                            libllvm11
                                            speedtest
                                          #85
                                          sudo apt remove speedtest-cli
