  4. [gelöst] Alexa Adapter startet nach Update auf 3.10.4 nicht
    5.3k
103 Beiträge 6 Kommentatoren 12.0k Aufrufe 6 Beobachtet
  • SKBS SKB
    @apollon77
    pi@ioBroker:/opt/iobroker/node_modules/ws $ cd /opt/iobroker/node_modules/bufferutil/
    pi@ioBroker:/opt/iobroker/node_modules/bufferutil $ npm rebuild
    pi@ioBroker:/opt/iobroker/node_modules/bufferutil $ cd /opt/iobroker/node_modules/ws/node_modules/bufferutil/
    pi@ioBroker:/opt/iobroker/node_modules/ws/node_modules/bufferutil $ npm rebuild
    Ist das richtig, das da keine Ausgabe kommt?
    Soll ich nun den Adapter noch einmal starten? Via Instanz oder Shell?
    #81
    @skb hm ... ne keine ausgabe ist blöd. mach mal in beiden dirs ein "npm install --production"
    SKBS 1 Antwort Letzte Antwort
    • apollon77A apollon77
      SKBS Offline
      SKBS Offline
      SKB
      #82
      @apollon77 said in Alexa Adapter startet nach Update auf 3.10.4 nicht mehr:
      pi@ioBroker:/opt/iobroker/node_modules/ws/node_modules/bufferutil $ npm install --production
      > bufferutil@4.0.2 install /opt/iobroker/node_modules/ws/node_modules/bufferutil
      > node-gyp-build
      npm notice created a lockfile as package-lock.json. You should commit this file.
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.1 (node_modules/chokidar/node_modules/fsevents):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
      added 1 package from 1 contributor and audited 115 packages in 7.61s
      found 1 moderate severity vulnerability
        run `npm audit fix` to fix them, or `npm audit` for details
      und
      pi@ioBroker:/opt/iobroker/node_modules/bufferutil $ npm install --production
      npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
      npm WARN deprecated har-validator@5.1.5: this library is no longer supported
      npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
      npm WARN deprecated querystring@0.2.0: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
      > bufferutil@4.0.4 install /opt/iobroker/node_modules/bufferutil
      > node-gyp-build
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents):
      added 1 package from 1 contributor and audited 411 packages in 14.738s
      found 5 vulnerabilities (1 low, 3 moderate, 1 high)
      Irgendwie sieht das sehr strubbelig aus ^^
      Soll ich npm audit fix laufen lassen?
      • SKBS SKB
        > node-gyp-build
        und
        > node-gyp-build
        #83
        @skb nneee kein audit fix. versuch mal start
          SKBS Offline
          SKBS Offline
          SKB
          #84
          @apollon77 npm start? Oder?
          • SKBS SKB
            #85
            @skb einfach adapter restarten ... admin oder "iob restart alexa2" oder so ist egal
              SKBS Offline
              SKBS Offline
              SKB
              #86
              @apollon77
              host.ioBroker	2021-10-13 09:52:28.035	info	Restart adapter system.adapter.alexa2.0 because enabled
              host.ioBroker	2021-10-13 09:52:28.035	info	instance system.adapter.alexa2.0 terminated with code NaN ()
              host.ioBroker	2021-10-13 09:52:28.034	warn	instance system.adapter.alexa2.0 terminated due to SIGBUS
              Frage: Wie könnte sich jetzt etwas geändert haben, wenn dort oben soviele Fehlermeldungen auftauchen?
              • SKBS SKB
                @apollon77
                #87
                @skb Problem ist das ich oben das was ich sehen wollte nicht gesehen habe ... keine ahnung gerade mehr :-( @AlCalzone noch ne idee als workaround?
                • apollon77A Offline
                  #88
                  @SKB next try ...
                  Ansonsten: in den entsprechenden Verzeichnissen die Datei node.napi.armv7.node löschen, dann sollten keine nativen Sachen mehr aufgerufen werden können. Siehe auch GitHub Issue.
                  ... schau mal ob so ein File in den bufferutil verzeichnissen ist und wenn ja benenn mal um
                    @SKB next try ...
                    SKBS Offline
                    SKBS Offline
                    SKB
                    #89
                    @apollon77
                    pi@ioBroker:/opt/iobroker/node_modules/bufferutil $ ls
                    binding.gyp  fallback.js  index.js  LICENSE  node_modules  package.json  package-lock.json  prebuilds  README.md  src
                    pi@ioBroker:/opt/iobroker/node_modules/ws/node_modules/bufferutil $ ls
                    binding.gyp  build  fallback.js  index.js  LICENSE  node_modules  package.json  package-lock.json  prebuilds  README.md  src
                    Soweit ich das sehe, ist in keinem der Verzeichnisse diese Datei vorhanden.
                    Habe mal eine Suche durchgeführt:
                    pi@ioBroker:/opt/iobroker/node_modules/ws/node_modules/bufferutil $ sudo find / -type f -name "node.napi.armv7.node"
                    /opt/iobroker/node_modules/utf-8-validate/prebuilds/linux-arm/node.napi.armv7.node
                    /opt/iobroker/node_modules/bufferutil/prebuilds/linux-arm/node.napi.armv7.node
                    find: ‘/proc/21028/task/21028/net’: Das Argument ist ungültig
                    find: ‘/proc/21028/net’: Das Argument ist ungültig
                    /home/pi/node_modules/utf-8-validate/prebuilds/linux-arm/node.napi.armv7.node
                    /home/pi/node_modules/bufferutil/prebuilds/linux-arm/node.napi.armv7.node
                    Soll ich alle entfernen?
                    • SKBS SKB
                      @apollon77
                      #90
                      @skb die von bufferutil ja :-) Falls das net tut kann man die utf8-validate auch mal versuchen
                        SKBS Offline
                        SKBS Offline
                        SKB
                        #91
                        @apollon77
                        pi@ioBroker:/opt/iobroker/node_modules/ws/node_modules/bufferutil $ rm /home/pi/node_modules/utf-8-validate/prebuilds/linux-arm/node.napi.armv7.node
                        pi@ioBroker:/opt/iobroker/node_modules/ws/node_modules/bufferutil $ rm /home/pi/node_modules/bufferutil/prebuilds/linux-arm/node.napi.armv7.node
                        pi@ioBroker:/opt/iobroker/node_modules/ws/node_modules/bufferutil $ rm /opt/iobroker/node_modules/utf-8-validate/prebuilds/linux-arm/node.napi.armv7.node
                        pi@ioBroker:/opt/iobroker/node_modules/ws/node_modules/bufferutil $ rm /opt/iobroker/node_modules/bufferutil/prebuilds/linux-arm/node.napi.armv7.node
                        find: ‘/proc/21709/task/21709/net’: Das Argument ist ungültig
                        find: ‘/proc/21709/net’: Das Argument ist ungültig
                        find: ‘/proc/21723’: Datei oder Verzeichnis nicht gefunden
                        find: ‘/proc/21724’: Datei oder Verzeichnis nicht gefunden
                        find: ‘/proc/21725’: Datei oder Verzeichnis nicht gefunden
                        • SKBS SKB
                          @apollon77
                          #92
                          @skb Ok, hast dich alle weggeworfen :-)) dann versuch mal
                          • AlCalzoneA Offline
                            AlCalzoneA Offline
                            AlCalzone
                            #93
                            Ich würde mit npm ls bufferutil herausfinden, welche Module von bufferutil abhängen und in deren Ordnern npm i bufferutil@4.0.3 ausführen.
                              SKBS Offline
                              SKBS Offline
                              SKB
                              #94
                              @apollon77 Was soll ich sagen? ES GEHT !!!!
                              alexa2.0	2021-10-13 10:40:15.772	info	Subscribing to states...
                              alexa2.0	2021-10-13 10:39:56.739	info	Alexa-Push-Connection (macDms = true) established. Disable Polling
                              alexa2.0	2021-10-13 10:39:53.252	info	starting. Version 3.11.2 in /opt/iobroker/node_modules/iobroker.alexa2, node: v14.18.0, js-controller: 3.3.18
                              host.ioBroker	2021-10-13 10:39:51.417	info	instance system.adapter.alexa2.0 started with pid 21873
                              host.ioBroker	2021-10-13 10:39:50.497	info	"system.adapter.alexa2.0" enabled
                              Ist ja herrlich. DANKE !!!
                              Jetzt musst Du mir vielleicht nur noch erklären, was da los war ;)
                              • SKBS SKB
                                #95
                                @skb Naja eins der beiden Binär Module (die machen dinge nur ggf schneller und sind optional) haben ein problem gehabt ... welches der beiden ist jetzt eher schwierig zu finden weil Du beide gelöscht hast gg
                                  SKBS Offline
                                  SKBS Offline
                                  SKB
                                  #96
                                  @apollon77 Danke, das sagt mir jetzt nicht ganz so viel, da ich mit NPM eigentlich fast nichts zu tun habe.
                                  Wie sieht das nun in Zukunft aus, wenn sich das Zeug aktualisiert? Habe ich dann wieder ähnliche Themen?
                                  • SKBS SKB
                                    #97
                                    @skb Das wird sich zeigen ... das fixen hoffentlich die wo es herkommt
                                      SKBS Offline
                                      SKBS Offline
                                      SKB
                                      #98
                                      @apollon77 Prima, danke für deine Hilfe - die spiegelt sich gerade im Sponsor bei Git wieder ;)
                                      • SKBS SKB
                                        #99
                                        @skb Wow, danke!
                                          @skb Wow, danke!
                                          SKBS Offline
                                          SKBS Offline
                                          SKB
                                          #100
                                          @apollon77 Da nicht für. Ich habe ja mehr zu danken und als Zeichen meiner Verzweiflung :D
