  4. [HowTo] ioBroker unter Docker auf Synology DiskStation
    5.8k
iobrokerdockerbuanetsynologydiskstation
2.9k Beiträge 248 Kommentatoren 1.9m Aufrufe 123 Beobachtet
    ts020339
    #1921
    @andre
    Ich habe seit dem neuesten Image diese FEhlermeldung im Log:
    (node:479) [DEP0106] DeprecationWarning: crypto.createDecipher is deprecated.
    Sagt Dir das irgendetwas?
    Das einzige Problem, dass ich aktuell sehe, ist dass ich mit dem Ipad nicht mehr auf die ioBroker-Oberfläche zugreifen kann. Mit Android oder PC (Firefox) geht es weiterhin.
    Log:
    ---------------     2020-07-01 18:30:37      ---------------
    -----       Welcome to your ioBroker-container!        -----
    -----          Startupscript is now running.           -----
    -----                Please be patient!                -----
    -----              Debugging information               -----
    -----                      System                      -----
    -----               arch:      x86_64                  -----
    -----                     Versions                     -----
    -----               image:     v5.0.0                  -----
    -----               node:      v12.18.1                -----
    -----               npm:       6.14.5                  -----
    -----                       ENV                        -----
    -----               PACKAGES:  nano                   build-essential libcairo2-dev          libpango1.0-dev libjpeg-dev            libgif-dev librsvg2-dev            -----
    -----               SETGID:    1000                    -----
    -----               SETUID:    1000                    -----
    -----         Step 1 of 5: Preparing container         -----
    Installing additional packages is set by ENV.
    The following packages will be installed: nano build-essential libcairo2-dev libpango1.0-dev libjpeg-dev libgif-dev librsvg2-dev...
    Done.
    -----   Step 2 of 5: Detecting ioBroker installation   -----
    Existing installation of ioBroker detected in /opt/iobroker.
    -----   Step 3 of 5: Checking ioBroker installation    -----
    (Re)Setting folder permissions (This might take a while! Please be patient!)...
    Done.
    Fixing "sudo-bug" by replacing sudo in iobroker with gosu...
    Done.
    -----      Step 4 of 5: Applying special settings      -----
    Some adapters have special requirements/ settings which can be activated by the use of environment variables.
    For more information take a look at readme.md on Github!
    -----          Step 5 of 5: ioBroker startup           -----
    Starting ioBroker...
    host.ioBroker-Host check instance "system.adapter.admin.0" for host "ioBroker-Host"
    host.ioBroker-Host check instance "system.adapter.calendar.0" for host "ioBroker-Host"
    host.ioBroker-Host check instance "system.adapter.daswetter.0" for host "ioBroker-Host"
    host.ioBroker-Host check instance "system.adapter.fritzdect.0" for host "ioBroker-Host"
    host.ioBroker-Host check instance "system.adapter.harmony.0" for host "ioBroker-Host"
    host.ioBroker-Host check instance "system.adapter.hue.0" for host "ioBroker-Host"
    host.ioBroker-Host check instance "system.adapter.info.0" for host "ioBroker-Host"
    host.ioBroker-Host check instance "system.adapter.iqontrol.0" for host "ioBroker-Host"
    host.ioBroker-Host check instance "system.adapter.javascript.0" for host "ioBroker-Host"
    host.ioBroker-Host check instance "system.adapter.mihome-vacuum.0" for host "ioBroker-Host"
    host.ioBroker-Host check instance "system.adapter.mqtt.0" for host "ioBroker-Host"
    host.ioBroker-Host check instance "system.adapter.parser.0" for host "ioBroker-Host"
    host.ioBroker-Host check instance "system.adapter.ping.0" for host "ioBroker-Host"
    host.ioBroker-Host check instance "system.adapter.simple-api.0" for host "ioBroker-Host"
    host.ioBroker-Host check instance "system.adapter.snips.0" for host "ioBroker-Host"
    host.ioBroker-Host check instance "system.adapter.socketio.0" for host "ioBroker-Host"
    host.ioBroker-Host check instance "system.adapter.text2command.0" for host "ioBroker-Host"
    host.ioBroker-Host check instance "system.adapter.vis-bars.0" for host "ioBroker-Host"
    host.ioBroker-Host check instance "system.adapter.vis-history.0" for host "ioBroker-Host"
    host.ioBroker-Host check instance "system.adapter.vis-hqwidgets.0" for host "ioBroker-Host"
    host.ioBroker-Host check instance "system.adapter.vis-jqui-mfd.0" for host "ioBroker-Host"
    host.ioBroker-Host check instance "system.adapter.vis-justgage.0" for host "ioBroker-Host"
    host.ioBroker-Host check instance "system.adapter.vis-metro.0" for host "ioBroker-Host"
    host.ioBroker-Host check instance "system.adapter.vis-players.0" for host "ioBroker-Host"
    host.ioBroker-Host check instance "system.adapter.vis-timeandweather.0" for host "ioBroker-Host"
    host.ioBroker-Host check instance "system.adapter.vis.0" for host "ioBroker-Host"
    host.ioBroker-Host check instance "system.adapter.web.0" for host "ioBroker-Host"
    host.ioBroker-Host check instance "system.adapter.zigbee.1" for host "ioBroker_Client_HomeAutomation"
    host.ioBroker-Host check instance "system.adapter.backitup.0" for host "ioBroker-Host"
    host.ioBroker-Host check instance "system.adapter.backitup.1" for host "ioBroker_Client_HomeAutomation"
    Cannot parse "/Wettericons/vis-views.json
    hash changed or no sources cached => force download of new sources
    andreA 1 Antwort Letzte Antwort
    • T ts020339
      @andre
      Log:
      -----                      System                      -----
      -----                       ENV                        -----
      Done.
      Done.
      Done.
      andreA Offline
      andreA Offline
      andre
      #1922
      @ts020339 Ich würde das jetzt mal als ioBroker spezifische Probleme sehen. Sehe da aktuell keinen Zusammenhang mit dem Image...
      MfG,
      André
      Bitte keine Support-Fragen per PN! Nutzt die öffentliche Kanäle damit auch andere von den Antworten profitieren können!
      • Amnesia1211A Offline
        Amnesia1211
        #1923
        @andre
        Die "latest" Version läuft jetzt seit ein paar tagen auf meinem Aktiv System und das ohne Probleme.
        Danke wieder für deine tolle Arbeit und mühe !!!! Mach weiter so
        Man muss nicht alles wissen, nur wissen wo es steht.
        Fragen schadet aber auch nicht :spock-hand:
        K 1 Antwort Letzte Antwort
        • Amnesia1211A Amnesia1211
          @andre
          K_o_bold
          #1924
          @Amnesia1211 ,@andre,
          dem kann ich mich nur anschließen.
          Vielen Dank für dein Arbeit...läuft alles sehr stabil
          • FoodFighterF Offline
            FoodFighter
            schrieb am zuletzt editiert von FoodFighter
            #1925
            Hallo Jungs,
            bei mir macht das Update auch Probleme - im Sinne von "funktioniert nicht".
            Streng nach "best practice" habe ich folgendes gemacht:
            1. Backup über den BackItUp-Adapter
            2. iobroker-Container gestoppt
            3. den Ordner iobrokerdata umbenannt
              mv iobrokerdata iobrokerdata_OLD
            4. Neuen Ordner iobrokerdata angelegt
              mkdir iobrokerdata
            5. Backup in den leeren iobrokerdata-Ordner kopiert
              cp /home/pi/iobroker/iobrokerdata_OLD/backup/iobroker_2020_07_04-10_28_48_backupiobroker.tar.gz /home/pi/iobroker/iobrokerdata/
            6. über Portainer den iobroker-Container ausgewählt -> Recreate -> Pull latest image
            7. Log verfolgt und geduldig sein
            Scheinbar geht da was beim Laden das Backups schief, denn die
            /opt/iobroker/log/restore.log
            gibt folgendes aus:
            host.iobroker Using backup file iobroker_2020_07_04-10_28_48_backupiobroker.tar.gz
            host.iobroker Cannot find extracted file from file "/opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/backup.json"
            Hier die Container-Log:
            ---------------     2020-07-04 11:22:49      ---------------,
            -----       Welcome to your ioBroker-container!        -----,
            -----          Startupscript is now running.           -----,
            -----                Please be patient!                -----,
            -----              Debugging information               -----,
            -----                      System                      -----,
            -----               arch:      armv7l                  -----,
            -----                     Versions                     -----,
            -----               image:     v5.0.0                  -----,
            -----               node:      v12.18.1                -----,
            -----               npm:       6.14.5                  -----,
            -----                       ENV                        -----,
            -----               PACKAGES:  vim                    nano       build-essential        libcairo2-dev libpango1.0-dev        libjpeg-dev libgif-dev             librsvg2-dev                         -----,
            -----               SETGID:    1000                    -----,
            -----               SETUID:    1000                    -----,
            -----               USBDEVICES: /dev/ttyACM0            -----,
            -----         Step 1 of 5: Preparing container         -----,
            Installing additional packages is set by ENV.,
            The following packages will be installed: vim nano build-essential libcairo2-dev libpango1.0-dev libjpeg-dev libgif-dev librsvg2-dev...,
            W: Failed to fetch https://deb.nodesource.com/node_12.x/dists/buster/InRelease  Temporary failure resolving 'deb.nodesource.com',
            W: Some index files failed to download. They have been ignored, or old ones used instead.,
            debconf: unable to initialize frontend: Dialog,
            debconf: (Dialog frontend will not work on a dumb terminal, an emacs shell buffer, or without a controlling terminal.),
            debconf: falling back to frontend: Readline,
            debconf: unable to initialize frontend: Readline,
            debconf: (This frontend requires a controlling tty.),
            debconf: falling back to frontend: Teletype,
            dpkg-preconfigure: unable to re-open stdin: ,
            Selecting previously unselected package xxd.
            (Reading database ...
            (Reading database ... 5%
            (Reading database ... 10%
            (Reading database ... 15%
            (Reading database ... 20%
            (Reading database ... 25%
            (Reading database ... 30%
            (Reading database ... 35%
            (Reading database ... 40%
            (Reading database ... 45%
            (Reading database ... 50%
            (Reading database ... 55%
            (Reading database ... 60%
            (Reading database ... 65%
            (Reading database ... 70%
            (Reading database ... 75%
            (Reading database ... 80%
            (Reading database ... 85%
            (Reading database ... 90%
            (Reading database ... 95%
            (Reading database ... 100%
            (Reading database ... 21711 files and directories currently installed.)
            Preparing to unpack .../xxd_2%3a8.1.0875-5_armhf.deb ...
            Unpacking xxd (2:8.1.0875-5) ...
            Selecting previously unselected package vim-common.
            Preparing to unpack .../vim-common_2%3a8.1.0875-5_all.deb ...
            Unpacking vim-common (2:8.1.0875-5) ...
            Selecting previously unselected package libgpm2:armhf.
            Preparing to unpack .../libgpm2_1.20.7-5_armhf.deb ...
            Unpacking libgpm2:armhf (1.20.7-5) ...
            Selecting previously unselected package vim-runtime.
            Preparing to unpack .../vim-runtime_2%3a8.1.0875-5_all.deb ...
            Adding 'diversion of /usr/share/vim/vim81/doc/help.txt to /usr/share/vim/vim81/doc/help.txt.vim-tiny by vim-runtime'
            Adding 'diversion of /usr/share/vim/vim81/doc/tags to /usr/share/vim/vim81/doc/tags.vim-tiny by vim-runtime'
            Unpacking vim-runtime (2:8.1.0875-5) ...
            Selecting previously unselected package vim.
            Preparing to unpack .../vim_2%3a8.1.0875-5_armhf.deb ...
            Unpacking vim (2:8.1.0875-5) ...
            Setting up libgpm2:armhf (1.20.7-5) ...
            Setting up xxd (2:8.1.0875-5) ...
            Setting up vim-common (2:8.1.0875-5) ...
            Setting up vim-runtime (2:8.1.0875-5) ...
            Setting up vim (2:8.1.0875-5) ...
            update-alternatives: using /usr/bin/vim.basic to provide /usr/bin/vim (vim) in auto mode
            update-alternatives: using /usr/bin/vim.basic to provide /usr/bin/vimdiff (vimdiff) in auto mode
            update-alternatives: using /usr/bin/vim.basic to provide /usr/bin/rvim (rvim) in auto mode
            update-alternatives: using /usr/bin/vim.basic to provide /usr/bin/rview (rview) in auto mode
            update-alternatives: using /usr/bin/vim.basic to provide /usr/bin/vi (vi) in auto mode
            update-alternatives: warning: skip creation of /usr/share/man/da/man1/vi.1.gz because associated file /usr/share/man/da/man1/vim.1.gz (of link group vi) doesn't exist
            update-alternatives: warning: skip creation of /usr/share/man/de/man1/vi.1.gz because associated file /usr/share/man/de/man1/vim.1.gz (of link group vi) doesn't exist
            update-alternatives: warning: skip creation of /usr/share/man/fr/man1/vi.1.gz because associated file /usr/share/man/fr/man1/vim.1.gz (of link group vi) doesn't exist
            update-alternatives: warning: skip creation of /usr/share/man/it/man1/vi.1.gz because associated file /usr/share/man/it/man1/vim.1.gz (of link group vi) doesn't exist
            update-alternatives: warning: skip creation of /usr/share/man/ja/man1/vi.1.gz because associated file /usr/share/man/ja/man1/vim.1.gz (of link group vi) doesn't exist
            update-alternatives: warning: skip creation of /usr/share/man/pl/man1/vi.1.gz because associated file /usr/share/man/pl/man1/vim.1.gz (of link group vi) doesn't exist
            update-alternatives: warning: skip creation of /usr/share/man/ru/man1/vi.1.gz because associated file /usr/share/man/ru/man1/vim.1.gz (of link group vi) doesn't exist
            update-alternatives: warning: skip creation of /usr/share/man/man1/vi.1.gz because associated file /usr/share/man/man1/vim.1.gz (of link group vi) doesn't exist
            update-alternatives: using /usr/bin/vim.basic to provide /usr/bin/view (view) in auto mode
            update-alternatives: warning: skip creation of /usr/share/man/da/man1/view.1.gz because associated file /usr/share/man/da/man1/vim.1.gz (of link group view) doesn't exist
            update-alternatives: warning: skip creation of /usr/share/man/de/man1/view.1.gz because associated file /usr/share/man/de/man1/vim.1.gz (of link group view) doesn't exist
            update-alternatives: warning: skip creation of /usr/share/man/fr/man1/view.1.gz because associated file /usr/share/man/fr/man1/vim.1.gz (of link group view) doesn't exist
            update-alternatives: warning: skip creation of /usr/share/man/it/man1/view.1.gz because associated file /usr/share/man/it/man1/vim.1.gz (of link group view) doesn't exist
            update-alternatives: warning: skip creation of /usr/share/man/ja/man1/view.1.gz because associated file /usr/share/man/ja/man1/vim.1.gz (of link group view) doesn't exist
            update-alternatives: warning: skip creation of /usr/share/man/pl/man1/view.1.gz because associated file /usr/share/man/pl/man1/vim.1.gz (of link group view) doesn't exist
            update-alternatives: warning: skip creation of /usr/share/man/ru/man1/view.1.gz because associated file /usr/share/man/ru/man1/vim.1.gz (of link group view) doesn't exist
            update-alternatives: warning: skip creation of /usr/share/man/man1/view.1.gz because associated file /usr/share/man/man1/vim.1.gz (of link group view) doesn't exist
            update-alternatives: using /usr/bin/vim.basic to provide /usr/bin/ex (ex) in auto mode
            update-alternatives: warning: skip creation of /usr/share/man/da/man1/ex.1.gz because associated file /usr/share/man/da/man1/vim.1.gz (of link group ex) doesn't exist
            update-alternatives: warning: skip creation of /usr/share/man/de/man1/ex.1.gz because associated file /usr/share/man/de/man1/vim.1.gz (of link group ex) doesn't exist
            update-alternatives: warning: skip creation of /usr/share/man/fr/man1/ex.1.gz because associated file /usr/share/man/fr/man1/vim.1.gz (of link group ex) doesn't exist
            update-alternatives: warning: skip creation of /usr/share/man/it/man1/ex.1.gz because associated file /usr/share/man/it/man1/vim.1.gz (of link group ex) doesn't exist
            update-alternatives: warning: skip creation of /usr/share/man/ja/man1/ex.1.gz because associated file /usr/share/man/ja/man1/vim.1.gz (of link group ex) doesn't exist
            update-alternatives: warning: skip creation of /usr/share/man/pl/man1/ex.1.gz because associated file /usr/share/man/pl/man1/vim.1.gz (of link group ex) doesn't exist
            update-alternatives: warning: skip creation of /usr/share/man/ru/man1/ex.1.gz because associated file /usr/share/man/ru/man1/vim.1.gz (of link group ex) doesn't exist
            update-alternatives: warning: skip creation of /usr/share/man/man1/ex.1.gz because associated file /usr/share/man/man1/vim.1.gz (of link group ex) doesn't exist
            update-alternatives: using /usr/bin/vim.basic to provide /usr/bin/editor (editor) in auto mode
            update-alternatives: warning: skip creation of /usr/share/man/da/man1/editor.1.gz because associated file /usr/share/man/da/man1/vim.1.gz (of link group editor) doesn't exist
            update-alternatives: warning: skip creation of /usr/share/man/de/man1/editor.1.gz because associated file /usr/share/man/de/man1/vim.1.gz (of link group editor) doesn't exist
            update-alternatives: warning: skip creation of /usr/share/man/fr/man1/editor.1.gz because associated file /usr/share/man/fr/man1/vim.1.gz (of link group editor) doesn't exist
            update-alternatives: warning: skip creation of /usr/share/man/it/man1/editor.1.gz because associated file /usr/share/man/it/man1/vim.1.gz (of link group editor) doesn't exist
            update-alternatives: warning: skip creation of /usr/share/man/ja/man1/editor.1.gz because associated file /usr/share/man/ja/man1/vim.1.gz (of link group editor) doesn't exist
            update-alternatives: warning: skip creation of /usr/share/man/pl/man1/editor.1.gz because associated file /usr/share/man/pl/man1/vim.1.gz (of link group editor) doesn't exist
            update-alternatives: warning: skip creation of /usr/share/man/ru/man1/editor.1.gz because associated file /usr/share/man/ru/man1/vim.1.gz (of link group editor) doesn't exist
            update-alternatives: warning: skip creation of /usr/share/man/man1/editor.1.gz because associated file /usr/share/man/man1/vim.1.gz (of link group editor) doesn't exist
            Processing triggers for libc-bin (2.28-10) ...
            Processing triggers for mime-support (3.62) ...
            Selecting previously unselected package nano.
            (Reading database ... 23606 files and directories currently installed.)
            Preparing to unpack .../archives/nano_3.2-3_armhf.deb ...
            Unpacking nano (3.2-3) ...
            Setting up nano (3.2-3) ...
            update-alternatives: using /bin/nano to provide /usr/bin/editor (editor) in auto mode
            update-alternatives: warning: skip creation of /usr/share/man/man1/editor.1.gz because associated file /usr/share/man/man1/nano.1.gz (of link group editor) doesn't exist
            update-alternatives: using /bin/nano to provide /usr/bin/pico (pico) in auto mode
            update-alternatives: warning: skip creation of /usr/share/man/man1/pico.1.gz because associated file /usr/share/man/man1/nano.1.gz (of link group pico) doesn't exist
            Selecting previously unselected package sensible-utils.
            (Reading database ... 23708 files and directories currently installed.)
            Preparing to unpack .../00-sensible-utils_0.0.12_all.deb ...
            Unpacking sensible-utils (0.0.12) ...
            Selecting previously unselected package ucf.
            Preparing to unpack .../01-ucf_3.0038+nmu1_all.deb ...
            Moving old data out of the way
            Unpacking ucf (3.0038+nmu1) ...
            Selecting previously unselected package fonts-dejavu-core.
            Preparing to unpack .../02-fonts-dejavu-core_2.37-1_all.deb ...
            Unpacking fonts-dejavu-core (2.37-1) ...
            Selecting previously unselected package fontconfig-config.
            Preparing to unpack .../03-fontconfig-config_2.13.1-2_all.deb ...
            Unpacking fontconfig-config (2.13.1-2) ...
            Selecting previously unselected package uuid-dev:armhf.
            Preparing to unpack .../04-uuid-dev_2.33.1-0.1_armhf.deb ...
            Unpacking uuid-dev:armhf (2.33.1-0.1) ...
            Selecting previously unselected package libblkid-dev:armhf.
            Preparing to unpack .../05-libblkid-dev_2.33.1-0.1_armhf.deb ...
            Unpacking libblkid-dev:armhf (2.33.1-0.1) ...
            Selecting previously unselected package libbsd0:armhf.
            Preparing to unpack .../06-libbsd0_0.9.1-2_armhf.deb ...
            Unpacking libbsd0:armhf (0.9.1-2) ...
            Selecting previously unselected package libpng16-16:armhf.
            Preparing to unpack .../07-libpng16-16_1.6.36-6_armhf.deb ...
            Unpacking libpng16-16:armhf (1.6.36-6) ...
            Selecting previously unselected package libfreetype6:armhf.
            Preparing to unpack .../08-libfreetype6_2.9.1-3+deb10u1_armhf.deb ...
            Unpacking libfreetype6:armhf (2.9.1-3+deb10u1) ...
            Selecting previously unselected package libfontconfig1:armhf.
            Preparing to unpack .../09-libfontconfig1_2.13.1-2_armhf.deb ...
            Unpacking libfontconfig1:armhf (2.13.1-2) ...
            Selecting previously unselected package libpixman-1-0:armhf.
            Preparing to unpack .../10-libpixman-1-0_0.36.0-1_armhf.deb ...
            Unpacking libpixman-1-0:armhf (0.36.0-1) ...
            Selecting previously unselected package libxau6:armhf.
            Preparing to unpack .../11-libxau6_1%3a1.0.8-1+b2_armhf.deb ...
            Unpacking libxau6:armhf (1:1.0.8-1+b2) ...
            Selecting previously unselected package libxdmcp6:armhf.
            Preparing to unpack .../12-libxdmcp6_1%3a1.1.2-3_armhf.deb ...
            Unpacking libxdmcp6:armhf (1:1.1.2-3) ...
            Selecting previously unselected package libxcb1:armhf.
            Preparing to unpack .../13-libxcb1_1.13.1-2_armhf.deb ...
            Unpacking libxcb1:armhf (1.13.1-2) ...
            Selecting previously unselected package libx11-data.
            Preparing to unpack .../14-libx11-data_2%3a1.6.7-1_all.deb ...
            Unpacking libx11-data (2:1.6.7-1) ...
            Selecting previously unselected package libx11-6:armhf.
            Preparing to unpack .../15-libx11-6_2%3a1.6.7-1_armhf.deb ...
            Unpacking libx11-6:armhf (2:1.6.7-1) ...
            Selecting previously unselected package libxcb-render0:armhf.
            Preparing to unpack .../16-libxcb-render0_1.13.1-2_armhf.deb ...
            Unpacking libxcb-render0:armhf (1.13.1-2) ...
            Selecting previously unselected package libxcb-shm0:armhf.
            Preparing to unpack .../17-libxcb-shm0_1.13.1-2_armhf.deb ...
            Unpacking libxcb-shm0:armhf (1.13.1-2) ...
            Selecting previously unselected package libxext6:armhf.
            Preparing to unpack .../18-libxext6_2%3a1.3.3-1+b2_armhf.deb ...
            Unpacking libxext6:armhf (2:1.3.3-1+b2) ...
            Selecting previously unselected package libxrender1:armhf.
            Preparing to unpack .../19-libxrender1_1%3a0.9.10-1_armhf.deb ...
            Unpacking libxrender1:armhf (1:0.9.10-1) ...
            Selecting previously unselected package libcairo2:armhf.
            Preparing to unpack .../20-libcairo2_1.16.0-4_armhf.deb ...
            Unpacking libcairo2:armhf (1.16.0-4) ...
            Selecting previously unselected package libcairo-gobject2:armhf.
            Preparing to unpack .../21-libcairo-gobject2_1.16.0-4_armhf.deb ...
            Unpacking libcairo-gobject2:armhf (1.16.0-4) ...
            Selecting previously unselected package liblzo2-2:armhf.
            Preparing to unpack .../22-liblzo2-2_2.10-0.1_armhf.deb ...
            Unpacking liblzo2-2:armhf (2.10-0.1) ...
            Selecting previously unselected package libcairo-script-interpreter2:armhf.
            Preparing to unpack .../23-libcairo-script-interpreter2_1.16.0-4_armhf.deb ...
            Unpacking libcairo-script-interpreter2:armhf (1.16.0-4) ...
            Selecting previously unselected package zlib1g-dev:armhf.
            Preparing to unpack .../24-zlib1g-dev_1%3a1.2.11.dfsg-1_armhf.deb ...
            Unpacking zlib1g-dev:armhf (1:1.2.11.dfsg-1) ...
            Selecting previously unselected package libpng-dev:armhf.
            Preparing to unpack .../25-libpng-dev_1.6.36-6_armhf.deb ...
            Unpacking libpng-dev:armhf (1.6.36-6) ...
            Selecting previously unselected package libfreetype6-dev:armhf.
            Preparing to unpack .../26-libfreetype6-dev_2.9.1-3+deb10u1_armhf.deb ...
            Unpacking libfreetype6-dev:armhf (2.9.1-3+deb10u1) ...
            Selecting previously unselected package libfontconfig1-dev:armhf.
            Preparing to unpack .../27-libfontconfig1-dev_2.13.1-2_armhf.deb ...
            Unpacking libfontconfig1-dev:armhf (2.13.1-2) ...
            Selecting previously unselected package xorg-sgml-doctools.
            Preparing to unpack .../28-xorg-sgml-doctools_1%3a1.11-1_all.deb ...
            Unpacking xorg-sgml-doctools (1:1.11-1) ...
            Selecting previously unselected package x11proto-dev.
            Preparing to unpack .../29-x11proto-dev_2018.4-4_all.deb ...
            Unpacking x11proto-dev (2018.4-4) ...
            Selecting previously unselected package x11proto-core-dev.
            Preparing to unpack .../30-x11proto-core-dev_2018.4-4_all.deb ...
            Unpacking x11proto-core-dev (2018.4-4) ...
            Selecting previously unselected package libxau-dev:armhf.
            Preparing to unpack .../31-libxau-dev_1%3a1.0.8-1+b2_armhf.deb ...
            Unpacking libxau-dev:armhf (1:1.0.8-1+b2) ...
            Selecting previously unselected package libxdmcp-dev:armhf.
            Preparing to unpack .../32-libxdmcp-dev_1%3a1.1.2-3_armhf.deb ...
            Unpacking libxdmcp-dev:armhf (1:1.1.2-3) ...
            Selecting previously unselected package xtrans-dev.
            Preparing to unpack .../33-xtrans-dev_1.3.5-1_all.deb ...
            Unpacking xtrans-dev (1.3.5-1) ...
            Selecting previously unselected package libpthread-stubs0-dev:armhf.
            Preparing to unpack .../34-libpthread-stubs0-dev_0.4-1_armhf.deb ...
            Unpacking libpthread-stubs0-dev:armhf (0.4-1) ...
            Selecting previously unselected package libxcb1-dev:armhf.
            Preparing to unpack .../35-libxcb1-dev_1.13.1-2_armhf.deb ...
            Unpacking libxcb1-dev:armhf (1.13.1-2) ...
            Selecting previously unselected package libx11-dev:armhf.
            Preparing to unpack .../36-libx11-dev_2%3a1.6.7-1_armhf.deb ...
            Unpacking libx11-dev:armhf (2:1.6.7-1) ...
            Selecting previously unselected package libxrender-dev:armhf.
            Preparing to unpack .../37-libxrender-dev_1%3a0.9.10-1_armhf.deb ...
            Unpacking libxrender-dev:armhf (1:0.9.10-1) ...
            Selecting previously unselected package x11proto-xext-dev.
            Preparing to unpack .../38-x11proto-xext-dev_2018.4-4_all.deb ...
            Unpacking x11proto-xext-dev (2018.4-4) ...
            Selecting previously unselected package libxext-dev:armhf.
            Preparing to unpack .../39-libxext-dev_2%3a1.3.3-1+b2_armhf.deb ...
            Unpacking libxext-dev:armhf (2:1.3.3-1+b2) ...
            Selecting previously unselected package x11-common.
            Preparing to unpack .../40-x11-common_1%3a7.7+19_all.deb ...
            Unpacking x11-common (1:7.7+19) ...
            Selecting previously unselected package libice6:armhf.
            Preparing to unpack .../41-libice6_2%3a1.0.9-2_armhf.deb ...
            Unpacking libice6:armhf (2:1.0.9-2) ...
            Selecting previously unselected package libsm6:armhf.
            Preparing to unpack .../42-libsm6_2%3a1.2.3-1_armhf.deb ...
            Unpacking libsm6:armhf (2:1.2.3-1) ...
            Selecting previously unselected package libice-dev:armhf.
            Preparing to unpack .../43-libice-dev_2%3a1.0.9-2_armhf.deb ...
            Unpacking libice-dev:armhf (2:1.0.9-2) ...
            Selecting previously unselected package libsm-dev:armhf.
            Preparing to unpack .../44-libsm-dev_2%3a1.2.3-1_armhf.deb ...
            Unpacking libsm-dev:armhf (2:1.2.3-1) ...
            Selecting previously unselected package libpixman-1-dev:armhf.
            Preparing to unpack .../45-libpixman-1-dev_0.36.0-1_armhf.deb ...
            Unpacking libpixman-1-dev:armhf (0.36.0-1) ...
            Selecting previously unselected package libxcb-render0-dev:armhf.
            Preparing to unpack .../46-libxcb-render0-dev_1.13.1-2_armhf.deb ...
            Unpacking libxcb-render0-dev:armhf (1.13.1-2) ...
            Selecting previously unselected package libxcb-shm0-dev:armhf.
            Preparing to unpack .../47-libxcb-shm0-dev_1.13.1-2_armhf.deb ...
            Unpacking libxcb-shm0-dev:armhf (1.13.1-2) ...
            Selecting previously unselected package libffi-dev:armhf.
            Preparing to unpack .../48-libffi-dev_3.2.1-9_armhf.deb ...
            Unpacking libffi-dev:armhf (3.2.1-9) ...
            Selecting previously unselected package libglib2.0-data.
            Preparing to unpack .../49-libglib2.0-data_2.58.3-2+deb10u2_all.deb ...
            Unpacking libglib2.0-data (2.58.3-2+deb10u2) ...
            Selecting previously unselected package libglib2.0-bin.
            Preparing to unpack .../50-libglib2.0-bin_2.58.3-2+deb10u2_armhf.deb ...
            Unpacking libglib2.0-bin (2.58.3-2+deb10u2) ...
            Selecting previously unselected package python3-lib2to3.
            Preparing to unpack .../51-python3-lib2to3_3.7.3-1_all.deb ...
            Unpacking python3-lib2to3 (3.7.3-1) ...
            Selecting previously unselected package python3-distutils.
            Preparing to unpack .../52-python3-distutils_3.7.3-1_all.deb ...
            Unpacking python3-distutils (3.7.3-1) ...
            Selecting previously unselected package libglib2.0-dev-bin.
            Preparing to unpack .../53-libglib2.0-dev-bin_2.58.3-2+deb10u2_armhf.deb ...
            Unpacking libglib2.0-dev-bin (2.58.3-2+deb10u2) ...
            Selecting previously unselected package libmount-dev:armhf.
            Preparing to unpack .../54-libmount-dev_2.33.1-0.1_armhf.deb ...
            Unpacking libmount-dev:armhf (2.33.1-0.1) ...
            Selecting previously unselected package libpcre16-3:armhf.
            Preparing to unpack .../55-libpcre16-3_2%3a8.39-12_armhf.deb ...
            Unpacking libpcre16-3:armhf (2:8.39-12) ...
            Selecting previously unselected package libpcre32-3:armhf.
            Preparing to unpack .../56-libpcre32-3_2%3a8.39-12_armhf.deb ...
            Unpacking libpcre32-3:armhf (2:8.39-12) ...
            Selecting previously unselected package libpcrecpp0v5:armhf.
            Preparing to unpack .../57-libpcrecpp0v5_2%3a8.39-12_armhf.deb ...
            Unpacking libpcrecpp0v5:armhf (2:8.39-12) ...
            Selecting previously unselected package libpcre3-dev:armhf.
            Preparing to unpack .../58-libpcre3-dev_2%3a8.39-12_armhf.deb ...
            Unpacking libpcre3-dev:armhf (2:8.39-12) ...
            Selecting previously unselected package libsepol1-dev:armhf.
            Preparing to unpack .../59-libsepol1-dev_2.8-1_armhf.deb ...
            Unpacking libsepol1-dev:armhf (2.8-1) ...
            Selecting previously unselected package libselinux1-dev:armhf.
            Preparing to unpack .../60-libselinux1-dev_2.8-1+b1_armhf.deb ...
            Unpacking libselinux1-dev:armhf (2.8-1+b1) ...
            Selecting previously unselected package libglib2.0-dev:armhf.
            Preparing to unpack .../61-libglib2.0-dev_2.58.3-2+deb10u2_armhf.deb ...
            Unpacking libglib2.0-dev:armhf (2.58.3-2+deb10u2) ...
            Selecting previously unselected package libcairo2-dev:armhf.
            Preparing to unpack .../62-libcairo2-dev_1.16.0-4_armhf.deb ...
            Unpacking libcairo2-dev:armhf (1.16.0-4) ...
            Setting up libpcrecpp0v5:armhf (2:8.39-12) ...
            Setting up libpixman-1-0:armhf (0.36.0-1) ...
            Setting up libxau6:armhf (1:1.0.8-1+b2) ...
            Setting up libpixman-1-dev:armhf (0.36.0-1) ...
            Setting up libpcre16-3:armhf (2:8.39-12) ...
            Setting up x11-common (1:7.7+19) ...
            update-rc.d: warning: start and stop actions are no longer supported; falling back to defaults
            invoke-rc.d: could not determine current runlevel
            invoke-rc.d: policy-rc.d denied execution of start.
            Setting up libsepol1-dev:armhf (2.8-1) ...
            Setting up liblzo2-2:armhf (2.10-0.1) ...
            Setting up libffi-dev:armhf (3.2.1-9) ...
            Setting up libpthread-stubs0-dev:armhf (0.4-1) ...
            Setting up xtrans-dev (1.3.5-1) ...
            Setting up libglib2.0-data (2.58.3-2+deb10u2) ...
            Setting up libx11-data (2:1.6.7-1) ...
            Setting up uuid-dev:armhf (2.33.1-0.1) ...
            Setting up libpng16-16:armhf (1.6.36-6) ...
            Setting up libpcre32-3:armhf (2:8.39-12) ...
            Setting up fonts-dejavu-core (2.37-1) ...
            Setting up zlib1g-dev:armhf (1:1.2.11.dfsg-1) ...
            Setting up sensible-utils (0.0.12) ...
            Setting up xorg-sgml-doctools (1:1.11-1) ...
            Setting up libbsd0:armhf (0.9.1-2) ...
            Setting up python3-lib2to3 (3.7.3-1) ...
            Setting up python3-distutils (3.7.3-1) ...
            Setting up x11proto-dev (2018.4-4) ...
            Setting up libglib2.0-dev-bin (2.58.3-2+deb10u2) ...
            Setting up libblkid-dev:armhf (2.33.1-0.1) ...
            Setting up libice6:armhf (2:1.0.9-2) ...
            Setting up libxdmcp6:armhf (1:1.1.2-3) ...
            Setting up libxcb1:armhf (1.13.1-2) ...
            Setting up libxau-dev:armhf (1:1.0.8-1+b2) ...
            Setting up libice-dev:armhf (2:1.0.9-2) ...
            Setting up libxcb-render0:armhf (1.13.1-2) ...
            Setting up libpcre3-dev:armhf (2:8.39-12) ...
            Setting up libpng-dev:armhf (1.6.36-6) ...
            Setting up libglib2.0-bin (2.58.3-2+deb10u2) ...
            Setting up libxcb-shm0:armhf (1.13.1-2) ...
            Setting up libxdmcp-dev:armhf (1:1.1.2-3) ...
            Setting up libfreetype6:armhf (2.9.1-3+deb10u1) ...
            Setting up x11proto-core-dev (2018.4-4) ...
            Setting up ucf (3.0038+nmu1) ...
            Setting up x11proto-xext-dev (2018.4-4) ...
            Setting up libx11-6:armhf (2:1.6.7-1) ...
            Setting up libsm6:armhf (2:1.2.3-1) ...
            Setting up libmount-dev:armhf (2.33.1-0.1) ...
            Setting up libxcb1-dev:armhf (1.13.1-2) ...
            Setting up libxrender1:armhf (1:0.9.10-1) ...
            Setting up libsm-dev:armhf (2:1.2.3-1) ...
            Setting up libselinux1-dev:armhf (2.8-1+b1) ...
            Setting up fontconfig-config (2.13.1-2) ...
            Setting up libx11-dev:armhf (2:1.6.7-1) ...
            Setting up libxext6:armhf (2:1.3.3-1+b2) ...
            Setting up libfreetype6-dev:armhf (2.9.1-3+deb10u1) ...
            Setting up libxcb-shm0-dev:armhf (1.13.1-2) ...
            Setting up libglib2.0-dev:armhf (2.58.3-2+deb10u2) ...
            Setting up libxcb-render0-dev:armhf (1.13.1-2) ...
            Setting up libxext-dev:armhf (2:1.3.3-1+b2) ...
            Setting up libfontconfig1:armhf (2.13.1-2) ...
            Setting up libxrender-dev:armhf (1:0.9.10-1) ...
            Setting up libfontconfig1-dev:armhf (2.13.1-2) ...
            Setting up libcairo2:armhf (1.16.0-4) ...
            Setting up libcairo-gobject2:armhf (1.16.0-4) ...
            Setting up libcairo-script-interpreter2:armhf (1.16.0-4) ...
            Processing triggers for libglib2.0-0:armhf (2.58.3-2+deb10u2) ...
            No schema files found: doing nothing.
            Setting up libcairo2-dev:armhf (1.16.0-4) ...
            Selecting previously unselected package fontconfig.
            (Reading database ... 26453 files and directories currently installed.)
            Preparing to unpack .../00-fontconfig_2.13.1-2_armhf.deb ...
            Unpacking fontconfig (2.13.1-2) ...
            Selecting previously unselected package libgirepository-1.0-1:armhf.
            Preparing to unpack .../01-libgirepository-1.0-1_1.58.3-2_armhf.deb ...
            Unpacking libgirepository-1.0-1:armhf (1.58.3-2) ...
            Selecting previously unselected package gir1.2-glib-2.0:armhf.
            Preparing to unpack .../02-gir1.2-glib-2.0_1.58.3-2_armhf.deb ...
            Unpacking gir1.2-glib-2.0:armhf (1.58.3-2) ...
            Selecting previously unselected package gir1.2-freedesktop:armhf.
            Preparing to unpack .../03-gir1.2-freedesktop_1.58.3-2_armhf.deb ...
            Unpacking gir1.2-freedesktop:armhf (1.58.3-2) ...
            Selecting previously unselected package libgraphite2-3:armhf.
            Preparing to unpack .../04-libgraphite2-3_1.3.13-7_armhf.deb ...
            Unpacking libgraphite2-3:armhf (1.3.13-7) ...
            Selecting previously unselected package libharfbuzz0b:armhf.
            Preparing to unpack .../05-libharfbuzz0b_2.3.1-1_armhf.deb ...
            Unpacking libharfbuzz0b:armhf (2.3.1-1) ...
            Selecting previously unselected package libharfbuzz-gobject0:armhf.
            Preparing to unpack .../06-libharfbuzz-gobject0_2.3.1-1_armhf.deb ...
            Unpacking libharfbuzz-gobject0:armhf (2.3.1-1) ...
            Selecting previously unselected package gir1.2-harfbuzz-0.0:armhf.
            Preparing to unpack .../07-gir1.2-harfbuzz-0.0_2.3.1-1_armhf.deb ...
            Unpacking gir1.2-harfbuzz-0.0:armhf (2.3.1-1) ...
            Selecting previously unselected package libfribidi0:armhf.
            Preparing to unpack .../08-libfribidi0_1.0.5-3.1+deb10u1_armhf.deb ...
            Unpacking libfribidi0:armhf (1.0.5-3.1+deb10u1) ...
            Selecting previously unselected package libthai-data.
            Preparing to unpack .../09-libthai-data_0.1.28-2_all.deb ...
            Unpacking libthai-data (0.1.28-2) ...
            Selecting previously unselected package libdatrie1:armhf.
            Preparing to unpack .../10-libdatrie1_0.2.12-2_armhf.deb ...
            Unpacking libdatrie1:armhf (0.2.12-2) ...
            Selecting previously unselected package libthai0:armhf.
            Preparing to unpack .../11-libthai0_0.1.28-2_armhf.deb ...
            Unpacking libthai0:armhf (0.1.28-2) ...
            Selecting previously unselected package libpango-1.0-0:armhf.
            Preparing to unpack .../12-libpango-1.0-0_1.42.4-8~deb10u1_armhf.deb ...
            Unpacking libpango-1.0-0:armhf (1.42.4-8~deb10u1) ...
            Selecting previously unselected package libpangoft2-1.0-0:armhf.
            Preparing to unpack .../13-libpangoft2-1.0-0_1.42.4-8~deb10u1_armhf.deb ...
            Unpacking libpangoft2-1.0-0:armhf (1.42.4-8~deb10u1) ...
            Selecting previously unselected package libpangocairo-1.0-0:armhf.
            Preparing to unpack .../14-libpangocairo-1.0-0_1.42.4-8~deb10u1_armhf.deb ...
            Unpacking libpangocairo-1.0-0:armhf (1.42.4-8~deb10u1) ...
            Selecting previously unselected package libxft2:armhf.
            Preparing to unpack .../15-libxft2_2.3.2-2_armhf.deb ...
            Unpacking libxft2:armhf (2.3.2-2) ...
            Selecting previously unselected package libpangoxft-1.0-0:armhf.
            Preparing to unpack .../16-libpangoxft-1.0-0_1.42.4-8~deb10u1_armhf.deb ...
            Unpacking libpangoxft-1.0-0:armhf (1.42.4-8~deb10u1) ...
            Selecting previously unselected package gir1.2-pango-1.0:armhf.
            Preparing to unpack .../17-gir1.2-pango-1.0_1.42.4-8~deb10u1_armhf.deb ...
            Unpacking gir1.2-pango-1.0:armhf (1.42.4-8~deb10u1) ...
            Selecting previously unselected package libicu63:armhf.
            Preparing to unpack .../18-libicu63_63.1-6+deb10u1_armhf.deb ...
            Unpacking libicu63:armhf (63.1-6+deb10u1) ...
            Selecting previously unselected package icu-devtools.
            Preparing to unpack .../19-icu-devtools_63.1-6+deb10u1_armhf.deb ...
            Unpacking icu-devtools (63.1-6+deb10u1) ...
            Selecting previously unselected package libfribidi-dev:armhf.
            Preparing to unpack .../20-libfribidi-dev_1.0.5-3.1+deb10u1_armhf.deb ...
            Unpacking libfribidi-dev:armhf (1.0.5-3.1+deb10u1) ...
            Selecting previously unselected package libgraphite2-dev:armhf.
            Preparing to unpack .../21-libgraphite2-dev_1.3.13-7_armhf.deb ...
            Unpacking libgraphite2-dev:armhf (1.3.13-7) ...
            Selecting previously unselected package libharfbuzz-icu0:armhf.
            Preparing to unpack .../22-libharfbuzz-icu0_2.3.1-1_armhf.deb ...
            Unpacking libharfbuzz-icu0:armhf (2.3.1-1) ...
            Selecting previously unselected package libicu-dev:armhf.
            Preparing to unpack .../23-libicu-dev_63.1-6+deb10u1_armhf.deb ...
            Unpacking libicu-dev:armhf (63.1-6+deb10u1) ...
            Selecting previously unselected package libharfbuzz-dev:armhf.
            Preparing to unpack .../24-libharfbuzz-dev_2.3.1-1_armhf.deb ...
            Unpacking libharfbuzz-dev:armhf (2.3.1-1) ...
            Selecting previously unselected package libxft-dev:armhf.
            Preparing to unpack .../25-libxft-dev_2.3.2-2_armhf.deb ...
            Unpacking libxft-dev:armhf (2.3.2-2) ...
            Selecting previously unselected package pango1.0-tools.
            Preparing to unpack .../26-pango1.0-tools_1.42.4-8~deb10u1_armhf.deb ...
            Unpacking pango1.0-tools (1.42.4-8~deb10u1) ...
            Selecting previously unselected package libpango1.0-dev:armhf.
            Preparing to unpack .../27-libpango1.0-dev_1.42.4-8~deb10u1_armhf.deb ...
            Unpacking libpango1.0-dev:armhf (1.42.4-8~deb10u1) ...
            Setting up libgraphite2-3:armhf (1.3.13-7) ...
            Setting up fontconfig (2.13.1-2) ...
            Regenerating fonts cache... done.
            Setting up libxft2:armhf (2.3.2-2) ...
            Setting up libdatrie1:armhf (0.2.12-2) ...
            Setting up libicu63:armhf (63.1-6+deb10u1) ...
            Setting up libgraphite2-dev:armhf (1.3.13-7) ...
            Setting up libfribidi0:armhf (1.0.5-3.1+deb10u1) ...
            Setting up icu-devtools (63.1-6+deb10u1) ...
            Setting up libharfbuzz0b:armhf (2.3.1-1) ...
            Setting up libthai-data (0.1.28-2) ...
            Setting up libgirepository-1.0-1:armhf (1.58.3-2) ...
            Setting up libicu-dev:armhf (63.1-6+deb10u1) ...
            Setting up libxft-dev:armhf (2.3.2-2) ...
            Setting up libharfbuzz-icu0:armhf (2.3.1-1) ...
            Setting up libfribidi-dev:armhf (1.0.5-3.1+deb10u1) ...
            Setting up libharfbuzz-gobject0:armhf (2.3.1-1) ...
            Setting up libthai0:armhf (0.1.28-2) ...
            Setting up gir1.2-glib-2.0:armhf (1.58.3-2) ...
            Setting up gir1.2-freedesktop:armhf (1.58.3-2) ...
            Setting up libpango-1.0-0:armhf (1.42.4-8~deb10u1) ...
            Setting up gir1.2-harfbuzz-0.0:armhf (2.3.1-1) ...
            Setting up libpangoft2-1.0-0:armhf (1.42.4-8~deb10u1) ...
            Setting up libpangocairo-1.0-0:armhf (1.42.4-8~deb10u1) ...
            Setting up libharfbuzz-dev:armhf (2.3.1-1) ...
            Setting up libpangoxft-1.0-0:armhf (1.42.4-8~deb10u1) ...
            Setting up pango1.0-tools (1.42.4-8~deb10u1) ...
            Setting up gir1.2-pango-1.0:armhf (1.42.4-8~deb10u1) ...
            Setting up libpango1.0-dev:armhf (1.42.4-8~deb10u1) ...
            Selecting previously unselected package libjpeg62-turbo:armhf.
            (Reading database ... 27068 files and directories currently installed.)
            Preparing to unpack .../libjpeg62-turbo_1%3a1.5.2-2+b1_armhf.deb ...
            Unpacking libjpeg62-turbo:armhf (1:1.5.2-2+b1) ...
            Selecting previously unselected package libjpeg62-turbo-dev:armhf.
            Preparing to unpack .../libjpeg62-turbo-dev_1%3a1.5.2-2+b1_armhf.deb ...
            Unpacking libjpeg62-turbo-dev:armhf (1:1.5.2-2+b1) ...
            Selecting previously unselected package libjpeg-dev.
            Preparing to unpack .../libjpeg-dev_1%3a1.5.2-2_all.deb ...
            Unpacking libjpeg-dev (1:1.5.2-2) ...
            Setting up libjpeg62-turbo:armhf (1:1.5.2-2+b1) ...
            Setting up libjpeg62-turbo-dev:armhf (1:1.5.2-2+b1) ...
            Setting up libjpeg-dev (1:1.5.2-2) ...
            Selecting previously unselected package libgif7:armhf.
            (Reading database ... 27097 files and directories currently installed.)
            Preparing to unpack .../libgif7_5.1.4-3_armhf.deb ...
            Unpacking libgif7:armhf (5.1.4-3) ...
            Selecting previously unselected package libgif-dev.
            Preparing to unpack .../libgif-dev_5.1.4-3_armhf.deb ...
            Unpacking libgif-dev (5.1.4-3) ...
            Setting up libgif7:armhf (5.1.4-3) ...
            Setting up libgif-dev (5.1.4-3) ...
            Selecting previously unselected package libjbig0:armhf.
            (Reading database ... 27116 files and directories currently installed.)
            Preparing to unpack .../00-libjbig0_2.1-3.1+b2_armhf.deb ...
            Unpacking libjbig0:armhf (2.1-3.1+b2) ...
            Selecting previously unselected package libwebp6:armhf.
            Preparing to unpack .../01-libwebp6_0.6.1-2_armhf.deb ...
            Unpacking libwebp6:armhf (0.6.1-2) ...
            Selecting previously unselected package libtiff5:armhf.
            Preparing to unpack .../02-libtiff5_4.1.0+git191117-2~deb10u1_armhf.deb ...
            Unpacking libtiff5:armhf (4.1.0+git191117-2~deb10u1) ...
            Selecting previously unselected package libxml2:armhf.
            Preparing to unpack .../03-libxml2_2.9.4+dfsg1-7+b3_armhf.deb ...
            Unpacking libxml2:armhf (2.9.4+dfsg1-7+b3) ...
            Selecting previously unselected package shared-mime-info.
            Preparing to unpack .../04-shared-mime-info_1.10-1_armhf.deb ...
            Unpacking shared-mime-info (1.10-1) ...
            Selecting previously unselected package libgdk-pixbuf2.0-common.
            Preparing to unpack .../05-libgdk-pixbuf2.0-common_2.38.1+dfsg-1_all.deb ...
            Unpacking libgdk-pixbuf2.0-common (2.38.1+dfsg-1) ...
            Selecting previously unselected package libgdk-pixbuf2.0-0:armhf.
            Preparing to unpack .../06-libgdk-pixbuf2.0-0_2.38.1+dfsg-1_armhf.deb ...
            Unpacking libgdk-pixbuf2.0-0:armhf (2.38.1+dfsg-1) ...
            Selecting previously unselected package gir1.2-gdkpixbuf-2.0:armhf.
            Preparing to unpack .../07-gir1.2-gdkpixbuf-2.0_2.38.1+dfsg-1_armhf.deb ...
            Unpacking gir1.2-gdkpixbuf-2.0:armhf (2.38.1+dfsg-1) ...
            Selecting previously unselected package libcroco3:armhf.
            Preparing to unpack .../08-libcroco3_0.6.12-3_armhf.deb ...
            Unpacking libcroco3:armhf (0.6.12-3) ...
            Selecting previously unselected package librsvg2-2:armhf.
            Preparing to unpack .../09-librsvg2-2_2.44.10-2.1_armhf.deb ...
            Unpacking librsvg2-2:armhf (2.44.10-2.1) ...
            Selecting previously unselected package gir1.2-rsvg-2.0:armhf.
            Preparing to unpack .../10-gir1.2-rsvg-2.0_2.44.10-2.1_armhf.deb ...
            Unpacking gir1.2-rsvg-2.0:armhf (2.44.10-2.1) ...
            Selecting previously unselected package libgdk-pixbuf2.0-bin.
            Preparing to unpack .../11-libgdk-pixbuf2.0-bin_2.38.1+dfsg-1_armhf.deb ...
            Unpacking libgdk-pixbuf2.0-bin (2.38.1+dfsg-1) ...
            Selecting previously unselected package libgdk-pixbuf2.0-dev:armhf.
            Preparing to unpack .../12-libgdk-pixbuf2.0-dev_2.38.1+dfsg-1_armhf.deb ...
            Unpacking libgdk-pixbuf2.0-dev:armhf (2.38.1+dfsg-1) ...
            Selecting previously unselected package librsvg2-common:armhf.
            Preparing to unpack .../13-librsvg2-common_2.44.10-2.1_armhf.deb ...
            Unpacking librsvg2-common:armhf (2.44.10-2.1) ...
            Selecting previously unselected package librsvg2-dev:armhf.
            Preparing to unpack .../14-librsvg2-dev_2.44.10-2.1_armhf.deb ...
            Unpacking librsvg2-dev:armhf (2.44.10-2.1) ...
            Setting up libgdk-pixbuf2.0-common (2.38.1+dfsg-1) ...
            Setting up libjbig0:armhf (2.1-3.1+b2) ...
            Setting up libwebp6:armhf (0.6.1-2) ...
            Setting up libtiff5:armhf (4.1.0+git191117-2~deb10u1) ...
            Setting up libxml2:armhf (2.9.4+dfsg1-7+b3) ...
            Setting up shared-mime-info (1.10-1) ...
            Setting up libcroco3:armhf (0.6.12-3) ...
            Setting up libgdk-pixbuf2.0-0:armhf (2.38.1+dfsg-1) ...
            Setting up libgdk-pixbuf2.0-bin (2.38.1+dfsg-1) ...
            Setting up gir1.2-gdkpixbuf-2.0:armhf (2.38.1+dfsg-1) ...
            Setting up libgdk-pixbuf2.0-dev:armhf (2.38.1+dfsg-1) ...
            Setting up librsvg2-2:armhf (2.44.10-2.1) ...
            Setting up librsvg2-common:armhf (2.44.10-2.1) ...
            Setting up gir1.2-rsvg-2.0:armhf (2.44.10-2.1) ...
            Setting up librsvg2-dev:armhf (2.44.10-2.1) ...
            Processing triggers for libgdk-pixbuf2.0-0:armhf (2.38.1+dfsg-1) ...
            Done.,
            -----   Step 2 of 5: Detecting ioBroker installation   -----,
            ioBroker backup file detected in /opt/iobroker. Restoring ioBroker...,
            Done.,
            !!!!!                             IMPORTANT NOTE                             !!!!!,
            !!!!!        The sartup script restored iobroker from a backup file.         !!!!!,
            !!!!! Check /opt/iobroker/log/restore.log to see if restore was successful.  !!!!!,
            !!!!! When ioBroker now starts it will reinstall all Adapters automatically. !!!!!,
            !!!!!         This might be take a looooong time! Please be patient!         !!!!!,
            !!!!!  You can view installation process by taking a look at ioBroker log.   !!!!!,
            -----   Step 3 of 5: Checking ioBroker installation    -----,
            (Re)Setting folder permissions (This might take a while! Please be patient!)...,
            Done.,
            Fixing "sudo-bug" by replacing sudo in iobroker with gosu...,
            Done.,
            Looks like this is a new and empty installation of ioBroker.,
            Hostname needs to be updated to  iobroker...,
            The host for instance "system.adapter.admin.0" was changed from "d8abcf375f01" to "iobroker".,
            The host for instance "system.adapter.discovery.0" was changed from "d8abcf375f01" to "iobroker".,
            The host for instance "system.adapter.info.0" was changed from "d8abcf375f01" to "iobroker".,
            Done.,
            -----      Step 4 of 5: Applying special settings      -----,
            Some adapters have special requirements/ settings which can be activated by the use of environment variables.,
            For more information take a look at readme.md on Github!,
            Usb-device-support is activated by ENV.,
            Setting permissions for /dev/ttyACM0...,
            Done.,
            -----          Step 5 of 5: ioBroker startup           -----,
            Starting ioBroker...,
            host.iobroker check instance "system.adapter.admin.0" for host "iobroker",
            host.iobroker check instance "system.adapter.discovery.0" for host "iobroker",
            host.iobroker check instance "system.adapter.info.0" for host "iobroker",
            Send diag info: {"uuid":"7abd3182-d399-f7bd-da19-9550d8babede","language":"","country":"","hosts":[{"version":"3.1.6","platform":"Javascript/Node.js","type":"linux"}],"node":"v12.18.1","arch":"arm","adapters":{"admin":{"version":"4.0.10","platform":"Javascript/Node.js"},"discovery":{"version":"2.3.5","platform":"Javascript/Node.js"},"info":{"version":"1.7.2","platform":"Javascript/Node.js"}},"statesType":"file","objectsType":"file","model":"ARMv7 Processor rev 3 (v7l)","cpus":4,"mem":4012838912,"ostype":"Linux","city":""},
            Dort steht die Container-Log nun seit 40 Minuten unverändert - der Rasppi scheint im idle zu laufen ...
            Bin ich noch zu ungeduldig oder zu blöd und habe irgendwas übersehen?
            FoodFighterF 1 Antwort Letzte Antwort
            • FoodFighterF FoodFighter
              Hallo Jungs,
                mkdir iobrokerdata
              gibt folgendes aus:
              -----                      System                      -----,
              -----                       ENV                        -----,
              Done.,
              Done.,
              Done.,
              Done.,
              Done.,
              Done.,
              FoodFighter
              #1926
              Kurzes Update:
              Nach ein Bisschen Googlei hängt wohl der Fehler
              damit zusammen, wenn der restore mit falschen Rechten ausgeführt wird (teilweise wurde berichtet, dass dies passiert, wenn man "sudo iobroker restore 0" ausführt)
              Daher kam ich auf folgende Idee, die letzten Endes auch (scheinbar) funktionierte:
              1. iobroker-Container beendet
              2. das versemmelte Verzeichnis "iobrokerdata" aus dem letzten Versuch wieder gelöscht
                sudo rm -r iobrokerdata
              3. neues Verzeichnis erstellt
                mkdir iobrokerdata
              4. KEIN BACKUP geladen
              5. Container gestartet (Clean install)
              6. gewartet bis der Container sauber hoch gelaufen ist
              7. Verzeichnis ./iobrokerdata/backups/ erstellt und das Backup dorthin kopiert
                mkdir /home/pi/iobroker/iobrokerdata/backups
                cp /home/pi/iobroker/iobrokerdata_OLD/backups/iobroker_2020_07_04-10_28_48_backupiobroker.tar.gz /home/pi/iobroker/iobrokerdata/backups/
              8. Über die Container-Konsole iobroker beendet:
                pkill -u iobroker
              9. Danach das Backup wiederhergestellt (Container-Konsole):
              10. Nachdem dieser Vorgang erfolgreich abgeschlossen wurde -> Container neu gestartet
              11. Gewartet und die Log im Admin-Backend vom iobroker verfolgt.
              Momentan werden fleißig alle Adapter nacheinander installiert. (noch nicht abgeschlossen)
              @andre Scheint also, als würde irgendwas mit deineim startup-script noch nicht 100%ig stimmen.
              Vielleicht führt dieser Script den Restore wirklich mit falschen Rechten aus, wodurch der Restore fehlschlägt?
              Ich bin gerne Bereit einen separaten Container anzulegen und andere Lösungsansätze auf dem rPi 4 zu testen, falls ich da hilfreich sein kann.
              Log Clean-Install:
              ---------------     2020-07-04 13:13:23      ---------------,
              -----                      System                      -----,
              -----                       ENV                        -----,
              Done.,
              There is no data detected in /opt/iobroker. Restoring initial ioBroker installation...,
              Done.,
              Done.,
              Done.,
              Done.,
              Done.,
              hash changed or no sources cached => force download of new sources,
              Send diag info: {"uuid":"7abd3182-d399-f7bd-da19-9550d8babede","language":"de","country":"","hosts":[{"version":"3.1.6","platform":"Javascript/Node.js","type":"linux"}],"node":"v12.18.1","arch":"arm","adapters":{"admin":{"version":"4.0.10","platform":"Javascript/Node.js"},"discovery":{"version":"2.3.5","platform":"Javascript/Node.js"},"info":{"version":"1.7.2","platform":"Javascript/Node.js"}},"statesType":"file","objectsType":"file","model":"ARMv7 Processor rev 3 (v7l)","cpus":4,"mem":4012838912,"ostype":"Linux","city":""},
              ================================== > LOG REDIRECT system.adapter.admin.0 => false [system.adapter.admin.0.logging],
              ================================== > LOG REDIRECT system.adapter.admin.0 => true [system.adapter.admin.0.logging],
              ================================== > LOG REDIRECT system.adapter.admin.0 => false [Process stopped],
              Log Backup-Restore:
              root@iobroker:/opt/iobroker# pkill -u iobroker
              root@iobroker:/opt/iobroker# sudo iobroker restore 0
              iobroker controller daemon is not running
              host.iobroker OK.
              host.iobroker Clear all objects and states...
              clean 528 objects...
              [Not critical] Cannot delete object 0_userdata.0: "Object is marked as non deletable"
              [Not critical] Cannot delete object alias.0: "Object is marked as non deletable"
              [Not critical] Cannot delete object system.repositories: "Object is marked as non deletable"
              [Not critical] Cannot delete object system.config: "Object is marked as non deletable"
              [Not critical] Cannot delete object enum.functions: "Object is marked as non deletable"
              [Not critical] Cannot delete object enum.rooms: "Object is marked as non deletable"
              clean 430 states...
              host.iobroker done.
              host.iobroker Processed 0/2508 states
              host.iobroker Processed 200/2508 states
              host.iobroker Processed 400/2508 states
              host.iobroker Processed 600/2508 states
              host.iobroker Processed 800/2508 states
              host.iobroker Processed 1000/2508 states
              host.iobroker Processed 1200/2508 states
              host.iobroker Processed 1400/2508 states
              host.iobroker Processed 1600/2508 states
              host.iobroker Processed 1800/2508 states
              host.iobroker Processed 2000/2508 states
              host.iobroker Processed 2200/2508 states
              host.iobroker Processed 2400/2508 states
              2508 states restored.
              host.iobroker Processed 0/2694 objects
              host.iobroker Processed 200/2694 objects
              host.iobroker Processed 400/2694 objects
              host.iobroker Processed 600/2694 objects
              host.iobroker Processed 800/2694 objects
              host.iobroker Processed 1000/2694 objects
              host.iobroker Processed 1200/2694 objects
              host.iobroker Processed 1400/2694 objects
              host.iobroker Processed 1600/2694 objects
              host.iobroker Processed 1800/2694 objects
              host.iobroker Processed 2000/2694 objects
              host.iobroker Processed 2200/2694 objects
              host.iobroker Processed 2400/2694 objects
              host.iobroker Processed 2600/2694 objects
              2694 objects restored.
              host.iobroker Upload user file "vis.0/Smartphone/vis-user.css
              host.iobroker Upload user file "vis.0/Smartphone/vis-views.json
              host.iobroker Upload user file "vis.0/Temperaturen/vis-views.json
              host.iobroker Upload user file "vis.0/main/img/BoRi10 - Wohnung - 3D Floor Plan_final.png
              host.iobroker Upload user file "vis.0/main/img/Gastherme_RI.png
              host.iobroker Upload user file "vis.0/main/img/Mond.png
              host.iobroker Upload user file "vis.0/main/img/Power.png
              host.iobroker Upload user file "vis.0/main/img/Sonne.png
              host.iobroker Upload user file "vis.0/main/img/Uhr.png
              host.iobroker Upload user file "vis.0/main/vis-user.css
              host.iobroker Upload user file "vis.0/main/vis-views.json
              upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/words.js words.js application/javascript
              upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index_m.html index_m.html text/html
              upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index.html index.html text/html
              upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
              upload [6] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/words.js words.js application/javascript
              upload [5] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/translateTools.js translateTools.js application/javascript
              upload [4] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings_m.html settings_m.html text/html
              upload [3] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings.html settings.html text/html
              upload [2] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index_m.html index_m.html text/html
              upload [1] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index.html index.html text/html
              upload [0] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/discovery.png discovery.png image/png
              upload [80] info.admin /opt/iobroker/node_modules/iobroker.info/admin/words.js words.js application/javascript
              upload [70] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/hostInfo.js lib/js/hostInfo.js application/javascript
              upload [60] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/bootstrap.min.js lib/js/bootstrap.min.js application/javascript
              upload [50] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/logos/slackware.png lib/img/logos/slackware.png image/png
              upload [40] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/logos/manjaro.png lib/img/logos/manjaro.png image/png
              upload [30] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/logos/coreos.png lib/img/logos/coreos.png image/png
              upload [20] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/icons/disk.png lib/img/icons/disk.png image/png
              upload [19] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/icons/cpu.png lib/img/icons/cpu.png image/png
              upload [18] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/icons/battery.png lib/img/icons/battery.png image/png
              upload [17] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/clock/sechand.png lib/img/clock/sechand.png image/png
              upload [16] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/clock/minhand.png lib/img/clock/minhand.png image/png
              upload [15] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/clock/hourhand.png lib/img/clock/hourhand.png image/png
              upload [14] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/clock/clockface.png lib/img/clock/clockface.png image/png
              upload [13] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/fontawesome-webfont.woff2 lib/fonts/fontawesome-webfont.woff2 font/woff2
              upload [12] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/fontawesome-webfont.woff lib/fonts/fontawesome-webfont.woff font/woff
              upload [11] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/fontawesome-webfont.ttf lib/fonts/fontawesome-webfont.ttf font/ttf
              upload [10] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/fontawesome-webfont.svg lib/fonts/fontawesome-webfont.svg image/svg+xml
              upload [9] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/fontawesome-webfont.eot lib/fonts/fontawesome-webfont.eot application/vnd.ms-fontobject
              upload [8] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/FontAwesome.otf lib/fonts/FontAwesome.otf font/otf
              upload [7] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/data/infoData.json lib/data/infoData.json application/json
              upload [6] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/simplemde.min.css lib/css/simplemde.min.css text/css
              upload [5] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/info.css lib/css/info.css text/css
              upload [4] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/font-awesome.min.css lib/css/font-awesome.min.css text/css
              upload [3] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/chartist.min.css lib/css/chartist.min.css text/css
              upload [2] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/bootstrap.min.css lib/css/bootstrap.min.css text/css
              upload [1] info.admin /opt/iobroker/node_modules/iobroker.info/admin/info.png info.png image/png
              upload [0] info.admin /opt/iobroker/node_modules/iobroker.info/admin/index_m.html index_m.html text/html
              System successfully restored!
              iobroker-Log nach restore und restart:
              -----                      System                      -----,
              -----                       ENV                        -----,
              Done.,
              Existing installation of ioBroker detected in /opt/iobroker.,
              Done.,
              Done.,
              Done.,
              host.iobroker check instance "system.adapter.alexa2.0" for host "iobroker",
              host.iobroker check instance "system.adapter.backitup.0" for host "iobroker",
              host.iobroker check instance "system.adapter.bsblan.0" for host "iobroker",
              host.iobroker check instance "system.adapter.fb-checkpresence.0" for host "iobroker",
              host.iobroker check instance "system.adapter.influxdb.0" for host "iobroker",
              host.iobroker check instance "system.adapter.javascript.0" for host "iobroker",
              host.iobroker check instance "system.adapter.mihome-vacuum.0" for host "iobroker",
              host.iobroker check instance "system.adapter.mqtt-client.0" for host "iobroker",
              host.iobroker check instance "system.adapter.node-red.0" for host "iobroker",
              host.iobroker check instance "system.adapter.octoprint.0" for host "iobroker",
              host.iobroker check instance "system.adapter.ping.0" for host "iobroker",
              host.iobroker check instance "system.adapter.rpi2.0" for host "iobroker",
              host.iobroker check instance "system.adapter.simple-api.0" for host "iobroker",
              host.iobroker check instance "system.adapter.sonoff.0" for host "iobroker",
              host.iobroker check instance "system.adapter.telegram.0" for host "iobroker",
              host.iobroker check instance "system.adapter.telegram.1" for host "iobroker",
              host.iobroker check instance "system.adapter.vis-bars.0" for host "iobroker",
              host.iobroker check instance "system.adapter.vis-canvas-gauges.0" for host "iobroker",
              host.iobroker check instance "system.adapter.vis-colorpicker.0" for host "iobroker",
              host.iobroker check instance "system.adapter.vis-fancyswitch.0" for host "iobroker",
              host.iobroker check instance "system.adapter.vis-history.0" for host "iobroker",
              host.iobroker check instance "system.adapter.vis-hqwidgets.0" for host "iobroker",
              host.iobroker check instance "system.adapter.vis-jqui-mfd.0" for host "iobroker",
              host.iobroker check instance "system.adapter.vis-justgage.0" for host "iobroker",
              host.iobroker check instance "system.adapter.vis-material.0" for host "iobroker",
              host.iobroker check instance "system.adapter.vis-materialdesign.0" for host "iobroker",
              host.iobroker check instance "system.adapter.vis-metro.0" for host "iobroker",
              host.iobroker check instance "system.adapter.vis-plumb.0" for host "iobroker",
              host.iobroker check instance "system.adapter.vis-rgraph.0" for host "iobroker",
              host.iobroker check instance "system.adapter.vis-timeandweather.0" for host "iobroker",
              host.iobroker check instance "system.adapter.vis-weather.0" for host "iobroker",
              host.iobroker check instance "system.adapter.vis.0" for host "iobroker",
              host.iobroker check instance "system.adapter.web.0" for host "iobroker",
              host.iobroker check instance "system.adapter.zigbee.0" for host "iobroker",
              �Send diag info: {"uuid":"7abd3182-d399-f7bd-da19-9550d8babede","language":"de","country":"Germany","hosts":[{"version":"3.1.6","platform":"Javascript/Node.js","type":"linux"}],"node":"v12.18.1","arch":"arm","adapters":{"admin":{"version":"4.1.1","platform":"Javascript/Node.js"},"alexa2":{"version":"3.2.4","platform":"Javascript/Node.js"},"backitup":{"version":"1.5.8","platform":"Javascript/Node.js"},"bsblan":{"version":"0.1.2","platform":"Javascript/Node.js"},"cloud":{"version":"3.0.3","platform":"Javascript/Node.js"},"devices":{"version":"0.3.6","platform":"Javascript/Node.js"},"discovery":{"version":"2.3.7","platform":"Javascript/Node.js"},"fb-checkpresence":{"version":"1.0.3","platform":"Javascript/Node.js"},"flot":{"version":"1.10.0","platform":"javascript/Node.js"},"icons-addictive-flavour-png":{"version":"0.1.0","platform":"javascript/Node.js"},"icons-icons8":{"version":"0.0.1","platform":"javascript/Node.js"},"icons-material-png":{"version":"0.1.0","platform":"javascript/Node.js"},"icons-material-svg":{"version":"0.1.0","platform":"javascript/Node.js"},"icons-mfd-png":{"version":"1.0.2","platform":"javascript/Node.js"},"icons-ultimate-png":{"version":"1.0.1","platform":"javascript/Node.js"},"influxdb":{"version":"1.8.6","platform":"Javascript/Node.js"},"info":{"version":"1.7.5","platform":"Javascript/Node.js"},"javascript":{"version":"4.6.17","platform":"Javascript/Node.js"},"mihome-vacuum":{"version":"2.0.7","platform":"Javascript/Node.js"},"mqtt-client":{"version":"1.3.1","platform":"Javascript/Node.js"},"node-red":{"version":"2.0.0","platform":"Javascript/Node.js"},"octoprint":{"version":"0.0.4","platform":"Javascript/Node.js"},"ping":{"version":"1.4.8","platform":"Javascript/Node.js"},"rickshaw":{"version":"1.0.0","platform":"javascript/Node.js"},"rpi2":{"version":"1.2.0","platform":"javascript/Node.js"},"simple-api":{"version":"2.4.6","platform":"Javascript/Node.js"},"socketio":{"version":"3.0.9","platform":"Javascript/Node.js"},"sonoff":{"version":"2.3.3","platform":"Javascript/Node.js"},"telegram":{"version":"1.5.9","platform":"Javascript/Node.js"},"vis":{"version":"1.2.6","platform":"Javascript/Node.js"},"vis-bars":{"version":"0.1.4","platform":"Javascript/Node.js"},"vis-canvas-gauges":{"version":"0.1.5","platform":"Javascript/Node.js"},"vis-colorpicker":{"version":"1.2.0","platform":"Javascript/Node.js"},"vis-fancyswitch":{"version":"1.1.0","platform":"Javascript/Node.js"},"vis-google-fonts":{"version":"0.1.0","platform":"Javascript/Node.js"},"vis-history":{"version":"1.0.0","platform":"Javascript/Node.js"},"vis-hqwidgets":{"version":"1.1.4","platform":"Javascript/Node.js"},"vis-inventwo":{"version":"1.3.8","platform":"Javascript/Node.js"},"vis-jqui-mfd":{"version":"1.0.12","platform":"Javascript/Node.js"},"vis-justgage":{"version":"1.0.2","platform":"Javascript/Node.js"},"vis-material":{"version":"0.1.3","platform":"Javascript/Node.js"},"vis-materialdesign":{"version":"0.3.14","platform":"Javascript/Node.js"},"vis-metro":{"version":"1.1.2","platform":"Javascript/Node.js"},"vis-plumb":{"version":"1.0.2","platform":"Javascript/Node.js"},"vis-rgraph":{"version":"0.0.2","platform":"Javascript/Node.js"},"vis-timeandweather":{"version":"1.1.7","platform":"Javascript/Node.js"},"vis-weather":{"version":"2.5.2","platform":"Javascript/Node.js"},"web":{"version":"3.0.9","platform":"Javascript/Node.js"},"zigbee":{"version":"1.1.1","platform":"Javascript/Node.js"}},"statesType":"file","objectsType":"file","model":"ARMv7 Processor rev 3 (v7l)","cpus":4,"mem":4012838912,"ostype":"Linux","vis":142},
                Kurzes Update:
                  mkdir iobrokerdata
                  pkill -u iobroker
                Log Clean-Install:
                -----                      System                      -----,
                -----                       ENV                        -----,
                Done.,
                Done.,
                Done.,
                Done.,
                Done.,
                Done.,
                Log Backup-Restore:
                host.iobroker OK.
                clean 430 states...
                host.iobroker done.
                -----                      System                      -----,
                -----                       ENV                        -----,
                Done.,
                Done.,
                Done.,
                Done.,
                andreA Offline
                andreA Offline
                andre
                #1927
                @FoodFighter Hier mal gelesen?
                https://github.com/buanet/docker-iobroker/issues/120
                Bei Problemen lohnt immer ein Blick in die issues. Für das restore Problem habe ich eine neue beta released.
                Das Problem sind nicht die Rechte beim restore, sondern dass die Berechtigungen bei der iobroker.json nicht passen (war zumindest bei mir so).
                Wenn es mit der beta nicht klappt brauche ich nochmal logs. Gerne als github issue. Dann steige ich da nochmal tiefer ein...
                MfG,
                André
                • andreA andre
                  MfG,
                  André
                  FoodFighter
                  #1928
                  @andre said in [HowTo][Anleitung] Installation ioBroker in Docker auf Synology DiskStation:
                  grml hätte mir die Arbeit gespart...aber nun gut. Danke.
                  Ein schneller Test mit einem Test-Container bestätigt die Funktion...jedenfalls läuft der Restore an (ich spare mir jetzt mal die Stunde bis alle Adapter durchgelaufen sind.)
                  Vielleicht auch interessant für die Nachwelt:
                  Mir hat es das komplette Node-Red-Projekt zerschossen....die nodes und flows werden scheinbar NICHT mit gebackupt....sehr ärgerlich, gibt es aber auch einige Berichte drüber
                  In meinem Fall noch überschaubar, da ich zum Glück den kompletten iobroker-Ordner gesichert hatte...da kann der eine oder andere aber schnell auf die Nase fallen und sich viele Tage Arbeit verschaffen.
                  Ich persönlich werde NodeRed zukünftig als eigenen Container laufen lassen, nicht mehr als Adapter.
                  Das lässt sich dann auch vernünftig sichern.
                  Der SSH-Key-Generator funktioniert im Adapter leider nicht, sonst hätte man das Projekt auch über Github sichern können...aber das ist ein anderes Thema.
                  Danke für deine Arbeit!
                  • SunshinemakerS Offline
                    Sunshinemaker
                    #1929
                    @andre Seid gestern Abend die 5.0.1beta auf dem Produktiven System. Ohne Probleme, läuft alles so wie es soll.
                    • D duffbeer2000
                      @stevie77 Also teilweise blickt man bei dem Beitrag nicht mehr durch.
                      Backup:
                      • du kannst den iobroker-data sichern, das gibt dann ein recht großes Backup. Falls was kaputt geht den Container an sich stoppen (nicht ioBroker im Container killen) das iobroker-data Verzeichnis wiederherstellen und den Container wieder starten.
                      • wichtig ist aber auf jeden Falal noch die interne Backupfunktion von ioBroker, das gibt dann ne recht kleine Datei aber wenn was im iobroker-data Verzeichnis kaputt ist und das vielleicht schon mehere Backups lang ohne das es auffällt ist dieses kleine Backup die Rettung. Damit kann man auch die ganzen Adapter von Grund auf sauber neu installieren lassen wenn es z.B. bei einem Wechsel der node.js Version zu Problemen kommt.
                      Latest oder Version:
                      Welche Version du genau bekommen hast siehst du beim Starten des Containers im Log ganz oben. Da sollte die Version stehen.
                      JS-Controller und Node.js update:
                      • Beide kannst du nicht über die ioBroker-Gui aktualisieren.
                      • Gefahrlos ist beides nicht, es kann immer zu inkompatibiläten kommen. Hier ist es wichtig vorher nachzulesen.
                      • Ein Update auf Node.js v12 am besten erst machen wenn das Image auch auf der neuen Version läuft sonst würde ein Update des Containers bedeuten du machst ein downgrade.
                      • beim Wechsel auf V12 sollte es dieses mal ohne händischen eingriff klappen. Aber das am besten nachlesen wenn Andre die neue Version ins stable bringt.
                      stevie77
                      #1930
                      @duffbeer2000 Sorry, dass ich mich lange nicht gemeldet habe und dass es teilverwirrt (oder -verwirrend) war. ;-)
                      Heute hatte ich endlich wieder mal Zeit und hab' mich mal weiter vorgetastet: Jetzt weiß ich immerhin, wie man das Backup von ioBroker anwirft, das Verzeichnis iobroker-data samt versteckter Daten kopieren/sichern kann und ich habe es geschafft unfallfrei auf Node.js v10.21.0 und JS-Controller 3.1.6 upzudaten. Das gibt erstmal etwas Sicherheit... ;-)
                      Danke für deine Infos hierzu!
                      Bevor ich auf die neue Image-Version 5.0.0 (oder gleich 5.0.1, sobald stable) update, versuche ich erstmal noch die 4.2.0 mit nem neuen Container zu versehen. Dabei will ich zusätzlich auch noch ein weiteres Host-Verzeichnis zwecks Datenaustausch mit nem eigenen Docker-Container (E3DC-Control) eines Vis-Projekts mappen.
                      volumes:
                        - "/home/pi/docker-data/iobroker-data:/opt/iobroker"
                        - "/home/pi/docker-data/e3dc-control/config:/home/iobroker/e3dc-config-transfer"
                      Ich baue ja die Container ioBroker, MySQL und phpMyAdmin mit einer Docker-Compose-Datei. Da wird es nicht reichen nur den ioBroker-Container zu löschen? Ich muss wahrscheinlich alle drei Container löschen und dann die Compose-Datei ausführen, oder?
                        dtp
                        #1931
                        ich habe die 5.0.0 seit einigen Tagen im Host-Modus laufen. Funktioniert soweit. Heute wollte ich allerdings einen Adapter neu installieren. Dabei bekam ich dann folgende Anzeigen:
                        Sprich der Hostname kann nicht aufgelöst werden.
                        Ein "iobroker host this" kann ich leider nicht durchführen, weil ich dazu den ioBroker stoppen müsste, aber dann ja nicht mehr ins Terminal komme.
                        Jemand eine Idee?
                        haselchenH Z andreA 3 Antworten Letzte Antwort
                        • D dtp
                          Jemand eine Idee?
                          haselchenH Offline
                          haselchenH Offline
                          haselchen
                          #1932
                          @dtp
                          Ist doch erfolgreich durchgelaufen.
                          Die Nichtauflösung habe ich auch, aber trotzdem läuft und installiert Iobroker alles.
                          Ansonsten , wenn es Dich stört und host this überhaupt was bringt, könnte man mit Putty arbeiten.
                          • D dtp
                            Jemand eine Idee?
                            Z Abwesend
                            Z Abwesend
                            zahnheinrich
                            #1933
                            @dtp
                            Sehr wohl kannst du im terminal den iobroker stoppen, versuche mal 'pkill io'.
                            Anschliessend dein 'host this...' im terminal.
                            Zum starten den ganzen container neu starten.
                            Ich denke du hast irrtümlich 'Container anhalten' verwechselt mit 'iobroker anhalten'.
                            MfG Ulrich
                            • Z zahnheinrich
                              @dtp
                              haselchenH Offline
                              haselchenH Offline
                              haselchen
                              #1934
                              @zahnheinrich
                              Kleine Anmerkung
                              Überarbeitung am 06.06.2020
                              Der Befehl zum Beenden des ioBrokers im Container wurde angepasst. Der bisherige Befehl „pkill io“ funktioniert seit Node 12 leider nicht mehr.
                              andreA 1 Antwort Letzte Antwort
                              • D dtp
                                Jemand eine Idee?
                                andreA Offline
                                andreA Offline
                                andre
                                #1935
                                @dtp sagte in [HowTo][Anleitung] Installation ioBroker in Docker auf Synology DiskStation:
                                Das ist ein alter Hut und daran wird sich nichts ändern bis der DSM eine aktuellere Kernel Version verwendet. Ohne Host Modus passiert das nicht.
                                Ich kann da persönlich nichts machen. Sorry.
                                MfG,
                                André
                                Bitte keine Support-Fragen per PN! Nutzt die öffentliche Kanäle damit auch andere von den Antworten profitieren können!
                                • haselchenH haselchen
                                  @zahnheinrich
                                  Kleine Anmerkung
                                  andreA Offline
                                  andreA Offline
                                  andre
                                  #1936
                                  @haselchen Korrekt. Bitte pkill -u iobroker oder pkill node verwenden.
                                  MfG,
                                  André
                                  • andreA andre
                                    MfG,
                                    André
                                    dtp
                                    #1937
                                    @andre sagte in [HowTo][Anleitung] Installation ioBroker in Docker auf Synology DiskStation:
                                    Okay. Heißt dann im Umkehrschluss, auch ein
                                    pkill -u iobroker
                                    iobroker host this
                                    würde nichts bewirken, oder? Da die Adapter ja erfolgreich installiert werden, dürfte es aber nicht so dramatisch sein. Dann lebe ich vorerst mit der Fehlermeldung.
                                    • D DrFirebird
                                      Hallo Andre,
                                      weißt Du ob Docker auf allen Synologys läuft ?
                                      Kann Docker im Packetzentrum nicht finden.
                                      Habe eine DS214
                                      Gruß,
                                      Michael
                                      da_WoodyD Offline
                                      da_WoodyD Offline
                                      da_Woody
                                      #1938
                                      @DrFirebird
                                      hi!
                                      nein, auf einer 214er läufts nicht, nur auf + nasen.
                                      auf der syno page gibts aber auch eine liste auf welchen docker läuft.
                                      wenns nicht angezeigt wird, wirds auch nicht unterstützt.
                                      gruß vom Woody
                                      • H Offline
                                        Hohenbostler
                                        #1939
                                        Hi zusammen. Ich habe seit einem Stromausfall irgendwie probleme. Ich komme gar nicht mehr auf die web oberfläche vom iobroker.
                                        Laut dem Error log gibt es irgendwie probleme mit dem jscontroller.
                                        Ich hoffe es kann mir jemand tipps geben wo das problem liegt ?
                                        107728690_3271107786278892_2680101610571426504_o.jpg 107714921_3271105862945751_6709430226335820759_o.jpg 1.PNG
                                          dtp
                                          #1940
                                          Das einfachste wäre wohl, den Container zu löschen und neu anzulegen. Ist ja ne Sache von fünf Minuten.
                                          H 1 Antwort Letzte Antwort
