  4. Rega Fehler
    6.4k
Rega Fehler
141 Beiträge 7 Kommentatoren 19.0k Aufrufe 5 Beobachtet
  • haselchenH haselchen
    @chris-d-0
    Auf keinen Fall unterbrechen oder Stromlos machen.
    Warte einfach mal ab....
    Chris-D 0
    schrieb am zuletzt editiert von Chris-D 0
    #61
    @haselchen danach passierte lange nichts und danach kam einfach eine neue Eingabezeile
    pi@raspberrypi:~ $ iobroker upgrade self
    Update js-controller from @2.2.8 to @3.3.15
    NPM version: 6.14.14
    npm install iobroker.js-controller@3.3.15 --unsafe-perm --loglevel error --prefix "/opt/iobroker" (System call)
    pi@raspberrypi:~ $
    • C Chris-D 0
      pi@raspberrypi:~ $
      haselchenH Offline
      haselchenH Offline
      haselchen
      #62
      @chris-d-0
      Gib mal in der Reihenfolge ein
      iobroker stop
      sudo -H -u iobroker npm install iobroker.js-controller
      iobroker start
      C 1 Antwort Letzte Antwort
        @chris-d-0
        iobroker stop
        iobroker start
        Chris-D 0
        #63
        @haselchen
        pi@raspberrypi:~ $ iobroker stop
        pi@raspberrypi:~ $
        pi@raspberrypi:~ $ sudo -H -u iobroker npm install iobroker.js-controller
        npm WARN checkPermissions Missing write access to /home/pi/node_modules/@iobroker
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents):
        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
        npm WARN enoent ENOENT: no such file or directory, open '/home/pi/package.json'
        npm WARN pi No description
        npm WARN pi No repository field.
        npm WARN pi No README data
        npm WARN pi No license field.
        npm ERR! code EACCES
        npm ERR! syscall access
        npm ERR! path /home/pi/node_modules/@iobroker
        npm ERR! errno -13
        npm ERR! Error: EACCES: permission denied, access '/home/pi/node_modules/@iobroker'
        npm ERR!  [Error: EACCES: permission denied, access '/home/pi/node_modules/@iobroker'] {
        npm ERR!   errno: -13,
        npm ERR!   code: 'EACCES',
        npm ERR!   syscall: 'access',
        npm ERR!   path: '/home/pi/node_modules/@iobroker'
        npm ERR! }
        npm ERR!
        npm ERR! The operation was rejected by your operating system.
        npm ERR! It is likely you do not have the permissions to access this file as the current user
        npm ERR!
        npm ERR! If you believe this might be a permissions issue, please double-check the
        npm ERR! permissions of the file and its containing directories, or try running
        npm ERR! the command again as root/Administrator.
        npm ERR!     /home/iobroker/.npm/_logs/2021-08-19T14_20_19_283Z-debug.log
        HomoranH haselchenH 3 Antworten Letzte Antwort
        • C Chris-D 0
          @haselchen
          pi@raspberrypi:~ $
          npm ERR! errno -13
          npm ERR! }
          npm ERR!
          npm ERR!
          #64
          @chris-d-0 sagte in Rega Fehler:
          was hast du da angestellt?
          den npm-Befehl in /home/pi ausgeführt???
          der muss in /opt/iobroker ausgeführt werden
          • C Chris-D 0
            @haselchen
            pi@raspberrypi:~ $
            npm ERR! errno -13
            npm ERR! }
            npm ERR!
            npm ERR!
            haselchenH Offline
            haselchenH Offline
            haselchen
            #65
            @chris-d-0
            cd /opt/iobroker
            Edit:
            sehe ich jetzt erst....wo zum Himmel hast du das alles hin installiert?
              Chris-D 0
              #66
              @homoran @haselchen Nicht bewusst
              • C Chris-D 0
                @haselchen
                pi@raspberrypi:~ $
                npm ERR! errno -13
                npm ERR! }
                npm ERR!
                npm ERR!
                #67
                da bist du in deinem Home Verzeichnis
                Wie man da die Installation wieder rausbekommt weiß ich nicht.
                Du musst vorher ein cd /opt/iobroker machen bevor du den npm-Befehl absetzst
                  Chris-D 0
                  #68
                  @homoran @haselchen Holy...
                  pi@raspberrypi:~ $ cd /opt/iobroker
                  pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
                  npm WARN read-shrinkwrap This version of npm is compatible with lockfileVersion@1, but package-lock.json was generated for lockfileVersion@2. I'll try to do my best with it!
                  > iobroker.js-controller@2.2.10 preinstall /opt/iobroker/node_modules/iobroker.js-controller
                  > node lib/preinstallCheck.js
                  > unix-dgram@2.0.3 install /opt/iobroker/node_modules/unix-dgram
                  > node-gyp rebuild
                  make: Verzeichnis „/opt/iobroker/node_modules/unix-dgram/build“ wird betreten
                    CXX(target) Release/obj.target/unix_dgram/src/unix_dgram.o
                  In file included from ../src/unix_dgram.cc:5:
                  ../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:
                  ../../nan/nan.h:2294:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                       , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)
                  In file included from ../../nan/nan.h:56,
                  ../src/unix_dgram.cc: At global scope:
                  /home/iobroker/.cache/node-gyp/14.17.5/include/node/node.h:758:43: warning: cast between incompatible function types from ‘void (*)(v8::Local<v8::Object>)’ to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
                         (node::addon_register_func) (regfunc),                          \
                  /home/iobroker/.cache/node-gyp/14.17.5/include/node/node.h:792:3: note: in expansion of macro ‘NODE_MODULE_X’
                     NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
                  ../src/unix_dgram.cc:404:1: note: in expansion of macro ‘NODE_MODULE’
                   NODE_MODULE(unix_dgram, Initialize)
                    SOLINK_MODULE(target) Release/obj.target/unix_dgram.node
                    COPY Release/unix_dgram.node
                  make: Verzeichnis „/opt/iobroker/node_modules/unix-dgram/build“ wird verlassen
                  > ursa-optional@0.9.10 install /opt/iobroker/node_modules/ursa-optional
                  > node rebuild.js
                  ursaNative bindings compilation fail. This is not an issue. Modules that depend on it will use fallbacks.
                  > @serialport/bindings@9.2.0 install /opt/iobroker/node_modules/@serialport/bindings
                  > prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
                  prebuild-install WARN install No prebuilt binaries found (target=14.17.5 runtime=node arch=arm libc= platform=linux)
                  make: Verzeichnis „/opt/iobroker/node_modules/@serialport/bindings/build“ wird betreten
                    CXX(target) Release/obj.target/bindings/src/serialport.o
                  ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Open(Nan::NAN_METHOD_ARGS_TYPE)’:
                  ../src/serialport.cpp:78:69: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                     uv_queue_work(uv_default_loop(), req, EIO_Open, (uv_after_work_cb)EIO_AfterOpen);
                  ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)’:
                  ../src/serialport.cpp:135:71: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                     uv_queue_work(uv_default_loop(), req, EIO_Update, (uv_after_work_cb)EIO_AfterUpdate);
                  ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Close(Nan::NAN_METHOD_ARGS_TYPE)’:
                  ../src/serialport.cpp:175:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                     uv_queue_work(uv_default_loop(), req, EIO_Close, (uv_after_work_cb)EIO_AfterClose);
                  ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Flush(Nan::NAN_METHOD_ARGS_TYPE)’:
                  ../src/serialport.cpp:215:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                     uv_queue_work(uv_default_loop(), req, EIO_Flush, (uv_after_work_cb)EIO_AfterFlush);
                  ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_METHOD_ARGS_TYPE)’:
                  ../src/serialport.cpp:271:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                     uv_queue_work(uv_default_loop(), req, EIO_Set, (uv_after_work_cb)EIO_AfterSet);
                  ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Get(Nan::NAN_METHOD_ARGS_TYPE)’:
                  ../src/serialport.cpp:316:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                     uv_queue_work(uv_default_loop(), req, EIO_Get, (uv_after_work_cb)EIO_AfterGet);
                  ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE GetBaudRate(Nan::NAN_METHOD_ARGS_TYPE)’:
                  ../src/serialport.cpp:366:76: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                     uv_queue_work(uv_default_loop(), req, EIO_GetBaudRate, (uv_after_work_cb)EIO_AfterGetBaudRate);
                  ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Drain(Nan::NAN_METHOD_ARGS_TYPE)’:
                  ../src/serialport.cpp:412:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                     uv_queue_work(uv_default_loop(), req, EIO_Drain, (uv_after_work_cb)EIO_AfterDrain);
                  ../src/serialport.cpp: At global scope:
                  ../src/serialport.cpp:433:28: warning: unnecessary parentheses in declaration of ‘ToParityEnum’ [-Wparentheses]
                   SerialPortParity NAN_INLINE(ToParityEnum(const v8::Local<v8::String>& v8str)) {
                  ../src/serialport.cpp:452:30: warning: unnecessary parentheses in declaration of ‘ToStopBitEnum’ [-Wparentheses]
                   SerialPortStopBits NAN_INLINE(ToStopBitEnum(double stopBits)) {
                  In file included from ../node_modules/nan/nan.h:58,
                                   from ../src/./serialport.h:13,
                                   from ../src/serialport.cpp:1:
                  /home/iobroker/.cache/node-gyp/14.17.5/include/node/node.h:758:43: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
                  ../src/serialport.cpp:486:1: note: in expansion of macro ‘NODE_MODULE’
                   NODE_MODULE(serialport, init);
                    CXX(target) Release/obj.target/bindings/src/serialport_unix.o
                  ../src/serialport_unix.cpp: In function ‘int setup(int, OpenBaton*)’:
                  ../src/serialport_unix.cpp:176:60: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1005 [-Wformat-truncation=]
                       snprintf(data->errorString, sizeof(data->errorString), "Error %s Cannot open %s", strerror(errno), data->path);
                  ../src/serialport_unix.cpp:176:13: note: ‘snprintf’ output 20 or more bytes (assuming 1043) into a destination of size 1024
                  ../src/serialport_unix.cpp: In function ‘void EIO_Open(uv_work_t*)’:
                  ../src/serialport_unix.cpp:86:60: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1003 [-Wformat-truncation=]
                       snprintf(data->errorString, sizeof(data->errorString), "Error: %s, cannot open %s", strerror(errno), data->path);
                  ../src/serialport_unix.cpp:86:13: note: ‘snprintf’ output 22 or more bytes (assuming 1045) into a destination of size 1024
                    CXX(target) Release/obj.target/bindings/src/poller.o
                    CXX(target) Release/obj.target/bindings/src/serialport_linux.o
                    SOLINK_MODULE(target) Release/obj.target/bindings.node
                    COPY Release/bindings.node
                  make: Verzeichnis „/opt/iobroker/node_modules/@serialport/bindings/build“ wird verlassen
                  > sharp@0.28.1 install /opt/iobroker/node_modules/sharp
                  > (node install/libvips && node install/dll-copy && prebuild-install) || (node-gyp rebuild && node install/dll-copy)
                  sharp: Using cached /home/iobroker/.npm/_libvips/libvips-8.10.6-linux-armv7.tar.br
                  prebuild-install WARN install No prebuilt binaries found (target=3 runtime=napi arch=arm libc= platform=linux)
                  make: Verzeichnis „/opt/iobroker/node_modules/sharp/build“ wird betreten
                    CC(target) Release/obj.target/nothing/../node-addon-api/nothing.o
                    AR(target) Release/obj.target/../node-addon-api/nothing.a
                    COPY Release/nothing.a
                    TOUCH Release/obj.target/libvips-cpp.stamp
                    CXX(target) Release/obj.target/sharp/src/common.o
                    CXX(target) Release/obj.target/sharp/src/metadata.o
                    CXX(target) Release/obj.target/sharp/src/stats.o
                    CXX(target) Release/obj.target/sharp/src/operations.o
                    CXX(target) Release/obj.target/sharp/src/pipeline.o
                    CXX(target) Release/obj.target/sharp/src/utilities.o
                    CXX(target) Release/obj.target/sharp/src/sharp.o
                    SOLINK_MODULE(target) Release/obj.target/sharp.node
                    COPY Release/sharp.node
                  make: Verzeichnis „/opt/iobroker/node_modules/sharp/build“ wird verlassen
                  > canvas@2.8.0 install /opt/iobroker/node_modules/canvas
                  > node-pre-gyp install --fallback-to-build
                  node-pre-gyp ERR! install response status 404 Not Found on https://github.com/Automattic/node-canvas/releases/download/v2.8.0/canvas-v2.8.0-node-v83-linux-glibc-arm.tar.gz
                  node-pre-gyp WARN Pre-built binaries not installable for canvas@2.8.0 and node@14.17.5 (node-v83 ABI, glibc) (falling back to source compile with node-gyp)
                  node-pre-gyp WARN Hit error response status 404 Not Found on https://github.com/Automattic/node-canvas/releases/download/v2.8.0/canvas-v2.8.0-node-v83-linux-glibc-arm.tar.gz
                  make: Verzeichnis „/opt/iobroker/node_modules/canvas/build“ wird betreten
                    SOLINK_MODULE(target) Release/obj.target/canvas-postbuild.node
                    COPY Release/canvas-postbuild.node
                    CXX(target) Release/obj.target/canvas/src/backend/Backend.o
                    CXX(target) Release/obj.target/canvas/src/backend/ImageBackend.o
                    CXX(target) Release/obj.target/canvas/src/backend/PdfBackend.o
                    CXX(target) Release/obj.target/canvas/src/backend/SvgBackend.o
                    CXX(target) Release/obj.target/canvas/src/bmp/BMPParser.o
                  ../src/bmp/BMPParser.cc: In member function ‘void BMPParser::Parser::parse(uint8_t*, int, uint8_t*)’:
                  ../src/bmp/BMPParser.cc:186:16: warning: comparison of integer expressions of different signedness: ‘int’ and ‘unsigned int’ [-Wsign-compare]
                     E(ptr - data > imgdOffset, "image data overlaps with another structure");
                  ../src/bmp/BMPParser.cc:10:25: note: in definition of macro ‘E’
                   #define E(cond, msg) if(cond) return setErr(msg)
                  ../src/bmp/BMPParser.cc:201:27: warning: comparison of integer expressions of different signedness: ‘uint32_t’ {aka ‘unsigned int’} and ‘int’ [-Wsign-compare]
                     E(ptr - data + imgdSize > len, "not enough image data");
                    CXX(target) Release/obj.target/canvas/src/Backends.o
                    CXX(target) Release/obj.target/canvas/src/Canvas.o
                    CXX(target) Release/obj.target/canvas/src/CanvasGradient.o
                    CXX(target) Release/obj.target/canvas/src/CanvasPattern.o
                    CXX(target) Release/obj.target/canvas/src/CanvasRenderingContext2d.o
                    CXX(target) Release/obj.target/canvas/src/closure.o
                    CXX(target) Release/obj.target/canvas/src/color.o
                    CXX(target) Release/obj.target/canvas/src/Image.o
                    CXX(target) Release/obj.target/canvas/src/ImageData.o
                    CXX(target) Release/obj.target/canvas/src/init.o
                    CXX(target) Release/obj.target/canvas/src/register_font.o
                    SOLINK_MODULE(target) Release/obj.target/canvas.node
                    COPY Release/canvas.node
                  make: Verzeichnis „/opt/iobroker/node_modules/canvas/build“ wird verlassen
                  > diskusage@1.1.3 install /opt/iobroker/node_modules/diskusage
                  > node-gyp rebuild
                  make: Verzeichnis „/opt/iobroker/node_modules/diskusage/build“ wird betreten
                    CXX(target) Release/obj.target/diskusage/src/main.o
                  In file included from ../src/main.cpp:3:
                  ../src/main.cpp: At global scope:
                  ../src/main.cpp:42:1: note: in expansion of macro ‘NODE_MODULE’
                   NODE_MODULE(diskusage, Init)
                    CXX(target) Release/obj.target/diskusage/src/diskusage_posix.o
                    SOLINK_MODULE(target) Release/obj.target/diskusage.node
                    COPY Release/diskusage.node
                  make: Verzeichnis „/opt/iobroker/node_modules/diskusage/build“ wird verlassen
                  > iobroker@2.0.3 install /opt/iobroker/node_modules/iobroker
                  > node lib/checkVersions.js
                  > iobroker.vis@1.4.3 install /opt/iobroker/node_modules/iobroker.vis
                  > node main.js --install
                  > iobroker.js-controller@2.2.10 install /opt/iobroker/node_modules/iobroker.js-controller
                  > node iobroker.js setup first
                  The following notifications happened during sync:
                  - Ignoring Directory "hm-rega" because officially not created as meta object. Please remove directory!
                  > acme-v2@1.8.6 postinstall /opt/iobroker/node_modules/acme-v2
                  > node scripts/postinstall
                  Greenlock and ACME.js v3 are on the way!
                  Watch for updates at https://indiegogo.com/at/greenlock
                  > iobroker@2.0.3 postinstall /opt/iobroker/node_modules/iobroker
                  > node lib/install.js
                  │ Manual installation of ioBroker is no longer supported  │
                  │ on Linux, OSX and FreeBSD!                              │
                  │ Please refer to the documentation on how to install it! │
                  │ https://github.com/ioBroker/ioBroker/wiki/Installation  │
                  npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.7 (node_modules/osx-temperature-sensor):
                  npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                  npm ERR! code ELIFECYCLE
                  npm ERR! errno 100
                  npm ERR! iobroker@2.0.3 postinstall: `node lib/install.js`
                  npm ERR! Exit status 100
                  npm ERR!
                  npm ERR! Failed at the iobroker@2.0.3 postinstall script.
                  npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
                  npm ERR!     /home/iobroker/.npm/_logs/2021-08-19T14_49_50_171Z-debug.log
                  • C Chris-D 0
                    > node-gyp rebuild
                    > node rebuild.js
                    > node-gyp rebuild
                    > node lib/install.js
                    npm ERR! errno 100
                    npm ERR!
                    #69
                    oops - passt das irgendwie??
                    npm ERR! errno 100 npm ERR! iobroker@2.0.3 postinstall: node lib/install.js npm ERR! Exit status 100
                    was ist denn da jetzt faul?
                    iobroker stop
                    iobroker fix
                    iobroker start
                    C 2 Antworten Letzte Antwort
                      iobroker stop
                      iobroker fix
                      iobroker start
                      Chris-D 0
                      #70
                      @homoran said in Rega Fehler:
                      euhm keine Ahnung
                        iobroker stop
                        iobroker fix
                        iobroker start
                        Chris-D 0
                        #71
                        iobroker stop
                        iobroker fix
                        mache ich
                        iobroker start
                        • C Chris-D 0
                          iobroker stop
                          iobroker fix
                          mache ich
                          iobroker start
                          Chris-D 0
                          #72
                          @Homoran
                          pi@raspberrypi:~ $ iobroker start
                          pi@raspberrypi:~ $ iobroker update -i
                          hash changed or no sources cached => force download of new sources
                          update done
                          Adapter    "admin"         : 5.1.23   , installed 5.1.23
                          Adapter    "backitup"      : 2.1.13   , installed 2.1.13
                          Adapter    "cloud"         : 4.1.0    , installed 4.1.0
                          Adapter    "discovery"     : 2.7.0    , installed 2.7.0
                          Adapter    "echarts"       : 0.4.13   , installed 0.4.13
                          Adapter    "email"         : 1.0.10   , installed 1.0.10
                          Adapter    "fb-checkpresence": 1.1.7   , installed 1.1.7
                          Adapter    "fritzdect"     : 2.1.15   , installed 2.1.15
                          Adapter    "habpanel"      : 0.4.3    , installed 0.4.3
                          Adapter    "history"       : 1.9.13   , installed 1.9.13
                          Adapter    "hm-rega"       : 3.0.29   , installed 3.0.29
                          Adapter    "hm-rpc"        : 1.14.43  , installed 1.14.43
                          Adapter    "ical"          : 1.11.2   , installed 1.11.2
                          Adapter    "info"          : 1.9.8    , installed 1.9.8
                          Adapter    "iot"           : 1.8.22   , installed 1.8.22
                          Adapter    "javascript"    : 5.2.8    , installed 5.2.8
                          Controller "js-controller" : 3.3.15   , installed 2.2.10 [Updateable]
                          Adapter    "material"      : 1.0.4    , installed 1.0.4
                          Adapter    "mobile"        : 1.0.1    , installed 1.0.1
                          Adapter    "openweathermap": 0.1.0    , installed 0.1.0
                          Adapter    "ping"          : 1.5.0    , installed 1.5.0
                          Adapter    "samsung"       : 0.2.9    , installed 0.2.9
                          Adapter    "simple-api"    : 2.6.1    , installed 2.6.1
                          Adapter    "socketio"      : 3.1.4    , installed 3.1.4
                          Adapter    "sonos"         : 2.1.1    , installed 2.1.1
                          Adapter    "synology"      : 1.0.0    , installed 1.0.0
                          Adapter    "telegram"      : 1.10.0   , installed 1.10.0
                          Adapter    "tr-064"        : 4.2.14   , installed 4.2.14
                          Adapter    "viessmann"     : 1.3.4    , installed 1.3.4
                          Adapter    "vis"           : 1.4.3    , installed 1.4.3
                          Adapter    "web"           : 3.4.7    , installed 3.4.7
                          Adapter    "whatsapp-cmb"  : 0.1.6    , installed 0.1.6
                          • C Chris-D 0
                            @Homoran
                            update done
                            #73
                            @chris-d-0
                            iobroker stop
                            iobroker update
                            Komplette Ein- und Ausgaben posten.
                              @chris-d-0
                              iobroker stop
                              iobroker update
                              Chris-D 0
                              #74
                              @thomas-braun said in Rega Fehler:
                              iobroker stop iobroker update iobroker upgrade self
                              update done
                              Adapter    "airconwithme"  : 0.0.3
                              Adapter    "airzone"       : 1.0.4
                              Adapter    "alarm"         : 2.0.2
                              Adapter    "alexa2"        : 3.9.3
                              Adapter    "alias-manager" : 1.2.3
                              Adapter    "alpha2"        : 1.0.0
                              Adapter    "amazon-dash"   : 1.1.0
                              Adapter    "artnet"        : 1.2.2
                              Adapter    "asterisk"      : 1.0.6
                              Adapter    "asuswrt"       : 1.0.1
                              Adapter    "b-control-em"  : 0.2.1
                              Adapter    "beckhoff"      : 1.4.1
                              Adapter    "benq"          : 0.2.4
                              Adapter    "binance"       : 1.1.3
                              Adapter    "ble"           : 0.12.0
                              Adapter    "bluelink"      : 1.0.7
                              Adapter    "bmw"           : 2.0.0
                              Adapter    "bosesoundtouch": 0.10.0
                              Adapter    "botvac"        : 1.0.0
                              Adapter    "bring"         : 1.7.7
                              Adapter    "broadlink2"    : 2.0.3
                              Adapter    "bsblan"        : 0.2.2
                              Adapter    "bshb"          : 0.1.13
                              Adapter    "bydbatt"       : 1.0.5
                              Adapter    "bydhvs"        : 1.2.3
                              Adapter    "chromecast"    : 2.3.1
                              Adapter    "comfoair"      : 1.1.3
                              Adapter    "contactid"     : 1.0.2
                              Adapter    "coronavirus-statistics": 0.6.3
                              Adapter    "countdown"     : 1.2.3
                              Adapter    "cul"           : 1.3.5
                              Adapter    "daikin"        : 1.3.3
                              Adapter    "daswetter"     : 3.0.7
                              Adapter    "deconz"        : 1.3.19
                              Adapter    "denon"         : 1.11.2
                              Adapter    "device-reminder": 1.2.9
                              Adapter    "devices"       : 1.0.9
                              Adapter    "digitalstrom"  : 2.2.1
                              Adapter    "discovergy"    : 0.5.4
                              Adapter    "divera247"     : 0.1.2
                              Adapter    "doorio"        : 2.0.1
                              Adapter    "ds18b20"       : 1.4.1
                              Adapter    "dwd"           : 2.7.7
                              Adapter    "dysonairpurifier": 0.9.2
                              Adapter    "easee"         : 1.0.2
                              Adapter    "ebus"          : 2.2.5
                              Adapter    "ecovacs-deebot": 1.2.1
                              Adapter    "egigeozone"    : 0.1.2
                              Adapter    "ekey"          : 1.1.0
                              Adapter    "emby"          : 1.0.2
                              Adapter    "energymanager" : 1.3.3
                              Adapter    "enet"          : 1.0.1
                              Adapter    "epson_ecotank_et_2750": 0.0.5
                              Adapter    "epson_stylus_px830": 0.2.1
                              Adapter    "epson_xp540"   : 1.0.6
                              Adapter    "exchangerates" : 0.0.14
                              Adapter    "fahrplan"      : 1.0.7
                              Adapter    "fakeroku"      : 0.2.1
                              Adapter    "feiertage"     : 1.0.17
                              Adapter    "fhem"          : 1.6.1
                              Adapter    "find-my-iphone": 0.2.15
                              Adapter    "firetv"        : 1.0.0
                              Adapter    "flot"          : 1.10.6
                              Adapter    "followthesun"  : 0.3.5
                              Adapter    "foobar2000"    : 2.0.4
                              Adapter    "fritzbox"      : 0.2.1
                              Adapter    "fronius"       : 1.0.5
                              Adapter    "frontier_silicon": 0.0.10
                              Adapter    "fuelpricemonitor": 0.2.6
                              Adapter    "fullcalendar"  : 1.1.0
                              Adapter    "fullybrowser"  : 2.0.8
                              Adapter    "g-homa"        : 0.5.3
                              Adapter    "geofency"      : 1.0.3
                              Adapter    "go-e"          : 1.0.15
                              Adapter    "growatt"       : 1.0.1
                              Adapter    "gruenbeck"     : 0.0.30
                              Adapter    "haassohn"      : 1.0.4
                              Adapter    "haier"         : 1.0.4
                              Adapter    "ham"           : 4.0.2
                              Adapter    "ham-wemo"      : 2.0.0
                              Adapter    "harmony"       : 1.2.2
                              Adapter    "heatingcontrol": 2.4.3
                              Adapter    "heos"          : 1.8.6
                              Adapter    "heytech"       : 1.0.0
                              Adapter    "hid"           : 0.1.17
                              Adapter    "hmip"          : 1.13.0
                              Adapter    "homeconnect"   : 0.0.36
                              Adapter    "homee"         : 1.2.0
                              Adapter    "homepilot"     : 1.0.3
                              Adapter    "hp-ilo"        : 1.0.6
                              Adapter    "hs100"         : 2.0.6
                              Adapter    "hue"           : 3.5.19
                              Adapter    "hue-extended"  : 2.0.0
                              Adapter    "i2c"           : 1.2.0
                              Adapter    "icons-addictive-flavour-png": 0.1.0
                              Adapter    "icons-fatcow-hosting": 0.1.0
                              Adapter    "icons-icons8"  : 0.0.1
                              Adapter    "icons-material-png": 0.1.0
                              Adapter    "icons-material-svg": 0.1.0
                              Adapter    "icons-mfd-png" : 1.0.2
                              Adapter    "icons-mfd-svg" : 1.0.2
                              Adapter    "icons-open-icon-library-png": 0.1.2
                              Adapter    "icons-ultimate-png": 1.0.1
                              Adapter    "influxdb"      : 1.9.5
                              Adapter    "innogy-smarthome": 0.3.7
                              Adapter    "iogo"          : 0.7.0
                              Adapter    "iqontrol"      : 1.8.2
                              Adapter    "jarvis"        : 2.2.1
                              Adapter    "jeelink"       : 0.1.0
                              Adapter    "kecontact"     : 1.2.3
                              Adapter    "klf200"        : 1.0.1
                              Adapter    "km200"         : 1.1.6
                              Adapter    "knmi-weather"  : 1.0.0
                              Adapter    "knx"           : 1.0.45
                              Adapter    "kodi"          : 2.0.5
                              Adapter    "kostal-piko-ba": 1.1.9
                              Adapter    "kress"         : 2.5.5
                              Adapter    "lametric"      : 1.3.2
                              Adapter    "landroid"      : 1.0.3
                              Adapter    "lcn"           : 1.0.2
                              Adapter    "legrand-ecocompteur": 1.0.0
                              Adapter    "letrika_comgw" : 0.0.5
                              Adapter    "lg-ess-home"   : 0.0.10
                              Adapter    "lgtv"          : 1.1.10
                              Adapter    "lgtv-rs"       : 0.1.1
                              Adapter    "lgtv11"        : 1.0.5
                              Adapter    "lifx"          : 0.1.0
                              Adapter    "lightify"      : 0.2.16
                              Adapter    "link"          : 0.5.10
                              Adapter    "linkeddevices" : 1.4.3
                              Adapter    "linktap"       : 0.1.8
                              Adapter    "linux-control" : 1.1.2
                              Adapter    "logparser"     : 1.1.0
                              Adapter    "lovelace"      : 2.0.4
                              Adapter    "loxone"        : 2.2.3
                              Adapter    "luftdaten"     : 1.0.3
                              Adapter    "lupusec"       : 1.3.5
                              Adapter    "luxtronik1"    : 0.3.1
                              Adapter    "maxcube"       : 1.0.4
                              Adapter    "maxcul"        : 1.3.1
                              Adapter    "mbus"          : 2.3.4
                              Adapter    "mclighting"    : 0.1.2
                              Adapter    "megad"         : 1.2.1
                              Adapter    "megadd"        : 0.2.0
                              Adapter    "megaesp"       : 0.1.0
                              Adapter    "melcloud"      : 1.1.4
                              Adapter    "mercedesme"    : 0.0.54
                              Adapter    "mercury"       : 0.1.4
                              Adapter    "meross"        : 1.6.3
                              Adapter    "meteoalarm"    : 2.0.2
                              Adapter    "midea"         : 0.0.6
                              Adapter    "miele"         : 0.1.5
                              Adapter    "mielecloudservice": 4.2.0
                              Adapter    "mihome"        : 1.3.7
                              Adapter    "mihome-lamp"   : 1.1.0
                              Adapter    "mihome-plug"   : 0.2.1
                              Adapter    "mihome-vacuum" : 3.2.2
                              Adapter    "mikrotik"      : 1.0.16
                              Adapter    "milight"       : 0.3.6
                              Adapter    "milight-smart-light": 1.2.0
                              Adapter    "minuvis"       : 1.4.0
                              Adapter    "modbus"        : 3.4.11
                              Adapter    "moma"          : 1.2.8
                              Adapter    "mpd"           : 1.0.6
                              Adapter    "mqtt"          : 2.4.0
                              Adapter    "mqtt-client"   : 1.4.0
                              Adapter    "musiccast"     : 0.1.5
                              Adapter    "mydlink"       : 1.1.12
                              Adapter    "mysensors"     : 2.0.1
                              Adapter    "nanoleaf-lightpanels": 1.2.0
                              Adapter    "net-tools"     : 0.1.5
                              Adapter    "netatmo"       : 1.4.3
                              Adapter    "netatmo-crawler": 0.5.1
                              Adapter    "nibeuplink"    : 0.4.0
                              Adapter    "nina"          : 0.0.25
                              Adapter    "node-red"      : 2.4.0
                              Adapter    "nuki"          : 1.5.0
                              Adapter    "nuki-extended" : 2.3.1
                              Adapter    "nut"           : 1.5.0
                              Adapter    "octoprint"     : 1.1.1
                              Adapter    "odl"           : 1.1.4
                              Adapter    "oilfox"        : 0.0.5
                              Adapter    "omnicomm-lls"  : 0.0.7
                              Adapter    "onkyo"         : 2.1.0
                              Adapter    "onvif"         : 0.4.4
                              Adapter    "openhab"       : 1.1.0
                              Adapter    "openligadb"    : 1.1.0
                              Adapter    "opi"           : 0.1.1
                              Adapter    "oppoplayer"    : 0.2.4
                              Adapter    "owfs"          : 0.6.4
                              Adapter    "owntracks"     : 1.0.0
                              Adapter    "panasonic-viera": 1.0.2
                              Adapter    "parser"        : 1.0.7
                              Adapter    "paw"           : 0.0.7
                              Adapter    "pegelalarm"    : 1.2.0
                              Adapter    "ph803w"        : 1.0.1
                              Adapter    "phantomjs"     : 1.1.2
                              Adapter    "pi-hole"       : 1.3.2
                              Adapter    "piface"        : 1.0.0
                              Adapter    "pimatic"       : 0.3.0
                              Adapter    "places"        : 1.0.0
                              Adapter    "plenticore"    : 2.2.0
                              Adapter    "plex"          : 0.8.11
                              Adapter    "plexconnect"   : 0.0.7
                              Adapter    "pollenflug"    : 1.0.6
                              Adapter    "proxmox"       : 1.3.3
                              Adapter    "proxy"         : 1.2.2
                              Adapter    "pushbullet"    : 0.0.11
                              Adapter    "pushover"      : 2.0.5
                              Adapter    "pushsafer"     : 1.0.3
                              Adapter    "radar2"        : 1.0.9
                              Adapter    "radiohead"     : 1.1.1
                              Adapter    "rflink"        : 2.1.6
                              Adapter    "rickshaw"      : 1.0.0
                              Adapter    "ring"          : 1.2.3
                              Adapter    "robonect"      : 0.1.3
                              Adapter    "roomba"        : 1.1.1
                              Adapter    "rpi2"          : 1.3.1
                              Adapter    "s7"            : 1.3.6
                              Adapter    "sainlogic"     : 0.7.2
                              Adapter    "sanext"        : 0.0.5
                              Adapter    "sayit"         : 1.12.3
                              Adapter    "sbfspot"       : 4.0.5
                              Adapter    "scenes"        : 2.3.6
                              Adapter    "schoolfree"    : 1.0.0
                              Adapter    "schwoerer-ventcube": 1.4.2
                              Adapter    "seq"           : 0.2.10
                              Adapter    "shelly"        : 4.0.7
                              Adapter    "shuttercontrol": 1.2.0
                              Adapter    "sia"           : 1.0.4
                              Adapter    "siegenia"      : 1.1.1
                              Adapter    "smappee"       : 0.2.5
                              Adapter    "smartcontrol"  : 1.2.1
                              Adapter    "smartgarden"   : 1.0.5
                              Adapter    "smartmeter"    : 3.2.1
                              Adapter    "snips"         : 1.5.1
                              Adapter    "snmp"          : 0.5.0
                              Adapter    "solarlog"      : 2.1.3
                              Adapter    "solarviewdatareader": 1.0.2
                              Adapter    "solarwetter"   : 1.0.0
                              Adapter    "sonnen"        : 1.9.4
                              Adapter    "sonoff"        : 2.4.5
                              Adapter    "sony-bravia"   : 1.0.1
                              Adapter    "spotify-premium": 1.0.0
                              Adapter    "sprinklecontrol": 0.1.7
                              Adapter    "sql"           : 1.15.7
                              Adapter    "squeezebox"    : 1.0.0
                              Adapter    "squeezeboxrpc" : 1.3.4
                              Adapter    "starline"      : 1.1.3
                              Adapter    "statistics"    : 1.0.9
                              Adapter    "stiebel-isg"   : 1.7.3
                              Adapter    "sunnyportal"   : 0.1.5
                              Adapter    "swiss-weather-api": 0.9.7
                              Adapter    "systeminfo"    : 0.3.1
                              Adapter    "tado"          : 0.3.4
                              Adapter    "tahoma"        : 0.4.3
                              Adapter    "tankerkoenig"  : 2.1.1
                              Adapter    "terminal"      : 0.1.2
                              Adapter    "tesla-motors"  : 0.5.2
                              Adapter    "text2command"  : 2.1.1
                              Adapter    "tinker"        : 1.1.0
                              Adapter    "traccar"       : 0.0.9
                              Adapter    "tradfri"       : 2.7.4
                              Adapter    "trashschedule" : 1.2.0
                              Adapter    "trivum"        : 0.0.4
                              Adapter    "tunnelbroker-endpoint-updater": 0.0.1
                              Adapter    "tuya"          : 3.6.5
                              Adapter    "tvprogram"     : 1.1.0
                              Adapter    "tvspielfilm"   : 1.0.4
                              Adapter    "unifi"         : 0.5.10
                              Adapter    "upnp"          : 1.0.19
                              Adapter    "vaillant"      : 0.0.13
                              Adapter    "valloxmv"      : 1.1.3
                              Adapter    "vcard"         : 0.0.9
                              Adapter    "velux"         : 0.0.7
                              Adapter    "virtualpowermeter": 1.4.2
                              Adapter    "vis-bars"      : 0.1.4
                              Adapter    "vis-canvas-gauges": 0.1.5
                              Adapter    "vis-colorpicker": 1.2.0
                              Adapter    "vis-fancyswitch": 1.1.0
                              Adapter    "vis-google-fonts": 0.1.0
                              Adapter    "vis-history"   : 1.0.0
                              Adapter    "vis-hqwidgets" : 1.1.7
                              Adapter    "vis-icontwo"   : 0.77.0
                              Adapter    "vis-inventwo"  : 3.0.11
                              Adapter    "vis-jqui-mfd"  : 1.0.12
                              Adapter    "vis-justgage"  : 1.0.2
                              Adapter    "vis-keyboard"  : 0.0.2
                              Adapter    "vis-lcars"     : 1.0.4
                              Adapter    "vis-map"       : 1.0.4
                              Adapter    "vis-material-advanced": 1.7.0
                              Adapter    "vis-metro"     : 1.1.2
                              Adapter    "vis-players"   : 0.1.6
                              Adapter    "vis-plumb"     : 1.0.2
                              Adapter    "vis-rgraph"    : 0.0.2
                              Adapter    "vis-timeandweather": 1.1.7
                              Adapter    "vis-weather"   : 2.5.3
                              Adapter    "volumio"       : 0.1.2
                              Adapter    "volvo"         : 0.0.4
                              Adapter    "vr200"         : 1.0.0
                              Adapter    "vw-connect"    : 0.0.39
                              Adapter    "weatherflow_udp": 0.1.1
                              Adapter    "weatherunderground": 3.3.1
                              Adapter    "weishaupt-wem" : 0.0.9
                              Adapter    "wiffi-wz"      : 2.2.0
                              Adapter    "wifilight"     : 1.1.0
                              Adapter    "windows-control": 0.1.5
                              Adapter    "wled"          : 0.5.6
                              Adapter    "wm-bus"        : 0.1.12
                              Adapter    "wolf"          : 1.2.1
                              Adapter    "wolf-smartset" : 1.0.0
                              Adapter    "worx"          : 1.4.3
                              Adapter    "xbox"          : 0.7.7
                              Adapter    "xs1"           : 1.0.2
                              Adapter    "yahka"         : 0.12.0
                              Adapter    "yamaha"        : 0.4.0
                              Adapter    "yeelight-2"    : 1.0.3
                              Adapter    "youtube"       : 1.1.1
                              Adapter    "yr"            : 3.0.5
                              Adapter    "zigbee"        : 1.5.6
                              Adapter    "zont"          : 0.5.3
                              Adapter    "zwave2"        : 1.10.2
                              Update js-controller from @2.2.10 to @3.3.15
                              npm install iobroker.js-controller@3.3.15 --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call)
                              ACHTUNG: Die Fehlerberichterstattung über Sentry wird beim nächsten Start von ioBroker aktiviert
                              Wir von ioBroker wollen das stabilste Smart-Home-System bereitstellen.
                              Um dies zu ermöglichen, haben wir uns entschlossen, eine automatische Fehler- und Crash-Reporting-Lösung in den js-Controller und auch in Adapter zu implementieren.
                              DIESE BERICHTERSTATTUNG WIRD MIT DEM NÄCHSTEN START IHRES IOBROKERS AKTIVIERT!
                              Bei Fehlern, die zum Absturz des js-Controllers oder eines der relevanten Adapter führen, werden die Fehlerdetails an einen Server gesendet. Für den js-controller und die Haupt-Adapter befindet sich dieser Server in Deutschland. Informationen zu Community-Adaptern sind in der Github-Readme-Datei des betroffenen Adapters zu finden. Dort steht welcher Sentry-Server verwendet wird.
                              Die Fehlerberichterstattung kann, falls gewünscht, über den Befehl
                              'iobroker plugin disable sentry'
                              deaktiviert werden. Dieser Befehl stellt auch sicher, dass kein Adapter, der auf diesem Host ausgeführt wird, Absturzberichtsdaten an den Sentry-Server sendet.
                              npm ERR! errno 100
                              npm ERR!
                              npm ERR!     /home/iobroker/.npm/_logs/2021-08-19T15_22_55_970Z-debug.log
                              host.raspberrypi Cannot install iobroker.js-controller@3.3.15: 100
                              • C Chris-D 0
                                update done
                                npm ERR! errno 100
                                npm ERR!
                                #75
                                @chris-d-0
                                cd /opt/iobroker
                                iobroker stop
                                  @chris-d-0
                                  cd /opt/iobroker
                                  iobroker stop
                                  Chris-D 0
                                  #76
                                  cd /opt/iobroker iobroker stop sudo -H -u iobroker npm install iobroker.js-controller
                                  pi@raspberrypi:/opt/iobroker $ iobroker stop
                                  > node lib/install.js
                                  npm ERR! errno 100
                                  npm ERR!
                                  npm ERR!     /home/iobroker/.npm/_logs/2021-08-19T15_29_16_679Z-debug.log
                                  • C Chris-D 0
                                    > node lib/install.js
                                    npm ERR! errno 100
                                    npm ERR!
                                    #77
                                    @chris-d-0 hattest du mal npm 7 drauf? Da ist ein Mischmasch bei dir.
                                    Thomas BraunT C 2 Antworten Letzte Antwort
                                    • apollon77A apollon77
                                      #78
                                      @apollon77
                                      Offenbar.
                                      ist jedenfalls ein starker Indikator für npm7.
                                        @apollon77
                                        Offenbar.
                                        #79
                                        @thomas-braun package-lock.json löschen
                                          #80
                                          @homoran Keine Ahnung was man da machen kann. Musste das auf meinem System noch nie gerade biegen. Aber da sind ja auch die Versionssprünge nie so groß. Da am Ball bleiben zahlt sich halt aus.
