  4. Rega Fehler
    6.4k
Rega Fehler
141 Beiträge 7 Kommentatoren 19.0k Aufrufe 5 Beobachtet
    @chris-d-0
    iobroker list instances
    Chris-D 0
    #101
    pi@raspberrypi:~ $ iobroker list instances
     system.adapter.admin.0                 : admin                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.backitup.0              : backitup              -  enabled
    + system.adapter.discovery.0             : discovery             -  enabled
    + system.adapter.echarts.0               : echarts               -  enabled
     system.adapter.email.0                 : email                 - disabled
     system.adapter.fb-checkpresence.0      : fb-checkpresence      - disabled
     system.adapter.fritzdect.0             : fritzdect             - disabled
     system.adapter.habpanel.0              : habpanel              -  enabled
    + system.adapter.history.0               : history               -  enabled
    + system.adapter.hm-rega.0               : hm-rega               -  enabled
    + system.adapter.hm-rpc.0                : hm-rpc                -  enabled, port: 0
    + system.adapter.hm-rpc.1                : hm-rpc                -  enabled, port: 0
     system.adapter.ical.0                  : ical                  -  enabled
    + system.adapter.info.0                  : info                  -  enabled
    + system.adapter.iot.0                   : iot                   -  enabled
    + system.adapter.javascript.0            : javascript            -  enabled
     system.adapter.material.0              : material              -  enabled
     system.adapter.mobile.0                : mobile                - disabled
     system.adapter.openweathermap.0        : openweathermap        -  enabled
    + system.adapter.ping.0                  : ping                  -  enabled
    + system.adapter.samsung.0               : samsung               -  enabled
    + system.adapter.simple-api.0            : simple-api            -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.sonos.0                 : sonos                 -  enabled
     system.adapter.synology.0              : synology              - disabled, port: 5000
    + system.adapter.telegram.0              : telegram              -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.tr-064.0                : tr-064                -  enabled
    + system.adapter.tr-064.1                : tr-064                -  enabled
     system.adapter.viessmann.0             : viessmann             - disabled, port: 3002
     system.adapter.vis.0                   : vis                   - disabled
     system.adapter.web.0                   : web                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + instance is alive
    pi@raspberrypi:~ $
    • C Chris-D 0
      + instance is alive
      pi@raspberrypi:~ $
      #102
      @chris-d-0
      Zweite Konsole öffnen, mit
      iobroker logs --watch
      schauen wass da passiert, wenn der admin gestartet werden soll.
      iobroker list adapters
        @thomas-braun package-lock.json löschen
        #103
        @homoran sagte in Rega Fehler:
        nicht die package.json
        @Chris-D-0
        hast du ein Backup?
        Thomas BraunT C 2 Antworten Letzte Antwort
          @Chris-D-0
          hast du ein Backup?
          #104
          Ja, hab ich dann auch gesehen...
          C 1 Antwort Letzte Antwort
            @Chris-D-0
            hast du ein Backup?
            Chris-D 0
            #105
            @homoran ja backup habe ich
              Chris-D 0
              #106
              2021-08-20 13:22:25.557  - info: hm-rpc.1 (23665) Connected
              2021-08-20 13:22:21.109  - info: hm-rpc.0 (23523) xmlrpc <- listDevices ["raspberrypi:hm-rpc.0"]
              2021-08-20 13:22:21.182  - info: hm-rpc.0 (23523) xmlrpc -> 52 devices
              2021-08-20 13:22:21.209  - info: hm-rpc.0 (23523) Connected
              2021-08-20 13:22:25.580  - info: hm-rpc.1 (23665) xmlrpc <- listDevices ["raspberrypi:hm-rpc.1"]
              2021-08-20 13:22:30.516  - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 24164
              2021-08-20 13:22:30.560  - info: host.raspberrypi instance scheduled system.adapter.ical.0 0 * * * *
              2021-08-20 13:22:30.575  - info: host.raspberrypi instance system.adapter.ical.0 started with pid 24170
              2021-08-20 13:22:31.165  - info: hm-rpc.1 (23665) xmlrpc -> 0 devices
              2021-08-20 13:22:31.198  - info: samsung.0 (24138) starting. Version 0.2.9 in /opt/iobroker/node_modules/iobroker.samsung, node: v14.17.5
              2021-08-20 13:22:32.466  - info: ical.0 (24170) starting. Version 1.11.2 in /opt/iobroker/node_modules/iobroker.ical, node: v14.17.5
              2021-08-20 13:22:32.784  - info: hm-rpc.1 (23665) xmlrpc <- newDevices 415
              2021-08-20 13:22:33.037  - info: ical.0 (24170) processing URL: Abfall http://abfallkalender.regioit.de/kalender-krwaf/downloadfile.jsp?format=ics&jahr=2021&ort=Schlo%C3%9F%20Holte-Stukenbrock&strasse=11671699&fraktion=1&fraktion=6&fraktion=7&fraktion=9&fraktion=11
              2021-08-20 13:22:33.087  - info: hm-rpc.1 (23665) new HMIP devices/channels after filter: 0
              2021-08-20 13:22:33.279  - info: ical.0 (24170) processing URL: Caro https://calendar.google.com/calendar/embed?src=caroline.deittert%40gmail.com&ctz=Europe%2FBerlin
              2021-08-20 13:22:33.329  - info: host.raspberrypi instance system.adapter.hm-rega.0 started with pid 24190
              2021-08-20 13:22:34.712  - info: ical.0 (24170) processing URL: Christian https://calendar.google.com/calendar/u/0?cid=Y2hyaXN0aWFuLmFkb2xmODlAZ29vZ2xlbWFpbC5jb20
              2021-08-20 13:22:35.046  - info: hm-rega.0 (24190) starting. Version 3.0.29 in /opt/iobroker/node_modules/iobroker.hm-rega, node: v14.17.5
              2021-08-20 13:22:35.209  - info: hm-rega.0 (24190) subscribe hm-rpc.0.BidCoS-RF.50.PRESS_SHORT
              2021-08-20 13:22:35.415  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
              2021-08-20 13:22:35.524  - info: backitup.0 (24164) starting. Version 2.1.13 in /opt/iobroker/node_modules/iobroker.backitup, node: v14.17.5
              2021-08-20 13:22:35.610  - info: backitup.0 (24164) [iobroker] backup was activated at 02:00 every 5 day(s)
              2021-08-20 13:22:35.712  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
              2021-08-20 13:22:35.712  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
              2021-08-20 13:22:35.695  - info: backitup.0 (24164) [ccu] backup was activated at 01:30 every 5 day(s)
              2021-08-20 13:22:36.183  - error: backitup.0 (24164) Error: Command failed: sudo mount -t cifs -o username=Backup,password=****,noserverino,rw,file_mode=0777,dir_mode=0777 //192.168.178.20/Datensicherung\SmartHome /opt/iobroker/backups
              mount error(2): No such file or directory
              Refer to the mount.cifs(8) manual page (e.g. man mount.cifs)
              2021-08-20 13:22:37.346  - info: host.raspberrypi instance system.adapter.echarts.0 started with pid 24226
              2021-08-20 13:22:41.032  - info: ical.0 (24170) Terminated (NO_ERROR): Without reason
              2021-08-20 13:22:41.184  - info: echarts.0 (24226) starting. Version 0.4.13 in /opt/iobroker/node_modules/iobroker.echarts, node: v14.17.5
              2021-08-20 13:22:41.327  - info: host.raspberrypi instance system.adapter.history.0 started with pid 24250
              2021-08-20 13:22:41.560  - info: host.raspberrypi instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
              2021-08-20 13:22:42.388  - info: history.0 (24250) starting. Version 1.9.13 in /opt/iobroker/node_modules/iobroker.history, node: v14.17.5
              2021-08-20 13:22:42.459  - info: history.0 (24250) enabled logging of hm-rpc.1.000A1A49A1021D.1.ACTUAL_TEMPERATURE (Count=1), Alias=false
              2021-08-20 13:22:42.460  - info: history.0 (24250) enabled logging of hm-rpc.1.000A9A49A2C621.1.HUMIDITY (Count=2), Alias=false
              2021-08-20 13:22:45.344  - info: host.raspberrypi instance system.adapter.simple-api.0 started with pid 24267
              2021-08-20 13:22:46.757  - info: simple-api.0 (24267) starting. Version 2.6.1 in /opt/iobroker/node_modules/iobroker.simple-api, node: v14.17.5
              2021-08-20 13:22:46.818  - info: simple-api.0 (24267) simpleAPI server listening on port 8087
              2021-08-20 13:22:46.819  - info: simple-api.0 (24267) Allow states only when user is owner: false
              2021-08-20 13:22:46.823  - info: simple-api.0 (24267) http server listening on port 8087
              2021-08-20 13:22:49.314  - error: host.raspberrypi startInstance system.adapter.web.0Invalid version of "js-controller". Installed "2.2.10", required ">=3.1.0
              2021-08-20 13:22:53.346  - info: host.raspberrypi instance system.adapter.javascript.0 started with pid 24293
              2021-08-20 13:22:57.507  - info: host.raspberrypi instance scheduled system.adapter.openweathermap.0 23 * * * *
              2021-08-20 13:22:57.533  - info: host.raspberrypi instance system.adapter.openweathermap.0 started with pid 24305
              2021-08-20 13:22:59.686  - info: javascript.0 (24293) starting. Version 5.2.8 in /opt/iobroker/node_modules/iobroker.javascript, node: v14.17.5
              2021-08-20 13:22:59.840  - info: javascript.0 (24293) requesting all states
              2021-08-20 13:22:59.844  - info: javascript.0 (24293) requesting all objects
              2021-08-20 13:23:00.032  - warn: host.raspberrypi instance system.adapter.openweathermap.0 already running with pid 24305
              2021-08-20 13:23:00.844  - info: openweathermap.0 (24305) starting. Version 0.1.0 in /opt/iobroker/node_modules/iobroker.openweathermap, node: v14.17.5
              2021-08-20 13:23:01.119  - info: javascript.0 (24293) received all objects
              2021-08-20 13:23:01.186  - info: javascript.0 (24293) received all states
              2021-08-20 13:23:03.830  - info: openweathermap.0 (24305) Terminated (NO_ERROR): Without reason
              2021-08-20 13:23:04.371  - info: host.raspberrypi instance system.adapter.openweathermap.0 terminated with code 0 (NO_ERROR)
              2021-08-20 13:23:25.756  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
              2021-08-20 13:23:25.827  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
              2021-08-20 13:23:25.828  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
              2021-08-20 13:24:05.379  - error: tr-064.0 (24042) Error: read ECONNRESET - {"errno":-104,"code":"ECONNRESET","syscall":"read"}
              2021-08-20 13:24:05.381  - error: tr-064.0 (24042) ~
              2021-08-20 13:24:05.383  - error: tr-064.0 (24042) ~~ Fatal error. Can not connect to your FritzBox.
              2021-08-20 13:24:05.384  - error: tr-064.0 (24042) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
              2021-08-20 13:24:05.385  - error: tr-064.0 (24042) ~
              2021-08-20 13:24:05.387  - warn: tr-064.0 (24042) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
              2021-08-20 13:24:05.951  - error: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
              2021-08-20 13:24:05.953  - info: host.raspberrypi Restart adapter system.adapter.tr-064.0 because enabled
              2021-08-20 13:24:15.873  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
              2021-08-20 13:24:15.956  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
              2021-08-20 13:24:15.957  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
              2021-08-20 13:24:35.986  - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 24403
              2021-08-20 13:24:37.537  - info: tr-064.0 (24403) starting. Version 4.2.14 in /opt/iobroker/node_modules/iobroker.tr-064, node: v14.17.5
              2021-08-20 13:25:06.003  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
              2021-08-20 13:25:06.054  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
              2021-08-20 13:25:06.055  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
              2021-08-20 13:25:56.103  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
              2021-08-20 13:25:56.149  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
              2021-08-20 13:25:56.150  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
              2021-08-20 13:26:28.738  - error: tr-064.0 (24403) Error: read ECONNRESET - {"errno":-104,"code":"ECONNRESET","syscall":"read"}
              2021-08-20 13:26:28.740  - error: tr-064.0 (24403) ~
              2021-08-20 13:26:28.741  - error: tr-064.0 (24403) ~~ Fatal error. Can not connect to your FritzBox.
              2021-08-20 13:26:28.742  - error: tr-064.0 (24403) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
              2021-08-20 13:26:28.743  - error: tr-064.0 (24403) ~
              2021-08-20 13:26:28.746  - warn: tr-064.0 (24403) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
              2021-08-20 13:26:29.293  - error: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
              2021-08-20 13:26:29.294  - info: host.raspberrypi Restart adapter system.adapter.tr-064.0 because enabled
              2021-08-20 13:26:46.194  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
              2021-08-20 13:26:46.235  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
              2021-08-20 13:26:46.236  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
              2021-08-20 13:26:59.349  - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 24563
              2021-08-20 13:27:00.989  - info: tr-064.0 (24563) starting. Version 4.2.14 in /opt/iobroker/node_modules/iobroker.tr-064, node: v14.17.5
              2021-08-20 13:27:36.311  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
              2021-08-20 13:27:36.383  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
              2021-08-20 13:27:36.384  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
              2021-08-20 13:28:26.425  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
              2021-08-20 13:28:26.459  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
              2021-08-20 13:28:26.461  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
              2021-08-20 13:28:52.099  - error: tr-064.0 (24563) Error: read ECONNRESET - {"errno":-104,"code":"ECONNRESET","syscall":"read"}
              2021-08-20 13:28:52.101  - error: tr-064.0 (24563) ~
              2021-08-20 13:28:52.103  - error: tr-064.0 (24563) ~~ Fatal error. Can not connect to your FritzBox.
              2021-08-20 13:28:52.104  - error: tr-064.0 (24563) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
              2021-08-20 13:28:52.105  - error: tr-064.0 (24563) ~
              2021-08-20 13:28:52.107  - warn: tr-064.0 (24563) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
              2021-08-20 13:28:52.648  - error: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
              2021-08-20 13:28:52.649  - info: host.raspberrypi Restart adapter system.adapter.tr-064.0 because enabled
              2021-08-20 13:29:16.497  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
              2021-08-20 13:29:16.515  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
              2021-08-20 13:29:16.516  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
              2021-08-20 13:29:22.687  - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 24700
              2021-08-20 13:29:24.211  - info: tr-064.0 (24700) starting. Version 4.2.14 in /opt/iobroker/node_modules/iobroker.tr-064, node: v14.17.5
              2021-08-20 13:30:06.556  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
              2021-08-20 13:30:06.598  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
              2021-08-20 13:30:06.599  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
              2021-08-20 13:30:56.641  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
              2021-08-20 13:30:56.671  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
              2021-08-20 13:30:56.672  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
              2021-08-20 13:31:15.458  - error: tr-064.0 (24700) Error: read ECONNRESET - {"errno":-104,"code":"ECONNRESET","syscall":"read"}
              2021-08-20 13:31:15.460  - error: tr-064.0 (24700) ~
              2021-08-20 13:31:15.462  - error: tr-064.0 (24700) ~~ Fatal error. Can not connect to your FritzBox.
              2021-08-20 13:31:15.463  - error: tr-064.0 (24700) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
              2021-08-20 13:31:15.464  - error: tr-064.0 (24700) ~
              2021-08-20 13:31:15.466  - warn: tr-064.0 (24700) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
              2021-08-20 13:31:16.019  - error: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
              2021-08-20 13:31:16.020  - info: host.raspberrypi Restart adapter system.adapter.tr-064.0 because enabled
              2021-08-20 13:31:46.047  - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 24828
              2021-08-20 13:31:46.712  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
              2021-08-20 13:31:46.734  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
              2021-08-20 13:31:46.735  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
              2021-08-20 13:31:47.595  - info: tr-064.0 (24828) starting. Version 4.2.14 in /opt/iobroker/node_modules/iobroker.tr-064, node: v14.17.5
              2021-08-20 13:32:36.775  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
              2021-08-20 13:32:36.805  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
              2021-08-20 13:32:36.805  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
              2021-08-20 13:33:26.876  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
              2021-08-20 13:33:26.947  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
              2021-08-20 13:33:26.948  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
              2021-08-20 13:33:43.938  - error: tr-064.0 (24828) Error: read ECONNRESET - {"errno":-104,"code":"ECONNRESET","syscall":"read"}
              2021-08-20 13:33:43.940  - error: tr-064.0 (24828) ~
              2021-08-20 13:33:43.942  - error: tr-064.0 (24828) ~~ Fatal error. Can not connect to your FritzBox.
              2021-08-20 13:33:43.943  - error: tr-064.0 (24828) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
              2021-08-20 13:33:43.944  - error: tr-064.0 (24828) ~
              2021-08-20 13:33:43.946  - warn: tr-064.0 (24828) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
              2021-08-20 13:33:44.494  - error: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
              2021-08-20 13:33:44.496  - info: host.raspberrypi Restart adapter system.adapter.tr-064.0 because enabled
              2021-08-20 13:34:14.550  - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 24956
              2021-08-20 13:34:16.029  - info: tr-064.0 (24956) starting. Version 4.2.14 in /opt/iobroker/node_modules/iobroker.tr-064, node: v14.17.5
              2021-08-20 13:34:16.992  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
              2021-08-20 13:34:17.024  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
              2021-08-20 13:34:17.025  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
              2021-08-20 13:35:07.064  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
              2021-08-20 13:35:07.087  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
              2021-08-20 13:35:07.088  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
              2021-08-20 13:35:57.125  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
              2021-08-20 13:35:57.159  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
              2021-08-20 13:35:57.160  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
              2021-08-20 13:36:07.298  - error: tr-064.0 (24956) Error: read ECONNRESET - {"errno":-104,"code":"ECONNRESET","syscall":"read"}
              2021-08-20 13:36:07.300  - error: tr-064.0 (24956) ~
              2021-08-20 13:36:07.301  - error: tr-064.0 (24956) ~~ Fatal error. Can not connect to your FritzBox.
              2021-08-20 13:36:07.302  - error: tr-064.0 (24956) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
              2021-08-20 13:36:07.303  - error: tr-064.0 (24956) ~
              2021-08-20 13:36:07.305  - warn: tr-064.0 (24956) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
              2021-08-20 13:36:07.867  - error: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
              2021-08-20 13:36:07.869  - info: host.raspberrypi Restart adapter system.adapter.tr-064.0 because enabled
              2021-08-20 13:36:37.931  - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 25084
              2021-08-20 13:36:39.428  - info: tr-064.0 (25084) starting. Version 4.2.14 in /opt/iobroker/node_modules/iobroker.tr-064, node: v14.17.5
              2021-08-20 13:36:47.203  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
              2021-08-20 13:36:47.232  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
              2021-08-20 13:36:47.233  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
              2021-08-20 13:37:37.275  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
              2021-08-20 13:37:37.310  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
              2021-08-20 13:37:37.311  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
              2021-08-20 13:38:27.383  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
              2021-08-20 13:38:27.452  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
              2021-08-20 13:38:27.453  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
              2021-08-20 13:38:30.658  - error: tr-064.0 (25084) Error: read ECONNRESET - {"errno":-104,"code":"ECONNRESET","syscall":"read"}
              2021-08-20 13:38:30.659  - error: tr-064.0 (25084) ~
              2021-08-20 13:38:30.660  - error: tr-064.0 (25084) ~~ Fatal error. Can not connect to your FritzBox.
              2021-08-20 13:38:30.661  - error: tr-064.0 (25084) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
              2021-08-20 13:38:30.662  - error: tr-064.0 (25084) ~
              2021-08-20 13:38:30.664  - warn: tr-064.0 (25084) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
              2021-08-20 13:38:31.227  - error: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
              2021-08-20 13:38:31.239  - info: host.raspberrypi Restart adapter system.adapter.tr-064.0 because enabled
              2021-08-20 13:39:01.302  - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 25224
              2021-08-20 13:39:02.883  - info: tr-064.0 (25224) starting. Version 4.2.14 in /opt/iobroker/node_modules/iobroker.tr-064, node: v14.17.5
              2021-08-20 13:39:17.496  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
              2021-08-20 13:39:17.530  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
              2021-08-20 13:39:17.531  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
              2021-08-20 13:40:07.576  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
              2021-08-20 13:40:07.606  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
              2021-08-20 13:40:07.607  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
              2021-08-20 13:40:54.014  - error: tr-064.0 (25224) Error: read ECONNRESET - {"errno":-104,"code":"ECONNRESET","syscall":"read"}
              2021-08-20 13:40:54.017  - error: tr-064.0 (25224) ~
              2021-08-20 13:40:54.018  - error: tr-064.0 (25224) ~~ Fatal error. Can not connect to your FritzBox.
              2021-08-20 13:40:54.019  - error: tr-064.0 (25224) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
              2021-08-20 13:40:54.020  - error: tr-064.0 (25224) ~
              2021-08-20 13:40:54.022  - warn: tr-064.0 (25224) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
              2021-08-20 13:40:54.574  - error: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
              2021-08-20 13:40:54.585  - info: host.raspberrypi Restart adapter system.adapter.tr-064.0 because enabled
              2021-08-20 13:40:57.648  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
              2021-08-20 13:40:57.673  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
              2021-08-20 13:40:57.674  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
              2021-08-20 13:41:24.645  - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 25417
              2021-08-20 13:41:26.131  - info: tr-064.0 (25417) starting. Version 4.2.14 in /opt/iobroker/node_modules/iobroker.tr-064, node: v14.17.5
              2021-08-20 13:41:47.710  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
              2021-08-20 13:41:47.757  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
              2021-08-20 13:41:47.758  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
              2021-08-20 13:42:37.803  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
              2021-08-20 13:42:37.836  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
              2021-08-20 13:42:37.837  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
              2021-08-20 13:43:17.376  - error: tr-064.0 (25417) Error: read ECONNRESET - {"errno":-104,"code":"ECONNRESET","syscall":"read"}
              2021-08-20 13:43:17.378  - error: tr-064.0 (25417) ~
              2021-08-20 13:43:17.379  - error: tr-064.0 (25417) ~~ Fatal error. Can not connect to your FritzBox.
              2021-08-20 13:43:17.380  - error: tr-064.0 (25417) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
              2021-08-20 13:43:17.381  - error: tr-064.0 (25417) ~
              2021-08-20 13:43:17.383  - warn: tr-064.0 (25417) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
              2021-08-20 13:43:17.923  - error: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
              2021-08-20 13:43:17.925  - info: host.raspberrypi Restart adapter system.adapter.tr-064.0 because enabled
              2021-08-20 13:43:27.884  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
              2021-08-20 13:43:27.930  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
              2021-08-20 13:43:27.931  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
              2021-08-20 13:43:47.963  - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 25546
              2021-08-20 13:43:49.562  - info: tr-064.0 (25546) starting. Version 4.2.14 in /opt/iobroker/node_modules/iobroker.tr-064, node: v14.17.5
              2021-08-20 13:44:18.000  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
              2021-08-20 13:44:18.070  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
              2021-08-20 13:44:18.070  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
              2021-08-20 13:45:08.109  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
              2021-08-20 13:45:08.139  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
              2021-08-20 13:45:08.140  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
              2021-08-20 13:45:40.738  - error: tr-064.0 (25546) Error: read ECONNRESET - {"errno":-104,"code":"ECONNRESET","syscall":"read"}
              2021-08-20 13:45:40.741  - error: tr-064.0 (25546) ~
              2021-08-20 13:45:40.742  - error: tr-064.0 (25546) ~~ Fatal error. Can not connect to your FritzBox.
              2021-08-20 13:45:40.743  - error: tr-064.0 (25546) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
              2021-08-20 13:45:40.744  - error: tr-064.0 (25546) ~
              2021-08-20 13:45:40.746  - warn: tr-064.0 (25546) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
              2021-08-20 13:45:41.299  - error: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
              2021-08-20 13:45:41.300  - info: host.raspberrypi Restart adapter system.adapter.tr-064.0 because enabled
              2021-08-20 13:45:58.178  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
              2021-08-20 13:45:58.212  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
              2021-08-20 13:45:58.213  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
              2021-08-20 13:46:11.356  - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 25653
              2021-08-20 13:46:12.879  - info: tr-064.0 (25653) starting. Version 4.2.14 in /opt/iobroker/node_modules/iobroker.tr-064, node: v14.17.5
              2021-08-20 13:46:48.251  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
              2021-08-20 13:46:48.280  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
              2021-08-20 13:46:48.281  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
              2021-08-20 13:47:38.326  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
              2021-08-20 13:47:38.401  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
              2021-08-20 13:47:38.402  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
              2021-08-20 13:48:04.097  - error: tr-064.0 (25653) Error: read ECONNRESET - {"errno":-104,"code":"ECONNRESET","syscall":"read"}
              2021-08-20 13:48:04.100  - error: tr-064.0 (25653) ~
              2021-08-20 13:48:04.101  - error: tr-064.0 (25653) ~~ Fatal error. Can not connect to your FritzBox.
              2021-08-20 13:48:04.102  - error: tr-064.0 (25653) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
              2021-08-20 13:48:04.103  - error: tr-064.0 (25653) ~
              2021-08-20 13:48:04.106  - warn: tr-064.0 (25653) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
              2021-08-20 13:48:04.652  - error: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
              2021-08-20 13:48:04.653  - info: host.raspberrypi Restart adapter system.adapter.tr-064.0 because enabled
              2021-08-20 13:48:28.445  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
              2021-08-20 13:48:28.495  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
              2021-08-20 13:48:28.496  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
              2021-08-20 13:48:34.689  - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 25770
              2021-08-20 13:48:36.152  - info: tr-064.0 (25770) starting. Version 4.2.14 in /opt/iobroker/node_modules/iobroker.tr-064, node: v14.17.5
              2021-08-20 13:49:18.566  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
              2021-08-20 13:49:18.599  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
              2021-08-20 13:49:18.600  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
              2021-08-20 13:50:08.645  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
              2021-08-20 13:50:08.713  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
              2021-08-20 13:50:08.714  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
              2021-08-20 13:50:27.460  - error: tr-064.0 (25770) Error: read ECONNRESET - {"errno":-104,"code":"ECONNRESET","syscall":"read"}
              2021-08-20 13:50:27.463  - error: tr-064.0 (25770) ~
              2021-08-20 13:50:27.465  - error: tr-064.0 (25770) ~~ Fatal error. Can not connect to your FritzBox.
              2021-08-20 13:50:27.467  - error: tr-064.0 (25770) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
              2021-08-20 13:50:27.468  - error: tr-064.0 (25770) ~
              2021-08-20 13:50:27.471  - warn: tr-064.0 (25770) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
              2021-08-20 13:50:28.040  - error: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
              2021-08-20 13:50:28.052  - info: host.raspberrypi Restart adapter system.adapter.tr-064.0 because enabled
              2021-08-20 13:50:58.104  - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 25863
              2021-08-20 13:50:58.756  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
              2021-08-20 13:50:58.781  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
              2021-08-20 13:50:58.782  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
              2021-08-20 13:50:59.632  - info: tr-064.0 (25863) starting. Version 4.2.14 in /opt/iobroker/node_modules/iobroker.tr-064, node: v14.17.5
              2021-08-20 13:51:48.824  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
              2021-08-20 13:51:48.850  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
              2021-08-20 13:51:48.851  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
              2021-08-20 13:52:38.894  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
              2021-08-20 13:52:38.920  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
              2021-08-20 13:52:38.921  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
              2021-08-20 13:52:50.812  - error: tr-064.0 (25863) Error: read ECONNRESET - {"errno":-104,"code":"ECONNRESET","syscall":"read"}
              2021-08-20 13:52:50.814  - error: tr-064.0 (25863) ~
              2021-08-20 13:52:50.815  - error: tr-064.0 (25863) ~~ Fatal error. Can not connect to your FritzBox.
              2021-08-20 13:52:50.816  - error: tr-064.0 (25863) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
              2021-08-20 13:52:50.817  - error: tr-064.0 (25863) ~
              2021-08-20 13:52:50.819  - warn: tr-064.0 (25863) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
              2021-08-20 13:52:51.373  - error: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
              2021-08-20 13:52:51.374  - info: host.raspberrypi Restart adapter system.adapter.tr-064.0 because enabled
              2021-08-20 13:53:21.409  - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 25970
              2021-08-20 13:53:22.902  - info: tr-064.0 (25970) starting. Version 4.2.14 in /opt/iobroker/node_modules/iobroker.tr-064, node: v14.17.5
              2021-08-20 13:53:28.957  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
              2021-08-20 13:53:28.973  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
              2021-08-20 13:53:28.973  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
              2021-08-20 13:54:19.016  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
              2021-08-20 13:54:19.038  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
              2021-08-20 13:54:19.039  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
              2021-08-20 13:55:09.112  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
              2021-08-20 13:55:09.179  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
              2021-08-20 13:55:09.180  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
              2021-08-20 13:55:14.178  - error: tr-064.0 (25970) Error: read ECONNRESET - {"errno":-104,"code":"ECONNRESET","syscall":"read"}
              2021-08-20 13:55:14.180  - error: tr-064.0 (25970) ~
              2021-08-20 13:55:14.182  - error: tr-064.0 (25970) ~~ Fatal error. Can not connect to your FritzBox.
              2021-08-20 13:55:14.183  - error: tr-064.0 (25970) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
              2021-08-20 13:55:14.184  - error: tr-064.0 (25970) ~
              2021-08-20 13:55:14.186  - warn: tr-064.0 (25970) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
              2021-08-20 13:55:14.748  - error: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
              2021-08-20 13:55:14.761  - info: host.raspberrypi Restart adapter system.adapter.tr-064.0 because enabled
              2021-08-20 13:55:44.821  - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 26097
              2021-08-20 13:55:46.478  - info: tr-064.0 (26097) starting. Version 4.2.14 in /opt/iobroker/node_modules/iobroker.tr-064, node: v14.17.5
              2021-08-20 13:55:59.224  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
              2021-08-20 13:55:59.249  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
              2021-08-20 13:55:59.250  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
              2021-08-20 13:56:49.294  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
              2021-08-20 13:56:49.370  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
              2021-08-20 13:56:49.371  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
              2021-08-20 13:57:37.538  - error: tr-064.0 (26097) Error: read ECONNRESET - {"errno":-104,"code":"ECONNRESET","syscall":"read"}
              2021-08-20 13:57:37.540  - error: tr-064.0 (26097) ~
              2021-08-20 13:57:37.542  - error: tr-064.0 (26097) ~~ Fatal error. Can not connect to your FritzBox.
              2021-08-20 13:57:37.543  - error: tr-064.0 (26097) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
              2021-08-20 13:57:37.544  - error: tr-064.0 (26097) ~
              2021-08-20 13:57:37.546  - warn: tr-064.0 (26097) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
              2021-08-20 13:57:38.085  - error: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
              2021-08-20 13:57:38.087  - info: host.raspberrypi Restart adapter system.adapter.tr-064.0 because enabled
              2021-08-20 13:57:39.412  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
              2021-08-20 13:57:39.438  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
              2021-08-20 13:57:39.439  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
              2021-08-20 13:58:08.120  - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 26200
              2021-08-20 13:58:09.574  - info: tr-064.0 (26200) starting. Version 4.2.14 in /opt/iobroker/node_modules/iobroker.tr-064, node: v14.17.5
              2021-08-20 13:58:29.477  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
              2021-08-20 13:58:29.501  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
              2021-08-20 13:58:29.502  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
              2021-08-20 13:59:19.543  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
              2021-08-20 13:59:19.558  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
              2021-08-20 13:59:19.559  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
              2021-08-20 14:00:00.074  - info: host.raspberrypi instance system.adapter.ical.0 started with pid 26327
              2021-08-20 14:00:00.885  - error: tr-064.0 (26200) Error: read ECONNRESET - {"errno":-104,"code":"ECONNRESET","syscall":"read"}
              2021-08-20 14:00:00.886  - error: tr-064.0 (26200) ~
              2021-08-20 14:00:00.887  - error: tr-064.0 (26200) ~~ Fatal error. Can not connect to your FritzBox.
              2021-08-20 14:00:00.888  - error: tr-064.0 (26200) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
              2021-08-20 14:00:00.889  - warn: tr-064.0 (26200) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
              2021-08-20 14:00:01.423  - error: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
              2021-08-20 14:00:01.424  - info: host.raspberrypi Restart adapter system.adapter.tr-064.0 because enabled
              2021-08-20 14:00:01.884  - info: ical.0 (26327) starting. Version 1.11.2 in /opt/iobroker/node_modules/iobroker.ical, node: v14.17.5
              2021-08-20 14:00:02.716  - info: ical.0 (26327) processing URL: Caro https://calendar.google.com/calendar/embed?src=caroline.deittert%40gmail.com&ctz=Europe%2FBerlin
              2021-08-20 14:00:02.738  - info: ical.0 (26327) processing URL: Abfall http://abfallkalender.regioit.de/kalender-krwaf/downloadfile.jsp?format=ics&jahr=2021&ort=Schlo%C3%9F%20Holte-Stukenbrock&strasse=11671699&fraktion=1&fraktion=6&fraktion=7&fraktion=9&fraktion=11
              2021-08-20 14:00:02.917  - info: ical.0 (26327) processing URL: Christian https://calendar.google.com/calendar/u/0?cid=Y2hyaXN0aWFuLmFkb2xmODlAZ29vZ2xlbWFpbC5jb20
              2021-08-20 14:00:07.955  - info: ical.0 (26327) Terminated (NO_ERROR): Without reason
              2021-08-20 14:00:08.486  - info: host.raspberrypi instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
              2021-08-20 14:00:09.598  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
              2021-08-20 14:00:09.675  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
              2021-08-20 14:00:09.676  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
              2021-08-20 14:00:31.477  - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 26353
              2021-08-20 14:00:32.997  - info: tr-064.0 (26353) starting. Version 4.2.14 in /opt/iobroker/node_modules/iobroker.tr-064, node: v14.17.5
              2021-08-20 14:00:59.742  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
              2021-08-20 14:00:59.786  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
              2021-08-20 14:00:59.786  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
              2021-08-20 14:01:49.826  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
              2021-08-20 14:01:49.859  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
              2021-08-20 14:01:49.860  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
              2021-08-20 14:02:24.258  - error: tr-064.0 (26353) Error: read ECONNRESET - {"errno":-104,"code":"ECONNRESET","syscall":"read"}
              2021-08-20 14:02:24.260  - error: tr-064.0 (26353) ~
              2021-08-20 14:02:24.261  - error: tr-064.0 (26353) ~~ Fatal error. Can not connect to your FritzBox.
              2021-08-20 14:02:24.263  - error: tr-064.0 (26353) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
              2021-08-20 14:02:24.264  - error: tr-064.0 (26353) ~
              2021-08-20 14:02:24.266  - warn: tr-064.0 (26353) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
              2021-08-20 14:02:24.825  - error: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
              2021-08-20 14:02:24.836  - info: host.raspberrypi Restart adapter system.adapter.tr-064.0 because enabled
              2021-08-20 14:02:39.922  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
              2021-08-20 14:02:39.946  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
              2021-08-20 14:02:39.947  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
              2021-08-20 14:02:54.938  - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 26489
              2021-08-20 14:02:56.448  - info: tr-064.0 (26489) starting. Version 4.2.14 in /opt/iobroker/node_modules/iobroker.tr-064, node: v14.17.5
              2021-08-20 14:03:29.987  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
              2021-08-20 14:03:30.017  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
              2021-08-20 14:03:30.017  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
              2021-08-20 14:04:20.056  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
              2021-08-20 14:04:20.093  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
              2021-08-20 14:04:20.094  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
              2021-08-20 14:04:47.618  - error: tr-064.0 (26489) Error: read ECONNRESET - {"errno":-104,"code":"ECONNRESET","syscall":"read"}
              2021-08-20 14:04:47.620  - error: tr-064.0 (26489) ~
              2021-08-20 14:04:47.622  - error: tr-064.0 (26489) ~~ Fatal error. Can not connect to your FritzBox.
              2021-08-20 14:04:47.623  - error: tr-064.0 (26489) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
              2021-08-20 14:04:47.624  - error: tr-064.0 (26489) ~
              2021-08-20 14:04:47.626  - warn: tr-064.0 (26489) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
              2021-08-20 14:04:48.177  - error: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
              2021-08-20 14:04:48.179  - info: host.raspberrypi Restart adapter system.adapter.tr-064.0 because enabled
              2021-08-20 14:05:10.140  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
              2021-08-20 14:05:10.216  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
              2021-08-20 14:05:10.217  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
              2021-08-20 14:05:18.244  - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 26596
              2021-08-20 14:05:19.768  - info: tr-064.0 (26596) starting. Version 4.2.14 in /opt/iobroker/node_modules/iobroker.tr-064, node: v14.17.5
              2021-08-20 14:06:00.286  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
              2021-08-20 14:06:00.360  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
              2021-08-20 14:06:00.360  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
              2021-08-20 14:06:50.404  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
              2021-08-20 14:06:50.432  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
              2021-08-20 14:06:50.433  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
              2021-08-20 14:07:10.978  - error: tr-064.0 (26596) Error: read ECONNRESET - {"errno":-104,"code":"ECONNRESET","syscall":"read"}
              2021-08-20 14:07:10.980  - error: tr-064.0 (26596) ~
              2021-08-20 14:07:10.981  - error: tr-064.0 (26596) ~~ Fatal error. Can not connect to your FritzBox.
              2021-08-20 14:07:10.983  - error: tr-064.0 (26596) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
              2021-08-20 14:07:10.984  - error: tr-064.0 (26596) ~
              2021-08-20 14:07:10.986  - warn: tr-064.0 (26596) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
              2021-08-20 14:07:11.538  - error: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
              2021-08-20 14:07:11.540  - info: host.raspberrypi Restart adapter system.adapter.tr-064.0 because enabled
              2021-08-20 14:07:40.472  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
              2021-08-20 14:07:40.497  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
              2021-08-20 14:07:40.498  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
              2021-08-20 14:07:41.599  - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 26712
              2021-08-20 14:07:43.185  - info: tr-064.0 (26712) starting. Version 4.2.14 in /opt/iobroker/node_modules/iobroker.tr-064, node: v14.17.5
              2021-08-20 14:08:30.537  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
              2021-08-20 14:08:30.563  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
              2021-08-20 14:08:30.564  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
              2021-08-20 14:09:20.601  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
              2021-08-20 14:09:20.704  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
              2021-08-20 14:09:20.705  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
              2021-08-20 14:09:34.338  - error: tr-064.0 (26712) Error: read ECONNRESET - {"errno":-104,"code":"ECONNRESET","syscall":"read"}
              2021-08-20 14:09:34.341  - error: tr-064.0 (26712) ~
              2021-08-20 14:09:34.342  - error: tr-064.0 (26712) ~~ Fatal error. Can not connect to your FritzBox.
              2021-08-20 14:09:34.344  - error: tr-064.0 (26712) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
              2021-08-20 14:09:34.345  - error: tr-064.0 (26712) ~
              2021-08-20 14:09:34.347  - warn: tr-064.0 (26712) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
              2021-08-20 14:09:34.907  - error: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
              2021-08-20 14:09:34.919  - info: host.raspberrypi Restart adapter system.adapter.tr-064.0 because enabled
              2021-08-20 14:10:04.983  - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 26843
              2021-08-20 14:10:06.495  - info: tr-064.0 (26843) starting. Version 4.2.14 in /opt/iobroker/node_modules/iobroker.tr-064, node: v14.17.5
              2021-08-20 14:10:10.746  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
              2021-08-20 14:10:10.780  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
              2021-08-20 14:10:10.781  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
              2021-08-20 14:11:00.819  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
              2021-08-20 14:11:00.840  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
              2021-08-20 14:11:00.840  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
              2021-08-20 14:11:50.913  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
              2021-08-20 14:11:50.987  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
              2021-08-20 14:11:50.988  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
              2021-08-20 14:11:57.690  - error: tr-064.0 (26843) Error: read ECONNRESET - {"errno":-104,"code":"ECONNRESET","syscall":"read"}
              2021-08-20 14:11:57.692  - error: tr-064.0 (26843) ~
              2021-08-20 14:11:57.693  - error: tr-064.0 (26843) ~~ Fatal error. Can not connect to your FritzBox.
              2021-08-20 14:11:57.694  - error: tr-064.0 (26843) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
              2021-08-20 14:11:57.695  - error: tr-064.0 (26843) ~
              2021-08-20 14:11:57.697  - warn: tr-064.0 (26843) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
              2021-08-20 14:11:58.237  - error: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
              2021-08-20 14:11:58.246  - info: host.raspberrypi Restart adapter system.adapter.tr-064.0 because enabled
              • C Chris-D 0
                @homoran ja backup habe ich
                #107
                @chris-d-0 sagte in Rega Fehler:
                dann mach doch alles neu bevor du hier Stunden verbrätst.
                node 14
                kommt mit npm v6
                curl -sLf https://iobroker.net/install.sh | bash -
                Backup einspielen - warten - fertig!
                C 1 Antwort Letzte Antwort
                  node 14
                  kommt mit npm v6
                  Chris-D 0
                  #108
                  @homoran ok welche befehle brauche ich genau?
                  • C Chris-D 0
                    #109
                    wofür genau?
                    • apollon77A Offline
                      #110
                      Jetzt mal langsam ... Also laut Log ist doch alles ok, ausser:
                      • tr-064 meldet das die Fritzbox die Verbindung ablehnt, da musst man Fritzbox Einstellungen checken
                      • hm-rega/rpc meldet das die CCU "401 Unauthorized" meldet ... hast du da irgendwie username/passwort konfiguriert aber nicht im Adapter?
                      • backitup meldet das ein CIFS Mount nicht da ist
                      Der Rest sieht alles normal und ok aus.
                      Von Admin finde ich im Log ausschnitt nicht
                      Also wenn das die Themen sind dann hilft auch ein backup einspielen nix
                        wofür genau?
                        Chris-D 0
                        #111
                        @homoran neu aufsetzen?
                        • apollon77A apollon77
                          Chris-D 0
                          #112
                          @apollon77 das ist leider nicht mehr das Problem, siehe verlauf
                          haselchenH apollon77A 2 Antworten Letzte Antwort
                          • C Chris-D 0
                            haselchenH Offline
                            haselchenH Offline
                            haselchen
                            #113
                            @chris-d-0
                            Wo liegt denn der Hase noch im Pfeffer?
                            Welche Probleme gibt es noch?
                            • C Chris-D 0
                              #114
                              @chris-d-0 ja was ist denn das Problem? Ich blicke bei dem Verkauf nimmer durch
                              • haselchenH haselchen
                                @chris-d-0
                                Chris-D 0
                                schrieb am zuletzt editiert von Chris-D 0
                                #115
                                @haselchen die IObroker Oberfläche wird nicht angezeigt. "Seite kann nicht angezeigt werden" Also Webseite nicht erreichbar
                                • C Chris-D 0
                                  #116
                                  @chris-d-0
                                  ich versuche mal zusammenzufassen:
                                  hu hast
                                  • Pi4 mit SD Karte
                                  • ein brauchbares iobroker backup
                                  Dann nimmst du eine neue Karte
                                  installierst darauf das aktuelle Raspberry OS lite
                                  dann den iobroker
                                  und spielst das Backup zurück.
                                  Dann sollte alles laufen
                                  Für den Notfall hast du immer noch die alte Karte
                                  @apollon77
                                  Problem ist admin 5 mit controller 2.x
                                  C apollon77A 2 Antworten Letzte Antwort
                                    @chris-d-0
                                    hu hast
                                    • Pi4 mit SD Karte
                                    dann den iobroker
                                    @apollon77
                                    Chris-D 0
                                    #117
                                    @homoran Das Problem ist das auf dem Raspberry auch wireguard läuft... also komplett (d.h. das Raspberrry) aufsetzen ist schwierig...
                                      @chris-d-0
                                      hu hast
                                      • Pi4 mit SD Karte
                                      dann den iobroker
                                      @apollon77
                                      #118
                                      @homoran sagte in Rega Fehler:
                                      Wie kriegt man das hin ausser manuell gefrickelt??
                                      Adrmin 5 braucht mindestens "js-controller": ">=3.2.16"
                                      Also Controller updaten und Problem ist erledigt. Oder Admin Downgrade
                                      • C Offline
                                        Chris-D 0
                                        #119
                                        @apollon77 System neu aufgesetzt, Rega Fehler bleibt
                                        HomoranH apollon77A 2 Antworten Letzte Antwort
                                        • C Chris-D 0
                                          #120
                                          immerhin läuft er jetzt wieder.
                                          Dieser Fehler deutet auf ein Problem mit der Firewall der CCU hin.
                                          Bitte vollständig als Text in code-tags posten und nicht als Screenshot
