  4. Rega Fehler
    6.4k
Rega Fehler
141 Beiträge 7 Kommentatoren 19.0k Aufrufe 5 Beobachtet
  • C Chris-D 0
    pi@raspberrypi:~ $ iobroker stop
    pi@raspberrypi:~ $ sudo -u iobroker mv /opt/iobroker/package.json /opt/iobroker/packagejson_backup
    pi@raspberrypi:~ $ sudo -u iobroker mv /opt/iobroker/package-lock.json /opt/iobroker/package-lockjson_backup
    pi@raspberrypi:~ $ iobroker start
    pi@raspberrypi:~ $ iobroker list instances
      system.adapter.admin.0                 : admin                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.backitup.0              : backitup              -  enabled
    + system.adapter.discovery.0             : discovery             -  enabled
      system.adapter.echarts.0               : echarts               -  enabled
      system.adapter.email.0                 : email                 - disabled
      system.adapter.fb-checkpresence.0      : fb-checkpresence      - disabled
      system.adapter.fritzdect.0             : fritzdect             - disabled
      system.adapter.habpanel.0              : habpanel              -  enabled
      system.adapter.history.0               : history               -  enabled
      system.adapter.hm-rega.0               : hm-rega               -  enabled
    + system.adapter.hm-rpc.0                : hm-rpc                -  enabled, port: 0
      system.adapter.hm-rpc.1                : hm-rpc                -  enabled, port: 0
      system.adapter.ical.0                  : ical                  -  enabled
    + system.adapter.info.0                  : info                  -  enabled
      system.adapter.iot.0                   : iot                   -  enabled
      system.adapter.javascript.0            : javascript            -  enabled
      system.adapter.material.0              : material              -  enabled
      system.adapter.mobile.0                : mobile                - disabled
      system.adapter.openweathermap.0        : openweathermap        -  enabled
      system.adapter.ping.0                  : ping                  -  enabled
      system.adapter.samsung.0               : samsung               -  enabled
      system.adapter.simple-api.0            : simple-api            -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      system.adapter.sonos.0                 : sonos                 -  enabled
      system.adapter.synology.0              : synology              - disabled, port: 5000
      system.adapter.telegram.0              : telegram              -  enabled, port: 8443, bind: 0.0.0.0
      system.adapter.tr-064.0                : tr-064                -  enabled
      system.adapter.tr-064.1                : tr-064                -  enabled
      system.adapter.viessmann.0             : viessmann             - disabled, port: 3002
      system.adapter.vis.0                   : vis                   - disabled
      system.adapter.web.0                   : web                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + instance is alive
    #96
    @chris-d-0
    iobroker start web
    iobroker start admin
    C 1 Antwort Letzte Antwort
      @chris-d-0
      iobroker start web
      Chris-D 0
      #97
      @thomas-braun schon direkt mit gemacht
      pi@raspberrypi:~ $ iobroker start admin
      pi@raspberrypi:~ $ iobroker start web
      keine Verbesserung
      • C Chris-D 0
        keine Verbesserung
        #98
        @chris-d-0 sagte in Rega Fehler:
        keine Verbesserung
        Was heißt das genau?
          keine Verbesserung
          Chris-D 0
          #99
          • C Chris-D 0
            #100
            @chris-d-0
              @chris-d-0
              Chris-D 0
              #101
              + system.adapter.backitup.0              : backitup              -  enabled
              + system.adapter.echarts.0               : echarts               -  enabled
              + system.adapter.history.0               : history               -  enabled
              + system.adapter.hm-rega.0               : hm-rega               -  enabled
              + system.adapter.hm-rpc.1                : hm-rpc                -  enabled, port: 0
              + system.adapter.iot.0                   : iot                   -  enabled
              + system.adapter.javascript.0            : javascript            -  enabled
              + system.adapter.ping.0                  : ping                  -  enabled
              + system.adapter.samsung.0               : samsung               -  enabled
              + system.adapter.simple-api.0            : simple-api            -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
              + system.adapter.sonos.0                 : sonos                 -  enabled
              + system.adapter.telegram.0              : telegram              -  enabled, port: 8443, bind: 0.0.0.0
              + system.adapter.tr-064.0                : tr-064                -  enabled
              + system.adapter.tr-064.1                : tr-064                -  enabled
              + instance is alive
              pi@raspberrypi:~ $
              • C Chris-D 0
                + instance is alive
                pi@raspberrypi:~ $
                #102
                @chris-d-0
                Zweite Konsole öffnen, mit
                iobroker logs --watch
                schauen wass da passiert, wenn der admin gestartet werden soll.
                iobroker list adapters
                  @thomas-braun package-lock.json löschen
                  #103
                  @homoran sagte in Rega Fehler:
                  nicht die package.json
                  @Chris-D-0
                  hast du ein Backup?
                  Thomas BraunT C 2 Antworten Letzte Antwort
                    @Chris-D-0
                    hast du ein Backup?
                    #104
                    Ja, hab ich dann auch gesehen...
                      @Chris-D-0
                      hast du ein Backup?
                      Chris-D 0
                      #105
                      @homoran ja backup habe ich
                        Chris-D 0
                        #106
                        2021-08-20 13:22:25.557  - info: hm-rpc.1 (23665) Connected
                        2021-08-20 13:22:21.109  - info: hm-rpc.0 (23523) xmlrpc <- listDevices ["raspberrypi:hm-rpc.0"]
                        2021-08-20 13:22:21.182  - info: hm-rpc.0 (23523) xmlrpc -> 52 devices
                        2021-08-20 13:22:21.209  - info: hm-rpc.0 (23523) Connected
                        2021-08-20 13:22:25.580  - info: hm-rpc.1 (23665) xmlrpc <- listDevices ["raspberrypi:hm-rpc.1"]
                        2021-08-20 13:22:30.516  - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 24164
                        2021-08-20 13:22:30.560  - info: host.raspberrypi instance scheduled system.adapter.ical.0 0 * * * *
                        2021-08-20 13:22:30.575  - info: host.raspberrypi instance system.adapter.ical.0 started with pid 24170
                        2021-08-20 13:22:31.165  - info: hm-rpc.1 (23665) xmlrpc -> 0 devices
                        2021-08-20 13:22:31.198  - info: samsung.0 (24138) starting. Version 0.2.9 in /opt/iobroker/node_modules/iobroker.samsung, node: v14.17.5
                        2021-08-20 13:22:32.466  - info: ical.0 (24170) starting. Version 1.11.2 in /opt/iobroker/node_modules/iobroker.ical, node: v14.17.5
                        2021-08-20 13:22:32.784  - info: hm-rpc.1 (23665) xmlrpc <- newDevices 415
                        2021-08-20 13:22:33.037  - info: ical.0 (24170) processing URL: Abfall http://abfallkalender.regioit.de/kalender-krwaf/downloadfile.jsp?format=ics&jahr=2021&ort=Schlo%C3%9F%20Holte-Stukenbrock&strasse=11671699&fraktion=1&fraktion=6&fraktion=7&fraktion=9&fraktion=11
                        2021-08-20 13:22:33.087  - info: hm-rpc.1 (23665) new HMIP devices/channels after filter: 0
                        2021-08-20 13:22:33.279  - info: ical.0 (24170) processing URL: Caro https://calendar.google.com/calendar/embed?src=caroline.deittert%40gmail.com&ctz=Europe%2FBerlin
                        2021-08-20 13:22:33.329  - info: host.raspberrypi instance system.adapter.hm-rega.0 started with pid 24190
                        2021-08-20 13:22:34.712  - info: ical.0 (24170) processing URL: Christian https://calendar.google.com/calendar/u/0?cid=Y2hyaXN0aWFuLmFkb2xmODlAZ29vZ2xlbWFpbC5jb20
                        2021-08-20 13:22:35.046  - info: hm-rega.0 (24190) starting. Version 3.0.29 in /opt/iobroker/node_modules/iobroker.hm-rega, node: v14.17.5
                        2021-08-20 13:22:35.209  - info: hm-rega.0 (24190) subscribe hm-rpc.0.BidCoS-RF.50.PRESS_SHORT
                        2021-08-20 13:22:35.415  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                        2021-08-20 13:22:35.524  - info: backitup.0 (24164) starting. Version 2.1.13 in /opt/iobroker/node_modules/iobroker.backitup, node: v14.17.5
                        2021-08-20 13:22:35.610  - info: backitup.0 (24164) [iobroker] backup was activated at 02:00 every 5 day(s)
                        2021-08-20 13:22:35.712  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                        2021-08-20 13:22:35.712  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                        2021-08-20 13:22:35.695  - info: backitup.0 (24164) [ccu] backup was activated at 01:30 every 5 day(s)
                        2021-08-20 13:22:36.183  - error: backitup.0 (24164) Error: Command failed: sudo mount -t cifs -o username=Backup,password=****,noserverino,rw,file_mode=0777,dir_mode=0777 //192.168.178.20/Datensicherung\SmartHome /opt/iobroker/backups
                        mount error(2): No such file or directory
                        Refer to the mount.cifs(8) manual page (e.g. man mount.cifs)
                        2021-08-20 13:22:37.346  - info: host.raspberrypi instance system.adapter.echarts.0 started with pid 24226
                        2021-08-20 13:22:41.032  - info: ical.0 (24170) Terminated (NO_ERROR): Without reason
                        2021-08-20 13:22:41.184  - info: echarts.0 (24226) starting. Version 0.4.13 in /opt/iobroker/node_modules/iobroker.echarts, node: v14.17.5
                        2021-08-20 13:22:41.327  - info: host.raspberrypi instance system.adapter.history.0 started with pid 24250
                        2021-08-20 13:22:41.560  - info: host.raspberrypi instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
                        2021-08-20 13:22:42.388  - info: history.0 (24250) starting. Version 1.9.13 in /opt/iobroker/node_modules/iobroker.history, node: v14.17.5
                        2021-08-20 13:22:42.459  - info: history.0 (24250) enabled logging of hm-rpc.1.000A1A49A1021D.1.ACTUAL_TEMPERATURE (Count=1), Alias=false
                        2021-08-20 13:22:42.460  - info: history.0 (24250) enabled logging of hm-rpc.1.000A9A49A2C621.1.HUMIDITY (Count=2), Alias=false
                        2021-08-20 13:22:45.344  - info: host.raspberrypi instance system.adapter.simple-api.0 started with pid 24267
                        2021-08-20 13:22:46.757  - info: simple-api.0 (24267) starting. Version 2.6.1 in /opt/iobroker/node_modules/iobroker.simple-api, node: v14.17.5
                        2021-08-20 13:22:46.818  - info: simple-api.0 (24267) simpleAPI server listening on port 8087
                        2021-08-20 13:22:46.819  - info: simple-api.0 (24267) Allow states only when user is owner: false
                        2021-08-20 13:22:46.823  - info: simple-api.0 (24267) http server listening on port 8087
                        2021-08-20 13:22:49.314  - error: host.raspberrypi startInstance system.adapter.web.0Invalid version of "js-controller". Installed "2.2.10", required ">=3.1.0
                        2021-08-20 13:22:53.346  - info: host.raspberrypi instance system.adapter.javascript.0 started with pid 24293
                        2021-08-20 13:22:57.507  - info: host.raspberrypi instance scheduled system.adapter.openweathermap.0 23 * * * *
                        2021-08-20 13:22:57.533  - info: host.raspberrypi instance system.adapter.openweathermap.0 started with pid 24305
                        2021-08-20 13:22:59.686  - info: javascript.0 (24293) starting. Version 5.2.8 in /opt/iobroker/node_modules/iobroker.javascript, node: v14.17.5
                        2021-08-20 13:22:59.840  - info: javascript.0 (24293) requesting all states
                        2021-08-20 13:22:59.844  - info: javascript.0 (24293) requesting all objects
                        2021-08-20 13:23:00.032  - warn: host.raspberrypi instance system.adapter.openweathermap.0 already running with pid 24305
                        2021-08-20 13:23:00.844  - info: openweathermap.0 (24305) starting. Version 0.1.0 in /opt/iobroker/node_modules/iobroker.openweathermap, node: v14.17.5
                        2021-08-20 13:23:01.119  - info: javascript.0 (24293) received all objects
                        2021-08-20 13:23:01.186  - info: javascript.0 (24293) received all states
                        2021-08-20 13:23:03.830  - info: openweathermap.0 (24305) Terminated (NO_ERROR): Without reason
                        2021-08-20 13:23:04.371  - info: host.raspberrypi instance system.adapter.openweathermap.0 terminated with code 0 (NO_ERROR)
                        2021-08-20 13:23:25.756  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                        2021-08-20 13:23:25.827  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                        2021-08-20 13:23:25.828  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                        2021-08-20 13:24:05.379  - error: tr-064.0 (24042) Error: read ECONNRESET - {"errno":-104,"code":"ECONNRESET","syscall":"read"}
                        2021-08-20 13:24:05.381  - error: tr-064.0 (24042) ~
                        2021-08-20 13:24:05.383  - error: tr-064.0 (24042) ~~ Fatal error. Can not connect to your FritzBox.
                        2021-08-20 13:24:05.384  - error: tr-064.0 (24042) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
                        2021-08-20 13:24:05.385  - error: tr-064.0 (24042) ~
                        2021-08-20 13:24:05.387  - warn: tr-064.0 (24042) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
                        2021-08-20 13:24:05.951  - error: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                        2021-08-20 13:24:05.953  - info: host.raspberrypi Restart adapter system.adapter.tr-064.0 because enabled
                        2021-08-20 13:24:15.873  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                        2021-08-20 13:24:15.956  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                        2021-08-20 13:24:15.957  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                        2021-08-20 13:24:35.986  - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 24403
                        2021-08-20 13:24:37.537  - info: tr-064.0 (24403) starting. Version 4.2.14 in /opt/iobroker/node_modules/iobroker.tr-064, node: v14.17.5
                        2021-08-20 13:25:06.003  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                        2021-08-20 13:25:06.054  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                        2021-08-20 13:25:06.055  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                        2021-08-20 13:25:56.103  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                        2021-08-20 13:25:56.149  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                        2021-08-20 13:25:56.150  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                        2021-08-20 13:26:28.738  - error: tr-064.0 (24403) Error: read ECONNRESET - {"errno":-104,"code":"ECONNRESET","syscall":"read"}
                        2021-08-20 13:26:28.740  - error: tr-064.0 (24403) ~
                        2021-08-20 13:26:28.741  - error: tr-064.0 (24403) ~~ Fatal error. Can not connect to your FritzBox.
                        2021-08-20 13:26:28.742  - error: tr-064.0 (24403) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
                        2021-08-20 13:26:28.743  - error: tr-064.0 (24403) ~
                        2021-08-20 13:26:28.746  - warn: tr-064.0 (24403) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
                        2021-08-20 13:26:29.293  - error: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                        2021-08-20 13:26:29.294  - info: host.raspberrypi Restart adapter system.adapter.tr-064.0 because enabled
                        2021-08-20 13:26:46.194  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                        2021-08-20 13:26:46.235  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                        2021-08-20 13:26:46.236  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                        2021-08-20 13:26:59.349  - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 24563
                        2021-08-20 13:27:00.989  - info: tr-064.0 (24563) starting. Version 4.2.14 in /opt/iobroker/node_modules/iobroker.tr-064, node: v14.17.5
                        2021-08-20 13:27:36.311  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                        2021-08-20 13:27:36.383  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                        2021-08-20 13:27:36.384  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                        2021-08-20 13:28:26.425  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                        2021-08-20 13:28:26.459  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                        2021-08-20 13:28:26.461  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                        2021-08-20 13:28:52.099  - error: tr-064.0 (24563) Error: read ECONNRESET - {"errno":-104,"code":"ECONNRESET","syscall":"read"}
                        2021-08-20 13:28:52.101  - error: tr-064.0 (24563) ~
                        2021-08-20 13:28:52.103  - error: tr-064.0 (24563) ~~ Fatal error. Can not connect to your FritzBox.
                        2021-08-20 13:28:52.104  - error: tr-064.0 (24563) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
                        2021-08-20 13:28:52.105  - error: tr-064.0 (24563) ~
                        2021-08-20 13:28:52.107  - warn: tr-064.0 (24563) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
                        2021-08-20 13:28:52.648  - error: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                        2021-08-20 13:28:52.649  - info: host.raspberrypi Restart adapter system.adapter.tr-064.0 because enabled
                        2021-08-20 13:29:16.497  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                        2021-08-20 13:29:16.515  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                        2021-08-20 13:29:16.516  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                        2021-08-20 13:29:22.687  - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 24700
                        2021-08-20 13:29:24.211  - info: tr-064.0 (24700) starting. Version 4.2.14 in /opt/iobroker/node_modules/iobroker.tr-064, node: v14.17.5
                        2021-08-20 13:30:06.556  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                        2021-08-20 13:30:06.598  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                        2021-08-20 13:30:06.599  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                        2021-08-20 13:30:56.641  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                        2021-08-20 13:30:56.671  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                        2021-08-20 13:30:56.672  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                        2021-08-20 13:31:15.458  - error: tr-064.0 (24700) Error: read ECONNRESET - {"errno":-104,"code":"ECONNRESET","syscall":"read"}
                        2021-08-20 13:31:15.460  - error: tr-064.0 (24700) ~
                        2021-08-20 13:31:15.462  - error: tr-064.0 (24700) ~~ Fatal error. Can not connect to your FritzBox.
                        2021-08-20 13:31:15.463  - error: tr-064.0 (24700) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
                        2021-08-20 13:31:15.464  - error: tr-064.0 (24700) ~
                        2021-08-20 13:31:15.466  - warn: tr-064.0 (24700) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
                        2021-08-20 13:31:16.019  - error: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                        2021-08-20 13:31:16.020  - info: host.raspberrypi Restart adapter system.adapter.tr-064.0 because enabled
                        2021-08-20 13:31:46.047  - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 24828
                        2021-08-20 13:31:46.712  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                        2021-08-20 13:31:46.734  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                        2021-08-20 13:31:46.735  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                        2021-08-20 13:31:47.595  - info: tr-064.0 (24828) starting. Version 4.2.14 in /opt/iobroker/node_modules/iobroker.tr-064, node: v14.17.5
                        2021-08-20 13:32:36.775  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                        2021-08-20 13:32:36.805  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                        2021-08-20 13:32:36.805  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                        2021-08-20 13:33:26.876  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                        2021-08-20 13:33:26.947  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                        2021-08-20 13:33:26.948  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                        2021-08-20 13:33:43.938  - error: tr-064.0 (24828) Error: read ECONNRESET - {"errno":-104,"code":"ECONNRESET","syscall":"read"}
                        2021-08-20 13:33:43.940  - error: tr-064.0 (24828) ~
                        2021-08-20 13:33:43.942  - error: tr-064.0 (24828) ~~ Fatal error. Can not connect to your FritzBox.
                        2021-08-20 13:33:43.943  - error: tr-064.0 (24828) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
                        2021-08-20 13:33:43.944  - error: tr-064.0 (24828) ~
                        2021-08-20 13:33:43.946  - warn: tr-064.0 (24828) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
                        2021-08-20 13:33:44.494  - error: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                        2021-08-20 13:33:44.496  - info: host.raspberrypi Restart adapter system.adapter.tr-064.0 because enabled
                        2021-08-20 13:34:14.550  - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 24956
                        2021-08-20 13:34:16.029  - info: tr-064.0 (24956) starting. Version 4.2.14 in /opt/iobroker/node_modules/iobroker.tr-064, node: v14.17.5
                        2021-08-20 13:34:16.992  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                        2021-08-20 13:34:17.024  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                        2021-08-20 13:34:17.025  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                        2021-08-20 13:35:07.064  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                        2021-08-20 13:35:07.087  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                        2021-08-20 13:35:07.088  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                        2021-08-20 13:35:57.125  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                        2021-08-20 13:35:57.159  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                        2021-08-20 13:35:57.160  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                        2021-08-20 13:36:07.298  - error: tr-064.0 (24956) Error: read ECONNRESET - {"errno":-104,"code":"ECONNRESET","syscall":"read"}
                        2021-08-20 13:36:07.300  - error: tr-064.0 (24956) ~
                        2021-08-20 13:36:07.301  - error: tr-064.0 (24956) ~~ Fatal error. Can not connect to your FritzBox.
                        2021-08-20 13:36:07.302  - error: tr-064.0 (24956) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
                        2021-08-20 13:36:07.303  - error: tr-064.0 (24956) ~
                        2021-08-20 13:36:07.305  - warn: tr-064.0 (24956) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
                        2021-08-20 13:36:07.867  - error: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                        2021-08-20 13:36:07.869  - info: host.raspberrypi Restart adapter system.adapter.tr-064.0 because enabled
                        2021-08-20 13:36:37.931  - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 25084
                        2021-08-20 13:36:39.428  - info: tr-064.0 (25084) starting. Version 4.2.14 in /opt/iobroker/node_modules/iobroker.tr-064, node: v14.17.5
                        2021-08-20 13:36:47.203  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                        2021-08-20 13:36:47.232  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                        2021-08-20 13:36:47.233  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                        2021-08-20 13:37:37.275  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                        2021-08-20 13:37:37.310  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                        2021-08-20 13:37:37.311  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                        2021-08-20 13:38:27.383  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                        2021-08-20 13:38:27.452  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                        2021-08-20 13:38:27.453  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                        2021-08-20 13:38:30.658  - error: tr-064.0 (25084) Error: read ECONNRESET - {"errno":-104,"code":"ECONNRESET","syscall":"read"}
                        2021-08-20 13:38:30.659  - error: tr-064.0 (25084) ~
                        2021-08-20 13:38:30.660  - error: tr-064.0 (25084) ~~ Fatal error. Can not connect to your FritzBox.
                        2021-08-20 13:38:30.661  - error: tr-064.0 (25084) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
                        2021-08-20 13:38:30.662  - error: tr-064.0 (25084) ~
                        2021-08-20 13:38:30.664  - warn: tr-064.0 (25084) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
                        2021-08-20 13:38:31.227  - error: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                        2021-08-20 13:38:31.239  - info: host.raspberrypi Restart adapter system.adapter.tr-064.0 because enabled
                        2021-08-20 13:39:01.302  - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 25224
                        2021-08-20 13:39:02.883  - info: tr-064.0 (25224) starting. Version 4.2.14 in /opt/iobroker/node_modules/iobroker.tr-064, node: v14.17.5
                        2021-08-20 13:39:17.496  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                        2021-08-20 13:39:17.530  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                        2021-08-20 13:39:17.531  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                        2021-08-20 13:40:07.576  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                        2021-08-20 13:40:07.606  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                        2021-08-20 13:40:07.607  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                        2021-08-20 13:40:54.014  - error: tr-064.0 (25224) Error: read ECONNRESET - {"errno":-104,"code":"ECONNRESET","syscall":"read"}
                        2021-08-20 13:40:54.017  - error: tr-064.0 (25224) ~
                        2021-08-20 13:40:54.018  - error: tr-064.0 (25224) ~~ Fatal error. Can not connect to your FritzBox.
                        2021-08-20 13:40:54.019  - error: tr-064.0 (25224) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
                        2021-08-20 13:40:54.020  - error: tr-064.0 (25224) ~
                        2021-08-20 13:40:54.022  - warn: tr-064.0 (25224) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
                        2021-08-20 13:40:54.574  - error: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                        2021-08-20 13:40:54.585  - info: host.raspberrypi Restart adapter system.adapter.tr-064.0 because enabled
                        2021-08-20 13:40:57.648  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                        2021-08-20 13:40:57.673  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                        2021-08-20 13:40:57.674  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                        2021-08-20 13:41:24.645  - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 25417
                        2021-08-20 13:41:26.131  - info: tr-064.0 (25417) starting. Version 4.2.14 in /opt/iobroker/node_modules/iobroker.tr-064, node: v14.17.5
                        2021-08-20 13:41:47.710  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                        2021-08-20 13:41:47.757  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                        2021-08-20 13:41:47.758  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                        2021-08-20 13:42:37.803  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                        2021-08-20 13:42:37.836  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                        2021-08-20 13:42:37.837  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                        2021-08-20 13:43:17.376  - error: tr-064.0 (25417) Error: read ECONNRESET - {"errno":-104,"code":"ECONNRESET","syscall":"read"}
                        2021-08-20 13:43:17.378  - error: tr-064.0 (25417) ~
                        2021-08-20 13:43:17.379  - error: tr-064.0 (25417) ~~ Fatal error. Can not connect to your FritzBox.
                        2021-08-20 13:43:17.380  - error: tr-064.0 (25417) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
                        2021-08-20 13:43:17.381  - error: tr-064.0 (25417) ~
                        2021-08-20 13:43:17.383  - warn: tr-064.0 (25417) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
                        2021-08-20 13:43:17.923  - error: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                        2021-08-20 13:43:17.925  - info: host.raspberrypi Restart adapter system.adapter.tr-064.0 because enabled
                        2021-08-20 13:43:27.884  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                        2021-08-20 13:43:27.930  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                        2021-08-20 13:43:27.931  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                        2021-08-20 13:43:47.963  - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 25546
                        2021-08-20 13:43:49.562  - info: tr-064.0 (25546) starting. Version 4.2.14 in /opt/iobroker/node_modules/iobroker.tr-064, node: v14.17.5
                        2021-08-20 13:44:18.000  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                        2021-08-20 13:44:18.070  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                        2021-08-20 13:44:18.070  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                        2021-08-20 13:45:08.109  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                        2021-08-20 13:45:08.139  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                        2021-08-20 13:45:08.140  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                        2021-08-20 13:45:40.738  - error: tr-064.0 (25546) Error: read ECONNRESET - {"errno":-104,"code":"ECONNRESET","syscall":"read"}
                        2021-08-20 13:45:40.741  - error: tr-064.0 (25546) ~
                        2021-08-20 13:45:40.742  - error: tr-064.0 (25546) ~~ Fatal error. Can not connect to your FritzBox.
                        2021-08-20 13:45:40.743  - error: tr-064.0 (25546) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
                        2021-08-20 13:45:40.744  - error: tr-064.0 (25546) ~
                        2021-08-20 13:45:40.746  - warn: tr-064.0 (25546) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
                        2021-08-20 13:45:41.299  - error: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                        2021-08-20 13:45:41.300  - info: host.raspberrypi Restart adapter system.adapter.tr-064.0 because enabled
                        2021-08-20 13:45:58.178  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                        2021-08-20 13:45:58.212  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                        2021-08-20 13:45:58.213  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                        2021-08-20 13:46:11.356  - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 25653
                        2021-08-20 13:46:12.879  - info: tr-064.0 (25653) starting. Version 4.2.14 in /opt/iobroker/node_modules/iobroker.tr-064, node: v14.17.5
                        2021-08-20 13:46:48.251  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                        2021-08-20 13:46:48.280  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                        2021-08-20 13:46:48.281  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                        2021-08-20 13:47:38.326  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                        2021-08-20 13:47:38.401  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                        2021-08-20 13:47:38.402  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                        2021-08-20 13:48:04.097  - error: tr-064.0 (25653) Error: read ECONNRESET - {"errno":-104,"code":"ECONNRESET","syscall":"read"}
                        2021-08-20 13:48:04.100  - error: tr-064.0 (25653) ~
                        2021-08-20 13:48:04.101  - error: tr-064.0 (25653) ~~ Fatal error. Can not connect to your FritzBox.
                        2021-08-20 13:48:04.102  - error: tr-064.0 (25653) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
                        2021-08-20 13:48:04.103  - error: tr-064.0 (25653) ~
                        2021-08-20 13:48:04.106  - warn: tr-064.0 (25653) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
                        2021-08-20 13:48:04.652  - error: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                        2021-08-20 13:48:04.653  - info: host.raspberrypi Restart adapter system.adapter.tr-064.0 because enabled
                        2021-08-20 13:48:28.445  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                        2021-08-20 13:48:28.495  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                        2021-08-20 13:48:28.496  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                        2021-08-20 13:48:34.689  - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 25770
                        2021-08-20 13:48:36.152  - info: tr-064.0 (25770) starting. Version 4.2.14 in /opt/iobroker/node_modules/iobroker.tr-064, node: v14.17.5
                        2021-08-20 13:49:18.566  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                        2021-08-20 13:49:18.599  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                        2021-08-20 13:49:18.600  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                        2021-08-20 13:50:08.645  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                        2021-08-20 13:50:08.713  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                        2021-08-20 13:50:08.714  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                        2021-08-20 13:50:27.460  - error: tr-064.0 (25770) Error: read ECONNRESET - {"errno":-104,"code":"ECONNRESET","syscall":"read"}
                        2021-08-20 13:50:27.463  - error: tr-064.0 (25770) ~
                        2021-08-20 13:50:27.465  - error: tr-064.0 (25770) ~~ Fatal error. Can not connect to your FritzBox.
                        2021-08-20 13:50:27.467  - error: tr-064.0 (25770) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
                        2021-08-20 13:50:27.468  - error: tr-064.0 (25770) ~
                        2021-08-20 13:50:27.471  - warn: tr-064.0 (25770) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
                        2021-08-20 13:50:28.040  - error: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                        2021-08-20 13:50:28.052  - info: host.raspberrypi Restart adapter system.adapter.tr-064.0 because enabled
                        2021-08-20 13:50:58.104  - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 25863
                        2021-08-20 13:50:58.756  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                        2021-08-20 13:50:58.781  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                        2021-08-20 13:50:58.782  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                        2021-08-20 13:50:59.632  - info: tr-064.0 (25863) starting. Version 4.2.14 in /opt/iobroker/node_modules/iobroker.tr-064, node: v14.17.5
                        2021-08-20 13:51:48.824  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                        2021-08-20 13:51:48.850  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                        2021-08-20 13:51:48.851  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                        2021-08-20 13:52:38.894  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                        2021-08-20 13:52:38.920  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                        2021-08-20 13:52:38.921  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                        2021-08-20 13:52:50.812  - error: tr-064.0 (25863) Error: read ECONNRESET - {"errno":-104,"code":"ECONNRESET","syscall":"read"}
                        2021-08-20 13:52:50.814  - error: tr-064.0 (25863) ~
                        2021-08-20 13:52:50.815  - error: tr-064.0 (25863) ~~ Fatal error. Can not connect to your FritzBox.
                        2021-08-20 13:52:50.816  - error: tr-064.0 (25863) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
                        2021-08-20 13:52:50.817  - error: tr-064.0 (25863) ~
                        2021-08-20 13:52:50.819  - warn: tr-064.0 (25863) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
                        2021-08-20 13:52:51.373  - error: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                        2021-08-20 13:52:51.374  - info: host.raspberrypi Restart adapter system.adapter.tr-064.0 because enabled
                        2021-08-20 13:53:21.409  - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 25970
                        2021-08-20 13:53:22.902  - info: tr-064.0 (25970) starting. Version 4.2.14 in /opt/iobroker/node_modules/iobroker.tr-064, node: v14.17.5
                        2021-08-20 13:53:28.957  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                        2021-08-20 13:53:28.973  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                        2021-08-20 13:53:28.973  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                        2021-08-20 13:54:19.016  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                        2021-08-20 13:54:19.038  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                        2021-08-20 13:54:19.039  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                        2021-08-20 13:55:09.112  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                        2021-08-20 13:55:09.179  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                        2021-08-20 13:55:09.180  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                        2021-08-20 13:55:14.178  - error: tr-064.0 (25970) Error: read ECONNRESET - {"errno":-104,"code":"ECONNRESET","syscall":"read"}
                        2021-08-20 13:55:14.180  - error: tr-064.0 (25970) ~
                        2021-08-20 13:55:14.182  - error: tr-064.0 (25970) ~~ Fatal error. Can not connect to your FritzBox.
                        2021-08-20 13:55:14.183  - error: tr-064.0 (25970) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
                        2021-08-20 13:55:14.184  - error: tr-064.0 (25970) ~
                        2021-08-20 13:55:14.186  - warn: tr-064.0 (25970) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
                        2021-08-20 13:55:14.748  - error: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                        2021-08-20 13:55:14.761  - info: host.raspberrypi Restart adapter system.adapter.tr-064.0 because enabled
                        2021-08-20 13:55:44.821  - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 26097
                        2021-08-20 13:55:46.478  - info: tr-064.0 (26097) starting. Version 4.2.14 in /opt/iobroker/node_modules/iobroker.tr-064, node: v14.17.5
                        2021-08-20 13:55:59.224  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                        2021-08-20 13:55:59.249  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                        2021-08-20 13:55:59.250  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                        2021-08-20 13:56:49.294  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                        2021-08-20 13:56:49.370  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                        2021-08-20 13:56:49.371  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                        2021-08-20 13:57:37.538  - error: tr-064.0 (26097) Error: read ECONNRESET - {"errno":-104,"code":"ECONNRESET","syscall":"read"}
                        2021-08-20 13:57:37.540  - error: tr-064.0 (26097) ~
                        2021-08-20 13:57:37.542  - error: tr-064.0 (26097) ~~ Fatal error. Can not connect to your FritzBox.
                        2021-08-20 13:57:37.543  - error: tr-064.0 (26097) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
                        2021-08-20 13:57:37.544  - error: tr-064.0 (26097) ~
                        2021-08-20 13:57:37.546  - warn: tr-064.0 (26097) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
                        2021-08-20 13:57:38.085  - error: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                        2021-08-20 13:57:38.087  - info: host.raspberrypi Restart adapter system.adapter.tr-064.0 because enabled
                        2021-08-20 13:57:39.412  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                        2021-08-20 13:57:39.438  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                        2021-08-20 13:57:39.439  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                        2021-08-20 13:58:08.120  - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 26200
                        2021-08-20 13:58:09.574  - info: tr-064.0 (26200) starting. Version 4.2.14 in /opt/iobroker/node_modules/iobroker.tr-064, node: v14.17.5
                        2021-08-20 13:58:29.477  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                        2021-08-20 13:58:29.501  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                        2021-08-20 13:58:29.502  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                        2021-08-20 13:59:19.543  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                        2021-08-20 13:59:19.558  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                        2021-08-20 13:59:19.559  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                        2021-08-20 14:00:00.074  - info: host.raspberrypi instance system.adapter.ical.0 started with pid 26327
                        2021-08-20 14:00:00.885  - error: tr-064.0 (26200) Error: read ECONNRESET - {"errno":-104,"code":"ECONNRESET","syscall":"read"}
                        2021-08-20 14:00:00.886  - error: tr-064.0 (26200) ~
                        2021-08-20 14:00:00.887  - error: tr-064.0 (26200) ~~ Fatal error. Can not connect to your FritzBox.
                        2021-08-20 14:00:00.888  - error: tr-064.0 (26200) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
                        2021-08-20 14:00:00.889  - warn: tr-064.0 (26200) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
                        2021-08-20 14:00:01.423  - error: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                        2021-08-20 14:00:01.424  - info: host.raspberrypi Restart adapter system.adapter.tr-064.0 because enabled
                        2021-08-20 14:00:01.884  - info: ical.0 (26327) starting. Version 1.11.2 in /opt/iobroker/node_modules/iobroker.ical, node: v14.17.5
                        2021-08-20 14:00:02.716  - info: ical.0 (26327) processing URL: Caro https://calendar.google.com/calendar/embed?src=caroline.deittert%40gmail.com&ctz=Europe%2FBerlin
                        2021-08-20 14:00:02.738  - info: ical.0 (26327) processing URL: Abfall http://abfallkalender.regioit.de/kalender-krwaf/downloadfile.jsp?format=ics&jahr=2021&ort=Schlo%C3%9F%20Holte-Stukenbrock&strasse=11671699&fraktion=1&fraktion=6&fraktion=7&fraktion=9&fraktion=11
                        2021-08-20 14:00:02.917  - info: ical.0 (26327) processing URL: Christian https://calendar.google.com/calendar/u/0?cid=Y2hyaXN0aWFuLmFkb2xmODlAZ29vZ2xlbWFpbC5jb20
                        2021-08-20 14:00:07.955  - info: ical.0 (26327) Terminated (NO_ERROR): Without reason
                        2021-08-20 14:00:08.486  - info: host.raspberrypi instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
                        2021-08-20 14:00:09.598  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                        2021-08-20 14:00:09.675  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                        2021-08-20 14:00:09.676  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                        2021-08-20 14:00:31.477  - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 26353
                        2021-08-20 14:00:32.997  - info: tr-064.0 (26353) starting. Version 4.2.14 in /opt/iobroker/node_modules/iobroker.tr-064, node: v14.17.5
                        2021-08-20 14:00:59.742  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                        2021-08-20 14:00:59.786  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                        2021-08-20 14:00:59.786  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                        2021-08-20 14:01:49.826  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                        2021-08-20 14:01:49.859  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                        2021-08-20 14:01:49.860  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                        2021-08-20 14:02:24.258  - error: tr-064.0 (26353) Error: read ECONNRESET - {"errno":-104,"code":"ECONNRESET","syscall":"read"}
                        2021-08-20 14:02:24.260  - error: tr-064.0 (26353) ~
                        2021-08-20 14:02:24.261  - error: tr-064.0 (26353) ~~ Fatal error. Can not connect to your FritzBox.
                        2021-08-20 14:02:24.263  - error: tr-064.0 (26353) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
                        2021-08-20 14:02:24.264  - error: tr-064.0 (26353) ~
                        2021-08-20 14:02:24.266  - warn: tr-064.0 (26353) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
                        2021-08-20 14:02:24.825  - error: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                        2021-08-20 14:02:24.836  - info: host.raspberrypi Restart adapter system.adapter.tr-064.0 because enabled
                        2021-08-20 14:02:39.922  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                        2021-08-20 14:02:39.946  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                        2021-08-20 14:02:39.947  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                        2021-08-20 14:02:54.938  - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 26489
                        2021-08-20 14:02:56.448  - info: tr-064.0 (26489) starting. Version 4.2.14 in /opt/iobroker/node_modules/iobroker.tr-064, node: v14.17.5
                        2021-08-20 14:03:29.987  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                        2021-08-20 14:03:30.017  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                        2021-08-20 14:03:30.017  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                        2021-08-20 14:04:20.056  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                        2021-08-20 14:04:20.093  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                        2021-08-20 14:04:20.094  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                        2021-08-20 14:04:47.618  - error: tr-064.0 (26489) Error: read ECONNRESET - {"errno":-104,"code":"ECONNRESET","syscall":"read"}
                        2021-08-20 14:04:47.620  - error: tr-064.0 (26489) ~
                        2021-08-20 14:04:47.622  - error: tr-064.0 (26489) ~~ Fatal error. Can not connect to your FritzBox.
                        2021-08-20 14:04:47.623  - error: tr-064.0 (26489) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
                        2021-08-20 14:04:47.624  - error: tr-064.0 (26489) ~
                        2021-08-20 14:04:47.626  - warn: tr-064.0 (26489) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
                        2021-08-20 14:04:48.177  - error: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                        2021-08-20 14:04:48.179  - info: host.raspberrypi Restart adapter system.adapter.tr-064.0 because enabled
                        2021-08-20 14:05:10.140  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                        2021-08-20 14:05:10.216  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                        2021-08-20 14:05:10.217  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                        2021-08-20 14:05:18.244  - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 26596
                        2021-08-20 14:05:19.768  - info: tr-064.0 (26596) starting. Version 4.2.14 in /opt/iobroker/node_modules/iobroker.tr-064, node: v14.17.5
                        2021-08-20 14:06:00.286  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                        2021-08-20 14:06:00.360  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                        2021-08-20 14:06:00.360  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                        2021-08-20 14:06:50.404  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                        2021-08-20 14:06:50.432  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                        2021-08-20 14:06:50.433  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                        2021-08-20 14:07:10.978  - error: tr-064.0 (26596) Error: read ECONNRESET - {"errno":-104,"code":"ECONNRESET","syscall":"read"}
                        2021-08-20 14:07:10.980  - error: tr-064.0 (26596) ~
                        2021-08-20 14:07:10.981  - error: tr-064.0 (26596) ~~ Fatal error. Can not connect to your FritzBox.
                        2021-08-20 14:07:10.983  - error: tr-064.0 (26596) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
                        2021-08-20 14:07:10.984  - error: tr-064.0 (26596) ~
                        2021-08-20 14:07:10.986  - warn: tr-064.0 (26596) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
                        2021-08-20 14:07:11.538  - error: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                        2021-08-20 14:07:11.540  - info: host.raspberrypi Restart adapter system.adapter.tr-064.0 because enabled
                        2021-08-20 14:07:40.472  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                        2021-08-20 14:07:40.497  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                        2021-08-20 14:07:40.498  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                        2021-08-20 14:07:41.599  - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 26712
                        2021-08-20 14:07:43.185  - info: tr-064.0 (26712) starting. Version 4.2.14 in /opt/iobroker/node_modules/iobroker.tr-064, node: v14.17.5
                        2021-08-20 14:08:30.537  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                        2021-08-20 14:08:30.563  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                        2021-08-20 14:08:30.564  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                        2021-08-20 14:09:20.601  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                        2021-08-20 14:09:20.704  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                        2021-08-20 14:09:20.705  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                        2021-08-20 14:09:34.338  - error: tr-064.0 (26712) Error: read ECONNRESET - {"errno":-104,"code":"ECONNRESET","syscall":"read"}
                        2021-08-20 14:09:34.341  - error: tr-064.0 (26712) ~
                        2021-08-20 14:09:34.342  - error: tr-064.0 (26712) ~~ Fatal error. Can not connect to your FritzBox.
                        2021-08-20 14:09:34.344  - error: tr-064.0 (26712) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
                        2021-08-20 14:09:34.345  - error: tr-064.0 (26712) ~
                        2021-08-20 14:09:34.347  - warn: tr-064.0 (26712) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
                        2021-08-20 14:09:34.907  - error: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                        2021-08-20 14:09:34.919  - info: host.raspberrypi Restart adapter system.adapter.tr-064.0 because enabled
                        2021-08-20 14:10:04.983  - info: host.raspberrypi instance system.adapter.tr-064.0 started with pid 26843
                        2021-08-20 14:10:06.495  - info: tr-064.0 (26843) starting. Version 4.2.14 in /opt/iobroker/node_modules/iobroker.tr-064, node: v14.17.5
                        2021-08-20 14:10:10.746  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                        2021-08-20 14:10:10.780  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                        2021-08-20 14:10:10.781  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                        2021-08-20 14:11:00.819  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                        2021-08-20 14:11:00.840  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                        2021-08-20 14:11:00.840  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                        2021-08-20 14:11:50.913  - info: hm-rega.0 (24190) ReGaHSS 192.168.178.50 up
                        2021-08-20 14:11:50.987  - error: hm-rega.0 (24190) <-- invalid response: "<?xml version=\"1.0\" encoding=\"iso-8859-1\"?>\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\"\n         \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\">\n<html xmlns=\"http://www.w3.org/1999/xhtml\" xml:lang=\"en\" lang=\"en\">\n <head>\n  <title>401 - Unauthorized</title>\n </head>\n <body>\n  <h1>401 - Unauthorized</h1>\n </body>\n</html>\n"
                        2021-08-20 14:11:50.988  - error: hm-rega.0 (24190) ReGaHSS 192.168.178.50 down
                        2021-08-20 14:11:57.690  - error: tr-064.0 (26843) Error: read ECONNRESET - {"errno":-104,"code":"ECONNRESET","syscall":"read"}
                        2021-08-20 14:11:57.692  - error: tr-064.0 (26843) ~
                        2021-08-20 14:11:57.693  - error: tr-064.0 (26843) ~~ Fatal error. Can not connect to your FritzBox.
                        2021-08-20 14:11:57.694  - error: tr-064.0 (26843) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
                        2021-08-20 14:11:57.695  - error: tr-064.0 (26843) ~
                        2021-08-20 14:11:57.697  - warn: tr-064.0 (26843) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
                        2021-08-20 14:11:58.237  - error: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                        2021-08-20 14:11:58.246  - info: host.raspberrypi Restart adapter system.adapter.tr-064.0 because enabled
                        • C Chris-D 0
                          @homoran ja backup habe ich
                          #107
                          @chris-d-0 sagte in Rega Fehler:
                          dann mach doch alles neu bevor du hier Stunden verbrätst.
                          node 14
                          kommt mit npm v6
                          curl -sLf https://iobroker.net/install.sh | bash -
                          Backup einspielen - warten - fertig!
                          C 1 Antwort Letzte Antwort
                            node 14
                            kommt mit npm v6
                            Chris-D 0
                            #108
                            @homoran ok welche befehle brauche ich genau?
                            • C Chris-D 0
                              #109
                              wofür genau?
                              • apollon77A Offline
                                #110
                                Jetzt mal langsam ... Also laut Log ist doch alles ok, ausser:
                                • tr-064 meldet das die Fritzbox die Verbindung ablehnt, da musst man Fritzbox Einstellungen checken
                                • hm-rega/rpc meldet das die CCU "401 Unauthorized" meldet ... hast du da irgendwie username/passwort konfiguriert aber nicht im Adapter?
                                • backitup meldet das ein CIFS Mount nicht da ist
                                Der Rest sieht alles normal und ok aus.
                                Von Admin finde ich im Log ausschnitt nicht
                                Also wenn das die Themen sind dann hilft auch ein backup einspielen nix
                                  wofür genau?
                                  Chris-D 0
                                  #111
                                  @homoran neu aufsetzen?
                                  • apollon77A apollon77
                                    Chris-D 0
                                    #112
                                    @apollon77 das ist leider nicht mehr das Problem, siehe verlauf
                                    haselchenH apollon77A 2 Antworten Letzte Antwort
                                    • C Chris-D 0
                                      haselchenH Offline
                                      haselchenH Offline
                                      haselchen
                                      #113
                                      @chris-d-0
                                      Wo liegt denn der Hase noch im Pfeffer?
                                      Welche Probleme gibt es noch?
                                      • C Chris-D 0
                                        #114
                                        @chris-d-0 ja was ist denn das Problem? Ich blicke bei dem Verkauf nimmer durch
                                        • haselchenH haselchen
                                          @chris-d-0
                                          Chris-D 0
                                          schrieb am zuletzt editiert von Chris-D 0
                                          #115
                                          @haselchen die IObroker Oberfläche wird nicht angezeigt. "Seite kann nicht angezeigt werden" Also Webseite nicht erreichbar
