  4. Rega Fehler
    6.4k
Rega Fehler
141 Beiträge 7 Kommentatoren 19.0k Aufrufe 5 Beobachtet
  • C Chris-D 0
    @haselchen yes
    haselchenH Offline
    haselchenH Offline
    haselchen
    @chris-d-0
    Auf keinen Fall unterbrechen oder Stromlos machen.
    Warte einfach mal ab....
    C 1 Antwort Letzte Antwort
    • haselchenH haselchen
      @chris-d-0
      Chris-D 0
      schrieb am zuletzt editiert von Chris-D 0
      @haselchen danach passierte lange nichts und danach kam einfach eine neue Eingabezeile
      pi@raspberrypi:~ $ iobroker upgrade self
      Update js-controller from @2.2.8 to @3.3.15
      NPM version: 6.14.14
      npm install iobroker.js-controller@3.3.15 --unsafe-perm --loglevel error --prefix "/opt/iobroker" (System call)
      pi@raspberrypi:~ $
      • C Chris-D 0
        pi@raspberrypi:~ $
        haselchenH Offline
        haselchenH Offline
        haselchen
        @chris-d-0
        Gib mal in der Reihenfolge ein
        iobroker stop
        sudo -H -u iobroker npm install iobroker.js-controller
        iobroker start
          @chris-d-0
          iobroker stop
          iobroker start
          Chris-D 0
          @haselchen
          pi@raspberrypi:~ $ iobroker stop
          pi@raspberrypi:~ $
          pi@raspberrypi:~ $ sudo -H -u iobroker npm install iobroker.js-controller
          npm WARN checkPermissions Missing write access to /home/pi/node_modules/@iobroker
          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents):
          npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
          npm WARN enoent ENOENT: no such file or directory, open '/home/pi/package.json'
          npm WARN pi No description
          npm WARN pi No repository field.
          npm WARN pi No README data
          npm WARN pi No license field.
          npm ERR! code EACCES
          npm ERR! syscall access
          npm ERR! path /home/pi/node_modules/@iobroker
          npm ERR! errno -13
          npm ERR! Error: EACCES: permission denied, access '/home/pi/node_modules/@iobroker'
          npm ERR!  [Error: EACCES: permission denied, access '/home/pi/node_modules/@iobroker'] {
          npm ERR!   errno: -13,
          npm ERR!   code: 'EACCES',
          npm ERR!   syscall: 'access',
          npm ERR!   path: '/home/pi/node_modules/@iobroker'
          npm ERR! }
          npm ERR!
          npm ERR! The operation was rejected by your operating system.
          npm ERR! It is likely you do not have the permissions to access this file as the current user
          npm ERR!
          npm ERR! If you believe this might be a permissions issue, please double-check the
          npm ERR! permissions of the file and its containing directories, or try running
          npm ERR! the command again as root/Administrator.
          npm ERR!     /home/iobroker/.npm/_logs/2021-08-19T14_20_19_283Z-debug.log
          HomoranH haselchenH 3 Antworten Letzte Antwort
          • C Chris-D 0
            @haselchen
            pi@raspberrypi:~ $
            npm ERR! errno -13
            npm ERR! }
            npm ERR!
            npm ERR!
            @chris-d-0 sagte in Rega Fehler:
            was hast du da angestellt?
            den npm-Befehl in /home/pi ausgeführt???
            der muss in /opt/iobroker ausgeführt werden
            • C Chris-D 0
              @haselchen
              pi@raspberrypi:~ $
              npm ERR! errno -13
              npm ERR! }
              npm ERR!
              npm ERR!
              haselchenH Offline
              haselchenH Offline
              haselchen
              @chris-d-0
              cd /opt/iobroker
              curl -sL https://iobroker.net/fix.sh | bash -
              Edit:
              sehe ich jetzt erst....wo zum Himmel hast du das alles hin installiert?
                Chris-D 0
                #66
                @homoran @haselchen Nicht bewusst
                • C Chris-D 0
                  @haselchen
                  pi@raspberrypi:~ $
                  npm ERR! errno -13
                  npm ERR! }
                  npm ERR!
                  npm ERR!
                  #67
                  da bist du in deinem Home Verzeichnis
                  Wie man da die Installation wieder rausbekommt weiß ich nicht.
                  Du musst vorher ein cd /opt/iobroker machen bevor du den npm-Befehl absetzst
                    Chris-D 0
                    #68
                    @homoran @haselchen Holy...
                    pi@raspberrypi:~ $ cd /opt/iobroker
                    pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
                    npm WARN read-shrinkwrap This version of npm is compatible with lockfileVersion@1, but package-lock.json was generated for lockfileVersion@2. I'll try to do my best with it!
                    > iobroker.js-controller@2.2.10 preinstall /opt/iobroker/node_modules/iobroker.js-controller
                    > node lib/preinstallCheck.js
                    > unix-dgram@2.0.3 install /opt/iobroker/node_modules/unix-dgram
                    > node-gyp rebuild
                    make: Verzeichnis „/opt/iobroker/node_modules/unix-dgram/build“ wird betreten
                      CXX(target) Release/obj.target/unix_dgram/src/unix_dgram.o
                    In file included from ../src/unix_dgram.cc:5:
                    ../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:
                    ../../nan/nan.h:2294:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                         , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)
                    In file included from ../../nan/nan.h:56,
                    ../src/unix_dgram.cc: At global scope:
                    /home/iobroker/.cache/node-gyp/14.17.5/include/node/node.h:758:43: warning: cast between incompatible function types from ‘void (*)(v8::Local<v8::Object>)’ to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
                           (node::addon_register_func) (regfunc),                          \
                    /home/iobroker/.cache/node-gyp/14.17.5/include/node/node.h:792:3: note: in expansion of macro ‘NODE_MODULE_X’
                       NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
                    ../src/unix_dgram.cc:404:1: note: in expansion of macro ‘NODE_MODULE’
                     NODE_MODULE(unix_dgram, Initialize)
                      SOLINK_MODULE(target) Release/obj.target/unix_dgram.node
                      COPY Release/unix_dgram.node
                    make: Verzeichnis „/opt/iobroker/node_modules/unix-dgram/build“ wird verlassen
                    > ursa-optional@0.9.10 install /opt/iobroker/node_modules/ursa-optional
                    > node rebuild.js
                    ursaNative bindings compilation fail. This is not an issue. Modules that depend on it will use fallbacks.
                    > @serialport/bindings@9.2.0 install /opt/iobroker/node_modules/@serialport/bindings
                    > prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
                    prebuild-install WARN install No prebuilt binaries found (target=14.17.5 runtime=node arch=arm libc= platform=linux)
                    make: Verzeichnis „/opt/iobroker/node_modules/@serialport/bindings/build“ wird betreten
                      CXX(target) Release/obj.target/bindings/src/serialport.o
                    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Open(Nan::NAN_METHOD_ARGS_TYPE)’:
                    ../src/serialport.cpp:78:69: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                       uv_queue_work(uv_default_loop(), req, EIO_Open, (uv_after_work_cb)EIO_AfterOpen);
                    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)’:
                    ../src/serialport.cpp:135:71: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                       uv_queue_work(uv_default_loop(), req, EIO_Update, (uv_after_work_cb)EIO_AfterUpdate);
                    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Close(Nan::NAN_METHOD_ARGS_TYPE)’:
                    ../src/serialport.cpp:175:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                       uv_queue_work(uv_default_loop(), req, EIO_Close, (uv_after_work_cb)EIO_AfterClose);
                    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Flush(Nan::NAN_METHOD_ARGS_TYPE)’:
                    ../src/serialport.cpp:215:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                       uv_queue_work(uv_default_loop(), req, EIO_Flush, (uv_after_work_cb)EIO_AfterFlush);
                    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_METHOD_ARGS_TYPE)’:
                    ../src/serialport.cpp:271:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                       uv_queue_work(uv_default_loop(), req, EIO_Set, (uv_after_work_cb)EIO_AfterSet);
                    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Get(Nan::NAN_METHOD_ARGS_TYPE)’:
                    ../src/serialport.cpp:316:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                       uv_queue_work(uv_default_loop(), req, EIO_Get, (uv_after_work_cb)EIO_AfterGet);
                    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE GetBaudRate(Nan::NAN_METHOD_ARGS_TYPE)’:
                    ../src/serialport.cpp:366:76: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                       uv_queue_work(uv_default_loop(), req, EIO_GetBaudRate, (uv_after_work_cb)EIO_AfterGetBaudRate);
                    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Drain(Nan::NAN_METHOD_ARGS_TYPE)’:
                    ../src/serialport.cpp:412:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                       uv_queue_work(uv_default_loop(), req, EIO_Drain, (uv_after_work_cb)EIO_AfterDrain);
                    ../src/serialport.cpp: At global scope:
                    ../src/serialport.cpp:433:28: warning: unnecessary parentheses in declaration of ‘ToParityEnum’ [-Wparentheses]
                     SerialPortParity NAN_INLINE(ToParityEnum(const v8::Local<v8::String>& v8str)) {
                    ../src/serialport.cpp:452:30: warning: unnecessary parentheses in declaration of ‘ToStopBitEnum’ [-Wparentheses]
                     SerialPortStopBits NAN_INLINE(ToStopBitEnum(double stopBits)) {
                    In file included from ../node_modules/nan/nan.h:58,
                                     from ../src/./serialport.h:13,
                                     from ../src/serialport.cpp:1:
                    /home/iobroker/.cache/node-gyp/14.17.5/include/node/node.h:758:43: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
                    ../src/serialport.cpp:486:1: note: in expansion of macro ‘NODE_MODULE’
                     NODE_MODULE(serialport, init);
                      CXX(target) Release/obj.target/bindings/src/serialport_unix.o
                    ../src/serialport_unix.cpp: In function ‘int setup(int, OpenBaton*)’:
                    ../src/serialport_unix.cpp:176:60: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1005 [-Wformat-truncation=]
                         snprintf(data->errorString, sizeof(data->errorString), "Error %s Cannot open %s", strerror(errno), data->path);
                    ../src/serialport_unix.cpp:176:13: note: ‘snprintf’ output 20 or more bytes (assuming 1043) into a destination of size 1024
                    ../src/serialport_unix.cpp: In function ‘void EIO_Open(uv_work_t*)’:
                    ../src/serialport_unix.cpp:86:60: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1003 [-Wformat-truncation=]
                         snprintf(data->errorString, sizeof(data->errorString), "Error: %s, cannot open %s", strerror(errno), data->path);
                    ../src/serialport_unix.cpp:86:13: note: ‘snprintf’ output 22 or more bytes (assuming 1045) into a destination of size 1024
                      CXX(target) Release/obj.target/bindings/src/poller.o
                      CXX(target) Release/obj.target/bindings/src/serialport_linux.o
                      SOLINK_MODULE(target) Release/obj.target/bindings.node
                      COPY Release/bindings.node
                    make: Verzeichnis „/opt/iobroker/node_modules/@serialport/bindings/build“ wird verlassen
                    > sharp@0.28.1 install /opt/iobroker/node_modules/sharp
                    > (node install/libvips && node install/dll-copy && prebuild-install) || (node-gyp rebuild && node install/dll-copy)
                    sharp: Using cached /home/iobroker/.npm/_libvips/libvips-8.10.6-linux-armv7.tar.br
                    prebuild-install WARN install No prebuilt binaries found (target=3 runtime=napi arch=arm libc= platform=linux)
                    make: Verzeichnis „/opt/iobroker/node_modules/sharp/build“ wird betreten
                      CC(target) Release/obj.target/nothing/../node-addon-api/nothing.o
                      AR(target) Release/obj.target/../node-addon-api/nothing.a
                      COPY Release/nothing.a
                      TOUCH Release/obj.target/libvips-cpp.stamp
                      CXX(target) Release/obj.target/sharp/src/common.o
                      CXX(target) Release/obj.target/sharp/src/metadata.o
                      CXX(target) Release/obj.target/sharp/src/stats.o
                      CXX(target) Release/obj.target/sharp/src/operations.o
                      CXX(target) Release/obj.target/sharp/src/pipeline.o
                      CXX(target) Release/obj.target/sharp/src/utilities.o
                      CXX(target) Release/obj.target/sharp/src/sharp.o
                      SOLINK_MODULE(target) Release/obj.target/sharp.node
                      COPY Release/sharp.node
                    make: Verzeichnis „/opt/iobroker/node_modules/sharp/build“ wird verlassen
                    > canvas@2.8.0 install /opt/iobroker/node_modules/canvas
                    > node-pre-gyp install --fallback-to-build
                    node-pre-gyp ERR! install response status 404 Not Found on https://github.com/Automattic/node-canvas/releases/download/v2.8.0/canvas-v2.8.0-node-v83-linux-glibc-arm.tar.gz
                    node-pre-gyp WARN Pre-built binaries not installable for canvas@2.8.0 and node@14.17.5 (node-v83 ABI, glibc) (falling back to source compile with node-gyp)
                    node-pre-gyp WARN Hit error response status 404 Not Found on https://github.com/Automattic/node-canvas/releases/download/v2.8.0/canvas-v2.8.0-node-v83-linux-glibc-arm.tar.gz
                    make: Verzeichnis „/opt/iobroker/node_modules/canvas/build“ wird betreten
                      SOLINK_MODULE(target) Release/obj.target/canvas-postbuild.node
                      COPY Release/canvas-postbuild.node
                      CXX(target) Release/obj.target/canvas/src/backend/Backend.o
                      CXX(target) Release/obj.target/canvas/src/backend/ImageBackend.o
                      CXX(target) Release/obj.target/canvas/src/backend/PdfBackend.o
                      CXX(target) Release/obj.target/canvas/src/backend/SvgBackend.o
                      CXX(target) Release/obj.target/canvas/src/bmp/BMPParser.o
                    ../src/bmp/BMPParser.cc: In member function ‘void BMPParser::Parser::parse(uint8_t*, int, uint8_t*)’:
                    ../src/bmp/BMPParser.cc:186:16: warning: comparison of integer expressions of different signedness: ‘int’ and ‘unsigned int’ [-Wsign-compare]
                       E(ptr - data > imgdOffset, "image data overlaps with another structure");
                    ../src/bmp/BMPParser.cc:10:25: note: in definition of macro ‘E’
                     #define E(cond, msg) if(cond) return setErr(msg)
                    ../src/bmp/BMPParser.cc:201:27: warning: comparison of integer expressions of different signedness: ‘uint32_t’ {aka ‘unsigned int’} and ‘int’ [-Wsign-compare]
                       E(ptr - data + imgdSize > len, "not enough image data");
                      CXX(target) Release/obj.target/canvas/src/Backends.o
                      CXX(target) Release/obj.target/canvas/src/Canvas.o
                      CXX(target) Release/obj.target/canvas/src/CanvasGradient.o
                      CXX(target) Release/obj.target/canvas/src/CanvasPattern.o
                      CXX(target) Release/obj.target/canvas/src/CanvasRenderingContext2d.o
                      CXX(target) Release/obj.target/canvas/src/closure.o
                      CXX(target) Release/obj.target/canvas/src/color.o
                      CXX(target) Release/obj.target/canvas/src/Image.o
                      CXX(target) Release/obj.target/canvas/src/ImageData.o
                      CXX(target) Release/obj.target/canvas/src/init.o
                      CXX(target) Release/obj.target/canvas/src/register_font.o
                      SOLINK_MODULE(target) Release/obj.target/canvas.node
                      COPY Release/canvas.node
                    make: Verzeichnis „/opt/iobroker/node_modules/canvas/build“ wird verlassen
                    > diskusage@1.1.3 install /opt/iobroker/node_modules/diskusage
                    > node-gyp rebuild
                    make: Verzeichnis „/opt/iobroker/node_modules/diskusage/build“ wird betreten
                      CXX(target) Release/obj.target/diskusage/src/main.o
                    In file included from ../src/main.cpp:3:
                    ../src/main.cpp: At global scope:
                    ../src/main.cpp:42:1: note: in expansion of macro ‘NODE_MODULE’
                     NODE_MODULE(diskusage, Init)
                      CXX(target) Release/obj.target/diskusage/src/diskusage_posix.o
                      SOLINK_MODULE(target) Release/obj.target/diskusage.node
                      COPY Release/diskusage.node
                    make: Verzeichnis „/opt/iobroker/node_modules/diskusage/build“ wird verlassen
                    > iobroker@2.0.3 install /opt/iobroker/node_modules/iobroker
                    > node lib/checkVersions.js
                    > iobroker.vis@1.4.3 install /opt/iobroker/node_modules/iobroker.vis
                    > node main.js --install
                    > iobroker.js-controller@2.2.10 install /opt/iobroker/node_modules/iobroker.js-controller
                    > node iobroker.js setup first
                    The following notifications happened during sync:
                    - Ignoring Directory "hm-rega" because officially not created as meta object. Please remove directory!
                    > acme-v2@1.8.6 postinstall /opt/iobroker/node_modules/acme-v2
                    > node scripts/postinstall
                    Greenlock and ACME.js v3 are on the way!
                    Watch for updates at https://indiegogo.com/at/greenlock
                    > iobroker@2.0.3 postinstall /opt/iobroker/node_modules/iobroker
                    > node lib/install.js
                    │ Manual installation of ioBroker is no longer supported  │
                    │ on Linux, OSX and FreeBSD!                              │
                    │ Please refer to the documentation on how to install it! │
                    │ https://github.com/ioBroker/ioBroker/wiki/Installation  │
                    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.7 (node_modules/osx-temperature-sensor):
                    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                    npm ERR! code ELIFECYCLE
                    npm ERR! errno 100
                    npm ERR! iobroker@2.0.3 postinstall: `node lib/install.js`
                    npm ERR! Exit status 100
                    npm ERR!
                    npm ERR! Failed at the iobroker@2.0.3 postinstall script.
                    npm ERR!     /home/iobroker/.npm/_logs/2021-08-19T14_49_50_171Z-debug.log
                    • C Chris-D 0
                      > node-gyp rebuild
                      > node rebuild.js
                      > node-gyp rebuild
                      > node lib/install.js
                      npm ERR! errno 100
                      npm ERR!
                      #69
                      oops - passt das irgendwie??
                      npm ERR! errno 100 npm ERR! iobroker@2.0.3 postinstall: node lib/install.js npm ERR! Exit status 100
                      was ist denn da jetzt faul?
                      iobroker stop
                      iobroker fix
                      iobroker start
                      C 2 Antworten Letzte Antwort
                        iobroker stop
                        iobroker fix
                        iobroker start
                        Chris-D 0
                        #70
                        @homoran said in Rega Fehler:
                        euhm keine Ahnung
                          iobroker stop
                          iobroker fix
                          iobroker start
                          Chris-D 0
                          #71
                          iobroker stop
                          iobroker fix
                          mache ich
                          iobroker start
                          • C Chris-D 0
                            iobroker stop
                            iobroker fix
                            mache ich
                            iobroker start
                            Chris-D 0
                            #72
                            @Homoran
                            pi@raspberrypi:~ $ iobroker start
                            pi@raspberrypi:~ $ iobroker update -i
                            hash changed or no sources cached => force download of new sources
                            update done
                            Adapter    "admin"         : 5.1.23   , installed 5.1.23
                            Adapter    "backitup"      : 2.1.13   , installed 2.1.13
                            Adapter    "cloud"         : 4.1.0    , installed 4.1.0
                            Adapter    "discovery"     : 2.7.0    , installed 2.7.0
                            Adapter    "echarts"       : 0.4.13   , installed 0.4.13
                            Adapter    "email"         : 1.0.10   , installed 1.0.10
                            Adapter    "fb-checkpresence": 1.1.7   , installed 1.1.7
                            Adapter    "fritzdect"     : 2.1.15   , installed 2.1.15
                            Adapter    "habpanel"      : 0.4.3    , installed 0.4.3
                            Adapter    "history"       : 1.9.13   , installed 1.9.13
                            Adapter    "hm-rega"       : 3.0.29   , installed 3.0.29
                            Adapter    "hm-rpc"        : 1.14.43  , installed 1.14.43
                            Adapter    "ical"          : 1.11.2   , installed 1.11.2
                            Adapter    "info"          : 1.9.8    , installed 1.9.8
                            Adapter    "iot"           : 1.8.22   , installed 1.8.22
                            Adapter    "javascript"    : 5.2.8    , installed 5.2.8
                            Controller "js-controller" : 3.3.15   , installed 2.2.10 [Updateable]
                            Adapter    "material"      : 1.0.4    , installed 1.0.4
                            Adapter    "mobile"        : 1.0.1    , installed 1.0.1
                            Adapter    "openweathermap": 0.1.0    , installed 0.1.0
                            Adapter    "ping"          : 1.5.0    , installed 1.5.0
                            Adapter    "samsung"       : 0.2.9    , installed 0.2.9
                            Adapter    "simple-api"    : 2.6.1    , installed 2.6.1
                            Adapter    "socketio"      : 3.1.4    , installed 3.1.4
                            Adapter    "sonos"         : 2.1.1    , installed 2.1.1
                            Adapter    "synology"      : 1.0.0    , installed 1.0.0
                            Adapter    "telegram"      : 1.10.0   , installed 1.10.0
                            Adapter    "tr-064"        : 4.2.14   , installed 4.2.14
                            Adapter    "viessmann"     : 1.3.4    , installed 1.3.4
                            Adapter    "vis"           : 1.4.3    , installed 1.4.3
                            Adapter    "web"           : 3.4.7    , installed 3.4.7
                            Adapter    "whatsapp-cmb"  : 0.1.6    , installed 0.1.6
                            • C Chris-D 0
                              @Homoran
                              update done
                              #73
                              @chris-d-0
                              iobroker stop
                              iobroker update
                              Komplette Ein- und Ausgaben posten.
                                @chris-d-0
                                iobroker stop
                                iobroker update
                                Chris-D 0
                                #74
                                @thomas-braun said in Rega Fehler:
                                iobroker stop iobroker update iobroker upgrade self
                                update done
                                Adapter    "airconwithme"  : 0.0.3
                                Adapter    "airzone"       : 1.0.4
                                Adapter    "alarm"         : 2.0.2
                                Adapter    "alexa2"        : 3.9.3
                                Adapter    "alias-manager" : 1.2.3
                                Adapter    "alpha2"        : 1.0.0
                                Adapter    "amazon-dash"   : 1.1.0
                                Adapter    "artnet"        : 1.2.2
                                Adapter    "asterisk"      : 1.0.6
                                Adapter    "asuswrt"       : 1.0.1
                                Adapter    "b-control-em"  : 0.2.1
                                Adapter    "beckhoff"      : 1.4.1
                                Adapter    "benq"          : 0.2.4
                                Adapter    "binance"       : 1.1.3
                                Adapter    "ble"           : 0.12.0
                                Adapter    "bluelink"      : 1.0.7
                                Adapter    "bmw"           : 2.0.0
                                Adapter    "bosesoundtouch": 0.10.0
                                Adapter    "botvac"        : 1.0.0
                                Adapter    "bring"         : 1.7.7
                                Adapter    "broadlink2"    : 2.0.3
                                Adapter    "bsblan"        : 0.2.2
                                Adapter    "bshb"          : 0.1.13
                                Adapter    "bydbatt"       : 1.0.5
                                Adapter    "bydhvs"        : 1.2.3
                                Adapter    "chromecast"    : 2.3.1
                                Adapter    "comfoair"      : 1.1.3
                                Adapter    "contactid"     : 1.0.2
                                Adapter    "coronavirus-statistics": 0.6.3
                                Adapter    "countdown"     : 1.2.3
                                Adapter    "cul"           : 1.3.5
                                Adapter    "daikin"        : 1.3.3
                                Adapter    "daswetter"     : 3.0.7
                                Adapter    "deconz"        : 1.3.19
                                Adapter    "denon"         : 1.11.2
                                Adapter    "device-reminder": 1.2.9
                                Adapter    "devices"       : 1.0.9
                                Adapter    "digitalstrom"  : 2.2.1
                                Adapter    "discovergy"    : 0.5.4
                                Adapter    "divera247"     : 0.1.2
                                Adapter    "doorio"        : 2.0.1
                                Adapter    "ds18b20"       : 1.4.1
                                Adapter    "dwd"           : 2.7.7
                                Adapter    "dysonairpurifier": 0.9.2
                                Adapter    "easee"         : 1.0.2
                                Adapter    "ebus"          : 2.2.5
                                Adapter    "ecovacs-deebot": 1.2.1
                                Adapter    "egigeozone"    : 0.1.2
                                Adapter    "ekey"          : 1.1.0
                                Adapter    "emby"          : 1.0.2
                                Adapter    "energymanager" : 1.3.3
                                Adapter    "enet"          : 1.0.1
                                Adapter    "epson_ecotank_et_2750": 0.0.5
                                Adapter    "epson_stylus_px830": 0.2.1
                                Adapter    "epson_xp540"   : 1.0.6
                                Adapter    "exchangerates" : 0.0.14
                                Adapter    "fahrplan"      : 1.0.7
                                Adapter    "fakeroku"      : 0.2.1
                                Adapter    "feiertage"     : 1.0.17
                                Adapter    "fhem"          : 1.6.1
                                Adapter    "find-my-iphone": 0.2.15
                                Adapter    "firetv"        : 1.0.0
                                Adapter    "flot"          : 1.10.6
                                Adapter    "followthesun"  : 0.3.5
                                Adapter    "foobar2000"    : 2.0.4
                                Adapter    "fritzbox"      : 0.2.1
                                Adapter    "fronius"       : 1.0.5
                                Adapter    "frontier_silicon": 0.0.10
                                Adapter    "fuelpricemonitor": 0.2.6
                                Adapter    "fullcalendar"  : 1.1.0
                                Adapter    "fullybrowser"  : 2.0.8
                                Adapter    "g-homa"        : 0.5.3
                                Adapter    "geofency"      : 1.0.3
                                Adapter    "go-e"          : 1.0.15
                                Adapter    "growatt"       : 1.0.1
                                Adapter    "gruenbeck"     : 0.0.30
                                Adapter    "haassohn"      : 1.0.4
                                Adapter    "haier"         : 1.0.4
                                Adapter    "ham"           : 4.0.2
                                Adapter    "ham-wemo"      : 2.0.0
                                Adapter    "harmony"       : 1.2.2
                                Adapter    "heatingcontrol": 2.4.3
                                Adapter    "heos"          : 1.8.6
                                Adapter    "heytech"       : 1.0.0
                                Adapter    "hid"           : 0.1.17
                                Adapter    "hmip"          : 1.13.0
                                Adapter    "homeconnect"   : 0.0.36
                                Adapter    "homee"         : 1.2.0
                                Adapter    "homepilot"     : 1.0.3
                                Adapter    "hp-ilo"        : 1.0.6
                                Adapter    "hs100"         : 2.0.6
                                Adapter    "hue"           : 3.5.19
                                Adapter    "hue-extended"  : 2.0.0
                                Adapter    "i2c"           : 1.2.0
                                Adapter    "icons-addictive-flavour-png": 0.1.0
                                Adapter    "icons-fatcow-hosting": 0.1.0
                                Adapter    "icons-icons8"  : 0.0.1
                                Adapter    "icons-material-png": 0.1.0
                                Adapter    "icons-material-svg": 0.1.0
                                Adapter    "icons-mfd-png" : 1.0.2
                                Adapter    "icons-mfd-svg" : 1.0.2
                                Adapter    "icons-open-icon-library-png": 0.1.2
                                Adapter    "icons-ultimate-png": 1.0.1
                                Adapter    "influxdb"      : 1.9.5
                                Adapter    "innogy-smarthome": 0.3.7
                                Adapter    "iogo"          : 0.7.0
                                Adapter    "iqontrol"      : 1.8.2
                                Adapter    "jarvis"        : 2.2.1
                                Adapter    "jeelink"       : 0.1.0
                                Adapter    "kecontact"     : 1.2.3
                                Adapter    "klf200"        : 1.0.1
                                Adapter    "km200"         : 1.1.6
                                Adapter    "knmi-weather"  : 1.0.0
                                Adapter    "knx"           : 1.0.45
                                Adapter    "kodi"          : 2.0.5
                                Adapter    "kostal-piko-ba": 1.1.9
                                Adapter    "kress"         : 2.5.5
                                Adapter    "lametric"      : 1.3.2
                                Adapter    "landroid"      : 1.0.3
                                Adapter    "lcn"           : 1.0.2
                                Adapter    "legrand-ecocompteur": 1.0.0
                                Adapter    "letrika_comgw" : 0.0.5
                                Adapter    "lg-ess-home"   : 0.0.10
                                Adapter    "lgtv"          : 1.1.10
                                Adapter    "lgtv-rs"       : 0.1.1
                                Adapter    "lgtv11"        : 1.0.5
                                Adapter    "lifx"          : 0.1.0
                                Adapter    "lightify"      : 0.2.16
                                Adapter    "link"          : 0.5.10
                                Adapter    "linkeddevices" : 1.4.3
                                Adapter    "linktap"       : 0.1.8
                                Adapter    "linux-control" : 1.1.2
                                Adapter    "logparser"     : 1.1.0
                                Adapter    "lovelace"      : 2.0.4
                                Adapter    "loxone"        : 2.2.3
                                Adapter    "luftdaten"     : 1.0.3
                                Adapter    "lupusec"       : 1.3.5
                                Adapter    "luxtronik1"    : 0.3.1
                                Adapter    "maxcube"       : 1.0.4
                                Adapter    "maxcul"        : 1.3.1
                                Adapter    "mbus"          : 2.3.4
                                Adapter    "mclighting"    : 0.1.2
                                Adapter    "megad"         : 1.2.1
                                Adapter    "megadd"        : 0.2.0
                                Adapter    "megaesp"       : 0.1.0
                                Adapter    "melcloud"      : 1.1.4
                                Adapter    "mercedesme"    : 0.0.54
                                Adapter    "mercury"       : 0.1.4
                                Adapter    "meross"        : 1.6.3
                                Adapter    "meteoalarm"    : 2.0.2
                                Adapter    "midea"         : 0.0.6
                                Adapter    "miele"         : 0.1.5
                                Adapter    "mielecloudservice": 4.2.0
                                Adapter    "mihome"        : 1.3.7
                                Adapter    "mihome-lamp"   : 1.1.0
                                Adapter    "mihome-plug"   : 0.2.1
                                Adapter    "mihome-vacuum" : 3.2.2
                                Adapter    "mikrotik"      : 1.0.16
                                Adapter    "milight"       : 0.3.6
                                Adapter    "milight-smart-light": 1.2.0
                                Adapter    "minuvis"       : 1.4.0
                                Adapter    "modbus"        : 3.4.11
                                Adapter    "moma"          : 1.2.8
                                Adapter    "mpd"           : 1.0.6
                                Adapter    "mqtt"          : 2.4.0
                                Adapter    "mqtt-client"   : 1.4.0
                                Adapter    "musiccast"     : 0.1.5
                                Adapter    "mydlink"       : 1.1.12
                                Adapter    "mysensors"     : 2.0.1
                                Adapter    "nanoleaf-lightpanels": 1.2.0
                                Adapter    "net-tools"     : 0.1.5
                                Adapter    "netatmo"       : 1.4.3
                                Adapter    "netatmo-crawler": 0.5.1
                                Adapter    "nibeuplink"    : 0.4.0
                                Adapter    "nina"          : 0.0.25
                                Adapter    "node-red"      : 2.4.0
                                Adapter    "nuki"          : 1.5.0
                                Adapter    "nuki-extended" : 2.3.1
                                Adapter    "nut"           : 1.5.0
                                Adapter    "octoprint"     : 1.1.1
                                Adapter    "odl"           : 1.1.4
                                Adapter    "oilfox"        : 0.0.5
                                Adapter    "omnicomm-lls"  : 0.0.7
                                Adapter    "onkyo"         : 2.1.0
                                Adapter    "onvif"         : 0.4.4
                                Adapter    "openhab"       : 1.1.0
                                Adapter    "openligadb"    : 1.1.0
                                Adapter    "opi"           : 0.1.1
                                Adapter    "oppoplayer"    : 0.2.4
                                Adapter    "owfs"          : 0.6.4
                                Adapter    "owntracks"     : 1.0.0
                                Adapter    "panasonic-viera": 1.0.2
                                Adapter    "parser"        : 1.0.7
                                Adapter    "paw"           : 0.0.7
                                Adapter    "pegelalarm"    : 1.2.0
                                Adapter    "ph803w"        : 1.0.1
                                Adapter    "phantomjs"     : 1.1.2
                                Adapter    "pi-hole"       : 1.3.2
                                Adapter    "piface"        : 1.0.0
                                Adapter    "pimatic"       : 0.3.0
                                Adapter    "places"        : 1.0.0
                                Adapter    "plenticore"    : 2.2.0
                                Adapter    "plex"          : 0.8.11
                                Adapter    "plexconnect"   : 0.0.7
                                Adapter    "pollenflug"    : 1.0.6
                                Adapter    "proxmox"       : 1.3.3
                                Adapter    "proxy"         : 1.2.2
                                Adapter    "pushbullet"    : 0.0.11
                                Adapter    "pushover"      : 2.0.5
                                Adapter    "pushsafer"     : 1.0.3
                                Adapter    "radar2"        : 1.0.9
                                Adapter    "radiohead"     : 1.1.1
                                Adapter    "rflink"        : 2.1.6
                                Adapter    "rickshaw"      : 1.0.0
                                Adapter    "ring"          : 1.2.3
                                Adapter    "robonect"      : 0.1.3
                                Adapter    "roomba"        : 1.1.1
                                Adapter    "rpi2"          : 1.3.1
                                Adapter    "s7"            : 1.3.6
                                Adapter    "sainlogic"     : 0.7.2
                                Adapter    "sanext"        : 0.0.5
                                Adapter    "sayit"         : 1.12.3
                                Adapter    "sbfspot"       : 4.0.5
                                Adapter    "scenes"        : 2.3.6
                                Adapter    "schoolfree"    : 1.0.0
                                Adapter    "schwoerer-ventcube": 1.4.2
                                Adapter    "seq"           : 0.2.10
                                Adapter    "shelly"        : 4.0.7
                                Adapter    "shuttercontrol": 1.2.0
                                Adapter    "sia"           : 1.0.4
                                Adapter    "siegenia"      : 1.1.1
                                Adapter    "smappee"       : 0.2.5
                                Adapter    "smartcontrol"  : 1.2.1
                                Adapter    "smartgarden"   : 1.0.5
                                Adapter    "smartmeter"    : 3.2.1
                                Adapter    "snips"         : 1.5.1
                                Adapter    "snmp"          : 0.5.0
                                Adapter    "solarlog"      : 2.1.3
                                Adapter    "solarviewdatareader": 1.0.2
                                Adapter    "solarwetter"   : 1.0.0
                                Adapter    "sonnen"        : 1.9.4
                                Adapter    "sonoff"        : 2.4.5
                                Adapter    "sony-bravia"   : 1.0.1
                                Adapter    "spotify-premium": 1.0.0
                                Adapter    "sprinklecontrol": 0.1.7
                                Adapter    "sql"           : 1.15.7
                                Adapter    "squeezebox"    : 1.0.0
                                Adapter    "squeezeboxrpc" : 1.3.4
                                Adapter    "starline"      : 1.1.3
                                Adapter    "statistics"    : 1.0.9
                                Adapter    "stiebel-isg"   : 1.7.3
                                Adapter    "sunnyportal"   : 0.1.5
                                Adapter    "swiss-weather-api": 0.9.7
                                Adapter    "systeminfo"    : 0.3.1
                                Adapter    "tado"          : 0.3.4
                                Adapter    "tahoma"        : 0.4.3
                                Adapter    "tankerkoenig"  : 2.1.1
                                Adapter    "terminal"      : 0.1.2
                                Adapter    "tesla-motors"  : 0.5.2
                                Adapter    "text2command"  : 2.1.1
                                Adapter    "tinker"        : 1.1.0
                                Adapter    "traccar"       : 0.0.9
                                Adapter    "tradfri"       : 2.7.4
                                Adapter    "trashschedule" : 1.2.0
                                Adapter    "trivum"        : 0.0.4
                                Adapter    "tunnelbroker-endpoint-updater": 0.0.1
                                Adapter    "tuya"          : 3.6.5
                                Adapter    "tvprogram"     : 1.1.0
                                Adapter    "tvspielfilm"   : 1.0.4
                                Adapter    "unifi"         : 0.5.10
                                Adapter    "upnp"          : 1.0.19
                                Adapter    "vaillant"      : 0.0.13
                                Adapter    "valloxmv"      : 1.1.3
                                Adapter    "vcard"         : 0.0.9
                                Adapter    "velux"         : 0.0.7
                                Adapter    "virtualpowermeter": 1.4.2
                                Adapter    "vis-bars"      : 0.1.4
                                Adapter    "vis-canvas-gauges": 0.1.5
                                Adapter    "vis-colorpicker": 1.2.0
                                Adapter    "vis-fancyswitch": 1.1.0
                                Adapter    "vis-google-fonts": 0.1.0
                                Adapter    "vis-history"   : 1.0.0
                                Adapter    "vis-hqwidgets" : 1.1.7
                                Adapter    "vis-icontwo"   : 0.77.0
                                Adapter    "vis-inventwo"  : 3.0.11
                                Adapter    "vis-jqui-mfd"  : 1.0.12
                                Adapter    "vis-justgage"  : 1.0.2
                                Adapter    "vis-keyboard"  : 0.0.2
                                Adapter    "vis-lcars"     : 1.0.4
                                Adapter    "vis-map"       : 1.0.4
                                Adapter    "vis-material-advanced": 1.7.0
                                Adapter    "vis-metro"     : 1.1.2
                                Adapter    "vis-players"   : 0.1.6
                                Adapter    "vis-plumb"     : 1.0.2
                                Adapter    "vis-rgraph"    : 0.0.2
                                Adapter    "vis-timeandweather": 1.1.7
                                Adapter    "vis-weather"   : 2.5.3
                                Adapter    "volumio"       : 0.1.2
                                Adapter    "volvo"         : 0.0.4
                                Adapter    "vr200"         : 1.0.0
                                Adapter    "vw-connect"    : 0.0.39
                                Adapter    "weatherflow_udp": 0.1.1
                                Adapter    "weatherunderground": 3.3.1
                                Adapter    "weishaupt-wem" : 0.0.9
                                Adapter    "wiffi-wz"      : 2.2.0
                                Adapter    "wifilight"     : 1.1.0
                                Adapter    "windows-control": 0.1.5
                                Adapter    "wled"          : 0.5.6
                                Adapter    "wm-bus"        : 0.1.12
                                Adapter    "wolf"          : 1.2.1
                                Adapter    "wolf-smartset" : 1.0.0
                                Adapter    "worx"          : 1.4.3
                                Adapter    "xbox"          : 0.7.7
                                Adapter    "xs1"           : 1.0.2
                                Adapter    "yahka"         : 0.12.0
                                Adapter    "yamaha"        : 0.4.0
                                Adapter    "yeelight-2"    : 1.0.3
                                Adapter    "youtube"       : 1.1.1
                                Adapter    "yr"            : 3.0.5
                                Adapter    "zigbee"        : 1.5.6
                                Adapter    "zont"          : 0.5.3
                                Adapter    "zwave2"        : 1.10.2
                                Update js-controller from @2.2.10 to @3.3.15
                                npm install iobroker.js-controller@3.3.15 --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call)
                                ACHTUNG: Die Fehlerberichterstattung über Sentry wird beim nächsten Start von ioBroker aktiviert
                                Wir von ioBroker wollen das stabilste Smart-Home-System bereitstellen.
                                Um dies zu ermöglichen, haben wir uns entschlossen, eine automatische Fehler- und Crash-Reporting-Lösung in den js-Controller und auch in Adapter zu implementieren.
                                DIESE BERICHTERSTATTUNG WIRD MIT DEM NÄCHSTEN START IHRES IOBROKERS AKTIVIERT!
                                Bei Fehlern, die zum Absturz des js-Controllers oder eines der relevanten Adapter führen, werden die Fehlerdetails an einen Server gesendet. Für den js-controller und die Haupt-Adapter befindet sich dieser Server in Deutschland. Informationen zu Community-Adaptern sind in der Github-Readme-Datei des betroffenen Adapters zu finden. Dort steht welcher Sentry-Server verwendet wird.
                                Die Fehlerberichterstattung kann, falls gewünscht, über den Befehl
                                'iobroker plugin disable sentry'
                                deaktiviert werden. Dieser Befehl stellt auch sicher, dass kein Adapter, der auf diesem Host ausgeführt wird, Absturzberichtsdaten an den Sentry-Server sendet.
                                npm ERR! errno 100
                                npm ERR!
                                npm ERR!     /home/iobroker/.npm/_logs/2021-08-19T15_22_55_970Z-debug.log
                                host.raspberrypi Cannot install iobroker.js-controller@3.3.15: 100
                                • C Chris-D 0
                                  update done
                                  npm ERR! errno 100
                                  npm ERR!
                                  #75
                                  @chris-d-0
                                  cd /opt/iobroker
                                  iobroker stop
                                    @chris-d-0
                                    cd /opt/iobroker
                                    iobroker stop
                                    Chris-D 0
                                    #76
                                    cd /opt/iobroker iobroker stop sudo -H -u iobroker npm install iobroker.js-controller
                                    pi@raspberrypi:/opt/iobroker $ iobroker stop
                                    > node lib/install.js
                                    npm ERR! errno 100
                                    npm ERR!
                                    npm ERR!     /home/iobroker/.npm/_logs/2021-08-19T15_29_16_679Z-debug.log
                                    • C Chris-D 0
                                      > node lib/install.js
                                      npm ERR! errno 100
                                      npm ERR!
                                      #77
                                      @chris-d-0 hattest du mal npm 7 drauf? Da ist ein Mischmasch bei dir.
                                      Thomas BraunT C 2 Antworten Letzte Antwort
                                      • apollon77A apollon77
                                        #78
                                        @apollon77
                                        Offenbar.
                                        ist jedenfalls ein starker Indikator für npm7.
                                          @apollon77
                                          Offenbar.
                                          #79
                                          @thomas-braun package-lock.json löschen
