  4. ZigBee neue Version 1.6.x
    2.7k
    4.7k
    4.0k
509 Beiträge 61 Kommentatoren 145.1k Aufrufe 62 Beobachtet
  • T tombox
    @docgame
    Habe das gleiche Verhalten
    CC2652P mit 20220219
    Normale Geräte
    model:WXKG11LM
    description:Aqara wireless switch
    model:SNZB-01
    description:Wireless button
    Werden gepairt und funktionieren, werden aber als undefined angezeigt.
    2022-03-13 22:17:20.416 - debug: zigbee.0 (4553) New device event: {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":2,"_type":"Router","_ieeeAddr":"0x84fd27fffe928394","_networkAddress":9397,"_manufacturerID":4098,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":256,"inputClusters":[0,3,4,5,6,4096],"outputClusters":[4096],"deviceNetworkAddress":9397,"deviceIeeeAddress":"0x84fd27fffe928394","clusters":{"genOnOff":{"attributes":{"onOff":0}},"genBasic":{"attributes":{"modelId":"01MINIZB","manufacturerName":"SONOFF","powerSource":0,"zclVersion":3,"dateCode":"20200927"}}},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":242,"profileID":41440,"deviceID":97,"inputClusters":[],"outputClusters":[33],"deviceNetworkAddress":9397,"deviceIeeeAddress":"0x84fd27fffe928394","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"SONOFF","_powerSource":"Mains (single phase)","_modelID":"01MINIZB","_zclVersion":3,"_dateCode":"20200927","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{"configured":1},"_lastSeen":1647206175034,"_defaultSendRequestWhen":"immediate"},"mapped":{"exposes":[{"type":"switch","features":[{"type":"binary","name":"state","property":"state","access":7,"value_on":"ON","value_off":"OFF","description":"On/off state of the switch","value_toggle":"TOGGLE"}]},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)","value_min":0,"value_max":255}],"fromZigbee":[{"cluster":"genOnOff","type":["attributeReport","readResponse"]},{"cluster":"genBasic","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state","on_time","off_wait_time"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["read"]},{"key":["write"]},{"key":["command"]}],"zigbeeModel":["01MINIZB"],"model":"ZBMINI","vendor":"SONOFF","description":"Zigbee two way smart switch","options":[]},"name":"0x84fd27fffe928394"}
    2022-03-13 22:17:20.416 - info: zigbee.0 (4553) 0x84fd27fffe928394 (addr 9397): ZBMINI - SONOFF Zigbee two way smart switch (Router)
    2022-03-13 22:17:20.417 - debug: zigbee.0 (4553) New device event: {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":3,"_type":"EndDevice","_ieeeAddr":"0x00158d0006726d5a","_networkAddress":41373,"_manufacturerID":4151,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":259,"inputClusters":[0,18,3],"outputClusters":[0],"deviceNetworkAddress":41373,"deviceIeeeAddress":"0x00158d0006726d5a","clusters":{"genBasic":{"attributes":{"65281":{"1":3055,"3":34,"4":424,"5":25,"6":[0,1],"10":0},"modelId":"lumi.remote.b1acn01","appVersion":2,"manufacturerName":"LUMI","powerSource":3,"zclVersion":1,"stackVersion":2,"hwVersion":2,"dateCode":"20180525","swBuildId":"3000-0001"}}},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.remote.b1acn01","_applicationVersion":2,"_stackVersion":2,"_zclVersion":1,"_hardwareVersion":2,"_dateCode":"20180525","_softwareBuildID":"3000-0001","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{},"_lastSeen":1647206019640,"_defaultSendRequestWhen":"immediate"},"mapped":{"zigbeeModel":["lumi.sensor_switch.aq2","lumi.remote.b1acn01"],"model":"WXKG11LM","vendor":"Xiaomi","description":"Aqara wireless switch","meta":{"battery":{"voltageToPercentage":"3V_2850_3000_log"}},"exposes":[{"type":"numeric","name":"battery","property":"battery","access":1,"unit":"%","description":"Remaining battery in %","value_min":0,"value_max":100},{"type":"numeric","name":"voltage","property":"voltage","access":1,"unit":"mV","description":"Voltage of the battery in millivolts"},{"type":"enum","name":"action","property":"action","access":1,"values":["single","double","triple","quadruple","hold","release"],"description":"Triggered action (e.g. a button click)"},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)","value_min":0,"value_max":255}],"fromZigbee":[{"cluster":"genMultistateInput","type":["attributeReport"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]},{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"],"options":[{"type":"binary","name":"legacy","property":"legacy","access":2,"value_on":true,"value_off":false,"description":"Set to false to disable the legacy integration (highly recommended), will change structure of the published payload (default true)."}]},{"cluster":"genMultistateInput","type":["attributeReport","readResponse"],"options":[{"type":"binary","name":"legacy","property":"legacy","access":2,"value_on":true,"value_off":false,"description":"Set to false to disable the legacy integration (highly recommended), will change structure of the published payload (default true)."}]}],"toZigbee":[{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["read"]},{"key":["write"]},{"key":["command"]}],"options":["[Circular]"]},"name":"0x00158d0006726d5a"}
    2022-03-13 22:17:20.417 - info: zigbee.0 (4553) 0x00158d0006726d5a (addr 41373): WXKG11LM - Xiaomi Aqara wireless switch (EndDevice)
    2022-03-13 22:17:20.418 - debug: zigbee.0 (4553) New device event: {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":4,"_type":"EndDevice","_ieeeAddr":"0x00124b00251d8bbc","_networkAddress":19490,"_manufacturerID":0,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":0,"inputClusters":[0,3,1],"outputClusters":[6,3],"deviceNetworkAddress":19490,"deviceIeeeAddress":"0x00124b00251d8bbc","clusters":{"genBasic":{"attributes":{"modelId":"WB01","manufacturerName":"eWeLink","powerSource":3,"zclVersion":0,"appVersion":5,"hwVersion":0,"dateCode":"20211103"}},"genPowerCfg":{"attributes":{"batteryVoltage":33,"batteryPercentageRemaining":200}}},"_binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c1299f","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0x00124b0024c1299f","endpointID":1}],"_configuredReportings":[{"cluster":1,"attrId":32,"minRepIntval":3600,"maxRepIntval":62000,"repChange":0},{"cluster":1,"attrId":33,"minRepIntval":3600,"maxRepIntval":62000,"repChange":0}],"meta":{},"pendingRequests":[]}],"_manufacturerName":"eWeLink","_powerSource":"Battery","_modelID":"WB01","_applicationVersion":5,"_zclVersion":0,"_hardwareVersion":0,"_dateCode":"20211103","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{"configured":1796851078},"_lastSeen":1647206160444,"_defaultSendRequestWhen":"immediate"},"mapped":{"zigbeeModel":["WB01","WB-01"],"model":"SNZB-01","vendor":"SONOFF","whiteLabel":[{"vendor":"eWeLink","model":"RHK07"}],"description":"Wireless button","exposes":[{"type":"numeric","name":"battery","property":"battery","access":1,"unit":"%","description":"Remaining battery in %","value_min":0,"value_max":100},{"type":"enum","name":"action","property":"action","access":1,"values":["single","double","long"],"description":"Triggered action (e.g. a button click)"},{"type":"numeric","name":"voltage","property":"voltage","access":1,"unit":"mV","description":"Voltage of the battery in millivolts"},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)","value_min":0,"value_max":255}],"fromZigbee":[{"cluster":"genOnOff","type":["commandOn","commandOff","commandToggle"]},{"cluster":"genPowerCfg","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["read"]},{"key":["write"]},{"key":["command"]}],"options":[]},"name":"0x00124b00251d8bbc"}
    2022-03-13 22:17:20.418 - info: zigbee.0 (4553) 0x00124b00251d8bbc (addr 19490): SNZB-01 - SONOFF Wireless button (EndDevice)
    2022-03-13 22:17:20.418 - info: zigbee.0 (4553) Zigbee started
    2022-03-13 22:17:20.424 - debug: zigbee.0 (4553) getGroups result: {}
    2022-03-13 22:17:20.425 - debug: zigbee.0 (4553) DeviceAvailability:register device Ping for "0x84fd27fffe928394"
    2022-03-13 22:17:20.427 - debug: zigbee.0 (4553) DeviceAvailability:register device Ping for "0x00158d0006726d5a"
    2022-03-13 22:17:20.427 - debug: zigbee.0 (4553) DeviceAvailability:register device Ping for "0x00124b00251d8bbc"
    2022-03-13 22:17:20.730 - debug: zigbee.0 (4553) handleMessage. {"type":"readResponse","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":2,"_type":"Router","_ieeeAddr":"0x84fd27fffe928394","_networkAddress":9397,"_manufacturerID":4098,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":256,"inputClusters":[0,3,4,5,6,4096],"outputClusters":[4096],"deviceNetworkAddress":9397,"deviceIeeeAddress":"0x84fd27fffe928394","clusters":{"genOnOff":{"attributes":{"onOff":0}},"genBasic":{"attributes":{"modelId":"01MINIZB","manufacturerName":"SONOFF","powerSource":0,"zclVersion":3,"dateCode":"20200927"}}},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":242,"profileID":41440,"deviceID":97,"inputClusters":[],"outputClusters":[33],"deviceNetworkAddress":9397,"deviceIeeeAddress":"0x84fd27fffe928394","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"SONOFF","_powerSource":"Mains (single phase)","_modelID":"01MINIZB","_zclVersion":3,"_dateCode":"20200927","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{"configured":1},"_lastSeen":1647206240730,"_defaultSendRequestWhen":"immediate","_linkquality":51},"endpoint":"[Circular]","data":{"onOff":0},"linkquality":51,"groupID":0,"cluster":"genOnOff","meta":{"zclTransactionSequenceNumber":2,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}}}
    2022-03-13 22:17:20.731 - debug: zigbee.0 (4553) Received Zigbee message from '0x84fd27fffe928394', type 'readResponse', cluster 'genOnOff', data '{"onOff":0}' from endpoint 1 with groupID 0
    2022-03-13 22:17:20.732 - debug: zigbee.0 (4553) Type readResponse device {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":2,"_type":"Router","_ieeeAddr":"0x84fd27fffe928394","_networkAddress":9397,"_manufacturerID":4098,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":256,"inputClusters":[0,3,4,5,6,4096],"outputClusters":[4096],"deviceNetworkAddress":9397,"deviceIeeeAddress":"0x84fd27fffe928394","clusters":{"genOnOff":{"attributes":{"onOff":0}},"genBasic":{"attributes":{"modelId":"01MINIZB","manufacturerName":"SONOFF","powerSource":0,"zclVersion":3,"dateCode":"20200927"}}},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":242,"profileID":41440,"deviceID":97,"inputClusters":[],"outputClusters":[33],"deviceNetworkAddress":9397,"deviceIeeeAddress":"0x84fd27fffe928394","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"SONOFF","_powerSource":"Mains (single phase)","_modelID":"01MINIZB","_zclVersion":3,"_dateCode":"20200927","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{"configured":1},"_lastSeen":1647206240730,"_defaultSendRequestWhen":"immediate","_linkquality":51},"mapped":{"exposes":[{"type":"switch","features":[{"type":"binary","name":"state","property":"state","access":7,"value_on":"ON","value_off":"OFF","description":"On/off state of the switch","value_toggle":"TOGGLE"}]},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)","value_min":0,"value_max":255}],"fromZigbee":[{"cluster":"genOnOff","type":["attributeReport","readResponse"]},{"cluster":"genBasic","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state","on_time","off_wait_time"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["read"]},{"key":["write"]},{"key":["command"]}],"zigbeeModel":["01MINIZB"],"model":"ZBMINI","vendor":"SONOFF","description":"Zigbee two way smart switch","options":[]},"name":"0x84fd27fffe928394"} incoming event: {"type":"readResponse","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":2,"_type":"Router","_ieeeAddr":"0x84fd27fffe928394","_networkAddress":9397,"_manufacturerID":4098,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":256,"inputClusters":[0,3,4,5,6,4096],"outputClusters":[4096],"deviceNetworkAddress":9397,"deviceIeeeAddress":"0x84fd27fffe928394","clusters":{"genOnOff":{"attributes":{"onOff":0}},"genBasic":{"attributes":{"modelId":"01MINIZB","manufacturerName":"SONOFF","powerSource":0,"zclVersion":3,"dateCode":"20200927"}}},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":242,"profileID":41440,"deviceID":97,"inputClusters":[],"outputClusters":[33],"deviceNetworkAddress":9397,"deviceIeeeAddress":"0x84fd27fffe928394","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"SONOFF","_powerSource":"Mains (single phase)","_modelID":"01MINIZB","_zclVersion":3,"_dateCode":"20200927","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{"configured":1},"_lastSeen":1647206240730,"_defaultSendRequestWhen":"immediate","_linkquality":51},"endpoint":"[Circular]","data":{"onOff":0},"linkquality":51,"groupID":0,"cluster":"genOnOff","meta":{"zclTransactionSequenceNumber":2,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}}}
    AsgothianA Offline
    AsgothianA Offline
    Asgothian
    #381
    @tombox Bitte den cache leeren und die Seite neu laden.
    A.
    T D 2 Antworten Letzte Antwort
    • AsgothianA Asgothian
      A.
      tombox
      #382
      @asgothian Auch nach Cache leeren und anderer Browser
        A.
        DocGame
        #383
        @asgothian Hier das selbe wie bei @tombox . Egal ob Firefox, Edge, Chrome oder I-Explorer.
        • D DocGame
          arteckA Offline
          arteckA Offline
          arteck
          #384
          ich kannst nachstellen.. die definition der Geräe nach neuanlernen ist hops..
          hmm...
          ich habs... installiert mal vom GIT..
          • arteckA arteck
            hmm...
            DocGame
            #385
            @arteck Leider immer noch das selbe.
            Nach dem anlernen ist keine Kachel da.
            Nach einem Adapterneustart ist die Kachel mit "undefined" da.
            Der einzige unterschied der GIT-Version....ich habe jetzt in den Objekten 2 Verzeichnisse des Geräts. Das neue kann ich nicht öffnen (die Datenpunkte des alten kann ich nach wie vor schalten).
            • D DocGame
              arteckA Offline
              arteckA Offline
              arteck
              #386
              @docgame
              ok also
              adapter stop
              jetzt adapter neu von GIT holen
              die 2 objekte die falsch angelegt sind löschen
              adapter neu starten
              • arteckA arteck
                @docgame
                ok also
                adapter stop
                adapter neu starten
                tombox
                #387
                @arteck
                Hat funktioniert
                zigbee.0 gelöscht und dann neugestartet jetzt werden alle Geräte angezeigt
                • arteckA arteck
                  @docgame
                  ok also
                  adapter stop
                  adapter neu starten
                  DocGame
                  #388
                  @arteck Super....
                  Nachdem ich so vorgegangen bin hat es geklappt. Kachel ist ohne neuanlernen da und sieht gut aus.
                  Danke!!
                  • I Offline
                    I Offline
                    Io-Alex
                    #389
                    Guten Abend,
                    ich habe der Zeit ein Problem mit dem Aquara E1 Rollomotor. Das Gerät lässt sich zwar anlernen überträgt aber keine Werte, so dass alle Datenpunkte auf (NULL) verbleiben.
                    Wie könnte ich dieses Problem lösen?
                    Information zum System:
                    Iobroker Version 3.3.22
                    Node.js v12.22.9
                    NPM 6.14.15
                    Zigbee Adapter v1.6.16
                    Verwendeter Stick: conbee 2
                    • I Io-Alex
                      Guten Abend,
                      Node.js v12.22.9
                      NPM 6.14.15
                      #390
                      @io-alex sagte in ZigBee neue Version 1.6.x:
                      Node.js v12.22.9
                      NPM 6.14.15
                      Losgelöst vom konkreten Problem:
                      Halt das System auf Stand.
                      I 1 Antwort Letzte Antwort
                        Node.js v12.22.9
                        NPM 6.14.15
                        I Offline
                        I Offline
                        Io-Alex
                        #391
                        @thomas-braun Wird gerade erledigt 👍
                        • ? Offline
                          #392
                          Wie bekomme ich Min und Max Werte für Hue/Color/ColorTemp/Saturation bei den Lampen raus? Wenn man außerhalb des Bereichs ist stürzt die Zigbee Instanz sofort ab.
                            AsgothianA Offline
                            AsgothianA Offline
                            Asgothian
                            #393
                            @typ1er sagte in ZigBee neue Version 1.6.x:
                            bitte poste die Meldung die kommt wenn die Werte ausserhalb des Bereiches sind. Eigentlich sollte der Adapter das abfangen.
                            A.
                            • ? Offline
                              #394
                              Ich kann es nicht mehr nachvollziehen , habe das Log gelöscht, ich habe 2 Lampen über Node-Red in HomeKit eingebunden, beim Testen ist die Zigbee Instanz mehrfach abgestürzt. Ich hatte die Min/Max angaben in Verdacht, das ich hier außerhalb der Bereiche wahr. daher auch die Frage wie ich min/max ermitteln kann.
                                AsgothianA Offline
                                AsgothianA Offline
                                Asgothian
                                #395
                                @typ1er Ganz einfach.. du musst die Dokumentation der Lampen lesen.
                                A.
                                • ? Offline
                                  #396
                                  @Asgothian gibst du mir noch einen Hinweis wo, habe vorher Deconz benutzt und hier sind andere Bereiche gültig gewesen.
                                  Ich habe jetzt eine Philips LCT010 hier, die zum probieren angemeldet habe.
                                  Die ColorTemp ist im Zigbee Adapter 200-9000
                                  in Deconz hatte ich 150-500
                                    AsgothianA Offline
                                    AsgothianA Offline
                                    Asgothian
                                    #397
                                    @typ1er
                                    wenn die Lampe es kann sind werte zwischen 150 und 500 sowie zwischen 2000 and 6500 gültig.. die niedrigen in mired, die hohen in Kelvin.
                                    A.
                                    ? 1 Antwort Letzte Antwort
                                      @typ1er
                                      A.
                                      #398
                                      Ich habe 3 kleine Probleme,
                                      -scheinbar werden keine neuen Aqara Sensoren an Hue Leuchten eingebunden, auch klappt das direkt Koppeln an den Lampen nicht.
                                      -am iPad sind die Symbole in der Übersicht abgeschnitten( Schriftgröße ändern bringt leider nichts)
                                      -ich habe hier eine Zigbee Pendelleuchte von LIDL (TS0502A), als Logo kommt ein Schalter.
                                      https://www.lidl.de/p/livarno-lux-pendelleuchte-mit-lichtfarbensteuerung-zigbee-smart-home/p100315338001
                                      Hier ein Bild der 2 letzten Punkte
                                        arteckA Offline
                                        arteckA Offline
                                        arteck
                                        #399
                                        • das koppeln direkt an den Hue's das hat doch nie funktioniert..
                                        • im ernst.. am ipad.. du nutzt exzessiv den admin am ipad..
                                        • wilkommen in der Tuya Welt.. da werden Schalter auch zur Lampen und umgekehrt
                                        • arteckA arteck
                                          #400
                                          @arteck, da ich fast nur Hue Lampen habe, und vorher Deconz genutzt habe, dachte ich das Klappt trotzdem irgendwie.
                                          Mit dem iPad kann ich zumindest an die Sensoren gehen und dann zurücksetzen oder koppeln.
                                          Ich habe zwar noch ein paar Sensoren von Tuya, hier werden die richtigen Logos angezeigt, daher dachte ich es ist nur falsch verknüpft.
