  4. Anfänger sucht Hilfe bei Install. proxmox auf INTELNUC8i3BEK
    2.4k
    4.3k
1.0k Beiträge 16 Kommentatoren 291.0k Aufrufe 15 Beobachtet
  • G GOETSCHHOFER
    @crunchip @Homoran
    Ich habe offenbar ein Problem bei meinem influxdb Service.
    Könntet ihr mir hier bitte weiterhelfen ?
    Wenn ich versuche den Influxdb Service zu starten bekomme ich folgende Fehlermeldung:
    login as: karl
    karl@192.168.1.177's password:
    Linux LXC-INFLUXDB-192 5.4.124-1-pve #1 SMP PVE 5.4.124-1 (Wed, 23 Jun 2021 13:4        7:09 +0200) x86_64
    The programs included with the Debian GNU/Linux system are free software;
    the exact distribution terms for each program are described in the
    individual files in /usr/share/doc/*/copyright.
    Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
    permitted by applicable law.
    Last login: Sat Aug 21 12:42:56 2021 from 192.168.1.3
    karl@LXC-INFLUXDB-192:~$ sudo service influxdb start
    [sudo] password for karl:
    Job for influxdb.service failed because the control process exited with error co        de.
    See "systemctl status influxdb.service" and "journalctl -xe" for details.
    Aug 21 12:36:20 LXC-INFLUXDB-192 systemd[1]: Stopped InfluxDB is an open-source,
    Aug 21 12:36:20 LXC-INFLUXDB-192 systemd[1]: influxdb.service: Start request rep
    Aug 21 12:36:20 LXC-INFLUXDB-192 systemd[1]: influxdb.service: Failed with resul
    Aug 21 12:36:20 LXC-INFLUXDB-192 systemd[1]: Failed to start InfluxDB is an open
    lines 1-12/12 (END)...skipping...
    * influxdb.service - InfluxDB is an open-source, distributed, time series database
       Loaded: loaded (/lib/systemd/system/influxdb.service; enabled; vendor preset: enabled)
       Active: failed (Result: exit-code) since Sat 2021-08-21 12:36:20 CEST; 10min ago
         Docs: https://docs.influxdata.com/influxdb/
      Process: 277 ExecStart=/usr/lib/influxdb/scripts/influxd-systemd-start.sh (code=exited, status=203/EXEC)
    Aug 21 12:36:20 LXC-INFLUXDB-192 systemd[1]: influxdb.service: Service RestartSec=100ms expired, scheduling restart.
    Aug 21 12:36:20 LXC-INFLUXDB-192 systemd[1]: influxdb.service: Scheduled restart job, restart counter is at 5.
    Aug 21 12:36:20 LXC-INFLUXDB-192 systemd[1]: Stopped InfluxDB is an open-source, distributed, time series database.
    Aug 21 12:36:20 LXC-INFLUXDB-192 systemd[1]: influxdb.service: Start request repeated too quickly.
    Aug 21 12:36:20 LXC-INFLUXDB-192 systemd[1]: influxdb.service: Failed with result 'exit-code'.
    Aug 21 12:36:20 LXC-INFLUXDB-192 systemd[1]: Failed to start InfluxDB is an open-source, distributed, time series database.
    crunchipC Offline
    crunchipC Offline
    #961
    @goetschhofer sagte in Anfänger sucht Hilfe bei Install. proxmox auf INTELNUC8i3BEK:
    hast du wahscheinlich auch ein Update auf die neue version gemacht, somit liegt das startscript an einem anderen Ort, bzw fehlen die nötigen Rechte, des weiteren gibt es da eine Zeitabfrage beim Start von Influx, guck mal hier
      @goetschhofer deine VM läuft zwar, aber nicht der iobroker ansich, geb iobroker start ein, dann sollte er wieder anlaufen
      GOETSCHHOFER
      schrieb am zuletzt editiert von GOETSCHHOFER
      #962
      @crunchip said in Anfänger sucht Hilfe bei Install. proxmox auf INTELNUC8i3BEK:
      Iobroker start habe ich gemacht.
      Der iobroker läuft meines Erachtens aktuell schon, aber die Verbindung zur InfluxDB wirft einen Fehler aus.
      Drehe mich gerade im Kreis.
      login as: karl
      Last login: Sat Aug 21 15:05:33 2021 from 192.168.1.3
      karl@LXC-INFLUXDB-192:~$ apt policy influxdb
      influxdb:
        Installed: 1.8.9-1
        Candidate: 1.8.9-1
        Version table:
       *** 1.8.9-1 500
              500 https://repos.influxdata.com/debian buster/stable amd64 Packages
              100 /var/lib/dpkg/status
           1.6.4-1+deb10u1 500
              500 http://ftp.debian.org/debian buster/main amd64 Packages
              500 http://security.debian.org buster/updates/main amd64 Packages
      login as: karl
      karl@192.168.1.176's password:
      Linux IOBROKER 4.19.0-17-amd64 #1 SMP Debian 4.19.194-3 (2021-07-18) x86_64
      Last login: Sat Aug 21 15:07:13 2021 from 192.168.1.3
      karl@IOBROKER:~$ login as: karl
      influxdb:
        Installed: 1.8.9-1
        Candidate: 1.8.9-1
        Version table:
       *** 1.8.9-1 500
           1.6.4-1+deb10u1 500
      login: Arbeit ohne effektive root-Rechte eventuell nicht möglich
      karl@IOBROKER:~$ karl@192.168.1.177's password:
      > Linux LXC-INFLUXDB-192 5.4.124-1-pve #1 SMP PVE 5.4.124-1 (Wed, 23 Jun 2021 13        :4        7        :09 +0200) x86_64
      > influxdb:
      >   Installed: 1.8.9-1
      >   Candidate: 1.8.9-1
      >   Version table:
      >  *** 1.8.9-1 500
      >      1.6.4-1+deb10u1 500
      karl@LXC-INFLUXDB-192:~$ ls -la /usr/lib/influxdb/scripts
      total 24
      drwxr-xr-x 2 root root 4096 Aug 21 14:12 .
      drwxr-xr-x 3 root root 4096 May  8 19:25 ..
      -rwxr-xr-x 1 root root 1116 Aug  5 00:31 influxd-systemd-start.sh
      -rw-r--r-- 1 root root  533 Aug  5 00:31 influxdb.service
      -rw-r--r-- 1 root root 5702 Aug  5 00:31 init.sh
      G crunchipC 2 Antworten Letzte Antwort
      • G GOETSCHHOFER
        login as: karl
        influxdb:
          Installed: 1.8.9-1
          Candidate: 1.8.9-1
          Version table:
         *** 1.8.9-1 500
             1.6.4-1+deb10u1 500
        login as: karl
        influxdb:
          Installed: 1.8.9-1
          Candidate: 1.8.9-1
          Version table:
         *** 1.8.9-1 500
             1.6.4-1+deb10u1 500
        > influxdb:
        >   Installed: 1.8.9-1
        >   Candidate: 1.8.9-1
        >   Version table:
        >  *** 1.8.9-1 500
        >      1.6.4-1+deb10u1 500
        total 24
        GOETSCHHOFER
        #963
        @crunchip
        Vielen herzlichen Dank.
        Die war jetzt die Lösung, jetzt läuft die InfluxDB wieder.
        Muss ich da jetzt noch etwas korrigieren ?
        sudo chmod +x /usr/lib/influxdb/scripts/influxd-systemd-start.sh
        sudo systemctl restart influxdb.service
        Jetzt bringt er mir nur noch diese Fehlermeldung im iobroker zu proxmox.
        Was kann dies noch sein ?
        • G GOETSCHHOFER
          login as: karl
          influxdb:
            Installed: 1.8.9-1
            Candidate: 1.8.9-1
            Version table:
           *** 1.8.9-1 500
               1.6.4-1+deb10u1 500
          login as: karl
          influxdb:
            Installed: 1.8.9-1
            Candidate: 1.8.9-1
            Version table:
           *** 1.8.9-1 500
               1.6.4-1+deb10u1 500
          > influxdb:
          >   Installed: 1.8.9-1
          >   Candidate: 1.8.9-1
          >   Version table:
          >  *** 1.8.9-1 500
          >      1.6.4-1+deb10u1 500
          total 24
          crunchipC Offline
          crunchipC Offline
          #964
          @goetschhofer hast du im link etwas geblättert. ja ab version 1.8.7 und folgende gab es Änderung.
          auf deinem Influx
          sudo chown -R influxdb:influxdb /usr/lib/influxdb
          dnach musst du noch ne Änderung im Startscript vornehmen
          edit :
          hast ja schon hinbekommen
          G 1 Antwort Letzte Antwort
          • G GOETSCHHOFER
            @crunchip
            crunchipC Offline
            crunchipC Offline
            #965
            ada hast du wahrscheinlich etwas im Adapter angehakt und bekommst nun die Meldung, dass das Objekt noch nicht vorhanden ist, sollte nach einem erneuten start des Adapters weg sein
            G 2 Antworten Letzte Antwort
              GOETSCHHOFER
              #966
              @crunchip
              Wie kann ich die Änderung von 1 auf 10 abspeichern ? Normalerweise habe ich da keine Probleme, aber heute bin ich wahrscheinlich geistig schon am Limit.
              Wenn ich mit Ja bestätige, kann ich nur Strg-C machen. Mit N kann ich aussteigen.
              nano /usr/lib/influxdb/scripts/influxd-systemd-start.sh
                GOETSCHHOFER
                #967
                Grafana funktioniert wieder, InfluxDB läuft auch, aber diese Fehlermeldung zu proxmox bekomme ich auch durch einen Neustart des Influxdb.adapters nicht weg.
                • G GOETSCHHOFER
                  @crunchip
                  crunchipC Offline
                  crunchipC Offline
                  #968
                  @goetschhofer strg o, strg x
                  • G GOETSCHHOFER
                    crunchipC Offline
                    crunchipC Offline
                    #969
                    dann issue beim Adapter anlegen
                    WalW 1 Antwort Letzte Antwort
                      WalW Offline
                      WalW Offline
                      Wal
                      #970
                      @crunchip ,
                      entweder bin ich blöd oder was haben die proxmox-adapter Fehler mit influxdb zu tun.
                      Walter
                      DoorIO-Adapter
                      • WalW Wal
                        @crunchip ,
                        crunchipC Offline
                        crunchipC Offline
                        #971
                        @wal na der Proxmox Adapter kann verschiedenste Info`s einholen, alles was an VM und LXC in deinem Proxmox läuft, je nachdem was man im Adapter anhakt. Dabei ist doch wurscht was auf der jeweiligen Maschine installiert ist.
                          WalW Offline
                          WalW Offline
                          Wal
                          #972
                          @crunchip ,
                          ich sehe aber nur sein iobroker und grafana Container in den Meldungen und nicht sein influx container.
                          Walter
                          DoorIO-Adapter
                          • WalW Wal
                            @crunchip ,
                            crunchipC Offline
                            crunchipC Offline
                            #973
                            @wal ah jetzt komm ich mit, du meinst deswegen? das hatte ich überlesen
                            @GOETSCHHOFER nicht influx neu starten, sondern den Proxmox Adapter
                              GOETSCHHOFER
                              #974
                              Den proxmox adaper neu starten hat jetzt zum Ziel geführt, die Fehlermeldungen sind weg.
                              Vielen Dank für den Tipp. 👍 😁
                                auf deinem Influx
                                edit :
                                GOETSCHHOFER
                                #975
                                auf deinem Influx
                                edit :
                                Mit Strg-o und Strg-x meinst du das abspeichern.
                                Nach Strg-o kann ich nur Strg-c machen, wo stehe ich hier auf dem Schlauch ?
                                Und mit Strg-c komme ich wieder retour.
                                Könnte dies wieder ein Rechteproblem sein ?
                                • G GOETSCHHOFER
                                  auf deinem Influx
                                  edit :
                                  crunchipC Offline
                                  crunchipC Offline
                                  #976
                                  @goetschhofer du machst das immer in der proxmox konsole. Geh doch mit putty drauf, dann kannst du wie beschrieben speichern beenden.
                                    GOETSCHHOFER
                                    #977
                                    Nein, da darf ich dir ausnahmsweise mal widersprechen.
                                    Ich steige bei allen diesen Befehlen immer über die putty/shell ein.
                                    Habe mal Strg-G help gemacht und hier sind bei mir nur die folgenden Funktionen möglich.
                                     The following function keys are available in Write File mode:
                                    ^G    (F1)      Display this help text
                                    ^C              Cancel the current function
                                    M-D             Toggle the use of DOS format
                                    M-M             Toggle the use of Mac format
                                    M-A             Toggle appending
                                    M-P             Toggle prepending
                                    M-B             Toggle backing up of the original file
                                    ^T              Go to file browser
                                                    Close buffer without saving it
                                    • G GOETSCHHOFER
                                      crunchipC Offline
                                      crunchipC Offline
                                      #978
                                      @goetschhofer du musst schon nach strg o noch die ENTER Taste drücken
                                      oder anders, änderst du etwas an der Datei und drückst anschliessend strg x, also ohne strg o, wird gefragt, ob du die Änderung speichern möchtest
                                        GOETSCHHOFER
                                        #979
                                        1. Nach Strg-o und enter bekomme ich folgende Fehlermeldung.
                                        2. Nach Strg-x, gebe ich Y ein und dann springt er wieder zurück, mit der Auswahl aufStrg-c.
                                          Mit N komme ich heraus.
                                        Habe es jetzt mal über putty über root, sudo su - versucht, das gleiche Problem, ich kann nicht abspeichern.
                                        Also dürfte es doch kein Rechteproblem sein ?
                                        • G GOETSCHHOFER
                                          GOETSCHHOFER
                                          #980
                                          @goetschhofer
                                          Ich habe gestern folgendes gemacht:
                                          Was hast du gestern mit folgendem Befehl gemeint ?
