  4. Anfänger sucht Hilfe bei Install. proxmox auf INTELNUC8i3BEK
    6.6k
1.0k Beiträge 16 Kommentatoren 322.5k Aufrufe 15 Beobachtet
  • G GOETSCHHOFER
    @wal said in Anfänger sucht Hilfe bei Install. proxmox auf INTELNUC8i3BEK:
    @goetschhofer,
    ist der influx-Server von iobroker ereichbar und läuft auf dem Server influxdb ?
    ping 192.168.1.177
    von iobroker aus.
    sudo systemctl status influxdb
    auf dem influx-Server
    permitted by applicable law.
    Last login: Sat Aug 21 11:25:06 2021 from 192.168.1.3
    karl@LXC-INFLUXDB-192:~$ ping 192.168.1.177
    PING 192.168.1.177 (192.168.1.177) 56(84) bytes of data.
    64 bytes from 192.168.1.177: icmp_seq=1 ttl=64 time=0.029 ms
    64 bytes from 192.168.1.177: icmp_seq=2 ttl=64 time=0.026 ms
    64 bytes from 192.168.1.177: icmp_seq=3 ttl=64 time=0.026 ms
    64 bytes from 192.168.1.177: icmp_seq=4 ttl=64 time=0.027 ms
    64 bytes from 192.168.1.177: icmp_seq=5 ttl=64 time=0.030 ms
    64 bytes from 192.168.1.177: icmp_seq=6 ttl=64 time=0.028 ms
    64 bytes from 192.168.1.177: icmp_seq=7 ttl=64 time=0.028 ms
    64 bytes from 192.168.1.177: icmp_seq=8 ttl=64 time=0.074 ms
    64 bytes from 192.168.1.177: icmp_seq=9 ttl=64 time=0.021 ms
    64 bytes from 192.168.1.177: icmp_seq=10 ttl=64 time=0.034 ms
    64 bytes from 192.168.1.177: icmp_seq=11 ttl=64 time=0.027 ms
    ^C
    --- 192.168.1.177 ping statistics ---
    11 packets transmitted, 11 received, 0% packet loss, time 257ms
    rtt min/avg/max/mdev = 0.021/0.031/0.074/0.015 ms
    karl@IOBROKER:~$ ping 192.168.1.177
    64 bytes from 192.168.1.177: icmp_seq=1 ttl=64 time=0.085 ms
    64 bytes from 192.168.1.177: icmp_seq=2 ttl=64 time=0.121 ms
    64 bytes from 192.168.1.177: icmp_seq=3 ttl=64 time=0.180 ms
    64 bytes from 192.168.1.177: icmp_seq=4 ttl=64 time=0.185 ms
    64 bytes from 192.168.1.177: icmp_seq=5 ttl=64 time=0.120 ms
    64 bytes from 192.168.1.177: icmp_seq=6 ttl=64 time=0.122 ms
    64 bytes from 192.168.1.177: icmp_seq=7 ttl=64 time=0.123 ms
    64 bytes from 192.168.1.177: icmp_seq=8 ttl=64 time=0.117 ms
    64 bytes from 192.168.1.177: icmp_seq=9 ttl=64 time=0.185 ms
    64 bytes from 192.168.1.177: icmp_seq=10 ttl=64 time=0.232 ms
    64 bytes from 192.168.1.177: icmp_seq=11 ttl=64 time=0.194 ms
    64 bytes from 192.168.1.177: icmp_seq=12 ttl=64 time=0.134 ms
    64 bytes from 192.168.1.177: icmp_seq=13 ttl=64 time=0.190 ms
    64 bytes from 192.168.1.177: icmp_seq=14 ttl=64 time=0.153 ms
    64 bytes from 192.168.1.177: icmp_seq=15 ttl=64 time=0.123 ms
    64 bytes from 192.168.1.177: icmp_seq=16 ttl=64 time=0.186 ms
    64 bytes from 192.168.1.177: icmp_seq=17 ttl=64 time=0.185 ms
    64 bytes from 192.168.1.177: icmp_seq=18 ttl=64 time=0.137 ms
    64 bytes from 192.168.1.177: icmp_seq=19 ttl=64 time=0.116 ms
    64 bytes from 192.168.1.177: icmp_seq=20 ttl=64 time=0.096 ms
    64 bytes from 192.168.1.177: icmp_seq=21 ttl=64 time=0.083 ms
    64 bytes from 192.168.1.177: icmp_seq=22 ttl=64 time=0.187 ms
    ^C
    22 packets transmitted, 22 received, 0% packet loss, time 512ms
    rtt min/avg/max/mdev = 0.083/0.147/0.232/0.043 ms
    karl@IOBROKER:~$
    Da könnte der Wurm liegen ?
    Last login: Sat Aug 21 12:20:06 2021 from 192.168.1.3
    karl@LXC-INFLUXDB-192:~$ sudo systemctl status influxdb
    [sudo] password for karl:
    * influxdb.service - InfluxDB is an open-source, distributed, time series databa
       Loaded: loaded (/lib/systemd/system/influxdb.service; enabled; vendor preset:
       Active: failed (Result: exit-code) since Sat 2021-08-21 11:57:37 CEST; 26min
         Docs: https://docs.influxdata.com/influxdb/
      Process: 277 ExecStart=/usr/lib/influxdb/scripts/influxd-systemd-start.sh (cod
    Aug 21 11:57:37 LXC-INFLUXDB-192 systemd[1]: influxdb.service: Service RestartSe
    Aug 21 11:57:37 LXC-INFLUXDB-192 systemd[1]: influxdb.service: Scheduled restart
    Aug 21 11:57:37 LXC-INFLUXDB-192 systemd[1]: Stopped InfluxDB is an open-source,
    Aug 21 11:57:37 LXC-INFLUXDB-192 systemd[1]: influxdb.service: Start request rep
    Aug 21 11:57:37 LXC-INFLUXDB-192 systemd[1]: influxdb.service: Failed with resul
    Aug 21 11:57:37 LXC-INFLUXDB-192 systemd[1]: Failed to start InfluxDB is an open
    lines 1-12/12 (END)...skipping...
    * influxdb.service - InfluxDB is an open-source, distributed, time series database
       Loaded: loaded (/lib/systemd/system/influxdb.service; enabled; vendor preset: enabled)
       Active: failed (Result: exit-code) since Sat 2021-08-21 11:57:37 CEST; 26min ago
      Process: 277 ExecStart=/usr/lib/influxdb/scripts/influxd-systemd-start.sh (code=exited, status=203/EXEC)
    Aug 21 11:57:37 LXC-INFLUXDB-192 systemd[1]: influxdb.service: Service RestartSec=100ms expired, scheduling restart.
    Aug 21 11:57:37 LXC-INFLUXDB-192 systemd[1]: influxdb.service: Scheduled restart job, restart counter is at 5.
    Aug 21 11:57:37 LXC-INFLUXDB-192 systemd[1]: Stopped InfluxDB is an open-source, distributed, time series database.
    Aug 21 11:57:37 LXC-INFLUXDB-192 systemd[1]: influxdb.service: Start request repeated too quickly.
    Aug 21 11:57:37 LXC-INFLUXDB-192 systemd[1]: influxdb.service: Failed with result 'exit-code'.
    Aug 21 11:57:37 LXC-INFLUXDB-192 systemd[1]: Failed to start InfluxDB is an open-source, distributed, time series database.
    WalW Offline
    WalW Offline
    Wal
    #955
    @goetschhofer ,
    jepp influxdb Service läuft nicht.
    Walter
    DoorIO-Adapter
    G 1 Antwort Letzte Antwort
    • WalW Wal
      @goetschhofer ,
      GOETSCHHOFER
      schrieb am zuletzt editiert von GOETSCHHOFER
      #956
      @goetschhofer ,
      Wie starte ich diesen jetzt:
      start mit start service influxdb ?
      WalW 1 Antwort Letzte Antwort
      • G GOETSCHHOFER
        @goetschhofer ,
        WalW Offline
        WalW Offline
        Wal
        #957
        @goetschhofer ,
        das wird nichts bringen, da der Service automatisch neu gestartet wird.
        Es stimmt was in deiner influx-config nicht. Da bin ich aber leider raus, habe meine local auf dem iobroker laufen.
        Walter
        DoorIO-Adapter
        • WalW Wal
          @goetschhofer ,
          GOETSCHHOFER
          #958
          @goetschhofer ,
          O.k., dann sage ich mal vielen Dank für deine Hilfe.
          • G GOETSCHHOFER
            @goetschhofer ,
            GOETSCHHOFER
            #959
            @crunchip @Homoran
            Ich habe offenbar ein Problem bei meinem influxdb Service.
            Könntet ihr mir hier bitte weiterhelfen ?
            Wenn ich versuche den Influxdb Service zu starten bekomme ich folgende Fehlermeldung:
            login as: karl
            karl@192.168.1.177's password:
            Linux LXC-INFLUXDB-192 5.4.124-1-pve #1 SMP PVE 5.4.124-1 (Wed, 23 Jun 2021 13:4        7:09 +0200) x86_64
            Last login: Sat Aug 21 12:42:56 2021 from 192.168.1.3
            karl@LXC-INFLUXDB-192:~$ sudo service influxdb start
            Job for influxdb.service failed because the control process exited with error co        de.
            See "systemctl status influxdb.service" and "journalctl -xe" for details.
            Aug 21 12:36:20 LXC-INFLUXDB-192 systemd[1]: Stopped InfluxDB is an open-source,
            Aug 21 12:36:20 LXC-INFLUXDB-192 systemd[1]: influxdb.service: Start request rep
            Aug 21 12:36:20 LXC-INFLUXDB-192 systemd[1]: influxdb.service: Failed with resul
            Aug 21 12:36:20 LXC-INFLUXDB-192 systemd[1]: Failed to start InfluxDB is an open
               Active: failed (Result: exit-code) since Sat 2021-08-21 12:36:20 CEST; 10min ago
            Aug 21 12:36:20 LXC-INFLUXDB-192 systemd[1]: influxdb.service: Service RestartSec=100ms expired, scheduling restart.
            Aug 21 12:36:20 LXC-INFLUXDB-192 systemd[1]: influxdb.service: Scheduled restart job, restart counter is at 5.
            Aug 21 12:36:20 LXC-INFLUXDB-192 systemd[1]: Stopped InfluxDB is an open-source, distributed, time series database.
            Aug 21 12:36:20 LXC-INFLUXDB-192 systemd[1]: influxdb.service: Start request repeated too quickly.
            Aug 21 12:36:20 LXC-INFLUXDB-192 systemd[1]: influxdb.service: Failed with result 'exit-code'.
            Aug 21 12:36:20 LXC-INFLUXDB-192 systemd[1]: Failed to start InfluxDB is an open-source, distributed, time series database.
            • G GOETSCHHOFER
              @meister-popper @crunchip
              Habe jetzt "nur" noch das Problem, dass ich den iobroker über die ip-Adresse nicht mehr aufrufen kann.
              Über die shell ist es möglich, er läuft auch in proxmox ohne Fehlermeldung.
              crunchipC Offline
              crunchipC Offline
              #960
              @goetschhofer deine VM läuft zwar, aber nicht der iobroker ansich, geb iobroker start ein, dann sollte er wieder anlaufen
              • G GOETSCHHOFER
                @crunchip @Homoran
                login as: karl
                crunchipC Offline
                crunchipC Offline
                #961
                @goetschhofer sagte in Anfänger sucht Hilfe bei Install. proxmox auf INTELNUC8i3BEK:
                hast du wahscheinlich auch ein Update auf die neue version gemacht, somit liegt das startscript an einem anderen Ort, bzw fehlen die nötigen Rechte, des weiteren gibt es da eine Zeitabfrage beim Start von Influx, guck mal hier
                  GOETSCHHOFER
                  #962
                  @crunchip said in Anfänger sucht Hilfe bei Install. proxmox auf INTELNUC8i3BEK:
                  Iobroker start habe ich gemacht.
                  Der iobroker läuft meines Erachtens aktuell schon, aber die Verbindung zur InfluxDB wirft einen Fehler aus.
                  Drehe mich gerade im Kreis.
                  login as: karl
                  Last login: Sat Aug 21 15:05:33 2021 from 192.168.1.3
                  karl@LXC-INFLUXDB-192:~$ apt policy influxdb
                  influxdb:
                    Installed: 1.8.9-1
                    Candidate: 1.8.9-1
                    Version table:
                   *** 1.8.9-1 500
                          500 https://repos.influxdata.com/debian buster/stable amd64 Packages
                       1.6.4-1+deb10u1 500
                          500 http://ftp.debian.org/debian buster/main amd64 Packages
                          500 http://security.debian.org buster/updates/main amd64 Packages
                  login as: karl
                  karl@192.168.1.176's password:
                  Linux IOBROKER 4.19.0-17-amd64 #1 SMP Debian 4.19.194-3 (2021-07-18) x86_64
                  Last login: Sat Aug 21 15:07:13 2021 from 192.168.1.3
                  karl@IOBROKER:~$ login as: karl
                  influxdb:
                    Installed: 1.8.9-1
                    Candidate: 1.8.9-1
                    Version table:
                   *** 1.8.9-1 500
                       1.6.4-1+deb10u1 500
                  login: Arbeit ohne effektive root-Rechte eventuell nicht möglich
                  karl@IOBROKER:~$ karl@192.168.1.177's password:
                  > Linux LXC-INFLUXDB-192 5.4.124-1-pve #1 SMP PVE 5.4.124-1 (Wed, 23 Jun 2021 13        :4        7        :09 +0200) x86_64
                  > influxdb:
                  >   Installed: 1.8.9-1
                  >   Candidate: 1.8.9-1
                  >   Version table:
                  >  *** 1.8.9-1 500
                  >      1.6.4-1+deb10u1 500
                  karl@LXC-INFLUXDB-192:~$ ls -la /usr/lib/influxdb/scripts
                  total 24
                  drwxr-xr-x 2 root root 4096 Aug 21 14:12 .
                  drwxr-xr-x 3 root root 4096 May  8 19:25 ..
                  -rwxr-xr-x 1 root root 1116 Aug  5 00:31 influxd-systemd-start.sh
                  -rw-r--r-- 1 root root  533 Aug  5 00:31 influxdb.service
                  -rw-r--r-- 1 root root 5702 Aug  5 00:31 init.sh
                  G crunchipC 2 Antworten Letzte Antwort
                  • G GOETSCHHOFER
                    login as: karl
                    influxdb:
                      Installed: 1.8.9-1
                      Candidate: 1.8.9-1
                      Version table:
                     *** 1.8.9-1 500
                         1.6.4-1+deb10u1 500
                    login as: karl
                    influxdb:
                      Installed: 1.8.9-1
                      Candidate: 1.8.9-1
                      Version table:
                     *** 1.8.9-1 500
                         1.6.4-1+deb10u1 500
                    > influxdb:
                    >   Installed: 1.8.9-1
                    >   Candidate: 1.8.9-1
                    >   Version table:
                    >  *** 1.8.9-1 500
                    >      1.6.4-1+deb10u1 500
                    total 24
                    GOETSCHHOFER
                    #963
                    @crunchip
                    Vielen herzlichen Dank.
                    Die war jetzt die Lösung, jetzt läuft die InfluxDB wieder.
                    Muss ich da jetzt noch etwas korrigieren ?
                    sudo chmod +x /usr/lib/influxdb/scripts/influxd-systemd-start.sh
                    sudo systemctl restart influxdb.service
                    Jetzt bringt er mir nur noch diese Fehlermeldung im iobroker zu proxmox.
                    Was kann dies noch sein ?
                    • G GOETSCHHOFER
                      login as: karl
                      influxdb:
                        Installed: 1.8.9-1
                        Candidate: 1.8.9-1
                        Version table:
                       *** 1.8.9-1 500
                           1.6.4-1+deb10u1 500
                      login as: karl
                      influxdb:
                        Installed: 1.8.9-1
                        Candidate: 1.8.9-1
                        Version table:
                       *** 1.8.9-1 500
                           1.6.4-1+deb10u1 500
                      > influxdb:
                      >   Installed: 1.8.9-1
                      >   Candidate: 1.8.9-1
                      >   Version table:
                      >  *** 1.8.9-1 500
                      >      1.6.4-1+deb10u1 500
                      total 24
                      crunchipC Offline
                      crunchipC Offline
                      #964
                      @goetschhofer hast du im link etwas geblättert. ja ab version 1.8.7 und folgende gab es Änderung.
                      auf deinem Influx
                      sudo chown -R influxdb:influxdb /usr/lib/influxdb
                      dnach musst du noch ne Änderung im Startscript vornehmen
                      edit :
                      hast ja schon hinbekommen
                      • G GOETSCHHOFER
                        @crunchip
                        crunchipC Offline
                        crunchipC Offline
                        #965
                        ada hast du wahrscheinlich etwas im Adapter angehakt und bekommst nun die Meldung, dass das Objekt noch nicht vorhanden ist, sollte nach einem erneuten start des Adapters weg sein
                        G 2 Antworten Letzte Antwort
                          GOETSCHHOFER
                          #966
                          @crunchip
                          Wie kann ich die Änderung von 1 auf 10 abspeichern ? Normalerweise habe ich da keine Probleme, aber heute bin ich wahrscheinlich geistig schon am Limit.
                          Wenn ich mit Ja bestätige, kann ich nur Strg-C machen. Mit N kann ich aussteigen.
                          nano /usr/lib/influxdb/scripts/influxd-systemd-start.sh
                            GOETSCHHOFER
                            #967
                            Grafana funktioniert wieder, InfluxDB läuft auch, aber diese Fehlermeldung zu proxmox bekomme ich auch durch einen Neustart des Influxdb.adapters nicht weg.
                            • G GOETSCHHOFER
                              @crunchip
                              crunchipC Offline
                              crunchipC Offline
                              #968
                              @goetschhofer strg o, strg x
                              • G GOETSCHHOFER
                                crunchipC Offline
                                crunchipC Offline
                                #969
                                dann issue beim Adapter anlegen
                                  WalW Offline
                                  WalW Offline
                                  Wal
                                  #970
                                  @crunchip ,
                                  entweder bin ich blöd oder was haben die proxmox-adapter Fehler mit influxdb zu tun.
                                  Walter
                                  DoorIO-Adapter
                                  • WalW Wal
                                    @crunchip ,
                                    crunchipC Offline
                                    crunchipC Offline
                                    #971
                                    @wal na der Proxmox Adapter kann verschiedenste Info`s einholen, alles was an VM und LXC in deinem Proxmox läuft, je nachdem was man im Adapter anhakt. Dabei ist doch wurscht was auf der jeweiligen Maschine installiert ist.
                                      WalW Offline
                                      WalW Offline
                                      Wal
                                      #972
                                      @crunchip ,
                                      ich sehe aber nur sein iobroker und grafana Container in den Meldungen und nicht sein influx container.
                                      Walter
                                      DoorIO-Adapter
                                      • WalW Wal
                                        @crunchip ,
                                        crunchipC Offline
                                        crunchipC Offline
                                        #973
                                        @wal ah jetzt komm ich mit, du meinst deswegen? das hatte ich überlesen
                                        @GOETSCHHOFER nicht influx neu starten, sondern den Proxmox Adapter
                                          GOETSCHHOFER
                                          #974
                                          Den proxmox adaper neu starten hat jetzt zum Ziel geführt, die Fehlermeldungen sind weg.
                                          Vielen Dank für den Tipp. 👍 😁
