  4. [How-to] Node.js ioBroker richtig updaten-2021/22 Edition
    5.9k
812 Beiträge 97 Kommentatoren 446.2k Aufrufe 83 Beobachtet
    @negalein sagte in [How-to] Node.js ioBroker richtig updaten-2021/22 Edition:
    Ist hier noch was zu machen?
    Ja, hau die 70 Updates auf dein System!
    NegaleinN Offline
    NegaleinN Offline
    Negalein
    #521
    @thomas-braun sagte in [How-to] Node.js ioBroker richtig updaten-2021/22 Edition:
    du meinst apt-get update && apt-get upgrade
    ° Fixer ---> iob fix
    • NegaleinN Negalein
      #522
      @negalein
      Natürlich.
      Mach das regelmäßig. Besser aber:
      sudo apt update
      sudo apt full-upgrade
        @negalein
        Natürlich.
        sudo apt update
        NegaleinN Offline
        NegaleinN Offline
        Negalein
        #523
        Besser aber:
        Merci :)
          Hallo
          Habe auch soeben auf 16.15.1 upgedatet.
          Im Log kommt nun
          javascript.0 2022-06-24 10:30:47.111	error	Request error: Error: connect ECONNRESET 85.31.3.249:443
          javascript.0 2022-06-24 10:30:47.111	error	Error in request callback: SyntaxError: Unexpected token u in JSON at position 0
          javascript.0 2022-06-24 10:30:15.935	error	notice
          javascript.0 2022-06-24 10:30:15.934	error	npm notice npm notice New minor version of npm available! 8.11.0 -> 8.13.1 npm notice Changelog: <https://github.com/npm/cli/releases/tag/v8.13.1> npm notice Run `npm install -g npm@8.13.1` to update! npm
          javascript.0 2022-06-24 10:30:14.740	error	deprecated coffee-script@1.12.7: CoffeeScript on NPM has moved to "coffeescript" (no hyphen)
          javascript.0 2022-06-24 10:30:14.740	error	npm WARN
          javascript.0 2022-06-24 10:30:14.673	error	deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
          javascript.0 2022-06-24 10:30:14.672	error	npm WARN
          javascript.0 2022-06-24 10:30:14.537	error	deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details.
          javascript.0 2022-06-24 10:30:14.537	error	npm WARN
          javascript.0 2022-06-24 10:30:14.442	error	npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
          javascript.0 2022-06-24 10:30:14.354	error	WARN deprecated har-validator@5.1.5: this library is no longer supported
          javascript.0 2022-06-24 10:30:14.354	error	npm
          javascript.0 2022-06-24 10:29:46.746	error	npm WARN old lockfile
          javascript.0 2022-06-24 10:29:46.746	error	WARN old lockfile npm WARN old lockfile The package-lock.json file was created with an old version of npm,npm WARN old lockfile so supplemental metadata must be fetched from the registry.npm WARN old lockfile npm WARN old lockfile This is a one-time fix-up, please be patient...
          javascript.0 2022-06-24 10:29:46.745	error	npm
          javascript.0 2022-06-24 10:29:46.618	error	WARN config production Use `--omit=dev` instead.
          javascript.0 2022-06-24 10:29:46.618	error	npm
          Und während dem fix kamen Permission Errors.
          nega@ioBroker:~$ iobroker stop
          nega@ioBroker:~$ curl -sL https://deb.nodesource.com/setup_16.x | sudo -E bash -
          [sudo] password for nega:
          ## Installing the NodeSource Node.js 16.x repo...
          ## Populating apt-get cache...
          + apt-get update
          Get:1 https://deb.nodesource.com/node_14.x focal InRelease [4583 B]
          Hit:2 http://archive.ubuntu.com/ubuntu focal InRelease
          Get:3 https://deb.nodesource.com/node_14.x focal/main amd64 Packages [774 B]
          Get:4 http://archive.ubuntu.com/ubuntu focal-updates InRelease [114 kB]
          Get:5 http://archive.ubuntu.com/ubuntu focal-security InRelease [114 kB]
          Get:7 http://archive.ubuntu.com/ubuntu focal-updates/main amd64 Packages [1935 kB]
          Get:8 http://archive.ubuntu.com/ubuntu focal-updates/main Translation-en [350 kB]
          Get:9 http://archive.ubuntu.com/ubuntu focal-updates/main amd64 c-n-f Metadata [15.6 kB]
          Get:10 http://archive.ubuntu.com/ubuntu focal-updates/restricted amd64 Packages [1099 kB]
          Get:11 http://archive.ubuntu.com/ubuntu focal-updates/restricted Translation-en [156 kB]
          Get:12 http://archive.ubuntu.com/ubuntu focal-updates/restricted amd64 c-n-f Metadata [524 B]
          Get:13 http://archive.ubuntu.com/ubuntu focal-updates/universe amd64 Packages [924 kB]
          Get:14 http://archive.ubuntu.com/ubuntu focal-updates/universe Translation-en [208 kB]
          Get:15 http://archive.ubuntu.com/ubuntu focal-updates/universe amd64 c-n-f Metadata [20.9 kB]
          Get:16 http://archive.ubuntu.com/ubuntu focal-updates/multiverse amd64 Packages [24.4 kB]
          Get:17 http://archive.ubuntu.com/ubuntu focal-updates/multiverse amd64 c-n-f Metadata [596 B]
          Get:18 http://archive.ubuntu.com/ubuntu focal-security/main amd64 Packages [1583 kB]
          Hit:6 https://packagecloud.io/ookla/speedtest-cli/ubuntu focal InRelease
          Get:19 http://archive.ubuntu.com/ubuntu focal-security/main Translation-en [268 kB]
          Get:20 http://archive.ubuntu.com/ubuntu focal-security/main amd64 c-n-f Metadata [10.6 kB]
          Get:21 http://archive.ubuntu.com/ubuntu focal-security/restricted amd64 Packages [1036 kB]
          Get:22 http://archive.ubuntu.com/ubuntu focal-security/restricted Translation-en [147 kB]
          Get:23 http://archive.ubuntu.com/ubuntu focal-security/restricted amd64 c-n-f Metadata [524 B]
          Get:24 http://archive.ubuntu.com/ubuntu focal-security/universe amd64 Packages [708 kB]
          Get:25 http://archive.ubuntu.com/ubuntu focal-security/universe Translation-en [127 kB]
          Get:26 http://archive.ubuntu.com/ubuntu focal-security/universe amd64 c-n-f Metadata [14.6 kB]
          Get:27 http://archive.ubuntu.com/ubuntu focal-security/multiverse amd64 Packages [22.2 kB]
          Get:28 http://archive.ubuntu.com/ubuntu focal-security/multiverse Translation-en [5376 B]
          Get:29 http://archive.ubuntu.com/ubuntu focal-security/multiverse amd64 c-n-f Metadata [512 B]
          Fetched 8891 kB in 3s (3494 kB/s)
          Reading package lists... Done
          ## Confirming "focal" is supported...
          + curl -sLf -o /dev/null 'https://deb.nodesource.com/node_16.x/dists/focal/Release'
          ## Adding the NodeSource signing key to your keyring...
          + curl -s https://deb.nodesource.com/gpgkey/nodesource.gpg.key | gpg --dearmor | tee /usr/share/keyrings/nodesou        rce.gpg >/dev/null
          ## Creating apt sources list file for the NodeSource Node.js 16.x repo...
          + echo 'deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_16.x focal main' > /e        tc/apt/sources.list.d/nodesource.list
          + echo 'deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_16.x focal main'        >> /etc/apt/sources.list.d/nodesource.list
          ## Running `apt-get update` for you...
          + apt-get update
          Get:1 https://deb.nodesource.com/node_16.x focal InRelease [4583 B]
          Get:2 https://deb.nodesource.com/node_16.x focal/main amd64 Packages [773 B]
          Hit:3 http://archive.ubuntu.com/ubuntu focal InRelease
          Hit:4 http://archive.ubuntu.com/ubuntu focal-updates InRelease
          Hit:5 http://archive.ubuntu.com/ubuntu focal-security InRelease
          Fetched 5356 B in 1s (5113 B/s)
          ## Run `sudo apt-get install -y nodejs` to install Node.js 16.x and npm
          ## You may also need development tools to build native addons:
               sudo apt-get install gcc g++ make
          ## To install the Yarn package manager, run:
               curl -sL https://dl.yarnpkg.com/debian/pubkey.gpg | gpg --dearmor | sudo tee /usr/share/keyrings/yarnkey.gp        g >/dev/null
               echo "deb [signed-by=/usr/share/keyrings/yarnkey.gpg] https://dl.yarnpkg.com/debian stable main" | sudo tee        /etc/apt/sources.list.d/yarn.list
               sudo apt-get update && sudo apt-get install yarn
          nega@ioBroker:~$ sudo apt install -y nodejs
          Building dependency tree
          The following package was automatically installed and is no longer required:
            libllvm11
          Use 'sudo apt autoremove' to remove it.
          The following packages will be upgraded:
            nodejs
          1 upgraded, 0 newly installed, 0 to remove and 70 not upgraded.
          Need to get 26.4 MB of archives.
          After this operation, 383 kB of additional disk space will be used.
          Get:1 https://deb.nodesource.com/node_16.x focal/main amd64 nodejs amd64 16.15.1-deb-1nodesource1 [26.4 MB]
          Fetched 26.4 MB in 0s (73.7 MB/s)
          (Reading database ... 36343 files and directories currently installed.)
          Preparing to unpack .../nodejs_16.15.1-deb-1nodesource1_amd64.deb ...
          Unpacking nodejs (16.15.1-deb-1nodesource1) over (14.19.1-deb-1nodesource1) ...
          Setting up nodejs (16.15.1-deb-1nodesource1) ...
          Processing triggers for man-db (2.9.1-1) ...
          nega@ioBroker:~$ node -v
          v16.15.1
          nega@ioBroker:~$ npm -v
          8.11.0
          nega@ioBroker:~$ iobroker fix
          library: loaded
          Library version=2022-06-15
              Welcome to the ioBroker installation fixer!
              Script version: 2022-06-03
              You might need to enter your password a couple of times.
              Installing prerequisites (1/3)
          Hit:1 https://deb.nodesource.com/node_16.x focal InRelease
          Hit:3 http://archive.ubuntu.com/ubuntu focal-updates InRelease
          Hit:4 http://archive.ubuntu.com/ubuntu focal-security InRelease
          Hit:5 https://packagecloud.io/ookla/speedtest-cli/ubuntu focal InRelease
          Installed gcc-c++
              Checking ioBroker user and directory permissions (2/3)
          Created /etc/sudoers.d/iobroker
          chown: changing ownership of '/opt/iobroker/backups/ioBroker/homematic_2022_06_01-01_30_11_3.63.8_backupiobroker        .tar.sbk': Operation not permitted
          chown: changing ownership of '/opt/iobroker/backups/ioBroker/homematic_2022_06_04-01_30_11_3.63.9_backupiobroker        .tar.sbk': Operation not permitted
          chown: changing ownership of '/opt/iobroker/backups/ioBroker/iobroker_2022_06_06-23_00_10_Standard_backupiobroke        r.tar.gz': Operation not permitted
          chown: changing ownership of '/opt/iobroker/backups/ioBroker/historyDB_2022_06_06-23_00_58_Standard_backupiobrok        er.tar.gz': Operation not permitted
          chown: changing ownership of '/opt/iobroker/backups/ioBroker/grafana_2022_06_06-23_01_46_Standard_backupiobroker        .tar.gz': Operation not permitted
          chown: changing ownership of '/opt/iobroker/backups/ioBroker/javascripts_2022_06_06-23_01_51_Standard_backupiobr        oker.tar.gz': Operation not permitted
          chown: changing ownership of '/opt/iobroker/backups/ioBroker/homematic_2022_06_07-01_30_11_3.63.9_backupiobroker        .tar.sbk': Operation not permitted
          chown: changing ownership of '/opt/iobroker/backups/ioBroker/iobroker_2022_06_07-23_00_10_Standard_backupiobroke        r.tar.gz': Operation not permitted
          chown: changing ownership of '/opt/iobroker/backups/ioBroker/historyDB_2022_06_07-23_01_00_Standard_backupiobrok        er.tar.gz': Operation not permitted
          chown: changing ownership of '/opt/iobroker/backups/ioBroker/grafana_2022_06_07-23_01_48_Standard_backupiobroker        .tar.gz': Operation not permitted
          chown: changing ownership of '/opt/iobroker/backups/ioBroker/javascripts_2022_06_07-23_01_53_Standard_backupiobr        oker.tar.gz': Operation not permitted
          chown: changing ownership of '/opt/iobroker/backups/ioBroker/iobroker_2022_06_08-23_00_10_Standard_backupiobroke        r.tar.gz': Operation not permitted
          chown: changing ownership of '/opt/iobroker/backups/ioBroker/historyDB_2022_06_08-23_00_58_Standard_backupiobrok        er.tar.gz': Operation not permitted
          chown: changing ownership of '/opt/iobroker/backups/ioBroker/grafana_2022_06_08-23_01_47_Standard_backupiobroker        .tar.gz': Operation not permitted
          chown: changing ownership of '/opt/iobroker/backups/ioBroker/javascripts_2022_06_08-23_01_53_Standard_backupiobr        oker.tar.gz': Operation not permitted
          chown: changing ownership of '/opt/iobroker/backups/ioBroker': Operation not permitted
          chown: changing ownership of '/opt/iobroker/backups/homematic_2022_06_16-01_30_11_3.63.9_backupiobroker.tar.sbk'        : Operation not permitted
          chown: changing ownership of '/opt/iobroker/backups/homematic_2022_06_19-01_30_11_3.63.9_backupiobroker.tar.sbk'        : Operation not permitted
          chown: changing ownership of '/opt/iobroker/backups/iobroker_2022_06_21-23_00_10_Standard_backupiobroker.tar.gz'        : Operation not permitted
          chown: changing ownership of '/opt/iobroker/backups/historyDB_2022_06_21-23_01_01_Standard_backupiobroker.tar.gz        ': Operation not permitted
          chown: changing ownership of '/opt/iobroker/backups/grafana_2022_06_21-23_01_51_Standard_backupiobroker.tar.gz':        Operation not permitted
          chown: changing ownership of '/opt/iobroker/backups/javascripts_2022_06_21-23_01_57_Standard_backupiobroker.tar.        gz': Operation not permitted
          chown: changing ownership of '/opt/iobroker/backups/homematic_2022_06_22-01_30_11_3.63.9_backupiobroker.tar.sbk'        : Operation not permitted
          chown: changing ownership of '/opt/iobroker/backups/iobroker_2022_06_22-23_00_10_Standard_backupiobroker.tar.gz'        : Operation not permitted
          chown: changing ownership of '/opt/iobroker/backups/historyDB_2022_06_22-23_01_02_Standard_backupiobroker.tar.gz        ': Operation not permitted
          chown: changing ownership of '/opt/iobroker/backups/grafana_2022_06_22-23_01_53_Standard_backupiobroker.tar.gz':        Operation not permitted
          chown: changing ownership of '/opt/iobroker/backups/javascripts_2022_06_22-23_01_58_Standard_backupiobroker.tar.        gz': Operation not permitted
          chown: changing ownership of '/opt/iobroker/backups/iobroker_2022_06_23-23_00_10_Standard_backupiobroker.tar.gz'        : Operation not permitted
          chown: changing ownership of '/opt/iobroker/backups/historyDB_2022_06_23-23_01_01_Standard_backupiobroker.tar.gz        ': Operation not permitted
          chown: changing ownership of '/opt/iobroker/backups/grafana_2022_06_23-23_01_51_Standard_backupiobroker.tar.gz':        Operation not permitted
          chown: changing ownership of '/opt/iobroker/backups/javascripts_2022_06_23-23_01_56_Standard_backupiobroker.tar.        gz': Operation not permitted
          chown: changing ownership of '/opt/iobroker/backups': Operation not permitted
          This system does not support setting default permissions.
          Do not use npm to manually install adapters unless you know what you are doing!
              Checking autostart (3/3)
          Enabling autostart...
          Autostart enabled!
          nega@ioBroker:~$ iobroker start
          nega@ioBroker:~$
          #524
          Das der Fixer aber nicht die persmissions fixen darf finde ich bedenklich
          • apollon77A apollon77
            NegaleinN Offline
            NegaleinN Offline
            Negalein
            #525
            @apollon77 sagte in [How-to] Node.js ioBroker richtig updaten-2021/22 Edition:
            soll was bedeuten, bzw. was wäre zu machen?
            BananaJoeB Thomas BraunT 2 Antworten Letzte Antwort
              BananaJoeB Offline
              BananaJoeB Offline
              BananaJoe
              #526
              Nicht gleich machen und warten was die anderen sagen, aber bei mir muss ich iobroker fix als root ausführen, also wäre es mit sudo. Was für mich Sinn macht weil nur der root alle Verzeichnisrechte auch anpassen dürfte, egal wem die gehören. Wenn es bei dir die Verzeichnisse nicht dem nega Benutzer gehören und nicht dem iobroker-Benutzer muss es halt fehlschlagen.
              Aber wie gesagt warte mal eben was die anderen schreiben.
                #527
                @negalein
                Schau erstmal wie das Ding jetzt ausschaut:
                getfacl /opt/iobroker/backups
                Ist das Verzeichnis ein Mountpunkt für eine Freigabe eines file-Servers?
                • BananaJoeB BananaJoe
                  #528
                  @bananajoe sagte in [How-to] Node.js ioBroker richtig updaten-2021/22 Edition:
                  Standard ist das nicht. Aber du hältst dich ja auch nicht an den Standard mit deiner root shell...
                    @negalein
                    NegaleinN Offline
                    NegaleinN Offline
                    Negalein
                    #529
                    nega@ioBroker:~$ getfacl /opt/iobroker/backups
                    getfacl: Removing leading '/' from absolute path names
                    # file: opt/iobroker/backups
                    # owner: nobody
                    # group: nogroup
                    user::rwx
                    group::rwx
                    other::rwx
                    Ja, auf ein NAS
                      # owner: nobody
                      # group: nogroup
                      user::rwx
                      group::rwx
                      other::rwx
                      Ja, auf ein NAS
                      #530
                      @negalein Ha, na da haben wir den Grund ... In dem Fall "ists dann halt so" mit allen potentiellen Issues die das produzieren kann ..."
                        Sushibomba
                        #531
                        @apollon77 Hey kann mir jemand einmal alle Befehle schicken die ich brauche um reibungslos von Node 14 auf die 16er Version zu kommen?
                        Und gibt es auch Befehle um alte Paket aufzuräumen auf dem PI?
                        Thomas BraunT apollon77A 2 Antworten Letzte Antwort
                        • S Sushibomba
                          #532
                          @sushibomba
                          Schau in meiner Signatur.
                          Da wird's erklärt.
                          • S Sushibomba
                            #533
                            @sushibomba Im ersten Post ist alles beschrieben ... und 14 durch 16 austauschen sollte ja kein großes Problem sein. Es macht in meinen Augen wenig Sinn jetzt hier alles nochmals zu wiederholen
                              Sushibomba
                              #534
                              @apollon77 Ok klasse. Wusste nicht das es so einfach ist. Tut mir leid für die dumme Frage. Dachte ich müsse vielleicht noch was anderes berücksichtigen.
                                @sushibomba
                                Da wird's erklärt.
                                Sushibomba
                                #535
                                @thomas-braun Meinst du den Beitrag von 2020?
                                • S Sushibomba
                                  #536
                                  @sushibomba
                                  Den meine ich:
                                  Wird aber regelmäßig up-to-date gehalten.
                                    @sushibomba
                                    Den meine ich:
                                    Sushibomba
                                    #537
                                    @thomas-braun Danke. Ok dann war ich doch richtig.
                                    Ich möchte allerdings ungerne den zweiten dieser Befehle ausführen, weil es letztes Mal dazu geführt hat, dass ich mein Grafana nicht mehr abrufen konnte :/
                                    Geht das auch ohne diesen Befehl?
                                    • S Sushibomba
                                      #538
                                      @sushibomba sagte in [How-to] Node.js ioBroker richtig updaten-2021/22 Edition:
                                      Welcher zweite Befehl?
                                      Und nodejs hat nix mit Grafana zu tun.
                                        Sushibomba
                                        #539
                                        @thomas-braun Ach sorry hatte vergessen die Zeilen einzufügen...haha
                                        sudo apt update
                                        sudo apt upgrade
                                        • S Sushibomba
                                          sudo apt update
                                          sudo apt upgrade
                                          crunchipC Offline
                                          crunchipC Offline
                                          #540
                                          @sushibomba glaub das geht mit
                                          apt-mark hold NameDesPakets
                                          Thomas BraunT S 2 Antworten Letzte Antwort
