[How-to] Node.js ioBroker richtig updaten-2021/22 Edition
Hallo
Habe auch soeben auf 16.15.1 upgedatet.
Im Log kommt nun
javascript.0 2022-06-24 10:30:47.111 error Request error: Error: connect ECONNRESET 85.31.3.249:443 javascript.0 2022-06-24 10:30:47.111 error Error in request callback: SyntaxError: Unexpected token u in JSON at position 0 javascript.0 2022-06-24 10:30:15.935 error notice javascript.0 2022-06-24 10:30:15.934 error npm notice npm notice New minor version of npm available! 8.11.0 -> 8.13.1 npm notice Changelog: <https://github.com/npm/cli/releases/tag/v8.13.1> npm notice Run `npm install -g npm@8.13.1` to update! npm javascript.0 2022-06-24 10:30:14.740 error deprecated coffee-script@1.12.7: CoffeeScript on NPM has moved to "coffeescript" (no hyphen) javascript.0 2022-06-24 10:30:14.740 error npm WARN javascript.0 2022-06-24 10:30:14.673 error deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142 javascript.0 2022-06-24 10:30:14.672 error npm WARN javascript.0 2022-06-24 10:30:14.537 error deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details. javascript.0 2022-06-24 10:30:14.537 error npm WARN javascript.0 2022-06-24 10:30:14.442 error npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained. javascript.0 2022-06-24 10:30:14.354 error WARN deprecated har-validator@5.1.5: this library is no longer supported javascript.0 2022-06-24 10:30:14.354 error npm javascript.0 2022-06-24 10:29:46.746 error npm WARN old lockfile javascript.0 2022-06-24 10:29:46.746 error WARN old lockfile npm WARN old lockfile The package-lock.json file was created with an old version of npm,npm WARN old lockfile so supplemental metadata must be fetched from the registry.npm WARN old lockfile npm WARN old lockfile This is a one-time fix-up, please be patient... javascript.0 2022-06-24 10:29:46.745 error npm javascript.0 2022-06-24 10:29:46.618 error WARN config production Use `--omit=dev` instead. javascript.0 2022-06-24 10:29:46.618 error npmIst hier noch was zu machen?
Und während dem fix kamen Permission Errors.
nega@ioBroker:~$ iobroker stop nega@ioBroker:~$ curl -sL https://deb.nodesource.com/setup_16.x | sudo -E bash - [sudo] password for nega: ## Installing the NodeSource Node.js 16.x repo... ## Populating apt-get cache... + apt-get update Get:1 https://deb.nodesource.com/node_14.x focal InRelease [4583 B] Hit:2 http://archive.ubuntu.com/ubuntu focal InRelease Get:3 https://deb.nodesource.com/node_14.x focal/main amd64 Packages [774 B] Get:4 http://archive.ubuntu.com/ubuntu focal-updates InRelease [114 kB] Get:5 http://archive.ubuntu.com/ubuntu focal-security InRelease [114 kB] Get:7 http://archive.ubuntu.com/ubuntu focal-updates/main amd64 Packages [1935 kB] Get:8 http://archive.ubuntu.com/ubuntu focal-updates/main Translation-en [350 kB] Get:9 http://archive.ubuntu.com/ubuntu focal-updates/main amd64 c-n-f Metadata [15.6 kB] Get:10 http://archive.ubuntu.com/ubuntu focal-updates/restricted amd64 Packages [1099 kB] Get:11 http://archive.ubuntu.com/ubuntu focal-updates/restricted Translation-en [156 kB] Get:12 http://archive.ubuntu.com/ubuntu focal-updates/restricted amd64 c-n-f Metadata [524 B] Get:13 http://archive.ubuntu.com/ubuntu focal-updates/universe amd64 Packages [924 kB] Get:14 http://archive.ubuntu.com/ubuntu focal-updates/universe Translation-en [208 kB] Get:15 http://archive.ubuntu.com/ubuntu focal-updates/universe amd64 c-n-f Metadata [20.9 kB] Get:16 http://archive.ubuntu.com/ubuntu focal-updates/multiverse amd64 Packages [24.4 kB] Get:17 http://archive.ubuntu.com/ubuntu focal-updates/multiverse amd64 c-n-f Metadata [596 B] Get:18 http://archive.ubuntu.com/ubuntu focal-security/main amd64 Packages [1583 kB] Hit:6 https://packagecloud.io/ookla/speedtest-cli/ubuntu focal InRelease Get:19 http://archive.ubuntu.com/ubuntu focal-security/main Translation-en [268 kB] Get:20 http://archive.ubuntu.com/ubuntu focal-security/main amd64 c-n-f Metadata [10.6 kB] Get:21 http://archive.ubuntu.com/ubuntu focal-security/restricted amd64 Packages [1036 kB] Get:22 http://archive.ubuntu.com/ubuntu focal-security/restricted Translation-en [147 kB] Get:23 http://archive.ubuntu.com/ubuntu focal-security/restricted amd64 c-n-f Metadata [524 B] Get:24 http://archive.ubuntu.com/ubuntu focal-security/universe amd64 Packages [708 kB] Get:25 http://archive.ubuntu.com/ubuntu focal-security/universe Translation-en [127 kB] Get:26 http://archive.ubuntu.com/ubuntu focal-security/universe amd64 c-n-f Metadata [14.6 kB] Get:27 http://archive.ubuntu.com/ubuntu focal-security/multiverse amd64 Packages [22.2 kB] Get:28 http://archive.ubuntu.com/ubuntu focal-security/multiverse Translation-en [5376 B] Get:29 http://archive.ubuntu.com/ubuntu focal-security/multiverse amd64 c-n-f Metadata [512 B] Fetched 8891 kB in 3s (3494 kB/s) Reading package lists... Done ## Confirming "focal" is supported... + curl -sLf -o /dev/null 'https://deb.nodesource.com/node_16.x/dists/focal/Release' ## Adding the NodeSource signing key to your keyring... + curl -s https://deb.nodesource.com/gpgkey/nodesource.gpg.key | gpg --dearmor | tee /usr/share/keyrings/nodesou rce.gpg >/dev/null ## Creating apt sources list file for the NodeSource Node.js 16.x repo... + echo 'deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_16.x focal main' > /e tc/apt/sources.list.d/nodesource.list + echo 'deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_16.x focal main' >> /etc/apt/sources.list.d/nodesource.list ## Running `apt-get update` for you... + apt-get update Get:1 https://deb.nodesource.com/node_16.x focal InRelease [4583 B] Get:2 https://deb.nodesource.com/node_16.x focal/main amd64 Packages [773 B] Hit:3 http://archive.ubuntu.com/ubuntu focal InRelease Hit:4 http://archive.ubuntu.com/ubuntu focal-updates InRelease Hit:5 http://archive.ubuntu.com/ubuntu focal-security InRelease Hit:6 https://packagecloud.io/ookla/speedtest-cli/ubuntu focal InRelease Fetched 5356 B in 1s (5113 B/s) Reading package lists... Done ## Run `sudo apt-get install -y nodejs` to install Node.js 16.x and npm ## You may also need development tools to build native addons: sudo apt-get install gcc g++ make ## To install the Yarn package manager, run: curl -sL https://dl.yarnpkg.com/debian/pubkey.gpg | gpg --dearmor | sudo tee /usr/share/keyrings/yarnkey.gp g >/dev/null echo "deb [signed-by=/usr/share/keyrings/yarnkey.gpg] https://dl.yarnpkg.com/debian stable main" | sudo tee /etc/apt/sources.list.d/yarn.list sudo apt-get update && sudo apt-get install yarn nega@ioBroker:~$ sudo apt install -y nodejs Reading package lists... Done Building dependency tree Reading state information... Done The following package was automatically installed and is no longer required: libllvm11 Use 'sudo apt autoremove' to remove it. The following packages will be upgraded: nodejs 1 upgraded, 0 newly installed, 0 to remove and 70 not upgraded. Need to get 26.4 MB of archives. After this operation, 383 kB of additional disk space will be used. Get:1 https://deb.nodesource.com/node_16.x focal/main amd64 nodejs amd64 16.15.1-deb-1nodesource1 [26.4 MB] Fetched 26.4 MB in 0s (73.7 MB/s) (Reading database ... 36343 files and directories currently installed.) Preparing to unpack .../nodejs_16.15.1-deb-1nodesource1_amd64.deb ... Unpacking nodejs (16.15.1-deb-1nodesource1) over (14.19.1-deb-1nodesource1) ... Setting up nodejs (16.15.1-deb-1nodesource1) ... Processing triggers for man-db (2.9.1-1) ... nega@ioBroker:~$ node -v v16.15.1 nega@ioBroker:~$ npm -v 8.11.0 nega@ioBroker:~$ iobroker fix library: loaded Library version=2022-06-15 ========================================================================== Welcome to the ioBroker installation fixer! Script version: 2022-06-03 You might need to enter your password a couple of times. ========================================================================== ========================================================================== Installing prerequisites (1/3) ========================================================================== Hit:1 https://deb.nodesource.com/node_16.x focal InRelease Hit:2 http://archive.ubuntu.com/ubuntu focal InRelease Hit:3 http://archive.ubuntu.com/ubuntu focal-updates InRelease Hit:4 http://archive.ubuntu.com/ubuntu focal-security InRelease Hit:5 https://packagecloud.io/ookla/speedtest-cli/ubuntu focal InRelease Reading package lists... Done Installed gcc-c++ ========================================================================== Checking ioBroker user and directory permissions (2/3) ========================================================================== Created /etc/sudoers.d/iobroker Fixing directory permissions... chown: changing ownership of '/opt/iobroker/backups/ioBroker/homematic_2022_06_01-01_30_11_3.63.8_backupiobroker .tar.sbk': Operation not permitted chown: changing ownership of '/opt/iobroker/backups/ioBroker/homematic_2022_06_04-01_30_11_3.63.9_backupiobroker .tar.sbk': Operation not permitted chown: changing ownership of '/opt/iobroker/backups/ioBroker/iobroker_2022_06_06-23_00_10_Standard_backupiobroke r.tar.gz': Operation not permitted chown: changing ownership of '/opt/iobroker/backups/ioBroker/historyDB_2022_06_06-23_00_58_Standard_backupiobrok er.tar.gz': Operation not permitted chown: changing ownership of '/opt/iobroker/backups/ioBroker/grafana_2022_06_06-23_01_46_Standard_backupiobroker .tar.gz': Operation not permitted chown: changing ownership of '/opt/iobroker/backups/ioBroker/javascripts_2022_06_06-23_01_51_Standard_backupiobr oker.tar.gz': Operation not permitted chown: changing ownership of '/opt/iobroker/backups/ioBroker/homematic_2022_06_07-01_30_11_3.63.9_backupiobroker .tar.sbk': Operation not permitted chown: changing ownership of '/opt/iobroker/backups/ioBroker/iobroker_2022_06_07-23_00_10_Standard_backupiobroke r.tar.gz': Operation not permitted chown: changing ownership of '/opt/iobroker/backups/ioBroker/historyDB_2022_06_07-23_01_00_Standard_backupiobrok er.tar.gz': Operation not permitted chown: changing ownership of '/opt/iobroker/backups/ioBroker/grafana_2022_06_07-23_01_48_Standard_backupiobroker .tar.gz': Operation not permitted chown: changing ownership of '/opt/iobroker/backups/ioBroker/javascripts_2022_06_07-23_01_53_Standard_backupiobr oker.tar.gz': Operation not permitted chown: changing ownership of '/opt/iobroker/backups/ioBroker/iobroker_2022_06_08-23_00_10_Standard_backupiobroke r.tar.gz': Operation not permitted chown: changing ownership of '/opt/iobroker/backups/ioBroker/historyDB_2022_06_08-23_00_58_Standard_backupiobrok er.tar.gz': Operation not permitted chown: changing ownership of '/opt/iobroker/backups/ioBroker/grafana_2022_06_08-23_01_47_Standard_backupiobroker .tar.gz': Operation not permitted chown: changing ownership of '/opt/iobroker/backups/ioBroker/javascripts_2022_06_08-23_01_53_Standard_backupiobr oker.tar.gz': Operation not permitted chown: changing ownership of '/opt/iobroker/backups/ioBroker': Operation not permitted chown: changing ownership of '/opt/iobroker/backups/homematic_2022_06_16-01_30_11_3.63.9_backupiobroker.tar.sbk' : Operation not permitted chown: changing ownership of '/opt/iobroker/backups/homematic_2022_06_19-01_30_11_3.63.9_backupiobroker.tar.sbk' : Operation not permitted chown: changing ownership of '/opt/iobroker/backups/iobroker_2022_06_21-23_00_10_Standard_backupiobroker.tar.gz' : Operation not permitted chown: changing ownership of '/opt/iobroker/backups/historyDB_2022_06_21-23_01_01_Standard_backupiobroker.tar.gz ': Operation not permitted chown: changing ownership of '/opt/iobroker/backups/grafana_2022_06_21-23_01_51_Standard_backupiobroker.tar.gz': Operation not permitted chown: changing ownership of '/opt/iobroker/backups/javascripts_2022_06_21-23_01_57_Standard_backupiobroker.tar. gz': Operation not permitted chown: changing ownership of '/opt/iobroker/backups/homematic_2022_06_22-01_30_11_3.63.9_backupiobroker.tar.sbk' : Operation not permitted chown: changing ownership of '/opt/iobroker/backups/iobroker_2022_06_22-23_00_10_Standard_backupiobroker.tar.gz' : Operation not permitted chown: changing ownership of '/opt/iobroker/backups/historyDB_2022_06_22-23_01_02_Standard_backupiobroker.tar.gz ': Operation not permitted chown: changing ownership of '/opt/iobroker/backups/grafana_2022_06_22-23_01_53_Standard_backupiobroker.tar.gz': Operation not permitted chown: changing ownership of '/opt/iobroker/backups/javascripts_2022_06_22-23_01_58_Standard_backupiobroker.tar. gz': Operation not permitted chown: changing ownership of '/opt/iobroker/backups/iobroker_2022_06_23-23_00_10_Standard_backupiobroker.tar.gz' : Operation not permitted chown: changing ownership of '/opt/iobroker/backups/historyDB_2022_06_23-23_01_01_Standard_backupiobroker.tar.gz ': Operation not permitted chown: changing ownership of '/opt/iobroker/backups/grafana_2022_06_23-23_01_51_Standard_backupiobroker.tar.gz': Operation not permitted chown: changing ownership of '/opt/iobroker/backups/javascripts_2022_06_23-23_01_56_Standard_backupiobroker.tar. gz': Operation not permitted chown: changing ownership of '/opt/iobroker/backups': Operation not permitted chown: changing ownership of '/opt/iobroker/backups/ioBroker/homematic_2022_06_01-01_30_11_3.63.8_backupiobroker .tar.sbk': Operation not permitted chown: changing ownership of '/opt/iobroker/backups/ioBroker/homematic_2022_06_04-01_30_11_3.63.9_backupiobroker .tar.sbk': Operation not permitted chown: changing ownership of '/opt/iobroker/backups/ioBroker/iobroker_2022_06_06-23_00_10_Standard_backupiobroke r.tar.gz': Operation not permitted chown: changing ownership of '/opt/iobroker/backups/ioBroker/historyDB_2022_06_06-23_00_58_Standard_backupiobrok er.tar.gz': Operation not permitted chown: changing ownership of '/opt/iobroker/backups/ioBroker/grafana_2022_06_06-23_01_46_Standard_backupiobroker .tar.gz': Operation not permitted chown: changing ownership of '/opt/iobroker/backups/ioBroker/javascripts_2022_06_06-23_01_51_Standard_backupiobr oker.tar.gz': Operation not permitted chown: changing ownership of '/opt/iobroker/backups/ioBroker/homematic_2022_06_07-01_30_11_3.63.9_backupiobroker .tar.sbk': Operation not permitted chown: changing ownership of '/opt/iobroker/backups/ioBroker/iobroker_2022_06_07-23_00_10_Standard_backupiobroke r.tar.gz': Operation not permitted chown: changing ownership of '/opt/iobroker/backups/ioBroker/historyDB_2022_06_07-23_01_00_Standard_backupiobrok er.tar.gz': Operation not permitted chown: changing ownership of '/opt/iobroker/backups/ioBroker/grafana_2022_06_07-23_01_48_Standard_backupiobroker .tar.gz': Operation not permitted chown: changing ownership of '/opt/iobroker/backups/ioBroker/javascripts_2022_06_07-23_01_53_Standard_backupiobr oker.tar.gz': Operation not permitted chown: changing ownership of '/opt/iobroker/backups/ioBroker/iobroker_2022_06_08-23_00_10_Standard_backupiobroke r.tar.gz': Operation not permitted chown: changing ownership of '/opt/iobroker/backups/ioBroker/historyDB_2022_06_08-23_00_58_Standard_backupiobrok er.tar.gz': Operation not permitted chown: changing ownership of '/opt/iobroker/backups/ioBroker/grafana_2022_06_08-23_01_47_Standard_backupiobroker .tar.gz': Operation not permitted chown: changing ownership of '/opt/iobroker/backups/ioBroker/javascripts_2022_06_08-23_01_53_Standard_backupiobr oker.tar.gz': Operation not permitted chown: changing ownership of '/opt/iobroker/backups/ioBroker': Operation not permitted chown: changing ownership of '/opt/iobroker/backups/homematic_2022_06_16-01_30_11_3.63.9_backupiobroker.tar.sbk' : Operation not permitted chown: changing ownership of '/opt/iobroker/backups/homematic_2022_06_19-01_30_11_3.63.9_backupiobroker.tar.sbk' : Operation not permitted chown: changing ownership of '/opt/iobroker/backups/iobroker_2022_06_21-23_00_10_Standard_backupiobroker.tar.gz' : Operation not permitted chown: changing ownership of '/opt/iobroker/backups/historyDB_2022_06_21-23_01_01_Standard_backupiobroker.tar.gz ': Operation not permitted chown: changing ownership of '/opt/iobroker/backups/grafana_2022_06_21-23_01_51_Standard_backupiobroker.tar.gz': Operation not permitted chown: changing ownership of '/opt/iobroker/backups/javascripts_2022_06_21-23_01_57_Standard_backupiobroker.tar. gz': Operation not permitted chown: changing ownership of '/opt/iobroker/backups/homematic_2022_06_22-01_30_11_3.63.9_backupiobroker.tar.sbk' : Operation not permitted chown: changing ownership of '/opt/iobroker/backups/iobroker_2022_06_22-23_00_10_Standard_backupiobroker.tar.gz' : Operation not permitted chown: changing ownership of '/opt/iobroker/backups/historyDB_2022_06_22-23_01_02_Standard_backupiobroker.tar.gz ': Operation not permitted chown: changing ownership of '/opt/iobroker/backups/grafana_2022_06_22-23_01_53_Standard_backupiobroker.tar.gz': Operation not permitted chown: changing ownership of '/opt/iobroker/backups/javascripts_2022_06_22-23_01_58_Standard_backupiobroker.tar. gz': Operation not permitted chown: changing ownership of '/opt/iobroker/backups/iobroker_2022_06_23-23_00_10_Standard_backupiobroker.tar.gz' : Operation not permitted chown: changing ownership of '/opt/iobroker/backups/historyDB_2022_06_23-23_01_01_Standard_backupiobroker.tar.gz ': Operation not permitted chown: changing ownership of '/opt/iobroker/backups/grafana_2022_06_23-23_01_51_Standard_backupiobroker.tar.gz': Operation not permitted chown: changing ownership of '/opt/iobroker/backups/javascripts_2022_06_23-23_01_56_Standard_backupiobroker.tar. gz': Operation not permitted chown: changing ownership of '/opt/iobroker/backups': Operation not permitted This system does not support setting default permissions. Do not use npm to manually install adapters unless you know what you are doing! ========================================================================== Checking autostart (3/3) ========================================================================== Enabling autostart... Autostart enabled! ========================================================================== Your installation was fixed successfully Run iobroker start to start ioBroker again! ========================================================================== nega@ioBroker:~$ iobroker start nega@ioBroker:~$ -
@negalein sagte in [How-to] Node.js ioBroker richtig updaten-2021/22 Edition:
Das der Fixer aber nicht die persmissions fixen darf finde ich bedenklich
@apollon77 sagte in [How-to] Node.js ioBroker richtig updaten-2021/22 Edition:
soll was bedeuten, bzw. was wäre zu machen?
Nicht gleich machen und warten was die anderen sagen, aber bei mir muss ich
iobroker fixals root ausführen, also wäre es mitsudo. Was für mich Sinn macht weil nur der root alle Verzeichnisrechte auch anpassen dürfte, egal wem die gehören. Wenn es bei dir die Verzeichnisse nicht demnegaBenutzer gehören und nicht dem iobroker-Benutzer muss es halt fehlschlagen.Aber wie gesagt warte mal eben was die anderen schreiben.
Schau erstmal wie das Ding jetzt ausschaut:
getfacl /opt/iobroker/backupsIst das Verzeichnis ein Mountpunkt für eine Freigabe eines file-Servers?
@bananajoe sagte in [How-to] Node.js ioBroker richtig updaten-2021/22 Edition:
aber bei mir muss ich iobroker fix als root ausführen
Standard ist das nicht. Aber du hältst dich ja auch nicht an den Standard mit deiner root shell...
@thomas-braun sagte in [How-to] Node.js ioBroker richtig updaten-2021/22 Edition:
nega@ioBroker:~$ getfacl /opt/iobroker/backups getfacl: Removing leading '/' from absolute path names # file: opt/iobroker/backups # owner: nobody # group: nogroup user::rwx group::rwx other::rwxIst das Verzeichnis ein Mountpunkt für eine Freigabe eines file-Servers?
Ja, auf ein NAS
Ja, auf ein NAS
@negalein Ha, na da haben wir den Grund ... In dem Fall "ists dann halt so" mit allen potentiellen Issues die das produzieren kann ..."
@apollon77 Hey kann mir jemand einmal alle Befehle schicken die ich brauche um reibungslos von Node 14 auf die 16er Version zu kommen?
Und gibt es auch Befehle um alte Paket aufzuräumen auf dem PI? -
Und gibt es auch Befehle um alte Paket aufzuräumen auf dem PI?Schau in meiner Signatur.
Da wird's erklärt. -
Und gibt es auch Befehle um alte Paket aufzuräumen auf dem PI?@sushibomba Im ersten Post ist alles beschrieben ... und 14 durch 16 austauschen sollte ja kein großes Problem sein. Es macht in meinen Augen wenig Sinn jetzt hier alles nochmals zu wiederholen
@apollon77 Ok klasse. Wusste nicht das es so einfach ist. Tut mir leid für die dumme Frage. Dachte ich müsse vielleicht noch was anderes berücksichtigen.
Da wird's erklärt.@thomas-braun Meinst du den Beitrag von 2020?
@sushibomba
Den meine ich:https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian
Wird aber regelmäßig up-to-date gehalten.
@sushibomba
@thomas-braun Danke. Ok dann war ich doch richtig.
Ich möchte allerdings ungerne den zweiten dieser Befehle ausführen, weil es letztes Mal dazu geführt hat, dass ich mein Grafana nicht mehr abrufen konnte :/
Geht das auch ohne diesen Befehl? -
Geht das auch ohne diesen Befehl?@sushibomba sagte in [How-to] Node.js ioBroker richtig updaten-2021/22 Edition:
Welcher zweite Befehl?
Und nodejs hat nix mit Grafana zu tun. -
Und nodejs hat nix mit Grafana zu tun.@thomas-braun Ach sorry hatte vergessen die Zeilen einzufügen...haha
sudo apt update
sudo apt upgrade -
sudo apt update
sudo apt upgrade@sushibomba glaub das geht mit
apt-mark hold NameDesPakets -
apt-mark hold NameDesPaketsIch würde eher eine grafana Version 8 pinnen (wenn denn der Switch auf V9 verhindert werden soll).
apt-mark hold NameDesPakets@crunchip said in [How-to] Node.js ioBroker richtig updaten-2021/22 Edition:
apt-mark hold NameDesPaketsOk verstehe nur Bahnhof aber ist nicht schlimm. Ich lese mich einfach noch weiter in die Materie ein und lerne von euch :)
sudo apt-mark hold grafananagelt das Paket 'grafana' auf die derzeitig installierte Version fest.
Siehe:echad@chet:~ $ apt list --upgradable Listing... Done grafana/stable 9.0.1 arm64 [upgradable from: 8.5.6] N: There are 156 additional versions. Please use the '-a' switch to see them. echad@chet:~ $ sudo apt full-upgrade Reading package lists... Done Building dependency tree... Done Reading state information... Done Calculating upgrade... Done The following packages have been kept back: grafana 0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded. echad@chet:~ $Empfehlen würde ich das allerdings nicht, du schneidest dich damit von allen Entwicklungen und Sicherheitsupdates ab.
