  3. Cloud Dienste
  4. Cloud Adapter
    6.5k
Cloud Adapter
cloudpro
66 Beiträge 11 Kommentatoren 9.3k Aufrufe 7 Beobachtet
  • haselchenH haselchen
    cloud.0	2021-02-12 18:19:10.579	info	(3364) Adapter redirected temporally to "https://iobroker.pro:10556" in 30 seconds. Reason: command from server
    cloud.0	2021-02-12 18:19:10.552	info	(3364) Connection changed: connect
    cloud.0	2021-02-12 18:19:10.442	info	(3364) Trying to connect as system.user.admin
    cloud.0	2021-02-12 18:19:10.292	info	(3364) Connecting with https://iobroker.pro:10555 with "XXX"
    cloud.0	2021-02-12 18:19:10.172	info	(3364) starting. Version 4.0.9 in /opt/iobroker/node_modules/iobroker.cloud, node: v10.23.2, js-controller: 3.1.6
    cloud.0	2021-02-12 18:19:10.156	info	(3364) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
    host.IOBrokerSynology	2021-02-12 18:19:07.418	info	instance system.adapter.cloud.0 started with pid 3364
    host.IOBrokerSynology	2021-02-12 18:19:07.346	info	"system.adapter.cloud.0" enabled
    host.IOBrokerSynology	2021-02-12 18:18:57.614	info	Do not restart adapter system.adapter.cloud.0 because desired by instance
    host.IOBrokerSynology	2021-02-12 18:18:57.610	error	instance system.adapter.cloud.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
    cloud.0	2021-02-12 18:18:57.068	info	(3322) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    host.IOBrokerSynology	2021-02-12 18:18:57.037	info	"system.adapter.cloud.0" disabled
    cloud.0	2021-02-12 18:18:51.970	info	(3322) Restart adapter by disconnect
    cloud.0	2021-02-12 18:18:51.969	info	(3322) Connection lost
    cloud.0	2021-02-12 18:18:51.969	info	(3322) Connection changed: io client disconnect
    cloud.0	2021-02-12 18:18:51.968	error	(3322) Please buy remote access to use pro. If you did it, please wait 5 minutes.
    cloud.0	2021-02-12 18:18:51.965	warn	(3322) Adapter stopped. Reason: command from server
    host.IOBrokerSynology	2021-02-12 18:19:45.871	info	"system.adapter.cloud.0" disabled
    cloud.0	2021-02-12 18:19:40.734	info	(3364) Restart adapter by disconnect
    cloud.0	2021-02-12 18:19:40.734	info	(3364) Connection lost
    cloud.0	2021-02-12 18:19:40.733	info	(3364) Connection changed: io client disconnect
    cloud.0	2021-02-12 18:19:40.732	error	(3364) Please buy remote access to use pro. If you did it, please wait 5 minutes.
    cloud.0	2021-02-12 18:19:40.731	warn	(3364) Adapter stopped. Reason: command from server
    cloud.0	2021-02-12 18:19:40.703	info	(3364) Connection changed: connect
    cloud.0	2021-02-12 18:19:40.593	info	(3364) Trying to connect as system.user.admin
    HomoranH Offline
    HomoranH Offline
    #41
    @haselchen sagte in Cloud Adapter:
    bis dahin ist alles ok!
    dann kommt nach dem redirect ein neuer Anmeldeversuch mit einem anderen Port
      HomoranH Offline
      HomoranH Offline
      #42
      ok, dann läuft es bei dir theoretisch mit pro, du darfst aber nicht ;-)
        @homoran @haselchen
        Bei mir werden auch andere Ports genutzt. Und ein redirect wird durchgeführt:
        2021-02-12 18:16:13.994  - info: cloud.0 (32766) starting. Version 4.0.9 in /opt/iobroker/node_modules/iobroker.cloud, node: v14.15.5, js-controller: 3.2.16
        2021-02-12 18:16:14.068  - info: cloud.0 (32766) Connecting with https://iobroker.net:10555 with "XXX"
        2021-02-12 18:16:14.233  - info: cloud.0 (32766) Trying to connect as system.user.admin
        2021-02-12 18:16:14.404  - info: cloud.0 (32766) Adapter redirected temporally to "https://iobroker.net:10556" in one minute. Reason: command from server
        2021-02-12 18:17:14.416  - info: cloud.0 (32766) Trying to connect as system.user.admin
        haselchenH Offline
        haselchenH Offline
        haselchen
        #43
        Das hatte ich @Homoran vorhin gefragt, weil ich seit Jahr und Tag den Port 10560 habe.
        Ich probiere mal Deinen (10555)
          HomoranH Offline
          HomoranH Offline
          #44
          Hast du doch
            Hast du doch
            haselchenH Offline
            haselchenH Offline
            haselchen
            #45
            Dieser Port wurde mit den Pro Daten benutzt, wie du es vorgeschlagen hast.
            Ich habe aber ne FreeCloud und Pro IOT Adapter.
            Ich wechsel mal wieder auf den FreeKey und den 10555 Port.
              #46
              @haselchen
              Schaut bei mir so aus:
                HomoranH Offline
                HomoranH Offline
                #47
                ich kann den gar nicht auswählen, der ist bei mir grau
                  @haselchen
                  haselchenH Offline
                  haselchenH Offline
                  haselchen
                  #48
                  Zack und leck die Ziege.
                  Mit dem Port 10555 geht es.
                  Jetzt müsst ihr mir nur verraten , wieso ich nach zig Jahren den Port ändern muss? 🤔
                    HomoranH Offline
                    HomoranH Offline
                    #49
                    und du musst mir verraten, wieso du den ändern kannst?
                    Der ist bei mir fest verdrahtet, deswegn ja der redirect
                      #50
                      @haselchen
                      Weil Server-seitig Änderungen getätigt wurden?
                        #51
                        @homoran sagte in Cloud Adapter:
                        Also ich kann den auch ändern.
                          @haselchen
                          haselchenH Offline
                          haselchenH Offline
                          haselchen
                          #52
                          Dann wären wir wieder beim Thema -> Kommunikation.
                          Ohne euch beiden, wäre ich jetzt nicht drauf gekommen den Port zu wechseln.
                          @Homoran
                          Bei mir macht er ein redirect zu 10556.
                            @Homoran
                            HomoranH Offline
                            HomoranH Offline
                            #53
                            genau!
                            Das ist die Änderung. aber die stört nicht, wenn du bisher auf 10555 gewesen bist/wärst:
                              genau!
                              haselchenH Offline
                              haselchenH Offline
                              haselchen
                              #54
                              @Thomas-Braun
                              Tja, vielleicht hilft es dem Einen oder Anderen.
                              Ein Portwechsel ist die Lösung.
                              10560 funktioniert aktuell nicht mehr.
                              Wechsel auf 10555 oder 10556 bringt wieder eine Verbindung.
                              Wenn ich ein wenig angefasst war tut mir das Leid.
                              Ist halt ärgerlich wenn das diesmal wirklich aus dem Nichts passiert.
                              Ich hab Euch trotzdem lieb und ihr mich hoffentlich auch :)
                              Danke für Eure Unterstützung in der Sache hier!!
                                @Homoran
                                #55
                                @haselchen
                                nodeJS kannst du auch mal auf was aktuelles bringen. 10 ist bald raus:
                                Release	End-of-life
                                v10	2021-04-30
                                  @haselchen
                                  Release	End-of-life
                                  v10	2021-04-30
                                  haselchenH Offline
                                  haselchenH Offline
                                  haselchen
                                  #56
                                  Ja, ich mach mich gerade ans Updaten :)
                                    Ja das ärgert mich gewaltig.
                                    Dann kann ich dir nicht mehr helfen.
                                    Vielleicht @apollon77 oder @Bluefox
                                    #57
                                    @homoran also der Apollon sagt: holla mischt ihr hier Dinge.
                                    Wendet Cloud einen websocket Fehler bringt hat das nix mit NIX Web oder socketio Adaptern zu tun.
                                    Wenn Es nicht geht wie üblich bitte GitHub issue anlegen bei Cloud. Am besten mit einem debug log.
                                    Danke.
                                      AndreasK
                                      #58
                                      ich habe auch seit neuestem, dass Cloud-Adapter sich nicht anmelden kann.
                                      Als Abo habe ich aktuell "assistant.promote3". Daher verstehe ich die Aufforderung zu "Buy remote access" nicht.
                                      Hier mal der Anmelde-Log:
                                      cloud.0	2021-02-13 12:05:17.661	info	(26497) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                      cloud.0	2021-02-13 12:05:12.596	info	(26497) Restart adapter by disconnect
                                      cloud.0	2021-02-13 12:05:12.596	info	(26497) Connection lost
                                      cloud.0	2021-02-13 12:05:12.595	info	(26497) Connection changed: io client disconnect
                                      cloud.0	2021-02-13 12:05:12.594	error	(26497) Please buy remote access to use pro. If you did it, please wait 5 minutes.
                                      cloud.0	2021-02-13 12:05:12.592	warn	(26497) Adapter stopped. Reason: command from server
                                      cloud.0	2021-02-13 12:05:12.569	info	(26497) Connection changed: connect
                                      cloud.0	2021-02-13 12:05:12.462	info	(26497) Trying to connect as system.user.admin
                                      cloud.0	2021-02-13 12:04:12.450	info	(26497) Connection lost
                                      cloud.0	2021-02-13 12:04:12.450	info	(26497) Connection changed: io client disconnect
                                      cloud.0	2021-02-13 12:04:12.447	info	(26497) Adapter redirected temporally to "https://iobroker.pro:10556" in one minute. Reason: command from server
                                      cloud.0	2021-02-13 12:04:12.425	info	(26497) Connection changed: connect
                                      cloud.0	2021-02-13 12:04:12.326	info	(26497) Trying to connect as system.user.admin
                                      cloud.0	2021-02-13 12:04:12.200	info	(26497) Connecting with https://iobroker.pro:10555 with "@pro_andreas.k............"
                                      cloud.0	2021-02-13 12:03:06.813	info	(26497) starting. Version 4.0.4 in /opt/iobroker/node_modules/iobroker.cloud, node: v14.15.4, js-controller: 3.1.6
                                      Andreas
                                      • A AndreasK
                                        Andreas
                                        #59
                                        @andreask hm .... du hast das Assistenten Paket. Das erlaubt Assistenten zugriff und mit iot. Cloud Access geht mit deinem pro key nicht. Du kannst maximal einen iobroker.net free Cloud Account nutzen für den freien Cloud Access.
                                        Also ... alles korrekt eingestellt?
                                        A 1 Antwort Letzte Antwort
                                        • apollon77A apollon77
                                          AndreasK
                                          #60
                                          @apollon77
                                          ich bin jetzt etwas verwirrt.
                                          Ich habe gedacht, das der Unterschied zwischen dem teuren "Remote" und dem günstigeren "Assistant" nur die zusätzliche Möglichkeit des Fernzugriffs ist.
                                          Alles andere sollte doch gleich sein.
                                          Das bedeutet, das ich den Cloud-Adapter für beide benötige.
                                          Ich gehe also auf iobroker.pro, App-Schlüssel und trage diesen im Cloud-Adapter ein. Über den App-Schlüssel weiß das System, welche Möglichkeiten ich habe und was freigeschaltet ist.
                                          Oder verstehe ich hier etwas falsch?
