  3. Cloud Dienste
  4. Cloud Adapter
    6.5k
Cloud Adapter
cloudpro
66 Beiträge 11 Kommentatoren 9.3k Aufrufe 7 Beobachtet
    @haselchen kannst du es bitte nochmal mit.pro versuchen?
    Dann kann ich vergleichen.
    Ich habe keinien free-Key
    @homoran @haselchen
    Bei mir werden auch andere Ports genutzt. Und ein redirect wird durchgeführt:
    2021-02-12 18:16:13.994  - info: cloud.0 (32766) starting. Version 4.0.9 in /opt/iobroker/node_modules/iobroker.cloud, node: v14.15.5, js-controller: 3.2.16
    2021-02-12 18:16:14.068  - info: cloud.0 (32766) Connecting with https://iobroker.net:10555 with "XXX"
    2021-02-12 18:16:14.233  - info: cloud.0 (32766) Trying to connect as system.user.admin
    2021-02-12 18:16:14.404  - info: cloud.0 (32766) Adapter redirected temporally to "https://iobroker.net:10556" in one minute. Reason: command from server
    2021-02-12 18:17:14.416  - info: cloud.0 (32766) Trying to connect as system.user.admin
    • haselchenH haselchen
      cloud.0	2021-02-12 18:19:10.579	info	(3364) Adapter redirected temporally to "https://iobroker.pro:10556" in 30 seconds. Reason: command from server
      cloud.0	2021-02-12 18:19:10.552	info	(3364) Connection changed: connect
      cloud.0	2021-02-12 18:19:10.442	info	(3364) Trying to connect as system.user.admin
      cloud.0	2021-02-12 18:19:10.292	info	(3364) Connecting with https://iobroker.pro:10555 with "XXX"
      cloud.0	2021-02-12 18:19:10.172	info	(3364) starting. Version 4.0.9 in /opt/iobroker/node_modules/iobroker.cloud, node: v10.23.2, js-controller: 3.1.6
      cloud.0	2021-02-12 18:19:10.156	info	(3364) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
      host.IOBrokerSynology	2021-02-12 18:19:07.418	info	instance system.adapter.cloud.0 started with pid 3364
      host.IOBrokerSynology	2021-02-12 18:19:07.346	info	"system.adapter.cloud.0" enabled
      host.IOBrokerSynology	2021-02-12 18:18:57.614	info	Do not restart adapter system.adapter.cloud.0 because desired by instance
      host.IOBrokerSynology	2021-02-12 18:18:57.610	error	instance system.adapter.cloud.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
      cloud.0	2021-02-12 18:18:57.068	info	(3322) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      host.IOBrokerSynology	2021-02-12 18:18:57.037	info	"system.adapter.cloud.0" disabled
      cloud.0	2021-02-12 18:18:51.970	info	(3322) Restart adapter by disconnect
      cloud.0	2021-02-12 18:18:51.969	info	(3322) Connection lost
      cloud.0	2021-02-12 18:18:51.969	info	(3322) Connection changed: io client disconnect
      cloud.0	2021-02-12 18:18:51.968	error	(3322) Please buy remote access to use pro. If you did it, please wait 5 minutes.
      cloud.0	2021-02-12 18:18:51.965	warn	(3322) Adapter stopped. Reason: command from server
      host.IOBrokerSynology	2021-02-12 18:19:45.871	info	"system.adapter.cloud.0" disabled
      cloud.0	2021-02-12 18:19:40.734	info	(3364) Restart adapter by disconnect
      cloud.0	2021-02-12 18:19:40.734	info	(3364) Connection lost
      cloud.0	2021-02-12 18:19:40.733	info	(3364) Connection changed: io client disconnect
      cloud.0	2021-02-12 18:19:40.732	error	(3364) Please buy remote access to use pro. If you did it, please wait 5 minutes.
      cloud.0	2021-02-12 18:19:40.731	warn	(3364) Adapter stopped. Reason: command from server
      cloud.0	2021-02-12 18:19:40.703	info	(3364) Connection changed: connect
      cloud.0	2021-02-12 18:19:40.593	info	(3364) Trying to connect as system.user.admin
      HomoranH Offline
      HomoranH Offline
      @haselchen sagte in Cloud Adapter:
      bis dahin ist alles ok!
      dann kommt nach dem redirect ein neuer Anmeldeversuch mit einem anderen Port
        HomoranH Offline
        HomoranH Offline
        ok, dann läuft es bei dir theoretisch mit pro, du darfst aber nicht ;-)
          @homoran @haselchen
          haselchenH Offline
          haselchenH Offline
          haselchen
          Das hatte ich @Homoran vorhin gefragt, weil ich seit Jahr und Tag den Port 10560 habe.
          Ich probiere mal Deinen (10555)
            HomoranH Offline
            HomoranH Offline
            Hast du doch
              Hast du doch
              haselchenH Offline
              haselchenH Offline
              haselchen
              Dieser Port wurde mit den Pro Daten benutzt, wie du es vorgeschlagen hast.
              Ich habe aber ne FreeCloud und Pro IOT Adapter.
              Ich wechsel mal wieder auf den FreeKey und den 10555 Port.
                @haselchen
                Schaut bei mir so aus:
                  HomoranH Offline
                  HomoranH Offline
                  ich kann den gar nicht auswählen, der ist bei mir grau
                    @haselchen
                    haselchenH Offline
                    haselchenH Offline
                    haselchen
                    Zack und leck die Ziege.
                    Mit dem Port 10555 geht es.
                    Jetzt müsst ihr mir nur verraten , wieso ich nach zig Jahren den Port ändern muss? 🤔
                      HomoranH Offline
                      HomoranH Offline
                      und du musst mir verraten, wieso du den ändern kannst?
                      Der ist bei mir fest verdrahtet, deswegn ja der redirect
                        @haselchen
                        Weil Server-seitig Änderungen getätigt wurden?
                          @homoran sagte in Cloud Adapter:
                          Also ich kann den auch ändern.
                            @haselchen
                            haselchenH Offline
                            haselchenH Offline
                            haselchen
                            Dann wären wir wieder beim Thema -> Kommunikation.
                            Ohne euch beiden, wäre ich jetzt nicht drauf gekommen den Port zu wechseln.
                            @Homoran
                            Bei mir macht er ein redirect zu 10556.
                              @Homoran
                              HomoranH Offline
                              HomoranH Offline
                              genau!
                              Das ist die Änderung. aber die stört nicht, wenn du bisher auf 10555 gewesen bist/wärst:
                                genau!
                                haselchenH Offline
                                haselchenH Offline
                                haselchen
                                @Thomas-Braun
                                Tja, vielleicht hilft es dem Einen oder Anderen.
                                Ein Portwechsel ist die Lösung.
                                10560 funktioniert aktuell nicht mehr.
                                Wechsel auf 10555 oder 10556 bringt wieder eine Verbindung.
                                Wenn ich ein wenig angefasst war tut mir das Leid.
                                Ist halt ärgerlich wenn das diesmal wirklich aus dem Nichts passiert.
                                Ich hab Euch trotzdem lieb und ihr mich hoffentlich auch :)
                                Danke für Eure Unterstützung in der Sache hier!!
                                  @Homoran
                                  @haselchen
                                  nodeJS kannst du auch mal auf was aktuelles bringen. 10 ist bald raus:
                                  Release	End-of-life
                                  v10	2021-04-30
                                    @haselchen
                                    Release	End-of-life
                                    v10	2021-04-30
                                    haselchenH Offline
                                    haselchenH Offline
                                    haselchen
                                    Ja, ich mach mich gerade ans Updaten :)
                                      Ja das ärgert mich gewaltig.
                                      Dann kann ich dir nicht mehr helfen.
                                      Vielleicht @apollon77 oder @Bluefox
                                      @homoran also der Apollon sagt: holla mischt ihr hier Dinge.
                                      Wendet Cloud einen websocket Fehler bringt hat das nix mit NIX Web oder socketio Adaptern zu tun.
                                      Wenn Es nicht geht wie üblich bitte GitHub issue anlegen bei Cloud. Am besten mit einem debug log.
                                      Danke.
                                        AndreasK
                                        ich habe auch seit neuestem, dass Cloud-Adapter sich nicht anmelden kann.
                                        Als Abo habe ich aktuell "assistant.promote3". Daher verstehe ich die Aufforderung zu "Buy remote access" nicht.
                                        Hier mal der Anmelde-Log:
                                        cloud.0	2021-02-13 12:05:17.661	info	(26497) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                        cloud.0	2021-02-13 12:05:12.596	info	(26497) Restart adapter by disconnect
                                        cloud.0	2021-02-13 12:05:12.596	info	(26497) Connection lost
                                        cloud.0	2021-02-13 12:05:12.595	info	(26497) Connection changed: io client disconnect
                                        cloud.0	2021-02-13 12:05:12.594	error	(26497) Please buy remote access to use pro. If you did it, please wait 5 minutes.
                                        cloud.0	2021-02-13 12:05:12.592	warn	(26497) Adapter stopped. Reason: command from server
                                        cloud.0	2021-02-13 12:05:12.569	info	(26497) Connection changed: connect
                                        cloud.0	2021-02-13 12:05:12.462	info	(26497) Trying to connect as system.user.admin
                                        cloud.0	2021-02-13 12:04:12.450	info	(26497) Connection lost
                                        cloud.0	2021-02-13 12:04:12.450	info	(26497) Connection changed: io client disconnect
                                        cloud.0	2021-02-13 12:04:12.447	info	(26497) Adapter redirected temporally to "https://iobroker.pro:10556" in one minute. Reason: command from server
                                        cloud.0	2021-02-13 12:04:12.425	info	(26497) Connection changed: connect
                                        cloud.0	2021-02-13 12:04:12.326	info	(26497) Trying to connect as system.user.admin
                                        cloud.0	2021-02-13 12:04:12.200	info	(26497) Connecting with https://iobroker.pro:10555 with "@pro_andreas.k............"
                                        cloud.0	2021-02-13 12:03:06.813	info	(26497) starting. Version 4.0.4 in /opt/iobroker/node_modules/iobroker.cloud, node: v14.15.4, js-controller: 3.1.6
                                        Andreas
                                        • A AndreasK
                                          Andreas
                                          @andreask hm .... du hast das Assistenten Paket. Das erlaubt Assistenten zugriff und mit iot. Cloud Access geht mit deinem pro key nicht. Du kannst maximal einen iobroker.net free Cloud Account nutzen für den freien Cloud Access.
                                          Also ... alles korrekt eingestellt?
