  4. Beta Test js-controller 3.2.x auf GitHub
    apollon77A
js-controller
287 Beiträge 25 Kommentatoren 89.3k Aufrufe 29 Beobachtet
  • L lonsimbt
    @apollon77
    Pushsafer will immer noch nicht (s. meinen Post oben) . Ansonsten ist bislang alles unauffällig.
    Gruß Marco
    coyoteC
    coyoteC
    coyote
    schrieb am zuletzt editiert von coyote
    #161
    Gerade auch mal die letzte Version installiert. Sieht soweit gut aus.
    Muss/kann ich hier noch was machen oder ok so?
    root@debian:/opt/iobroker# npm i iobroker.js-controller@next
    npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
    npm WARN deprecated har-validator@5.1.5: this library is no longer supported
    > iobroker.js-controller@3.2.6-0 preinstall /opt/iobroker/node_modules/iobroker.js-controller
    > node lib/preinstallCheck.js
    NPM version: 6.14.10
    > iobroker.js-controller@3.2.6-0 install /opt/iobroker/node_modules/iobroker.js-controller
    > node iobroker.js setup first
    object _design/system updated
    Renamed repository "default to "stable"
    Renamed repository "latest to "beta"
    > @root/acme@3.1.0 postinstall /opt/iobroker/node_modules/@root/acme
    > node scripts/postinstall
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.1 (node_modules/chokidar/node_modules/fsevents):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.1: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@^1.0.7 (node_modules/iobroker.info/node_modules/osx-temperature-sensor):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
    npm WARN @material-ui/pickers@3.2.10 requires a peer of @material-ui/core@^4.0.0 but none is installed. You must install peer dependencies yourself.
    npm WARN @material-ui/pickers@3.2.10 requires a peer of react@^16.8.4 but none is installed. You must install peer dependencies yourself.
    npm WARN @material-ui/pickers@3.2.10 requires a peer of react-dom@^16.8.4 but none is installed. You must install peer dependencies yourself.
    npm WARN react-transition-group@4.4.1 requires a peer of react@>=16.6.0 but none is installed. You must install peer dependencies yourself.
    npm WARN react-transition-group@4.4.1 requires a peer of react-dom@>=16.6.0 but none is installed. You must install peer dependencies yourself.
    npm WARN rifm@0.7.0 requires a peer of react@>=16.8 but none is installed. You must install peer dependencies yourself.
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@0.1.4 (node_modules/xpc-connection):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
    + iobroker.js-controller@3.2.6-0
    added 38 packages from 10 contributors, removed 29 packages, updated 44 packages and moved 1 package in 84.186s
    46 packages are looking for funding
      run `npm fund` for details
    • J Jan1
      @apollon77
      Kann alle 3 Versionen nicht einzeln installieren. Beim Klick auf das Update Symbol passiert einfach nichts.
      Einzig das gesamt Update oben über das Fähnchen klappt.
      apollon77A
      apollon77A
      #162
      @jan1 denke geht nach Admin update :-) das ggf per cli
      lobomauL 1 Antwort Letzte Antwort
      • L lonsimbt
        @apollon77
        Gruß Marco
        apollon77A
        apollon77A
        #163
        @lonsimbt Auch nicht mit der Verison vom github?? zeig mal log von der
        • coyoteC coyote
          apollon77A
          apollon77A
          #164
          @coyote nee, alles ok
          • apollon77A apollon77
            lobomauL
            lobomauL
            lobomau
            schrieb am zuletzt editiert von lobomau
            #165
            Edit: erledigt... upgrade... nicht update und ohne 0 :-)
            also:
            iobroker upgrade admin
            @apollon77 said in Beta Test js-controller 3.2.x auf GitHub:
            wie war hier der genaue Befehl?
            iobroker update admin.0
            ist es nicht ;-)
            Anonsten kann ich keinen Adapter updaten über die GUI vom Admin.
            Host: NUC8i3 mit Proxmox:
            • Slave: Pi4
            • lobomauL lobomau
              also:
              ist es nicht ;-)
              lobomauL
              lobomauL
              lobomau
              #166
              @apollon77 ich kann keine Updates machen... auch nicht mit Admin 4.2.1.
              • Slave: Pi4
              • lobomauL lobomau
                apollon77A
                apollon77A
                #167
                @lobomau Zeig doch mal was in dem mouse over steht über dem update button :-) So schnell kann ich nicht lesen
                  lobomauL
                  lobomauL
                  lobomau
                  #168
                  @apollon77 aaahh... ich habe da gar nicht drauf geachtet, dass da was steht :-)
                  Wurde ja schon vorher hier geschrieben wie ich sehe:
                  Das ist ja das Problem mit der "komischen" Version.
                  • Slave: Pi4
                  apollon77A 2 Antworten Letzte Antwort
                  • lobomauL lobomau
                    apollon77A
                    apollon77A
                    #169
                    @lobomau Auch mal wirklich shift reload und so das wirklich das neueste JS im browser ist?
                      L
                      L
                      lonsimbt
                      #170
                      @apollon77
                      Sorry man sollte erst das Hirn einschalten...
                      Mit der pushsafer-Version vom github funktioniert wieder alles. Keine Fehler mehr im Log, Push-Nachrichten werden zugestellt.
                      Gruß Marco
                      iobroker im Container (debian Bullseye) unter proxmox 7.1
                      debmatic in VM (debian Buster) unter proxmox 7.1 mit HB-RF-USB und RPI-RF-MOD
                      40 HomeMatic Geräte, Phillips Hue, Ikea Tradfri, Logitech Harmony Hub, Botvac Connected, Robonect
                      • lobomauL lobomau
                        apollon77A
                        apollon77A
                        #171
                        @lobomau Hey, ja habe Grund gefunden ... wir schauen mal .. Wie gesagt aktuell gehen updates per Kommandozeile :-(
                        lobomauL 2 Antworten Letzte Antwort
                          Gibt nachher folgendes:
                          • admin 4.2.1
                          • socketip 3.1.3
                          • web 3.2.3
                          FeuersturmF
                          FeuersturmF
                          Feuersturm
                          #172
                          • admin 4.2.1
                          • socketip 3.1.3
                          • web 3.2.3
                          Adapter konnten regulär über die Adminoberfläche eingespielt werden. Bisher keine Auffälligkeiten.
                            lobomauL
                            lobomauL
                            lobomau
                            #173
                            sehr schön. Habe erstmal alles über Kommandozeile geupdatet.
                            • Slave: Pi4
                            O 1 Antwort Letzte Antwort
                            • lobomauL lobomau
                              O
                              O
                              oFbEQnpoLKKl6mbY5e13
                              #174
                              Abgesehen von den
                              has no existing object, this might lead to an error in future versions
                              Meldungen der Adapter alexa2 (Fehler bereits gefunden) und sonos (issue erstellt) läuft der neue JS-Controller bisher einwandfrei.
                                lobomauL
                                lobomauL
                                lobomau
                                #175
                                @apollon77 muss ich wenn ich auf js-controller 3.1.6 zurückgehe auch den admin downgraden?
                                3.1.6 läuft bereit, aber meine Admin Probleme bleiben bestehen.
                                • Slave: Pi4
                                J apollon77A 2 Antworten Letzte Antwort
                                • lobomauL lobomau
                                  J
                                  J
                                  Jan1
                                  #176
                                  @lobomau
                                  Nein, wobei Admin 3.1.6? Ist das der aktuelle aus dem default REPO? Ist ja welten hinter dem aktuellen aus beta.
                                  • J Jan1
                                    @lobomau
                                    lobomauL
                                    lobomauL
                                    lobomau
                                    #177
                                    @jan1 nee, admin ist gerade 4.2.1.
                                    JS ist 3.1.6.
                                    • Slave: Pi4
                                    J 1 Antwort Letzte Antwort
                                    • lobomauL lobomau
                                      JS ist 3.1.6.
                                      J
                                      J
                                      Jan1
                                      #178
                                      @lobomau
                                      Ok, ist noch früh ;)
                                      Den JS brauchst aber auuch nicht downgraden, da der läuft, außer die Unschönheit mit dem Adapter Update. Das kannst aber sehr einfach mit Klick oben auf das Fähnchen übergehen.
                                      • J Jan1
                                        @lobomau
                                        lobomauL
                                        lobomauL
                                        lobomau
                                        #179
                                        @jan1 mein System scheint da speziell (Proxmox Debian 10 Container). Da ging einiges nicht mehr (Adapter wurden nicht angezeigt, Updates der Adapter nicht möglich, einige Abstürze über Nacht (RAM und CPU bis 100%...). Ich habe einige Adapter ausgestellt und gestern sogar ein ganz frisches System erstellt.
                                        Nun bin ich wieder auf ein Backup vom 4. Januar.
                                        Bei Gegebenheit versuche ich es mal mit einem Testsystem wieder nachzustellen. Leider bin ich mit meiner 120 GB SSD auch etwas begrenzt für weitere Testcontainer.
                                        • Slave: Pi4
                                        • lobomauL lobomau
                                          J
                                          J
                                          Jan1
                                          #180
                                          @lobomau
                                          Der Grund warum ich mir Proxmox nie antun würde. Die meisten Probleme die ich im Forum lese sind irgendwelche nicht native Aufbauten ;)
                                          84.0k
                                          1.4m
