  4. Test Adapter tvprogram
    6.0k
adaptertvprogramviswidget
929 Beiträge 51 Kommentatoren 333.3k Aufrufe 51 Beobachtet
  • C claus1993
    @oliverio
    Habe alles durchlaufen leide ohne Erfolg. Auf der Console auch keinen Fehler gefunden was den TV Adapter betrifft.
    Anbei mal die Meldungen aus der Console, vielleicht siehst du etwas das verkehrt ist.
    Version vis-map: 1.0.3
    index.html:12624 Uncaught TypeError: vis.addFont is not a function
        at index.html:12624
    (anonymous) @ index.html:12624
    material.js:29 Version material: 0.1.3
    DevTools failed to load SourceMap: Could not load content for http://192.168.178.11:8082/lib/js/socket.io.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
    index.html:14575 Metro version: "1.1.2"
    lib.min.js:22 Download the Vue Devtools extension for a better development experience:
    https://github.com/vuejs/vue-devtools
    lib.min.js:22 You are running Vue in development mode.
    Make sure to turn on production mode when deploying for production.
    See more tips at https://vuejs.org/guide/deployment.html
    mytime.js:22 Version mytime: 0.0.1
    openligadb.js:27 Version openligadb: 0.5.0
    players.js:55 Version players: 0.1.0
    index.html:16347 Version vis-plumb: 1.0.0
    DevTools failed to load SourceMap: Could not load content for http://192.168.178.11:8082/vis/widgets/material-webfont/css/materialdesignicons.css.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
    trashschedule.js:47 Version trashschedule: 0.0.10
    tvprogram.js:36 Version tvprogram: 0.0.1
    vis-material-advanced.js:174 Version vis-material-advanced: 0.6.5
    index.html:24700 Version vis-weather: 2.4.1
    jquery-1.11.2.min.js:4 GET http://192.168.178.11:8082/vis/adapter/mytime/words.js 404 (Not Found)
    send @ jquery-1.11.2.min.js:4
    ajax @ jquery-1.11.2.min.js:4
    m.<computed> @ jquery-1.11.2.min.js:4
    (anonymous) @ mytime.js:11
    conn.js:273 2021-02-13T15:00:33.908Z Connected => authenticate
    conn.js:293 2021-02-13T15:00:34.047Z Authenticated: true
    materialdesign.js:33 Version vis-materialdesign: 0.3.19
    VM346:1 Uncaught SyntaxError: Unexpected end of input
        at Object.<anonymous> (vis.js:3420)
        at vis.js:1960
        at conn.js:530
    (anonymous) @ vis.js:3420
    (anonymous) @ vis.js:1960
    (anonymous) @ conn.js:530
    setTimeout (async)
    (anonymous) @ conn.js:529
    r.onack @ index.js:83
    r.onpacket @ index.js:83
    (anonymous) @ index.js:83
    r.emit @ index.js:83
    r.ondecoded @ index.js:83
    a.add @ index.js:83
    r.ondata @ index.js:83
    r.onPacket @ index.js:83
    r.onData @ index.js:83
    ws.onmessage @ index.js:83
    instrument.ts:129 sentry initialized for vis-materialdesign
    instrument.ts:129
    OliverIOO Offline
    OliverIOO Offline
    OliverIO
    #621
    @claus1993 sagte in Test Adapter tvprogram:
    @oliverio
        at index.html:12624
        at vis.js:1960
        at conn.js:530
    setTimeout (async)
    a.add @ index.js:83
    instrument.ts:129
    hm, da sehe ich keine Fehler, die von tvprorgam verursacht werden.
    Was definitiv zum Abbruch führt ist dieser hier:
        at vis.js:1960
        at conn.js:530
    Ich weiß jetzt nicht welche vis-version du hast. Bei mir wird an dieser Zeile ein script, welches geladen wird in das HTML hinzugefügt.
    tvprogram ist es nicht, das wurde bereits in zeile 19 deines Protokolls erfolgreich geladen
    theoretisch müsste der gleiche Fehler auch drin stehen, wenn du alle tvprogram widgets entfernst.
    Kannst du mal den script-Reiter von vis kontrollieren oder mal leeren.
    Eine Vermutung ist, das da fehlerhaftes javascript enthalten ist.
    Ein weiterer seltsamer Fehler ist auch
        at index.html:12624
    Der ist aber unkritisch, da er nicht zum kompletten Abbruch führt. Sollte aber auch nicht sein.
    Meine Adapter und Widgets
    Links im Profil
    C OliverIOO 2 Antworten Letzte Antwort
    • OliverIOO OliverIO
      @oliverio
          at index.html:12624
          at vis.js:1960
          at conn.js:530
      setTimeout (async)
      a.add @ index.js:83
      instrument.ts:129
          at vis.js:1960
          at conn.js:530
          at index.html:12624
      claus1993
      #622
      @oliverio
      Habe den Eintrag im Vis-Script entfernt und zumindest eine Meldung weniger. Dennoch werden immer noch keine Daten für das TV Widget geladen. Das TV Widget ist aber nicht die Quelle des Übels, nach dem löschen waren die Meldungen, wie du bereits geschrieben hast, immer noch da. Jetzt heißt es auf die Fehlersuche gehen.
      Solltest du noch einen Tipp haben ist dieser gerne gesehen :-)
      Danke dir!
        @oliverio
            at index.html:12624
            at vis.js:1960
            at conn.js:530
        setTimeout (async)
        a.add @ index.js:83
        instrument.ts:129
            at vis.js:1960
            at conn.js:530
            at index.html:12624
        OliverIOO Offline
        OliverIOO Offline
        OliverIO
        #623
            at index.html:12624
        Such mal nochmal nach diesem Fehler in der console und schau mal was in dieser Zeilennummern in der Index.html steht. Evtl kann sich mittlerweile die zeilennummer geändert haben.
        Wenn du da ein paar Zeilen davor oder danach schaust könntest du sehen was das genau betrifft. Ich vermute es ist ein Adapter, dessen Skripte an dieser Stelle eingefügt werden die fehlerhaft sind
        Links im Profil
              at index.html:12624
          OliverIOO Offline
          OliverIOO Offline
          OliverIO
          #624
          Neue Version 0.0.30
          • Das search widget wurde angepasst.
            Es enthält nur noch ein reines Datumsfeld, welches durch die meisten Browser auch als solches erkannt wird.
            Dieses ist mit dem aktuellen Datum vorbelegt.
            Suche startet, wenn es der gleiche Tag ist um die aktuelle Zeit.
            Wenn es ein anderer Tag ist, um 00:00 Uhr.
            Das Search widget hat nun ein Attribut maxresults erhalten, um die Menge der Daten, die zu übertragen sind zu begrenzen.
            Es erfolgt keine Suche, wenn das Textfeld UND die Kategorienauswahl leer ist.
          • Im control-widget wurde ein weiteres Attribut time eingeführt um das widget etwas flexibler einsetzen zu können. Es gibt nun 3 Möglichkeiten:
            1. time bleibt leer
              Sendungen zur aktuellen Uhrzeit wird angezeigt und auch immer aktualisiert.
            1. time wird mit Uhrzeit im 24h-Format belegt, bspw 20:15:
              Es werden die Sendungen die zu dieser Uhrzeit laufen angezeigt.
              Ist die aktuelle Uhrzeit nach dieser Zeit, werden die Sendungen des nächsten Tages zu dieser Uhrzeit angezeigt. auch hier erfolgt automatisch die Aktualisierung.
            2. time wird mit einem validen Datumsausdruck belegt
              bspw. 2021-02-15T19:15:00.000Z (Achtung Zeitzonen beachten)
              valide bedeutet, wenn der folgende javascript-Ausdruck ein gültiges Datumsobjekt zurückgibt:
              new Date("2021-02-15T19:15:00.000Z")
              siehe auch https://developer.mozilla.org/de/docs/Web/JavaScript/Reference/Global_Objects/Date
              Es werden die Sendungen genau zu diesem Zeitpunkt laufen angezeigt. So können wechselnde Zeiten, die in einen Datenpunkt geschrieben und über Bindung in diesem Feld gesetzt werden, realisiert werden. Ich warne allerdings davor, dieses Feld sekündlich zu ändern, das dürfte den Netzwerkverkehr, vis und iobroker über Gebühr belasten. Minütlich müsste reichen, wenn nicht gar erst auf Knopfdruck oder in größere Zeitabstände.
          Links im Profil
          ? 1 Antwort Letzte Antwort
            Neue Version 0.0.30
              1. time bleibt leer
            #625
            @oliverio klasse Update :-)
            Weiß nicht ob das ein Bug oder so gewollt ist: Wenn man eine Uhrzeit vorgibt, z.b. halt 20:15, kann man sich die Sendungen durch anklicken nicht mehr anzeigen lassen. Lässt man das time leer, funktioniert es anschließend wie es sein sollte.
              OliverIOO Offline
              OliverIOO Offline
              OliverIO
              #626
              @ash2k said in Test Adapter tvprogram:
              Das ist ein bug
              Links im Profil
              KnallochseK OliverIOO 2 Antworten Letzte Antwort
                Das ist ein bug
                KnallochseK Offline
                KnallochseK Offline
                Knallochse
                #627
                @oliverio Zum Suche-Widget kann ich schon mal sagen, dass es unter Windows, Android und IOS funktioniert (sowohl die Datumseingabe als auch die Suche im allgemeinen). Vielen Dank 😊
                HM&HMIP über 100 Geräte + IoBroker auf DS918+ uvm.
                  Das ist ein bug
                  OliverIOO Offline
                  OliverIOO Offline
                  OliverIO
                  #628
                  Neue Version 0.0.31
                  • Der Fehler mit der Anzeige der Details, wenn eine Uhrzeit eingetragen ist, wurde behoben.
                  @oliverio said in Test Adapter tvprogram:
                  Das ist ein bug
                  Links im Profil
                    Neue Version 0.0.31
                    Das ist ein bug
                    MCU
                    #629
                    @oliverio Ist mir gerade aufgefallen:
                    Auswahl vom 11.02.2021 12:00 bis 12.02.2021 00:00
                    Anzeige: 11.11.2021 ?
                    Auch mit anderen Einstellungen:
                    • M MCU
                      KnallochseK Offline
                      KnallochseK Offline
                      Knallochse
                      schrieb am zuletzt editiert von Knallochse
                      #630
                      @mcu das Feld Till:
                      gibt es seit der Version 0.0.30 nicht mehr. Musst bestimmt einen Upload durchführen.
                        MCU
                        #631
                        @knallochse
                        pi@raspberrypi:/opt/iobroker $ iobroker upload tvprogram
                        upload [20] tvprogram.admin /opt/iobroker/node_modules/iobroker.tvprogram/admin/style.css style.css text/css
                        upload [19] tvprogram.admin /opt/iobroker/node_modules/iobroker.tvprogram/admin/src/index.jsx src/index.jsx text/jsx
                        upload [18] tvprogram.admin /opt/iobroker/node_modules/iobroker.tvprogram/admin/src/i18n/zh-cn.json src/i18n/zh-cn.json application/json
                        upload [17] tvprogram.admin /opt/iobroker/node_modules/iobroker.tvprogram/admin/src/i18n/ru.json src/i18n/ru.json application/json
                        upload [16] tvprogram.admin /opt/iobroker/node_modules/iobroker.tvprogram/admin/src/i18n/pt.json src/i18n/pt.json application/json
                        upload [15] tvprogram.admin /opt/iobroker/node_modules/iobroker.tvprogram/admin/src/i18n/pl.json src/i18n/pl.json application/json
                        upload [14] tvprogram.admin /opt/iobroker/node_modules/iobroker.tvprogram/admin/src/i18n/nl.json src/i18n/nl.json application/json
                        upload [13] tvprogram.admin /opt/iobroker/node_modules/iobroker.tvprogram/admin/src/i18n/it.json src/i18n/it.json application/json
                        upload [12] tvprogram.admin /opt/iobroker/node_modules/iobroker.tvprogram/admin/src/i18n/i18n.d.ts src/i18n/i18n.d.ts video/mp2t
                        upload [11] tvprogram.admin /opt/iobroker/node_modules/iobroker.tvprogram/admin/src/i18n/fr.json src/i18n/fr.json application/json
                        upload [10] tvprogram.admin /opt/iobroker/node_modules/iobroker.tvprogram/admin/src/i18n/es.json src/i18n/es.json application/json
                        upload [9] tvprogram.admin /opt/iobroker/node_modules/iobroker.tvprogram/admin/src/i18n/en.json src/i18n/en.json application/json
                        upload [8] tvprogram.admin /opt/iobroker/node_modules/iobroker.tvprogram/admin/src/i18n/de.json src/i18n/de.json application/json
                        upload [7] tvprogram.admin /opt/iobroker/node_modules/iobroker.tvprogram/admin/src/components/settingslist.jsx src/components/settingslist.jsx text/jsx
                        upload [6] tvprogram.admin /opt/iobroker/node_modules/iobroker.tvprogram/admin/src/components/settings.jsx src/components/settings.jsx text/jsx
                        upload [5] tvprogram.admin /opt/iobroker/node_modules/iobroker.tvprogram/admin/src/app.jsx src/app.jsx text/jsx
                        upload [4] tvprogram.admin /opt/iobroker/node_modules/iobroker.tvprogram/admin/index_m.html index_m.html text/html
                        upload [3] tvprogram.admin /opt/iobroker/node_modules/iobroker.tvprogram/admin/build/index.js.map build/index.js.map application/json
                        upload [2] tvprogram.admin /opt/iobroker/node_modules/iobroker.tvprogram/admin/build/index.js build/index.js application/javascript
                        upload [1] tvprogram.admin /opt/iobroker/node_modules/iobroker.tvprogram/admin/build/index.css.map build/index.css.map application/json
                        upload [0] tvprogram.admin /opt/iobroker/node_modules/iobroker.tvprogram/admin/build/index.css build/index.css text/css
                        Adapter "system.adapter.vis.0" restarted.
                        • M MCU
                          OliverIOO Offline
                          OliverIOO Offline
                          OliverIO
                          #632
                          @mcu said in Test Adapter tvprogram:
                          b
                          ne der Fehler war echt auch in der aktuellen Version.
                          da sieht man, das genau eine Klammer an der falschen Stelle, so etwas verursachen kann
                          Fehler habe ich gerade behoben und auf github geladen, aber ohne neue Versionsnummer
                          einfachnochmal neu runterladen
                          iobroker upload tvprogram oder
                          iobroker upload all
                          musst trotzdem durchführen
                          Links im Profil
                            b
                            iobroker upload all
                            MCU
                            #633
                            @oliverio Ja funktioniert. Super. Danke.
                            Kleinigkeit noch: Farbe hinter den Logos ist dort noch grau, einheitlich weiß wäre schöner. Hast du ja auch beim Control geändert.
                            • M MCU
                              OliverIOO Offline
                              OliverIOO Offline
                              OliverIO
                              #634
                              Ich gebe selbst keine Farben vor, allerdings setze ich die Hintergrundfarbe des widgets, bzw. was weiter oben im HTML-Hierarchiebaum als Hintergrundfarbe gefunden wird.
                              ich schau mal ob ich bei search noch etwas anderes mache wie bei control
                              Edit: Hab grade nachgeschaut. Bei channel setze ich die Hintergrundfarbe. prüfe mal deine Widgeteinstellung, bo die gleich ist wie bei control
                              Links im Profil
                                MCU
                                #635
                                @oliverio Ja , das war es. Prima. Danke.
                                • OliverIOO Offline
                                  OliverIOO Offline
                                  OliverIO
                                  #636
                                  und was machen wir nun?
                                  Fehlt noch was?
                                  Weitere Ideen`?
                                  Links im Profil
                                  ChaotC O 2 Antworten Letzte Antwort
                                    Fehlt noch was?
                                    Weitere Ideen`?
                                    ChaotC Offline
                                    ChaotC Offline
                                    Chaot
                                    #637
                                    @oliverio Waschmaschine vom Nachbarn deaktivieren wenn die Lieblingssendung läuft? 😀
                                    Ne, ernsthaft: Alles läuft schön rund und ich kann bisher auch keine Fehler finden. Die Funktionen sind umfangreicher als ich ursprünglich erwartet habe. Ich verwende zwar die Aufnahmefunktion nicht, aber als Reminder ist das doch klasse aufgebaut.
                                    Der Adapter hat das Script vollwertig ersetzt 👏 👏 Gute Arbeit.
                                      McOnno
                                      schrieb am zuletzt editiert von McOnno
                                      #638
                                      Ich habe gerade auf die 0.31 upgedatet und bekomme im Control keine Anzeige in der Vis!?
                                      Im Vis-Editor sehe ich die Einträge allerdings.
                                      Hier das Bild von der VIS: Vis-Anzeige.png
                                      man sieht nur den Bereich der Favoriten, rechts ist gar nichts zu sehen...
                                      Weiterhin wäre in der Suche ein Eintrag für Formel-1 ganz gut!
                                        Fehlt noch was?
                                        Weitere Ideen`?
                                        O Offline
                                        O Offline
                                        Oli
                                        #639
                                        @oliverio
                                        ich bin vom Adapter voll begeistert, wenn du mir jetzt noch sagst, wie ich die Daten (Beginn, Ende, Beschreibung, Bild) des aktuell ausgewählten Programm, in extra Datenpunkte zum weiterverarbeiten bekomme. Bin ich wunschlos glücklich :-)
                                        Eigentlich fehlt nur noch eine zusätzliche Datenquelle, um die fehlenden TV Programme zu integrieren.
                                        Oliver
                                        • M McOnno
                                          OliverIOO Offline
                                          OliverIOO Offline
                                          OliverIO
                                          #640
                                          @mconno sagte in Test Adapter tvprogram:
                                          bitte adapter (nicht nur die instanz) einmal komplett deinstallieren,
                                          dann wieder installieren.
                                          zur sicherheit auf der console
                                          iobroker upload all
                                          eingeben
                                          bei allen widgets prüfen, ob der datenpunkt mit cmd des jeweiligen tvs am ende richtig ausgewählt wurde.
                                          falls dann immer noch nicht, dann benötige ich die fehler aus der browser console
                                          Links im Profil
