  4. Test Adapter tvprogram
adaptertvprogramviswidget
929 Beiträge 51 Kommentatoren 345.8k Aufrufe 51 Beobachtet
  • M MCU
    @oliverio Ist mir gerade aufgefallen:
    Auswahl vom 11.02.2021 12:00 bis 12.02.2021 00:00
    Anzeige: 11.11.2021 ?
    Auch mit anderen Einstellungen:
    KnallochseK Nicht stören
    Knallochse
    schrieb am zuletzt editiert von Knallochse
    #630
    @mcu das Feld Till:
    gibt es seit der Version 0.0.30 nicht mehr. Musst bestimmt einen Upload durchführen.
      MCU
      #631
      @knallochse
      pi@raspberrypi:/opt/iobroker $ iobroker upload tvprogram
      upload [20] tvprogram.admin /opt/iobroker/node_modules/iobroker.tvprogram/admin/style.css style.css text/css
      upload [19] tvprogram.admin /opt/iobroker/node_modules/iobroker.tvprogram/admin/src/index.jsx src/index.jsx text/jsx
      upload [18] tvprogram.admin /opt/iobroker/node_modules/iobroker.tvprogram/admin/src/i18n/zh-cn.json src/i18n/zh-cn.json application/json
      upload [17] tvprogram.admin /opt/iobroker/node_modules/iobroker.tvprogram/admin/src/i18n/ru.json src/i18n/ru.json application/json
      upload [16] tvprogram.admin /opt/iobroker/node_modules/iobroker.tvprogram/admin/src/i18n/pt.json src/i18n/pt.json application/json
      upload [15] tvprogram.admin /opt/iobroker/node_modules/iobroker.tvprogram/admin/src/i18n/pl.json src/i18n/pl.json application/json
      upload [14] tvprogram.admin /opt/iobroker/node_modules/iobroker.tvprogram/admin/src/i18n/nl.json src/i18n/nl.json application/json
      upload [13] tvprogram.admin /opt/iobroker/node_modules/iobroker.tvprogram/admin/src/i18n/it.json src/i18n/it.json application/json
      upload [12] tvprogram.admin /opt/iobroker/node_modules/iobroker.tvprogram/admin/src/i18n/i18n.d.ts src/i18n/i18n.d.ts video/mp2t
      upload [11] tvprogram.admin /opt/iobroker/node_modules/iobroker.tvprogram/admin/src/i18n/fr.json src/i18n/fr.json application/json
      upload [10] tvprogram.admin /opt/iobroker/node_modules/iobroker.tvprogram/admin/src/i18n/es.json src/i18n/es.json application/json
      upload [9] tvprogram.admin /opt/iobroker/node_modules/iobroker.tvprogram/admin/src/i18n/en.json src/i18n/en.json application/json
      upload [8] tvprogram.admin /opt/iobroker/node_modules/iobroker.tvprogram/admin/src/i18n/de.json src/i18n/de.json application/json
      upload [7] tvprogram.admin /opt/iobroker/node_modules/iobroker.tvprogram/admin/src/components/settingslist.jsx src/components/settingslist.jsx text/jsx
      upload [6] tvprogram.admin /opt/iobroker/node_modules/iobroker.tvprogram/admin/src/components/settings.jsx src/components/settings.jsx text/jsx
      upload [5] tvprogram.admin /opt/iobroker/node_modules/iobroker.tvprogram/admin/src/app.jsx src/app.jsx text/jsx
      upload [4] tvprogram.admin /opt/iobroker/node_modules/iobroker.tvprogram/admin/index_m.html index_m.html text/html
      upload [3] tvprogram.admin /opt/iobroker/node_modules/iobroker.tvprogram/admin/build/index.js.map build/index.js.map application/json
      upload [2] tvprogram.admin /opt/iobroker/node_modules/iobroker.tvprogram/admin/build/index.js build/index.js application/javascript
      upload [1] tvprogram.admin /opt/iobroker/node_modules/iobroker.tvprogram/admin/build/index.css.map build/index.css.map application/json
      upload [0] tvprogram.admin /opt/iobroker/node_modules/iobroker.tvprogram/admin/build/index.css build/index.css text/css
      Adapter "system.adapter.vis.0" restarted.
      • M MCU
        OliverIOO Offline
        OliverIOO Offline
        OliverIO
        #632
        @mcu said in Test Adapter tvprogram:
        b
        ne der Fehler war echt auch in der aktuellen Version.
        da sieht man, das genau eine Klammer an der falschen Stelle, so etwas verursachen kann
        Fehler habe ich gerade behoben und auf github geladen, aber ohne neue Versionsnummer
        einfachnochmal neu runterladen
        iobroker upload tvprogram oder
        iobroker upload all
        musst trotzdem durchführen
        Meine Adapter und Widgets
        Links im Profil
        • OliverIOO OliverIO
          b
          iobroker upload all
          MCU
          #633
          @oliverio Ja funktioniert. Super. Danke.
          Kleinigkeit noch: Farbe hinter den Logos ist dort noch grau, einheitlich weiß wäre schöner. Hast du ja auch beim Control geändert.
          • M MCU
            OliverIOO Offline
            OliverIOO Offline
            OliverIO
            #634
            Ich gebe selbst keine Farben vor, allerdings setze ich die Hintergrundfarbe des widgets, bzw. was weiter oben im HTML-Hierarchiebaum als Hintergrundfarbe gefunden wird.
            ich schau mal ob ich bei search noch etwas anderes mache wie bei control
            Edit: Hab grade nachgeschaut. Bei channel setze ich die Hintergrundfarbe. prüfe mal deine Widgeteinstellung, bo die gleich ist wie bei control
            Links im Profil
              MCU
              #635
              @oliverio Ja , das war es. Prima. Danke.
              • OliverIOO Offline
                OliverIOO Offline
                OliverIO
                #636
                und was machen wir nun?
                Fehlt noch was?
                Weitere Ideen`?
                Links im Profil
                ChaotC O 2 Antworten Letzte Antwort
                  Fehlt noch was?
                  Weitere Ideen`?
                  ChaotC Offline
                  ChaotC Offline
                  Chaot
                  #637
                  @oliverio Waschmaschine vom Nachbarn deaktivieren wenn die Lieblingssendung läuft? 😀
                  Ne, ernsthaft: Alles läuft schön rund und ich kann bisher auch keine Fehler finden. Die Funktionen sind umfangreicher als ich ursprünglich erwartet habe. Ich verwende zwar die Aufnahmefunktion nicht, aber als Reminder ist das doch klasse aufgebaut.
                  Der Adapter hat das Script vollwertig ersetzt 👏 👏 Gute Arbeit.
                    McOnno
                    schrieb am zuletzt editiert von McOnno
                    #638
                    Ich habe gerade auf die 0.31 upgedatet und bekomme im Control keine Anzeige in der Vis!?
                    Im Vis-Editor sehe ich die Einträge allerdings.
                    Hier das Bild von der VIS: Vis-Anzeige.png
                    man sieht nur den Bereich der Favoriten, rechts ist gar nichts zu sehen...
                    Weiterhin wäre in der Suche ein Eintrag für Formel-1 ganz gut!
                      Fehlt noch was?
                      Weitere Ideen`?
                      O Online
                      O Online
                      Oli
                      #639
                      @oliverio
                      ich bin vom Adapter voll begeistert, wenn du mir jetzt noch sagst, wie ich die Daten (Beginn, Ende, Beschreibung, Bild) des aktuell ausgewählten Programm, in extra Datenpunkte zum weiterverarbeiten bekomme. Bin ich wunschlos glücklich :-)
                      Eigentlich fehlt nur noch eine zusätzliche Datenquelle, um die fehlenden TV Programme zu integrieren.
                      Oliver
                      • M McOnno
                        OliverIOO Offline
                        OliverIOO Offline
                        OliverIO
                        #640
                        @mconno sagte in Test Adapter tvprogram:
                        bitte adapter (nicht nur die instanz) einmal komplett deinstallieren,
                        dann wieder installieren.
                        zur sicherheit auf der console
                        iobroker upload all
                        eingeben
                        bei allen widgets prüfen, ob der datenpunkt mit cmd des jeweiligen tvs am ende richtig ausgewählt wurde.
                        falls dann immer noch nicht, dann benötige ich die fehler aus der browser console
                        Links im Profil
                        • O Oli
                          @oliverio
                          OliverIOO Offline
                          OliverIOO Offline
                          OliverIO
                          #641
                          @oli sagte in Test Adapter tvprogram:
                          @oliverio
                          was ist das aktuell ausgewählte Programm?
                          Über den javascript-Adapter kannst du alles abrufen:
                          https://github.com/oweitman/iobroker.tvprogram#getserverbroadcastnow
                          und in datenpunkte schreiben.
                          Links im Profil
                            spaceduck
                            #642
                            Ich hab mir gerade mal das Such-Widget eingerichtet... Wenn ich das Suchfeld antippe, dann kommt kurz das on-screen-keyboard hoch, verschwindet nach 1-2 sekunden und ich lande auf einem anderen view. Sehr komisch das ganze - ich vermute jedoch das liegt am System, nicht am Adapter. Ich verwende ein Xoro Megapad 2154 mit Android 7.1
                            Hat irgendwer hier noch so einen Effekt?
                            HP Gen8 16GB / Ubuntu Server 20.04 LTS - Nein, ein Server braucht keine GUI…;-)
                            • S spaceduck
                              OliverIOO Offline
                              OliverIOO Offline
                              OliverIO
                              #643
                              @spaceduck sagte in Test Adapter tvprogram:
                              mach mal zur sicherheit auf der konsole
                              iobroker upload all
                              evtl. hat sich da etwas verhakt. aber das er automatisch den view wechselt ist nicht normal
                              Links im Profil
                              O 1 Antwort Letzte Antwort
                                iobroker upload all
                                O Online
                                O Online
                                Oli
                                #644
                                @oliverio
                                irgendwie mache ich hier was falsch und stoße als Laie wieder mal an meine Grenzen.
                                Ich versuche per Script Daten aus deiner Liste für das aktuelle Programm in einen Datenpunkt zu schreiben
                                let sender = getState("tvprogram.0.tv1.show").val
                                sendTo("tvprogram.0","getServerBroadcastNow",[4],(data)=> setState("javascript.0.TV.Steuerung.Aktuelle Beschreibung",data.events.content.texts.VeryShort.value));
                                sendTo("tvprogram.0","getServerBroadcastNow",[sender],(data)=>console.log(data));
                                Wenn ich die Sendernummer durch eine Variable ersetze wird gar nichts angezeigt
                                20:20:46.626	info	javascript.0 (22208) script.js.TV_Programm.Test: []
                                Wenn ich versuche die Beschreibung in einen Datenpunkt zu schreiben, bekomme ich folgende Warnung
                                20:20:46.625	warn	javascript.0 (22208) TypeError: Cannot read property 'content' of undefined at Object.sendTo [as cb] (script.js.TV_Programm.Test:2:130) at change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5297:71) at Immediate.setImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:234:41) at runCallback (timers.js:705:18) at tryOnImmediate (timers.js:676:5) at processImmediate (timers.js:658:5) at process.topLevelDomainCallback (domain.js:126:23)
                                Was mache ich falsch?
                                Oliver
                                • O Oli
                                  @oliverio
                                  OliverIOO Offline
                                  OliverIOO Offline
                                  OliverIO
                                  #645
                                  @oliverio
                                  ok,
                                  man muss ein array von channelids übergeben, soweit schon mal richtig.
                                  es müssen gültige channelids sein. soweit auch ok.
                                  die 4 steht für Radio Bremen
                                  Ansonsten kann man die channelids hier nachsehen
                                  sendTo("tvprogram.0","getServerData","channels",(data)=>console.log(data));
                                  Die Abfrage der Programmbeschreibung ist dann wie folgt
                                  sendTo("tvprogram.0","getServerBroadcastNow",[4],(data)=> console.log(data[0].events[0].content.texts.VeryShort.value))
                                  Da ich diverse Datenstrukturen immer wieder verwende, ist das Array die Auflistung der verschiedenen Sender und das zweite Array die Auflistung der verschiedenen Events/Sendungen. Bei dieser Funktion sollte da aber immer nur ein event enthalten sein.
                                  je nachdem wieviel channelids ich übergebe, können im ersten array auch mehrere elemente enthalten sein.
                                  Auch sind bei texts.VeryShort.value und texts.Long.value nicht immer Werte enthalten, so das das auch undefined sein kann. das muss man vorher prüfen.
                                  Manchmal gibt es nur VeryShort, manchmal nur Long, manchmal beides, manchmal keins.
                                  Zum prüfen kannst du folgenden Ausdruck verewenden:
                                  var content=(event.content.texts.Long.value) ? event.content.texts.Long.value:(event.content.texts.VeryShort.value)?event.content.texts.VeryShort.value:"";
                                  In der Variable event, muss natürlich auch das event enthalten sein.
                                  Wenn du eine Variable verwendest, dann muss diese auch eine echte Zahl sein und nicht ein String der eine Zahl enthält.
                                  Zur Sicherheit am besten so machen:
                                  sendTo("tvprogram.0","getServerBroadcastNow",[parseInt(sender)],(data)=>console.log(data));
                                  Man kann auch gern in den code der widgets reinschauen.
                                  Der ist hier zu finden:
                                  https://github.com/oweitman/ioBroker.tvprogram/blob/master/widgets/tvprogram/js/tvprogram.js
                                  Noch ein tip: zum besseren Verständnis von JSON-Datenstrukturen kann man das JSON kopieren und direkt in die Developer-Konsole im Browser kopieren. Man muss nur aufpassen, das man richtig kopiert, weil er falsche JSONS dann auch gleich anmeckert. Chrome zumindest zeigt dann die Datenstruktur dann schön zum klicken an. Wenn man das dann noch einer Variable zuweist, dann kann man dort auch den Propertypfad direkt ausprobieren. Das erspart einem einige Edit/Run/Fail/Repeat Schleifen
                                  Links im Profil
                                  • ? Offline
                                    #646
                                    @oliverio sagte in Test Adapter tvprogram:
                                    1. time wird mit Uhrzeit im 24h-Format belegt, bspw 20:15:
                                      Es werden die Sendungen die zu dieser Uhrzeit laufen angezeigt.
                                      Ist die aktuelle Uhrzeit nach dieser Zeit, werden die Sendungen des nächsten Tages zu dieser Uhrzeit angezeigt. auch hier erfolgt automatisch die Aktualisierung.
                                    Wäre es möglich das anpassbar zu machen das er nach der aktuellen Zeit nicht direkt den nächsten Tag anzeigt?
                                    Ich habe eine Übersicht für 20:15 auf meiner Startseite, alle anderen Zeiten wie z.B. was läuft Jetzt, auf einer extra-Seite.
                                    Gehe ich nun um 20:16 auf die VIS seh ich auf der Startseite logischerweise schon den nächsten Tag und müsste dann erst auf die nächste Seite wechseln um zu sehen was jetzt gerade läuft.
                                    OliverIOO 2 Antworten Letzte Antwort
                                      OliverIOO Offline
                                      OliverIOO Offline
                                      OliverIO
                                      #647
                                      @ash2k sagte in Test Adapter tvprogram:
                                      hm stimmt.
                                      ich würde ungern dafür ein weiteres Einstellfeld hinzufügen.
                                      mir würden 2 Möglichkeiten einfallen:
                                      1. folgende Notation
                                        20:15/120
                                        Bedeutet Anzeige für 20:15 für 120 Minuten
                                        Wenn diese Angabe fehlt, werden automatisch 120 Minuten angenommen
                                      Eingabe wie bisher, aber ab 00:00 Uhr wechselt es erst.
                                      Nachteil daran ist, wenn man hier bspw 10:00 Uhr einstellt, dann werden sehr lang die alten Sendungen noch angezeigt.
                                      ich bin für Variante 1)
                                      Links im Profil
                                      ? 2 Antworten Letzte Antwort
                                        hm stimmt.
                                          20:15/120
                                        #648
                                        Ich auch :-)
                                        Geht das jetzt schon so oder musst du es noch anpassen?
                                          OliverIOO Offline
                                          OliverIOO Offline
                                          OliverIO
                                          #649
                                          Jetzt muss ich nochmal nachfragen. Ich hab selbst schonb vergessen wie ich das umgesetzt habe, sehe es aber gerade im code
                                          Hattest du das getestet?
                                          Eigentlich ist es so hinterlegt, das zur eingegebenen Uhrzeit die Sendungen abgefragt werden,
                                          Eine erneute Überprüfung und Aktualisierung erfolgt allerdings erst dann, wenn die letzte Sendung der Liste abgeschlossen wurde, oder bei reload des widgets.
                                          Links im Profil
