  5. [Vorlage] Xiaomi Airpurifier 3H u.a. inkl. Token auslesen.
    5.1k
474 Beiträge 50 Kommentatoren 131.4k Aufrufe 41 Beobachtet
    @michael-mauer
    Ja, hab ich auch:
    2022-07-22 19:05:42.199  - info: javascript.0 (155217) Start javascript script.js.common.nodemihome
    2022-07-22 19:05:42.394  - info: javascript.0 (155217) script.js.common.nodemihome: Starting AllMyMi V.0.2.29
    2022-07-22 19:05:42.500  - info: javascript.0 (155217) script.js.common.nodemihome: registered 0 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
    2022-07-22 19:05:43.259  - info: javascript.0 (155217) script.js.common.nodemihome: Retrieving your in cn registered MiHome Devices
    2022-07-22 19:05:48.288  - error: javascript.0 (155217) An error happened which is most likely from one of your scripts, but the originating script could not be detected.
    2022-07-22 19:05:48.290  - error: javascript.0 (155217) Error: network timeout at: https://api.io.mi.com/app/home/device_list
    2022-07-22 19:05:48.291  - error: javascript.0 (155217) FetchError: network timeout at: https://api.io.mi.com/app/home/device_list
        at Timeout.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-fetch/lib/index.js:1484:13)
        at listOnTimeout (node:internal/timers:564:17)
        at processTimers (node:internal/timers:507:7)
    Issue angelegt:
    https://github.com/Pittini/iobroker-nodemihome/issues/61
    Mike77M Offline
    Mike77M Offline
    Mike77
    schrieb am zuletzt editiert von Mike77
    #421
    @thomas-braun said in [Vorlage] Xiaomi Airpurifier 3H u.a. inkl. Token auslesen.:
    @michael-mauer
    Ja, hab ich auch:
    Issue angelegt:
    auf Github hat jemand eine Lösung für das Timeout gepostet!
    George-Cara commented 8 days ago •
    Hi . For this error with newer JSCRIPT Adapter (>6) the developer should modify the code. until then please go to /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-mihome/lib and edit the file protocol-micloud.js . You will find
    this.REQUEST_TIMEOUT = that you should set to 20000
    This is the proper timeout for me. I think it will work for you also.
    Hat bei mir funktioniert, ich kann den Luftreiniger wieder steuern.
    Mike
    • W Offline
      W Offline
      W0RSCHD
      schrieb am zuletzt editiert von W0RSCHD
      #422
      [SOLVED]
      habe hier jetzt mal soweit alles durch, aber leider nicht wirklich die Lösung gefunden...
      Bei mir startet das Script nicht, es kommt immer folgender Fehler:
      14:17:49.332	info	javascript.0 (28083) Start javascript script.js.MiHomeAll
      14:17:49.342	error	javascript.0 (28083) script.js.MiHomeAll: /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-mihome/lib/devices/yeelink.light.color2.js:8
      14:17:49.342	error	javascript.0 (28083) at script.js.MiHomeAll:3:16
      14:17:49.343	error	javascript.0 (28083) at script.js.MiHomeAll:1186:3
      14:17:49.343	info	javascript.0 (28083) script.js.MiHomeAll: Starting AllMyMi V.0.2.29
      14:17:49.344	info	javascript.0 (28083) script.js.MiHomeAll: registered 0 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
      14:17:49.345	error	javascript.0 (28083) script.js.MiHomeAll: TypeError: Cannot read properties of undefined (reading 'miioProtocol')
      14:17:49.345	error	javascript.0 (28083) at Init (script.js.MiHomeAll:863:12)
      14:17:49.345	error	javascript.0 (28083) at script.js.MiHomeAll:35:1
      14:17:49.345	error	javascript.0 (28083) at script.js.MiHomeAll:1186:3
      NodeJS18 und NPM9.6.2...
      Installiert hab ichs nach Github Anleitung und auch das NPM Modul Mi-Home nochmal händisch nachinstalliert ohne Erfolg. Iobroker läuft auf einem Debian Bullseye.
      Was kann ich noch machen um das Script zum laufen zu bekommen?
      Lösche ich die yeelink.light.color2.js, dann startet das Script und legt die beiden Lampen an, aber es kommt dann die Fehlermeldung Yeelink.light.color2 not supported...
      Kopiere ich die yeelink.light.color2.js wieder in den ordner, dann startet das script komplett nicht, siehe geposteten Log von oben.
      EDIT: Problem gelöst, war mein Fehler, da hat sich die yeelink.light.color2.js irgendwie verhauen, hab die nochmal neu erstellt und den Inhalt händisch rein kopiert, jetzt läuft es :)
      • W W0RSCHD
        [SOLVED]
        #423
        @w0rschd sagte in [Vorlage] Xiaomi Airpurifier 3H u.a. inkl. Token auslesen.:
        Von Hand herumgebastelt...
        Die Kombination kommt so nicht von nodejs im Downstream voreingestellt.
        Schau dir das Thema nodejs und wie man das richtig sauber installiert an.
        • W Offline
          W Offline
          W0RSCHD
          #424
          @thomas-braun ja hast recht, normal ist 9.5.0... lag ja aber letzten Endes nicht da dran
          • W W0RSCHD
            #425
            Fix das, sonst liegt es beim nächsten Problem dann doch daran.
            W 1 Antwort Letzte Antwort
              W Offline
              W Offline
              W0RSCHD
              #426
              @thomas-braun downgrade durchgeführt, bin wieder bei 9.5.0... (npm install -g npm@9.5.0)
              Ein Problem habe ich schon, die Lampen lassen sich an, aber nicht mehr ausschalten :D ...
              Der Datenpunkt POWER geht auf false, die Lampen bleiben aber an
              • W W0RSCHD
                #427
                Schau per
                sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
                uname -m && type -P nodejs node npm npx && nodejs -v && node -v && npm -v && npx -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                nach ob das jetzt senkrecht ist.
                  Schau per
                  W Offline
                  W Offline
                  W0RSCHD
                  #428
                  x86_64
                  /usr/bin/nodejs
                  /usr/bin/node
                  /usr/bin/npm
                  /usr/bin/npx
                  v18.15.0
                  v18.15.0
                  9.5.0
                  9.5.0
                  4.0.24
                  root
                  root
                  /root
                  nodejs:
                   Installiert:           18.15.0-deb-1nodesource1
                   Installationskandidat: 18.15.0-deb-1nodesource1
                   Versionstabelle:
                  *** 18.15.0-deb-1nodesource1 500
                         500 https://deb.nodesource.com/node_18.x bullseye/main amd64 Packages
                         100 /var/lib/dpkg/status
                      12.22.5~dfsg-2~11u1 500
                         500 http://ftp.de.debian.org/debian bullseye/main amd64 Packages
                  • W W0RSCHD
                    x86_64
                    /usr/bin/nodejs
                    /usr/bin/node
                    /usr/bin/npm
                    /usr/bin/npx
                    v18.15.0
                    v18.15.0
                    9.5.0
                    9.5.0
                    4.0.24
                    root
                    root
                    /root
                    nodejs:
                     Versionstabelle:
                    W Offline
                    W Offline
                    W0RSCHD
                    #429
                    16:13:23.049	info	javascript.0 (140952) script.js.MiHomeAll: Keyvalue=true key=0
                    16:13:23.049	info	javascript.0 (140952) script.js.MiHomeAll: {}
                    16:13:23.711	info	javascript.0 (140952) script.js.MiHomeAll: Keyvalue=true key=0
                    16:13:23.711	info	javascript.0 (140952) script.js.MiHomeAll: {}
                    16:13:26.884	info	javascript.0 (140952) script.js.MiHomeAll: Keyvalue=false key=0
                    16:13:26.884	info	javascript.0 (140952) script.js.MiHomeAll: {}
                    16:13:27.519	info	javascript.0 (140952) script.js.MiHomeAll: Keyvalue=false key=0
                    16:13:27.519	info	javascript.0 (140952) script.js.MiHomeAll: {}
                    Gehen aber nur an, aber nicht mehr aus ?!?
                    • Thomas BraunT Online
                      #430
                      @w0rschd
                      Passt, allerdings meld dich als root ab!!
                      Nutze einen Standarduser, wie es vorgesehen ist.
                        @w0rschd
                        W Offline
                        W Offline
                        W0RSCHD
                        #431
                        @thomas-braun ja, das ist klar, so hab ichs auch in der Regel.
                        Nur hast du evtl. auch eine Lösung, dass die Lampen IMMER an gehen, das klappt jedesmal, aber AUS gehen sie nicht mehr, wenn ich den Datenpunkt POWER auf false schalte. Auf false geht er, die Lampen bleiben aber an, ich muss sie dann wieder über die APP ausschalten... Wo könnte der Fehler liegen dass das ausschalten nicht geht?
                          #432
                          Und warum JETZT nicht? Man wird NIE NIE NIE root, weil es einfach NIE NIE NIE dafür einen Grund gibt.
                          Als user einloggen, root-Zugang vergessen,
                          Mit
                          iob stop
                          iob fix
                          iob start
                          den iobroker reparieren.
                            Mit
                            iob stop
                            iob fix
                            iob start
                            W Offline
                            W Offline
                            W0RSCHD
                            #433
                            @thomas-braun ja, danke für den Hinweis, ich verstehe die Problematik schon, fix auch schon durchgeführt...
                            Kann mir jemand evtl. noch bitte sagen warum die Lampen nicht mehr auszuschalten gehen? Es kommt auch kein Fehler und der Datenpunkt bleibt auf False...
                            In der App sieht man aber dass sie noch an sind und nur über die App lassen sie sich wieder ausschalten.
                            Mit der Yeelight App ging das an und ausschalten, die läuft ja leider unter NodeJS18 nicht mehr (was an sich auch egal wäre, wenn das schalten per Script klappen würde)
                            • W W0RSCHD
                              W Offline
                              W Offline
                              W0RSCHD
                              #434
                              Habs hinbekommen, jetzt läufts, habe das Script folgendermassen verändert:
                              "power": async function (obj, val) { await device[obj].setPower(val ? 'on' : 'off') },
                              "power": async function (obj, val) { await device[obj].setPower(val) },
                              • W W0RSCHD
                                W Offline
                                W Offline
                                W0RSCHD
                                #435
                                Eine andere Frage,
                                damit die Yeelight Color 2 mit dem Script funktionieren, muss man ja das File mit dem Profile in den "/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-mihome/lib/devices/yeelink.light.color2.js" Ordner kopieren.
                                Danach Javascript und das eigentliche Script neu starten...
                                Das funktioniert auch soweit gut, allerdings habe ich das Problem, nach einem Neustart von iobroker ist das File wieder weg.
                                Habe gedacht ok, mach ich ein shell script, welches nach einem reboot das file direkt wieder in den Ordner kopiert, aaaaber: Den Ordner gibts nicht direkt nach
                                Reboot, der wird erst wieder erstellt wenn iobroker gestartet ist, bzw. 1-2 Minuten nach Start von iobroker...
                                Somit muss ich das file jedesmal nachdem iobroker gestartet ist wieder hin kopiert werden und und und...
                                Auch wenn ich das File hin kopiere, den Besitzer auf iobroker ändere und die rechte setze, ist nach einem Neustart wieder das File weg.
                                Hat(te) das Problem noch jemand, falls ja wie gelöst damit das dauerhaft vorhanden bleibt?
                                • W W0RSCHD
                                  Eine andere Frage,
                                  haselchenH Offline
                                  haselchenH Offline
                                  haselchen
                                  #436
                                  @w0rschd
                                  Damit wirst Du leben müssen .
                                  Ist tatsächlich so.
                                  Mich stört es schon gar nicht mehr.
                                  1,2 Klicks und alles erledigt .
                                  Passiert schon im Schlaf 😬
                                  • Siggi0904S Offline
                                    Siggi0904S Offline
                                    Siggi0904
                                    #437
                                    Ja, leider reagiert der Entwickler vom node-mihome nicht mehr auf github.
                                    Da liegen einige offene merge-requests und offene Probleme.
                                    Leider geht es da mit der Entwicklung nicht weiter.
                                    • Siggi0904S Siggi0904
                                      haselchenH Offline
                                      haselchenH Offline
                                      haselchen
                                      #438
                                      @siggi0904
                                      Eventuell guckt er ja mal hier vorbei.....
                                      @Pittini
                                      U 1 Antwort Letzte Antwort
                                      • haselchenH haselchen
                                        @siggi0904
                                        @Pittini
                                        U Offline
                                        U Offline
                                        UncleB
                                        #439
                                        Läuft bei euch das Script?
                                        Habs gestern installiert, es tauchen auch alle meine Yeelight Ceiling Lampen auf in den Objekten.
                                        Kann sie aber nicht an bzw. ausschalten.
                                        Moonlight kann ich aktivieren, aber den power state nicht verändern, bzw passiert nix
                                        • tobasiumT Offline
                                          tobasiumT Offline
                                          tobasium
                                          #440
                                          Hallo Zusammen,
                                          Nutzt das Skript noch jemand. Ich habe wieder das login Problem seit einer Weile und bekomme es nicht gefixt:
                                          Error: Pls login before make any request
                                          javascript.0	22:01:11.403	error
                                              at Init (script.js.Smarthome_Tobi.Geräte.Sonstige.mihome:938:50)
                                          Hab mich auch aus der App ausgeloggt weiterhin kein Erfolg. Will sich scheinbar nicht richtig einloggen.
